TMD27253M
TMD27253M
    AMSOSRAM(艾迈斯半导体)
    SMD-8P
    TMD27253M
TMD27253M 数据手册
Product Document Published by ams OSRAM Group TMD2725 ALS, and Small Aperture Proximity Sensor Module General Description The device features advanced proximity measurement and digital ambient light sensing (ALS). The package has been designed to accommodate a single small aperture approach. The slim module incorporates an IR LED and factory calibrated LED driver. The proximity detection feature provides object detection (e.g. mobile device screen to user’s ear) by photodiode detection of reflected IR energy (sourced by the integrated LED). Detect/release events are interrupt driven, and occur when proximity result crosses upper and/or lower threshold settings. The proximity engine features offset adjustment registers to compensate for unwanted IR energy reflection at the sensor. Proximity results are further improved by automatic ambient light subtraction. The ALS detection feature provides photopic light intensity data. The ALS photodiode has UV and IR blocking filters and a dedicated data converter producing 16-bit data. This architecture allows applications to accurately measure ambient light which enables devices to calculate illuminance to control display backlight. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of TMD2725, ALS, and Small Aperture Proximity Sensor Module are listed below: Figure 1: Added Value of Using TMD2725 Benefits Features • Small aperture requirements • 1.055mm emitter to detector distance • Single device integrated optical solution • • • • • • Accurate ambient light sensing • Photopic Ambient Light Sensor (ALS) • UV / IR blocking filters • Programmable gain and integration time • Reduced power consumption • 1.8V power supply with 1.8V I²C bus ams Datasheet [v1-13] 2018-Feb-23 ALS + proximity 2mm x 3.65mm x 1mm Integrated IR LED Power management features I²C fast mode interface compatible Page 1 Document Feedback TMD2725 − General Description Applications The TMD2725 applications include: • Ambient light sensing • Single hole proximity sensing • Mobile phone touch screen disable Block Diagram The functional blocks of this device are shown below: Figure 2: Functional Blocks of TMD2725 LEDK/LDR Optically Isolated IR LED PGND Proximity LED Current Sink Prox ADC LEDA Prox Data Prox Control SCL Lower Upper Prox Integration Wait Control ALS Thresholds Lower I²C Interface Prox Thresholds SDA Upper ALS Control Photopic IR ALS ADC ALS Data IR ADC IR Data Interrupt Out / Threshold Status INT VDD TMD2725 Page 2 Document Feedback VSS ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Pin Assignments Pin Assignments Figure 3: Pin Diagram of TMD2725 9'' 966 6'$ ,17 6&/ 3*1' /('$ /('./LDR Figure 4: Pin Description of TMD2725 (8-Pin Module) Description Pin Number Pin Name 1 VDD Supply voltage 2 SDA I²C serial data I/O terminal 3 SCL I²C serial clock input terminal 4 LEDA 5 LEDK/LDR 6 PGND 7 INT Interrupt. Open drain output (active low) 8 VSS Ground. All voltages are referenced to GND ams Datasheet [v1-13] 2018-Feb-23 LED anode This test point is the junction of the LED cathode and internal current source. Do not connect. Ground for LED current sink and digital core Page 3 Document Feedback TMD2725 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD Supply Voltage to Ground -0.3 2.2 V LEDA LED Voltage to PGND -0.3 3.6 V VIO Digital I/O terminal voltage -0.3 3.6 V IIO SDA, INT Output terminal current -1 20 mA Electrostatic Discharge Input Current (latch up immunity) JEDEC JESD78D ± 100 mA ESDHBM Electrostatic Discharge HBM JS-001-2014 ± 2000 V ESDCDM Electrostatic Discharge CDM JEDEC JESD22-C101F ± 500 V ISCR Class II Temperature Ranges and Storage Conditions TSTRG Storage Temperature Range TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level Page 4 Document Feedback -40 85 5 3 °C 260 °C 85 % IPC/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” Maximum floor life time 168 hours ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 6: Recommended Operating Conditions Parameter Min Typ Max Unit VDD supply range 1.7 1.8 2.0 V VLEDA, Supply voltage range (1) 3.0 3.3 3.6 V TA, Operating free-air temperature(2) -30 85 °C Note(s): 1. The minimum required supply voltage on the LED anode (VLEDA) is the sum of the LED's VF and the voltage drop from the LDR pin to PGND pin. The minimum required VLEDA can be lowered to 2.8V if the LED's forward current doesn't exceed 102mA (PLDRIVE value of 16 or less). 2. While the device is operational across the temperature range, performance will vary with temperature. Operational characteristics are at 25°C, unless otherwise noted. Figure 7: Operating Characteristics, VDD = 1.8V, TA = 25°C (unless otherwise noted) Symbol fOSC IDD Parameter Conditions Min Oscillator frequency Supply Current (1) VOL INT, SDA output low voltage ILEAK Leakage current, SDA,SCL,INT Typ Max 8.107 MHz Active ALS State (PON=AEN=1, PEN=0) (2) 80 150 Idle State (PON=1,AEN=PEN=0) (3) 30 60 Sleep State (4) 0.7 5 6mA sink current Unit μA 0.6 V -5 5 μA VIH SCL, SDA input high voltage 1.26 3.3 V VIL SCL, SDA input low voltage 0 0.54 V TActive Time from power-on to ready to receive I²C commands 1.5 ms Note(s): 1. Values are shown at the VDD pin and do not include current through the IR LED. 2. This parameter indicates the supply current during periods of ALS integration. If Wait is enabled (WEN=1), the supply current is lower during the Wait period. 3. Idle state occurs when PON=1 and all functions are not enabled. 4. Sleep state occurs when PON = 0 and I²C bus is idle. If Sleep state has been entered as the result of operational flow, SAI = 1, PON will remain high. ams Datasheet [v1-13] 2018-Feb-23 Page 5 Document Feedback TMD2725 − Typical Operating Characteristics Typical Operating Characteristics Figure 8: Optical Characteristics, VDD = 1.8V, TA = 25°C (unless otherwise noted) Clear Channel Parameter Conditions Unit Min Re Irradiance responsivity Settings: AGAIN = 16x ATIME = 400ms Typ λD = 465 nm LED, 53.8 μW/cm2 58 λD = 530 nm LED, 43.9 μW/cm2 490 λD = 620 nm LED, 37.5 μW/cm2 405 Warm White LED, 45.6 μW/cm2 363 Warm White LED, 45.6 μW/cm2 14025 λD = 950 nm LED, 21.1 μW/cm2 16500 Max Count/ (μW/cm2) 18975 Counts Count/ (μW/cm2) 8 Figure 9: ALS Optical Characteristics, VDD = 1.8V, TA = 25°C (unless otherwise noted) Parameter Conditions Integration time step size Dark ADC count value Gain Scaling, relative to 1x gain setting ADC noise Page 6 Document Feedback Ee = 0 μW/ cm2 AGAIN: 64x ATIME = 100ms (0x23) Min Typ Max Unit 2.72 2.82 2.94 ms 0 1 3 Counts AGAIN = 1x 1 AGAIN = 4x 4 AGAIN = 16x 16 AGAIN = 64x 66 AGAIN = 128x 140 AGAIN = 16x 0.005 x % full scale ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Typical Operating Characteristics Figure 10: Proximity Optical Characteristics, VDD = 1.8V, TA = 25°C (unless otherwise noted) Parameter Conditions Min Typ Max Unit Part to part variation (1) Conditions: PGAIN = 2 (4x) PLDRIVE = 8 (54mA) PPULSE = 15 (16 pulses) PPULSE_LEN = 1 (8μs) d=23mm round target 30mm target distance 75 100 125 % Response, absolute Basic proximity measurement (2) Conditions: PGAIN = 2 (4x), PLDRIVE = 16 (102mA) PPULSE = 15 (16 pulses) PPULSE_LEN = 2 (16μs) Target material: 90% reflective surface of Kodak gray card Target Size: 100mm x 100mm Target Distance: 100mm 128 160 192 Response, no target PGAIN = 2 (4x) ILEDDRIVE = 16 (102mA) PPULSE = 16 (17 Pulses) Pulse Length = 2 (16μS) Noise/Signal (3) PGAIN = 2 (4x) IRLEDDRIVE = 8 (54mA) PPULSE = 15 (16 pulses) PPULSE_LEN = 1 (8μs) d=23mm round target 30mm target distance Counts 0 20 1.2 % Note(s): 1. Production tested result is the average of 5 readings expressed relative to a calibrated response. 2. Representative result by characterization. 3. Production tested result is the average of 20 readings divided by the maximum proximity value 255. ams Datasheet [v1-13] 2018-Feb-23 Page 7 Document Feedback TMD2725 − Typical Operating Characteristics Figure 11: Spectral Responsivity 120% Photopic Normalized Responsivity 100% IR 80% 60% 40% 20% 0% 300 400 500 600 700 800 900 1000 1100 Wavelength (nm) Figure 12: ALS Responsivity vs Angular Displacement 100% Normalized Response (%) 90% Green LED Photopic Ch 80% 70% 60% 50% 40% 30% 20% 10% 0% -90 -75 -60 -45 -30 -15 0 15 30 45 60 75 90 Angle of Incident Light (°) Page 8 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Typical Operating Characteristics Figure 13: ALS Linearity TMD2725 Linearity Response, 2700 K LED, 50ms 100000 Gain Corrected ALS Count Best Linear Fit 10000 ADC Counts 1000 100 10 1 0.01 0.1 1 10 0.1 100 1000 10000 Illuminance(Lux) Figure 14: Proximity Operation of TMD2725 Proximity Operating Range using six 90mA pulses, while varying Gain and Pulse Length Proximity Count (0 - 255 Range) 250 200 150 100 50 0 0 5 10 15 20 25 30 40 50 60 70 80 90 100 110 120 130 140 150 Distance to Target in mm 4μs, 1X Gain 8μs, 2X Gain 16μs, 4X Gain 32μs, 8X Gain Proximity Operation: By varying Gain, LED drive current, number of LED pulses and LED pulse duration the proximity detection range can be adjusted. ams Datasheet [v1-13] 2018-Feb-23 Page 9 Document Feedback TMD2725 − Detailed Description Detailed Description Proximity Proximity results are affected by three fundamental factors: the integrated IR LED emission, IR reception, and environmental factors, including target distance and surface reflectivity. The IR reception signal path begins with IR detection from a photodiode and ends with the 8-bit proximity result in PDATA register. Signal from the photodiode is amplified, and offset adjusted to optimize performance. Offset correction or cross-talk compensation is accomplished by adjustment to the POFFSET register. The analog circuitry of the device applies the offset value as a subtraction to the signal accumulation; therefore a positive offset value has the effect of decreasing the results. Ambient Light Sensing, ALS The ALS reception signal path begins as photodiodes receive filtered light and ends with the 16-bit results in the PHOTOPICL/H and ALS_IRL/H registers. The Photopic photodiode is filtered with a UV and IR filter. The ALS_IR photodiode is filtered to receive only IR. Signal from the photodiodes simultaneously accumulate for a period of time set by the value in ATIME before the results are available. Gain is adjustable from 1x to 64x to facilitate operation over a wide range of lighting conditions. Custom LUX equations are used to calculate the amount of ambient light, as well as, determine the light type (e.g. LED, fluorescent, incandescent, etc.) using the two ALS results. I²C Characteristics The device uses I²C serial communication protocol for communication. The device supports 7-bit chip addressing and both standard and fast clock frequency modes with a chip address of 0x39. Read and Write transactions comply with the standard set by Philips (now NXP). Internal to the device, an 8-bit buffer stores the register address location of the desired byte to read or write. This buffer auto-increments upon each byte transfer and is retained between transaction events (I.e. valid even after the master issues a STOP command and the I²C bus is released). During consecutive Read transactions, the future/repeated I²C Read transaction may omit the memory address byte normally following the chip address byte; the buffer retains the last register address + 1. Page 10 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Detailed Description I²C Write Transaction A Write transaction consists of a START, CHIP-ADDRESS WRITE, REGISTER-ADDRESS, DATA BYTE(S), and STOP. Following each byte (9TH clock pulse) the slave places an ACKNOWLEDGE/ NOT-ACKNOWLEDGE (ACK/NACK) on the bus. If NACK is transmitted by the slave, the master may issue a STOP. I²C Read Transaction A Read transaction consists of a START, CHIP-ADDRESS WRITE, REGISTER-ADDRESS, START, CHIP-ADDRESS READ, DATA BYTE(S), and STOP. Following all but the final byte the master places an ACK on the bus (9TH clock pulse). Termination of the Read transaction is indicated by a NACK being placed on the bus by the master, followed by STOP. Alternately, if the previous I²C transaction was a Read, the internal register address buffer is still valid, allowing the transaction to proceed without “re”-specifying the register address. In this case the transaction consists of a START, CHIP-ADDRESS READ, DATA BYTE(S), and STOP. Following all but the final byte the master places an ACK on the bus (9 TH clock pulse). Termination of the Read transaction is indicated by a NACK being placed on the bus by the master, followed by STOP. The I²C bus protocol was developed by Philips (now NXP). For a complete description of the I²C protocol, please review the NXP I²C design specification at: http://www.i2c-bus.org/references/ Timing Diagrams Figure 15: I²C Timing ams Datasheet [v1-13] 2018-Feb-23 Page 11 Document Feedback TMD2725 − Principles of Operation Principles of Operation System State Machine An internal state machine provides system control of the ALS, proximity detection, and power management features of the device. At power up, an internal power-on-reset initializes the device and puts it in a lowpower Sleep state. When a write on I²C bus to the Enable register (0x80) PON bit is set, the device transitions to the Idle state. If PON is disabled, the device will return to the Sleep state to save power. Otherwise, the device will remain in the Idle state until a Proximity or ALS function is enabled. Once enabled, the device will execute the ALS, Proximity and Wait states in sequence as indicated in Figure 16 and Figure 17. Upon completion, the device will automatically begin a new ALS-Prox-Wait cycle as long as PON and either PEN or AEN remain enabled. If the Prox or ALS function generates an interrupt and the Sleep-After-Interrupt (SAI) feature is enabled, the device will transition to the Sleep state and remain in a low-power mode until an I²C command is received clearing the interrupts in the STATUS register. See Interrupts for additional information. Page 12 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Principles of Operation Figure 16: Detailed State Diagram Oscillator Off (SLEEP) az-done = 0 (reset) no pon An I2C Write to az-nth-iteration register, except of the value 00h(disable-az), resets az-done independent of actual cntrl-state. In consequence, a new autozero calibration will be started in advance to the next ALS integration cycle. yes Oscillator On (IDLE) no no aen | pen start-offset-calib Run Proximity Offset Calibration yes yes no aen pen no yes yes yes az-done Run Proximity Integration no Run Autozero Calibration aen | pen no yes az-done = 1 no wen yes no aen aen==1 && az-done==0 no yes yes Run ALS Integration ~aen wtime-done = 0 Run Autozero Calibration Run WTIME timer aen==0 aborts ALS ~wen | (~aen & ~pen) az-done = 1 wtime-done = 1 az-done = 0, if az-nth iterations passed since last AZ calibration. (refer to note 1 for exceptions) autozero calibration is executed in parallel to running WTIME timer az-done & wtime-done wen==0 | (aen==0 & pen==0) aborts WTIME timer yes ams Datasheet [v1-13] 2018-Feb-23 Page 13 Document Feedback TMD2725 − Principles of Operation Figure 17: Simplified State Diagram CNTRL Typical Flow rev 1v0, 24.08.2016 Az_nth_iteration is assumed 0x7f – Run Autozero once before 1st ALS integration This makes the flow chart simpler, and this is the more usual case Oscillator Off (SLEEP) no pon=1 yes Run Proximity Offset Calibration Oscillator On (IDLE) aen=0 & pen=0 no yes yes start-offset-calib no no aen=1 yes aen=1 & pen=x no yes no 1st ALS iteration yes Run Autozero Calibration no aen=0 aborts ALS Run ALS Integration yes pen=1 aen=0 & pen=1 no yes Run Proximity Integration wen=1 yes wen=0 | (aen=0 & pen=0) aborts WTIME timer Page 14 Document Feedback Run WTIME timer ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description Register Description Register Overview Figure 18: Register Overview Address Register Name R/W 0x80 ENABLE R/W Enables states and functions 0x00 0x81 ATIME R/W ALS integration time 0x00 0x82 PRATE R/W Proximity sampling time 0x1F 0x83 WTIME R/W Wait time 0x00 0x84 AILTL R/W ALS interrupt low threshold low byte 0x00 0x85 AILTH R/W ALS interrupt low threshold high byte 0x00 0x86 AIHTL R/W ALS interrupt high threshold low byte 0x00 0x87 AIHTH R/W ALS interrupt high threshold high byte 0x00 0x88 PILT R/W Proximity interrupt low threshold 0x00 0x8A PIHT R/W Proximity interrupt high threshold 0x00 0x8C PERS R/W Interrupt persistence filters 0x00 0x8D CFG0 R/W Configuration register zero 0x80 0x8E PCFG0 R/W Proximity configuration register zero 0x4F 0x8F PCFG1 R/W Proximity configuration register one 0x80 0x90 CFG1 R/W Configuration register one 0x00 0x91 REVID R Revision ID 0x20 0x92 ID R Device ID 0xE4 0x93 STATUS R Device status register 0x00 0x94 PHOTOPICL R Photopic channel data low byte 0x00 0x95 PHOTOPICH R Photopic channel data high byte 0x00 0x96 ALS_IRL R IR channel data low byte 0x00 0x97 ALS_IRH R IR channel data high byte 0x00 0x9C PDATA R Proximity channel data 0x00 0x9E REVID2 R Auxiliary ID 0x00 0x9F CFG2 R/W Configuration register two 0x04 0xAB CFG3 R/W Configuration register three 0x4C ams Datasheet [v1-13] 2018-Feb-23 Register Function Reset Value Page 15 Document Feedback TMD2725 − Register Description Address Register Name R/W Register Function Reset Value 0xC0 POFFSETL R/W Proximity offset magnitude 0x00 0xC1 POFFSETH R/W Proximity offset sign 0x00 0xD6 AZ_CONFIG R/W Autozero configuration 0x7F 0xD7 CALIB R/W Calibration start 0x00 0xD9 CALIBCFG R/W Calibration configuration 0x50 0xDC CALIBSTAT R/W Calibration status 0x00 0xDD INTENAB R/W Interrupt enables 0x00 Note(s): 1. Address 0x98 and 0x99 will contain the results for the IR photodiode when controlled by the Green/IR MUX. Register Access: R = Read Only W = Write Only R/W = Read or Write SC = Self Clearing after access Page 16 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description Detailed Register Description Enable Register (Address 0x80) Figure 19: Enable Register Addr: 0x80 Enable Bit Bit Name Default Access Bit Description 7:4 RESERVED 0000 RW Reserved. 3 WEN 0 RW This bit activates the wait feature. Active high. 2 PEN 0 RW This bit activates the proximity detection. Active high. 1 AEN 0 RW This bit actives the ALS function. Active high. *Set AEN=1 and PON=1 in the same command to ensure auto-zero function is run prior to the first measurement. 0 PON 0 RW This field activates the internal oscillator and ADC channels. Active high. Before activating AEN or PEN, preset each applicable operating mode registers and bits. ams Datasheet [v1-13] 2018-Feb-23 Page 17 Document Feedback TMD2725 − Register Description ATIME Register (Address 0x81) Figure 20: ATIME Register Addr: 0x81 Bit Bit Name ATIME Default Access Bit Description ALS value that specifies the integration time in 2.78ms intervals. 0x00 indicates 2.8ms. The maximum ALS value depends on the integration time. For every 2.78ms, the maximum value increases by 1024. This means that to be able to reach ALS full scale, the integration time has to be at least 64*2.8ms. 7:0 ATIME 0x00 RW Value Integration Cycles Integration Time Maximum ALS Value 0x00 1 2.8ms 1023 0x01 2 5.6ms 2047 … … … … 0x3F 64 180ms 65535 … … … … 0xFF 256 719ms 65535 The ATIME register controls the integration time of the ALS ADCs. The timer is implemented with a down counter with 0x00 as the terminal count. The timer is clocked at a 2.8ms nominal rate. Loading 0x00 will generate a 2.8ms integration time, loading 0x01 will generate a 5.6ms integration time, and so forth. The RC oscillator runs at 8MHz nominal rate. This gets divided by 11 to generate the integration clock of 727kHz. One count in ATIME (nominal 2.8ms) are 2.78ms. This is 2048 integration clock cycles: 125ns*11*8*256=2.8ms. PTIME Register (Address 0x82) Figure 21: PTIME Register Addr: 0x82 PTIME Bit Bit Name Default Access 7:0 PTIME 0x1F RW Page 18 Document Feedback Bit Description This register defines the duration of 1 Prox Sample, which is (PTIME + 1)*88μs. ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description WTIME Register (Address 0x83) Figure 22: WTIME Register Addr: 0x83 Bit Bit Name WTIME Default Access Bit Description Value that specifies the wait time between ALS cycles in 2.78ms increments. 7:0 WTIME 0x00 RW Value Increments Wait Time 0x00 1 2.8ms (33.8ms) 0x01 2 5.6ms (67.6ms) … … … 0x3F 64 180ms (2.16s) … … … 0xFF 256 719ms (8.65s) The wait timer is implemented using a down counter. Wait time = (value +1) x 2.8ms. If WLONG is enabled then Wait time = (value +1) x 2.8ms. x 12. AILTL Register (Address 0x84) Figure 23: AILTL Register Addr: 0x84 AILTL Bit Bit Name Default Access Bit Description 7:0 AILTL 0x00 RW This register sets the low byte of the LOW ALS threshold. The photopic channel is compared against low-going 16-bit threshold value set by AILTL and AILTH. ams Datasheet [v1-13] 2018-Feb-23 Page 19 Document Feedback TMD2725 − Register Description AILTH Register (Address 0x85) Figure 24: AILTH Register Addr: 0x85 AILTH Bit Bit Name Default Access 7:0 AILTH 0x00 RW Bit Description This register sets the high byte of the LOW ALS threshold. The photopic channel is compared against low-going 16-bit threshold value set by AILTL and AILTH. The contents of the AILTH and AILTL registers are combined and treated as a sixteen bit threshold value. If the value generated by the photopic channel is below the AILTL/H threshold and the APERS value is reached, the AINT bit is asserted. If AIEN is set, then the INT pin will also assert. When setting the 16-bit ALS threshold AILTL must be written first, immediately follow by AILTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 16-bit value. AIHTL Register (Address 0x86) Figure 25: AIHTL Register Addr: 0x86 AIHTL Bit Bit Name Default Access 7:0 AIHTL 0x00 RW Bit Description This register sets the low byte of the HIGH ALS threshold. The photopic channel is compared against high-going 16-bit threshold value set by AIHTL and AIHTH. The contents of the AIHTH and AIHTL registers are combined and treated as a sixteen bit threshold value. If the value generated by the photopic channel is above the AIHTL/H threshold and the APERS value is reached, the AINT bit is asserted. If AIEN is set, then the INT pin will also assert. When setting the 16-bit ALS threshold AIHTL must be written first, immediately follow by AIHTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 16-bit value. Page 20 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description AIHTH Register (Address 0x87) Figure 26: AIHTH Register Addr: 0x87 AIHTH Bit Bit Name Default Access 7:0 AIHTH 0x00 RW Bit Description This register sets the high byte of the HIGH ALS threshold. The photopic channel is compared against high-going 16-bit threshold value set by AIHTL and AIHTH. The contents of the AIHTH and AIHTL registers are combined and treated as a sixteen bit threshold value. If the value generated by the photopic channel is above the AIHTL/H threshold and the APERS value is reached, the AINT bit is asserted. If AIEN is set, then the INT pin will also assert. When setting the 16-bit ALS threshold AIHTL must be written first, immediately follow by AIHTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 16-bit value. PILT Register (Address 0x88) Figure 27: PILT Register Addr: 0x88 PILT Bit Bit Name Default Access 7:0 PILT 0x00 RW Bit Description This register sets the Proximity ADC channel low threshold. The proximity channel is compared against low-going 8-bit threshold value set by PILT. If the value generated by the Proximity channel is below the PILT threshold and the PPERS value is reached, the PINT bit is asserted. If PIEN is set, then the INT pin will also assert. ams Datasheet [v1-13] 2018-Feb-23 Page 21 Document Feedback TMD2725 − Register Description PIHT Register (Address 0x8A) Figure 28: PIHT Register Addr: 0x8A PIHT Bit Bit Name Default Access 7:0 PIHT 0x00 RW Bit Description This register sets the Proximity ADC channel high threshold. The proximity channel is compared against high-going 8-bit threshold value set by PIHT. If the value generated by the Proximity channel is above the PIHT threshold and the PPERS value is reached, the PINT bit is asserted. If PIEN is set, then the INT pin will also assert. PERS Register (Address 0x8C) Figure 29: PERS Register Addr: 0x8C Bit Bit Name PERS Default Access Bit Description This register sets the Proximity persistence filter. Value 7:4 PPERS Page 22 Document Feedback 0000 Interrupt 0 Every Proximity Cycle 1 Any value outside PILT/PIHT thresholds 2 2 consecutive proximity values out of range 3 3 consecutive proximity values out of range … …. 15 15 consecutive proximity values out of range RW ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description Addr: 0x8C Bit Bit Name PERS Default Access Bit Description This register sets the ALS persistence filter. 3:0 APERS 0000 RW 0 Every ALS Cycle 1 Any value outside ALS thresholds 2 2 consecutive ALS values out of range 3 3 consecutive ALS values out of range 4 5 consecutive ALS values out of range 5 10 consecutive ALS values out of range 6 15 consecutive ALS values out of range 7 20 consecutive ALS values out of range … … 13 50 consecutive ALS values out of range 14 55 consecutive ALS values out of range 15 60 consecutive ALS values out of range The frequency of consecutive proximity channel results outside of threshold limits are counted; this count value is compared against the PPERS value. If the counter is equal to the PPERS value an interrupt is asserted. Any time a proximity channel result is inside the threshold values the counter is cleared. The frequency of consecutive photopic channel results outside of threshold limits are counted; this count value is compared against the APERS value. If the counter is equal to the APERS setting an interrupt is asserted. Any time a photopic channel result is inside the threshold values the counter is cleared. ams Datasheet [v1-13] 2018-Feb-23 Page 23 Document Feedback TMD2725 − Register Description CFG0 Register (Address 0x8D) Figure 30: CFG0 Register Addr: 0x8D CFG0 Bit Bit Name Default Access Bit Description 7:3 Reserved 10000 RW This field must be set to the default value. 2 WLONG 0 RW When Wait Long is asserted the wait period as set by WTIME is increased by a factor of 12. 1:0 Reserved 00 RW This field must be set to the default value. The wait timer is implemented using a down counter. Wait time = (value +1) x 2.8ms. If WLONG is enabled then Wait time = (value +1) x 2.8ms x 12. Page 24 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description PCFG0 Register (Address 0x8E) Figure 31: PCFG0 Register Addr: 0x8E Bit Bit Name PCFG0 Default Access Bit Description Proximity Pulse Length 7:6 PPULSE_LEN 01 Value Pulse Length 0 4μs 1 8μs 2 16μs 3 32μs RW Maximum Number of Pulses in a single proximity cycle. 5:0 PPULSE 001111 RW Value Maximum Number of Pulses 0 1 1 2 2 3 … … 63 64 The PPULSE_LEN field sets the width of all IR LED pulses within the proximity cycle. Longer pulses result in increased proximity range and typically result in less electrical noise generated in the analog front end. However, a setting of 8μs is recommended because less cumulative noise is generated during a proximity cycle. The PPULSE field sets the maximum number of IR LED pulses that may occur in a proximity cycle. The proximity engine will automatically continue to add IR LED pulses, up to the value set in PPULSE or if a near-saturation condition occurs. The dynamic range of the sensor is automatically adjusted to detect distant targets as well as prevent saturation from close targets. This operation also reduces power consumption because proximity integration period is automatically shortened when a target is either to close or far from the sensor. ams Datasheet [v1-13] 2018-Feb-23 Page 25 Document Feedback TMD2725 − Register Description PCFG1 Register (Address 0x8F) Figure 32: PCFG1 Register Addr: 0x8F Bit Bit Name PCFG1 Default Access Bit Description This field sets the gain of the proximity IR sensor. 7:6 5 PGAIN Reserved 10 0 Gain Value Bit Field 1x 0 00b 2x 1 01b 4x 2 10b 8x 3 11b RW RW Reserved This field sets the drive strength of the IR LED current. Values are approximate; actual current through LED is factory trimmed to normalize IR intensity. 4:0 PLDRIVE 00000 Value LED Current 0 6mA 1 12mA RW iLED = 6(PLDRIVE +1) mA Page 26 Document Feedback 30 186mA 31 192mA ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description CFG1 Register (Address 0x90) Figure 33: CFG1 Register Addr: 0x90 CFG1 Bit Bit Name Default Access 7:2 Reserved 000000 RW Bit Description Reserved This field sets the gain of the ALS sensor. 1:0 AGAIN 00 Value Gain 0 1x 1 4x 2 16x 3 64x RW REVID Register (Address 0x91) Figure 34: REVID Register Addr: 0x91 REVID Bit Bit Name Default Access Bit Description 7:3 Reserved 00100 RO Reserved 2:0 REV_ID 000 RO Device revision number ID Register (Address 0x92) Figure 35: ID Register Addr: 0x92 ID Bit Bit Name Default Access Bit Description 7:2 ID 111001 RO Device type identification. 1:0 Reserved 00 RO Reserved ams Datasheet [v1-13] 2018-Feb-23 Page 27 Document Feedback TMD2725 − Register Description Status Register (Address 0x93) Figure 36: Status Register Addr: 0x93 Status Register Bit Bit Name Default Access Bit Description 7 ASAT 0 R, SC The Analog Saturation flag signals that the ALS results may be unreliable due to saturation of the AFE. 6 PSAT 0 R, SC The Proximity Saturation flag indicates that an ambientor reflective-saturation event occurred during a previous proximity cycle. 5 PINT 0 R, SC The Proximity Interrupt flag indicates that proximity results have exceeded thresholds and persistence settings. 4 AINT 0 R, SC The ALS Interrupt flag indicates that ALS results (photopic channel) have exceeded thresholds and persistence settings. 3 CINT 0 R, SC The Calibration Interrupt flag indicates that calibration has completed. 2 Reserved 0 R, SC Reserved 1 PSAT_REFLECTIVE 0 R, SC The Reflective Proximity Saturation Interrupt flag signals that the AFE has saturated during the IR LED active portion of proximity integration. 0 PSAT_AMBIENT 0 R, SC The Ambient Proximity Saturation Interrupt flag signals that the AFE has saturated during the IR LED inactive portion of proximity integration. All flags in this register can be cleared by setting the bit high. Alternatively, if the CFG3.int_read_clear bit is set, then simply reading this register automatically clears all eight flags. PHOTOPICL Register (Address 0x94) Figure 37: PHOTOPICL Register Addr: 0x94 PHOTOPICL Bit Bit Name Default Access 7:0 PHOTOPICL 0x00 RO Page 28 Document Feedback Bit Description This register contains the low byte of the 16-bit photopic channel data. ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description PHOTOPICH Register (Address 0x95) Figure 38: PHOTOPICH Register Addr: 0x95 PHOTOPICH Bit Bit Name Default Access Bit Description 7:0 PHOTOPICH 0x00 RO This register contains the high byte of the 16-bit photopic channel data. ALS_IRL Register (Address 0x96) Figure 39: ALS_IRL Register Addr: 0x96 ALS_IRL Bit Bit Name Default Access Bit Description 7:0 ALS_IRL 0x00 RO This register contains the low byte of the 16-bit IR channel data. ALS_IRH Register (Address 0x97) Figure 40: ALS_IRH Register Addr: 0x97 ALS_IRH Bit Bit Name Default Access Bit Description 7:0 ALS_IRH 0x00 RO This register contains the high byte of the 16-bit IR channel data. PDATA Register (Address 0x9C) Figure 41: PDATA Register Addr: 0x9C PDATA Bit Bit Name Default Access Bit Description 7:0 PDATA 0x00 RO This register contains the 8-bit proximity channel data. ams Datasheet [v1-13] 2018-Feb-23 Page 29 Document Feedback TMD2725 − Register Description REVID2 Register (Address 0x9E) Figure 42: REVID2 Register Addr: 0x9E REVID2 Bit Bit Name Default Access Description 7:4 Reserved 0000 RO Reserved 3:0 REVID2 0000 RO Package Identification CFG2 Register (Address 0x9F) Figure 43: CFG2 Register Addr: 0x9F CFG2 Bit Bit Name Default Access Bit Description 7:5 Reserved 000 RW Reserved 4 AGAINMAX 0 RW This bit adjusts the overall ALS gain factor. See Figure 44 for recommended settings and corresponding overall ALS gain factor. 3 Reserved 0 RW Reserved 2 AGAINL 1 RW This bit adjusts the overall ALS gain factor. See Figure 44 for recommended settings and corresponding overall ALS gain factor. 1:0 Reserved 00 RW Reserved The ALS gain can be adjusted using by setting the two AGAIN bits as well as the AGAINL bit which yields an overall range from ½ x to 128x. Page 30 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description Figure 44: AGAIN Range AGAIN[1] AGAIN[0] AGAINMAX AGAINL Overall ALS Gain 0 0 0 0 ½ 0 0 0 1 1 0 1 0 1 4 1 0 0 1 16 1 1 0 1 64 1 1 1 1 128 CFG3 Register (Address 0xAB) Figure 45: CFG3 Register Addr: 0xAB CFG3 Bit Bit Name Default Access Bit Description 7 INT_READ_CLEAR 0 RW If the Interrupt-Clear-by-Read bit is set, then all flag bits in the STATUS register will be reset whenever the STATUS register is read over I²C. 6:5 Reserved 10 RW Reserved The Sleep After Interrupt bit is used to place the device into a low power mode upon an interrupt pin assertion. 4 3:0 SAI Reserved ams Datasheet [v1-13] 2018-Feb-23 0 1100 RW RW PON SAI INT Oscillator 0 X X OFF 1 0 X ON 1 1 1 ON 1 1 0 OFF Reserved Page 31 Document Feedback TMD2725 − Register Description The SAI bit sets the device operational mode following the completion of an ALS or proximity cycle. If AINT and AIEN are both set or if PINT and PIEN are both set, causing an interrupt on the INT pin, and the SAI bit is set, then the oscillator will deactivate. The Device will appear as if PON = 0, however, PON will read as 1. The device can only be reactivated (oscillator enabled) by clearing the interrupts in the STATUS register. POFFSETL Register (Address 0xC0) Figure 46: POFFSETL Register Addr: 0xC0 POFFSETL Bit Bit Name Default Access Bit Description 7:0 POFFSETL 0x00 RW This register contains the magnitude portion of proximity offset adjust value. Typically, optical and/or electrical crosstalk negatively influence proximity operation and results. The POFFSETL/POFFSETH registers provide a mechanism to remove system crosstalk from the proximity data. POFFSETL and POFFSETH contains the magnitude and sign of a value which adjusts PDATA generated in the AFE. An offset value in the range of ± 255 is possible. POFFSETH Register (Address 0xC1) Figure 47: POFFSETH Register Addr: 0xC1 POFFSETH Bit Bit Name Default Access 7:1 Reserved 0000000 RW Reserved 0 POFFSET_SIGN 0 RW This register contains the sign portion of proximity offset adjust value. Page 32 Document Feedback Bit Description ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description AZ_CONFIG Register (Address 0xD6) Figure 48: AZ_CONFIG Register Addr: 0xD6 AZ_CONFIG Bit Bit Name Default Access Description 7 Reserved 0 RW Reserved. 6:0 AZ_NTH_ ITERATION 1111111 RW Run autozero automatically before every nth ALS cycle (00h = never, n = every nth ALS cycle, and 7Fh = only before the first ALS cycle). CALIB Register (Address 0xD7) Figure 49: CALIB Register Addr: 0xD7 CALIB Bit Bit Name Default Access Bit Description 7:6 Reserved 00 RO Reserved 5 ELECTRICAL_ CALIBRATION 0 RW Selects proximity calibration type. 1 = electrical offset only. 0 = calibration compensates for electrical and optical crosstalk. 4:1 Reserved 0000 RW Reserved 0 START_OFFSET_ CALIB 0 RW Set to 1 to start a calibration sequence. Proximity response in systems with electrical and optical crosstalk may be improved by using the calibration feature. Optical crosstalk is caused when the photodiode receives a small portion of the LED IR which was unintentionally reflected by a surface other than the target. Electrical offset is caused by electrical disturbance in the sensor AFE, and also influences the proximity result. The calibration routine adjusts the value in registers C0 and C1 until the proximity result is as close to BINSRCH_TARGET as possible without becoming zero. Optical and electrical calibration function identically, except that during an electrical calibration the proximity photodiode is disconnected from the AFE. An electrical only calibration can be initiated by setting the ELECTRICAL_CALIBRATION and START_OFFSET_CALB bits. To perform an optical (and electrical) calibration do not set the ELECTRICAL_CALIBRATION bit when setting the START_ OFFSET_CALIB. The CINT flag will assert after calibration has ams Datasheet [v1-13] 2018-Feb-23 Page 33 Document Feedback TMD2725 − Register Description finished. Upon completion Proximity offset registers are automatically loaded with calibration result. CALIBCFG Register (Address 0xD9) Figure 50: CALIBCFG Register Addr: 0xD9 Bit Bit Name CALIBCFG Default Access Bit Description Proximity Result Target 7:5 BINSRCH_ TARGET 010 Value PDATA Target 0 0 1 1 2 3 3 7 4 15 5 31 6 63 7 127 RW 4 Reserved 1 RW Reserved 3 AUTO_ OFFSET_ADJ 0 RW The Proximity Auto Offset Adjust bit causes the value in POFFSETL register to decrement when PDATA equals zero at the completion of the proximity cycle. The Proximity Averaging field defines the number of ADC samples collected and averaged during a cycle which become the proximity result. 2:0 PROX_AVG Page 34 Document Feedback 000 RW Value Sample Size 0 Disable 1 2 2 4 3 8 4 16 5 32 6 64 7 128 ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Register Description The binary search target field is used by the calibration feature to set the baseline value for PDATA when no target is present. For example, calibration of a device in open air, with no target, and BINSEARCH_TARGET setting of 4 causes the PDATA value will be approximately 15 counts. This feature is useful because it forces PDATA result to always be above zero. The PROX_AVG field sets the number of ADC samples that are averaged to calculate the PDATA result. CALIBSTAT Register (Address 0xDC) Figure 51: CALIBSTAT Register Addr: 0xDC CALIBSTAT Bit Bit Name Default Access Bit Description 7:1 Reserved 0000000 RW Reserved 0 CALIB_FINISHED 0 RW This flag indicates that calibration has finished. It can only be cleared by setting this bit high. INTENAB Register (Address 0xDD) Figure 52: INTENAB Register Addr: 0xDD INTENAB Bit Bit Name Default Access 7 ASIEN 0 RW ALS Saturation Interrupt Enable 6 PSIEN 0 RW Proximity Saturation Interrupt Enable 5 PIEN 0 RW Proximity Interrupt Enable 4 AIEN 0 RW ALS Interrupt Enable 3 CIEN 0 RW Calibration Interrupt Enable 2:0 Reserved 000 RW Reserved ams Datasheet [v1-13] 2018-Feb-23 Bit Description Page 35 Document Feedback TMD2725 − Application Information Application Information Schematic Figure 53: Typical Applications Circuit VBUS RINT = 10KΩ RPU TMD2725 R = 22Ω SCL SCL VDD SDA SDA VSS INT INT LEDA LEDK/LDR PGND 4.7μF 1.8V Bulk System Capacitance 3.0V 10μF Typical Applications Circuit: It is important to place the 4.7μF (VDD) and 10μF (LEDA) capacitors at the package pins. Page 36 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Application Information PCB Layout Figure 54: Typical Applications Circuit The dominant factor governing device performance is the component placement, not necessarily component value. The placement of the decoupling capacitor, C1, is the most critical. Place the component on the same side of PCB as device as shown in the figure above. Make connection as close as possible to minimize series inductance and resistance. This is critical. ams Datasheet [v1-13] 2018-Feb-23 Page 37 Document Feedback TMD2725 − Package Drawings & Markings Package Drawings & Markings Figure 55: Package Drawings  /('$3(5785( 5 &/ &/  3,1,1',&$725 3$57 &/ 72$/6 &/  3$57 &/ 72352; &/  /(' &/ 72352; &/  $ % “ “ “ & ;“  0 & $ % &/ ;  ;“  0 & $ % &/ ;  ;  ;  RoHS Green Note(s): 1. All linear dimensions are in millimeters. 2. Contact finish is Au. 3. This package contains no lead (Pb). 4. This drawing is subject to change without notice. Page 38 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Package Drawings & Markings Figure 56: Recommended PCB Layout ; &/ ;  &/ ; ; ; ;  Note(s): 1. All dimensions are in millimeters. 2. Dimension tolerances are 0.05mm unless otherwise noted. 3. This drawing is subject to change without notice. ams Datasheet [v1-13] 2018-Feb-23 Page 39 Document Feedback TMD2725 − Tape & Reel Information Tape & Reel Information Figure 57: Tape and Reel Information J “ “ “ %  $ $ . “ $ “ “ “ ƒPD[ $$ ƒPD[ % “ % “     “ [ “      XQZLQGLQJGLUHFWLRQHPSW\  %% Note(s): 1. All linear dimensions are in millimeters. 2. For missing tolerances and dimensions, refer to EIA-481. 3. In accordance with EIA standard, device pin 1 is located next to the sprocket holes in the tape. Page 40 Document Feedback ams Datasheet [v1-13] 2018-Feb-23 TMD2725 − Soldering & Storage Information Soldering & Storage Information The module has been tested and has demonstrated an ability to be reflow soldered to a PCB substrate. The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 58: Solder Reflow Profile Profile Feature Preheat/ Soak Sn-Pb Eutectic Assembly Pb-Free Assembly Temperature Min (Tsmin) 100 °C 150 °C Temperature Max (Tsmax) 150 °C 200 °C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up rate (TL to TP) 3 °C/second max. 3 °C/second max. Liquidous temperature (TL) Time (tL) maintained above TL 183 °C 60-150 seconds 217 °C 60-150 seconds Peak package body temperature (TP) For users TP must not exceed the Classification temp of 235 °C For suppliers TP must equal or exceed the Classification temp of 235 °C For users TP must not exceed the Classification temp of 260 °C For suppliers TP must equal or exceed the Classification temp of 260 °C Time (tP) (1) within 5 °C of the specified classification temperature (Tc) 20 (1)seconds 30 (1)seconds Ramp-down rate (TP to TL) 6 °C/second max. 6 °C/second max. Time 25 °C to peak temperature 6 minutes max. 8 minutes max. Note(s): 1. Tolerance for peak profile temperature (TP) is defined as a supplier minimum and a user maximum. ams Datasheet [v1-13] 2018-Feb-23 Page 41 Document Feedback TMD2725 − Soldering & Storage Information Figure 59: Solder Reflow Profile Graph Not to Scale – For Reference Only TP Max Ramp Up Rate = 3°C/s Max Ramp Down Rate = 6°C/s TL TC - 5°C tP Temperature (°C) tL Tsmax Preheat Area Tsmin 25 Time (seconds) Storage Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. Shelf Life The calculated shelf life of the device in an unopened moisture barrier bag is 12 months from the date code on the bag when stored under the following conditions: • Shelf Life: 12 months • Ambient Temperature:
TMD27253M 价格&库存
很抱歉,暂时无法提供与“TMD27253M”相匹配的价格&库存,您可以联系我们找货
