ADA4098-1HUJZ-RL7
ADA4098-1HUJZ-RL7
    ANALOGDEVICES
    TSOT-6
    ADA4098-1HUJZ-RL7
ADA4098-1HUJZ-RL7 数据手册
Data Sheet ADA4098-1/ADA4098-2 50 V, 1 MHz, 165 µA per Channel, Robust, Over-The-Top, Precision Op Amps FEATURES ► ► ► ► ► ► ► ► ► ► ► ► ► ► ► GENERAL DESCRIPTION Ultrawide common-mode input range: −VS − 0.1 V to −VS + 70 V Wide power supply voltage range: +3 V to +50 V (to ±25 V for PSRR) Low power supply current: 165 µA per channel (typical) Low input offset voltage: ±35 µV maximum Low input offset voltage drift: ±0.5 µV/°C maximum (B grade) Low input voltage noise ► 1/f noise corner: 6 Hz typical ► 400 nV p-p typical at 0.1 Hz to 10 Hz ► 17 nV/√Hz typical at 100 Hz High speed ► GBP: 1.05 MHz typical for fTEST = 2.5 kHz ► Slew rate: 0.85 V/µs typical at ΔVOUT = 25 V Low power supply current shutdown: 20 µA maximum Low input offset current: ±700 pA maximum Large signal voltage gain: 126 dB minimum for ΔVOUT = 3.5 V CMRR: 120 dB minimum at VCM = −0.1 V to +70 V PSRR: 123 dB minimum at VSY = +3 V to ±25 V Input overdrive tolerant with no phase reversal ±3 kV HBM and ±1.25 kV FICDM Wide temperature range: −55°C to +150°C (H grade) The ADA4098-1 and ADA4098-2 are single/dual robust, precision, rail-to-rail input and output operational amplifiers (op amps) with inputs that operate from −VS to +VS and beyond, which is referred to in this data sheet as Over-The-Top™. The devices feature offset voltages of 5 V f = 100 Hz f = 100 Hz, VCM > 5 V H Grade ±0.05 Typ Max Unit ±35 ±90 ±15 ±35 ±100 µV µV ±40 ±200 ±135 ±40 ±200 ±200 ±0.5 ±0.7 ±10 12 14.8 1 ±20 ±20 ±40 ±200 ±135 ±40 ±200 ±250 ±0.8 ±0.7 ±25 12 15 1 µV µV µV µV µV µV µV/°C nA nA µA µA µA 10 ±700 ±15 ±0.15 ±0.2 µA pA nA µA µA dB +70 400 6 17 20 0.15 1.8 ±0.1 ±0.35 3.5 1.5 8 0.001 ±350 ±0.05 120 134 122 ±20 ±20 10 ±700 ±5 ±0.15 ±0.2 140 150 Min 109 116 110 −0.1 126 120 112 106 140 134 +70 150 122 400 6 17 20 0.15 1.8 dB dB dB V dB dB dB dB nV p-p Hz nV/√Hz nV/√Hz pA/√Hz pA/√Hz Rev. A | 3 of 33 Data Sheet ADA4098-1/ADA4098-2 SPECIFICATIONS Table 1. B Grade Parameter DYNAMIC PERFORMANCE Slew Rate Gain Bandwidth Product (GBP) Phase Margin 1% Settling Time 0.1% Settling Time Total Harmonic Distortion Plus Noise (THD + N) Channel Separation INPUT CHARACTERISTICS Input Resistance Over-The-Top Input Capacitance SHDN AND SHDNx PINS Input Logic Low Input Logic High Response Time Pull-Down Current OUTPUT CHARACTERISTICS Output Voltage Swing Low Output Voltage Swing High Short-Circuit Current Output Pin Leakage During Shutdown Test Conditions/Comments Min Typ ΔVOUT = 2 V TMIN < TA < TMAX Test frequency (fTEST) = 2.5 kHz TMIN < TA < TMAX 0.15 0.1 0.9 0.9 0.4 ΔVOUT = ±2 V ΔVOUT = ±2 V f = 10 kHz, VOUT = 1 V p-p, RL = 10 kΩ, bandwidth = 80 kHz f = 1 kHz, RL = 2 kΩ Differential mode Common mode Differential mode, VCM > 5 V Common mode, VCM > 5 V Differential mode Common mode Amplifier active, SHDN and SHDNx pin voltage (VSHDN) < −VS + 0.5 V, TMIN < TA < TMAX Amplifier shutdown, VSHDN > −VS + 1.5 V, TMIN < TA < TMAX Amplifier active to shutdown Amplifier shutdown to active VSHDN = −VS + 0.5 V, TMIN < TA < TMAX VSHDN = −VS + 1.5 V, TMIN < TA < TMAX Overdrive voltage (VOD)4 = 30 mV, no load TMIN < TA < TMAX VOD = 30 mV, sink current (ISINK) = 10 mA TMIN < TA < TMAX VOD = 30 mV, no load TMIN < TA < TMAX VOD = 30 mV, source current (ISOURCE) = 10 mA TMIN < TA < TMAX ISOURCE TMIN< TA < TMAX ISINK TMIN < TA < TMAX VSHDN = −VS + 1.5 V TMIN < TA < TMAX analog.com H Grade Max Min Typ 0.15 0.1 0.9 0.9 0.4 Unit 55 14 18 0.01 55 14 18 0.01 V/µs V/µs MHz MHz Degrees µs µs % 115 115 dB 1 >1 7 >250 1 3 1 >1 7 >250 1 3 MΩ GΩ kΩ MΩ pF pF 1.05 1.05 −VS + 0.5 −VS + 1.5 −VS + 0.5 −VS + 1.5 2.5 30 0.6 V V 3 2.5 30 0.6 3 µs µs µA 0.3 2.5 0.3 2.5 µA 20 45 20 45 mV 260 50 360 260 55 360 mV mV 450 15 30 1100 mV mV mV mV 1650 ±100 mV mA mA mA mA nA ±10 µA 2.5 900 435 15 25 1100 2.5 900 1500 24 15 35 25 Max 40 24 12 35 20 50 ±0.01 ±100 ±10 40 50 ±0.01 Rev. A | 4 of 33 Data Sheet ADA4098-1/ADA4098-2 SPECIFICATIONS Table 1. B Grade Parameter POWER SUPPLY Maximum Operating Voltage5 VSY Range Supply Current per Channel PSRR THERMAL SHUTDOWN6 Temperature Hysteresis Operating Temperature Test Conditions/Comments Min Guaranteed by Power Supply Rejection Ratio (PSRR) Amplifier active TMIN < TA < TMAX Amplifier shutdown, VSHDN = −VS + 1.5 V TMIN < TA < TMAX VSY = +3 V to ±25 V TMIN < TA < TMAX Typ H Grade Max 50 50 3 165 12 Min Typ 3 175 242 20 165 12 22.5 123 120 145 Junction temperature (TJ) 123 120 175 20 TA −40 Max Unit 50 50 V V 175 250 20 µA µA µA 22.5 µA dB dB 145 175 20 +125 −55 +150 °C °C °C 1 Thermoelectric voltages present in the high speed production test limit the measurement accuracy of this parameter. The limits shown in Table 1 are determined by test capability and are not necessarily indicative of actual device performance. 2 Offset voltage drift is guaranteed through lab characterization and is not production tested. 3 Test accuracy is limited by high speed production test equipment repeatability. Bench measurements indicate that the input offset current in Over-The-Top configuration is typically controlled to under 50 nA at +25°C and 100 nA over the −55°C < TA < +150°C temperature range. 4 VOD is +30 mV for VOUT high and −30 mV for VOUT low. 5 Maximum operating voltage is limited by the time-dependent dielectric breakdown (TDDB) of the on-chip capacitor oxides. The amplifiers tolerate temporary transient overshoot up to the specified absolute maximum rating, but the dc supply voltage must be limited to the maximum operating voltage. 6 Thermal shutdown is lab characterized only and is not tested in production. ±15 V SUPPLY VCM = 0 V, SHDN pin (ADA4098-1) and SHDNx pins (ADA4098-2 10-lead LFCSP) are open, RL = 499 kΩ to ground, and TA = 25°C, unless otherwise noted. Table 2. B Grade Parameter Test Conditions/Comments DC PERFORMANCE VOS1 Input Offset Voltage Drift2 Input Bias Current (IB) TMIN < TA < TMAX VSY = ±25 V TMIN < TA < TMAX TMIN < TA < TMAX TMIN < TA < TMAX VSY = ±25 V TMIN < TA < TMAX IOS Typ Max ±15 ±40 ±90 ±40 ±90 ±0.5 ±0.7 ±10 ±0.7 ±10 ±0.7 ±5 ±0.7 ±5 ±15 ±0.1 ±0.35 ±0.35 ±0.35 TMIN < TA < TMAX VSY = ±25 V TMIN < TA < TMAX analog.com Min H Grade ±0.35 Min Typ Max Unit ±15 ±40 ±100 ±40 ±100 ±0.8 ±0.7 ±25 ±0.7 ±25 ±0.7 ±15 ±0.7 ±15 µV µV µV µV µV/°C nA nA nA nA nA nA nA nA ±15 ±0.1 ±0.35 ±0.35 ±0.35 ±0.35 Rev. A | 5 of 33 Data Sheet ADA4098-1/ADA4098-2 SPECIFICATIONS Table 2. B Grade Parameter Test Conditions/Comments Min Typ CMRR VCM = −14.75 V to +13.25 V TMIN < TA < TMAX VCM = −15.1 V to +13.25 V TMIN < TA < TMAX VCM = −15.1 V to +55 V TMIN < TA < TMAX Guaranteed by CMRR tests ΔVOUT = 25 V TMIN < TA < TMAX ΔVOUT = 25 V, RL = 10 kΩ TMIN < TA < TMAX 118 116 117 102 120 110 −15.1 134 126 117 108 135 Common-Mode Input Range AOL NOISE PERFORMANCE Input Voltage Noise Over-The-Top Input Current Noise Over-The-Top DYNAMIC PERFORMANCE Slew Rate GBP Phase Margin 1% Settling Time 0.1% Settling Time THD + N Channel Separation INPUT CHARACTERISTICS Input Resistance Input Capacitance SHDN AND SHDNx PINS Input Logic Low Input Logic High Response Time Pull-Down Current analog.com f = 0.1 Hz to 10 Hz 1/f noise corner f = 100 Hz f = 100 Hz, VCM > +VS f = 100 Hz f = 100 Hz, VCM > +VS ΔVOUT = 25 V TMIN < TA < TMAX fTEST = 2.5 kHz TMIN < TA < TMAX H Grade Max 135 140 +55 150 120 Min Typ 118 116 117 100 120 108 −15.1 134 123 117 106 135 400 6 17 20 0.15 1.8 0.35 0.2 0.9 0.9 ΔVOUT = ±2 V ΔVOUT = ±2 V f = 10 kHz, VOUT = 1 V p-p, RL = 10 kΩ, bandwidth = 80 kHz f = 1 kHz, RL = 2 kΩ Differential mode Common mode Differential mode Common mode Amplifier active, VSHDN < −VS + 0.5 V Amplifier shutdown, VSHDN > −VS + −VS + 1.5 1.5 V Amplifier active to shutdown Amplifier shutdown to active VSHDN = −VS + 0.5 V, TMIN < TA < TMAX VSHDN = −VS + 1.5 V, TMIN < TA < TMAX 0.85 0.35 0.2 0.9 0.9 Max Unit dB dB dB dB dB dB V dB dB dB dB 135 140 +55 150 120 400 6 17 20 0.15 1.8 nV p-p Hz nV/√Hz nV/√Hz pA/√Hz pA/√Hz 0.85 57 14 18 0.01 57 14 18 0.01 V/µs V/µs MHz MHz Degrees µs µs % 115 115 dB 1 >1 1 3 1 >1 1 3 MΩ GΩ pF pF 1.05 1.05 −VS + 0.5 −VS + 0.5 −VS + 1.5 2.5 30 0.6 0.3 V V 3 2.5 30 0.6 3 µs µs µA 2.5 0.3 2.5 µA Rev. A | 6 of 33 Data Sheet ADA4098-1/ADA4098-2 SPECIFICATIONS Table 2. B Grade Parameter OUTPUT CHARACTERISTICS Output Voltage Swing Low Output Voltage Swing High Short-Circuit Current POWER SUPPLY Maximum Operating Voltage4 VSY Range Supply Current per Channel PSRR THERMAL SHUTDOWN5 Temperature Hysteresis Operating Temperature Test Conditions/Comments VOD3 = 30 mV, no load TMIN < TA < TMAX VOD = 30 mV, ISINK = 10 mA TMIN < TA < TMAX VOD = 30 mV, no load TMIN < TA < TMAX VOD = 30 mV, ISOURCE = 10 mA TMIN < TA < TMAX ISOURCE TMIN < TA < TMAX ISINK TMIN < TA < TMAX Min 20 45 50 360 435 15 25 1100 1500 2.5 900 Guaranteed by PSRR 3 Amplifier active TMIN < TA < TMAX VSY = ±25 V TMIN < TA < TMAX Amplifier shutdown, VSHDN = −VS + 1.5 V TMIN < TA < TMAX VSY = 3 V to 50 V 123 TMIN < TA < TMAX 120 TJ TA Max 260 24 15 35 20 H Grade Typ 34 195 17 50 50 205 272 215 292 24 Typ Max Unit 20 45 55 360 450 15 30 1100 1650 mV mV mV mV mV mV mV mV mA mA mA mA 50 50 205 295 215 315 24 V V µA µA µA µA µA 27 µA dB dB 260 2.5 900 24 12 35 20 50 185 Min 34 50 3 185 195 17 27 145 123 120 175 20 −40 145 175 20 +125 −55 +150 °C °C °C 1 Thermoelectric voltages present in the high speed production test limit the measurement accuracy of this parameter. The limits shown in Table 2 are determined by test capability and are not necessarily indicative of actual device performance. 2 Offset voltage drift is guaranteed through lab characterization and is not production tested. 3 VOD is +30 mV for VOUT high and −30 mV for VOUT low. 4 Maximum operating voltage is limited by the TDDB of the on-chip capacitor oxides. The amplifiers tolerate temporary transient overshoot up to the specified absolute maximum rating and the dc supply voltage must be limited to the maximum operating voltage. 5 Thermal shutdown is lab characterized only and is not tested in production. analog.com Rev. A | 7 of 33 Data Sheet ADA4098-1/ADA4098-2 ABSOLUTE MAXIMUM RATINGS Table 3. Parameter Supply Voltage1 Transient Continuous Power Dissipation (PD) Differential Input Voltage ±IN Pin Voltage Continuous Survival ±IN Pin Current SHDN and SHDNx Pin Voltage 2 Storage Temperature Range Operating Temperature Range Lead Temperature (Soldering, 10 sec) TJ Rating 60 V 50 V See Figure 3 ±80 V −10 V to +80 V −20 V to +80 V 15 mA −0.3 V to +60 V −65°C to +150°C −55°C to +150°C 300°C 175°C 1 Maximum supply voltage is limited by the TDDB of the on-chip capacitor oxides. The amplifiers tolerate temporary transient overshoot up to the specified transient maximum rating. The continuous operating supply voltage must be limited to no more than 50 V. 2 SHDN is Pin 5 on the ADA4098-1. SHDNx refers to SHDN1 and SHDN2 (Pin 5 and Pin 6, respectively) on the ADA4098-2 (10-lead LFCSP). Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Junction temperatures (TJ) exceeding 125°C promotes accelerated aging. The ADA4098-1 and ADA4098-2 demonstrate ±25 V supply operation beyond 1000 hours at TA = 150°C. MAXIMUM POWER DISSIPATION The maximum safe PD on the devices is limited by the associated rise in either case temperature (TC) or TJ on the die. At approximately TC = 150°C, which is the glass transition temperature, the properties of the plastic changes. Exceeding this temperature limit, even temporarily, may change the stresses that the package exerts on the die, which permanently shifts the parametric performance of the ADA4098-1 and ADA4098-2. Exceeding TJ = 175°C for an extended period may result in changes in the silicon devices and may potentially cause failure of the devices. The PD on the package is the sum of the quiescent power dissipation and the power dissipated in the package due to the output load drive. The quiescent power is expressed as VSY × ISY, where ISY is the quiescent current. the associated voltage drop across the devices. RMS voltages and currents must be used in these calculations. Airflow increases heat dissipation, effectively reducing θJA. Additional metal that is directly in contact with the package leads from metal traces through vias, ground, and power planes reduces θJA. Figure 3 shows the maximum PD vs. TA for the single and dual 6-lead TSOT packages on a JEDEC standard, 4‑layer board, with −VS connected to a pad that is thermally connected to a printed circuit board (PCB) plane. θJA values are approximations. Figure 3. Maximum Power Dissipation vs. Ambient Temperature THERMAL RESISTANCE Thermal performance is directly linked to PCB design and operating environment. Careful attention to PCB thermal design is required. θJA is the junction to ambient thermal resistance. Table 4. Thermal Resistance Package Type θJA Unit UJ-6 R-8 RM-8 05-08-1699 192 120 163 43 °C/W °C/W °C/W °C/W ELECTROSTATIC DISCHARGE (ESD) RATINGS The following ESD information is provided for handling of ESD-sensitive devices in an ESD protected area only. Human body model (HBM) per ANSI/ESDA/JEDEC JS-001. Field induced charged device model (FICDM) per ANSI/ESDA/JEDEC JS-002. The PD due to the load drive depends on the application. The PD due to load drive is calculated by multiplying the load current by analog.com Rev. A | 8 of 33 Data Sheet ADA4098-1/ADA4098-2 ABSOLUTE MAXIMUM RATINGS ESD CAUTION ESD Ratings for ADA4098-1/ADA4098-2 Table 5. ADA4098-1 6-Lead TSOT, ADA4098-2 8-Lead SOIC_N, ADA4098-2 8-Lead MSOP, ADA4098-2 10-Lead LFCSP ESD Model Withstand Threshold (kV) Class HBM FICDM ±3 ±1.25 2 3 analog.com ESD (electrostatic discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features patented or proprietary protection circuitry, damage may occur on devices subjected to high energy ESD. Therefore, proper ESD precautions should be taken to avoid performance degradation or loss of functionality. Rev. A | 9 of 33 Data Sheet ADA4098-1/ADA4098-2 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS Figure 4. Pin Configuration for ADA4098-1 6-Lead TSOT Table 6. Pin Function Descriptions for ADA4098-1 6-Lead TSOT Pin No. Mnemonic Description 1 2 VOUT −VS 3 4 5 +IN −IN SHDN 6 +VS Amplifier Output. Negative Power Supply. In single-supply applications, the −VS pin is normally soldered to a low impedance ground plane. In split-supply applications, bypass the −VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the −VS pin as possible. Noninverting Input of the Amplifier. Inverting Input of the Amplifier. Op Amp Shutdown. The threshold for shutdown is approximately 1 V above the negative supply. If the SHDN pin is hard tied to the −VS pin or floating, the amplifier is active. If the SHDN pin is asserted high (VSHDN > −VS + 1.5 V), the amplifier is placed in a shutdown state, and the output of the amplifier goes to a high impedance state. If the SHDN pin is left floating, it is recommended to connect a small capacitor of 1 nF between the SHDN pin and the −VS pin to prevent signals from the −IN pin from capacitively coupling to the SHDN pin. Positive Power Supply. Bypass the +VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the +VS pin as possible. Figure 5. Pin Configuration for ADA4098-2 8-Lead SOIC_N and 8-Lead MSOP Table 7. Pin Function Descriptions for ADA4098-2 8-Lead SOIC_N and 8-Lead MSOP Pin No. Mnemonic Description 1 VOUT1 Amplifier Output, Channel 1. 2 −IN1 Inverting Input of the Amplifier, Channel 1. 3 +IN1 Noninverting Input of the Amplifier, Channel 1. 4 −VS Negative Power Supply. In single-supply applications, the −VS pin is normally soldered to a low impedance ground plane. In split-supply applications, bypass the −VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the −VS pin as possible. 5 −IN2 Inverting Input of the Amplifier, Channel 2. 6 +IN2 Noninverting Input of the Amplifier, Channel 2. 7 VOUT2 Amplifier Output, Channel 2. 8 +VS Positive Power Supply. Bypass the +VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the +VS pin as possible. analog.com Rev. A | 10 of 33 Data Sheet ADA4098-1/ADA4098-2 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS Figure 6. Pin Configuration for ADA4098-2 10-Lead LFCSP Table 8. Pin Function Descriptions for ADA4098-2 10-Lead LFCSP Pin No. Mnemonic Description 1 2 3 4 VOUT1 −IN1 +IN1 −VS 5 SHDN1 6 SHDN2 7 8 9 10 −IN2 +IN2 VOUT2 +VS Amplifier Output, Channel 1. Inverting Input of the Amplifier, Channel 1. Noninverting Input of the Amplifier, Channel 1. Negative Power Supply. In single-supply applications, the −VS pin is normally soldered to a low impedance ground plane. In split-supply applications, bypass the −VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the −VS pin as possible. Op Amp Shutdown, Channel 1. The threshold for shutdown is approximately 1 V above the negative supply. If the SHDN1 pin is hard tied to the −VS pin or floating, the amplifier is active. If the SHDN1 pin is asserted high (VSHDN > −VS + 1.5 V), the amplifier is placed in a shutdown state, and the output of the amplifier goes to a high impedance state. If the SHDN1 pin is left floating, it is recommended to connect a small capacitor of 1 nF between the SHDN1 pin and the −VS pin to prevent signals from the −INx pins from capacitively coupling to the SHDN1 pin. Op Amp Shutdown, Channel 2. The threshold for shutdown is approximately 1 V above the negative supply. If the SHDN2 pin is hard tied to the −VS pin or floating, the amplifier is active. If the SHDN2 pin is asserted high (VSHDN > −VS + 1.5 V), the amplifier is placed in a shutdown state, and the output of the amplifier goes to a high impedance state. If the SHDN2 pin is left floating, it is recommended to connect a small capacitor of 1 nF between the SHDN2 pin and the −VS pin to prevent signals from the −INx pins from capacitively coupling to the SHDN2 pin. Inverting Input of the Amplifier, Channel 2. Noninverting Input of the Amplifier, Channel 2. Amplifier Output, Channel 2. Positive Power Supply. Bypass the +VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the +VS pin as possible. Exposed Pad. Connect the exposed pad to −VS. EPAD analog.com Rev. A | 11 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 7. Supply Current vs. Supply Voltage Figure 10. Shutdown Supply Current vs. Supply Voltage Figure 8. Supply Current vs. Temperature Across Various Supply Voltages Figure 11. Typical Distribution of Input Offset Voltage, VSY = 5 V Figure 9. Supply Current vs. VSHDN with Respect to −VS Figure 12. Typical Distribution of Input Offset Voltage with VSY = ±15 V analog.com Rev. A | 12 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 13. Typical Distribution of Input Offset Voltage with VSY = ±25 V Figure 16. Midsupply Offset Voltage vs. Temperature with VSY = ±25 V Figure 14. Midsupply Offset Voltage vs. Temperature with VSY = 5 V Figure 17. Midsupply Input Bias Current vs. Temperature with VSY = 5 V Figure 15. Midsupply Offset Voltage vs. Temperature with VSY = ±15 V Figure 18. Midsupply Input Bias Current vs. Temperature with VSY = ±15 V analog.com Rev. A | 13 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 19. Offset Voltage vs. Temperature with VCM = 6 V, Over-The-Top Figure 22. Input Bias Current vs. Temperature with VSY = 5 V, Over-The-Top Figure 20. Offset Voltage vs. Temperature with VCM = 70 V Figure 23. Midsupply Input Bias Current vs. Temperature Across Various Supply Voltages Figure 21. Over-The-Top Input Bias Current vs. Temperature with VCM = 6 V analog.com Figure 24. Offset Voltage vs. Temperature Across Various Supply Voltages Rev. A | 14 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 25. Offset Voltage vs. Input Common-Mode Voltage over the Input Common-Mode Range Figure 28. Offset Voltage vs. Input Common-Mode Voltage for Ground Sensing Applications Figure 26. Offset Voltage vs. Input Common-Mode Voltage from Normal Operation to Over-The-Top Operation Figure 29. Input Bias Current vs. Input Common-Mode Voltage for Ground Sensing Applications Figure 27. Input Bias Current vs. Input Common-Mode Voltage from Normal Operation to Over-The-Top Operation Figure 30. Input Bias Current vs. Input Common-Mode Voltage analog.com Rev. A | 15 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 31. Supply Current vs. Minimum Supply Voltage Figure 34. ΔOffset Voltage vs. VOUT Figure 32. Offset Voltage vs. Minimum Supply Voltage Figure 35. ΔOffset Voltage vs. VOUT (5 kΩ Load) Figure 33. Offset Voltage vs. Supply Voltage Figure 36. SHDN Pin Current vs. VSHDN with Respect to −VS over Various Temperatures analog.com Rev. A | 16 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 37. Output Voltage Low (VOL) and Output Voltage High (VOH) vs. Temperature Figure 38. Gain Bandwidth vs. Temperature Figure 40. Noninverting Small Signal Frequency Response (RF Is the Feedback Resistor, RG Is the Gain Setting Resistor, and VIN Is the Input Voltage) Figure 41. Inverting Small Signal Frequency Response Figure 39. Loop Gain and Phase vs. Frequency Figure 42. Voltage Noise Density vs. Frequency for a Unity-Gain Configuration analog.com Rev. A | 17 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 46. THD + N vs. Frequency over Load Figure 43. 0.1 Hz to 10 Hz Noise Figure 47. THD + N vs. Output Amplitude Figure 44. Unity-Gain Small Signal Step Response (CLOAD Is the Load Capacitor) Figure 48. THD + N vs. Output Amplitude and Load Figure 45. Unity-Gain Large Signal Step Response analog.com Rev. A | 18 of 33 Data Sheet ADA4098-1/ADA4098-2 TYPICAL PERFORMANCE CHARACTERISTICS Figure 49. CMRR vs. Frequency Figure 51. Output Impedance vs. Frequency Figure 50. PSRR vs. Frequency analog.com Rev. A | 19 of 33 Data Sheet ADA4098-1/ADA4098-2 THEORY OF OPERATION The ADA4098-1 and ADA4098-2 are robust, voltage feedback amplifiers that combine unity-gain stability with low offset, low offset drift, and 17 nV/√Hz of input voltage noise. Figure 54 shows a simplified schematic of the devices. The ADA4098-1 and ADA4098-2 have two input stages: a common emitter differential input stage consisting of the Q1 and Q2 PNP transistors that operate with the inputs biased between −VS and 1.25 V below +VS, and a common base input stage that consists of the Q3 to Q6 PNP transistors that operate when the common-mode input is biased >+VS − 1.25 V. These input stages result in two distinct operating regions, as shown in Figure 52. For common-mode input voltages that are approximately 1.25 V below the +VS supply, where Q1 and Q2 are active (see Figure 52), the common emitter PNP input stage is active and the input bias current is typically 20 V below −VS, at the cost of stability and added thermal noise. The input stage of the ADA4098-1 and ADA4098-2 incorporates phase reversal protection to prevent the output from phase reversing for inputs below −VS. The ADA4098-1 and ADA4098-2 op amps do not have clamping diodes between the inputs and can be differentially overdriven up to 80 V without damage, inducing parametric shifts, or drawing appreciable input current. Figure 56 summarizes the input fault types that can be applied to the ADA4098-1 and ADA4098-2 without compromising input integrity. OVER-THE-TOP OPERATION CONSIDERATIONS When the ADA4098-1 and ADA4098-2 input common-modes are biased near or >+VS supply, the amplifiers operate in the Over-TheTop configuration. The differential input pair that controls amplifier operation is the common base pair, Q3 to Q6 (see Figure 54). Input bias currents change from
ADA4098-1HUJZ-RL7 价格&库存
很抱歉,暂时无法提供与“ADA4098-1HUJZ-RL7”相匹配的价格&库存,您可以联系我们找货
