C1808C470JHGAC7800
C1808C470JHGAC7800
    KEMET/TDK
    C1808C470JHGAC7800
C1808C470JHGAC7800 数据手册
Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Overview KEMET’s High Voltage surface mount MLCCs in C0G dielectric are temperature compensating and are suited for resonant circuit applications or those where Q and stability of capacitance characteristics are required. C0G exhibits no change in capacitance with respect to time and voltage and boasts a negligible change in capacitance with reference to ambient temperature. Capacitance change is limited to ±30ppm/°C from −55°C to +125°C. These devices exhibit low ESR at high frequencies and find conventional use as snubbers or filters in applications such as switching power supplies and lighting ballasts. Their exceptional performance at high frequencies has made C0G high voltage the preferred dielectric choice of design engineers worldwide. In addition to Commercial Grade, Automotive Grade devices are available which meet the demanding Automotive Electronics Council's AEC–Q200 qualification requirements. Benefits • Operating temperature range of −55°C to +125°C • Capacitance offerings ranging from 1 pF to 0.15 μF • DC voltage ratings of 500 V, 630 V, 1 KV, 1.5 KV, 2 KV, 2.5 KV, 3 KV and 10KV • EIA 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225, 2824, 3040, 3640 and 4540 case sizes • Extremely low ESR and ESL • High ripple current capability • No capacitance shift with voltage • Negligible capacitance shift with respect to temperature • No piezoelectric noise • Lead (Pb)-Free, RoHS and REACH compliant Click image above for interactive 3D content Open PDF in Adobe Reader for full functionality Applications • High frequency power converters • Wide bandgap (WBG), silicon carbide (SiC) and gallium nitride (GaN) systems • Snubber (high dV/dT) • Resonant circuits (LLC, Wireless Charging, etc) • Timing • Filtering Built Into Tomorrow © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 1 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Ordering Information C 1210 Ceramic 2 332 Case Size Specification/ Capacitance (L" x W") Series Code (pF) 0603 0805 1206 1210 1808 1812 1825 2220 2225 2824 3040 3640 4540 1 C C = Standard Two significant digits and number of zeros. J Capacitance Tolerance1 B = ±0.10 pF C = ±0.25 pF D = ±0.5 pF F = ±1% G = ±2% J = ±5% K = ±10% M = ±20% C G A Rated Voltage Failure Rate/ Dielectric (VDC) Design C = 500 B = 630 D = 1,000 F = 1,500 G = 2,000 Z = 2,500 H = 3,000 K = 10,000 G = C0G A = N/A C TU Termination Finish2 Packaging/ Grade (C-Spec) C = 100% Matte Sn L = SnPb (5% Pb minimum) See "Packaging C-Spec Ordering Options Table" Additional capacitance tolerance offerings may be available. Contact KEMET for details. Additional termination finish options may be available. Contact KEMET for details. Packaging C-Spec Ordering Options Table Packaging Type1 Bulk Bag/Unmarked 7" Reel/Unmarked 13" Reel/Unmarked 7" Reel/Unmarked/2 mm pitch2 13" Reel/Unmarked/2 mm pitch2 Packaging/Grade Ordering Code (C-Spec) Not required (Blank) TU 7411 (EIA 0603 and smaller case sizes) 7210 (EIA 0805 and larger case sizes) 7081 7082 Default packaging is “Bulk Bag”. An ordering code C-Spec is not required for “Bulk Bag” packaging. "Bulk Bag" packaging option is not available for case sizes larger than 2225 (5664 Metric). 1 The terms “Marked” and “Unmarked” pertain to laser marking option of capacitors. All packaging options labeled as “Unmarked” will contain capacitors that have not been laser marked. The option to laser mark is not available on these devices. For more information see “Capacitor Marking”. 2 The 2 mm pitch option allows for double the packaging quantity of capacitors on a given reel size. This option is limited to EIA 0603 (1608 metric) case size devices. For more information regarding 2 mm pitch option see “Tape & Reel Packaging Information”. 1 1 © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 2 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Dimensions – Millimeters (Inches) L W B T S EIA Size Code Metric Size Code 0603 1608 0805 2012 1206 3216 1210 3225 1808 4520 1812 4532 1825 4564 2220 5650 2225 5664 2824 7260 3040 7610 3640 9210 4540 - L Length W Width 1.60 (0.063) ±0.15 (0.006) 2.00 (0.079) ±0.20 (0.008) 3.20 (0.126) ±0.20 (0.008) 3.20 (0.126) ±0.20 (0.008) 4.70 (0.185) ±0.50 (0.020) 4.50 (0.177) ±0.30 (0.012) 4.50 (0.177) ±0.30 (0.012) 5.70 (0.224) ±0.40 (0.016) 5.60 (0.220) ±0.40 (0.016) 7.10 (0.280) ±0.40 (0.016) 7.60 (0.300) ±0.40 (0.016) 9.10 (0.358) ±0.40 (0.016) 11.40 (0.449) ±0.40 (0.016) 0.80 (0.032) ±0.15 (0.006) 1.25 (0.049) ±0.20 (0.008) 1.60 (0.063) ±0.20 (0.008) 2.50 (0.098) ±0.20 (0.008) 2.00 (0.079) ±0.20 (0.008) 3.20 (0.126) ±0.30 (0.012) 6.40 (0.252) ±0.40 (0.016) 5.00 (0.197) ±0.40 (0.016) 6.40 (0.248) ±0.40 (0.016) 6.10 (0.240) ±0.40 (0.016) 10.20 (0.402) ±0.40 (0.016) 10.20 (0.402) ±0.40 (0.016) 10.20 (0.402) ±0.40 (0.016) T Thickness B Bandwidth See Table 2 for Thickness 0.35 (0.014) ±0.15 (0.006) 0.50 (0.02) ±0.25 (0.010) 0.50 (0.02) ±0.25 (0.010) 0.50 (0.02) ±0.25 (0.010) 0.60 (0.024) ±0.35 (0.014) 0.60 (0.024) ±0.35 (0.014) 0.60 (0.024) ±0.35 (0.014) 0.60 (0.024) ±0.35 (0.014) 0.60 (0.024) ±0.35 (0.014) 1.27 (0.050) ±0.40 (0.016) 1.27 (0.050) ±0.40 (0.016) 1.27 (0.050) ±0.40 (0.016) 1.27 (0.050) ±0.40 (0.016) © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com S Separation Minimum Mounting Technique 0.70 (0.028) 0.75 (0.030) N/A Solder Wave or Solder Reflow Solder Reflow Only C1009_C0G_HV_SMD • 9/15/2020 3 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Qualification/Certification Commercial Grade products are subject to internal qualification. Details regarding test methods and conditions are referenced in Table 4, Performance & Reliability. Environmental Compliance Lead (Pb)-free, RoHS, and REACH compliant without exemptions (excluding SnPb termination finish option). Electrical Parameters/Characteristics Item Parameters/Characteristics Operating Temperature Range Capacitance Change with Reference to +25°C and 0 VDC Applied (TCC) Aging Rate (Maximum % Capacitance Loss/Decade Hour) Dielectric Withstanding Voltage (DWV) 1 2 Dissipation Factor (DF) Maximum Limit at 25°C 3 Insulation Resistance (IR) Limit at 25°C −55°C to +125°C ±30 ppm/°C 0% See Dielectric Withstanding Voltage (DWV) Table (5 ±1 seconds and charge/discharge not exceeding 50 mA) 0.1% 1,000 megohm microfarads or 100 GΩ (500 VDC applied for 120 ±5 seconds at 25°C) DWV is the voltage a capacitor can withstand (survive) for a short period of time. It exceeds the nominal and continuous working voltage of the capacitor. 2 Capacitance and dissipation factor (DF) measured under the following conditions: 1 MHz ±100 kHz and 1.0 Vrms ±0.2 V if capacitance ≤ 1,000 pF 1 kHz ±50 Hz and 1.0 Vrms ±0.2 V if capacitance > 1,000 pF 3 To obtain IR limit, divide MΩ-µF value by the capacitance and compare to GΩ limit. Select the lower of the two limits. Note: When measuring capacitance it is important to ensure the set voltage level is held constant. The HP4284 and Agilent E4980 have a feature known as Automatic Level Control (ALC). The ALC feature should be switched to "ON." 1 © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 4 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Dielectric Withstanding Voltage (DWV) EIA Case Size 500V 630V 0603 130% of rated voltage 0805 1206 1210 1808 ≥ 1000V 150% of rated voltage 1812 1825 2220 ±2225 < 620pF 150% of rated voltage ≥ 620pF 130% of rated voltage < 5.1nF 150% of rated voltage ≥ 5.1nF 130% of rated voltage < 7.5nF 150% of rated voltage ≥ 7.5nF 130% of rated voltage < 5.1nF 150% of rated voltage ≥ 5.1nF 130% of rated voltage < 12nF 150% of rated voltage ≥ 12nF 130% of rated voltage < 22nF 150% of rated voltage ≥ 22nF 130% of rated voltage < 27nF 150% of rated voltage ≥ 27nF 130% of rated voltage < 33nF 150% of rated voltage ≥ 33nF 130% of rated voltage 120% of rated voltage Post Environmental Limits High Temperature Life, Biased Humidity, Moisture Resistance Dielectric Rated DC Voltage Capacitance Value Dissipation Factor (Maximum %) Capacitance Shift C0G All All 0.5 0.3% or ±0.25 pF © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com Insulation Resistance 10% of Initial Limit C1009_C0G_HV_SMD • 9/15/2020 5 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 1A – Capacitance Range/Selection Waterfall (0603 – 1808 Case Sizes) 2500 3000 H 2000 Z 1500 G 1000 F 630 D LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LA LA LA LA LA LA LA LA LA LA LA LA LA LA LA LA LA LA LB LB LB LB LB LC LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LA LA LA LA LA LA LA LA LA LA LA LA LA LB LB LB LB LB LB LB LB LB LB LC LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LA LA LA LA LA LA LA LA LA LA LA LA LA LB LB LB LB LB LB LB LB LB LB LC LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LA LA LA LA LA LA LA LB LB LB LB LB LB LC LC LC LC LA LA LA LA LA LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LC LC LC LC LC LC LC LC LA LA LA LA LB LB LC LC LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LC LC LC LC LC LC LC LC LC LC LC LC LC LC LC LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LB LC LC LC LC Product Availability and Chip Thickness Codes See Table 2 for Chip Thickness Dimensions CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG CG Rated Voltage (VDC) 1000 1500 2000 2500 3000 FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FK FK FK FS FS FS FS FS FS FS FS 630 FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FK FK FK FK FK FS FS FS FS FS FS FM FM FY FY FS 500 FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FG FG FG FG FG FG FG FG FG FG FG FG FG FM FM FM FM FM FM FM FM FM FM FK 2000 FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FG FG FG FG FG FG FG FG FG FG FG FG FG FM FM FM FM FM FM FM FM FM FM FK 1500 FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FM FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FG FM FM FM 1000 ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED EF EF EF EF EG EG EG EG EG EG EG EG EG EG 630 ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED EF EF EF EF EG EG EG EG EG EG EG EG EG EG EG 500 ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED EF EF EF EF EF EG EG EG EG EG EG EG EG EG ED 2000 ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED EF EF EF EF EG 1500 ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED ED EF 1000 DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DN DN DN DN DP DP DP DG DG DG DG DG B 630 DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DN DN DN C 500 500 DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DG DN DN DN G 500 M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M F 2000 1000 K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K K D 1000 J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J B 1500 630 G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G C 1000 500 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F G 630 1000 C D F 500 630 Capacitance Tolerance C1808C D 2000 Rated Voltage (VDC) C1210C B 1500 C 1000 D 630 B 630 Cap Code C 500 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 112 D 1000 Capacitance 109 - 919* B 100 - 470* B 630 1.0 - 9.1 pF* 10 pF - 47pF* 11 pF 12 pF 13 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 51 pF 56 pF 62 pF 68 pF 75 pF 82 pF 91 pF 100 pF 110 pF 120 pF 130 pF 150 pF 160 pF 180 pF 200 pF 220 pF 240 pF 270 pF 300 pF 330 pF 360 pF 390 pF 430 pF 470 pF 510 pF 560 pF 620 pF 680 pF 750 pF 820 pF 910 pF 1,000 pF 1,100 pF Cap Code C1206C C 500 Capacitance C0805C Voltage Code 500 Case Size/Series C0603C Voltage Code C B D C B D C B D F G C B D F G C B D F G Z H Case Size/Series C0603C C0805C C1206C C1210C C1808C *Capacitance range Includes E24 decade values only. (i.e., 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91) KEMET reserves the right to substitute product with an improved temperature characteristic, tighter capacitance tolerance and/or higher voltage capability within the same form factor (configuration and dimensions). These products are protected under US Patents 7,172,985 and 7,670,981, other patents pending, and any foreign counterparts. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 6 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 1A – Capacitance Range/Selection Waterfall (0603 – 1808 Case Sizes) cont. 2500 3000 3000 B D C B D C B D F G C B D F G C B D F G Z H G G G G G G G G G G G G G G G G G G G G G G G G G G G G G J J J J J J J J J J J J J J J J J J J J J J J J J J J J J K K K K K K K K K K K K K K K K K K K K K K K K K K K K K Case Size/Series M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C0603C DN DN DP DP DG DG DG DG DG DN DN DP DP DG DG DG DG DG C0805C EF EF EF EF EF EG EG EG EG EB EB EC EC ED ED EE EF EF EG EG EG EG EH EG EG EG EG EG EG EG EB EB EB EB EB EB EC EC ED ED EE EF EF EG EG EG EG EH ED ED ED ED EF EF EF EG EG C1206C FM FM FK FK FK FK FK FS FS FS FS FL FL FM FM FY FY FY FY FS FS FF FG FG FM FM FY FS FS FK FS FS FS FS FL FL FL FL FL FM FM FY FY FY FS FS FE FE FF FF FF FG FG FM FM FY FS FS FK FS FS FS FS FS FS FS FS FF FG FG FL FL FM FM FM FY FY FS FS FS FS FM FS FS FS FS C1210C 1500 C F F F F F F F F F F F F F F F F F F F F F F F F F F F F F Product Availability and Chip Thickness Codes See Table 2 for Chip Thickness Dimensions 1000 Voltage Code Capacitance Tolerance 630 2500 500 2000 2000 Rated Voltage (VDC) 2000 1500 H 1500 1000 Z 1000 630 G 630 F 500 D 2000 B 1500 C 1000 G 630 F 500 500 D 500 1000 B 2000 630 C 2000 500 G 1500 1000 F 1500 630 D 1000 Rated Voltage (VDC) B 1000 C 630 D 630 B 500 C 1000 D 630 Capacitance Cap Code B 500 122 132 152 162 182 202 222 242 272 302 332 362 392 432 472 512 562 622 682 752 822 912 103 123 153 183 223 273 333 C C1808C 1000 1,200 pF 1,300 pF 1,500 pF 1,600 pF 1,800 pF 2,000 pF 2,200 pF 2,400 pF 2,700 pF 3,000 pF 3,300 pF 3,600 pF 3,900 pF 4,300 pF 4,700 pF 5,100 pF 5,600 pF 6,200pF 6,800pF 7,500pF 8,200 pF 9,100 pF 10,000 pF 12,000 pF 15,000 pF 18,000 pF 22,000 pF 27,000 pF 33,000 pF Voltage Code C1210C 630 Cap Code C1206C 500 Capacitance C0805C 500 Case Size/Series C0603C LC LC LC LC LC LC LC LC LC LA LA LA LA LA LA LA LB LC LC LA LA LA LA LA LB LC LC LC LC LC LC LA LA LA LA LA LA LB LB LC LC LB LC LC LC LA LA LA LA LA LB LC LC LC LC LC LC LB LB LB LC LA LA LA LA LA LB LB LC LC LC LC LC LC C1808C *Capacitance range Includes E24 decade values only. (i.e., 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91) KEMET reserves the right to substitute product with an improved temperature characteristic, tighter capacitance tolerance and/or higher voltage capability within the same form factor (configuration and dimensions). These products are protected under US Patents 7,172,985 and 7,670,981, other patents pending, and any foreign counterparts. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 7 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 1B – Capacitance Range/Selection Waterfall (1812 – 2225 Case Sizes) 1000 1500 2000 2500 3000 10000 GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GH GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GB GB GB GB GB GD GD GD GD GH GH GH GH GK GK GM GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GD GD GH GH GH GK GK GK GK GM GM GM GO GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GK GK GK GM GM GM GM GM GO GO GO HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HJ HJ HJ HJ HK HK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JE JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JK JK JL JL JL JL JN JN KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KF KF KF KF KF KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KF KF KF KF KF KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KF KF KF KF KF KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KE KE KE KE KE KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KE KE KE KE KE KE KE KE KE KE KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KF KH KH KH KJ KJ Rated Voltage (VDC) 10000 500 630 2500 2500 3000 3000 2000 GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB 2500 1500 GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GD GD GD GD GD GD GD GD GD GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB 3000 1000 1500 500 630 2000 K 1500 H 2000 Z 630 G 1000 F 630 D 1000 B 500 C 500 H 2500 Z 3000 G 2000 F 1500 D 1000 B 500 C 630 H 3000 Z 2500 G 2000 F 1500 D 1000 B 500 2500 3000 C 630 H 2500 Z 3000 1000 G 1500 500 F 2000 D 2000 B 1500 Cap Code C C2225C 1000 Capacitance 100 - 470* 110 120 130 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 Voltage Code C2220C 500 10 pF - 47pF* 11 pF 12 pF 13 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 51 pF 56 pF 62 pF 68 pF 75 pF 82 pF 91 pF 100 pF 110 pF 120 pF 130 pF 150 pF 160 pF 180 pF 200 pF 220 pF 240 pF 270 pF 300 pF 330 pF 360 pF 390 pF 430 pF 470 pF 510 pF 560 pF 620 pF 680 pF 750 pF 820 pF 910 pF Cap Code C1825C 630 Capacitance C1812C 630 Case Size/Series Voltage Code C B D F G Z H C B D F G Z H C B D F G Z H C B D F G Z H K Rated Voltage (VDC) F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F Capacitance Tolerance G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K Case Size/Series M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C1812C Product Availability and Chip Thickness Codes See Table 2 for Chip Thickness Dimensions C1825C C2220C KE KE KE KF KF KF KF KH KH KJ KJ KJ C2225C *Capacitance range Includes E24 decade values only. (i.e., 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91) KEMET reserves the right to substitute product with an improved temperature characteristic, tighter capacitance tolerance and/or higher voltage capability within the same form factor (configuration and dimensions). These products are protected under US Patents 7,172,985 and 7,670,981, other patents pending, and any foreign counterparts. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 8 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 1B – Capacitance Range/Selection Waterfall (1812 – 2225 Case Sizes) cont. C1812C D F G Z H C B D F G Z H K 500 630 1000 1500 2000 2500 3000 500 630 1000 1500 2000 2500 3000 500 630 1000 1500 2000 2500 3000 10000 D F G Z C1825C JK JK JK JE JE JE JE JK JK JL JL JL JN JN JN JK JN KE KE KE KF KE KF KJ JK KE KE KE KF KF KF JL KE KE KE KF KF KF JL KE KE KE KF KF KH JL KE KE KE KF KF KH JL KE KE KE KF KE KH JN KE KE KE KF KE KH KE KE KE KF KE KJ KE KE KE KF KF KJ KE KE KE KE KH KE KE KE KE KH KE KE KE KE KH KE KE KE KE KJ KE KF KF KF KJ KE KF KF KF KJ KE KF KF KF KE KF KF KH KE KF KF KH KE KF KF KH KE KF KF KJ KE KF KF KJ KF KE KF KF KE KF KF KE KH KF KE KH KE KE KH KE KF KJ KE KH KE KF KJ KF KF KJ KH KH KE KH KJ KE KJ KE KE KE KE KF KF KH KH KH KH KJ KJ H C B D F G C2220C Z H C B D F G 10000 B JK JK JK JK JK JK JK JE JE JE JE JE JK JK JK JK JL JL JN JN JN 2500 C JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JK JK JL JL JL JN JE JE JK JL JN 3000 H JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JE JK JL JL JN JN JE JE JE JK JL JL JN 1500 Z JE JE JE JE JE JE JE JE JE JK JK JK JK JK JK JK JK JK JK JK JK JK JK JE JE JE JE JE JK JL JN JE JE JK JL JL JN 2000 HG HJ HJ HJ HK HK 630 HG HG HG HE HE HG HG HJ HJ HJ HK HK 1000 HG HG HG HG HG HG HG HE HE HE HE HE HG HG HJ HJ HJ HK HK 500 HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HG HG HG HJ HJ HJ HK HK HE HE HG HJ HK HK 2500 HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HE HE HG HG HG HJ HK HE HE HE HE HE HG HJ HK HK 3000 HE HE HE HE HE HE HE HE HE HE HE HG HG HG HG HG HG HG HG HG HG HG HG HE HE HE HE HG HJ HJ HK HE HE HG HJ HK HK 2000 Product Availability and Chip Thickness Codes See Table 2 for Chip Thickness Dimensions 1500 2500 3000 B 1000 G C 500 F H 630 D Z 3000 B G 2500 C F 2000 Voltage Code D 1500 Rated Voltage (VDC) B 1000 GM GO GO GO GO C2225C C 500 GH GH GH GH GK GK GM GM GO GO GO H 630 GB GB GB GB GB GD GD GH GH GK GK GK GK GM GM GO GO GO GO GH GH GK GK GM GM GO GO Z C2220C 2500 GB GB GB GB GB GD GD GH GH GH GH GH GH GH GH GH GH GK GK GK GM GM GO GO GO GH GH GH GH GK GM GO GO C1825C 3000 1500 1000 G 2000 500 F GB GB GB GB GB GB GB GB GB GB GB GB GB GB GB GH GH GH GH GH GH GH GK GM GM GO GO GH GH GK GM GO GO Case Size/Series M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M D 2000 Capacitance Cap Code F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F Capacitance Tolerance G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K G J K B 1500 102 112 122 132 152 162 182 202 222 242 272 302 332 362 392 432 472 512 562 622 682 752 822 912 103 123 153 183 223 273 333 393 473 563 683 823 104 124 Rated Voltage (VDC) C 1000 1,000 pF 1,100 pF 1,200 pF 1,300 pF 1,500 pF 1,600 pF 1,800 pF 2,000 pF 2,200 pF 2,400 pF 2,700 pF 3,000 pF 3,300 pF 3,600 pF 3,900 pF 4,300 pF 4,700 pF 5,100 pF 5,600 pF 6,200pF 6,800pF 7,500pF 8,200 pF 9,100 pF 10,000 pF 12,000 pF 15,000 pF 18,000 pF 22,000 pF 27,000 pF 33,000 pF 39,000 pF 47,000 pF 56,000 pF 68,000 pF 82,000 pF 0.1 µF 0.12 µF Voltage Code 500 Cap Code 630 Capacitance C1812C 630 Case Size/Series Z H K C2225C *Capacitance range Includes E24 decade values only. (i.e., 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91) KEMET reserves the right to substitute product with an improved temperature characteristic, tighter capacitance tolerance and/or higher voltage capability within the same form factor (configuration and dimensions). These products are protected under US Patents 7,172,985 and 7,670,981, other patents pending, and any foreign counterparts. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 9 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 1C – Capacitance Range/Selection Waterfall (2824 – 4540 Case Sizes) Case Size/Series 2000 SA SA SA SA SA SA SA SA SA SA SA SA SA SA SA SA SB SB SC SA SA SA SA SA SA SA SA SA SA SA SA SA SA SB SB SC SA SA SA SA SA SA SA SA SA SA SA SB SB SB SC SA SA SA SA SA SA SB SB SB SC SA SA SA SA SB SB SB SC 2000 G 1500 F 1500 D 1000 F B 1000 D C 630 B G 630 C F 500 1500 Voltage Code D 500 Rated Voltage (VDC) B 2000 TA TA TA TB TB TC C 2000 500 TA TA TA TA TB TB TB TC G C4540C 1500 2000 TA TA TA TA TA TA TA TA TA TA TB TB TC F 1000 1500 TA TA TA TA TA TA TA TA TA TA TA TA TB TB TB TC D 630 1000 TA TA TA TA TA TA TA TA TA TA TA TA TA TA TB TB TB TC B 500 C 2000 G 1500 F 1000 D C3640C 630 B 1000 G C B D F G 630 1000 1500 G C B D F C2824C C3040C MA MA MA MA MA MA MA MA MA MA MA MA MA MA MA MB MB MC MC MA MA MA MA MA MA MA MA MA MA MA MA MA MB MB MC MA MA MA MA MA MA MA MA MA MA MA MB MB MC MA MA MA MA MA MA MB MB MC MA MA MA MA MB MB MB MC 1500 QB QB QB QB QC QC QD 1000 QB QB QB QB QB QC QC QD QD 630 QB QB QB QB QB QB QB QB QB QB QC QC QC QD 500 QB QB QB QB QB QB QB QB QB QB QB QB QC QC QC QD QD 2000 QB QB QB QB QB QB QB QB QB QB QB QB QB QB QB QC QC QC QD 500 Product Availability and Chip Thickness Codes See Table 2 for Chip Thickness Dimensions 2000 Capacitance Cap Code C Rated Voltage (VDC) Capacitance Tolerance J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M J K M 630 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 124 154 Voltage Code 630 2,200 pF 2,700 pF 3,300 pF 3,900 pF 4,700 pF 5,600 pF 6,800 pF 8,200 pF 10,000 pF 12,000 pF 15,000 pF 18,000 pF 22,000 pF 27,000 pF 33,000 pF 39,000 pF 47,000 pF 56,000 pF 68,000 pF 82,000 pF 0.1 µF 0.12 µF 0.15 µF C3040C 500 Cap Code C2824C 500 Capacitance Case Size/ Series G C B D F C3640C C4540C *Capacitance range Includes E24 decade values only. (i.e., 10, 11, 12, 13, 15, 16, 18, 20, 22, 24, 27, 30, 33, 36, 39, 43, 47, 51, 56, 62, 68, 75, 82 and 91) KEMET reserves the right to substitute product with an improved temperature characteristic, tighter capacitance tolerance and/or higher voltage capability within the same form factor (configuration and dimensions). These products are protected under US Patents 7,172,985 and 7,670,981, other patents pending, and any foreign counterparts. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 10 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 2A – Chip Thickness/Tape & Reel Packaging Quantities Paper Quantity Plastic Quantity Thickness Code Case Size Thickness ± Range (mm) 7" Reel 13" Reel 7" Reel 13" Reel CG DN DP DG EB EC ED EE EF EG EH FE FF FG FL FM FY FK FS LA LB LC GB GD GH GK GM GO HE HG HJ HK JE JK JL JN KE KF KH KJ TA TB TC QB QC QD MA MB MC SA SB SC 0603 0805 0805 0805 1206 1206 1206 1206 1206 1206 1206 1210 1210 1210 1210 1210 1210 1210 1210 1808 1808 1808 1812 1812 1812 1812 1812 1812 1825 1825 1825 1825 2220 2220 2220 2220 2225 2225 2225 2225 2824 2824 2824 3040 3040 3040 3640 3640 3640 4540 4540 4540 0.80 ± 0.10* 0.78 ± 0.10* 0.90 ± 0.10* 1.25 ± 0.15 0.78 ± 0.10 0.90 ± 0.10 1.00 ± 0.10 1.10 ± 0.10 1.20 ± 0.15 1.60 ± 0.15 1.60 ± 0.20 1.00 ± 0.10 1.10 ± 0.10 1.25 ± 0.15 1.40 ± 0.15 1.70 ± 0.20 2.00 ± 0.20 2.10 ± 0.20 2.50 ± 0.30 1.40 ± 0.15 1.60 ± 0.15 2.00 ± 0.15 1.00 ± 0.10 1.25 ± 0.15 1.40 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 2.00 ± 0.20 2.50 ± 0.20 1.40 ± 0.15 2.00 ± 0.20 2.50 ± 0.20 4000 4000 4000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 15000 15000 15000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2,500 4,000 4,000 2,500 2,500 2,500 2,000 2,000 2,500 2,500 2,500 2,000 2,000 2,000 2,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 500 500 1,000 1,000 500 500 1,000 1,000 500 500 1,000 1,000 500 500 750 300 300 500 500 350 250 250 250 200 200 200 0 0 0 10,000 10,000 10,000 10,000 10,000 10,000 8,000 8,000 10,000 10,000 10,000 8,000 8,000 8,000 8,000 4,000 4,000 4,000 4,000 4,000 4,000 4,000 4,000 2,000 2,000 4,000 4,000 2,000 2,000 4,000 4,000 2,000 2,000 4,000 4,000 2,000 2,000 1,500 1,500 1,500 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 Thickness Code Case Size Thickness ± Range (mm) 7" Reel 13" Reel 7" Reel 13" Reel Paper Quantity Plastic Quantity Package quantity based on finished chip thickness specifications. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 11 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 2B – Bulk Packaging Quantities Loose Packaging Packaging Type Bulk Bag (default) Packaging C-Spec1 N/A 2 Case Size Packaging Quantities (pieces/unit packaging) EIA (in) Metric (mm) 0603 0805 1206 1210 1808 1812 1608 2012 3216 3225 4520 4532 1825 2220 2225 4564 5650 5664 Minimum Maximum 50,000 1 20,000 The "Packaging C-Spec" is a 4 to 8 digit code which identifies the packaging type and/or product grade. When ordering, the proper code must be included in the 15th through 22nd character positions of the ordering code. See "Ordering Information" section of this document for further details. Commercial Grade product ordered without a packaging C-Spec will default to our standard "Bulk Bag" packaging. Contact KEMET if you require a bulk bag packaging option for Automotive Grade products. 2 A packaging C-Spec (see note 1 above) is not required for "Bulk Bag" packaging (excluding Anti-Static Bulk Bag and Automotive Grade products). The 15th through 22nd character positions of the ordering code should be left blank. All product ordered without a packaging C-Spec will default to our standard "Bulk Bag" packaging. 1 © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 12 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 3 – Chip Capacitor Land Pattern Design Recommendations per IPC–7351 EIA Size Code Metric Size Code 0603 Density Level A: Maximum (Most) Land Protrusion (mm) Density Level B: Median (Nominal) Land Protrusion (mm) Density Level C: Minimum (Least) Land Protrusion (mm) C Y X V1 V2 C Y X V1 V2 C Y X V1 V2 1608 0.90 1.15 1.10 4.00 2.10 0.80 0.95 1.00 3.10 1.50 0.60 0.75 0.90 2.40 1.20 0805 2012 1.00 1.35 1.55 4.40 2.60 0.90 1.15 1.45 3.50 2.00 0.75 0.95 1.35 2.80 1.70 1206 3216 1.60 1.35 1.90 5.60 2.90 1.50 1.15 1.80 4.70 2.30 1.40 0.95 1.70 4.00 2.00 1210 3225 1.60 1.35 2.80 5.65 3.80 1.50 1.15 2.70 4.70 3.20 1.40 0.95 2.60 4.00 2.90 1808 4520 2.30 1.75 2.30 7.40 3.30 2.20 1.55 2.20 6.50 2.70 2.10 1.35 2.10 5.80 2.40 1812 4532 2.15 1.60 3.60 6.90 4.60 2.05 1.40 3.50 6.00 4.00 1.95 1.20 3.40 5.30 3.70 1825 4564 2.15 1.60 6.90 6.90 7.90 2.05 1.40 6.80 6.00 7.30 1.95 1.20 6.70 5.30 7.00 2220 5650 2.75 1.70 5.50 8.20 6.50 2.65 1.50 5.40 7.30 5.90 2.55 1.30 5.30 6.60 5.60 2225 5664 2.70 1.70 6.90 8.10 7.90 2.60 1.50 6.80 7.20 7.30 2.50 1.30 6.70 6.50 7.00 2824 7260 3.45 1.70 6.60 9.60 7.60 3.35 1.50 6.50 8.70 7.00 3.25 1.30 6.40 8.00 6.70 3040 7610 3.70 1.70 10.70 10.10 11.70 3.60 1.50 10.60 9.20 11.10 3.50 1.30 10.50 8.50 10.80 3640 9210 4.45 1.70 10.70 11.60 11.70 4.35 1.50 10.60 10.70 11.10 4.25 1.30 10.50 10.00 10.80 4540 - 5.60 1.70 10.70 13.90 11.70 5.50 1.50 10.60 13.00 11.10 5.40 1.30 10.50 12.30 10.80 Density Level A: For low-density product applications. Recommended for wave solder applications and provides a wider process window for reflow solder processes. KEMET only recommends wave soldering of EIA 0603, 0805 and 1206 case sizes. Density Level B: For products with a moderate level of component density. Provides a robust solder attachment condition for reflow solder processes. Density Level C: For high component density product applications. Before adapting the minimum land pattern variations the user should perform qualification testing based on the conditions outlined in IPC Standard 7351 (IPC–7351). Image below based on Density Level B for an EIA 1210 case size. V1 Y Y X X C C V2 Grid Placement Courtyard © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 13 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Soldering Process Recommended Soldering Technique: • Solder wave or solder reflow for EIA case sizes 0603, 0805 and 1206 • All other EIA case sizes are limited to solder reflow only Recommended Reflow Soldering Profile: KEMET’s families of surface mount multilayer ceramic capacitors (SMD MLCCs) are compatible with wave (single or dual), convection, IR or vapor phase reflow techniques. Preheating of these components is recommended to avoid extreme thermal stress. KEMET’s recommended profile conditions for convection and IR reflow reflect the profile conditions of the IPC/ J-STD-020 standard for moisture sensitivity testing. These devices can safely withstand a maximum of three reflow passes at these conditions. Preheat/Soak Temperature Minimum (TSmin) Temperature Maximum (TSmax) Termination Finish SnPb TP 100% Matte Sn 100°C 150°C 150°C 200°C Time (tS) from TSmin to TSmax 60 – 120 seconds 60 – 120 seconds Ramp-Up Rate (TL to TP) 3°C/second maximum 3°C/second maximum Liquidous Temperature (TL) 183°C 217°C Time Above Liquidous (tL) 60 – 150 seconds 60 – 150 seconds Peak Temperature (TP) 235°C 260°C Time Within 5°C of Maximum Peak Temperature (tP) 20 seconds maximum 30 seconds maximum Ramp-Down Rate (TP to TL) 6°C/second maximum 6°C/second maximum Time 25°C to Peak Temperature 6 minutes maximum 8 minutes maximum TL Temperature Profile Feature tP Maximum Ramp-up Rate = 3°C/second Maximum Ramp-down Rate = 6°C/second tL Tsmax Tsmin 25 ts 25°C to Peak Time Note 1: All temperatures refer to the center of the package, measured on the capacitor body surface that is facing up during assembly reflow. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 14 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Table 4 – Performance & Reliability: Test Methods and Conditions Stress Reference Test or Inspection Method Terminal Strength JIS–C–6429 Appendix 1, Note: Force of 1.8 kg for 60 seconds. Board Flex JIS–C–6429 Appendix 2, Note: Standard termination system – 2.0 mm (minimum) for all except 3 mm for C0G. Flexible termination system – 3.0 mm (minimum). Magnification 50 X. Conditions: Solderability J–STD–002 a) Method B, 4 hours at 155°C, dry heat at 235°C b) Method B at 215°C category 3 c) Method D, category 3 at 260°C Temperature Cycling JESD22 Method JA–104 Biased Humidity MIL–STD–202 Method 103 Moisture Resistance Thermal Shock High Temperature Life Storage Life Vibration Mechanical Shock Resistance to Solvents MIL–STD–202 Method 106 MIL–STD–202 Method 107 MIL–STD–202 Method 108 MIL–STD–202 Method 108 MIL–STD–202 Method 204 MIL–STD–202 Method 213 MIL–STD–202 Method 215 1,000 cycles (−55°C to +125°C). Measurement at 24 hours +/−4 hours after test conclusion. Load Humidity: 1,000 hours 85°C/85% RH and 200 VDC maximum. Add 100 K ohm resistor. Measurement at 24 hours +/−4 hours after test conclusion. Low Volt Humidity: 1,000 hours 85°C/85% RH and 1.5 V. Add 100 K ohm resistor. Measurement at 24 hours +/−4 hours after test conclusion. t = 24 hours/cycle. Steps 7a and 7b not required. Measurement at 24 hours +/−4 hours after test conclusion. −55°C/+125°C. Note: Number of cycles required – 300. Maximum transfer time – 20 seconds. Dwell time – 15 minutes. Air – Air. 1,000 hours at 125°C (85°C for X5R, Z5U and Y5V) with 1.2 X rated voltage applied. 150°C, 0 VDC for 1,000 hours. 5 g's for 20 min., 12 cycles each of 3 orientations. Note: Use 8" X 5" PCB 0.031" thick 7 secure points on one long side and 2 secure points at corners of opposite sides. Parts mounted within 2" from any secure point. Test from 10 – 2,000 Hz Figure 1 of Method 213, Condition F. Add aqueous wash chemical, OKEM Clean or equivalent. Storage and Handling Ceramic chip capacitors should be stored in normal working environments. While the chips themselves are quite robust in other environments, solderability will be degraded by exposure to high temperatures, high humidity, corrosive atmospheres, and long term storage. In addition, packaging materials will be degraded by high temperature–reels may soften or warp and tape peel force may increase. KEMET recommends that maximum storage temperature not exceed 40°C and maximum storage humidity not exceed 70% relative humidity. Temperature fluctuations should be minimized to avoid condensation on the parts and atmospheres should be free of chlorine and sulfur bearing compounds. For optimized solderability chip stock should be used promptly, preferably within 1.5 years of receipt. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 15 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Construction Detailed Cross Section Dielectric Material (CaZrO3) Barrier Layer (Ni) Termination Finish (100% Matte Sn / SnPb - 5% Pb min) Dielectric Material (CaZrO3) End Termination/ External Electrode (Cu) Inner Electrodes (Ni) End Termination/ External Electrode (Cu) Barrier Layer (Ni) Termination Finish (100% Matte Sn / SnPb - 5% Pb min) Inner Electrodes (Ni) Capacitor Marking (Optional) Laser marking option is not available on: • C0G, Ultra Stable X8R and Y5V dielectric devices • EIA 0402 case size devices • EIA 0603 case size devices with Flexible Termination option. • KPS Commercial and Automotive grade stacked devices. These capacitors are supplied unmarked only. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 16 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Tape & Reel Packaging Information KEMET offers multilayer ceramic chip capacitors packaged in 8, 12, 16 and 24 mm tape on 7" and 13" reels in accordance with EIA Standard 481. This packaging system is compatible with all tape-fed automatic pick and place systems. See Table 2 for details on reeling quantities for commercial chips. Bar code label Anti-static reel ® Embossed plastic* or punched paper carrier. ET KEM Chip and KPS orientation in pocket (except 1825 commercial, and 1825 and 2225 Military) Sprocket holes Embossment or punched cavity 8 mm, 12 mm or 16 mm carrier tape 180 mm (7.00") or 330 mm (13.00") Anti-static cover tape (0.10 mm (0.004") maximum thickness) *EIA 01005, 0201, 0402 and 0603 case sizes available on punched paper carrier only. Table 5 – Carrier Tape Configuration, Embossed Plastic & Punched Paper (mm) EIA Case Size Tape Size (W)* Embossed Plastic 7" Reel 13" Reel Pitch (P1)* Punched Paper 7" Reel 13" Reel Pitch (P1)* 01005 – 0402 8 2 2 0603 8 2/4 2/4 0805 8 4 4 4 4 1206 – 1210 8 4 4 4 4 1805 – 1808 12 4 4 ≥ 1812 12 8 8 2824 16 12 12 3040 – 4540 24 16 16 KPS 1210 12 8 8 KPS 1812 & 2220 16 12 12 Array 0508 & 0612 8 4 4 *Refer to Figures 1 and 2 for W and P1 carrier tape reference locations. *Refer to Tables 6 and 7 for tolerance specifications. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com New 2 mm Pitch Reel Options* Packaging Ordering Code (C-Spec) Packaging Type/Options C-3190 C-3191 C-7081 C-7082 Automotive grade 7" reel unmarked Automotive grade 13" reel unmarked Commercial grade 7" reel unmarked Commercial grade 13" reel unmarked * 2 mm pitch reel only available for 0603 EIA case size. 2 mm pitch reel for 0805 EIA case size under development. Benefits of Changing from 4 mm to 2 mm Pitching Spacing • Lower placement costs • Double the parts on each reel results in fewer reel changes and increased effi ciency • Fewer reels result in lower packaging, shipping and storage costs, reducing waste C1009_C0G_HV_SMD • 9/15/2020 17 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Figure 1 – Embossed (Plastic) Carrier Tape Dimensions P2 T T2 ØD0 P0 (10 pitches cumulative tolerance on tape ±0.2 mm) A0 E1 F K0 B1 E2 B0 S1 W P1 T1 Center Lines of Cavity ØD1 Cover Tape B1 is for tape feeder reference only, including draft concentric about B0. Embossment For cavity size, see Note 1 Table 4 User Direction of Unreeling Table 6 – Embossed (Plastic) Carrier Tape Dimensions Metric will govern Constant Dimensions — Millimeters (Inches) Tape Size D0 E1 P0 P2 1.5+0.10/−0.0 (0.059+0.004/−0.0) 1.75±0.10 (0.069±0.004) 4.0±0.10 (0.157±0.004) 2.0±0.05 (0.079±0.002) 1.5+0.10/−0.0 (0.059+0.004/−0.0) 1.75±0.10 (0.069±0.004) 4.0±0.10 (0.157±0.004) 2.0±0.10 (0.078±0.003) 8 mm 12 mm 16 mm 24 mm R Reference Note 2 25.0 (0.984) 30 (1.181) 30 (1.181) S1 Minimum Note 3 T Maximum T1 Maximum 0.600 (0.024) 0.600 (0.024) 0.100 (0.004) 5 (0.196) 0.250 (0.009) 0.350 (0.013) Variable Dimensions — Millimeters (Inches) Tape Size Pitch 8 mm Single (4 mm) 12 mm Single (4 mm) & Double (8 mm) 16 mm Triple (12 mm) 24 mm 16 mm E2 Minimum 6.25 (0.246) 10.25 (0.404) 14.25 (0.561) 22.25 (0.875) F P1 3.5±0.05 (0.138±0.002) 5.5±0.05 (0.217±0.002) 7.5±0.05 (0.138±0.002) 11.5±0.10 (0.452±0.003) 4.0±0.10 (0.157±0.004) 8.0±0.10 (0.315±0.004) 12.0±0.10 (0.157±0.004) 16.0±0.10 (0.629±0.004) T2 Maximum 2.5 (0.098) 4.6 (0.181) 4.6 (0.181) 3 (0.118) W Maximum 8.3 (0.327) 12.3 (0.484) 16.3 (0.642) 24.3 (0.956) A0,B0 & K0 Note 5 1. The embossment hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location and hole location shall be applied independent of each other. 2. The tape with or without components shall pass around R without damage (see Figure 6). 3. If S1 < 1.0 mm, there may not be enough area for cover tape to be properly applied (see EIA Standard 481 paragraph 4.3 section b). 4. B1 dimension is a reference dimension for tape feeder clearance only. 5. The cavity defined by A0, B0 and K0 shall surround the component with sufficient clearance that: (a) the component does not protrude above the top surface of the carrier tape. (b) the component can be removed from the cavity in a vertical direction without mechanical restriction, after the top cover tape has been removed. (c) rotation of the component is limited to 20° maximum for 8 and 12 mm tapes and 10° maximum for 16 mm tapes (see Figure 3). (d) lateral movement of the component is restricted to 0.5 mm maximum for 8 and 12 mm wide tape and to 1.0 mm maximum for 16 mm tape (see Figure 4). (e) for KPS Series product, A0 and B0 are measured on a plane 0.3 mm above the bottom of the pocket. (f) see Addendum in EIA Standard 481 for standards relating to more precise taping requirements. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 18 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Figure 2 – Punched (Paper) Carrier Tape Dimensions T Po ØDo (10 pitches cumulative tolerance on tape ±0.2 mm) A0 F P1 T1 T1 Top Cover Tape W E2 B0 Bottom Cover Tape E1 G Cavity Size, See Note 1, Table 7 Center Lines of Cavity Bottom Cover Tape User Direction of Unreeling Table 7 – Punched (Paper) Carrier Tape Dimensions Metric will govern Constant Dimensions — Millimeters (Inches) Tape Size D0 E1 P0 P2 T1 Maximum G Minimum 8 mm 1.5+0.10/−0.0 (0.059+0.004/−0.0) 1.75±0.10 (0.069±0.004) 4.0±0.10 (0.157±0.004) 2.0±0.05 (0.079±0.002) 0.10 (0.004) Maximum R Reference Note 2 0.75 (0.030) 2 (0.984) Variable Dimensions — Millimeters (Inches) Tape Size Pitch 8 mm Half (2 mm) 8 mm Single (4 mm) E2 Minimum F P1 T Maximum W Maximum A0 B 0 6.25 (0.246) 3.5±0.05 (0.138±0.002) 2.0±0.05 (0.079±0.002) 4.0±0.10 (0.157±0.004) 1.1 (0.098) 8.3 (0.327) 8.3 (0.327) Note 1 1. The cavity defined by A0, B0 and T shall surround the component with sufficient clearance that: a) the component does not protrude beyond either surface of the carrier tape. b) the component can be removed from the cavity in a vertical direction without mechanical restriction, after the top cover tape has been removed. c) rotation of the component is limited to 20° maximum (see Figure 3). d) lateral movement of the component is restricted to 0.5 mm maximum (see Figure 4). e) see Addendum in EIA Standard 481 for standards relating to more precise taping requirements. 2. The tape with or without components shall pass around R without damage (see Figure 6). © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 19 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Packaging Information Performance Notes 1. Cover Tape Break Force: 1.0 Kg minimum. 2. Cover Tape Peel Strength: The total peel strength of the cover tape from the carrier tape shall be: Tape Width Peel Strength 8 mm 0.1 to 1.0 newton (10 to 100 gf) 12 and 16 mm 0.1 to 1.3 newton (10 to 130 gf) 24 mm 0.1 to 1.6 newton (10 to 160 gf) The direction of the pull shall be opposite the direction of the carrier tape travel. The pull angle of the carrier tape shall be 165° to 180° from the plane of the carrier tape. During peeling, the carrier and/or cover tape shall be pulled at a velocity of 300 ±10 mm/minute. 3. Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA Standards 556 and 624. Figure 3 – Maximum Component Rotation ° T Maximum Component Rotation Top View Maximum Component Rotation Side View Typical Pocket Centerline Tape Maximum Width (mm) Rotation ( 8,12 20 16 – 200 10 Bo ° T) ° s Tape Width (mm) 8,12 16 – 56 72 – 200 Typical Component Centerline Ao Figure 4 – Maximum Lateral Movement 8 mm & 12 mm Tape 0.5 mm maximum 0.5 mm maximum Maximum Rotation ( 20 10 5 ° S) Figure 5 – Bending Radius Embossed Carrier 16 mm Tape Punched Carrier 1.0 mm maximum 1.0 mm maximum R © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com Bending Radius R C1009_C0G_HV_SMD • 9/15/2020 20 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Figure 6 – Reel Dimensions Full Radius, See Note W3 (Includes flange distortion at outer edge) Access Hole at Slot Location (Ø 40 mm minimum) W2 D A (See Note) N C (Arbor hole diameter) B (see Note) (Measured at hub) W1 (Measured at hub) If present, tape slot in core for tape start: 2.5 mm minimum width x 10.0 mm minimum depth Note: Drive spokes optional; if used, dimensions B and D shall apply. Table 8 – Reel Dimensions Metric will govern Constant Dimensions — Millimeters (Inches) Tape Size 8 mm 12 mm 16 mm 24 mm A B Minimum C D Minimum 178±0.20 (7.008±0.008) or 330±0.20 (13.000±0.008) 1.5 (0.059) 13.0+0.5/−0.2 (0.521+0.02/−0.008) 20.2 (0.795) 1.2 (0.047) 13.0 + −0.2 (0.521 + −0.008) 21 (0.826) Variable Dimensions — Millimeters (Inches) Tape Size N Minimum W1 W2 Maximum W3 50 (1.969) 8.4+1.5/−0.0 (0.331+0.059/−0.0) 12.4+2.0/−0.0 (0.488+0.078/−0.0) 16.4+2.0/−0.0 (0.646+0.078/−0.0) 25+1.0/−0.0 (0.984+0.039/−0.0) 14.4 (0.567) 18.4 (0.724) 22.4 (0.882) 27.4+1.0/−1.0 (1.078+0.039/−0.039) Shall accommodate tape width without interference 8 mm 12 mm 16 mm 24 mm © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 21 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) Figure 7 – Tape Leader & Trailer Dimensions Embossed Carrier Punched Carrier 8 mm & 12 mm only END Carrier Tape Round Sprocket Holes START Top Cover Tape Elongated Sprocket Holes (32 mm tape and wider) Trailer 160 mm minimum Components 100 mm minimum leader 400 mm minimum Top Cover Tape Figure 8 – Maximum Camber Elongated Sprocket Holes (32 mm & wider tapes) Carrier Tape Round Sprocket Holes 1 mm maximum, either direction Straight Edge 250 mm © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 22 Surface Mount Multilayer Ceramic Chip Capacitors (SMD MLCCs) High Voltage C0G Dielectric, 500 – 10,000 VDC (Commercial Grade) KEMET Electronics Corporation Sales Offices For a complete list of our global sales offi ces, please visit www.kemet.com/sales. Disclaimer All product specifi cations, statements, information and data (collectively, the “Information”) in this datasheet are subject to change. The customer is responsible for checking and verifying the extent to which the Information contained in this publication is applicable to an order at the time the order is placed. All Information given herein is believed to be accurate and reliable, but it is presented without guarantee, warranty, or responsibility of any kind, expressed or implied. Statements of suitability for certain applications are based on KEMET Electronics Corporation’s (“KEMET”) knowledge of typical operating conditions for such applications, but are not intended to constitute – and KEMET specifi cally disclaims – any warranty concerning suitability for a specifi c customer application or use. The Information is intended for use only by customers who have the requisite experience and capability to determine the correct products for their application. Any technical advice inferred from this Information or otherwise provided by KEMET with reference to the use of KEMET’s products is given gratis, and KEMET assumes no obligation or liability for the advice given or results obtained. Although KEMET designs and manufactures its products to the most stringent quality and safety standards, given the current state of the art, isolated component failures may still occur. Accordingly, customer applications which require a high degree of reliability or safety should employ suitable designs or other safeguards (such as installation of protective circuitry or redundancies) in order to ensure that the failure of an electrical component does not result in a risk of personal injury or property damage. Although all product–related warnings, cautions and notes must be observed, the customer should not assume that all safety measures are indicted or that other measures may not be required. KEMET is a registered trademark of KEMET Electronics Corporation. © KEMET Electronics Corporation • KEMET Tower • One East Broward Boulevard Fort Lauderdale, FL 33301 USA • 954-766-2800 • www.kemet.com C1009_C0G_HV_SMD • 9/15/2020 23
C1808C470JHGAC7800
物料型号:文档中描述的是KEMET公司生产的高电压C0G介质的SMD MLCCs(Surface Mount Multilayer Ceramic Chip Capacitors),即多层陶瓷片式电容器。
器件简介:这些电容器使用C0G介质,具有温度补偿特性,适用于谐振电路或需要Q值和电容特性稳定性的应用。C0G介质的电容几乎不随时间和电压变化,且在-55°C至+125°C的温度范围内,电容变化限制在±30ppm/°C。
引脚分配:文档中没有明确提到引脚分配,因为这些是表面贴装元件,通常有两个端子或焊盘用于连接。
参数特性:电容器的工作温度范围为-55°C至+125°C,电容值从1pF至0.15μF,直流电压等级有500V、630V、1kV、1.5kV、2kV、2.5kV、3kV和10kV等多种选项。此外,具有极低的ESR(等效串联电阻)和ESL(等效串联电感),高纹波电流承受能力,电容随电压变化极小,几乎不随环境温度变化,无压电噪声,且符合无铅、RoHS和REACH标准。
功能详解:C0G介质的电容器在高频下表现出色,常用于开关电源和照明滤波器中的滤波器或消振器。它们的高频特性使得C0G高电压介质成为全球设计工程师的首选。
应用信息:适用于高频电源转换器、宽带隙(WBG)系统、碳化硅(SiC)和氮化镓(GaN)系统、消振(高dV/dT)、谐振电路(如LLC、无线充电等)、定时和滤波等应用。
封装信息:提供多种尺寸,包括EIA 0603、0805、1206、1210、1808、1812、1825、2220、2225、2824、3040、3640和4540等。
C1808C470JHGAC7800 价格&库存
很抱歉,暂时无法提供与“C1808C470JHGAC7800”相匹配的价格&库存,您可以联系我们找货
