DEA162500LT-5033F1
DEA162500LT-5033F1
    OTHER
    DEA162500LT-5033F1
DEA162500LT-5033F1 数据手册
July. 2016 Ver.2.0 TDK Corporation Multilayer Low Pass Filter For 2400-2500MHz DEA Series P/N: 1.6x0.8mm [EIA 0603] TYPE DEA162500LT-5033F1 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies July. 2016 Ver.2.0 TDK Corporation   DEA162500LT-5033F1 ■ SHAPES AND DIMENSIONS [Top View] [Bottom View] (6) (5) (4) (1) (2) (3) Dimensions (mm) L W T a b c d e 1.60 0.80 0.60 0.10 0.30 0.25 0.55 0.15 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 Terminal functions GND (1) Input Port (2) GND (3) GND (4) Output Port (5) (6) GND ■ TEMPERATURE RANGE Operating temperature Storage temperature –40 to +85 °C –40 to +85 °C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies July. 2016 Ver.2.0 TDK Corporation   DEA162500LT-5033F1 ■ ELECTRICAL CHARACTERISTICS Parameter Frequency (MHz) Insertion Loss (dB) 2400 to 2500 VSWR 2400 to 2500 Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C 3603 4804 6005 7206 8407 9608 10809 12010 13211 14412 to to to to to to to to to to 3720 4960 6200 7440 8680 9920 11160 12400 13640 14880 ( Measurement ) TDK Spec Min. Typ. Max. 0.53 0.80 1.13 2.0 15 30 30 43 10 33 20 31 10 35 20 48 10 35 10 31 10 27 15 25 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   July. 2016 Ver.2.0 TDK Corporation DEA162500LT-5033F1 ■ FREQUENCY CHARACTERISTICS All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   July. 2016 Ver.2.0 TDK Corporation DEA162500LT-5033F1 ■ RECOMMENDED LAND PATTERN ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies July. 2016 Ver.2.0 TDK Corporation   DEA162500LT-5033F1 ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications.
DEA162500LT-5033F1
物料型号:DEA162500LT-5033F1
器件简介:这是TDK公司生产的多层低通滤波器,适用于2400-2500MHz的频率范围。
引脚分配: - (1) GND:接地端口 - (2) Input Port:输入端口 - (3) GND:接地端口 - (4) GND:接地端口 - (5) Output Port:输出端口
参数特性: - 尺寸:长1.60mm,宽0.80mm,高0.60mm - 工作温度范围:-40至+85°C - 存储温度范围:-40至+85°C - 插入损耗:在2400至2500MHz频率范围内为0.53至0.80dB - VSWR(电压驻波比):在2400至2500MHz频率范围内为1.13至2.0 - 特定频率范围内的衰减值:例如,在3603至3720MHz为15dB,在4804至4960MHz为30dB - 特性阻抗:在+25±5°C时为50欧姆(标称值)
功能详解:该滤波器设计用于在指定频率范围内提供低通滤波功能,具有低插入损耗和高衰减特性。
应用信息:适用于一般电子设备,如音视频设备、通信设备、家用电器、娱乐设备、计算机设备、个人设备、办公设备、测量设备和工业机器人等。
封装信息:封装尺寸为1.6x0.8mm [EIA 0603]。
环境信息:符合RoHS指令,即限制有害物质使用。
推荐焊接曲线:提供了详细的焊接温度和时间参数,推荐使用无铅焊料。
安全提醒:在使用这些产品时,需要请求交货规格,并注意安全设计警告。产品不适用于需要更高安全或可靠性水平的特定应用,如航空/航空设备、运输设备、医疗设备等。
DEA162500LT-5033F1 价格&库存
很抱歉,暂时无法提供与“DEA162500LT-5033F1”相匹配的价格&库存,您可以联系我们找货
