CJQ4459
CJQ4459
    OTHER
    SOP-8
    CJQ4459
CJQ4459 数据手册
JIANGSU CHANGJIANG ELECTRONICS TECHNOLOGY CO., LTD SOP8 Plastic-Encapsulate MOSFETS CJQ4459 P-Channel Power MOSFET V(BR)DSS ID RDS(on)MAX 46mΩ@ -10V 72mΩ@ -4.5V -30V   SOP8   -6.5A DESCRIPTION The CJQ4459 combines advanced trench MOSFET technology with a low resistance package to provide extremely low RDS(ON). This device is ideal for load switch and battery protection applications APPLICATIONS z Battery Switch z Load Switch MARKING Equivalent Circuit Q4459= Device code D 8 Solid dot=Pin1 indicator D 7 D 6 D 5 Solid dot = Green molding compound device, if none, the normal device YY=Date Code 1 2 S Front side 3 S 4 S G MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted ) Parameter Symbol Limit Unit Drain-Source Voltage VDS -30 V Gate-Source Voltage VGS ±20 V Continuous Drain Current ID -6.5 A Pulsed Drain Current IDM -26 A 14 mJ PD 1.4 W RθJA 89 ℃/W Junction Temperature TJ 150 ℃ Storage Temperature Range Tstg -55 ~+150 ℃ Lead Temperature for Soldering Purposes(1/8’’ from case for 10s) TL 260 ℃ Single Pulsed Avalanche Energy Power Dissipation Thermal Resistance from Junction to Ambient EAS (1) (1).EAS condition: VDD=-50V,L=0.1mH, RG=25Ω, Starting TJ = 25°C   1 DMar6         Ta =25 Я unless otherwise specified Parameter Symbol Test Condition Min Typ Max Unit Off characteristics Drain-source breakdown voltage V(BR) DSS VGS = 0V, ID =-250µA Zero gate voltage drain current IDSS VDS =-30V, VGS =0V -1 µA Gate-body leakage current IGSS VDS =0V, VGS =±20V ±100 nA Gate-threshold voltage VGS(th) VDS =VGS, ID =-250µA -2.0 -2.4 V Static drain-source on-sate resistance RDS(on) VGS =-10V, ID =-6.5A 26 46 mΩ VGS =-4.5V, ID =-5A 46 72 mΩ -30 V On characteristics (note1) Forward transconductance gFS VDS =-5V, ID =-6.5A -1.4 6 S Dynamic characteristics (note 2) Input capacitance Ciss VDS =-15V,VGS =0V, 415 625 70 130 90 Output capacitance Coss Reverse transfer capacitance Crss 40 Qg 7.4 11 1.3 1.9 1.3 3.1 f =1MHz pF Switching characteristics (note 2) Total gate charge Gate-source charge Qgs Gate-drain charge Qgd Turn-on delay time td(on) Turn-on rise time Turn-off delay time tr td(off) Turn-off fall time tf Gate Resistance Rg VDS=-15V, VGS=-10V, ID=-6.5A nC 7.5 VDD=-15V,ID=-1A, 5.5 VGS=-10V,RG=3Ω, ns 19 RL=2.5Ω 7 f =1MHz, VDS=0V, 11.5 Ω -1 V IS -6.5 A ISM -26 A VGS=0V, 3.5 7.5 Drain-Source Diode Characteristics Drain-source diode forward voltage(note1) Continuous drain-source diode forward current Pulsed drain-source diode forward current VSD VGS =0V, IS=-1A Notes: 1. Pulse Test : Pulse Width≤300µs, duty cycle ≤2%. 2. Guaranteed by design, not subject to production.    2 DMar6 7\SLFDO&KDUDFWHULVWLFV Transfer Characteristics Output Characteristics -24 Pulsed -20 -4.5V -8.0V VDS= -5V -6.0V (A) -12 DRAIN CURRENT DRAIN CURRENT -15 ID -16 ID (A) Pulsed -4.0V -20 VGS=-3.5V -8 -10 Ta=100℃ -5 Ta=25℃ -4 -0 -0 -1 -2 -3 -4 DRAIN TO SOURCE VOLTAGE RDS(ON) —— 80 -5 VDS -0 -6 -0 -1 (V) -2 -3 -4 GATE TO SOURCE VOLTAGE ID RDS(ON) 100 —— VGS VGS Ta=25℃ Ta=25℃ Pulsed (mΩ) 60 80 RDS(ON) VGS= -4.5V ON-RESISTANCE RDS(ON) (mΩ) Pulsed ON-RESISTANCE -5 (V) 40 VGS= -10V 20 60 ID= -6.5A 40 20 0 -4 -8 -12 DRAIN CURRENT -16 ID -2 -20 -4 (A) -6 GATE TO SOURCE VOLTAGE -10 (V) IS —— VSD Threshold Voltage -2.1 -8 VGS -10 Ta=25℃ IS (A) -2.0 SOURCE CURRENT THRESHOLD VOLTAGE VTH (V) Pulsed ID= -250uA -1.9 -1.8 25 50 75 AMBIENT TEMPERATURE 100 Ta (℃ ) 125 -1 -0.1 -0.4 -0.6 -0.8 SOURCE TO DRAIN VOLTAGE -1.0 -1.2 VSD (V)    3 DMar6 SOP8 Package Outline Dimensions Symbol A A1 A2 b c D e E E1 L θ Dimensions In Millimeters Min 1.350 Max 1.750 Dimensions In Inches Min 0.053 Max 0.069 0.100 0.250 1.350 1.550 0.330 0.510 0.170 0.250 4.800 5.000 1.270(BSC) 0.004 0.010 0.053 0.061 0.013 0.020 0.007 0.010 0.189 0.197 0.050(BSC) 5.800 3.800 0.400 6.200 4.000 1.270 0.228 0.150 0.016 0.244 0.157 0.050 0° 8° 0° 8° SOP8 Suggested Pad Layout www.cj-elec.com 4 D,Mar,2016 SOP8 Tape and Reel Dimensions are in millimeter Reel Option D D1 D2 G H I W1 W2 13''Dia Ø330.00 100.00 13.00 R151.00 R56.00 R6.50 12.40 17.60 G.W.(kg) REEL 4,000 pcs www.cj-elec.com Reel Size Box 13 inch 8,000 pcs Box Size(mm) Carton Carton Size(mm) 360×360×65 64,000 pcs 565×380×390 5 D,Mar,2016
CJQ4459 价格&库存
很抱歉,暂时无法提供与“CJQ4459”相匹配的价格&库存,您可以联系我们找货
