BM28B0.6-50DP/2-0.35V(51)
    HRS(广濑)
    SMD,P=0.35mm
    板对板连接器 立贴 针脚数:54Pin 间距:0.35mm 排数:2
BM28B0.6-50DP/2-0.35V(51) 数据手册
BM28 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Feb. 2022 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Features 1. 5A Rated Current Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 Power contacts up to 5A with 0. 2A contacts for signal, space- saving connector. Conventional Product (0.35mm Pitch, 20pos.) BM28-10pos. (+2pos. for power) Power Lines are Concentrated into 2 Power Contacts Instead of Conventional Multiple Signal Contacts. 2. Highly Reliable Contact Design Power Contact : 2-point Contact 2- point contact design for both power and signal ensures a highly reliable contact. Signal Contact : 2-point Contact 3. Superior Mating Operability Guide ribs ensure 0. 3mm self- alignment. Clear tactile click prevents partial mating, increases mating operability. 4. Supports USB4 Gen. 2 ( 10Gbps) Transmission Signal contacts support USB4 Gen. 2 ( 10Gbps) transmission signals. 5. Environmental Compatibility ・Halogen Free Connector does not contain chlorine or bromine exceeding the standard value. * As defined by IEC 61249- 2- 21 Br : 900ppm max. , Cl : 900ppm max. , Br+ Cl : 1500ppm max. 2 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Applications Devices that require low- profile, compact design such as mobile phone, wearable terminals and tablet PCs. NFC Earphone Jack USB Camera Battery Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LCD Main Board Interface Connector Product Specifications Rated Current (Note 1) Rated Voltage 40pos. or Less 44pos. or More Operating Temperature (Note 2) -40 to +85℃ Signal Contact : 0.3A Power Contact : 5A Signal Contact : 0.2A Power Contact : 5A Storage Temperature (Note 3) -10 to +60℃ Operating Humidity Range 20-80% Storage Humidity Range (Note 3) 40-70% 30V AC/DC Note 1 : The total current capacity for connectors with 50 or more signal contacts is 10A for all contacts. (Signal contact only) Note 2 : Includes temperature rise caused by current flow. Note 3 : The term“storage”refers to products stored for long period of time prior to mounting and use. Operating Temperature and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Items Specifications Conditions Contact Resistance Signal contact : 100m Ω Max. Power contact : 30m Ω Max. Measured at 20mV AC, 1kHz, and 1mA Insulation Resistance 1000M Ω Min. Measured at 100V DC Withstanding Voltage No flashover or dielectric breakdown 150V AC for 1 min. Mating Durability Contact resistance : Signal contact : 100m Ω Max. Power contact : 30m Ω Max. 10 cycles Vibration No electrical discontinuity for more than 1μ s. Frequency : 10 to 55Hz ; half amplitude of 0.75mm, 10 cycles in each of 3 axis directions for 5 minutes/cycle Shock Resistance No electrical discontinuity of 1μ s or more. Acceleration : 450m/s2, duration : 11ms, 3-axis half-sine wave in both directions, 3 cycles for each Humidity Resistance Contact resistance : Signal contact : 100m Ω Max. Power contact : 30m Ω Max. Insulation resistance : 100M Ω Min. 96 hours at a temperature of 40 ± 2℃ and a humidity range from 90 to 95% Temperature Cycle Contact resistance : Signal contact : 100m Ω Max. Power contact : 30m Ω Max. Insulation resistance : 100M Ω Min. -55 ± 3℃ : 30 minutes → +85 ± 2℃ : 30 minutes, 5 cycles Solder Heat Resistance No dissolution or resin melting that will affect performance. Reflow : Recommended temperature profile ; Hand solder : Solder iron temperature of 350℃ for 3 seconds Max. 3 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Materials / Finish Product Header Receptacle Part Materials Finish UL Standard Insulator LCP Black UL94V-0 Signal Contact Copper Alloy Gold Plated - Power Contact Copper Alloy Gold Plated - Product Number Structure Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Header/Receptacle BM28 B 0.6 - # DS / 2 - 0.35 V (##) ❶ ❷ ❶ Series Name ❷ Stacking Height ❸ Number of Signal Contacts ❸ ❹ ❺ ❻ ❼ ❽ ❺ Number of Power 2 0.6mm ❻ Contact Pitch 0.35mm 6, 10, 16, 18, 20, 24, 30, 34, 36, 40, 44, 46, 50, 58, 60 ❼ Termination Type V : Straight SMT ❽ Gold Plated Specification and Packaging (51) : Gold Plate Thickness 0.05μ m Embossed Tape Packaging (20,000pcs per reel) (53) : Gold Plate Thickness 0.05μ m Embossed Tape Packaging (1,000pcs per reel) BM28 Contacts ❹ Connector Type DP : Header DS : Receptacle 4 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Header A B 1.5 0.85 P=0.35 0.465 0.12 C ■ Recommended PCB Layout D±0.02 F Min. 1.9 Min. 0 0.25 -0.05 P=0.35±0.02 1.05 +0.05 0 E Min. B±0.02 0 0.57-0.05 1.8 +0.05 0 0.52±0.02 0.18±0.02 Insulation area (Pattern prohibited area) ■ Recommended Metal Mask Dimensions   (Mask Thickness : 0.08mm) 0.52±0.01 D±0.02 B±0.02 0.33±0.01 0.97±0.01 1.8±0.01 0.57±0.01 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.32 P=0.35±0.01 0.18±0.01 Unit : mm Part No. HRS No. No. of Pos. A B C D E F BM28B0.6-6DP/2-0.35V(##) CL0673-5047-0-## 6 2.97 0.70 1.56 1.36 3.85 3.17 BM28B0.6-10DP/2-0.35V(##) CL0673-5043-0-## 10 3.67 1.40 2.26 2.06 4.55 3.87 BM28B0.6-16DP/2-0.35V(##) CL0673-5066-0-## 16 4.72 2.45 3.31 3.11 5.60 4.92 BM28B0.6-18DP/2-0.35V(##) CL0673-5093-0-## 18 5.07 2.80 3.66 3.46 5.95 5.27 BM28B0.6-20DP/2-0.35V(##) CL0673-5039-0-## 20 5.42 3.15 4.01 3.81 6.30 5.62 BM28B0.6-24DP/2-0.35V(##) CL0673-5024-0-## 24 6.12 3.85 4.71 4.51 7.00 6.32 BM28B0.6-30DP/2-0.35V(##) CL0673-5020-0-## 30 7.17 4.90 5.76 5.56 8.05 7.37 BM28B0.6-34DP/2-0.35V(##) CL0673-5064-0-## 34 7.87 5.60 6.46 6.26 8.75 8.07 BM28B0.6-36DP/2-0.35V(##) CL0673-5026-0-## 36 8.22 5.95 6.81 6.61 9.10 8.42 BM28B0.6-40DP/2-0.35V(##) CL0673-5018-0-## 40 8.92 6.65 7.51 7.31 9.80 9.12 BM28B0.6-44DP/2-0.35V(##) CL0673-5049-0-## 44 9.62 7.35 8.21 8.01 10.50 9.82 BM28B0.6-46DP/2-0.35V(##) CL0673-5097-0-## 46 9.97 7.70 8.56 8.36 10.85 10.17 BM28B0.6-50DP/2-0.35V(##) CL0480-0397-0-## 50 10.67 8.40 9.26 9.06 11.55 10.87 BM28B0.6-58DP/2-0.35V(##) CL0480-0378-0-## 58 12.07 9.80 10.66 10.46 12.95 12.27 BM28B0.6-60DP/2-0.35V(##) CL0673-5037-0-## 60 12.42 10.15 11.01 10.81 13.30 12.62 Note : This connector has no polarity. 5 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 20,000pcs per reel 1,000pcs per reel BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Receptacle G B 1.7 P=0.35 0.6 0.12 ■ Recommended PCB Layout H±0.02 H ■ Recommended Metal Mask Dimensions   (Mask Thickness : 0.08mm) H±0.02 0.35±0.02 0.53±0.01 1.9±0.01 1.18±0.01 B±0.02 1.8±0.01 1.9 +0.05 0 0 0.53±0.02 1.24 -0.05 0 1.18 -0.05 B±0.02 1.24±0.01 Insulation area 1.8 +0.05 0 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.28 0.18±0.02 P=0.35±0.01 0.18±0.01 Unit : mm HRS No. No. of Pos. B G H BM28B0.6-6DS/2-0.35V(##) CL0673-5048-0-## 6 0.70 3.65 2.11 BM28B0.6-10DS/2-0.35V(##) CL0673-5044-0-## 10 1.40 4.35 2.81 BM28B0.6-16DS/2-0.35V(##) CL0673-5067-0-## 16 2.45 5.40 3.86 BM28B0.6-18DS/2-0.35V(##) CL0673-5092-0-## 18 2.80 5.75 4.21 BM28B0.6-20DS/2-0.35V(##) CL0673-5040-0-## 20 3.15 6.10 4.56 BM28B0.6-24DS/2-0.35V(##) CL0673-5025-0-## 24 3.85 6.80 5.26 BM28B0.6-30DS/2-0.35V(##) CL0673-5021-0-## 30 4.90 7.85 6.31 BM28B0.6-34DS/2-0.35V(##) CL0673-5065-0-## 34 5.60 8.55 7.01 BM28B0.6-36DS/2-0.35V(##) CL0673-5027-0-## 36 5.95 8.90 7.36 BM28B0.6-40DS/2-0.35V(##) CL0673-5019-0-## 40 6.65 9.60 8.06 BM28B0.6-44DS/2-0.35V(##) CL0673-5050-0-## 44 7.35 10.30 8.76 BM28B0.6-46DS/2-0.35V(##) CL0673-5098-0-## 46 7.70 10.65 9.11 BM28B0.6-50DS/2-0.35V(##) CL0480-0396-0-## 50 8.40 11.35 9.81 BM28B0.6-58DS/2-0.35V(##) CL0480-0377-0-## 58 9.80 12.75 11.21 BM28B0.6-60DS/2-0.35V(##) CL0673-5038-0-## 60 10.15 13.10 11.56 Part No. Note : This connector has no polarity. 6 Purchase Unit (##) : (51) Purchase Unit (##) : (53) 20,000pcs per reel 1,000pcs per reel BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Embossed Tape Dimensions (Complies with IEC 60286-3, JIS C 0806) 12 M±0.3 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. J-J 0.2±0.1 0.65±0.15 0° K J φ1.5 feed hole diameter 12 0° L±0.1 8 J 2±0.5 φ80±1 Product label K-K φ380±2 (Note) K 2 2±0.1 φ1 3± 0. 4±0.1 4±0.1 0. ± 21 φ φ1.5 +0.1 0 ● Reel Dimensions 1.75±0.1 ● Header N±0.5 Q±1 Note : Specification 53 is φ180±2. Unreeling Direction Unit : mm Part No. No. of Pos. L M N Q 6 5.5 12 13.5 17.5 BM28B0.6-10DP/2-0.35V(##) 10 5.5 12 13.5 17.5 BM28B0.6-16DP/2-0.35V(##) 16 7.5 16 17.5 21.5 BM28B0.6-18DP/2-0.35V(##) 18 7.5 16 17.5 21.5 BM28B0.6-20DP/2-0.35V(##) 20 7.5 16 17.5 21.5 BM28B0.6-24DP/2-0.35V(##) 24 7.5 16 17.5 21.5 BM28B0.6-30DP/2-0.35V(##) 30 7.5 16 17.5 21.5 BM28B0.6-34DP/2-0.35V(##) 34 11.5 24 25.4 29.4 BM28B0.6-36DP/2-0.35V(##) 36 11.5 24 25.4 29.4 BM28B0.6-40DP/2-0.35V(##) 40 11.5 24 25.4 29.4 BM28B0.6-44DP/2-0.35V(##) 44 11.5 24 25.4 29.4 BM28B0.6-46DP/2-0.35V(##) 46 11.5 24 25.4 29.4 BM28B0.6-50DP/2-0.35V(##) 50 11.5 24 25.4 29.4 BM28B0.6-58DP/2-0.35V(##) 58 11.5 24 25.4 29.4 BM28B0.6-60DP/2-0.35V(##) 60 11.5 24 25.4 29.4 BM28B0.6-6DP/2-0.35V(##) 7 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A S-S Product label 12 U±0.3 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0° R-R 0.2±0.1 0.8±0.15 φ1.5 feed hole diameter 12 0° T±0.1 8 0. ± 21 φ S R R 2±0.5 φ80±1 S φ380±2 (Note) 2±0.1 2 4±0.1 φ1.5+0.1 0 φ1 3± 0. 4±0.1 ● Reel Dimensions 1.75±0.1 ● Receptacle V±0.5 W±1 Note : Specification 53 is φ180±2. Unreeling Direction Unit : mm Part No. No. of Pos. T U V W 6 5.5 12 13.5 17.5 BM28B0.6-10DS/2-0.35V(##) 10 7.5 16 17.5 21.5 BM28B0.6-16DS/2-0.35V(##) 16 7.5 16 17.5 21.5 BM28B0.6-18DS/2-0.35V(##) 18 7.5 16 17.5 21.5 BM28B0.6-20DS/2-0.35V(##) 20 7.5 16 17.5 21.5 BM28B0.6-24DS/2-0.35V(##) 24 7.5 16 17.5 21.5 BM28B0.6-30DS/2-0.35V(##) 30 11.5 24 25.4 29.4 BM28B0.6-34DS/2-0.35V(##) 34 11.5 24 25.4 29.4 BM28B0.6-36DS/2-0.35V(##) 36 11.5 24 25.4 29.4 BM28B0.6-40DS/2-0.35V(##) 40 11.5 24 25.4 29.4 BM28B0.6-44DS/2-0.35V(##) 44 11.5 24 25.4 29.4 BM28B0.6-46DS/2-0.35V(##) 46 11.5 24 25.4 29.4 BM28B0.6-50DS/2-0.35V(##) 50 11.5 24 25.4 29.4 BM28B0.6-58DS/2-0.35V(##) 58 11.5 24 25.4 29.4 BM28B0.6-60DS/2-0.35V(##) 60 11.5 24 25.4 29.4 BM28B0.6-6DS/2-0.35V(##) 8 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Usage Precautions Recommended Temperature Profile 10sec Max. 250℃ Max. 250 Temperature (℃) 220℃ 200 180℃ 150 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 50 Room temperature 0 Within 60 seconds 90 to 120 sec Preheating Soldering time Heating time (sec) [Conditions] 1. 2. 3. 4. Peak Temperature : Maximum of 250℃ Heating : 220℃ min. for 60 sec. max. Preheating : 150 to 180℃ , 90 to 120 sec. Number of Reflow Cycles : 2 cycles max. Note : The temperature refers to the surface temperature of the board near the connector lead. Reflow mounting in a nitrogen environment is recommended. Recommended Manual Soldering Conditions Soldering Iron Temperature : 340 ± 10℃ ; Soldering Time : within 3 seconds Recommended Metal Mask Thickness and Open Area to PCB Pattern Area Ratio Thickness : 0.08mm Aperture Ratio : Header Side : (Signal Contact) 100%, (Power Contact) 80%, Receptacle Side : 100% Board Warpage Max. of 0.02mm at the center in reference to both ends of the connector Cleaning Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors) Precautions ・Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/deformation to contacts. ・Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ・Excessive prying during unmating/mating may result in damage. ・In the case of hand soldering, please do not apply any flux which could cause flux wicking. ・This product may have slight color differences due to production lot variability, but this does not affect the performance. ・Please refer to the following page for handling precautions when inserting and removing. ・Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials. ・Do not use the connector in non-recommended conditions (i.e., rated current, rated voltage, PCB design and operating environment, etc.). Such usage could lead to material outgassing, ignition, or short-circuit, etc. Refer to the specifications and guidelines for board pattern dimensions, board cautions, and connector treatment. Please contact Hirose if connector usage in conditions other than those described in the specifications and the guidelines is being considered. 9 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Connector Handling Precautions Mating Method BM28B0.6-#DP/2-0.35V BM28B0.6-#DS/2-0.35V Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) When aligning, look for the guide port without applying excessive force. If excessive force is applied, the housing may be damaged or shaved resulting in poor contact resistance, so please be careful. Alignment method OK × 2) When fully aligned the connectors are parallel to each other with restricted longitudinal and lateral movement. Mate them parallel to each other. Fully Aligned Mated 10 BM28 Series/0.35mm Pitch, 0.6mm Stacking Height, FPC-to-Board Connectors Supporting Up to 5A Handling Precautions for Connector Removal 1) Pull out the connector parallel to each other. OK Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2) If the connector cannot be removed by pulling it out parallel to its mating partner, it can be removed by extracting the connector diagonally in the direction of the pitch as shown in the below figure. However, there is a risk that the connector may break if the FPC is not rigid. Please confirm the FPC rigidity at the time of trial production. OK Pitch Direction 3) Do not remove the connector by pulling from the FPC corner as shown below. Pulling from the FPC corner may result in connector and contact damage. × Corner Direction 4) Please provide a reinforcing plate for the FPC. Insufficient FPC rigidity may result in connector breakage as shown in the below figure. Please check the repeated mechanical operation of the FPC before use. A reinforcing plate of 0. 3mm or thicker made of glass epoxy material is recommended, or 0. 2mm or thicker stainless steel is recommended. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 2/ 2022. Contents are subject to change without notice for the purpose of improvements. 11
BM28B0.6-50DP/2-0.35V(51) 价格&库存
很抱歉,暂时无法提供与“BM28B0.6-50DP/2-0.35V(51)”相匹配的价格&库存,您可以联系我们找货
