ONE mXTEND
(NN02-201)
TM
DATASHEET
DATASHEET
ONE mXTENDTM (NN02-201)
ONE mXTEND™ (NN02-201)
The ONE mXTEND™ antenna booster, with a volume of only 21mm3, is the smallest
chip of the Virtual Antenna™ family. This miniature, multipurpose and ultra slim
component is designed to provide multiband connectivity at cellular IoT, including
connectivity within several 2G, 3G, 4G and 5G bands, but also for other regions of the
spectrum, such as Wi-Fi 6E.
Product Benefits
Smallest volume: Multiband cellular/ISM IoT performance in the smallest
volume form factor: 7.0 mm x 3.0 mm x 1.0 mm.
Multiband: 2G/3G, NB-IoT/LTE-M, 5G, ISM and Wi-Fi 6E applications.
Wide reach: Multi regional product (compatible with multiple regional standards).
Reliability: Off-the-Shelf standard product, no antenna part customization
(electronic optimization).
Use cases: Wi-Fi 6E devices and IoT entry level products such as miniature.
trackers, IoT sensors, wearables and alike.
Operation Bands Summary
GSM, UMTS, 5G, Wi-Fi 6E (824 – 960MHz, 1710 – 2170MHz, 3300 – 5000MHz, 5170 –
5835 MHz and 5925 – 7125 MHz)
Last Update: January 2022
2
DATASHEET
1. AVAILABLE SOLUTIONS SUMMARY
Class
Frequency
Regions
Frequency range
More detailed info
1 Port
1
3300 – 5000 MHz
5G
1 Port
2
1 Port
2
1 Port
3
880 – 894 MHz &
1710 – 2170 MHz
824 – 960 MHz &
1710 – 2170 MHz
2400 – 2500 MHz &
5170 – 5835 MHz &
5925 – 7125 MHz
CELLULAR EUROPE
CELLULAR USA
Wi-Fi 6E
2. DETAILED AVAILABLE SOLUTIONS
2.1. 5G SOLUTION
Technical features
3300 MHz – 5000 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 70 %
4.1
< 3:1
Omnidirectional
Linear
0.02 g.
-40 to +125 ºC
50 Ω
Technical features. Measures from the evaluation board (131 mm x 60 mm x 1 mm).
2.2 CELLULAR EUROPE SOLUTION
Technical features
880 – 960 MHz
1710 – 2170 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 55%
1.3 dBi
> 65%
1.7 dBi
< 3:1
Omnidirectional
Linear
0.02 g.
-40 to +125 ºC
50 Ω
3
DATASHEET
2.3 CELLULAR USA SOLUTION
Technical features
824 – 894 MHz
1850 – 2170 MHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 65%
1.9
> 70%
2.0
< 3:1
Omnidirectional
Linear
0.02 g.
-40 to +125 ºC
50 Ω
2.4 WI-FI 6E SOLUTION
Technical
features
Average
Efficiency
Peak Gain
VSWR
Radiation
Pattern
Polarization
Weight
(approx.)
Temperature
Impedance
Dimensions
(L x W x H)
2400 – 2500 MHz
5170 – 5835 MHz
5925 – 7125 MHz
> 80%
> 85%
> 85%
3.2
3.3
< 2.5:1
Omnidirectional
5.0
Linear
0.02 g.
-40 to +125 ºC
50 Ω
Technical features. Measures from the evaluation board (86 mm x 54 mm x 1 mm).
4
DATASHEET
2.5 ANTENNA FOOTPRINT
Measure
A
B
C
D
mm
3.0
1.65
2.3
6.3
Tolerance: ±0.05mm
Footprint dimensions for the ONE mXTENDTM (NN02-201) antenna booster.
If you need assistance to design your matching network beyond this application note, please
contact support@ignion.io, or if you are designing a different device size or a different
frequency band, we can assist you in less than 24 hours. Please, try our free-of-charge1
Antenna Intelligence Cloud, which will get you a complete design report including a custom
matching network for your device in 24h 1. Additional information related to Ignion’s range of
R&D services is available at: https://ignion.io/rdservices/
1
See terms and conditions for a free Antenna Intelligence Cloud service in 24h at: https://www.ignion.io/antenna-intelligence/
5
DATASHEET
Contact:
support@ignion.io
+34 935 660 710
Barcelona
Av. Alcalde Barnils, 64-68 Modul C, 3a pl.
Sant Cugat del Vallés
08174 Barcelona
Spain
Shanghai
Shanghai Bund Centre
18/F Bund Centre, 222 Yan’an Road East,
Huangpu District
Shanghai, 200002
China
New Dehli
New Delhi, Red Fort Capital Parsvnath Towers
Bhai Veer Singh Marg, Gole Market,
New Delhi, 110001
India
Tampa
8875 Hidden River Parkway
Suite 300
Tampa, FL 33637
USA
6
很抱歉,暂时无法提供与“NN02-201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+3.440595000+0.44514
- 10000+3.3667710000+0.43558
- 15000+3.3298015000+0.43080
- 25000+3.2888325000+0.42550
- 国内价格 香港价格
- 1+7.855521+1.01632
- 10+5.5959910+0.72399
- 25+5.0382125+0.65183
- 100+4.42471100+0.57246
- 250+4.13188250+0.53457
- 500+3.95551500+0.51175
- 1000+3.810411000+0.49298
- 2500+3.781282500+0.48921
