BAT-HLD-006-SMT
BAT-HLD-006-SMT
    LINXTECHNOLOGIES(灵思)
    SMD
BAT-HLD-006-SMT 数据手册
8 7 5 6 4 2 3 1 REVISIONS REV DESCRIPTION DATE JHAGER 3/29/21 A PRODUCTION RELEASE 35.8mm 1.409in 25.5mm 1.004in D 5.15mm .203in 3.30mm .130in 7.20mm .283in 23.2mm .913in 2.50mm .098in C 1.9mm .074in 5.00mm .197in D 6.2mm .24in A 2X 6.00mm .236in 2.50mm .098in 30° 2X 5.000mm .197in 36.8mm 1.45in 6.0mm .24in CL C 2X 2.70mm .106in 2X 2.30mm .091in A CL B NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN MILLIMETERS [IN]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE,USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. ALL UNLISTED GEOMETRY CONTROLLED BY MODEL AT LATEST REVISION. 5. MATERIAL: .250mm C5191 PHOSPHOR BRONZE 3µIN NICKEL PLATING. 6. BEND RADIUS: MINIMUM FOR LISTED MATERIAL AT TEMPER LEVEL SHOWN. ALL BENDS 90°±3º UNLESS OTHERWISE SPECIFIED. 7. INTENDED TO ACCOMODATE CR2450 FORM FACTOR Ø24.5mm COIN POWER CELL. 25.50mm 1.004in 5.86mm .231in 13.78mm .543in 5.70mm .224in 0.250mm±0.050 .010in±.002 7.50mm .295in 2.78mm .109in WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS TITLE: DESIGNATED AGENTS. A INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. MATERIAL: PHOSPHOR BRONZE C5191 WEIGHT: 1.33gm FINISH: NICKEL 7 6 5 23.0mm .91in PCB LAND PATTERN 11.00mm .433in SECTION A-A 8 APPV 4 .X .3 .XX .2 .XXX .1 ANGLES: 3 SURFACE: 32 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. REV B A BAT-HLD-006-SMT DRAWN: JHAGER DT: 3/29/21 DO NOT SCALE DRAWING ENGR: DASARATHAN DT: 10-JUL-08 SCALE: 2:1 3 A Battery Retainer Coin, 24.5 mm 1 Cell SMT (SMD), 2450 PROJECTION: 2 SHEET 1 OF 2 1 B LDCFDFB_B 8 7 6 5 4 3 2 1 D D C C B B A NOTES: 1. The cumulative allowable tolerance of the distance between ten holes of the round hole is ±0.2mm 2. The length of the belt is 250mm and the allowable bending degree is 1mm 3. The thickness of the material is measured at the edge of the carrier tape 4. All size definitions follow the definitions of EIA-481-C series standards 5. Material: black PS T=0.35mm 6. All reels are gray and blue hollowed out rotating plastic reels 7. The non-specified tolerance range is: ±0.1mm; the cumulative error is not calculated if it exceeds 250mm 8. The chamfer R where the shape of the cavity is not marked is 0.2-0.3; if the draft angle is not marked, it is below 3° DEATAIL A A 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. B 7 6 5 4 3 2 A BAT-HLD-006-SMT-TR SCALE: 2:1 8 REV SHEET 2 OF 2 DO NOT SCALE DRAWING 1 LDCFDFB_B
BAT-HLD-006-SMT 价格&库存
很抱歉,暂时无法提供与“BAT-HLD-006-SMT”相匹配的价格&库存,您可以联系我们找货
