BT816Q-T
BT816Q-T
    BRIDGETEK
    VQFN64_9X9MM
    BT81X系列是一种易于使用的图形控制器,面向嵌入式应用以生成高质量的人机界面(HMI)。它具有以下特点:- 高级嵌入式视频引擎(EVE),支持高分辨率图形和视频播放- BT815/6功能包括图形控制...
BT816Q-T 数据手册
BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Bridgetek Pte Ltd BT81X (815/6) Advanced Embedded Video Engine Datasheet The BT81X Series is an easy to use graphic controllers targeted at embedded applications to generate high-quality Human Machine Interfaces (HMIs). It has the following features:  Advanced Embedded Video Engine(EVE) with high resolution graphics and video playback  BT815/6 functionality includes graphic control, audio control, and touch control interface.  Support multiple widgets for simplified design implementation  Built-in graphics operations allow users with little expertise to create high-quality displays  Support Adaptive Scalable Texture Compression (ASTC) format to save considerable memory space for larger fonts and graphics images  Support external QSPI NOR flash up to 2Gbit to store and fetch graphic elements (image, font, widget etc.)  Support 4-wire resistive touch screen (BT816)  Support capacitive touch screen with up to 5 touch point detection (BT815)  Hardware engine can recognize touch tags and track touch movement. Provides notification for up to 255 touch tags.  Enhanced sketch processing  Built-in 12MHz crystal oscillator with PLL providing programmable system clock up to 72MHz  Support crystal-less operation with internal relaxation clock source  Video RGB parallel output; configurable to support PCLK up to 72MHz and R/G/B output of 1 to 8 bits  Programmable timing to adjust HSYNC and VSYNC timing, enabling interface to numerous displays  Support for LCD display with resolution up to SVGA (800x600) and formats with data enable (DE) mode or VSYNC/HSYNC mode  Support landscape and portrait orientations  Display enable control output to LCD panel  Integrated 1MByte graphics RAM, no frame buffer RAM required  Support playback of motion-JPEG encoded AVI videos  Mono audio channel output with Sigma-delta modulation  Built-in sound synthesizer  Audio wave playback for mono 8-bit linear PCM, 4-bit ADPCM and µ-Law coding format at sampling frequencies from 8 kHz to 48 kHz. Built-in digital filter reduces the system design complexity of external filtering  PWM output for display backlight dimming control  Advanced object oriented architecture enables low cost MPU/MCU as system host using SPI interfaces  Support SPI data lines in single, dual or quad mode; SPI clock up to 30MHz  Power mode control allows the chip to be put in power down, sleep and standby states  Supports I/O voltage from 1.8V to 3.3V  Internal voltage regulator supplies 1.2V to the digital core  Built-in Power-on-reset circuit  -40°C to 85°C extended operating temperature range  Available in a compact package, RoHS compliant Pb-free, VQFN-64 Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Bridgetek Pte Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document prov ides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H Copyright © Bridgetek Pte Ltd 1 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 1 Typical Applications  Point of Sales Machines  Breathalyzers  Multi-function Printers  Gas chromatographs  Instrumentation  Power meter  Home Security Systems  Home appliance devices  Graphic touch pad – remote, dial pad  Set-top box  Tele / Video Conference Systems  Thermostats  Phones and Switchboards  Sprinkler system displays  Medical Appliances  Medical Appliances  Blood Pressure displays  GPS / Satnav  Heart monitors  Vending Machine Control Panels  Glucose level displays  Elevator Controls  ……and many more 1.1 Part Numbers Part Number Description Package BT815Q-x EVE with ASTC and external NOR flash, capacitive touch 64 Pin VQFN, body 9 x 9 mm, pitch 0.5mm BT816Q-x EVE with ASTC and external NOR flash, resistive touch 64 Pin VQFN, body 9 x 9 mm, pitch 0.5mm Table 1- BT815/6 Embedded Video Engine Part Numbers Note: Packaging codes for x is: -R: Taped and Reel (3000 pcs per reel) -T: Tray packing (260 pcs per tray) For example: BT815Q-R is 3000 VQFN pieces in taped and reel packaging Copyright © Bridgetek Pte Ltd 2 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 2 Block Diagram Figure 2-1 BT815/6 Block Diagram For a description of each function please refer to Section 4. Figure 2-2 BT815/6 System Design Diagram BT815/6 with EVE (Embedded Video Engine) technology simplifies the system architecture for advanced human machine interfaces (HMIs) by providing support for display, audio, and touch as well as an object oriented architecture approach that extends from display creation to the rendering of the graphics. Copyright © Bridgetek Pte Ltd 3 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Table of Contents 1 Typical Applications....................................................... 2 1.1 Part Numbers ............................................................................. 2 2 Block Diagram ............................................................... 3 3 Device Pin Out and Signal Description ........................... 7 3.1 BT815 VQFN-64 Package Pin Out ............................................... 7 3.2 BT816 VQFN-64 Package Pin Out ............................................... 7 3.3 Pin Description .......................................................................... 8 4 Functional Description ................................................. 12 4.1 Quad SPI Host Interface .......................................................... 12 4.1.1 QSPI Interface .......................................................................................... 12 4.1.2 Serial Data Protocol ................................................................................... 14 4.1.3 Host Memory Read .................................................................................... 14 4.1.4 Host Memory Write.................................................................................... 15 4.1.5 Host Command ......................................................................................... 15 4.1.6 Interrupts ................................................................................................ 19 4.2 System Clock ........................................................................... 20 4.2.1 Clock Source ............................................................................................ 20 4.2.2 Phase Locked Loop .................................................................................... 21 4.2.3 Clock Enable ............................................................................................. 21 4.2.4 Clock Frequency ........................................................................................ 21 4.3 Graphics Engine ....................................................................... 21 4.3.1 Introduction ............................................................................................. 21 4.3.2 ASTC ....................................................................................................... 22 4.3.3 ROM and RAM Fonts .................................................................................. 22 4.4 SPI NOR Flash Interface .......................................................... 26 4.5 Parallel RGB Interface ............................................................. 26 4.6 Miscellaneous Control .............................................................. 29 4.6.1 Backlight Control Pin ................................................................................. 29 4.6.2 DISP Control Pin ....................................................................................... 29 4.6.3 General Purpose IO pins ............................................................................ 29 4.6.4 Pins Drive Current Control .......................................................................... 30 4.7 Audio Engine ............................................................................ 30 4.7.1 Sound Synthesizer .................................................................................... 30 4.7.2 Audio Playback ......................................................................................... 32 Copyright © Bridgetek Pte Ltd 4 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 4.8 Clearance No.: BRT#126 Touch-Screen Engine ............................................................... 33 4.8.1 Resistive Touch Control .............................................................................. 33 4.8.2 Capacitive Touch Control ............................................................................ 34 4.8.3 Compatibility Mode .................................................................................... 34 4.8.4 Extended Mode ......................................................................................... 35 4.8.5 Short-Circuit Protection .............................................................................. 35 4.8.6 Capacitive Touch Configuration ................................................................... 35 4.8.7 Host Driven Multi-Touch ............................................................................. 35 4.8.8 Touch Detection in none-ACTIVE State ........................................................ 37 4.9 Power Management ................................................................. 37 4.9.1 Power Supply ........................................................................................... 37 4.9.2 Internal Regulator and POR ........................................................................ 38 4.9.3 Power Modes ............................................................................................ 38 4.9.4 Reset and Boot-up Sequence ...................................................................... 40 4.9.5 Pin Status at Different Power States ............................................................ 40 5 Memory Map ................................................................ 42 5.1 Registers.................................................................................. 42 5.2 Chip ID..................................................................................... 47 6 Devices Characteristics and Ratings ............................ 48 6.1 Absolute Maximum Ratings ...................................................... 48 6.2 ESD and Latch-up Specifications .............................................. 48 6.3 DC Characteristics .................................................................... 48 6.4 AC Characteristics .................................................................... 51 6.4.1 System Clock and Reset ............................................................................. 51 6.4.2 SPI Interface Timing .................................................................................. 52 6.4.3 RGB Interface Timing ................................................................................ 53 7 Application Examples .................................................. 54 8 Package Parameters .................................................... 56 8.1 Part Markings .......................................................................... 56 8.1.1 Top Side .................................................................................................. 56 8.1.2 Bottom Side ............................................................................................. 56 8.2 VQFN-64 Package Dimensions ................................................. 57 8.3 Solder Reflow Profile ............................................................... 57 9 Contact Information .................................................... 59 Appendix A – References ................................................... 60 Copyright © Bridgetek Pte Ltd 5 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Document References ...................................................................... 60 Acronyms and Abbreviations............................................................ 60 Appendix B - List of Figures and Tables ............................. 62 List of Figures .................................................................................. 62 List of Tables.................................................................................... 62 Appendix C - Revision History ............................................ 64 Copyright © Bridgetek Pte Ltd 6 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 3 Device Pin Out and Signal Description 3.1 BT815 VQFN-64 Package Pin Out Figure 3-1 Pin Configuration BT815 VQFN-64(Top View) 3.2 BT816 VQFN-64 Package Pin Out Figure 3-2 Pin Configuration BT816 VQFN-64 (Top View) Copyright © Bridgetek Pte Ltd 7 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 3.3 Pin Description Pin Number Pin Name Type BT815 BT816 1 1 R0 O 2 2 VCC1V2 P 3 3 SCK I 4 4 MISO I/O Description Bit 0 of Red RGB signals Powered from pin VCCIO2 1.2V digital core supply. Connect to VOUT1V2 pin. SPI clock input Powered from pin VCCIO1 SPI Single mode: SPI MISO output SPI Dual/Quad mode: SPI data line 1 Powered from pin VCCIO1 SPI Single mode: SPI MOSI input 5 5 MOSI I/O SPI Dual/Quad mode: SPI data line 0 Powered from pin VCCIO1 SPI slave select input 6 6 CS_N I Powered from pin VCCIO1 SPI Single/Dual mode: General purpose IO 0 7 7 GPIO0/IO2 I/O SPI Quad mode: SPI data line 2 Powered from pin VCCIO1 SPI Single/Dual mode: General purpose IO 1 8 8 GPIO1/IO3 I/O SPI Quad mode: SPI data line 3 Powered from pin VCCIO1 9 9 VCCIO1 P 10 10 GPIO2 I/O 11 11 INT_N OD/O I/O power supply for host interface pins. Support 1.8V, 2.5V or 3.3V. General purpose IO 2 12 12 PD_N I Powered from pin VCCIO1 Interrupt to host, open drain output(default) or pushpull output, active low Chip power down mode control input, active low. Connect to MCU GPIO for power management or hardware reset function, or pulled up to VCCIO1 through 47kΩ resistor and 100nF to ground. Powered from pin VCCIO1 General purpose IO 3 13 13 GPIO3 I/O 14 14 SPIM_SCLK O Powered from pin VCCIO1 SPI flash clock output line Powered from pin VCCIO3 SPI flash chip select output line 15 15 SPIM_SS_N O 16 16 SPIM_MOSI I/O Copyright © Bridgetek Pte Ltd Powered from pin VCCIO3 SPI flash MOSI line Powered from pin VCCIO3 8 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Pin Number Pin Name BT815 Type Description BT816 I/O power supply for SPIM pins. Support 1.8V, 2.5V or 3.3V. 17 17 VCCIO3 P 18 18 SPIM_MISO I/O 19 19 SPIM_IO2 I/O 20 20 SPIM_IO3 I/O VCCIO3 can be connected to different voltage with VCCIO1 or VCCIO2. SPI flash MISO line Powered from pin VCCIO3 SPI flash IO2 line Powered from pin VCCIO3 SPI flash IO3 line Powered from pin VCCIO3 Crystal oscillator or clock input 21 21 X1/CLK I 3.3V peak input allowed. Powered from pin VCC. Crystal oscillator output 22 22 X2 O 23 23 GND P Ground 24 24 VCC P 3.3V power supply input. 25 25 VOUT1V2 P 1.2V regulator output pin. Connect a 4.7uF decoupling capacitor to GND. 26 26 AUDIO_L O 27 27 VCCA P 3.3V power supply input. 28 28 VCCIO2 P I/O power supply for RGB and touch pins. Supports 1.8V, 2.5V or 3.3V. VCCIO2 can be connected to different voltage with VCCIO1 or VCCIO3. Powered from pin VCC. Audio Sigma-delta output - - - 29 30 31 XP YP XM AI/O AI/O AI/O Powered from pin VCCA Connect to X right electrode of 4-wire resistive touchscreen panel. Powered from pin VCCIO2. Connect to Y top electrode of 4-wire resistive touchscreen panel. Powered from pin VCCIO2. Connect to X left electrode of 4-wire resistive touchscreen panel. Powered from pin VCCIO2. - 32 YM AI/O 29 - CTP_RST_N O 30 - CTP_INT_N I/O Connect to Y bottom electrode of 4-wire resistive touch-screen panel. Powered from pin VCCIO2. Connect to reset pin of the CTPM. Powered from pin VCCIO2. Connect to interrupt pin of the CTPM. Copyright © Bridgetek Pte Ltd Powered from pin VCCIO2. 9 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Pin Number Pin Name Type BT815 BT816 31 - CTP_SCL I/OD 32 - CTP_SDA I/OD 33 33 GND P 34 34 BACKLIGHT O 35 35 DE O 36 36 VSYNC O 37 37 HSYNC O 38 38 DISP O 39 39 PCLK O 40 40 B7 O 41 41 B6 O 42 42 B5 O 43 43 B4 O 44 44 B3 O 45 45 B2 O 46 46 B1 O 47 47 B0 O 48 48 GND P 49 49 G7 O 50 50 G6 O 51 51 G5 O Description Connect to I2C SCL pin of the CTPM. Powered from pin VCCIO2. Connect to I2C SDA pin of the CTPM. Powered from pin VCCIO2. Ground LED Backlight brightness PWM control signal. Powered from pin VCCIO2. LCD Data Enable. Powered from pin VCCIO2. LCD Vertical Sync. Powered from pin VCCIO2. LCD Horizontal Sync. Powered from pin VCCIO2. LCD Display Enable. Powered from pin VCCIO2. LCD Pixel Clock. Powered from pin VCCIO2. Bit 7 of Blue RGB signals. Powered from pin VCCIO2. Bit 6 of Blue RGB signals. Powered from pin VCCIO2. Bit 5 of Blue RGB signals. Powered from pin VCCIO2. Bit 4 of Blue RGB signals. Powered from pin VCCIO2. Bit 3 of Blue RGB signals. Powered from pin VCCIO2. Bit 2 of Blue RGB signals. Powered from pin VCCIO2. Bit 1 of Blue RGB signals. Powered from pin VCCIO2. Bit 0 of Blue RGB signals. Powered from pin VCCIO2. Ground Bit 7 of Green RGB signals. Powered from pin VCCIO2. Bit 6 of Green RGB signals. Copyright © Bridgetek Pte Ltd Powered from pin VCCIO2. Bit 5 of Green RGB signals. 10 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Pin Number Pin Name BT815 Type Description BT816 Powered from pin VCCIO2. Bit 4 of Green RGB signals. 52 52 G4 O 53 53 G3 O 54 54 G2 O 55 55 G1 O 56 56 G0 O 57 57 VCC1V2 P 58 58 R7 O 59 59 R6 O 60 60 R5 O 61 61 R4 O 62 62 R3 O 63 63 R2 O 64 64 R1 O EP EP GND P Powered from pin VCCIO2. Bit 3 of Green RGB signals. Powered from pin VCCIO2. Bit 2 of Green RGB signals. Powered from pin VCCIO2. Bit 1 of Green RGB signals. Powered from pin VCCIO2. Bit 0 of Green RGB signals. Powered from pin VCCIO2. 1.2V digital core supply. Connect to VOUT1V2 pin. Bit 7 of Red RGB signals. Powered from pin VCCIO2. Bit 6 of Red RGB signals. Powered from pin VCCIO2. Bit 5 of Red RGB signals. Powered from pin VCCIO2. Bit 4 of Red RGB signals. Powered from pin VCCIO2. Bit 3 of Red RGB signals. Powered from pin VCCIO2. Bit 2 of Red RGB signals. Powered from pin VCCIO2. Bit 1 of Red RGB signals Powered from pin VCCIO2 Ground. Exposed thermal pad. Table 3-1 BT815/6 Pin Description Note: P : Power or ground I : Input O : Output OD : Open drain output I/O : Bi-direction Input and Output AI/O: Analog Input and Output Copyright © Bridgetek Pte Ltd 11 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 4 Functional Description The BT815/6 is a single chip, embedded video controller with the following functional blocks:         Quad SPI Host Interface Quad SPI Flash Interface System Clock Graphics Engine Parallel RGB video interface Audio Engine Touch-screen support and interface (Resistive = BT816 / Capacitive – BT815) Power Management The functions for each block are briefly described in the following subsections. 4.1 Quad SPI Host Interface The BT815/6 uses a quad serial peripheral interface (QSPI) to communicate with host microcontrollers and microprocessors. 4.1.1 QSPI Interface The QSPI slave interface operates up to 30MHz. Only SPI mode 0 is supported. Refer to section 6.4.2 for detailed timing specification. The QSPI can be configured as a SPI slave in SINGLE, DUAL or QUAD channel modes. By default the SPI slave operates in the SINGLE channel mode with MOSI as input from the master and MISO as output to the master. DUAL and QUAD channel modes can be configured through the SPI slave itself. To change the channel modes, write to register REG_SPI_WIDTH. The table below depicts the setting. REG_SPI_WIDTH[1:0] Channel Mode Data pins Max bus speed 00 SINGLE – default mode MISO, MOSI 30 MHz 01 DUAL MOSI, MISO 30 MHz 10 QUAD MOSI, MISO, IO2, IO3 30 MHz 11 Reserved - - Table 4-1 QSPI Channel Selection With DUAL/QUAD channel modes, the SPI data ports are now unidirectional. In these modes, each SPI transaction (signified by CS_N going active low) will begin with the data ports set as inputs. Hence, for writing to the BT815/6, the protocol will operate as in FT800, with “WR-Command/Addr2, Addr1, Addr0, DataX, DataY, DataZ …” The write operation is considered complete when CS_N goes inactive high. For reading from the BT815/6, the protocol will still operate as in FT800, with “RD-Command/Addr2, Addr1, Addr0, Dummy-Byte, DataX, DataY, DataZ”. However as the data ports are now unidirectional, a change of port direction will occur before DataX is clocked out of the BT815/6. Therefore it is important that the firmware controlling the SPI master changes the SPI master data port direction to “input” after transmitting Addr0. The BT815/6 will not change the port direction till it starts to clock out DataX. Hence, the Dummy-Byte cycles will be used as a change-over period when neither the SPI master nor slave will be driving the bus; the data paths thus must have pull-ups/pull-downs. The SPI slave from the BT815/6 will reset all its data ports’ direction to input once CS_N goes inactive high (i.e. at the end of the current SPI master transaction). The diagram depicts the behaviour of both the SPI master and slave in the master read case. Copyright © Bridgetek Pte Ltd 12 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 SS WR / Addr2 Addr 1 Addr 2 Dum my Data X Data 0 SPI Slave drives the data bus SPI Slave resets data ports into inputs SPI Master drives the data bus Bus not driven SPI Master changes data ports into inputs Data Y SPI Slave changes data ports into outputs Figure 4-1 SPI Master and Slave in the Master Read Case In the DUAL channel mode, MISO (MSB) and MOSI are used while in the QUAD channel mode. IO3 (MSB), IO2, MISO and MOSI are used. Figure 4-2 illustrates a direct connection to a 1.8-3.3V IO MPU/MCU with single or dual SPI interface. Figure 4-3 illustrates a direct connection to a 1.8-3.3V IO MPU/MCU with Quad SPI interface. 1.8-3.3V 3.3V VCCIO1 MPU/MCU 4.7k SCLK VCC BT815/6 SCK MISO MISO MOSI MOSI SS# CS_N PD# PD_N INT# INT_N GND GND Figure 4-2 Single/Dual SPI Interface connection Copyright © Bridgetek Pte Ltd 13 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 1.8-3.3V Clearance No.: BRT#126 3.3V VCCIO1 MPU/MCU 4.7k VCC BT815/6 SCLK SCK MISO MISO MOSI MOSI IO2 IO2 IO3 IO3 SS# CS_N PD# PD_N INT# INT_N GND GND Figure 4-3 Quad SPI Interface connection 4.1.2 Serial Data Protocol The BT815/6 appears to the host MPU/MCU as a memory-mapped SPI device. The host communicates with the BT815/6 using reads and writes to a large (4 megabyte) address space. Within this address space are dedicated areas for graphics, audio and touch control. Refer to section 5 for the detailed memory map. The host reads and writes the BT815/6 address space using SPI transactions. These transactions are memory read, memory write and command write. Serial data is sent by the most significant bit first. Each transaction starts with CS_N goes low, and ends when CS_N goes high. There’s no limit on data length within one transaction, as long as the memory address is continuous. 4.1.3 Host Memory Read For SPI memory read transactions, the host sends two zero bits, followed by the 22-bit address. This is followed by a dummy byte. After the dummy byte, the BT815/6 responds to each host byte with read data bytes. 7 6 0 0 5 4 3 2 1 0 Address [21:16] Address [15:8] Write Address Address [7:0] Dummy byte Byte 0 Read Data Byte n Table 4-2 Host Memory Read Transaction Copyright © Bridgetek Pte Ltd 14 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 4.1.4 Clearance No.: BRT#126 Host Memory Write For SPI memory write transactions, the host sends a ‘1’ bit and ‘0’ bit, followed by the 22-bit address. This is followed by the write data. 7 6 1 0 5 4 3 2 1 0 Address [21:16] Write Address Address [15:8] Address [7:0] Byte 0 Write Data Byte n Table 4-3 Host Memory Write Transaction 4.1.5 Host Command When sending a command, the host transmits a 3 byte command. Table 4-5 Host Command List Error! Reference source not found. lists all the host command functions. For SPI command transactions, the host sends a ‘0’ bit and ‘1’ bit, followed by the 6-bit command code. The 2nd byte can be either 00h, or the parameter of that command. The 3rd byte is fixed at 00h. All SPI commands except the system reset can only be executed when the SPI is in the Single channel mode. They will be ignored when the SPI is in either Dual or Quad channel mode. Some commands are used to configure the device and these configurations will be reset upon receiving the SPI PWRDOWN command, except those that configure the pin state during power down. These commands will be sticky unless reconfigured or power-on-reset (POR) occurs. 7 6 0 1 5 4 3 2 1 0 Command [5:0] 1st Byte 2nd Byte Parameter for the command 0 0 0 0 0 0 0 0 3rd Byte Table 4-4 Host Command Transaction 1st Byte 2nd byte 3rd byte Command Description Power Modes 00000000b 00000000b 00000000b 00h ACTIVE 01000001b 00000000b 00000000b 41h STANDBY Copyright © Bridgetek Pte Ltd Switch from Standby/Sleep/PWRDOWN modes to active mode. Dummy memory read from address 0(read twice) generates ACTIVE command. Put BT815/6 core to standby mode. Clock gate off, PLL and Oscillator remain on (default). ACTIVE command to wake up. 15 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 1st Byte 2nd byte 3rd byte Command Description 01000010b 00000000b 00000000b 42h SLEEP Put BT815/6 core to sleep mode. Clock gate off, PLL and Oscillator off. ACTIVE command to wake up. 00000000b 00000000b 43h/50h PWRDOWN 01000011b 01010000b Switch off 1.2V core voltage to the digital core circuits. Clock, PLL and Oscillator off. SPI is alive. ACTIVE command to wake up. Clock and Reset 01000100b 00000000b 00000000b 44h CLKEXT 01001000b 00000000b 00000000b 48h CLKINT Select PLL input from external crystal oscillator or external input clock. No effect if external clock is already selected, otherwise a system reset will be generated Select PLL input from internal relaxation oscillator (default). No effect if internal clock is already selected, otherwise a system reset will be generated Select the system clock frequency. Note that software shall also update the register value for REG_FREQUENCY to align with system clock selected. This command will only be effective when the PLL is stopped (SLEEP mode). For compatibility to FT800/FT801, set Byte2 to 0x00. This will set the PLL clock back to default (60 MHz). 01100001b 01100010b 01101000b xx 00000000b 00000000b 00000000b 61h/62h CLKSEL 68h RST_PULSE Byte2 [5:0] sets the clock frequency 0 Set to default clock speed 1 Reserved 2 to 6 2 to 6 times the osc frequency (i.e. 24 to 72MHz with 12MHz oscillator) Byte2 [7:6] sets the PLL range 0 When Byte2[5:0] = 0, 2, 3 1 When Byte2[5:0] = 4, 5, 6 Send reset pulse to BT815/6 core. The behaviour is the same as POR except that settings done through SPI commands will not be affected Configuration 01110000b xx 00000000b 70h PINDRIVE This will set the drive strength for various pins. For FT800/FT801 compatibility, by default those settings are from the GPIO registers. BT815/6 supports setting the drive strength via SPI command instead. When PINDRIVE for a pin from the SPI command is not updated, the drive strength Copyright © Bridgetek Pte Ltd 16 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 1st Byte 2nd byte 3rd byte Command Clearance No.: BRT#126 Description will be determined by its corresponding GPIO register bits, if they exist. If they don’t exist, a hard coded setting is used. Please refer to Table 4-21 for default values. When PINDRIVE for a pin from the SPI command is updated, it will override the corresponding setting in the GPIO register bits. Byte2 determines which pin and the setting are to be updated. Byte2[1:0] determine the drive strength. For pins R[7:0]/G[7:0]/B[7:0]/PCLK/DISP/HSYNC/V SYNC/DE/BACKLIGHT: Byte2[1:0] Drive Strength 0h 1.2mA 1h 2.4mA 2h 3.6mA 3h 4.8mA For all other pins: Byte2[1:0] Drive Strength 0h 5mA 1h 10mA 2h 15mA 3h 20mA Byte2[7:2] determine which pin/pin group to set: Copyright © Bridgetek Pte Ltd Byte2 [7:2] Pin / Pin Group 00h GPIO 0 01h GPIO 1 02h GPIO 2 03h GPIO 3 04-07h Reserved 17 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 1st Byte 2nd byte 3rd byte Command Clearance No.: BRT#126 Description 08h DISP 09h DE 0Ah VSYNC / HSYNC 0Bh PCLK 0Ch BACKLIGHT 0Dh R[7:0], G[7:0], B[7:0] 0Eh AUDIO_L 0Fh INT_N 10h CTP_RST_N 11h CTP_SCL 12h CTP_SDA 13h SPI MISO/MOSI/IO2/IO3 14h SPIM_SCLK 15h SPIM_SS_N 16h SPIM_MISO 17h SPIM_MOSI 18h SPIM_IO2 19h SPIM_IO3 Others Reserved Note: GPIO0 shares the same pin as SPI IO2 and GPIO1 with SPI IO3. When SPI is set in Quad mode, IO2 and IO3 will inherit the drive strength set in GROUP 13h; otherwise GPIO0 and GPIO1 will inherit the drive strength from GROUP 00h and 01h respectively. During power down, all output and in/out pins will not be driven. Please refer to Table 4-21 for their default power down state. 01110001b xx 00000000b Copyright © Bridgetek Pte Ltd 71h PIN_PD_STA TE These settings will only be effective during power down and will not affect normal operations. Also note that these configuration bits are sticky and, unlike other configuration bits, will not reset to default values upon exiting power down. Only POR will reset them. 18 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 1st Byte 2nd byte 3rd byte Command Clearance No.: BRT#126 Description Byte2 determines which pin and the setting are to be updated. Byte2[1:0] determine the pin state. Byte2 [1:0] Pin Setting 0h Float 1h Pull-Down 2h Pull-Up 3h Reserved Byte2[7:2] determine which pin/pin group to set. Please refer to the PINDRIVE entry. table in command Table 4-5 Host Command List Note: Any command code not specified is reserved and should not be used by the software 4.1.6 Interrupts The interrupt output pin is enabled by REG_INT_EN. When REG_INT_EN is 0, INT_N is tri-state (pulled to high by external pull-up resistor). When REG_INT_EN is 1, INT_N is driven low when any of the interrupt flags in REG_INT_FLAGS are high, after masking with REG_INT_MASK. Writing a ‘1’ in any bit of REG_INT_MASK will enable the corresponding interrupt. Each bit in REG_INT_FLAGS is set by a corresponding interrupt source. REG_INT_FLAGS is readable by the host at any time, and clears when read. The INT_N pin is open-drain (OD) output by default. It can be configured to push-pull output by register REG_GPIOX. Bit 7 6 5 4 Interrupt Sources CONVCOMPLETE CMDFLAG CMDEMPTY PLAYBACK Conditions Touch-screen conversions completed Command FIFO flag Command FIFO empty Audio playback ended Bit 3 2 1 0 Interrupt Sources SOUND TAG TOUCH SWAP Conditions Sound effect ended Touch-screen tag value change touch detected Display list swap occurred Table 4-6 Interrupt Flags bit assignment Copyright © Bridgetek Pte Ltd 19 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 4.2 System Clock 4.2.1 Clock Source The BT815/6 can be configured to use any of the three clock sources for system clock:  Internal relaxation oscillator clock (default)  External 12MHz crystal  External 12MHz square wave clock Figure 4-4, Figure 4-5 and Figure 4-6 show the pin connections for these clock options. Figure 4-4 Internal relaxation oscillator connection Figure 4-5 Crystal Oscillator Connection Figure 4-6 External Clock Input 4.2.2 Phase Locked Loop The internal PLL takes an input clock from the oscillator, and generates clocks to all internal circuits, including the graphics engine, audio engine and touch engine. Copyright © Bridgetek Pte Ltd 20 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 4.2.3 Clearance No.: BRT#126 Clock Enable At power-on the BT815/6 is in sleep mode. The internal relaxation oscillator is selected for the PLL clock source. The system clock will be enabled when the following step is executed:  Host sends an “ACTIVE” command If the application chooses to use the external clock source (12MHz crystal or clock), the following steps shall be executed:   4.2.4 Host sends a “CLKEXT” command Host sends an “ACTIVE” command Clock Frequency By default the system clock is running at 60MHz when the input clock is 12MHz. The host is allowed to switch the system clock to other frequencies (72MHz, 48MHz, 36MHz, and 24MHz) by the host command “CLKSEL”. The clock switching command shall be sent in SLEEP mode only. After the chip is put into Active mode, software shall update the REG_FREQUENCY value to align with the chosen system clock frequency by CLKSEL command, if the default 60MHz is changed. When using the internal relaxation oscillator, its clock frequency is trimmed to be 12MHz at factory. Software is allowed to change the frequency to a lower value by programming the register REG_TRIM. Note that software shall not change the internal oscillator frequency to be higher than 12MHz. 4.3 Graphics Engine 4.3.1 Introduction The graphics engine executes the display list once for every horizontal line. It executes the primitive objects in the display list and constructs the display line buffer. The horizontal pixel content in the line buffer is updated if the object is visible at the horizontal line. Main features of the graphics engine are:        The primitive objects supported by the graphics processor are: lines, points, rectangles, bitmaps (comprehensive set of formats), text display, plotting bar graph, edge strips, and line strips, etc. Operations such as stencil test, alpha blending and masking are useful for creating a rich set of effects such as shadows, transitions, reveals, fades and wipes. Anti-aliasing of the primitive objects (except bitmaps) gives a smoothing effect to the viewer. Bitmap transformations enable operations such as translate, scale and rotate. Display pixels are plotted with 1/16th pixel precision. Four levels of graphics states Tag buffer detection The graphics engine also supports customized built-in widgets and functionalities such as ASTC decode, jpeg decode, screen saver, calibration etc. The graphics engine interprets commands from the MPU host via a 4 Kbyte FIFO in the BT815/6 memory at RAM_CMD. The MPU/MCU writes commands into the FIFO, and the graphics engine reads and executes the commands. The MPU/MCU updates the register REG_CMD_WRITE to indicate that there are new commands in the FIFO, and the graphics engine updates REG_CMD_READ after commands have been executed. Main features supported are:     Drawing of widgets such as buttons, clock, keys, gauges, text displays, progress bars, sliders, toggle switches, dials, gradients, etc. JPEG and motion-JPEG decode Inflate functionality (zlib inflate is supported) Timed interrupt (generate an interrupt to the host processor after a specified number of milliseconds) Copyright © Bridgetek Pte Ltd 21 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220   Clearance No.: BRT#126 In-built animated functionalities such as displaying logo, calibration, spinner, screen saver and sketch Snapshot feature to capture the current graphics display For a complete list of graphics engine BT81X_Series_Programming_Guide, Chapter 4. 4.3.2 display commands and widgets refer to ASTC ASTC stands for Adaptive Scalable Texture Compression, an open standard developed by ARM for use in mobile GPUs. ASTC is a block-based lossy compression format. The compressed image is divided into a number of blocks of uniform size, which makes it possible to quickly determine which block a given texel resides in. Each block has a fixed memory footprint of 128 bits, but these bits can represent varying numbers of texels (the block footprint). Block footprint sizes are not confined to powers-of-two, and are also not confined to be square. For 2D formats the block dimensions range from 4 to 12 texels. Using ASTC for the large ROM fonts can save considerable space. Encoding the four largest fonts in ASTC 8x8 formats gives no noticeable loss in quality and reduces the ROM size from 1 MByte to about 640 Kbytes. 4.3.3 ROM and RAM Fonts The BT815/6 has built in ROM character bitmaps as font metrics. The graphics engine can use these metrics when drawing text fonts. There are a total of 19 ROM fonts, numbered with font handle 16-34. Fonts 31-34 are large ROM fonts encoded in ASTC 8x8 format. The user can define and load customized font metrics into RAM_G or external flash, making it possible to support a full range of Unicode characters with UTF-8 coding points. Each ROM font metric block has a 148 byte font table which defines the parameters of the font and the pointer of font image. The font table format is shown in Table 4-7. Address Offset 0 128 132 136 140 144 Size(byte) Parameter Description 128 width of each font character, in pixels 4 font bitmap format, for example L1, L4 or L8 4 font line stride, in bytes 4 font width, in pixels 4 font height, in pixels 4 pointer to font image data in memory Table 4-7 Font Table Format The ROM fonts are stored in the memory space ROM_FONT. The ROM font table is also stored in the ROM. The starting address of the ROM font table for font index 16 is stored at ROM_FONT_ADDR, with other font tables following. The ROM font table and individual character width (in pixel) are listed in Table 4-8, Table 4-9 and Table 4-10. Font index 16, 18 and 20-31 are for basic ASCII characters (code 0-127), while font index 17 and 19 are for Extended ASCII characters (code 128-255). The character width for font index 16 through 19 is fixed at 8 pixels for any of the ASCII characters. Font Index Font format Line stride Font width (max) Font height 1 6 L 1 1 7 L 1 1 8 L 1 1 9 L 1 2 0 L 1 2 1 L 1 2 2 L 1 2 3 L 1 2 4 L 1 2 5 L 1 2 6 L 4 2 7 L 4 2 8 L 4 1 1 1 1 2 2 2 3 3 4 7 8 9 8 8 8 8 8 8 1 1 1 1 1 1 3 1 1 7 2 1 8 2 2 5 2 3 4 3 1 3 1 1 5 2 1 9 2 Copyright © Bridgetek Pte Ltd 2 9 L 4 1 1 2 1 2 3 0 L 4 1 4 2 8 3 3 1 L 4 1 8 3 7 4 3 2 L 4 2 3 4 9 6 3 3 L 4 3 0 6 3 8 22 3 4 L 4 3 9 8 2 1 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 6 6 3 7 0 2 9 8 6 0 5 8 6 Clearance No.: BRT#126 9 3 3 0 8 Table 4-8 ROM Font Table ASCII Character width in pixels Font Index => 0 NULL 1 SOH 2 STX 3 ETX 4 EOT 5 ENQ 6 ACK 7 BEL 8 BS 9 HT 10 LF 11 VT 12 FF 13 CR 14 SO 15 SI 16 DLE 17 DC1 18 DC2 19 DC3 20 DC4 21 NAK 22 SYN 23 ETB 24 CAN 25 EM 26 SUB 27 ESC 28 FS 29 GS 30 RS 31 US spac 32 e 33 ! 34 " 35 # 36 $ 37 % 38 & 39 ' 40 ( 41 ) 42 * 43 + 44 , 45 46 . 47 / 48 0 49 1 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 3 3 4 6 6 9 8 2 4 4 4 6 3 4 3 3 6 6 4 4 5 8 8 12 10 3 5 5 7 9 3 4 3 4 8 8 5 5 6 9 9 14 11 3 6 6 6 10 4 5 4 5 9 9 5 6 5 10 10 16 13 3 6 6 7 10 5 6 5 5 10 10 6 6 8 14 13 22 17 6 8 8 10 14 6 8 6 7 13 13 9 9 12 19 18 29 22 6 11 11 13 19 9 11 9 9 18 18 3 3 5 10 8 11 9 3 5 5 7 9 3 6 3 6 8 8 4 4 6 11 10 13 11 4 6 6 8 10 4 7 4 7 10 10 5 6 7 14 11 16 14 4 7 8 10 12 4 10 6 9 12 12 6 6 8 15 15 17 15 5 9 8 11 14 5 11 7 10 14 14 8 9 12 19 18 23 19 7 11 10 14 17 7 15 8 13 17 17 10 11 15 26 25 31 26 10 15 14 18 24 9 18 11 17 24 24 13 15 19 33 31 40 34 11 18 18 24 30 12 24 14 22 30 30 18 19 25 44 41 52 44 15 24 24 31 41 16 32 19 29 40 40 23 25 33 57 54 68 57 20 31 31 40 52 20 41 24 38 52 52 Copyright © Bridgetek Pte Ltd 23 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Font Index => 50 2 51 3 52 4 53 5 54 6 55 7 56 8 57 9 58 : 59 ; 60 < 61 = 62 > 63 ? 64 @ 65 A 66 B 67 C 68 D 69 E 70 F 71 G 72 H 73 I 74 J 75 K 76 L 77 M 78 N 79 O 80 P 81 Q 82 R 83 S 84 T 85 U 86 V 87 W 88 X 89 Y 90 Z 91 [ 92 \ 93 ] 94 ^ 95 _ 96 ` 97 a 98 b 99 c 100 d 101 e 102 f 103 g 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 0 6 6 6 6 6 6 6 6 3 3 6 5 6 6 11 7 7 8 8 7 6 8 8 3 5 7 6 9 8 8 7 8 7 7 5 8 7 9 7 7 7 3 3 3 6 6 3 5 6 5 6 5 4 6 2 1 8 8 8 8 8 8 8 8 3 4 8 9 8 8 13 9 9 10 10 9 8 11 10 4 7 9 8 12 10 11 9 11 10 9 9 10 9 13 9 9 9 4 4 4 7 8 5 8 7 7 8 8 4 8 Copyright © Bridgetek Pte Ltd 2 2 9 9 9 9 9 9 9 9 4 4 10 10 10 9 17 11 11 12 12 11 10 13 12 4 8 11 9 13 12 13 11 13 12 11 10 12 11 15 11 11 10 5 5 5 8 9 6 9 9 8 9 9 5 9 2 3 10 10 10 10 10 10 10 10 5 5 10 11 10 10 18 13 13 14 14 13 12 15 14 6 10 13 11 16 14 15 13 15 14 13 12 14 13 18 13 13 12 5 5 5 9 11 4 11 11 10 11 10 6 11 2 4 13 13 13 13 13 13 13 13 6 6 15 15 15 12 25 17 17 18 18 16 14 19 18 8 13 18 14 21 18 18 16 18 17 16 16 18 17 22 17 16 15 7 7 7 12 14 7 13 14 12 14 13 8 14 2 5 18 18 18 18 18 18 18 18 9 9 19 19 19 18 34 22 22 24 24 22 20 25 24 9 16 22 18 27 24 25 22 26 24 22 20 24 22 31 22 22 20 9 9 9 16 18 11 18 18 16 18 18 9 18 2 6 8 8 8 8 8 8 8 8 3 3 8 8 8 7 13 9 9 9 9 7 7 9 9 4 8 9 7 11 9 10 9 10 9 9 10 9 9 12 9 9 9 4 6 4 6 8 4 8 8 8 8 8 6 8 2 7 10 10 10 10 10 10 10 10 4 4 9 9 9 9 15 11 10 11 11 9 9 11 11 5 9 11 9 14 11 12 10 12 11 11 12 11 11 15 11 10 11 5 7 5 7 10 5 9 9 9 10 9 7 10 2 8 12 12 12 12 12 12 12 12 6 6 11 13 11 10 19 13 14 13 14 12 12 14 15 6 12 14 12 19 15 14 14 14 13 12 14 13 14 18 13 14 13 6 9 7 9 11 7 11 11 11 12 11 8 11 2 9 14 14 14 14 14 14 14 14 6 6 12 14 13 12 21 15 15 15 17 13 13 16 17 7 13 16 13 21 17 16 15 17 15 14 15 17 15 21 15 15 14 7 10 7 10 13 8 13 14 12 14 12 10 14 3 0 17 17 17 17 17 17 17 17 7 8 16 18 16 15 28 20 19 20 22 16 17 22 23 9 17 19 17 26 23 22 19 22 19 20 19 21 20 27 20 19 18 9 13 9 13 16 10 17 17 16 17 16 12 18 3 1 24 24 24 24 24 24 24 24 10 10 21 23 22 20 37 27 27 26 28 23 22 28 29 12 23 26 22 35 29 28 26 29 27 26 26 28 27 36 27 26 25 12 18 12 18 21 13 23 24 22 24 22 15 24 Clearance No.: BRT#126 3 2 30 30 30 30 30 30 30 30 13 14 28 30 29 26 49 34 34 34 36 29 29 37 37 15 30 34 29 46 37 37 34 38 33 33 32 37 34 46 34 34 32 15 22 15 23 26 17 30 31 28 31 29 19 31 3 3 40 40 40 40 40 40 40 40 18 18 36 40 37 34 63 45 45 45 48 39 39 48 50 20 40 45 39 62 50 49 45 50 45 43 42 48 45 61 45 45 42 19 29 19 30 34 22 39 40 37 40 37 25 41 24 3 4 52 52 52 52 52 52 52 52 23 23 46 52 48 44 82 58 58 58 63 50 50 62 65 26 50 58 51 79 65 63 58 64 58 56 56 62 58 79 58 58 55 25 38 25 38 43 29 50 52 48 52 48 31 52 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Font Index => 104 h 105 i 106 j 107 k 108 l 109 m 110 n 111 o 112 p 113 q 114 r 115 s 116 t 117 u 118 v 119 w 120 x 121 y 122 z 123 { 124 | 125 } 126 ~ 127 DEL 16/ 18 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 2 2 2 2 2 2 0 1 2 3 4 5 6 8 9 10 13 18 2 3 3 4 6 7 2 3 4 4 6 7 5 7 8 9 12 16 2 3 3 4 6 7 8 11 14 16 20 27 6 8 9 10 14 18 6 8 9 11 13 18 6 8 9 11 14 18 6 8 9 11 14 18 4 5 5 6 9 11 5 7 8 9 12 16 4 4 5 6 8 9 5 7 9 10 14 18 6 7 8 10 13 16 8 10 12 14 18 23 6 7 8 10 12 16 5 7 8 10 13 16 5 7 8 9 12 16 3 5 6 6 8 11 3 3 4 5 6 9 3 5 6 6 8 11 7 8 10 10 14 19 0 0 0 0 0 0 Table 4-9 ROM font ASCII 2 2 6 7 8 9 3 4 3 4 7 9 3 4 11 15 8 9 8 10 8 9 8 10 5 6 7 9 6 7 8 9 7 9 11 13 7 9 7 9 8 9 5 6 3 4 5 6 10 11 4 3 character 2 2 8 9 11 14 6 6 6 6 11 13 6 6 18 21 11 14 12 13 11 14 12 13 7 9 11 12 8 9 12 14 11 12 16 18 11 12 11 12 11 12 8 8 5 6 7 9 14 15 5 6 width in Clearance No.: BRT#126 3 3 0 1 17 24 7 10 8 11 16 22 7 10 27 36 17 24 17 24 17 24 17 24 11 15 17 22 11 14 17 24 16 21 23 32 16 21 16 21 15 22 11 15 7 10 10 15 21 29 5 10 pixels 3 2 31 13 14 28 13 47 31 31 31 31 19 29 17 31 27 41 27 27 27 18 14 18 36 13 3 3 41 18 18 36 18 63 41 40 40 40 25 38 23 41 36 54 36 36 36 24 18 24 47 18 3 4 52 23 23 47 23 80 52 52 51 52 32 48 29 52 46 70 46 46 46 31 23 31 63 23 Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol Decimal Symbol 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 Ç 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 É 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 á 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 ░ 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 └ 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 ╨ 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 α 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 Ξ ü é â ä à å ç ê ë è ï î ì Ä Å æ Æ ô ö ò û ù ÿ Ö Ü ₵ £ ¥ Pt ƒ í ó ú ñ Ñ ª º ¿ ⌐ ¬ ½ ¼ ¡ « ▒ ▓ │ ┤ ╡ ╢ ╖ ╕ ╣ ║ ╗ ╝ ╜ ╛ ┴ ┬ ├ ─ ┼ ╞ ╟ ╚ ╔ ╩ ╦ ╠ ═ ╬ ╤ ╥ ╙ ╘ ╒ ╓ ╫ ╪ ┘ ┌ █ ▄ ▌ ▐ ┐ ╧ » ▀ Table 4-10 ROM Font Extended ASCII Characters ß Γ ∏ Σ σ µ τ Φ θ Ω δ ω φ Ɛ Π ± ≥ ≤ ⌠ ⌡ ÷ ≈ ° • · √ ⁿ ² ■ nbsp Note 1: Font 17 and 19 are extended ASCII characters, with width fixed at 8 pixels for all characters. Note 2: All fonts included in the BT815/6 ROM are widely available to the market-place for general usage. See section nine for specific copyright data and links to the corresponding license agreements. Copyright © Bridgetek Pte Ltd 25 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 4.4 SPI NOR Flash Interface The BT815/6 implements a SPI master to connect to external SPI NOR Flash. Graphics assets such as Unicode fonts and images can be stored in the flash memory. The BT815/6 graphics engine can fetch these graphics assets directly without going through external host MCU, thus significantly offloading the host MCU from feeding display contents. The BT815/6 supports various NOR flash memory device from different vendors such as Macronix, Winbond, Micron, ISSI and Gigadevice. The interface will work at system clock speed (up to 72MHz) at 4 bit mode. Figure 4-7 Flash Interface States The register REG_FLASH_STATE indicates the state of the flash subsystem. At boot the flash state is FLASH_STATE_INIT. After detection has completed flash is in state FLASH_STATE_DETACHED or FLASH_STATE_BASIC, depending on whether an attached flash device was detected. If no device is detected, then all SPI output signals are driven low. When the host MCU calls CMD_FLASHFAST, the flash system attempts to go to full-speed mode, setting state to FLASH_STATE_FULL. At any time the user can call CMD_FLASHDETACH in order to disable flash communications. In the detached state, commands CMD_FLASHSPIDESEL, CMD_FLASHSPITX and CMD_FLASHSPIRX can be used to control the SPI bus. If detached, the host MCU can call CMD_FLASHATTACH to re-establish communication with the flash device. Direct rendering of bitmaps from flash is only possible in FLASH_STATE_FULL. After modifying the contents of flash, the MCU should clear the on-chip bitmap cache by calling CMD_CLEARCACHE. 4.5 Parallel RGB Interface The RGB parallel interface consists of 29 signals - DISP, PCLK, VSYNC, HSYNC, DE, 8 signals each for R, G and B. A set of RGB registers configure the LCD operation and timing parameters. Copyright © Bridgetek Pte Ltd 26 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 REG_PCLK is the PCLK divisor. The default value is 0, which means the PCLK output is disabled. When REG_PCLK is none 0 (1-1023), the PCLK frequency can be calculated as: PCLK frequency = System Clock frequency / REG_PCLK The BT815/6 system clock frequency is programmable. Some of the possible PCLK frequencies that BT815/6 supports are listed in Table 4-11. System Clock Frequency (MHz) REG_PCLK 72 60(default) 48 36 24 2 36 30 24 18 12 3 24 20 16 12 8.0 4 18 15 12 9.0 6.0 5 14.5 12 9.6 7.2 4.8 6 12 10 8.0 6.0 4.0 7 10.3 8.6 6.9 5.1 3.4 8 9 7.5 6.0 4.5 3.0 9 8 6.7 5.3 4.0 2.7 10 7.2 6.0 4.8 3.6 2.4 Table 4-11 RGB PCLK Frequency REG_PCLK_POL defines the clock polarity, with 0 for positive active clock edge, and 1 for negative clock edge. REG_CSPREAD controls the transition of RGB signals with respect to the PCLK active clock edge. When REG_CSPREAD=0, R[7:0], G[7:0] and B[7:0] signals change following the active edge of PCLK. When REG_CSPREAD=1, R[7:0] changes a PCLK clock early and B[7:0] a PCLK clock later, which helps reduce the switching noise. REG_DITHER enables colour dither. This option improves the half-tone appearance on displays. Internally, the graphics engine computes the colour values at an 8 bit precision; however, the LCD colour at a lower precision is sufficient. REG_OUTBITS gives the bit width of each colour channel; the default is 8/8/8 bits for each R/G/B colour. A lower value means fewer bits are output for each channel allowing dithering on lower precision LCD displays. REG_SWIZZLE controls the arrangement of the output colour pins, to help the PCB route different LCD panel arrangements. Bit 0 of the register causes the order of bits in each colour channel to be reversed. Bits 1-3 control the RGB order. Setting Bit 1 causes R and B channels to be swapped. Setting Bit 3 allows rotation to be enabled. If Bit 3 is set, then (R, G, B) is rotated right if bit 2 is one, or left if bit 2 is zero. REG_SWIZZLE b3 b2 b1 b0 0 0 0 0 1 Copyright © Bridgetek Pte Ltd X X X X 0 0 0 1 1 0 0 1 0 1 0 R7, R6, R5, R4, R3, R2, R1, R0 R[7:0] R[0:7] B[7:0] B[0:7] B[7:0] RGB PINS G7, G6, G5, G4, G3, G2, G1, G0 G[7:0] G[0:7] G[7:0] G[0:7] R[7:0] B7, B6, B5, B4, B3, B2, B1, B0 B[7:0] B[0:7] R[7:0] R[0:7] G[7:0] 27 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 1 0 0 1 B[0:7] 1 0 1 0 G[7:0] 1 0 1 1 G[0:7] 1 1 0 0 G[7:0] 1 1 0 1 G[0:7] 1 1 1 0 R[7:0] 1 1 1 1 R[0:7] Table 4-12 REG_SWIZZLE R[0:7] R[7:0] R[0:7] B[7:0] B[0:7] B[7:0] B[0:7] RGB Pins Clearance No.: BRT#126 G[0:7] B[7:0] B[0:7] R[7:0] R[0:7] G[7:0] G[0:7] Mapping Vertical Horizontal REG_HCYCLE, REG_HSIZE, REG_HOFFSET, REG_HSYNC0 and REG_HSYNC1 define the LCD horizontal timings. Each register has 12 bits to allow programmable range of 0-4095 PCLK cycles. REG_VCYCLE, REG_VSIZE, REG_VOFFSET, REG_VSYNC0 and REG_VSYNC1 define the LCD vertical timings. Each register has 12 bits to allow a programmable range of 0-4095 lines. Register Display Parameter Description REG_HCYCLE TH Total length of line (visible and non-visible) (in PCLKs) REG_HSIZE THD Length of visible part of line (in PCLKs) REG_HOFFSET THF + THP + THB Length of non-visible part of line. Must be < TH - THD (in PCLK cycles) REG_HSYNC0 THF Horizontal Front Porch (in PCLK cycles) REG_HSYNC1 THF + THP Horizontal Front Porch plus Hsync Pulse width (in PCLK cycles) REG_VCYCLE TV Total number of lines (visible and non-visible) (in lines) REG_VSIZE TVD Number of visible lines (in lines) REG_VOFFSET TVF + TVP + TVB Number of non-visible lines. Must be < TV - TVD (in lines) REG_VSYNC0 TVF Vertical Front Porch (in lines) REG_VSYNC1 TVF + TVP Vertical Front Porch plus Vsync Pulse width (in lines) Table 4-13 Registers for RGB Horizontal and Vertical Timings Copyright © Bridgetek Pte Ltd 28 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Figure 4-8 RGB Timing Waveforms 4.6 Miscellaneous Control 4.6.1 Backlight Control Pin The backlight dimming control pin (BACKLIGHT) is a pulse width modulated (PWM) signal controlled by two registers: REG_PWM_HZ and REG_PWM_DUTY. REG_PWM_HZ specifies the PWM output frequency, the range is 250-10000 Hz. REG_PWM_DUTY specifies the duty cycle; the range is 0-128. A value of 0 means that the PWM is completely off and 128 means completely on. The BACKLIGHT pin will output low when the DISP pin is not enabled (i.e. logic 0). 4.6.2 DISP Control Pin The DISP pin is a general purpose output that can be used to enable, or reset the LCD display panel. The pin is controlled by writing to Bit 7 of the REG_GPIO register, or bit 15 of REG_GPIOX. 4.6.3 General Purpose IO pins The BT815/6 can be configured to use up to 4 GPIO pins. These GPIO pins are controlled by the REG_GPIOX_DIR and REG_GPIOX registers. Alternatively the GPIO0 and GPIO1 pins can also be controlled by REG_GPIO_DIR and REG_GPIO to maintain backward compatibility with the FT800/FT801. When the QSPI is enabled in Quad mode, GPIO0/IO2 and GPIO1/IO3 pins are used as data lines of the QSPI. Copyright © Bridgetek Pte Ltd 29 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 4.6.4 Clearance No.: BRT#126 Pins Drive Current Control The output drive current of output pins can be changed as per the following table by writing to bit[6:2] of REG_GPIO register or bit[14:10] of REG_GPIOX register. Alternatively, use the SPI command PINDRIVE to change the individual pin drive strength. REG_GPIO Bit[6:5] Bit[4] Bit[3:2] REG_GPIOX Bit[14:13] Bit[12] Bit[11:10] Value 00b# 01b 10b 11b 0b# 1b 00b# 01b 10b 11b Drive Current 5mA 10mA 15mA 20mA 1.2mA 2.4mA 5mA 10mA 15mA 20mA Pins GPIO0 PCLK MISO GPIO1 DISP MOSI GPIO2 VSYNC IO2 GPIO3 HSYNC IO3 CTP_RST_N DE INT_N R7..R0 G7..G0 B7..B0 BACKLIGHT Table 4-14 Output Drive Current Selection Note: #Default value 4.7 Audio Engine BT815/6 provides mono audio output with sigma-delta modulation through a digital output pin, AUDIO_L. It outputs two audio sources, the sound synthesizer and audio file playback. 4.7.1 Sound Synthesizer A sound processor, AUDIO ENGINE, generates the sound effects from a small ROM library of waves table. To play a sound effect listed in Table 4.3, load the REG_SOUND register with a code value and write 1 to the REG_PLAY register. The REG_PLAY register reads 1 while the effect is playing and returns a ‘0’ when the effect ends. Some sound effects play continuously until interrupted or instructed to play the next sound effect. To interrupt an effect, write a new value to REG_SOUND and REG_PLAY registers; e.g. write 0 (Silence) to REG_SOUND and 1 to PEG_PLAY to stop the sound effect. The sound volume is controlled by register REG_VOL_SOUND. The 16-bit REG_SOUND register takes an 8-bit sound in the low byte. For some sounds, marked "pitch adjust" in the table below, the high 8 bits contain a MIDI note value. For these sounds, a note value of zero indicates middle C. For other sounds the high byte of REG_SOUND is ignored. Value Effect Pitch adjust Value Effect Silence Contin uous Y 00h N 32h square wave Y Y 33h 02h sine wave Y Y 03h sawtooth wave Y Y 01h Copyright © Bridgetek Pte Ltd DTMF 2 Contin uous Y Pitch adjust N DTMF 3 Y N 34h DTMF 4 Y N 35h DTMF 5 Y N 30 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 04h triangle wave Y 05h Beeping Y Alarm Y 07h Warble Y Y 39h DTMF 9 Y 08h Carousel Y Y 40h harp N Y 10h 1 short pip N Y 41h xylophone N Y 11h 2 short pips N Y 42h tuba N Y 12h 3 short pips N Y 43h glockenspiel N Y 13h 4 short pips N Y 44h organ N Y 06h 14h 5 short pips N N Y 36h DTMF 6 Y N Y 37h DTMF 7 Y N DTMF 8 Y N N Y Y 15h 6 short pips 16h 7 short pips N 17h 8 short pips N Y 18h 9 short pips N Y 19h 10 short pips N 1Ah 11 short pips N 1Bh 12 short pips N Y 1Ch 13 short pips N Y 1Dh 14 short pips N Y 1Eh 15 short pips N Y 16 short pips N 1Fh 23h DTMF # 2Ch DTMF * 30h 31h Y 38h 45h trumpet N Y N Y 46h piano Y 47h chimes N Y 48h music box N Y 49h bell N Y 50h click N Y N Y 51h switch N N 52h cowbell N N 53h notch N N 54h hihat N N 55h kickdrum N N pop N N N N Y 56h Y N 57h clack Y N 58h chack N N DTMF 0 Y N 60h mute N N DTMF 1 Y unmute N N N 61h Table 4-15 Sound Effect MIDI note ANSI note Freq (Hz) MIDI note ANSI note Freq (Hz) 21 A0 27.5 65 F4 349.2 22 A#0 29.1 66 F#4 370.0 23 B0 30.9 67 G4 392.0 24 C1 32.7 68 G#4 415.3 25 C#1 34.6 69 A4 440.0 26 D1 36.7 70 A#4 466.2 27 D#1 38.9 71 B4 493.9 28 E1 41.2 72 C5 523.3 29 F1 43.7 73 C#5 554.4 30 F#1 46.2 74 D5 587.3 31 G1 49.0 75 D#5 622.3 32 G#1 51.9 76 E5 659.3 33 A1 55.0 77 F5 698.5 34 A#1 58.3 78 F#5 740.0 35 B1 61.7 79 G5 784.0 36 C2 65.4 80 G#5 830.6 37 C#2 69.3 81 A5 880.0 38 D2 73.4 82 A#5 932.3 39 D#2 77.8 83 B5 987.8 40 E2 82.4 84 C6 1046.5 41 F2 87.3 85 C#6 1108.7 42 F#2 92.5 86 D6 1174.7 Copyright © Bridgetek Pte Ltd 31 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 43 G2 98.0 87 D#6 1244.5 44 G#2 103.8 88 E6 1318.5 45 A2 110.0 89 F6 1396.9 46 A#2 116.5 90 F#6 1480.0 47 B2 123.5 91 G6 1568.0 48 C3 130.8 92 G#6 1661.2 49 C#3 138.6 93 A6 1760.0 50 D3 146.8 94 A#6 1864.7 51 D#3 155.6 95 B6 1975.5 52 E3 164.8 96 C7 2093.0 53 F3 174.6 97 C#7 2217.5 54 F#3 185.0 98 D7 2349.3 55 G3 196.0 99 D#7 2489.0 56 G#3 207.7 100 E7 2637.0 57 A3 220.0 101 F7 2793.8 58 A#3 233.1 102 F#7 2960.0 59 B3 246.9 103 G7 3136.0 60 C4 261.6 104 G#7 3322.4 61 C#4 277.2 105 A7 3520.0 62 D4 293.7 106 A#7 3729.3 63 D#4 311.1 107 B7 3951.1 64 E4 329.6 108 C8 4186.0 Clearance No.: BRT#126 Table 4-16 MIDI Note Effect 4.7.2 Audio Playback The BT815/6 can play back recorded sound through its audio output. To do this, load the original sound data into the BT815/6’s RAM, and set registers to start the playback. The registers controlling audio playback are: REG_PLAYBACK_START: the start address of the audio data REG_PLAYBACK_LENGTH: the length of the audio data, in bytes REG_PLAYBACK_FREQ: the playback sampling frequency, in Hz REG_PLAYBACK_FORMAT: the playback format, one of LINEAR SAMPLES, uLAW SAMPLES, or ADPCM SAMPLES REG_PLAYBACK_LOOP: if zero, the sample is played once. If one, the sample is repeated indefinitely REG_PLAYBACK_PLAY: a write to this location triggers the start of audio playback, regardless of writing ‘0’ or ‘1’. Read back ‘1’ when playback is ongoing, and ‘0’ when playback finishes REG_VOL_PB: playback volume, 0-255 The mono audio formats supported are 8-bits PCM, 8-bits uLAW and 4-bits IMA-ADPCM. For ADPCM_SAMPLES, each sample is 4 bits, so two samples are packed per byte, the first sample is in bits 0-3 and the second is in bits 4-7. The current audio playback read pointer can be queried by reading the REG_PLAYBACK_READPTR. Using a large sample buffer, looping, and this read pointer, the host MPU/MCU can supply a continuous stream of audio. Copyright © Bridgetek Pte Ltd 32 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 4.8 Touch-Screen Engine The BT815/6 touch-screen engine supports both resistive and capacitive touch panels. BT816 supports resistive touch, while BT815 supports capacitive touch. 4.8.1 Resistive Touch Control The resistive touch-screen consists of a touch screen engine, ADC, Axis-switches, and ADC input multiplexer. The touch screen engine reads commands from the memory map register and generates the required control signals to the axis-switches and inputs mux and ADC. The ADC data are acquired, processed and updated in the respective register for the MPU/MCU to read. BT816 Y+ XP YP XM YM X- Resistive Touch Screen X+ Y- Figure 4-9 Resistive Touch Screen Connection The host controls the TOUCH SCREEN ENGINE operation mode by writing the REG_TOUCH_MODE. REG_TOUCH_MODE Mode Description 0 OFF Acquisition stopped, only touch detection interrupt is still valid. 1 ONE-SHOT Perform acquisition once every time the MPU writes '1' to REG_TOUCH_MODE. 2 FRAME-SYNC Perform acquisition for every frame sync (~60 data acquisition/second. 3 CONTINUOUS Perform acquisition continuously at approximately 1000 data acquisition / second. Table 4-17 Resistive Touch Controller Operating Mode The Touch Screen Engine captures the raw X and Y coordinate and writes to register REG_TOUCH_RAW XY. The range of these values is 0-1023. If the touch screen is not being pressed, both registers read 65535 (FFFFh). These touch values are transformed into screen coordinates using the matrix in registers REG_TOUCH_TRANSFORM_A-F. The post-transform coordinates are available in register REG_TOUCH_SCREEN_XY. If the touch screen is not being pressed, both registers read -32768 (8000h). The values for REG TOUCH TRANSFORM A-F may be computed using an on-screen calibration process. If the screen is being touched, the screen coordinates are looked up in the screen's tag buffer, delivering a final 8-bit tag value, in REG TOUCH TAG. Because the tag lookup takes a full frame, and touch coordinates change continuously, the original (x; y) used for the tag lookup is also available in REG_TOUCH_TAG_XY. Copyright © Bridgetek Pte Ltd 33 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Screen touch pressure is available in REG_TOUCH_RZ. The value is relative to the resistance of the touch contact, a lower value indicates more pressure. The register defaults to 32767 when touch is not detected. The REG_TOUCH_THRESHOLD can be set to accept a touch only when the force threshold is exceeded. 4.8.2 Capacitive Touch Control The Capacitive Touch Screen Engine (CTSE) of the BT815 communicates with the external capacitive touch panel module (CTPM) through an I2C interface. The CTPM will assert its interrupt line when there is a touch detected. Upon detecting CTP_INT_N line active, the BT815/6 will read the touch data through I2C. Up to 5 touches can be reported and stored in BT815 registers. The BT815 CTSE supports Focaltech and Goodix touch controllers, as well as touch host mode (refer to section 4.8.7). For a supported CTPM list please refer to AN_336 FT8xx - Selecting an LCD Display. The BT815 uses the I2C address value in the REG_TOUCH_CONFIG register to differentiate Focaltech or Goodix touch controllers. For Focaltech IC the I2C address must be set as 0x38-0x3F (example: REG_TOUCH_CONFIG = 0x0380), while for Goodix IC the I2C address must be set as 0x5D (example: REG_TOUCH_CONFIG = 0x05D0). VCCIO2 (1.8-3.3V) BT815 1K 1K CTP_SCL SCL CTP_SDA SDA CTP_INT_N INTN CTP_RST_N RSTN Capacitive Touch Panel Module Figure 4-10 Touch Screen Connection The host controls the CTSE operation mode by writing the REG_CTOUCH_MODE. REG_CTOUCH_MODE Mode Description 0 OFF Acquisition stopped 1-2 Reserved Reserved 3 CONTINUOUS Perform acquisition continuously at the reporting rate of the connected CTPM. Table 4-18 Capacitive Touch Controller Operating Mode The BT815 CTSE supports compatibility mode and extended mode. By default the CTSE runs in compatibility mode where the touch system provides an interface very similar to the resistive touch engine. In extended mode, the touch register meanings are modified, and a second set of registers are exposed. These allow multi-touch detection (up to 5 touches). 4.8.3 Compatibility Mode The CTSE reads the X and Y coordinates from the CTPM and writes to register REG_CTOUCH_RAW_XY. If the touch screen is not being pressed, both registers read 65535 (FFFFh). Copyright © Bridgetek Pte Ltd 34 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 These touch values are transformed into screen coordinates using the matrix in registers REG_CTOUCH_TRANSFORM_A-F. The post-transform coordinates are available in register REG_CTOUCH_SCREEN_XY. If the touch screen is not being pressed, both registers read -32768 (8000h). The values for REG_CTOUCH_TRANSFORM_A-F may be computed using an on-screen calibration process. If the screen is being touched, the screen coordinates are looked up in the screen's tag buffer, delivering a final 8-bit tag value, in REG_TOUCH_TAG. Because the tag lookup takes a full frame, and touch coordinates change continuously, the original (x; y) used for the tag lookup is also available in REG_TOUCH_TAG_XY. 4.8.4 Extended Mode Setting REG_CTOUCH_EXTENDED to 1b’0 enables extended mode. In extended mode a new set of readout registers are available, allowing gestures and up to five touches to be read. There are two classes of registers: control registers and status registers. Control registers are written by the MCU. Status registers can be read out by the MCU and the BT815/6’s hardware tag system. The five touch coordinates are packed in REG_CTOUCH_TOUCH0_XY, REG_CTOUCH_TOUCH1_XY, REG_CTOUCH_TOUCH2_XY, REG_CTOUCH_TOUCH3_XY, REG_CTOUCH4_X and REG_CTOUCH4_Y. Coordinates stored in these registers are signed 16-bit values, so have a range of -32768 to 32767. The no-touch condition is indicated by x=y= -32768. These coordinates are already transformed into screen coordinates based on the raw data read from the CTPM, using the matrix in registers REG_CTOUCH_TRANSFORM_A-F. To obtain raw (x,y) coordinates read from CTPM, the user sets the REG_CTOUCH_TRANSFORM_A-F registers to the identity matrix. The BT815/6 tag mechanism is implemented by hardware, where up to 5 tags can be looked up. 4.8.5 Short-Circuit Protection For resistive touch it is useful to protect the chip from permanent damage due to potential short-circuits on the 4 XY lines. When a short circuit on the touch screen happens, the BT816 can detect it and stop the touch detection operation, leaving the 4 XY pins in the high impedance state. The short-circuit protection can be enabled/disabled by the REG_TOUCH_CONFIG. 4.8.6 Capacitive Touch Configuration On a capacitive touch system some users may need to adjust the CTPM default values, such as the registers affecting touch sensitivity. To do this the following sequence shall be executed once after chip reset: - Hold the touch engine in reset (set REG_CPURESET = 2) Write the CTPM configure register address and value to the BT815 designated memory location Up to 10 register address/value can be added Release the touch engine reset (set REG_CPURESET = 0) The CTPM can be enabled in low power state when the touch function is not required by the application. Setting the low-power bit in REG_TOUCH_CONFIG will enable the low power mode of the CTPM. When the low-power bit is cleared, the BT815 touch engine will send a reset to the CTPM, thus re-enabling the touch detection function. 4.8.7 Host Driven Multi-Touch If the host MCU can provide touch inputs, it can supply them directly to the BT815 using touch host mode. By using touch host mode, an application can choose to select a touch controller that is not in the BT815 direct support list. For example, Touch Host mode would allow controllers to be used from other manufacturers beyond Focaltech and Goodix. To use the touch host mode, the host MCU shall be connected to the touch panel directly. The four touch related pins of the BT815 can be left unconnected on the PCB. The host MCU is responsible for Copyright © Bridgetek Pte Ltd 35 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 communicating with the touch controller, fetching the touch data when reported, and writing the touch data to the BT815 for touch TAG lookup and reporting. The touch host mode can be entered by setting bit 14 in register REG_TOUCH_CONFIG and resetting the touch engine: - Hold the touch engine in reset (set REG_CPURESET = 2) Write 1 to bit 14 in REG_TOUCH_CONFIG (set REG_TOUCH_CONFIG = 0x4000) Release the touch engine reset (set REG_CPURESET = 0) Figure 4-11 Touch Host Mode Connections In touch host mode, the host supplies touch information via four registers: BT815 address Register Name Bits Description 0x30210c REG_EHOST_TOUCH_X Unsigned 16-bit Touch x coordinate 0x302118 REG_EHOST_TOUCH_Y Unsigned 16-bit Touch y coordinate 0x302114 REG_EHOST_TOUCH_ID 4-bit Touch ID / phase 0x302170 REG_EHOST_TOUCH_ACK 4-bit Acknowledgement Table 4-19 Registers for Touch Host Mode The host writes raw (x; y) coordinates and IDs to the above registers. Up to 5 touches can be set, using touch IDs 0-4. The host indicates no touch by supplying coordinates (0x8000; 0x8000). When the host writes 0xf to the ID register, BT815 sets the ACK register to 0, transforms all the raw coordinates, and writes the results to the regular touch registers. Pseudocode: wait until REG_EHOST_TOUCH_ACK is 1 for each touch: write x coordinate to REG_EHOST_TOUCH_X write y coordinate to REG_EHOST_TOUCH_Y write id to REG_EHOST_TOUCH_ID write 0xf to REG_EHOST_TOUCH_ID As soon as BT815 has converted the coordinates, it writes 1 to the ACK register and sets the INT_CONV _COMPLETE interrupt flag. Copyright © Bridgetek Pte Ltd 36 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 The ID should be zero in touch compatibility mode. The host should indicate no touch at all by writing (0x8000; 0x8000) with ID 0. In extended mode, the multiple touches may be sent in any order. Any IDs not assigned are assumed to be not pressed. Again, the host should indicate no touch at all by writing (0x8000; 0x8000) with ID 0. The host can use three methods to ensure that BT815 is ready to accept touch inputs: 1. poll the ACK register until it is 1 2. use the INT_CONV_COMPLETE interrupt flag 3. supply touches slower than 1000 Hz, since BT815 guarantees to process the touches in under 1 ms. Note that report rates from capacitive touch panels are about 100 Hz Like the direct capacitive driver, this touch host mode works when REG_CTOUCH_EXTENDED is both CTOUCH_MODE_EXTENDED and CTOUCH_MODE_COMPATIBILITY. CTOUCH_MODE_COMPATIBILITY should be used for the calibration procedure, just as when using native capacitive support. After changing mode, the BT815 touch engine must be reset. 4.8.8 Touch Detection in none-ACTIVE State When the BT815/6 is in none-ACTIVE state, a touch event can still be detected and reported to the host through the INT_N pin. In other words, a touch event can wake-up the host if needed. For resistive touch, the INT_N pin will be asserted low when the screen is touched, regardless of the setting of the interrupt registers. This will happen when the BT816 is in STANDBY or SLEEP state, but not in POWERDOWN state. For capacitive touch, the INT_N pin will follow CTP_INT_N pin when the BT815 is in STANDBY, SLEEP or POWERDOWN state. 4.9 Power Management 4.9.1 Power Supply The BT815/6 may be operated with a single supply of 3.3V applied to VCC and VCCIO pins. For operation with a host MPU/MCU at a lower supply, connect the VCCIO1 to the MPU IO supply to match the interface voltage. For operation with LCD/touch panels at lower voltages, connect the VCCIO2 to the LCD/touch IO supply. Symbol Typical Description VCCIO1 1.8V, or 2.5V, or 3.3V Supply for Host interface digital I/O pins VCCIO2 1.8V, or 2.5V, or 3.3V Supply for RGB and touch interface I/O pins VCCIO3 1.8V, or 2.5V, or 3.3V Supply for NOR Flash interface I/O pins VCCA 3.3V Supply for AUDIO_L pin and ADC circuit VCC 3.3V Supply for 3.3V circuits and internal 1.2V regulator VOUT1V2, VCC1V2 1.2V Supply for digital core. Generated by internal regulator Table 4-20 Power Supply Copyright © Bridgetek Pte Ltd 37 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 4.9.2 Clearance No.: BRT#126 Internal Regulator and POR The internal regulator provides power to the core circuit. A 47kΩ resistor is recommended to pull the PD_N pin up to VCCIO1, together with a 100nF capacitor to ground in order to delay the internal regulator powering up after the VCC and VCCIO are stable. The internal regulator requires a compensation capacitor to be stable. A typical design requires a 4.7uF capacitor between the VOUT1V2 and GND pins. Do not connect any other load to the VOUT1V2 pin. The internal regulator will generate a Power-On-Reset (POR) pulse when the output voltage rises above the POR threshold. The POR will reset all the core digital circuits. It is possible to use the PD_N pin as an asynchronous hardware reset input. Drive PD_N low for at least 5ms and then drive it high will reset the BT815/6 chip. VCCIO1 VCC R1 47k C2 C1 10uF GND VOUT1V2 BT815/6 C3 4.7uF GND GND PD_N GND 100nF VCC GND Figure 4-12 Internal Regulator 4.9.3 Power Modes When the supply to VCCIO and VCC is applied, the internal regulator is powered by VCC. An internal POR pulse will be generated during the regulator power up until it is stable. After the initial power up, the BT815/6 will stay in the SLEEP state. When needed, the host can set the BT815/6 to the ACTIVE state by performing a SPI ACTIVE command. The graphics engine, the audio engine and the touch engine are only functional in the ACTIVE state. To save power the host can send a command to put the BT815/6 into any of the low power modes: STANDBY, SLEEP and POWERDOWN. In addition, the host is allowed to put the BT815/6 in POWERDOWN mode by driving the PD_N pin to low, regardless of what state it is currently in. Refer to Figure 4-13 for the power state transitions. Copyright © Bridgetek Pte Ltd 38 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Toggle PD_N from high to low Clearance No.: BRT#126 VCC/VCCIO Power ON Toggle PD_N from low to high POWERDOWN SLEEP Write command “ACTIVE” Toggle PD_N from high to low or Write command “POWERDOWN” Toggle PD_N from high to low Write command “SLEEP” Write command “ACTIVE” STANDBY ACTIVE Write command “STANDBY” Figure 4-13 Power State Transition 4.9.3.1 ACTIVE state In ACTIVE state, the BT815/6 is in normal operation. The clock oscillator and PLL are functioning. The system clock applied to the BT815/6 core engines is enabled. 4.9.3.2 STANDBY state In STANDBY state, the clock oscillator and PLL remain functioning; the system clock applied to the BT815/6 core engines is disabled. All register contents are retained. 4.9.3.3 SLEEP state In SLEEP state, the clock oscillator, PLL and system clock applied to the BT815/6 core engines are disabled. All register contents are retained. 4.9.3.4 POWERDOWN state In POWERDOWN state, the clock oscillator, the PLL and the system clock applied to the BT815/6 core is disabled. The core engines are powered down while the SPI interface for host commands remains functional. All register contents are lost and reset to default when the chip is next switched on. The internal regulator remains on. 4.9.3.5 Wake up to ACTIVE from other power states When in the POWER DOWN state, if the device enters this state via an SPI command, then only the SPI ACTIVE command will bring the device back to the ACTIVE state, provided PD_N pin is also high. However, if PD_N is used instead, then making PD_N high followed by a SPI ACTIVE command will wake up the device. Upon exiting this state, the device will perform a global reset, and will go through the same power up sequence. All settings from SPI commands will be reset except those that pertain to pin states during power down. The clock enable sequence mentioned in section 4.2.3 shall be executed to properly select and enable the system clock. Copyright © Bridgetek Pte Ltd 39 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 From the SLEEP state, the host MPU sends an SPI ACTIVE command to wake the BT815/6 into the ACTIVE state. The host needs to wait for at least 20ms before accessing any registers or commands. This is to guarantee the clock oscillator and PLL are up and stable. From the STANDBY state, the host MPU sends SPI ACTIVE command to wake the BT815/6 into the ACTIVE state. The host can immediately access any register or command. 4.9.4 Reset and Boot-up Sequence There are a few hardware and software reset events which can be triggered to reset the BT815/6. Hardware reset events:   Power-on-Reset(POR) Toggle the PD_N pin Software reset events:    SPI command RST_PULSE SPI command to switch between the internal clock and the external clock SPI command to enter POWERDOWN then wakeup After reset the BT815/6 will be in the SLEEP state. Upon receiving the SPI ACTIVE command (or CLKEXT followed by SPI ACTIVE command if external clock source is used), the clock oscillator and PLL will start up. Once the clock is stable, the chip will check and repair its internal RAM, running the configuration and release the clock to the system. The chip will exit the reset and boot-up state and enter into normal operations. The boot-up may take up to 300ms to complete. During boot up process, software should not access BT815/6 register or RAM. 4.9.5 Pin Status at Different Power States The BT815/6 pin status depends on the power state of the chip. See the following table for more details. At the power transition from ACTIVE to STANDBY or ACTIVE to SLEEP, all pins retain their previous status. The software needs to set AUDIO_L, BACKLIGHT to a known state before issuing power transition commands. The pin status in the power down state can be changed by SPI command PIN_PD_STATE. Pin Name Default Drive Reset Normal Power Down (Default) AUDIO_L 20mA Out, Float Out Retain SCK - In In In MISO 5mA IO Out, Float MOSI 5mA In IO In CS_N - In In In IO2 5mA In IO Float GPIO0 5mA In IO Float IO3 5mA In IO Float GPIO1 5mA In IO Float GPIO2 5mA In IO Float Copyright © Bridgetek Pte Ltd Out, Float (CS_N = 1) 40 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Pin Name Default Drive Reset Normal Power Down (Default) INT_N 5mA OD, Float OD / Out Float PD_N - In In In GPIO3 5mA In IO Float SPIM_SCLK 5mA In Out Float SPIM_MISO 5mA In IO Float SPIM_MOSI 5mA In IO Float SPIM_SS_N 5mA In Out Float SPIM_IO2 5mA In IO Float SPIM_IO3 5mA In IO Float X1/CLK - In In In XP - IO, Float IO Retain YP - IO, Float IO Retain XM - IO, Float IO Retain YM - IO, Float IO Retain CTP_RST_N 5mA Out Out Pull Low CTP_INT_N 5mA In I/O In CTP_SCL 20mA OD IO Float CTP_SDA 20mA OD IO Float BACKLIGHT 1.2mA Out Out Pull Low DE 1.2mA Out Out Pull Low VSYNC 1.2mA Out Out Pull Low HSYNC 1.2mA Out Out Pull Low DISP 1.2mA Out Out Pull Low PCLK 1.2mA Out Out Pull Low R/G/B 1.2mA Out Out Pull Low Table 4-21 Pin Status Copyright © Bridgetek Pte Ltd 41 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 5 Memory Map All memory and registers in the BT815/6 core are memory mapped in 22-bit address space with a 2-bit SPI command prefix. Prefix 0'b00 for read and 0'b10 for write to the address space, 0'b01 is reserved for Host Commands and 0'b11 undefined. The following are the memory space definition. Start Address End Address Size NAME Description 00 0000h 0F FFFFh 1024 kB RAM_G General purpose graphics RAM 20 0000h 2F FFFFh 1024 kB ROM ROM codes, font table and bitmap 30 0000h 30 1FFFh 8 kB RAM_DL Display List RAM 30 2000h 30 2FFFh 4 kB RAM_REG Registers 30 8000h 30 8FFFh 4 kB RAM_CMD Command buffer 80 0000h 107F FFFFh 256 MB FLASH External NOR flash memory. Maximum 256MB. The address is used by internal command only. Table 5-1 BT815/6 Memory Map Note 1: The addresses beyond this table are reserved and shall not be read or written unless otherwise specified. 5.1 Registers Table 5-2 shows the complete list of the BT815/6 registers. Refer to BT81X_Series_Programming_Guide, Chapter 3 for details of the register function. Address (hex) Register Name 302000h REG_ID 302004h r/ w Reset value 8 r/o 7Ch REG_FRAMES 32 r/o 0 Frame counter, since reset 302008h REG_CLOCK 32 r/o 0 Clock cycles, since reset 30200Ch REG_FREQUENCY 28 r/w 60000000 302010h REG_RENDERMODE 1 r/w 0 Rendering mode: 0 = normal, 1 = singleline 302014h REG_SNAPY 11 r/w 0 Scanline select for RENDERMODE 1 302018h REG_SNAPSHOT 1 r/w - Trigger for RENDERMODE 1 30201Ch REG_SNAPFORMAT 6 r/w 20h 302020h REG_CPURESET 3 r/w 2 Copyright © Bridgetek Pte Ltd Bit s Description Identification register, always reads as 7Ch Main clock frequency (Hz) Pixel format for scanline readout Graphics, audio and touch engines reset control. Bit2: audio, bit1: touch, bit0: graphics 42 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Address (hex) Register Name 302024h REG_TAP_CRC 302028h Bit s Clearance No.: BRT#126 r/ w Reset value Description 32 r/o - REG_TAP_MASK 32 r/w FFFFFFFFh 30202Ch REG_HCYCLE 12 r/w 224h Horizontal total cycle count 302030h REG_HOFFSET 12 r/w 02Bh Horizontal display start offset 302034h REG_HSIZE 12 r/w 1E0h Horizontal display pixel count 302038h REG_HSYNC0 12 r/w 000h Horizontal sync fall offset 30203Ch REG_HSYNC1 12 r/w 029h Horizontal sync rise offset 302040h REG_VCYCLE 12 r/w 124h Vertical total cycle count 302044h REG_VOFFSET 12 r/w 00Ch Vertical display start offset 302048h REG_VSIZE 12 r/w 110h Vertical display line count 30204Ch REG_VSYNC0 10 r/w 000h Vertical sync fall offset 302050h REG_VSYNC1 10 r/w 00Ah Vertical sync rise offset 302054h REG_DLSWAP 2 r/w 0 Display list swap control 302058h REG_ROTATE 3 r/w 0 Screen rotation control. Allow normal/mirrored/inverted for landscape or portrait orientation. 30205Ch REG_OUTBITS 9 r/w 0 Output bit resolution, 3 register bits each for R/G/B. 0 indicates 8 bits, 1-7 indicates 1-7 bits respectively. 302060h REG_DITHER 1 r/w 1 Output dither enable 302064h REG_SWIZZLE 4 r/w 0 Output RGB signal swizzle 302068h REG_CSPREAD 1 r/w 1 Output clock spreading enable 30206Ch REG_PCLK_POL 1 r/w 0 PCLK polarity: Live video tap crc. Frame CRC is computed every DL SWAP. Live video tap mask 0 = output on PCLK rising edge, 1 = output on PCLK falling edge 302070h REG_PCLK 8 r/w 0 PCLK frequency divider, 0 = disable 302074h REG_TAG_X 11 r/w 0 Tag query X coordinate 302078h REG_TAG_Y 11 r/w 0 Tag query Y coordinate 30207Ch REG_TAG 8 r/o 0 Tag query result 302080h REG_VOL_PB 8 r/w FFh Volume for playback 302084h REG_VOL_SOUND 8 r/w FFh Volume for synthesizer sound 302088h REG_SOUND 16 r/w 0 Copyright © Bridgetek Pte Ltd Sound effect select 43 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Address (hex) Register Name Bit s r/ w Reset value 30208Ch REG_PLAY 1 r/w 0h 302090h REG_GPIO_DIR 8 r/w 80h Clearance No.: BRT#126 Description Start effect playback Legacy GPIO pin direction, 0 = input , 1 = output 302094h REG_GPIO 302098h REG_GPIOX_DIR 8 r/w 00h 16 r/w 8000h Legacy GPIO read/write Extended GPIO pin direction, 0 = input , 1 = output 30209Ch REG_GPIOX 3020A0h3020A4h Reserved - - 3020A8h REG_INT_FLAGS 8 r/o 00h 3020Ach REG_INT_EN 1 r/w 0 3020B0h REG_INT_MASK 8 r/w FFh 3020B4h REG_PLAYBACK_START 20 r/w 0 Audio playback RAM start address 3020B8h REG_PLAYBACK_LENGTH 20 r/w 0 Audio playback sample length (bytes) 3020BCh REG_PLAYBACK_READPTR 20 r/o - Audio playback current read pointer 3020C0h REG_PLAYBACK_FREQ 16 r/w 8000 3020C4h REG_PLAYBACK_FORMAT 2 r/w 0 Audio playback format 3020C8h REG_PLAYBACK_LOOP 1 r/w 0 Audio playback loop enable 3020CCh REG_PLAYBACK_PLAY 1 r/w 0 Start audio playback 3020D0h REG_PWM_HZ 14 r/w 250 BACKLIGHT PWM output frequency (Hz) 3020D4h REG_PWM_DUTY 8 r/w 128 BACKLIGHT PWM output duty cycle 0=0%, 128=100% 3020D8h REG_MACRO_0 32 r/w 0 Display list macro command 0 3020DCh REG_MACRO_1 32 r/w 0 Display list macro command 1 3020E0h – 3020F4h Reserved - - Reserved 3020F8h REG_CMD_READ 12 r/w 0 Command buffer read pointer 3020FCh REG_CMD_WRITE 12 r/o 0 Command buffer write pointer 302100h REG_CMD_DL 13 r/w 0 Command display list offset 302104h REG_TOUCH_MODE 2 r/w 3 Touch-screen sampling mode 302108h REG_TOUCH_ADC_MODE 1 r/w 1 Set Touch ADC mode REG_CTOUCH_EXTENDED Copyright © Bridgetek Pte Ltd 16 - r/w 0080h - Extended GPIO read/write Reserved Interrupt flags, clear by read Global interrupt enable, 1=enable Individual interrupt enable, 1=enable Audio playback sampling frequency (Hz) Set capacitive touch operation mode: 44 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Address (hex) Register Name Bit s r/ w Reset value Clearance No.: BRT#126 Description 0: extended mode (multi-touch) 1: FT800 compatibility mode (single touch). 30210Ch REG_TOUCH_CHARGE 16 r/w 9000 REG_EHOST_TOUCH_X Touch charge time, units of 6 clocks Touch host mode: touch x value updated by host 302110h REG_TOUCH_SETTLE 4 r/w 3 Touch settle time, units of 6 clocks 302114h REG_TOUCH_OVERSAMPLE 4 r/w 7 Touch oversample factor REG_EHOST_TOUCH_ID 302118h REG_TOUCH_RZTHRESH Touch host mode: touch ID, 0-4 16 r/w FFFFh REG_EHOST_TOUCH_Y 30211Ch REG_TOUCH_ Touch host mode: touch x value updated by host 32 r/o - RAW_XY REG_TOUCH_RZ 16 r/o - REG_CTOUCH_TOUCH4_Y 302124h REG_TOUCH_ 32 r/o - 32 r/o - Touch-screen screen (x-MSB16; yLSB16) used for tag 0 lookup 8 r/o - Touch-screen tag result 0 32 r/o - Touch-screen screen (x-MSB16; yLSB16) used for tag 1 lookup 8 r/o - Touch-screen tag result 1 32 r/o - Touch-screen screen (x-MSB16; yLSB16) used for tag 2 lookup 8 r/o - Touch-screen tag result 2 32 r/o - Touch-screen screen (x-MSB16; yLSB16) used for tag 3 lookup 8 r/o - Touch-screen tag result 3 TAG_XY 30212Ch REG_TOUCH_TAG 302130h REG_TOUCH_ TAG1_XY 302134h REG_TOUCH_TAG1 302138h REG_TOUCH_ TAG2_XY 30213Ch REG_TOUCH_TAG2 302140h REG_TOUCH_ TAG3_XY 302144h REG_TOUCH_TAG3 Copyright © Bridgetek Pte Ltd Compatibility mode: touch-screen screen (x-MSB16; y-LSB16) Extended mode: touch-screen screen data for touch 0 (x-MSB16; y-LSB16) REG_CTOUCH_TOUCH0_XY REG_TOUCH_ Compatibility mode: touch-screen resistance Extended mode: touch-screen screen Y data for touch 4 SCREEN_XY 302128h Compatibility mode: touch-screen raw (xMSB16; y-LSB16) Extended mode: touch-screen screen data for touch 1 (x-MSB16; y-LSB16) REG_CTOUCH_TOUCH1_XY 302120h Touch resistance threshold 45 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Address (hex) Register Name 302148h REG_TOUCH_ Bit s Clearance No.: BRT#126 r/ w Reset value 32 r/o - Touch-screen screen (x-MSB16; yLSB16) used for tag 4 lookup 8 r/o - Touch-screen tag result 4 TAG4_XY Description 30214Ch REG_TOUCH_TAG4 302150h REG_TOUCH_TRANSFORM_A 32 r/w 00010000h Touch-screen transform coefficient (s15.16) 302154h REG_TOUCH_TRANSFORM_B 32 r/w 00000000h Touch-screen transform coefficient (s15.16) 302158h REG_TOUCH_TRANSFORM_C 32 r/w 00000000h Touch-screen transform coefficient (s15.16) 30215Ch REG_TOUCH_TRANSFORM_D 32 r/w 00000000h Touch-screen transform coefficient (s15.16) 302160h REG_TOUCH_TRANSFORM_E 32 r/w 00010000h Touch-screen transform coefficient (s15.16) 302164h REG_TOUCH_TRANSFORM_F 32 r/w 00000000h Touch-screen transform coefficient (s15.16) 302168h REG_TOUCH_CONFIG 16 r/w 8381h (BT816) 0381h (BT815) Touch configuration. RTP/CTP select RTP: short-circuit, sample clocks CTP: I2C address, CTPM type, low-power mode, touch host mode 30216Ch REG_CTOUCH_TOUCH4_X 16 r/o - Extended mode: touch-screen screen X data for touch 4 302170h REG_EHOST_TOUCH_ACK 4 r/w 0 Touch host mode: acknowledgement 302174h REG_BIST_EN 1 r/w 0 BIST memory mapping enable 302178h302187Ch Reserved - - - Reserved 302180h REG_TRIM 5 r/w 0 Internal relaxation clock trimming 302184h REG_ANA_COMP 8 r/w 0 Analogue control register Copyright © Bridgetek Pte Ltd 46 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Address (hex) Register Name 302188h REG_SPI_WIDTH Bit s 3 r/ w Reset value r/w 0 Clearance No.: BRT#126 Description QSPI bus width setting Bit [2]: extra dummy cycle on read Bit [1:0]: bus width (0=1-bit, 1=2-bit, 2=4-bit) 30218Ch REG_TOUCH_DIRECT_XY 32 r/o - Extended mode: touch-screen screen data for touch 2 (x-MSB16; y-LSB16) REG_CTOUCH_TOUCH2_XY 302190h REG_TOUCH_DIRECT_Z1Z2 32 r/o - Reserved 302564h REG_DATESTAMP 302574h Compatibility mode: Touch screen direct (z1-MSB16; z2-LSB16) conversions Extended mode: touch-screen screen data for touch 3 (x-MSB16; y-LSB16) REG_CTOUCH_TOUCH3_XY 302194h302560h Compatibility mode: Touch screen direct (x-MSB16; y-LSB16) conversions - - - Reserved 128 r/o - Stamp date code REG_CMDB_SPACE 12 r/w FFCh 302578h REG_CMDB_WRITE 32 w/o 0 Command DL (bulk) write 30257Ch REG_ADAPTIVE_FRAMERATE 1 r/w 1 Reduce frame rate during complex drawing 3025ECh REG_PLAYBACK_PAUSE 1 r/w 0 Audio playback pause 3025F0h REG_FLASH_STATUS 2 r/w 0 Flash status Command DL (bulk) space available Table 5-2 Overview of BT815/6 Registers Note: All register addresses are 4-byte aligned. The value in the “Bits” column refers to the number of valid bits from bit 0 unless otherwise specified; other bits are reserved. 5.2 Chip ID The BT815/6 Chip ID can be read at memory location 0C0000h – 0C0003h. The reset values of these bytes are: - 0C0000h: 0C0001h: 0C0002h: 0C0003h: 08h 15h (BT815), 16h(BT816) 01h 00h Note that the Chip ID location can be over-written by software. Copyright © Bridgetek Pte Ltd 47 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 6 Devices Characteristics and Ratings 6.1 Absolute Maximum Ratings The absolute maximum ratings for the BT815/6 devices are as follows. These are in accordance with the Absolute Maximum Rating System (IEC 60134). Exceeding these may cause permanent damage to the device. Parameter Value Unit Storage Temperature -65 to +150 °C Floor Life (Out of Bag) At Factory Ambient 168 (IPC/JEDEC J-STD-033A MSL Level 3 Compliant)* Hours Ambient Temperature (Power Applied) -40 to +85 °C VCC Supply Voltage 0 to +4 V VCCIO Supply Voltage 0 to +4 V DC Input Voltage -0.5 to + (VCCIO + 0.3) V (30°C / 60% Relative Humidity) Table 6-1 Absolute Maximum Ratings * If the devices are stored out of the packaging, beyond this time limit, the devices should be baked before use. The devices should be ramped up to a temperature of +125°C and baked for up to 17 hours. 6.2 ESD and Latch-up Specifications Description Specification Human Body Mode (HBM) > ± 2kV Machine mode (MM) > ± 200V Latch-up > ± 200mA Table 6-2 ESD and Latch-Up Specifications 6.3 DC Characteristics Parameter Description VCCIO1/ VCCIO operating supply voltage VCCIO2/VCC IO3 Copyright © Bridgetek Pte Ltd Minimum Typical Maximum Units 1.62 1.80 1.98 V 2.25 2.50 2.75 V 2.97 3.30 3.63 V Conditions Normal Operation 48 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Parameter Description VCC/VCCA VCC operating supply voltage Icc1 Clearance No.: BRT#126 Minimum Typical Maximum Units Conditions 2.97 3.30 3.63 V Normal Operation Power Down current - 0.2 - mA Power down mode Icc2 Sleep current - 0.6 - mA Sleep Mode Icc3 Standby current - 3 - mA Standby Mode Icc4 Operating current - 22 - mA Normal Operation Table 6-3 Operating Voltage and Current Parameter Description Minimum Typical Maximum Units Voh Output Voltage High VCCIO-0.4 - - V Ioh=5mA Vol Output Voltage Low - - 0.4 V Iol=5mA Vih Input High Voltage 2.0 - - V Vil Input Low Voltage - - 0.8 V Vth Schmitt Hysteresis Voltage 0.22 - 0.3 V Iin -10 - 10 uA -10 - 10 uA Rpu Input leakage current Tri-state output leakage current Pull-up resistor - 42 - kΩ Rpd Pull-down resistor - 44 - kΩ Ioz Conditions Vin = VCCIO or 0 Vin = VCCIO or 0 Table 6-4 Digital I/O Pin Characteristics (VCCIO = +3.3V) Parameter Description Voh Output Voltage High VCCIO-0.4 - - V Ioh=5mA Vol Output Voltage Low - - 0.4 V Iol=5mA Vih Input High Voltage 1.7 - - V - Vil Input Low Voltage - - 0.7 V - Copyright © Bridgetek Pte Ltd Minimum Typical Maximum Units Conditions 49 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Vth Schmitt Hysteresis Voltage Iin Rpu Input leakage current Tri-state output leakage current Pull-up resistor Rpd Pull-down resistor Ioz 0.2 - 0.3 V -10 - 10 uA -10 - 10 uA - 57 - kΩ - 59 - kΩ Clearance No.: BRT#126 - Vin = VCCIO or 0 Vin = VCCIO or 0 Table 6-5 Digital I/O Pin Characteristics (VCCIO = +2.5V) Parameter Description Minimum Typical Maximum Units Voh Output Voltage High VCCIO-0.4 - - V Ioh=5mA Vol Output Voltage Low - - 0.4 V Iol=5mA Vih Input High Voltage 1.2 - - V - Vil Input Low Voltage - - 0.6 V - Vth 0.17 - 0.3 V -10 - 10 uA -10 - 10 uA Rpu Schmitt Hysteresis Voltage Input leakage current Tri-state output leakage current Pull-up resistor - 90 - kΩ Rpd Pull-down resistor - 97 - kΩ Iin Ioz Conditions Vin = VCCIO or 0 Vin = VCCIO or 0 Table 6-6 Digital I/O Pin Characteristics (VCCIO = +1.8V) Parameter Description Units Conditions Rsw-on X-,X+,Y- and Y+ Drive On resistance - 6 10 Ω VCCIO=3.3V - 9 16 Ω VCCIO=1.8V Rsw-off X-,X+,Y- and Y+ Drive Off resistance 10 - - MΩ Rpu Touch sense pull up resistance 78 100 125 kΩ Vth+ Touch Detection rising-edge threshold on XP 1.59 - 2.04 V VCCIO=3.3V 0.58 - 0.68 V VCCIO=1.8V Copyright © Bridgetek Pte Ltd Minimum Typical Maximum 50 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Parameter Description Minimum Typical Maximum Clearance No.: BRT#126 Units Conditions pin Vth- Rl Touch Detection falling-edge threshold on XP pin 1.23 - 1.55 V VCCIO=3.3V 0.51 - 0.56 V VCCIO=1.8V X-axis and Y-axis drive load resistance 200 - - Ω Table 6-7 Touch Sense Characteristics 6.4 AC Characteristics 6.4.1 System Clock and Reset Value Parameter Units Minimum Typical Maximum Trimmed frequency target - 12 - MHz Trimmed frequency accuracy - ±1.2 ±6.0 % Trimmed frequency variation over temperature and voltage - - ±4.0 % Frequency - 12.000 - MHz X1/X2 Capacitance - - 10 pF Frequency - 12.000 - MHz Duty cycle 45 50 55 % - 3.3 - V Internal Relaxation Clock Crystal External clock input Input voltage on X1/CLK Reset Reset pulse on PD_N 5 ms Table 6-8 System Clock Characteristics Copyright © Bridgetek Pte Ltd 51 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 6.4.2 Clearance No.: BRT#126 SPI Interface Timing Figure 6-1 SPI Interface Timing VCCIO=1.8V VCCIO=2.5V VCCIO=3.3V Min Min Min Units Parameter Description Tsclk SPI clock period (SINGLE/DUAL mode) 33.3 33.3 33.3 ns Tsclk SPI clock period (QUAD mode) 33.3 33.3 33.3 ns Tsclkl SPI clock low duration 13 13 13 ns Tsclkh SPI clock high duration 13 13 13 ns Tsac SPI access time 4 3.5 3 ns Tisu Input Setup 4 3.5 3 ns Tih Input Hold 0 0 0 ns Tzo Output enable delay 16 13 11 ns Toz Output disable delay 13 11 10 ns Tod Output data delay 15 12 11 ns Tcsnh CSN hold time 0 Max 0 Max 0 Max ns Table 6-9 SPI Interface Timing Specifications Copyright © Bridgetek Pte Ltd 52 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 6.4.3 Clearance No.: BRT#126 RGB Interface Timing Value Parameter Description Tpclk Min Typ Pixel Clock period 13.9 27.8 Tpclkdc Pixel Clock duty cycle 40 50 Td Output delay relative to PCLK rising edge (REG_PCLK_POL=0) or falling edge (REG_PCLK_POL=1). Applied for all the RGB output pins. Th Output hold time relative to PCLK rising edge (REG_PCLK_POL=0) or falling edge (REG_PCLK_POL=1). Applied for all the RGB output pins. 0.5 Max Units ns 60 % 4 ns ns Table 6-10 RGB Interface Timing Characteristics Figure 6-2 RGB Interface Timing Copyright © Bridgetek Pte Ltd 53 Figure 7-1 BT815 application circuit 54 GND 3 2 0.1uF EN VIN U3 GND GND 6 1 R8 4.7k C10 2.2nF SCK_M CS#_M MOSI_M MISO_M IO2_M IO3_M INT# PD# SCK MISO MOSI CS# IO2 IO3 GND R9 LED Current Sense R22 10k/1% 95mV/1.6R = 60mA D1 1N4148 IO3_M SCK_M MOSI_M R5 47K MIC2289-34YML FB VOUT SW NR3015T220M L1 0.1uF C7 7 VCC33 INT# CS# MOSI IO2 W25Q128JVSIQ 8 CS# VCC 7 MISO IO3 6 CLK IO2 5 GND MOSI U2 C13 GND C14 10uF GND 1 2 3 4 VCC33 R4 47K BL_PWM CS#_M MISO_M IO2_M 2 4 6 8 10 12 14 16 2 4 6 8 10 12 14 16 8x2 Pin Header 1 3 5 7 9 11 13 15 CN1 SPI NOR Flash GND R3 47K PD# AUDIO 1 3 5 7 9 11 13 15 R1 4.7K Host Connector 9 SCK MISO IO3 VCC33 AGND PGND EP C15 0.22uF GND GND 1.6R R10 LEDK LEDA VCC33 0.1uF 0.1uF GND C6 C5 GND 18pF C8 R0 VCC1.2 SCK MISO MOSI CS_N GPIO0/IO2 GPIO1/IO3 VCCIO1 GPIO2 INT_N PD_N GPIO3 SPIMSCLK SPIMSSN SPIMMOSI R0 R1 R2 R3 R4 R5 R6 R7 12MHz GND 18pF C9 Y1 Backlight LED driver 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 BT815 GND C12 10uF VCC12 0.1uF C11 CTP_SDA CTP_SCL CTP_INT# CTP_RST# AUDIO EP/GND GND B0 B1 B2 B3 B4 B5 B6 B7 PCLK DISP HSYNC VSYNC DE BACKLIGHT GND BT815 65 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 CTP_INT# CTP_RST# CTP_SDA CTP_SCL B0 B1 B2 B3 B4 B5 B6 B7 PCLK DISP HSYNC VSYNC DE BL_PWM R6 1k R7 1k GND VCC33 PCLK DISP HSYNC VSYNC DE R0 R1 R2 R3 R4 R5 R6 R7 G0 G1 G2 G3 G4 G5 G6 G7 B0 B1 B2 B3 B4 B5 B6 B7 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 0 J1 0 1 2 3 4 5 6 0 J2 CN_6Pin_FPC 0 1 2 3 4 5 6 0 GND 0.5B-40PBS VCC33 LEDK LEDA CTP Connector GND GND 0.1uF 0.1uF 0.1uF 0.1uF U1 C4 C3 C2 C1 VCC33 TFT Connector Document No.: BRT_000220 4 8 9 G0 G1 G2 G3 G4 G5 G6 G7 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 R1 R2 R3 R4 R5 R6 R7 VCC1.2 G0 G1 G2 G3 G4 G5 G6 G7 VCCIO3 SPIMMISO SPIMIO2 SPIMIO3 X1/CLK X2 GND VCC VCC1.2 AUDIO_L VCCA VCCIO2 CTP_RST_N CTP_INT_N CTP_SCL CTP_SDA Copyright © Bridgetek Pte Ltd 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 VCC12 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Clearance No.: BRT#126 7 Application Examples Figure 7-2 BT816 application circuit 55 2 4 6 8 10 12 14 16 GND 3 2 0.1uF EN VIN U3 GND GND 6 1 R8 4.7k C10 2.2nF SCK_M CS#_M MOSI_M MISO_M IO2_M IO3_M INT# PD# SCK MISO MOSI CS# IO2 IO3 GND R9 LED Current Sense R22 10k/1% 95mV/1.6R = 60mA D1 1N4148 IO3_M SCK_M MOSI_M R5 47K MIC2289-34YML FB VOUT SW NR3015T220M L1 0.1uF C7 7 VCC33 INT# CS# MOSI IO2 W25Q128JVSIQ 8 CS# VCC 7 MISO IO3 6 CLK IO2 5 GND MOSI U2 C13 GND C14 10uF GND 1 2 3 4 VCC33 R4 47K BL_PWM CS#_M MISO_M IO2_M 2 4 6 8 10 12 14 16 8x2 Pin Header 1 3 5 7 9 11 13 15 CN1 SPI NOR Flash GND R3 47K PD# AUDIO 1 3 5 7 9 11 13 15 R1 4.7K Host Connector 9 SCK MISO IO3 VCC33 AGND PGND EP C15 0.22uF GND GND 1.6R R10 LEDK LEDA VCC33 0.1uF 0.1uF GND C6 C5 GND 18pF C8 R0 VCC1V2 SCK MISO MOSI CS_N GPIO0/IO2 GPIO1/IO3 VCCIO1 GPIO2 INT_N PD_N GPIO3 SPIMSCLK SPIMSSN SPIMMOSI R0 R1 R2 R3 R4 R5 R6 R7 12MHz GND 18pF C9 Y1 Backlight LED driver 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 BT816 GND C12 10uF VCC12 0.1uF C11 YM XM YP XP AUDIO EP/GND GND B0 B1 B2 B3 B4 B5 B6 B7 PCLK DISP HSYNC VSYNC DE BACKLIGHT GND 65 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 GND GND B0 B1 B2 B3 B4 B5 B6 B7 PCLK DISP HSYNC VSYNC DE BL_PWM 0.1uF 0.1uF 0.1uF 0.1uF U1 BT816 C4 C3 C2 C1 VCC33 XP YM XM YP PCLK DISP HSYNC VSYNC DE R0 R1 R2 R3 R4 R5 R6 R7 G0 G1 G2 G3 G4 G5 G6 G7 B0 B1 B2 B3 B4 B5 B6 B7 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 0 J1 GND 0.5B-40PBS VCC33 LEDK LEDA 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 0 TFT Connector Document No.: BRT_000220 4 8 9 G0 G1 G2 G3 G4 G5 G6 G7 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 R1 R2 R3 R4 R5 R6 R7 VCC1V2 G0 G1 G2 G3 G4 G5 G6 G7 VCCIO3 SPIMMISO SPIMIO2 SPIMIO3 X1/CLK X2 GND VCC VOUT1V2 AUDIO_L VCCA VCCIO2 X+ Y+ XY- Copyright © Bridgetek Pte Ltd 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 VCC12 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Clearance No.: BRT#126 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 8 Package Parameters The BT815/6 is available in VQFN-64 package. The package dimensions, markings and solder reflow profile for all packages are described in following sections. 8.1 Part Markings 8.1.1 Top Side 64 1 BRT XXXXXXXXXX BT815Q YYWW-A Line 1 – BRT Logo Line 2 – Wafer Lot Number Line 3 – BRT Part Number Line 4 – Date Code, Revision Notes: 1. YYWW = Date Code, where YY is year and WW is week number 2. BRT part number will be either BT815Q or BT816Q as per device selected. 8.1.2 Bottom Side No markings should be placed on the bottom side. Copyright © Bridgetek Pte Ltd 56 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 8.2 VQFN-64 Package Dimensions A A1 A3 b MIN. 0.80 0.00 0.18 NOM. 0.85 0.02 0.20 0.25 MAX. 0.90 0.05 0.30 All dimensions are in millimetres (mm) D E 9.00 9.00 D2 7.25 7.30 7.35 E2 7.25 7.30 7.35 e 0.50 L 0.35 0.40 0.45 K 0.20 Figure 8-1 VQFN-64 Package Dimensions 8.3 Solder Reflow Profile The recommended solder reflow profile for the package is shown in Figure 8-2. Temperature, T (Degrees C) tp Tp Critical Zone: when T is in the range TL to Tp Ramp Up TL tL TS Max Ramp Down TS Min tS Preheat 25 T = 25º C to TP Time, t (seconds) Figure 8-2 BT815/6 Solder Reflow Profile The recommended values for the solder reflow profile are detailed in Figure 8-2. Values are shown for both a completely Pb free solder process (i.e. the BT815/6 is used with Pb free solder), and for a non-Pb free solder process (i.e. the BT815/6 is used with non-Pb free solder). Copyright © Bridgetek Pte Ltd 57 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Profile Feature Average Ramp Up Rate (Ts to Tp) Clearance No.: BRT#126 Pb Free Solder Process Non-Pb Free Solder Process 3°C / second Max. 3°C / Second Max. Preheat - Temperature Min (Ts Min.) 150°C - Temperature Max (Ts Max.) - Time (ts Min to ts Max) 100°C 200°C 150°C 60 to 120 seconds 60 to 120 seconds 217°C 183°C 60 to 150 seconds Time Maintained Above Critical Temperature TL: - Temperature (TL) 60 to 150 seconds - Time (tL) Peak Temperature (Tp) 260°C 240°C Time within 5°C of actual Peak Temperature 20 to 40 seconds 20 to 40 seconds 6°C / second Max. 6°C / second Max. 8 minutes Max. 6 minutes Max. (tp) Ramp Down Rate Time for T= 25°C to Peak Temperature, Tp Table 8-1 Reflow Profile Parameter Values Copyright © Bridgetek Pte Ltd 58 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 9 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 5691 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Bridgetek Pte Ltd (BRT Chip) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested Bridgetek devices and other materials) is provided for reference only. While Bridgetek has taken care to assure it is accurate, this information is subject to customer confirmation, and Bridgetek disclaims all liability for system designs and for any applications assistance pr ovided by Bridgetek. Use of Bridgetek devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless Bridgetek from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H. Copyright © Bridgetek Pte Ltd 59 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Appendix A – References Document References BT81X_Series_Programming_Guide AN_252 FT800 Audio Primer AN_254 FT800 Designs with Visual TFT AN_259 FT800 Example with 8-bit MCU AN_275 FT800 Example with Arduino AN_276 Audio File Conversion AN_277 FT800 Create User Defined Font AN_281 FT800 Emulator Library User Guide AN_291 FT800 Create Multi-Language Font AN_299 FT800 FT801 Internal Clock Trimming AN_303 - FT800 Image File Conversion AN_308 FT800 Example with an 8-bit MCU AN_312 FT800 Example with ARM AN_314 FT800 Advanced Techniques - Working with Bitmaps AN_318 Arduino Library for FT800 Series AN_320 FT800 Example with PIC AN_327 EVE Screen Editor Installation Guide AN_336 FT8xx - Selecting an LCD Display FT800 Series Sample Application EVE Frequently Asked Questions Acronyms and Abbreviations Terms Description ADPCM Adaptive Differential Pulse Code Modulation ASCII American Standard Code for Information Interchange ASTC Adaptive Scalable Texture Compression CTPM Capacitive Touch Panel Module CTSE Capacitive Touch Screen Engine EVE Embedded Video Engine HMI Human Machine Interfaces I2C Inter-Integrated Circuit LCD Liquid Crystal Display Copyright © Bridgetek Pte Ltd 60 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 LED Light Emitting Diode MCU Micro Controller Unit MPU Micro Processor Unit PCM Pulse Code Modulation PLL Phased Locked Loop PWM WVGA ROM SPI VQFN Clearance No.: BRT#126 Pulse Width Modulation Wide Video Graphics Array Read Only Memory Serial Peripheral Interface Very Thin Quad Flat Non-Leaded Package Copyright © Bridgetek Pte Ltd 61 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Appendix B - List of Figures and Tables List of Figures Figure 2-1 BT815/6 Block Diagram ................................................................................................. 3 Figure 2-2 BT815/6 System Design Diagram .................................................................................... 3 Figure 3-1 Pin Configuration BT815 VQFN-64(Top View) .................................................................... 7 Figure 3-2 Pin Configuration BT816 VQFN-64 (Top View) ................................................................... 7 Figure 4-1 SPI Master and Slave in the Master Read Case ................................................................ 13 Figure 4-2 Single/Dual SPI Interface connection ............................................................................. 13 Figure 4-3 Quad SPI Interface connection ...................................................................................... 14 Figure 4-4 Internal relaxation oscillator connection ......................................................................... 20 Figure 4-5 Crystal Oscillator Connection ........................................................................................ 20 Figure 4-6 External Clock Input .................................................................................................... 20 Figure 4-6 Flash Interface States .................................................................................................. 26 Figure 4-7 RGB Timing Waveforms................................................................................................ 29 Figure 4-8 Resistive Touch Screen Connection ................................................................................ 33 Figure 4-9 Touch Screen Connection ............................................................................................. 34 Figure 4-10 Touch Host Mode Connections ..................................................................................... 36 Figure 4-11 Internal Regulator ..................................................................................................... 38 Figure 4-12 Power State Transition ............................................................................................... 39 Figure 6-1 SPI Interface Timing .................................................................................................... 52 Figure 6-2 RGB Interface Timing ................................................................................................... 53 Figure 7-1 BT815 application circuit .............................................................................................. 54 Figure 7-2 BT816 application circuit .............................................................................................. 55 Figure 8-1 VQFN-64 Package Dimensions ...................................................................................... 57 Figure 8-2 BT815/6 Solder Reflow Profile ....................................................................................... 57 List of Tables Table 3-1 BT815/6 Pin Description ................................................................................................ 11 Table 4-1 QSPI Channel Selection ................................................................................................. 12 Table 4-2 Host Memory Read Transaction ...................................................................................... 14 Table 4-3 Host Memory Write Transaction ...................................................................................... 15 Table 4-4 Host Command Transaction ........................................................................................... 15 Table 4-5 Host Command List ...................................................................................................... 19 Table 4-6 Interrupt Flags bit assignment ....................................................................................... 19 Table 4-7 Font Table Format ........................................................................................................ 22 Table 4-8 ROM Font Table ............................................................................................................ 23 Copyright © Bridgetek Pte Ltd 62 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Table 4-9 ROM font ASCII character width in pixels......................................................................... 25 Table 4-10 ROM Font Extended ASCII Characters ........................................................................... 25 Table 4-11 RGB PCLK Frequency................................................................................................... 27 Table 4-12 REG_SWIZZLE RGB Pins Mapping ................................................................................. 28 Table 4-13 Registers for RGB Horizontal and Vertical Timings ........................................................... 28 Table 4-14 Output Drive Current Selection ..................................................................................... 30 Table 4-15 Sound Effect .............................................................................................................. 31 Table 4-16 MIDI Note Effect ......................................................................................................... 32 Table 4-17 Resistive Touch Controller Operating Mode .................................................................... 33 Table 4-18 Capacitive Touch Controller Operating Mode .................................................................. 34 Table 4-19 Registers for Touch Host Mode .................................................................................... 36 Table 4-20 Power Supply ............................................................................................................. 37 Table 4-21 Pin Status .................................................................................................................. 41 Table 5-1 BT815/6 Memory Map ................................................................................................... 42 Table 5-2 Overview of BT815/6 Registers ...................................................................................... 47 Table 6-1 Absolute Maximum Ratings ............................................................................................ 48 Table 6-2 ESD and Latch-Up Specifications .................................................................................... 48 Table 6-3 Operating Voltage and Current ....................................................................................... 49 Table 6-4 Digital I/O Pin Characteristics (VCCIO = +3.3V) ............................................................... 49 Table 6-5 Digital I/O Pin Characteristics (VCCIO = +2.5V) ............................................................... 50 Table 6-6 Digital I/O Pin Characteristics (VCCIO = +1.8V) ............................................................... 50 Table 6-7 Touch Sense Characteristics .......................................................................................... 51 Table 6-8 System Clock Characteristics ......................................................................................... 51 Table 6-9 SPI Interface Timing Specifications ................................................................................. 52 Table 6-10 RGB Interface Timing Characteristics ............................................................................ 53 Table 8-1 Reflow Profile Parameter Values ..................................................................................... 58 Copyright © Bridgetek Pte Ltd 63 BT81X (815/6) Advanced Embedded Video Engine Datasheet Version 1.0 Document No.: BRT_000220 Clearance No.: BRT#126 Appendix C - Revision History Document Title: BT81X (815/6) Advanced Embedded Video Engine Datasheet Document Reference No.: BRT_000220 Clearance No.: BRT#126 Product Page: http://brtchip.com/product Document Feedback: Send Feedback Revision Changes Date Draft Initial Release 2018-02-22 1.0 Added application circuit / internal clock function and parameters 2018-08-15 Copyright © Bridgetek Pte Ltd 64
BT816Q-T 价格&库存
很抱歉,暂时无法提供与“BT816Q-T”相匹配的价格&库存,您可以联系我们找货
