1SMA5918A
1SMA5918A
    LGE(鲁光)
    SMA(DO-214AC)
    特性:完整电压范围 3.3 至 200 伏。 高反向峰值功率耗散。 高可靠性。 低漏电流
1SMA5918A 数据手册
1SMA5913A-1SMA5957A Silicon Zener Diodes VZ : 3.3 - 240 Volts PD : 1.5 Watts Features  Complete Voltage Range 3.3 to 200 Volts  High peak reverse power dissipation SMA/DO-214AC  High reliability 0. 181( 4. 60) 0. 161( 4. 10)  Low leakage current Mechanical Data 0. 108( 2. 75) 0. 096( 2. 45) 0. 063(1.60) 0. 051(1.30)  Case : SMA (DO-214AC) Molded plastic  Epoxy : UL94V-O rate flame retardant 0. 209( 5. 30) 0. 193( 4. 90)  Lead : Lead formed for Surface mount  Polarity : Color band denotes cathode end  Mounting position : Any 0. 012(0.30) 0. 006(0.15) 0.096(2.45) 0.078(2.00) 0. 059( 1. 50) 0. 035( 0. 90)  Weight : 0.093 gram 0.008(0.20) 0. 002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit DC Power Dissipation at T L = 75 °C (Note1) PD 1.5 Watts Maximum Forward Voltage at IF = 200 mA VF 1.5 Volts Junction Temperature Range TJ - 55 to + 150 °C Storage Temperature Range Ts - 55 to + 150 °C Note : 2 (1) TL = Lead temperature at 5.0 mm ( 0.013 mm thick ) copper land areas. PD, MAXIMUM DISSIPATION (WATTS) Fig. 1 POWER TEMPERATURE DERATING CURVE 1.5 1.2 0.9 0.6 2 5.0 mm ( 0.013 mm thick ) copper land areas. 0.3 0 25 50 75 100 125 150 175 TL, LEAD TEMPERATURE (°C) ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com 1SMA5913A-1SMA5957A Silicon Zener Diodes ELECTRICAL CHARACTERISTICS Rating at = 25 °C ambient temperature unless otherwise specified Nominal Zener Voltage V Z @ I ZT IZT (V) (mA) TYPE Z ZT @ I ZT (Ω ) Maximum Zener Impedance Z ZK @ I ZK (Ω ) IZK (mA) Maximum Reverse Leakage Current IR @ V R (V) (µA) Maximum DC Zener Current IZM (mA) 1SMA5913A 3.3 113.6 10 500 1.0 100 1.0 454 1SMA5914A 3.6 104.2 9.0 500 1.0 75 1.0 416 1SMA5915A 3.9 96.1 7.5 500 1.0 25 1.0 384 1SMA5916A 4.3 87.2 6.0 500 1.0 5.0 1.0 348 1SMA5917A 4.7 79.8 5.0 500 1.0 5.0 1.5 319 1SMA5918A 5.1 73.5 4.0 500 1.0 5.0 2.0 294 1SMA5919A 5.6 66.9 2.0 250 1.0 5.0 3.0 267 1SMA5920A 6.2 60.5 2.0 200 1.0 5.0 4.0 241 1SMA5921A 6.8 55.1 2.5 200 1.0 5.0 5.2 220 1SMA5922A 7.5 50.0 3.0 400 0.5 5.0 6.0 200 1SMA5923A 8.2 45.7 3.5 400 0.5 5.0 6.5 182 1SMA5924A 9.1 41.2 4.0 500 0.5 5.0 7.0 164 1SMA5925A 10 37.5 4.5 500 0.25 5.0 8.0 150 1SMA5926A 11 34.1 5.5 550 0.25 5.0 8.4 136 1SMA5927A 12 31.2 6.5 550 0.25 1.0 9.1 125 1SMA5928A 13 28.8 7.0 550 0.25 1.0 9.9 115 1SMA5929A 15 25.0 9.0 600 0.25 1.0 11.4 100 1SMA5930A 16 23.4 10 600 0.25 1.0 12.2 93 1SMA5931A 18 20.8 12 650 0.25 1.0 13.7 83 1SMA5932A 20 18.7 14 650 0.25 1.0 15.2 75 1SMA5933A 22 17.0 17.5 650 0.25 1.0 16.7 68 1SMA5934A 24 15.6 19 700 0.25 1.0 18.2 62 1SMA5935A 27 13.9 23 700 0.25 1.0 20.6 55 1SMA5936A 30 12.5 26 750 0.25 1.0 22.8 50 1SMA5937A 33 11.4 33 800 0.25 1.0 25.1 45 1SMA5938A 36 10.4 38 850 0.25 1.0 27.4 41 1SMA5939A 39 9.6 45 900 0.25 1.0 29.7 38 1SMA5940A 43 8.7 53 950 0.25 1.0 32.7 34 1SMA5941A 47 8.0 67 1000 0.25 1.0 35.8 31 1SMA5942A 51 7.3 70 1100 0.25 1.0 38.8 29 1SMA5943A 56 6.7 86 1300 0.25 1.0 42.6 26 1SMA5944A 62 6.0 100 1500 0.25 1.0 47.1 24 1SMA5945A 68 5.5 120 1700 0.25 1.0 51.7 22 1SMA5946A 75 5.0 140 2000 0.25 1.0 56.0 20 1SMA5947A 82 4.6 160 2500 0.25 1.0 62.2 18 1SMA5948A 91 4.1 200 3000 0.25 1.0 69.2 16 1SMA5949A 100 3.7 250 3100 0.25 1.0 76.0 15 1SMA5950A 110 3.4 300 4000 0.25 1.0 83.6 13 1SMA5951A 120 3.1 380 4500 0.25 1.0 91.2 12 1SMA5952A 130 2.9 450 5000 0.25 1.0 98.8 11 1SMA5953A 150 2.5 600 6000 0.25 1.0 114.0 10 1SMA5954A 160 2.3 700 6500 0.25 1.0 121.6 9.0 1SMA5955A 180 2.1 900 7000 0.25 1.0 136.8 8.0 1SMA5956A 200 1.9 1200 8000 0.25 1.0 152.0 7.0 1SMA5957A 240 1.5 1600 9000 0.25 1.0 182.4 6.0 Note : ( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates ± 5.0% tolerance. PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMA 5000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
1SMA5918A 价格&库存
很抱歉,暂时无法提供与“1SMA5918A”相匹配的价格&库存,您可以联系我们找货
1SMA5918A
  • 5+0.78311
  • 50+0.62727
  • 150+0.54929
  • 500+0.49076
  • 2500+0.37757
  • 5000+0.35414
库存:2122
1SMA5918A
  • 1+0.34650
  • 5000+0.31570
库存:4893
