MC3419
MC3419
    MEMSIC(美新)
    VLGA12_2X2MM
    MC3419是一款小尺寸、集成式数字输出三轴加速度计,其功能特性专为手机和消费产品的运动感应进行了优化。应用场景包括用户界面控制、游戏运动输入、手机电子罗盘倾斜补偿、游戏控制器、遥控器和便携式媒体产品...
MC3419 数据手册
MC3419 3-Axis Accelerometer GENERAL DESCRIPTION FEATURES Range, Sampling & Power The MC3419 is a small form factor, integrated digital output 3-axis accelerometer with a feature set optimized for cell phones and consumer product motion sensing. Applications include user interface control, gaming motion input, electronic compass tilt compensation for cell phones, game controllers, remote controls and portable media products.       Simple System Integration The MC3419 features a dedicated motion block which implements algorithms to support “any motion” and shake detection, tilt/flip and tilt 35 position detection.     Low power consumption and small size are inherent in the monolithic fabrication approach, where the MEMS accelerometer is integrated in a single-chip with the electronics integrated circuit.  In the MC3419 the internal sample rate can be set from 0.5 to 1000 samples / second. The device supports the reading of sample and event status via polling or interrupts. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, or for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. ±2, ±4, ±8, ±12, ±16g range 16-bit single sample resolution 16-bit resolution with FIFO 0.5 to 1000 Hz Output Data Rate 4 μA typical Standby current Low typical active current SPI up to 10 MHz I2C interface, up to 1 MHz 2×2×0.92 mm 12-pin LGA package High reliability thru single-chip 3D silicon MEMS technology RoHS compliant Applications       Smartphone Wearable IoT & IoMT Remote controls, gaming Vibration in Cell phone VR & game controllers  MEMSIC Semiconductor (Tianjin) Co., Ltd. Room 4-501, Financial Center, No. 158, West Third Road, Tianjin Airport Economic Zone, Tianjin, China, 300308 Tel: +86 022-59896226 www.memsic.com MEMSIC MC3419 APS-048-0071 v1.1 Page 1 of 78 Formal release date: 2020/07/13 TABLE OF CONTENTS 1 Order Information............................................................................................................. 5 2 Functional Block Diagram ................................................................................................ 6 3 Packaging and Pin Description ........................................................................................ 7 3.1 Package Outline ................................................................................................................... 7 3.2 Package Orientation ............................................................................................................. 8 3.3 Pin Description ..................................................................................................................... 9 3.4 Typical Application Circuits ................................................................................................ 10 3.5 Tape and Reel ................................................................................................................... 13 3.6 Soldering Profile ................................................................................................................. 15 3.7 Shipping and Handling Guidelines ..................................................................................... 15 3.8 Moisture Sensitivity Level Control ...................................................................................... 15 4 Specifications................................................................................................................. 16 4.1 Absolute Maximum Ratings ................................................................................................ 16 4.2 Sensor Characteristics ....................................................................................................... 17 4.3 Electrical and Timing Characteristics.................................................................................. 18 4.3.1 Electrical Power and Internal Characteristics ..................................................................... 18 4.3.2 Electrical Characteristics .................................................................................................... 19 4.3.3 I2C Timing Characteristics ................................................................................................. 20 4.3.4 SPI Timing Characteristics ................................................................................................. 21 5 General Operation ......................................................................................................... 22 5.1 Sensor Sampling ................................................................................................................ 22 5.2 Offset and Gain Calibration ................................................................................................ 22 6 Operational States ......................................................................................................... 23 7 Operational State Flow .................................................................................................. 24 8 Interrupts........................................................................................................................ 25 8.1 Interrupt Overview .............................................................................................................. 25 8.2 Enabling and Clearing Interrupts ........................................................................................ 26 8.3 Interrupt Sources................................................................................................................ 26 8.3.1 ACQ_INT Interrupt ............................................................................................................. 26 8.3.2 TILT/FLIP (TILT_INT, FLIP_INT) ........................................................................................ 26 8.3.3 Interrupt on AnyMotion (ANYM_INT) .................................................................................. 26 8.3.4 Interrupt on SHAKE (SHAKE_INT) ..................................................................................... 26 MEMSIC MC3419 APS-048-0071 v1.1 Page 2 of 78 Formal release date: 2020/07/13 8.3.5 Interrupt on TILT_35 (TILT_35_INT) .................................................................................. 27 8.3.6 Interrupt on FIFO Empty (FIFO_EMPTY_INT) ................................................................... 27 8.3.7 Interrupt on FIFO Full (FIFO_FULL_INT) ........................................................................... 27 8.3.8 Interrupt on FIFO Threshold (FIFO_THRESH_INT) ........................................................... 27 8.4 Interrupt Servicing .............................................................................................................. 28 8.4.1 Global Interrupt Service method ......................................................................................... 28 8.4.2 Bitmask/Individual Interrupt Service method....................................................................... 28 8.5 Interrupt Requests and External INT Pins .......................................................................... 30 8.5.1 Selecting Drive and Polarity ............................................................................................... 30 8.5.2 Swapping INT Pins............................................................................................................. 31 8.5.3 Combining Interrupt Requests ............................................................................................ 31 9 Sampling ........................................................................................................................ 32 9.1 Continuous Sampling ......................................................................................................... 32 9.2 Setting the Sample Rate .................................................................................................... 32 9.3 Additional Rate Options...................................................................................................... 33 10 I2C Interface .................................................................................................................. 34 10.1 Physical Interface ............................................................................................................... 34 10.2 Timing ................................................................................................................................ 35 10.3 I2C Message Format .......................................................................................................... 35 10.4 I2C Watchdog Timer .......................................................................................................... 36 11 SPI Interface .................................................................................................................. 37 11.1 SPI Physical Interface ........................................................................................................ 37 11.2 SPI Protocol ....................................................................................................................... 37 11.3 SPI Register Write Cycle - Single ....................................................................................... 37 11.4 SPI Register Write Cycle - Burst ........................................................................................ 37 11.5 SPI Register Read Cycle - Single ....................................................................................... 38 11.6 SPI Register Read Cycle - Burst ........................................................................................ 38 12 Register Interface .......................................................................................................... 39 12.1 Register Summary ............................................................................................................. 39 12.2 (0x05)Device Status Register ............................................................................................. 42 12.3 (0x06) Interrupt Enable Register ........................................................................................ 43 12.4 (0x07) Mode Register ......................................................................................................... 44 12.5 (0x08) Sample Rate Register ............................................................................................. 45 12.6 (0x09) Motion Control Register........................................................................................... 46 12.7 (0x0A) FIFO Status Register .............................................................................................. 47 MEMSIC MC3419 APS-048-0071 v1.1 Page 3 of 78 Formal release date: 2020/07/13 12.8 (0x0B) FIFO Read Pointer Register.................................................................................... 48 12.9 (0x0C) FIFO Write Pointer Register.................................................................................... 49 12.10 (0x0D - 0x12) XOUT, YOUT and ZOUT Data Accelerometer Registers ............................. 50 12.11 (0x13) Status Register........................................................................................................ 51 12.12 (0x14) Interrupt Status Register ......................................................................................... 52 12.13 (0x20) Range and Scale Control Register .......................................................................... 53 12.14 (0x21 – 0x22) X-Axis Digital Offset Registers ..................................................................... 54 12.15 (0x23 – 0x24) Y-Axis Digital Offset Registers ..................................................................... 55 12.16 (0x25 – 0x26) Z-Axis Digital Offset Registers ..................................................................... 56 12.17 (0x22 & 0x27) X-Axis Digital Gain Registers ...................................................................... 57 12.18 (0x24 & 0x28) Y-Axis Digital Gain Registers ...................................................................... 58 12.19 (0x26 & 0x29) Z-Axis Digital Gain Registers....................................................................... 59 12.20 (0x2D) FIFO Control Register............................................................................................. 60 12.21 (0x2E) FIFO Threshold Register ........................................................................................ 62 12.22 (0x2F) FIFO Interrupt Status Register ................................................................................ 63 12.23 (0x30) FIFO Control Register2, Sample Rate Register 2 .................................................... 64 12.24 (0x31) Communication Control Register ............................................................................. 66 12.25 (0x33) GPIO Control Register ............................................................................................ 67 12.26 (0x40 – 0x41) Tilt/Flip Threshold Registers ........................................................................ 68 12.27 (0x42) Tilt/Flip Debounce Register ..................................................................................... 69 12.28 (0x43 – 0x44) AnyMotion Threshold Registers ................................................................... 70 12.29 (0x45) AnyMotion Debounce Register ................................................................................ 71 12.30 (0x46 – 0x47) Shake Threshold Registers.......................................................................... 72 12.31 (0x48 – 0x49) Shake Duration, Peak-to-Peak Registers..................................................... 73 12.32 (0x4A) Timer Control Register ............................................................................................ 74 12.33 (0x4B) Read Count Register .............................................................................................. 75 13 Index of Tables .............................................................................................................. 76 14 Revision History ............................................................................................................. 78 MEMSIC MC3419 APS-048-0071 v1.1 Page 4 of 78 Formal release date: 2020/07/13 1 ORDER INFORMATION Table 1. Order Information Part Number Resolution Order Number Package Shipping MC3419 16-bit MC3419 VLGA-12 Tape & Reel, 5Ku Table 2. Package Information MEMSIC MC3419 APS-048-0071 v1.1 Page 5 of 78 Formal release date: 2020/07/13 2 FUNCTIONAL BLOCK DIAGRAM Sensors VDD Oscillator / Clock Generator Regulators and Bias INTN2 Mode Logic Motion Event Detect X Interrupts INTN1 FIFO 32 x 48 SCL_SCK Y C to V Sigma Delta Accum./ Filter XYZ data paths LPF Offset/ Gain Adjust Range and Scale Registers (80x8) I2C/SPI Interface DIN_SDA (MOSI) DOUT_A6 (MISO) CSN GND Z OTP Memory VPP Figure 1. Block Diagram MEMSIC MC3419 APS-048-0071 v1.1 Page 6 of 78 Formal release date: 2020/07/13 3 PACKAGING AND PIN DESCRIPTION 3.1 PACKAGE OUTLINE Figure 2. Package Outline and Mechanical Dimensions MEMSIC MC3419 APS-048-0071 v1.1 Page 7 of 78 Formal release date: 2020/07/13 3.2 PACKAGE ORIENTATION Top View a. Direction of Earth gravity acceleration Top Pin 1 Side View e. b. XOUT = +1g YOUT = 0g ZOUT = 0g c. XOUT = 0g YOUT = 0g ZOUT = +1g f. XOUT = 0g YOUT = -1g ZOUT = 0g d. XOUT = 0g YOUT = +1g ZOUT = 0g XOUT = 0g YOUT = 0g ZOUT = -1g XOUT = -1g YOUT = 0g ZOUT = 0g Figure 3. Package Orientation +Z +X +Y -Y -X -Z Figure 4. Package Axis Reference MEMSIC MC3419 APS-048-0071 v1.1 Page 8 of 78 Formal release date: 2020/07/13 3.3 PIN DESCRIPTION Pin Name Function 1 DOUT_A6 2 DIN_SDA 1 3 NC No connect 4 VPP Connect to GND 5 INTN 1 2 Interrupt active LOW 3 6 INTN 2 2 Interrupt active LOW 3 7 VDD Power supply for internal 8 NC No Connect 9 GND Ground 10 CSN SPI chip select (active low) 11 NC No connect 12 SCK_SCL 1 I2C/SPI serial clock input SPI data output I2C address bit 6 SPI data In I2C serial data input/output Table 3. Pin Description Notes: 1) This pin requires a pull-up resistor, typically 4.7kΩ to pin VDD. Refer to I2C Specification for Fast-Mode devices. Higher resistance values can be used (typically done to reduce current leakage) but such applications are outside the scope of this datasheet. 2) This pin can be configured by software to operate either as an open-drain output or push-pull output (see GPIO control register, address 0x33). If set to open-drain, then it requires a pull-up resistor, typically 4.7kΩ to VDD. 3) INTN pin polarity is programmable in the GPIO control register, address 0x33. MEMSIC MC3419 APS-048-0071 v1.1 Page 9 of 78 Formal release date: 2020/07/13 3.4 TYPICAL APPLICATION CIRCUITS } To Fast-Mode I2C circuitry1 12 11 SCK_SCL NC Rp 1 Rp 2 3 4 DOUT_A6 CSN DIN_SDA GND NC NC VPP VDD 10 9 8 7 0.1µF Rp Rp INTN1 5 (optional) To MCU interrupt input2 From power supply INTN2 Place cap close to VDD and GND on PCB 6 NOTE1: Rp are typically 4.7kΩ pullup resistors to VDDIO, per I2C specification. When VDDIO is powered down, DIN_SDA and SCK_SCL will be driven low by internal ESD diodes. NOTE2: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 5. Typical I2C Application Circuit In typical applications, the interface power supply may contain significant noise from external sources and other circuits which should be kept away from the sensor. Therefore, for some applications a lower-noise power supply might be desirable to power the VDD pin. MEMSIC MC3419 APS-048-0071 v1.1 Page 10 of 78 Formal release date: 2020/07/13 To 4-wire SPI master 12 11 SCK_SCL NC 1 2 3 4 DOUT_A6 CSN DIN_SDA GND NC NC VPP VDD 10 9 8 7 0.1µF Rp Rp From power supply INTN1 INTN2 (optional) To MCU interrupt input 5 Place cap close to VDD and GND on PCB 6 NOTE Rp: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 6. Typical 4-wire SPI Application Circuit MEMSIC MC3419 APS-048-0071 v1.1 Page 11 of 78 Formal release date: 2020/07/13 To 3-wire SPI master 12 11 SCK_SCL NC 1 2 3 4 DOUT_A6 CSN DIN_SDA GND NC NC VPP VDD 10 9 8 7 0.1µF Rp Rp INTN1 (optional) To MCU interrupt input 5 From power supply INTN2 Place cap close to VDD and GND on PCB 6 NOTE Rp: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 7. Typical 3-wire SPI Application Circuit MEMSIC MC3419 APS-048-0071 v1.1 Page 12 of 78 Formal release date: 2020/07/13 3.5 TAPE AND REEL Devices are shipped in reels, in standard cardboard box packaging. See Figure 8. MC3419 Tape Dimensions and Figure 9. MC3419 Reel Dimensions.  Dimensions in mm.  10 sprocket hole pitch cumulative tolerance ±0.2  Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole. Figure 8. MC3419 Tape Dimensions MEMSIC MC3419 APS-048-0071 v1.1 Page 13 of 78 Formal release date: 2020/07/13  Dimensions in mm. Figure 9. MC3419 Reel Dimensions MEMSIC MC3419 APS-048-0071 v1.1 Page 14 of 78 Formal release date: 2020/07/13 3.6 SOLDERING PROFILE The LGA package follows the reflow soldering classification profiles described in Joint Industry Standard, Moisture/Reflow Sensitivity Classification for Nonhermetic Surface Mount Devices, document number J-STD-020E. Reflow soldering has a peak temperature (Tp) of 260⁰C 3.7 SHIPPING AND HANDLING GUIDELINES Shipping and handling follow the standards described in Joint Industry Standard, Handling, Packing, Shipping and Use of Moisture/Reflow Sensitive Surface Mount Devices, document number J-STD-033C. The following are additional handling guidelines (refer to the MEMSIC document, PCB Design, Device Handling and Assembly Guidelines, for more information):     While the mechanical sensor is designed to handle high-g shock events, direct mechanical shock to the package should be avoided. SMT assembly houses should use automated assembly equipment with either plastic nozzles or nozzles with compliant tips (for example, soft rubber or silicone). Avoid g-forces beyond the specified limits during transportation. Handling and mounting of sensors should be done in a defined and qualified installation. 3.8 MOISTURE SENSITIVITY LEVEL CONTROL The following are storage recommendations (refer to the MEMSIC document, PCB Design, Device Handling and Assembly Guidelines, for more information):    Store the tape and reel in the unopened dry pack, until required on the assembly floor. If the dry pack has been opened or the reel has been removed from the dry pack, reseal the reel inside of the dry pack with a black protective belt. Avoid crushing the tape and reel. Store the cardboard box in a vertical position. MEMSIC MC3419 APS-048-0071 v1.1 Page 15 of 78 Formal release date: 2020/07/13 4 SPECIFICATIONS 4.1 ABSOLUTE MAXIMUM RATINGS Parameters exceeding the Absolute Maximum Ratings may permanently damage the device. Rating Symbol Minimum / Maximum Value Unit Supply Voltages Pin VDD -0.3 / +3.6 V Ambient operating temperature TOP -40 / +85 ⁰C Storage temperature TSTG -40 / +125 ⁰C ESD human body model HBM ± 2000 V Latch-up current at Top = 25 ⁰C ILU 100 mA Input voltage to non-power pin Pins CSN, DIN_SDA, DOUT_A6, INTN 1, INTN 2, and SCK_SCL -0.3 / (VDD + 0.3) or 3.6 whichever is lower V Table 4. Absolute Maximum Ratings MEMSIC MC3419 APS-048-0071 v1.1 Page 16 of 78 Formal release date: 2020/07/13 4.2 SENSOR CHARACTERISTICS VDD = 2.8V, Top = 25 ⁰C unless otherwise noted Parameter Conditions Min Acceleration range = ±4.0g 8192 Acceleration range = ±8.0g 4096 Acceleration range = ±12.0g 2730 Acceleration range = ±16.0g 2048 -40 ≤ Top ≤ +85 ⁰C ±0.025 %/⁰C Chip Level Board Level ±20 ±50 mg -40 ≤ Top ≤ +85 ⁰C ±1 mg/⁰C ODR = 125 Hz, LPF = ODR/16 0.7 (X,Y) 1.3 (Z) mg RMS Acceleration range = ±2.0g 0.6 % FS Between any two axes ±2 % Zero-g Offset Temperature Coefficient 1 Cross-axis Sensitivity 1 ODR, Output Data Rate 1 g 16384 Zero-g Offset Nonlinearity 1 Unit Acceleration range = ±2.0g Sensitivity Temperature Coefficient 1 RMS Noise Max ±2.0 ±4.0 ±8.0 ±12.0 ±16.0 Acceleration range Sensitivity Typ 0.5 LSB/g 1000 Hz Values are based on device characterization, not tested in production. Table 5. Sensor Characteristics MEMSIC MC3419 APS-048-0071 v1.1 Page 17 of 78 Formal release date: 2020/07/13 4.3 ELECTRICAL AND TIMING CHARACTERISTICS 4.3.1 ELECTRICAL POW ER AND INTERNAL CHARACTERISTICS Parameter Conditions Symbol Min Pin VDD VDD Tclock Supply voltage 1 Sample Rate Tolerance 2 1 Min and Max limits are hard limits without additional tolerance. 2 Values are based on device characterization, not tested in production. Typ Max Unit 1.7 3.6 V -2 2 % Test condition: VDD = 2.8V, Top = 25 ⁰C unless otherwise noted Parameter Conditions Min Standby current WAKE state current Pad Leakage ODR = 100 Hz Per I/O pad -1 Typ Max Unit 4 μA 77 μA 0.01 1 μA Wake-Up time 3 ms Start-Up time 1/ODR+1mS ms Table 6. Electrical Characteristics MEMSIC MC3419 APS-048-0071 v1.1 Page 18 of 78 Formal release date: 2020/07/13 4.3.2 ELECTRICAL CHARACTERISTICS Parameter Symbol Min Max Unit LOW level input voltage VIL -0.5 0.3*VDD V HIGH level input voltage VIH 0.7*VDD - V Hysteresis of Schmitt trigger inputs Vhys 0.05*VDD - V Vol 0 0.4 V Voh 0 0.9*VDD V Vols - 0.1*VDD V Ii -10 10 µA Ci - 10 pF Output voltage, pin INTN 1 or INTN 2, Iol ≤ 2 mA Output voltage, pin DIN_SDA (open drain), Iol ≤ 1 mA Input current, pins DIN_SDA and SCK_SCL (input voltage between 0.1*VDD and 0.9*VDD max) Capacitance, pins DIN_SDA and SCL 1 1 Values are based on device characterization, not tested in production. Table 7. Electrical and Timing Characteristics - Interface NOTES:   If multiple slaves are connected to the I2C signals in addition to this device, only 1 pullup resistor on each of DIN_SDA and SCK_SCL should exist. Also, care must be taken to not violate the I2C specification for capacitive loading. When pin VDD is disconnected from power or ground (e.g. Hi-Z), the device may become inadvertently powered up through the ESD diodes present on other powered signals. MEMSIC MC3419 APS-048-0071 v1.1 Page 19 of 78 Formal release date: 2020/07/13 4.3.3 I2C TIMING CHARACTERISTICS Figure 10. I2C Interface Timing Parameter fSCL tHD; STA tLOW tHIGH tSU;STA tHD;DAT tSU;DAT tSU;STO tBUF Description SCL clock frequency Hold time (repeated) START condition LOW period of the SCL clock HIGH period of the SCL clock Set-up time for a repeated START condition Data hold time Data set-up time Set-up time for STOP condition Bus free time between a STOP and START Standard Mode Min Max 0 100 Fast Mode Min Max 0 400 Fast Mode Plus Min Max 0 1000 4.0 - 0.6 - 0.26 - μs 4.7 4.0 - 1.3 0.6 - 0.5 0.26 - μs μs 4.7 - 0.6 - 0.26 - μs 5.0 250 4.0 - 100 0.6 - 50 0.26 - μs ns μs 4.7 - 1.3 - 0.5 - μs Units kHz Table 8. I2C Timing Characteristics NOTE: Values are based on I2C Specification requirements, not tested in production. See also Section 10.3 I2C Message Format. MEMSIC MC3419 APS-048-0071 v1.1 Page 20 of 78 Formal release date: 2020/07/13 4.3.4 SPI TIMING CHARACTERISTICS DOUT_A6 Figure 11. SPI Interface Timing Waveform Symbol Parameter Value Min Units Max tc SPI SCK_SCL Clock Cycle 500 ns fc SPI SCK_SCL Clock Frequency tcs_su SPI CSN Setup Time 6 ns tcs_hld SPI CSN Hold Time 8 ns tdi_su SPI DIN_SDA Input Setup Time 5 ns tdi_hld SPI DIN_SDA Input Hold Time 15 ns tdo_vld SPI DOUT_A6 Valid Output Time tdo_hld SPI DOUT_A6 Output Hold Time tdo_dis SPI DOUT_A6 Output Disable Time 10 50 9 MHz ns ns 50 ns Table 9. SPI Interface Timing Parameters MEMSIC MC3419 APS-048-0071 v1.1 Page 21 of 78 Formal release date: 2020/07/13 5 GENERAL OPERATION The device supports the reading of samples and device status upon interrupt or by polling. 5.1 SENSOR SAMPLING In the WAKE state, acceleration data for X, Y, and Z axes is sampled at a rate between 0.5 and 1000 samples/second. See the Sample Rate Register section. The detectable acceleration range is variable and is set in the RANGE bits of the range and scale control register. Acceleration Value per Resolution bit Range (mg/LSB) 16-bit Full Scale Negative Reading Full Scale Positive Reading ± 2g ~.061 0x8000 0x7FFF ± 4g ~.122 (-32768) (+32767) ± 8g ~.244 ± 12g ~.366 ± 16g ~.488 Comments Signed 2’s complement number, results in XOUT_EX, YOUT_EX, ZOUT_EX. The MSB is the sign bit. (Integer interpretation also shown) Table 10. Summary of Resolution, Range, and Scaling 5.2 OFFSET AND GAIN CALIBRATION Digital offset and gain calibration can be performed on the sensor, if necessary, in order to reduce the effects of post-assembly influences and stresses which may cause the sensor readings to be offset from their factory values. MEMSIC MC3419 APS-048-0071 v1.1 Page 22 of 78 Formal release date: 2020/07/13 6 OPERATIONAL STATES The device has two states of operation: STANDBY and WAKE. All states are controlled by the software, there is no automatic power control. The device defaults to the STANDBY state following a power-up and must be in the WAKE state before executing a reset. The time to change from the STANDBY to WAKE state takes one sample period (takes less than 10 µs). State STANDBY WAKE I2C/SPI Bus R/W Description  Lowest power consumption  Internal clocking is halted  No motion detection, sampling, or calibration  The I2C/SPI bus can read and write to registers (resolution, range, thresholds and other settings can be changed)  Reset not allowed  Default state after a power-up  Highest power consumption  Internal clocking is enabled  Continuous motion detection and sampling; automatic calibration is available  The I2C/SPI bus can only write to the mode register and read all other registers  Reset allowed R Table 11. Operational States MEMSIC MC3419 APS-048-0071 v1.1 Page 23 of 78 Formal release date: 2020/07/13 7 OPERATIONAL STATE FLOW Figure 12. Operational State Flow shows the operational state flow for the device. The device defaults to STANDBY following power-on. STANDBY STATE=00 STATE=01 WAKE Figure 12. Operational State Flow The operation state may be read from the STATE bits of the device status register. The operational state may be forced to a specific state by writing into the STATE bits of the mode register, as shown below. Two bits are specified in order to promote software compatibility with other MEMSIC devices. The operational state will stay in the mode specified until changed. Action Setting Effect Force STANDBY State STATE[1:0] = 00 Force WAKE State STATE[1:0] = 01     Switch to the STANDBY state and stay there Disable sensor and event sampling Switch to WAKE state and stay there Continuous sampling Table 12. Forcing Operational States MEMSIC MC3419 APS-048-0071 v1.1 Page 24 of 78 Formal release date: 2020/07/13 8 INTERRUPTS The sensor device utilizes output pin INTN 1 or INTN 2 to signal to an external microprocessor that an event has been detected. The microprocessor should contain an interrupt service routine which would perform certain tasks after receiving this interrupt and reading the associated status bits, perhaps after a sample was made ready. If interrupts are to be used, the microprocessor must set up the registers in the sensor so that when a specific event is detected, the microprocessor would receive the interrupt and the interrupt service routine would be executed. If polling is used, there is no need for the interrupt registers to be set up. For products that use polling, the microprocessor must periodically poll the sensor and read the status data (the INTN 1 or INTN 2 pin is not used). For most applications, this is likely best done at the sensor sampling rate or faster. NOTE: At least one I2C STOP condition must be present between samples for the sensor to update the sample data registers. 8.1 INTERRUPT OVERVIEW Feature Description Comment Interrupt Pins Two interrupt pins are supported: INTN1 INTN2 INTN1 defaults to open-drain mode, active low polarity, and transitions on SAMPLE+MOTION interrupt events. INTN2 defaults to open-drain mode, active low polarity, and transitions on FIFO interrupt events Interrupt Polarity INTN1 and INTN2 pins operate in open-drain and active-drive modes. The polarity of the interrupts is independently selectable. The interrupt polarity/drive mode bits are in the GPIO control register 0x33. Interrupt Sources 1 interrupt on sample 5 motion interrupts 3 FIFO interrupts The default setting is to route SAMPLE+MOTION interrupt requests (INT1_REQ) to INTN1 pin and FIFO interrupt requests (INT2_REQ) to the INTN2 pin. Interrupt Servicing Interrupts may be cleared globally or individually. All interrupts are cleared by writing to register 0x14. FIFO interrupt bits are loaded in register 0x2F. Global clearing is the default, use register 0x31 bit 6 (INDIV_INTR_CLR) to enable the individual interrupt clear option (bitmask mode). Read/writing to register 0x2F does not clear FIFO interrupts. Swapping or Combining Interrupt Requests INT1_REQ (sample + motion) and INT2_REQ (FIFO) may be swapped between the INTN1 and INTN2 pins or combined on a single INTN1 pin. If all interrupts are combined in a single source, the pin to be used can still be chosen by using register 0x31 bit 4, INTN1 or INTN2. Table 13. Interrupt Overview MEMSIC MC3419 APS-048-0071 v1.1 Page 25 of 78 Formal release date: 2020/07/13 8.2 ENABLING AND CLEARING INTERRUPTS The interrupt status register (0x14) contains the bits for the sample acquisition interrupt ACQ_INT and the motion interrupts. The FIFO interrupt status register (0x2F) contains the bits for the FIFO interrupts The interrupt enable register (0x06) and FIFO control register (0x2D) determine if a flag event generates interrupts. The interrupts are cleared and rearmed every time the interrupt status register (0x14) is written. Interrupts may be cleared globally or individually. See section 8.4 for more information. When an event is detected, it is masked with a flag bit in the interrupt enable register, and then the corresponding status bit is set in the status registers. The polarity and driving mode of the external interrupt signals may be chosen by setting the INTN1 or INTN2 IPP and IAH bits in the GPIO control register (0x33). 8.3 INTERRUPT SOURCES 8.3.1 ACQ_INT INTERRUPT The ACQ_INT flag bit in the status registers is always active. This bit is cleared when it is read. When a sample has been produced, an interrupt will be generated only if the ACQ_INT_EN bit in the interrupt enable register is active. The frequency of the ACQ_INT bit being set active is always the same as the sample rate. 8.3.2 TILT/FLIP (TILT_INT, FLIP_INT) The TILT and FLIP flag bits in register 0x03/0x13 bit are active when the TILT/FLIP features are enabled by register 0x9 bit 0. The flag bits can transition quickly, so polled operation may be difficult. It is recommended to use the interrupt register 0x04/0x14 bits 0 or 1 instead. Note that the TILT and FLIP interrupt enables in register 0x06 bits [1:0] are separate, although there is a single control bit in register 0x09. 8.3.3 INTERRUPT ON ANYMOTION (ANYM_INT) The ANYM flag bit in register 0x03/0x13 bit is active when the ANYM feature is enabled by register 0x9 bit 2. The flag bit can transition quickly, so polled operation may be difficult. It is recommended to use the interrupt in register 0x04/0x14 bit 2 instead. Note that the SHAKE and TILT_35 interrupts require the ANYM feature to be enabled in register 0x09 bit 2, but the ANYM interrupt enable in register 0x06 bit 2 is not required. 8.3.4 INTERRUPT ON SHAKE (SHAKE_INT) The SHAKE flag bit in register 0x03/0x13 bit is active when the SHAKE feature is enabled by register 0x9 bit 3. The flag bit can transition quickly, so polled operation may be difficult. It is recommended to use the interrupt register 0x04/0x14 bit 3 instead. Note that the SHAKE interrupt requires the ANYM feature to be enabled in register 0x09 bit 2, but the ANYM interrupt enable in register 0x06 bit 2 is not required. MEMSIC MC3419 APS-048-0071 v1.1 Page 26 of 78 Formal release date: 2020/07/13 8.3.5 INTERRUPT ON TILT_35 (TILT_35_INT) The TILT_35 flag bit in register 0x03/0x13 bit is active when the SHAKE feature is enabled by register 0x9 bit 4. The flag bit can transition quickly, so polled operation may be difficult. It is recommended to use the interrupt register 0x04/0x14 bit 4 instead. Note that the TILT_35 interrupt requires the ANYM feature to be enabled in register 0x09 bit 2, but the ANYM interrupt enable in register 0x06 bit 2 is not required. 8.3.6 INTERRUPT ON FIFO EMPTY (FIFO_EMPTY_INT) The FIFO_EMPTY flag bit in register 0x0A bit 0 is active when the FIFO enable (FIFO_EN) control is enabled in register 0x2D bit 5. The FIFO_EMPTY flag will be set to ‘1’ following a POR or SW_RESET because the default state of the FIFO is empty. Note that the FIFO_EMPTY bit may transition on any write or read to the FIFO. The FIFO_EMPTY_INT_EN interrupt control bit is at register 0x2D bit 0. No bits in register 0x06 are required to be set. 8.3.7 INTERRUPT ON FIFO FULL (FIFO_FULL_INT) The FIFO_FULL flag bit in register 0x0A bit 1 is active when the FIFO enable (FIFO_EN) control is enabled in register 0x2D bit 5. The FIFO_FULL flag will be set to ‘0’ following a POR or SW_RESET because the default state of the FIFO is empty. Note that the FIFO_FULL bit may transition on any write or read to the FIFO. The FIFO_FULL_INT_EN interrupt control bit is at register 0x2D bit 1. No bits in register 0x06 are required to be set. 8.3.8 INTERRUPT ON FIFO THRESHOLD (FIFO_THRESH_INT) The FIFO_THRESH flag bit in register 0x0A bit 2 is active when the FIFO enable (FIFO_EN) control is enabled in register 0x2D bit 5. The FIFO_THRESH flag will be set to ‘0’ following a POR or SW_RESET because the default state of the FIFO is empty, and the default threshold level is a count of 16 samples (located in register 0x2E). Note that the FIFO_THRESH bit may transition on any write or read to the FIFO when a threshold level is crossed. The FIFO_THERESH_INT_EN interrupt control bit is at register 0x2D bit 2. No bits in register 0x06 are required to be set. MEMSIC MC3419 APS-048-0071 v1.1 Page 27 of 78 Formal release date: 2020/07/13 8.4 INTERRUPT SERVICING The MC3419 offers two methods for software to clear interrupts, and three operational modes. Methods:   Global Method: Software may globally clear all pending interrupts. Bitmask/Individual Method: Software may individually clear specific interrupts. Modes:    Mode 1 Latched: software clears any/all pending interrupts. Mode 2 Temp Latched: software clears interrupts or the temp_latch timer feature in register 0x4A clears interrupts on a selected time out period. Mode 3 Auto-Clear: software clears interrupts or hardware auto-clears interrupts. Note that some interrupts are not supported in Modes 2 or 3 (see Table 14 and Table 15 below). Please contact MEMSIC for more information. 8.4.1 GLOBAL INTERRUPT SERVICE METHOD Global mode (register 0x31 bit 6 = 0) is the default means for servicing interrupts. In this mode any write to registers 0x04 or 0x14 will clear *any* pending interrupts, including the FIFO interrupts in register 0x2F. The contents of the write cycle to registers 0x04/0x14 is ignored, but the address is used to generate the clear pulse. The table below shows how the interrupt sources behave in the three modes of interrupt operations. Note that the FIFO interrupts only operate in Mode 1. 8.4.2 BITMASK/INDIVIDUAL INTERRUPT SERVICE METHOD Bitmask/individual mode is enabled by setting register 0x31 bit 6 to ‘1’. In this mode, register 0x04 is not used to clear interrupts, only register 0x14. The contents of the write cycle to register 0x14 determine which interrupts are cleared (0 = no change, 1 = clear). Writing to register 0x14 bit 5 clears all pending FIFO interrupt flags in 0x2F (e.g. the single FIFO_INTR bit at register 0x14 bit 5 is a combined FIFO interrupt clear). The table below shows how the interrupt sources behave in the three modes of interrupt operations. Note that the FIFO interrupts only operate in Mode 1. Mode of Operation Mode 1 Latched Mode 2 Temp Latch ACQ_INT TILT_35_INT SHAKE_INT ANYM_INT FLIP_INT TILT_INT Set End of Z-axis processing TILT_35 condition has exceeded TILT_35 duration (1.6 to 3.0s). ANYM enable required. SHAKE_INT peak threshold and duration have been met. ANYM enable required. ANYM lock status met and relative threshold exceeded. TF threshold exceeded and debounce count met for TILT to FLIP transitions. TF threshold exceeded and debounce count met for FLAT to TILT or FLIP to TILT transitions. Clear Write to 0x14 Write to 0x14 Write to 0x14 Write to 0x14 Write to 0x14 Write to 0x14 Set End of Z-axis processing TILT_35 condition has exceeded TILT_35 duration (1.6 to 3.0s). SHAKE_INT peak threshold and duration have ANYM lock status met and relative threshold exceeded. TF threshold exceeded and debounce count TF threshold exceeded and debounce count met for FLAT to MEMSIC MC3419 APS-048-0071 v1.1 Page 28 of 78 Formal release date: 2020/07/13 Mode 3 Auto-Clear ANYM enable required. been met. ANYM enable required. met for TILT to FLIP transitions. TILT or FLIP to TILT transitions. Clear Temp latch period timeout or write to 0x14 Temp latch period timeout or write to 0x14 Temp latch period timeout or write to 0x14 Temp latch period timeout or write to 0x14 Temp latch period timeout or write to 0x14 Temp latch period timeout or write to 0x14 Set End of Z-axis processing TILT_35 condition has exceeded TILT_35 duration (1.6 to 3.0s). ANYM enable required. SHAKE_INT peak threshold and duration have been met. ANYM enable required. ANYM lock status met and relative threshold exceeded. TF threshold exceeded and debounce count met for TILT to FLIP transitions. TF threshold exceeded and debounce count met for FLAT to TILT or FLIP to TILT transitions. Clear Beginning of Z-axis accumulation, or write to 0x14 Cleared when condition ends or is reset by hardware, or write to 0x14 Cleared when condition ends or is reset by hardware, or write to 0x14 Cleared when condition ends or is reset by hardware, or write to 0x14 Cleared when condition ends or is reset by hardware, or write to 0x14 Cleared when condition ends or is reset by hardware, or write to 0x14 Table 14. Interrupt servicing details (Motion + Sample) Mode of Operation Mode 1 Latched FIFO_THRESH FIFO_FULL FIFO_EMPTY Set FIFO sample count equals or exceeds the FIFO threshold count in register 0x2E. FIFO has 32 samples; hardware writes to the FIFO in WAKE mode and FIFO_EN = 1. FIFO has 0 samples. Reading the FIFO at register 0xD with I2C/SPI removes 1 or more samples. Clear Write to 0x14 Write to 0x14 Write to 0x14 Table 15. Interrupt servicing details (FIFO) MEMSIC MC3419 APS-048-0071 v1.1 Page 29 of 78 Formal release date: 2020/07/13 8.5 INTERRUPT REQUESTS AND EXTERNAL INT PINS MC3419 has two pins which support external interrupts. Each pin may be separately configured as open-drain or active drive and the polarity is programmable. The drive and polarity control is loaded in the GPIO Control register 0x07 to register 0x33. By default the sample + motion interrupt request is routed to the INTN1 pin, and FIFO interrupt request is routed to the INTN2 pin. These requests may be swapped between the INTN1 pin and INTN2 pin or combined on a single pin. 8.5.1 SELECTING DRIVE AND POLARITY The drive mode (open-drain or push/pull) are controlled by register 0x33 bits 7:6 and 3:2. Addr 0x33 Name GPIO_CTRL Descriptio n GPIO Control Register Bit 7 6 5 4 3 2 1 0 GPIO2_ INTN2_IPP GPIO2_ INTN2_ IAH Resv Resv GPIO1_ INTN1_IPP GPIO1_ INTN1_ IAH Resv Resv POR Value R/W 0x00 RW Table 16. GPIO Control Register Bit 2 Name Function Description GPIO1_INTN1_IAH Set polarity of INTN1 output. 0: The INTN1 pin is active low. 1: The INTN1 pin is active high. This bit sets the polarity level of the INTN1 pin. This bit is used in interrupt mode to set the level of the interrupt request. 3 GPIO1_INTN1_IPP Select open drain or push/pull mode for INTN1. 0: The INTN1 pin operates in open-drain mode as an output and requires an external pullup to VDD. 1: The INTN1 pin operates in push-pull mode as an output. This bit sets the drive mode of the INTN1 pin as an interrupt request output. 6 GPIO2_INTN2_IAH Set polarity of INTN2 output. 0: The INTN2 pin is active low. 1: The INTN2 pin is active high. This bit sets the polarity level of the INTN2 pin. This bit is used in interrupt mode to set the level of the interrupt request. 7 GPIO2_INTN2_IPP Select open drain or push/pull mode for INTN2. 0: The INTN2 pin operates in open-drain mode as an output and requires an external pullup to VDD. 1: The INTN2 pin operates in push-pull mode as an output. This bit sets the drive mode of the INTN2 pin as an interrupt request output. Table 17. Interrupt drive and polarity control MEMSIC MC3419 APS-048-0071 v1.1 Page 30 of 78 Formal release date: 2020/07/13 8.5.2 SW APPING INT PINS The interrupt requests driving the INTN1 and INTN2 pins may be swapped. Setting register 0x31 bit 4 to ‘1’ (INT1_INT2_REQ_SWAP) internally swaps the INT1_REQ and INT2_REQ signals in the MC3419. To clarify, the requests are swapped, but the bits controlling the INTN1 and INTN2 pin mode, drive, and polarity are not. Bit Name Function Description 4 INT1_INT2_REQ_SWAP Swap INT1 and INT2 pin functionality. 0: INT1 requests are routed to the INTN1 pin, INTN2 requests are routed to the INT2 pin (default). 1: INT1 requests are routed to the INTN2 pin, INT2 requests are routed to the INTN1 pin Table 18. Swapping Interrupt Requests, register 0x31 bit 4 8.5.3 COMBINING INTERRUPT REQUESTS The separate internal interrupt requests (INT1_REQ or motion + sample, and INT2_REQ or FIFO) may be combined into a single request that appears on one pin. Setting register 0x2D bit 3 (COMB_INT_EN) to ‘1’ combines both requests on INT1_REQ that is routed to the INTN1 pin. To move it to the INTN2 pin, use the pin “swap” feature described in the previous section. Bit Name 3 COMB_INT_EN Function Description Combined interrupt enable. 0: Motion/interrupt on sample interrupts are routed to INTN1, and FIFO interrupts are routed to INTN2. (default). 1: All interrupts are routed to INTN1. When the COMB_INT_EN bit is set, all interrupts requests are routed to INT1_REQ internally. INT2_REQ becomes disabled. Table 19. Combining interrupt requests, register 0x2D bit 3 MEMSIC MC3419 APS-048-0071 v1.1 Page 31 of 78 Formal release date: 2020/07/13 9 SAMPLING 9.1 CONTINUOUS SAMPLING The device has the ability to read all sampled readings in a continuous sampling fashion. The device always updates the XOUT, YOUT, and ZOUT registers at the chosen output data rate. An optional interrupt can be generated each time the sample registers have been updated (using the ACQ_INT bit in the interrupt enable register). See the ACQ_INT Interrupt section or status register for more information about ACQ_INT. 9.2 SETTING THE SAMPLE RATE The MC3419 supports eight sample rates using I2C or SPI interfaces. When decimation mode is disabled, the table below shows the “internal data rate” (IDR) which is the same as ODR (ODR = IDR). The sample rate register (0x08) selects the WAKE mode sample rate. If the I2C interface is selected or if the SPI clock frequency is 4 MHz or less, use the register 0x08 settings as shown in the “Selection A” column below. If the SPI clock frequency is 4 MHz to 10 MHz, use the register 0x08 settings as shown in the “Selection B” column below. I2C or SPI I2C Speed ≤ 1MHz or SPI Speed ≤ 4MHz Rate SPI Only 4MHz < SPI Speed ≤ 10MHz IDR = ODR (Hz) Register 0x08 Selection A IDR = ODR (Hz) Register 0x08 Selection B 0 25 0x10 50 0x08 1 50 0x11 62.5 0x09 2 62.5 0x12 100 0x0A 3 100 0x13 125 0x0B 4 125 0x14 250 0x0C 5 250 0x15 500 0x0D 6 500 0x16 1000 0x0E 7 1000 0x17 - - Table 20. Sample Rate Settings MEMSIC MC3419 APS-048-0071 v1.1 Page 32 of 78 Formal release date: 2020/07/13 9.3 ADDITIONAL RATE OPTIONS The MC3419 can generate slower sample rates from the frequencies listed in Table 20. When decimation mode is enabled the “internal data rate” (IDR) is divided by a fixed ratio to obtain an ODR or “output data rate”. If decimation mode is not enabled (default), the IDR and ODR are the same frequency. The FIFO control 2/sample rate 2 register (0x30) selects the ratio used for decimation mode. Bits Name Function Description 3:0 DEC_MODE_ RATE[3:0] Decimation mode rate selection. 0000: Decimation mode disabled (default). 0001: Divide sample rate by 2 0010: Divide sample rate by 4 0011: Divide sample rate by 5 0100: Divide sample rate by 8 0101: Divide sample rate by 10 0110: Divide sample rate by 16 0111: Divide sample rate by 20 1000: Divide sample rate by 40 1001: Divide sample rate by 67 1010: Divide sample rate by 80 1011: Divide sample rate by 100 1100: Divide sample rate by 200 1101: Divide sample rate by 250 1110: Divide sample rate by 500 1111: Divide sample rate by 1000 When decimation mode is enabled, the internal data rate (IDR) is divided by the above factor to create a slower output data rate (ODR). The FIFO, motion block, output registers, and interrupts operate off the slower ODR when decimation mode is on. If decimation mode is disabled, then the IDR and ODR are the same value. Table 21. Hardware Decimation Ratios The FIFO, motion events, and interrupts operate at the decimated rate (output data rate) when decimation mode is enabled. The low pass filter always operates at the internal data rate whether decimation mode is on or off. Please contact MEMSIC for more information. MEMSIC MC3419 APS-048-0071 v1.1 Page 33 of 78 Formal release date: 2020/07/13 10 I2C INTERFACE 10.1 PHYSICAL INTERFACE The I2C slave interface operates at a maximum speed of 1 MHz. The SDA (data) is an opendrain, bi-directional pin and the SCL (clock) is an input pin. Note: The device always operates as an I2C slave. An I2C master initiates all communication and data transfers and generates the SCL clock that synchronizes the data transfer. The I2C device address depends upon the state of the DOUT_A6 pin during power-up as shown in the table below. An optional I2C watchdog timer can be enabled to prevent bus stall conditions. See the Watchdog Timer section for more information. 7-bit Device ID 8-bit Address – Write 8-bit Address – Read DOUT_A6 level upon power-up 0x4C (0b1001100) 0x98 0x99 GND 0x6C (0b1101100) 0xD8 0xD9 VDD Table 22. I2C Address Selection The I2C interface remains active as long as power is applied to the VDD pin. In the STANDBY state, the device responds to I2C read and write cycles, but interrupts cannot be serviced or cleared. All registers can be written in the STANDBY state, but in the WAKE state, only the mode register can be modified (see the Operational States section for more information). Internally, the registers which are used to store samples are clocked by the sample clock gated by I2C activity. Therefore, in order to allow the device to collect and present samples in the sample registers, at least one I2C STOP condition must be present between samples. Refer to the I2C specification for a detailed discussion of the protocol. Per I2C requirements, SDA is an open drain, bi-directional pin. SCL and SDA each require an external pull-up resistor, typically 4.7kΩ. MEMSIC MC3419 APS-048-0071 v1.1 Page 34 of 78 Formal release date: 2020/07/13 10.2 TIMING See the I2C Timing Characteristics section for I2C timing requirements. 10.3 I2C MESSAGE FORMAT Note: At least one I2C STOP condition must be present between samples in order for the sensor to update the sample data registers. The device uses the following general format for writing to the internal registers: The I2C master generates a START condition and then supplies the 7-bit device ID. The 8th bit is the R/W# flag (write cycle = 0). The device pulls SDA low during the 9 th clock cycle indicating a positive ACK. The second byte is the 8-bit register address of the device to access. The last byte is the data to write. START I2C Master (To Sensor) S Device ID 1 1 0 1 R/W# 1 1 0 I2C Slave (From Sensor) Register Address 0 R7 R6 R5 R4 R3 R2 Register Data to Write R1 R0 D7 D6 D5 D4 D4 D2 D1 Stop D0 P ACK ACK ACK ACK/NAK ACK/NAK ACK/NAK Figure 13. I2C Message Format, Write Cycle, Single Register Write In a read cycle, the I2C master generates a START condition and then writes the device ID, R/W# flag (write cycle = 0), and register address. The master issues a RESTART condition and then writes the device ID with the R/W# flag set to ‘1’. The device shifts out the contents of the register address. START I2C Master (To Sensor) I2C Slave (from Sensor) S Device ID 1 1 0 1 1 R/W# 1 0 Register Address 0 R7 R6 R5 R4 R3 R2 Restart R1 R0 R Device ID 1 1 0 1 1 R/W# 1 0 NAK NAK 1 ACK ACK ACK ACK/NAK ACK/NAK ACK/NAK D7 D6 D5 D4 D3 D2 D1 STOP P D0 Read Data Byte Figure 14. I2C Message Format, Read Cycle, Single Register Read The I2C master may write or read consecutive register addresses by writing or reading additional bytes after the first access. The device will internally increment the register address. MEMSIC MC3419 APS-048-0071 v1.1 Page 35 of 78 Formal release date: 2020/07/13 10.4 I2C WATCHDOG TIMER The I2C watchdog timer, when enabled (see the mode register), prevents bus stall conditions when the master does not provide enough clocks to the slave to complete a read cycle. The I2C watchdog timer does not resolve why the master did not provide enough clocks to complete a read cycle, but it does prevent a slave from holding the bus indefinitely. During a read cycle, the slave that is actively driving the bus (SDA pin) does not release the bus until nine SCL clock edges are detected. While the SDA pin is held low by a slave opendrain output, any other I2C devices attached to the bus will not be able to communicate. If the slave does not see nine SCL clocks from the master within the timeout period (about 200 ms), the slave assumes a system problem has occurred and resets the I2C circuitry, releases the SDA pin, and readies the sensor for additional I2C commands. When an I2C watchdog timer event is triggered, the I2C_WDT bit in the device status register is activated by the Watchdog timer hardware. No other registers are changed. External software can detect this activation by reading the I2C_WDT bit. Reading the device status register (0x05) clears the I2C_WDT bit. MEMSIC MC3419 APS-048-0071 v1.1 Page 36 of 78 Formal release date: 2020/07/13 11 SPI INTERFACE 11.1 SPI PHYSICAL INTERFACE The device always operates as an SPI slave. An SPI master must initiate all communication and data transfers and generate the SCK_SCL clock that synchronizes the data transfer. The CSN pin must be pulled up to VDD when the SPI interface is not in use. The SPI interface can operate in 3-wire or 4-wire mode. See section 9.2 for SPI clock selection and Output Data Rate, ODR. 11.2 SPI PROTOCOL An SPI write transaction requires a minimum of 16 clock cycles, and a SPI read transaction requires a minimum of 24 cycles of the SCK_SCL pin. The falling edge of CSN initiates the start of the SPI bus cycle. When the SPI master is writing data to the MC3419 via the SPI DIN pin, data may change when the SCL_SCK is low, and must be stable on the rising edge. Similarly, output data written from MC3419 to the SPI master is shifted out on the SPI DOUT pin on the falling edge of SCL_SCK and can be latched by the master on the rising edge of SCL_SCK. Serial data in or out of the device is always MSB first. 11.3 SPI REGISTER WRITE CYCLE - SINGLE A single register write consists of a 16-clock transaction. As described above, the first bit is set to ‘0’ indicating a register write followed by the register address. CSN SCL_SCK SPI_DIN 1 2 3 4 5 6 7 8 0 A6 A5 A4 A3 A2 A1 A0 9 10 DIN7 DIN6 11 12 DIN5 DIN4 13 14 DIN3 DIN2 15 16 DIN1 DIN0 Z SPI_DOUT Figure 15. SPI Register Write Cycle - Single 11.4 SPI REGISTER WRITE CYCLE - BURST A burst (multi-byte) register write cycle uses the address specified at the beginning of the transaction as the starting register address. Internally the address will auto-increment to the next consecutive address for each additional byte (8-clocks) of data written beyond clock 8. MEMSIC MC3419 APS-048-0071 v1.1 Page 37 of 78 Formal release date: 2020/07/13 CSN SCL_SCK DIN_SDA 1 2 3 4 5 6 7 8 0 A6 A5 A4 A3 A2 A1 A0 9 11 10 12 13 14 15 16 DIN7 DIN6 DIN5 DIN4 DIN3 DIN2 DIN1 DIN0 17 18 19 20 21 22 23 24 25 26 DIN15 DIN14 DIN13 DIN12 DIN11 DIN10 DIN9 DIN8 DIN31 DIN30 Data for register N 27 28 29 30 31 32 DIN29 DIN28 DIN27 DIN26 DIN25 DIN24 Data for register N+2 Data for register N+1 DOUT_A6 Figure 16.SPI Register Write Cycle - Burst (3-register burst example) 11.5 SPI REGISTER READ CYCLE - SINGLE A single register read consists of a 24-clock transaction. As described above, the first bit is set to ‘1’ indicating a register read followed by the register address. CSN SCL_SCK DIN_SDA 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 1 A6 A5 A4 A3 A2 A1 A0 0 0 0 0 0 0 0 0 X X X X X X X X DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 DOUT_A6 Figure 17. SPI Register Read Cycle - Single 11.6 SPI REGISTER READ CYCLE - BURST A burst (multi-byte) register read cycle uses the address specified at the beginning of the transaction as the starting register address. Internally the address will auto-increment to the next consecutive address for each additional byte (8-clocks) of data read beyond clock 8. CSN SCL_SCK DIN_SDA 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1 A6 A5 A4 A3 A2 A1 A0 0 0 0 0 0 0 0 0 X X X X X X X X X X X X X X X X DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 DO15 DO14 DO13 DO12 DO11 DO10 DO9 DO8 DOUT_A6 Data read from register N Data read from register N+1 Figure 18. SPI Register Read Cycle - Burst (2 register burst example) MEMSIC MC3419 APS-048-0071 v1.1 Page 38 of 78 Formal release date: 2020/07/13 12 REGISTER INTERFACE The device has a register interface which allows an MCU, I2C or SPI master to configure and monitor all aspects of the device. This section lists an overview of user programmable registers. By convention, bit 0 is the least significant bit (LSB) of a byte register. 12.1 REGISTER SUMMARY NOTE: Registers are not updated with new event status or samples while an I2C or SPI cycle is in process. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W1 STATE[0] 0x00 R 0x00 W RESERVED2 0x00 – 0x04 0x05 DEV_STAT Device Status Register 0x06 INTR_ CTRL Interrupt Enable 0x07 MODE Mode RESV RESV 0x08 SR Sample Rate 03 03 0x09 MOTION_ CTRL Motion Control 0x0A FIFO_ STAT FIFO Status Register 0x0B Bit 4 FIFO-RD_P FIFO Read Pointer SEC_ENA (TMODE) OTP_BUSY ACQ_INT AUTO_ _EN CLR_EN RAW_ MOTION PROC_ _RESET STAT RESV I2C_WDT RESV TILT_35_ SHAKE_ INT_EN INT_EN I2C_ I2C_ RESV WDT_POS WDT_NEG Resv 03 03 03 Z_AXIS_ TILT_35_ SHAKE_ ORT EN EN RES_MODE STATE[1] ANYM_ FLIP_INT_ TILT_INT_ INT_EN EN EN 03 STATE1 STATE0 0x00 W RATE[2] RATE[1] RATE[0] 0x00 W ANYM_ MOTION_ TF_ EN LATCH ENABLE 0x00 W FIFO_ FIFO_ FIFO_FULL THRESH EMPTY 0x00 RO FIFO_ RD_PTR[2] RESV RESV RESV RESV RESV RESV RESV FIFO_ RD_PTR[5] FIFO_ RD_PTR[4] FIFO_ RD_PTR[3] FIFO_ RD_PTR[0] 0x00 RO RESV RESV FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ WR_PTR[5] WR_PTR[4] WR_PTR[3] WR_PTR[2] WR_PTR[1] WR_PTR[0] 0x00 RO FIFO_ RD_PTR[1] FIFO_ WR_P XOUT_ EX_L XOUT Accelerometer XOUT_ Data LSB EX[7] XOUT_ EX[6] XOUT_ EX[5] XOUT_ EX[4] XOUT_ EX[3] XOUT_ EX[2] XOUT_ EX[1] XOUT_ EX[0] 0x00 R 0x0E XOUT_ EX_H XOUT Accelerometer XOUT_ Data MSB EX[15] XOUT_ EX[14] XOUT_ EX[13] XOUT_ EX[12] XOUT_ EX[11] XOUT_ EX[10] XOUT_ EX[9] XOUT_ EX[8] 0x00 R 0x0F YOUT_ EX_L YOUT Accelerometer YOUT_ Data LSB EX[7] YOUT_ EX[6] YOUT_ EX[5] YOUT_ EX[4] YOUT_ EX[3] YOUT_ EX[2] YOUT_ EX[1] YOUT_ EX[0] 0x00 R 0x10 YOUT_ EX_L YOUT Accelerometer YOUT_ Data MSB EX[15] YOUT_ EX[14] YOUT_ EX[13] YOUT_ EX[12] YOUT_ EX[11] YOUT_ EX[10] YOUT_ EX[9] YOUT_ EX[8] 0x00 R 0x11 ZOUT_ EX_L ZOUT Accelerometer ZOUT_ Data LSB EX[7] ZOUT_ EX[6] ZOUT_ EX[5] ZOUT_ EX[4] ZOUT_ EX[3] ZOUT_ EX[2] ZOUT_ EX[1] ZOUT_ EX[0] 0x00 R 0x12 ZOUT_ EX_H ZOUT Accelerometer ZOUT_ Data MSB EX[15] ZOUT_ EX[14] ZOUT_ EX[13] ZOUT_ EX[12] ZOUT_ EX[11] ZOUT_ EX[10] ZOUT_ EX[9] ZOUT_ EX[8] 0x00 R 0x13 STATUS TILT_ FLAG 0x00 R 0x00 R 0x00 W 0x0C 0x0D INTR_ STAT 0x15 – 0x1F 0x14 FIFO Write Pointer Status Register NEW_ DATA RESV FIFO_FLAG TILT_35_ SHAKE_ FLAG FLAG ANYM_ FLIP_FLAG FLAG Interrupt Status Register ACQ_INT RESV FIFO_INT TILT_35_ SHAKE_ INT INT RESERVED2 ANYM_ INT 03 RANGE[2] RANGE[1] RANGE[0] LPF_EN LPF[2] LPF[1] XOFF[2] FLIP_INT TILT_INT 0x20 RANGE Range Select Control 0x21 XOFFL X-Offset LSB XOFF[7] XOFF[6] XOFF[1] XOFF[0] Per chip W 0x22 XOFFH X-Offset MSB XGAIN[8] XOFF[14] XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] Per chip W MEMSIC MC3419 APS-048-0071 v1.1 XOFF[5] XOFF[4] Page 39 of 78 XOFF[3] LPF[0] Formal release date: 2020/07/13 Addr Name Description Bit 7 Bit 6 0x23 YOFFL Y-Offset LSB YOFF[7] YOFF[6] I0x24 YOFFH 0x25 R/W1 Bit 4 Bit 3 Bit 2 Bit 1 YOFF[5] YOFF[4] YOFF[3] YOFF[2] YOFF[1] YOFF[0] Per chip W Y-Offset MSB YGAIN[8] YOFF[14] YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] YOFF[8] Per chip W ZOFFL Z-Offset LSB ZOFF[7] ZOFF[6] ZOFF[1] ZOFF[0] Per chip W 0x26 ZOFFH Z-Offset MSB ZGAIN[8] ZOFF[14] ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] ZOFF[8] Per chip W 0x27 XGAIN X Gain XGAIN[7] XGAIN[6] XGAIN[5] XGAIN[4] XGAIN[3] XGAIN[2] XGAIN[1] XGAIN[0] Per chip W 0x28 YGAIN Y Gain YGAIN[7] YGAIN[6] YGAIN[5] YGAIN[4] YGAIN[3] YGAIN[2] YGAIN[1] YGAIN[0] Per chip W 0x29 ZGAIN Z Gain ZGAIN[7] ZGAIN[6] ZGAIN[5] ZGAIN[4] ZGAIN[3] ZGAIN[2] ZGAIN[1] ZGAIN[0] Per chip W ZOFF[5] 0x2D FIFO_ CTRL FIFO Control Register 03 FIFO_ MODE 0x2E FIFO_TH FIFO Threshold Register RESV RESV RESV 0x2F FIFO_ INTR FIFO Interrupt Status Register 03 RESV RESV 0x30 FIFO_ CTRL2 _SR2 FIFO_ BURST_ MODE 03 SELECT_ WRAP_ ADDR 0x31 COMM_ CTRL FIFO Control 2, Sample Rate 2 Register Comm. Control Register 03 FIFO_EN FIFO_RESET 0x43 0x44 0x45 0x46 TF_DB FIFO_TH[4] FIFO_TH[3] FIFO_TH[2] FIFO_TH[1] FIFO_TH[0] FIFO_ FIFO_FULL_ FIFO_EMPT THRESH_ INT (RO) Y _INT (RO) INT (RO) DEC_ ENABLE_ DEC_MODE DEC_MODE DEC_MODE MODE WRAP_N RATE[3] RATE[1] RATE[0] RATE[2] RESV RESV 0x00 W 0x10 W 0x00 R W 0x00 W 03 03 RESV RESV 0x00 W INTN1_ IPP INTN1_IAH RESV RESV 0x00 W 0x00 W 0x00 W 0x00 W RESERVED2 GPIO Control Register 0x34 -0x3F TF_ Tilt/Flip Threshold 0x40 THRESH_L LSB SB TF_ Tilt/Flip Threshold 0x41 THRESH_ MSB MSB 0x42 ZOFF[2] FIFO_ COMB_INT FIFO_TH_ FIFO_FULL_ EMPTY_ _ EN INT_EN INT_EN INT_EN INDIV_ SPI_3WIRE INT1_INT2_ INTR_CLR _ EN REQ_SWAP 0x32 GPIO_ CTRL ZOFF[3] RESERVED2 0x2A -0x2C 0x33 ZOFF[4] Bit 0 POR Value Bit 5 INTN2_ INTN2_IAH IPP RESV RESV RESERVED2 TF_ TF_ TF_THR[6] TF_THR[5] TF_THR[4] TF_THR[3] TF_THR[2] TF_THR[1] THR[7] THR[0] RESV TF_ THR[14] TF_ THR[13] TF_ THR[12] TF_ THR[11] TF_ TF_ TF_THR[9] THR[10] THR[8] Tilt/Flip Debounce TF_DB[7] TF_DB[6] TF_DB[5] TF_DB[4] TF_DB[3] TF_DB[2] TF_DB[1] TF_DB[0] AM_ AnyMotion Threshold THRESH_L LSB SB AM_ AnyMotion Threshold THRESH_ MSB MSB AnyMotion AM_DB Debounce SHK_ THRESH_L Shake Threshold LSB SB ANYM_ THR[7] ANYM_ THR[6] ANYM_ THR[5] ANYM_ THR[4] ANYM_ THR[3] ANYM_ THR[2] ANYM_ THR[1] ANYM_ THR[0] 0x00 W RESV ANYM_ THR[14] ANYM_ THR[13] ANYM_ THR[12] ANYM_ THR[11] ANYM_ THR[10] ANYM_ THR[9] ANYM_ THR[8] 0x00 W ANYM_ DB[7] ANYM_ DB[6] ANYM_ DB[5] ANYM_ DB[4] ANYM_ DB[3] ANYM_ DB[2] ANYM_ DB[1] ANYM_ DB[0] 0x00 W SH _ THR[7] SH _ THR[6] SH _ THR[5] SH _ THR[4] SH _ THR[3] SH _ THR[2] SH _ THR[1] SH _ THR[0] 0x00 W MEMSIC MC3419 APS-048-0071 v1.1 Page 40 of 78 Formal release date: 2020/07/13 Addr 0x47 0x48 0x49 0x4A 0x4B Name Description Bit 7 Bit 6 Bit 5 SHK_ SH_ SH _ SH _ SH _ THRESH_ Shake Threshold MSB THR[15] THR[14] THR[13] THR[12] MSB PK_P2P_D UR_ Peak-to-Peak PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ THRESH_L Duration LSB DUR[7] DUR[6] DUR[5] DUR[4] SB PK_P2P_D Shake Duration and UR_ SHK_CNT_ SHK_CNT SHK_CNT_ RESV Peak-to-Peak THRESH_ DUR[2] _DUR[1] DUR[0] Duration MSB MSB TEMP_ TIMER_CT TEMP_ TEMP_ TEMP_ Timer Control PER_INT RL PERIOD[2] PERIOD[1] PERIOD[0] _EN RD_CNT Read Count Register Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W1 SH _ THR[11] SH _ THR[10] SH _ THR[9] SH _ THR[8] 0x00 W PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ DUR[3] DUR[2] DUR[1] DUR[0] 0x00 W PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ DUR[11] DUR[10] DUR[9] DUR[8] 0x00 W 0x00 W 0x06 R/W Bit 4 RESV TILT_ 35[2] TILT_35[1] TILT_ 35[0] RD_CNT[7] RD_CNT[6] RD_CNT[5] RD_CNT[4] RD_CNT[3] RD_CNT[2] RD_CNT[1] RD_CNT[0] 0x4C – 0x50 RESERVED2 1 ‘R’ registers are read-only, via external I2C access. ‘W’ registers are read-write, via external I2C access. Registers designated as ‘RESERVED’ should not be accessed by software. 3 Software must write a zero (0) to this bit. 4 Software must write a one (1) to this bit. 2 Table 23. Register Summary MEMSIC MC3419 APS-048-0071 v1.1 Page 41 of 78 Formal release date: 2020/07/13 12.2 (0X05)DEVICE STATUS REGISTER The device status register reports various conditions of the sensor circuitry. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 0x05 DEV_ STAT Device Status OTP_ BUSY Resv Resv I2C_WDT Resv RES_ MODE Name STATE[1:0] RES_MODE I2C_WDT OTP_BUSY Bit 1 Bit 0 STATE[1] STATE[0] POR Value R/W 0x00 R Description Operating mode of the current device. 00: STANDBY. Clocks are not running and X, Y, and Z-axis data are not sampled. 01: WAKE. Clocks are running and X, Y, and Z-axis data are acquired at the sample rate. 10: Reserved. 11: Reserved. Resolution mode of the current device. 0: 16-bit (high) resolution is enabled. 1: Reserved. I2C watchdog timeout. This bit is cleared when register 0x05 is read. 0: A watchdog event is not detected. 1: A watchdog event has been detected by the hardware and the I2C slave state machine is reset to idle. One-Time programming (OTP) activity status. 0: Internal memory is idle and the device is ready to use. 1: Internal memory is active and the device cannot be used. Table 24. Device Status Register MEMSIC MC3419 APS-048-0071 v1.1 Page 42 of 78 Formal release date: 2020/07/13 12.3 (0X06) INTERRUPT ENABLE REGISTER The interrupt enable register enables or disables the reporting of interrupt status for each interrupt source. FIFO interrupt are enabled in the FIFO control register 0x2D. Addr Name Description 0x06 INTR_ CTRL Interrupt Enable Name TILT_INT_EN FLIP_INT_EN ANYM_INT_EN SHAKE_INT_EN TILT_35_INT_EN AUTO_CLR_EN ACQ_INT_EN Bit 7 Bit 6 ACQ_INT_ AUTO_ EN CLR_EN Bit 5 Resv Bit 4 Bit 3 TILT_35_ SHAKE_ INT_EN INT_EN Bit 2 Bit 1 Bit 0 ANYM_ FLIP_INT_ TILT_INT_ INT_EN EN EN POR Value R/W 0x00 W Description Use with the tilt/flip feature in the motion control register (register 0x09, bit 0) to activate the reporting status of the tilt interrupt. 0: Tilt interrupt is disabled. 1: Tilt interrupt is enabled. Use with the tilt/flip feature in the motion control register (register 0x09, bit 0) to activate the reporting status of the flip interrupt. 0: Flip interrupt is disabled. 1: Flip interrupt is enabled. Use with the AnyMotion feature in the motion control register (register 0x09, bit 2) to activate the reporting status of the AnyMotion interrupt. 0: AnyMotion interrupt is disabled. 1: AnyMotion interrupt is enabled. Use with the shake feature in the motion control register (register 0x09, bit 3) and the AnyMotion feature in the motion control register (register 0x09, bit 2) to activate the reporting status of the shake interrupt. 0: Shake interrupt is disabled. 1: Shake interrupt is enabled. Use with the tilt-35 feature in the motion control register (register 0x09, bit 4) and the AnyMotion feature in the motion control register (register 0x09, bit 2) to activate the reporting status of the tilt-35 interrupt. 0: Tilt-35 interrupt is disabled. 1: Tilt-35 interrupt is enabled. Clear pending interrupts automatically or by reading a register. See section 8.4 for more information. 0: Clear pending interrupts by writing to register 0x14. 1: Automatically clear pending interrupts if the interrupt condition is no longer valid. Refer to Interrupts for more information about interrupts. Generate interrupts. 0: Disable automatic interrupt after each sample (default). 1: Enable automatic interrupt after each sample (activates the ACQ_INT flag, bit 7, in register 0x14). Table 25. Interrupt Enable Register MEMSIC MC3419 APS-048-0071 v1.1 Page 43 of 78 Formal release date: 2020/07/13 12.4 (0X07) MODE REGISTER The mode register controls the active operating state of the accelerometer. This register can be written from all operational states (WAKE, or STANDBY). Addr Name Description Bit 7 Bit 6 0x07 MODE Mode Resv Resv 1Software Bit 5 Bit 4 I2C_ I2C_ WDT_POS WDT_NEG Bit 3 Bit 2 0 01 Bit 1 Bit 0 STATE[1] STATE[0] POR R/W Value 0x00 W must write a zero (0) to bit 2. Name STATE[1:0] I2C_WDT_NEG I2C_WDT_POS Description Accelerometer operational state. 00: STANDBY. Clocks are not running and X, Y, and Z-axis data are not sampled. 01: WAKE. Clocks are running and X, Y, and Z-axis data are acquired at the sample rate. 10: Reserved. 11: Reserved. Watchdog timer for negative SCL stalls. 0: The I2C watchdog timer for negative SCL stalls is disabled (default). 1: The I2C watchdog timer for negative SCL stalls is enabled. Watchdog timer for positive SCL stalls. 0: The I2C watchdog timer for positive SCL stalls is disabled (default). 1: The I2C watchdog timer for positive SCL stalls is enabled. Table 26. Mode Register States MEMSIC MC3419 APS-048-0071 v1.1 Page 44 of 78 Formal release date: 2020/07/13 12.5 (0X08) SAMPLE RATE REGISTER The sample rate register sets the sampling output data rate (ODR) for the sensor and the clock frequency of the main oscillator. Addr Name Description Bit 7 Bit 6 Bit 5 0x08 SR Sample Rate 01 01 01 Bit 4 Bit 3 See table below Bit 2 Bit 1 Bit 0 RATE[2] RATE[1] RATE[0] POR R/W Value 0x00 RW 1 Software must write a zero (0). Name Description RATE[2:0] Select the Output Data Rate, ODR Table 27. Sample Rate Register I2C or SPI Speed ≤ 4MHz I2C or 4MHz < SPI Speed ≤ 10MHz Rate IDR = ODR (Hz) Reg 0x08 IDR = ODR (Hz) Reg 0x08 0 25 0x10 50 0x08 1 50 0x11 62.5 0x09 2 62.5 0x12 100 0x0A 3 100 0x13 125 0x0B 4 125 0x14 250 0x0C 5 250 0x15 500 0x0D 6 500 0x16 1000 0x0E 7 1000 0x17 - - Table 28. Sample Rate Values MEMSIC MC3419 APS-048-0071 v1.1 Page 45 of 78 Formal release date: 2020/07/13 12.6 (0X09) MOTION CONTROL REGISTER The motion control register enables the flags and interrupts for motion detection features. Addr 0x09 Name Description Bit 7 Bit 6 RAW_ MOTION_ MOTION_ Motion Control PROC_ CTRL RESET STAT Name TF_ENABLE MOTION_LATCH ANYM_EN SHAKE _EN TILT_35 _EN Z_AXIS_ORT RAW_PROC_STAT MOTION_RESET Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Z_AXIS_ TILT_35_ SHAKE_ MOTION_ TF_ ANYM_EN ORT EN EN LATCH ENABLE POR Value R/W 0x00 W Description Enable or disable the tilt/flip feature. Used with the tilt/flip features in registers 0x13, 0x14, and 0x06. 0: Tilt/Flip feature is disabled (default). 1: Tilt/Flip feature is enabled. If motion interrupts are used, this bit is generally not used. 0: Motion block does not latch outputs. 1: Motion block latches outputs. Enable or disable the AnyMotion feature. Used with the AnyMotion feature in registers 0x13, 0x14, and 0x06 and the shake and tilt-35 features in registers 0x14 and 0x06. 0: AnyMotion feature is disabled (default). 1: AnyMotion feature is enabled. Enable or disable the shake feature. Used with the shake feature in registers 0x13, 0x14, and 0x06. 0: Shake feature is disabled (default). 1: Shake feature is enabled. ANYM_EN must also be enabled. Enable or disable the tilt-35 feature. Used with tilt-35 feature in registers 0x13, 0x14, and 0x06. 0: Tilt-35 feature is disabled (default). 1: Tilt-35 feature is enabled. ANYM_EN must also be enabled. Z-axis orientation. 0: Z-axis orientation is positive through the top of the package (default). 1: Z-axis orientation is positive through the bottom of the package. Enable or disable filtering of motion data. 0: Motion flag bits are filtered by debounce and other settings (default). 1: Motion flag bits are real-time, raw data. Motion block reset. This bit is not automatically cleared. 0: The motion block is not in reset (default). 1: The motion block is held in reset. The software must set this bit for the reset to be cleared. Table 29. Motion Control Register MEMSIC MC3419 APS-048-0071 v1.1 Page 46 of 78 Formal release date: 2020/07/13 12.7 (0X0A) FIFO STATUS REGISTER Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 0x0A FIFO_STAT FIFO Status RESV RESV RESV RESV RESV Bit 2 Bit 1 Bit 0 FIFO_ FIFO_ FIFO_FULL THRESH EMPTY POR Value R/W 0x01 RO This register returns the current flags/status from the FIFO. These signals are not registered so the bits may transition unexpectedly at any time. The FIFO interrupt enable bits in register 0x2D do not affect these flags. Note that the FIFO_EMPTY flag is ‘1’ at boot or POR. Bit Name Description 0 FIFO_EMPTY 0: FIFO is not empty 1: FIFO is empty (default) This flag is valid if the FIFO is enabled or disabled. 1 FIFO_FULL 0: FIFO is not full (default) 1: FIFO is full This flag is valid if the FIFO is enabled or disabled. 2 FIFO_THRESH 0: FIFO threshold is less than threshold setting (default) 1: FIFO threshold is at or greater than threshold setting. The default threshold level is 16 or ½ of the 32 sample FIFO capacity. 7:3 RESV Reserved, returns ‘00000’ when read. Table 19: FIFO Status, 0x0A Register MEMSIC MC3419 APS-048-0071 v1.1 Page 47 of 78 Formal release date: 2020/07/13 12.8 (0X0B) FIFO READ POINTER REGISTER Addr Name Description Bit 7 Bit 6 0x0B FIFO_R_P FIFO Read Pointer RESV RESV Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ RD_PTR[5] RD_PTR[4] RD_PTR[3] RD_PTR[2] RD_PTR[1] RD_PTR[0] POR Value R/W 0x00 RO READ POINTER The FIFO read pointer is a 6-bit value that points to the current address of the read port on the FIFO. The actual address is bits 4:0 since the FIFO is limited to 32 locations. Bit 5 is used as “wrap” flag by hardware when comparing the read and write pointers. Bit Name Description 4:0 FIFO_RD_PTR[4:0] 00000 – default This is the current address the FIFO read pointer is accessing. The valid range is 0 to 31. 5 FIFO_RD_PTR[5] 0 -default This bit is used by hardware to manage the full/empty status of the FIFO. This is not a physical address bit. 7:6 RESV Reserved, returns ‘00’ when read. Table 12-30: FIFO read pointer, register 0x0B MEMSIC MC3419 APS-048-0071 v1.1 Page 48 of 78 Formal release date: 2020/07/13 12.9 (0X0C) FIFO WRITE POINTER REGISTER Addr 0x0C Name Description FIFO_W_P FIFO Write Pointer Bit 7 Bit 6 RESV RESV Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ FIFO_ WR_PTR[5] WR_PTR[4] WR_PTR[3] WR_PTR[2] WR_PTR[1] WR_PTR[0] POR Value R/W 0x00 RO The FIFO write pointer is a 6-bit value that points to the current address of the write port on the FIFO. The actual address is bits 4:0 since the FIFO is limited to 32 locations. Bit 5 is used as “wrap” flag by hardware when comparing the read and write pointers. This value will always be updated when a new valid sample is acquired (Z-axis data must be successfully acquired). Bit Name Description 4:0 FIFO_WR_PTR[4:0] 00000 – default This is the current address the FIFO write pointer is accessing. The valid range is 0 to 31. 5 FIFO_WR_PTR[5] 0 -default This bit is used by hardware to manage the full/empty status of the FIFO. This is not a physical address bit. 7:6 RESV Reserved, returns ‘00’ when read. Table 12-31: FIFO write pointer, register 0xC MEMSIC MC3419 APS-048-0071 v1.1 Page 49 of 78 Formal release date: 2020/07/13 12.10 (0X0D - 0X12) XOUT, YOUT AND ZOUT DATA ACCELEROMETER REGISTERS X, Y, and Z-axis accelerometer measurements are in 16-bit, signed 2’s complement format. Register addresses 0x0D to 0x12 hold the latest sampled data from the X, Y, and Z accelerometers. When the FIFO is enabled (register 0x2D bit 5), reading from address 0x0D supplies data from the FIFO instead of the output registers. During FIFO reads, software must start a read at address 0x0D and complete a read to address 0x12 for the FIFO pointers to increment correctly. Once an I2C start bit has been recognized by the device, registers will not be updated until an I2C stop bit has occurred. Therefore, if software desires to read the low and high byte registers ‘atomically’, knowing that the values have not been changed, it should do so by issuing a start bit, reading one register, then reading the other register then issuing a stop bit. Note that all 6 registers may be read in one burst with the same effect. Addr Name 0x0D XOUT_ EX_L 0x0E XOUT_ EX_H 0x0F YOUT_ EX_L 0x10 YOUT_ EX_L 0x11 ZOUT_ EX_L 0x12 ZOUT_ EX_H Description XOUT Accelerometer Data LSB XOUT Accelerometer Data MSB YOUT Accelerometer Data LSB YOUT Accelerometer Data MSB ZOUT Accelerometer Data LSB ZOUT Accelerometer Data MSB Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W XOUT_ EX[7] XOUT_ EX[6] XOUT_ EX[5] XOUT_ EX[4] XOUT_ EX[3] XOUT_ EX[2] XOUT_ EX[1] XOUT_ EX[0] 0x00 R XOUT_ EX[15] XOUT_ EX[14] XOUT_ EX[13] XOUT_ EX[12] XOUT_ EX[11] XOUT_ EX[10] XOUT_ EX[9] XOUT_ EX[8] 0x00 R YOUT_ EX[7] YOUT_ EX[6] YOUT_ EX[5] YOUT_ EX[4] YOUT_ EX[3] YOUT_ EX[2] YOUT_ EX[1] YOUT_ EX[0] 0x00 R YOUT_ EX[14] YOUT_ EX[13] YOUT_ EX[12] YOUT_ EX[11] YOUT_ EX[10] YOUT_ EX[9] YOUT_ EX[8] 0x00 R ZOUT_ EX[6] ZOUT_ EX[5] ZOUT_ EX[4] ZOUT_ EX[3] ZOUT_ EX[2] ZOUT_ EX[1] ZOUT_ EX[0] 0x00 R ZOUT_ EX[14] ZOUT_ EX[13] ZOUT_ EX[12] ZOUT_ EX[11] ZOUT_ EX[10] ZOUT_ EX[9] ZOUT_ EX[8] 0x00 R YOUT_ EX[15] ZOUT_ EX[7] ZOUT_ EX[15] Table 32. Accelerometer LSB and MSB Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 50 of 78 Formal release date: 2020/07/13 12.11 (0X13) STATUS REGISTER The status register contains the flag and status bits for sample acquisition and motion detection. Addr Name Description Bit 7 Bit 6 0x13 STATUS Status Register NEW_ DATA Resv Name TILT_FLAG FLIP_FLAG ANYM_FLAG SHAKE_FLAG TILT_35_FLAG FIFO_FLAG NEW_DATA Bit 5 Bit 4 FIFO_FLA TILT_35_ G FLAG Bit 3 SHAKE_ FLAG Bit 2 Bit 1 ANYM_ FLIP_FLAG FLAG Bit 0 POR Value R/W TILT_ FLAG 0x00 R Description This bit is active when the tilt feature in the motion control register (register 0x09, bit 0) is enabled. If polling is used, use the tilt interrupt in the interrupt status register (register 0x14, bit 0) instead because this bit can transition quickly. 0: Tilt condition is not detected. 1: Tilt condition is detected. This bit is active when the flip feature in the motion control register (register 0x09, bit 0) is enabled. If polling is used, use the flip interrupt in the interrupt status register (register 0x14, bit 1) instead because this bit can transition quickly. 0: Flip condition is not detected. 1: Flip condition is detected. This bit is active when the AnyMotion feature in the motion control register (register 0x09, bit 2) is enabled. If polling is used, use the AnyMotion interrupt in the interrupt status register (register 0x14, bit 2) instead because this bit can transition quickly. 0: AnyMotion condition is not detected. 1: AnyMotion condition is detected. This bit is active when the shake feature in the motion control register (register 0x09, bit 3) is enabled. If polling is used, use the shake interrupt in the interrupt status register (register 0x14, bit 3) instead because this bit can transition quickly. 0: Shake condition is not detected. 1: Shake condition is detected. This bit is active when the tilt-35 feature in the motion control register (register 0x09, bit 4) is enabled. If polling is used, use the tilt-35 interrupt in the interrupt status register (register 0x14, bit 4) instead because this bit can transition quickly. 0: Tilt-35 condition is not detected. 1: Tilt-35 condition is detected. This flag is an OR of the three FIFO flags from register 0x0A, FIFO_FULL, FIFO_THRESH, and FIFO_EMPTY. This bit is always active, only operates in WAKE mode, and is cleared and rearmed each time this register is read. This flag is set when XYZ data is written to registers 0x0D - 0x12. The host must poll this bit at the sample rate or faster to see this bit transition. 0: No data has been generated by the sensor since the last read. 1: Data has been acquired and written to the output registers (0x0D - 0x12). Table 33. Status Register MEMSIC MC3419 APS-048-0071 v1.1 Page 51 of 78 Formal release date: 2020/07/13 12.12 (0X14) INTERRUPT STATUS REGISTER The interrupt status register reports the status of any pending interrupt sources. Each interrupt source must be enabled by the corresponding interrupt enable bit in register 0x06. All interrupts are cleared each time this register is written (default). Individual interrupts may be cleared using a bitmask if the INDIV_INTR_CLR bit is set in the communications control register, address 0x31. Addr Name 0x14 INTR_ STAT Description Bit 7 Interrupt Status ACQ_INT Register Name TILT_INT FLIP_INT ANYM_INT SHAKE_INT TILT_35_INT FIFO_INT ACQ_INT Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Resv FIFO_INT TILT_35_ INT SHAKE_ INT ANYM_ INT Bit 1 Bit 0 FLIP_INT TILT_INT POR Value R/ W 0x00 RW Description This bit is active when the tilt feature in the interrupt enable register (register 0x06, bit 0) is enabled and the tilt/flip feature in the motion control register (register 0x09, bit 0) is enabled. 0: Tilt interrupt is not pending. 1: Tilt interrupt is pending. This bit is active when the flip feature in the interrupt enable register (register 0x06, bit 1) is enabled and the tilt/flip feature in the motion control register (register 0x09, bit 0) is enabled. 0: Flip interrupt is not pending. 1: Flip interrupt is pending. This bit is active when the AnyMotion feature in the interrupt enable register (register 0x06, bit 2) is enabled and the AnyMotion feature in the motion control register (register 0x09, bit 2) is enabled. 0: AnyMotion interrupt is not pending. 1: AnyMotion interrupt is pending. This bit is active when the shake feature in the interrupt enable register (register 0x06, bit 3) is enabled, the shake feature in the motion control register (register 0x09, bit 3) is enabled, and the AnyMotion feature in the motion control register (register 0x09, bit 2) is enabled. 0: Shake interrupt is not pending. 1: Shake interrupt is pending. This bit is active when the tilt-35 feature in the interrupt enable register (register 0x06, bit 4) is enabled, the tilt-35 feature in the motion control register (register 0x09, bit 4) is enabled, and the AnyMotion feature in the motion control register (register 0x09, bit 2) is enabled. 0: Tilt-35 interrupt is not pending. 1: Tilt-35 interrupt is pending. 0: FIFO_INTR interrupt is not pending. 1: FIFO_INTR interrupt is pending. This bit is an OR of the three FIFO interrupt flags from register 0x2F, FIFO_FULL_INTR, FIFO_THRESH_INTR, and FIFO_EMPTY_INTR. This bit only operates in WAKE mode. This bit is active when the interrupt feature in the interrupt enable register (register 0x06, bit 7) is enabled. 0: Sample interrupt is not pending. 1: Sample interrupt is pending. Table 34. Interrupt Status Register MEMSIC MC3419 APS-048-0071 v1.1 Page 52 of 78 Formal release date: 2020/07/13 12.13 (0X20) RANGE AND SCALE CONTROL REGISTER The range and scale control register sets the resolution, range, and filtering options for the accelerometer. All values are in sign-extended 2’s complement format. Values are reported in registers 0x0D – 0x12 (the hardware formats the output). Addr Name Description Bit 7 0x20 RANGE Range Select Control 01 1Software Bit 6 Bit 5 Bit 4 Bit 3 RANGE[2] RANGE[1] RANGE[0] LPF_EN Bit 2 Bit 1 Bit 0 LPF[2] LPF[1] LPF[0] POR R/W Value 0x00 W must write a zero (0) to bit 7. Name RANGE[2:0] LPF_EN LPF[2:0] Description Resolution range of the accelerometer, based on the current resolution. 000: ± 2g 001: ± 4g 010: ± 8g 011: ± 16g 100: ± 12g 101: Reserved. 110: Reserved. 111: Reserved. 0: Low pass Filter Disabled 1: Low Pass Filter Enabled 000: Reserved 001: Bandwidth setting 1, Fc = IDR / 4.255 010: Bandwidth setting 2, Fc = IDR / 6 011: Bandwidth setting 3, Fc = IDR / 12 100: Reserved 101: Bandwidth setting 5, Fc = IDR / 16 110: Reserved 111: Reserved Table 35. Range and Scale Control Register MEMSIC MC3419 APS-048-0071 v1.1 Page 53 of 78 Formal release date: 2020/07/13 12.14 (0X21 – 0X22) X-AXIS DIGITAL OFFSET REGISTERS The X-axis digital offset registers contain a signed 2’s complement 14-bit value used to offset the output of the X-axis filter. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x22 bit 7 is the ninth bit of X-axis gain (XGAIN). See X-Axis Digital Gain Registers for more information about XGAIN. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed. Addr Name 0x21 XOFFL 0x22 XOFFH Description X-Offset LSB X-Offset MSB Bit 0 POR R/W Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 XOFF[7] XOFF[6] XOFF[5] XOFF[4] XOFF[3] XOFF[2] XOFF[1] XOFF[0] Per chip W XGAIN[8] XOFF[14] XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] Per chip W Table 36. X-Axis Digital Offset Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 54 of 78 Formal release date: 2020/07/13 12.15 (0X23 – 0X24) Y-AXIS DIGITAL OFFSET REGISTERS The Y-axis digital offset registers contain a signed 2’s complement 14-bit value used to offset the output of the Y-axis filter. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x24 bit 7 is the ninth bit of Y-axis gain (YGAIN). See Y-Axis Digital Gain Registers for more information about YGAIN. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed. Addr Name 0x23 YOFFL 0x24 YOFFH Description Y-Offset LSB Y-Offset MSB POR R/W Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 YOFF[7] YOFF[6] YOFF[5] YOFF[4] YOFF[3] YOFF[2] YOFF[1] YOFF[0] Per chip W YGAIN[8] YOFF[14] YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] YOFF[8] Per chip W Table 37. Y-Axis Digital Offset Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 55 of 78 Formal release date: 2020/07/13 12.16 (0X25 – 0X26) Z-AXIS DIGITAL OFFSET REGISTERS The Z-axis digital offset registers contain a signed 2’s complement 14-bit value used to offset the output of the Z-axis filter. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x26 bit 7 is the ninth bit of Z-axis gain (ZGAIN). See Z-Axis Digital Gain Registers for more information about ZGAIN. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed. Addr Name 0x25 ZOFFL 0x26 ZOFFH Description Z-Offset LSB Z-Offset MSB POR R/W Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ZOFF[7] ZOFF[6] ZOFF[5] ZOFF[4] ZOFF[3] ZOFF[2] ZOFF[1] ZOFF[0] Per chip W ZGAIN[8] ZOFF[14] ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] ZOFF[8] Per chip W Table 38. Z-Axis Digital Offset Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 56 of 78 Formal release date: 2020/07/13 12.17 (0X22 & 0X27) X-AXIS DIGITAL GAIN REGISTERS The X-axis digital gain registers contain an unsigned 9-bit value. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x22 bit 7 is the ninth bit of XGAIN. NOTE: When modifying these registers with new gain values, software should perform a readmodify-write type of access to ensure that unrelated bits do not get changed. Addr Name Description 0x22 XOFFH X-Offset MSB 0x27 XGAIN X Gain Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 XGAIN[8] XOFF[14] XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] Bit 0 POR R/W Value XOFF[8] Per chip W XGAIN[7] XGAIN[6] XGAIN[5] XGAIN[4] XGAIN[3] XGAIN[2] XGAIN[1] XGAIN[0] Per chip W Table 39. X-Axis Digital Gain Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 57 of 78 Formal release date: 2020/07/13 12.18 (0X24 & 0X28) Y-AXIS DIGITAL GAIN REGISTERS The Y-axis digital gain registers contain an unsigned 9-bit value. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x24 bit 7 is the ninth bit of YGAIN. NOTE: When modifying these registers with new gain values, software should perform a readmodify-write type of access to ensure that unrelated bits do not get changed. Addr Name Description 0x24 YOFFH Y-Offset MSB 0x28 YGAIN Y Gain Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 YGAIN[8] YOFF[14] YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] Bit 0 YOFF[8] POR R/W Value Per chip W YGAIN[7] YGAIN[6] YGAIN[5] YGAIN[4] YGAIN[3] YGAIN[2] YGAIN[1] YGAIN[0] Per chip W Table 40. Y-Axis Digital Offset Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 58 of 78 Formal release date: 2020/07/13 12.19 (0X26 & 0X29) Z-AXIS DIGITAL GAIN REGISTERS The Z-axis digital gain registers contain an unsigned 9-bit value. These registers are loaded from the OTP at device initialization and POR. If necessary, these values can be overwritten by software. Register 0x26 bit 7 is the ninth bit of ZGAIN. NOTE: When modifying these registers with new gain values, software should perform a readmodify-write type of access to ensure that unrelated bits do not get changed. Addr Name Description 0x26 ZOFFH Z-Offset MSB 0x29 ZGAIN Z Gain Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 ZGAIN[8] ZOFF[14] ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] Bit 1 Bit 0 ZOFF[9] ZOFF[8] POR R/W Value Per chip W ZGAIN[7] ZGAIN[6] ZGAIN[5] ZGAIN[4] ZGAIN[3] ZGAIN[2] ZGAIN[1] ZGAIN[0] Per chip W Table 41. Z-Axis Digital Offset Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 59 of 78 Formal release date: 2020/07/13 12.20 (0X2D) FIFO CONTROL REGISTER This register controls the options for the MC3419 FIFO. This register was previously undefined in Mensa. Addr Name 0x2D FIFO_CTRL Bit Description Bit 7 Bit 6 FIFO Control Register 0 FIFO_ MODE Bit 5 Bit 4 FIFO_EN FIFO_RESET Bit 3 Bit 2 Bit 1 Bit 0 POR R/W Value FIFO_ COMB_INT FIFO_TH_ FIFO_FULL_ EMPTY_ _EN INT_EN INT_EN INT_EN 0x00 Name Function Description 0 FIFO_EMPTY_INT_EN FIFO empty interrupt enable 0: FIFO empty interrupt enable is disabled (default) 1: FIFO empty interrupt enable is enabled. 1 FIFO_FULL_INT_EN FIFO full interrupt enable 0: FIFO full interrupt enable is disabled (default) 1: FIFO full interrupt enable is enabled. 2 FIFO_TH_INT_EN FIFO threshold interrupt enable. 0: FIFO threshold interrupt enable is disabled (default) 1: FIFO full threshold enable is enabled. 3 COMB_INT_EN Combined interrupt enable 0: Motion/interrupt on sample interrupts are routed to INTN1, and FIFO interrupts are routed to INTN2. (default). 1: All interrupts are routed to INTN1. RW When the COMB_INT_EN bit is set, all interrupts requests are routed to INTN1, INTN2 becomes disabled. 4 FIFO_RESET FIFO reset control 0: FIFO is not reset (default) 1: FIFO is reset, read and write pointers are cleared. In a FIFO reset, the contents of the FIFO are not cleared, only the FIFO control logic, read and write pointers are reset. 5 FIFO_EN FIFO enable MEMSIC MC3419 APS-048-0071 v1.1 0: FIFO and FIFO operations are disabled (default) 1: FIFO and FIFO operations are enabled. Page 60 of 78 Formal release date: 2020/07/13 6 FIFO_MODE FIFO mode select 0: Normal operation, the FIFO continues to accept new sample data as long as there is space remaining (default) 1: Watermark (threshold) mode, once the amount of samples in the FIFO reaches or exceeds the threshold level, the FIFO stops accepting new sample data. Any additional sample data is “dropped”. 7 Reserved Reserved This bit must be ‘0’ for current FIFO operation. Table 42. FIFO Control bit assignments MEMSIC MC3419 APS-048-0071 v1.1 Page 61 of 78 Formal release date: 2020/07/13 12.21 (0X2E) FIFO THRESHOLD REGISTER Addr Name 0x2E FIFO_CTRL Description Bit 7 Bit 6 Bit 5 FIFO Threshold Register RESV RESV RESV Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FIFO_TH[4] FIFO_TH[3] FIFO_TH[2] FIFO_TH[1] FIFO_TH[0] POR R/W Value 0x10 RW FIFO THRESHOLD SETTING Register 0x2E holds the threshold or “watermark” level to apply to the number of samples in the FIFO. Note that the POR default of the level is 0x10 (decimal 16), or ½ of the total size of the FIFO. Bit Name Description 4:0 FIFO_TH[4:0] The FIFO threshold level selects the number of samples in the FIFO for different FIFO events. The threshold value may be 1 to 31 (00001 to 11111). 7:5 RESV Reserved, returns ‘0’ when read. Table 43. FIFO Threshold level bit assignments MEMSIC MC3419 APS-048-0071 v1.1 Page 62 of 78 Formal release date: 2020/07/13 12.22 (0X2F) FIFO INTERRUPT STATUS REGISTER Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 0x2E FIFO_ INTR FIFO Interrupt Status Register RESV RESV RESV RESV RESV Bit 2 Bit 1 Bit 0 FIFO_ FIFO_FULL_ FIFO_EMPT THRESH_ INT (RO) Y_INT (RO) INT (RO) POR Value R/W 0x00 R Register 0x2F reports the status of any pending FIFO interrupts. The corresponding FIFO interrupt enable bit must be enabled in register 0x2D for the interrupts to be detected. Bit 0 Name Function Description FIFO_EMPTY_INT (RO) FIFO Empty interrupt flag. 0: No FIFO empty interrupt is pending. 1: FIFO empty interrupt is pending. This read only bit reports the status of the FIFO empty interrupt. It requires register 0x2B bit 0 be enabled. 1 FIFO_FULL_ INT (RO) FIFO Full interrupt flag. 0: No FIFO full interrupt is pending. 1: FIFO full interrupt is pending. This read only bit reports the status of the FIFO full interrupt. It requires register 0x2B bit 1 be enabled. 2 7:3 FIFO_ THRESH_ INT (RO) FIFO Threshold interrupt flag. RESV (RO) Reserved 0: No FIFO threshold interrupt is pending. 1: FIFO threshold interrupt is pending. This read only bit reports the status of the FIFO threshold interrupt. It requires register 0x2B bit 2 be enabled. Reserved bits, returns ‘00000’ when read. Table 44. Interrupt status bit assignments MEMSIC MC3419 APS-048-0071 v1.1 Page 63 of 78 Formal release date: 2020/07/13 12.23 (0X30) FIFO CONTROL REGISTER2, SAMPLE RATE REGISTER 2 This register controls the behavior of the FIFO burst mode, and the hardware decimation feature of the MC3419. The hardware decimation feature divides the internal data rate (IDR) generated by the timebase module. Blocks at the end of signal acquisition pipeline may run at a slower output data rate (ODR). The FIFO, motion, and interrupt blocks operate at the decimated rate while the ADC and LPF filter operate at the higher internal rate. The hardware decimation feature is disabled by default and can be applied to any data rate generated by the settings in register 0x08. FIFO burst mode refers to the reading of multiple samples from the FIFO in the same transaction. FIFO_BURST must be set to ‘1’ any time SW intends to drain more than one sample in the same read cycle. It is not necessary to use FIFO_BURST mode for reading only one sample at a time (single 6, 7, or 8-byte sequence). Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 0x30 FIFO_CTRL 2_SR2 FIFO Control Register 2, Sample Rate 2 Register FIFO_ BURST_ MODE 0 Bit Name Function Description 3:0 DEC_MODE_ RATE[3:0] Decimation mode rate selection. 0000: Decimation mode disabled (default). 0001: Divide sample rate by 2 0010: Divide sample rate by 4 0011: Divide sample rate by 5 0100: Divide sample rate by 8 0101: Divide sample rate by 10 0110: Divide sample rate by 16 0111: Divide sample rate by 20 1000: Divide sample rate by 40 1001: Divide sample rate by 67 1010: Divide sample rate by 80 1011: Divide sample rate by 100 1100: Divide sample rate by 200 1101: Divide sample rate by 250 1110: Divide sample rate by 500 1111: Divide sample rate by 1000 SELECT_ ENABLE_ WRAP_ADD WRAP_N R Bit 3 Bit 2 Bit 1 Bit 0 POR Value DEC_MODE DEC_MODE DEC_MODE DEC_MODE 00000000 RATE[3] RATE[2] RATE[1] RATE[0] R/W RW When decimation mode is enabled, the internal data rate (IDR) is divided by the above factor to create a slower output data rate (ODR). The FIFO, motion block, output registers, and interrupts operate off the slower ODR when decimation mode is on. If decimation mode is disabled, then the IDR and ODR are the same value. MEMSIC MC3419 APS-048-0071 v1.1 Page 64 of 78 Formal release date: 2020/07/13 4 ENABLE_WRAP_N Enable/disable automatic address increment to internal register file. Applies to I2C and SPI operations. 0: Internal register address pointer will “wrap” at address selected by bit 5 (default). 1: Internal register address pointer will increment to the next consecutive value. 5 SELECT_WRAP_ ADDR Select the register address “wrap” value during burst operations. 0: Internal register address wraps from address 0x12 to 0x0D on read cycles. (default). 1: Internal register address wraps from address 0x14 to 0x0D on read cycles. This bit determines which register address triggers a “wrap” to register 0x0D (XOUT_LSB) during a read cycle. Address 0x12 is the MSB of the Z-axis data, and address 0x14 is the address of the interrupt data register. Setting this bit to a ‘1’ allows the contents of 0x13 (accel flag bits) and 0x14 (accel interrupt flags) to be included in a read cycle that includes XOUT[15:0], YOUT[15:0], ZOUT[15:0], STATUS[7:0], and INTR_STATUS[7:0]. 6 Reserved Reserved. This bit must be ‘0’ for correct FIFO operation. 7 FIFO_BURST Enable FIFO burst read operations. 0: FIFO read cycle reads a single 6 byte XYZ sample from the FIFO (default). 1: FIFO read cycle reads 2 or more 6-byte XYZ samples (up to 32) from the FIFO. The length of the burst read must be set in the Read Count register, 0x4B. Table 45. FIFO Control 2 bit assignments MEMSIC MC3419 APS-048-0071 v1.1 Page 65 of 78 Formal release date: 2020/07/13 12.24 (0X31) COMMUNICATION CONTROL REGISTER Addr 0x31 Name Description COMM_CTRL Comm. Control Register Bit 7 Resv Bit 6 Bit 5 Bit 4 INDIV_ SPI_3WIRE_ INT1_INT2_ INTR_CLR EN REQ_SWAP Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W 0 0 RESV RESV 0x00 RW Bit Name Function Description 0 RESV Reserved Reserved, returns ‘0’ when read. 1 RESV Reserved Reserved, returns ‘0’ when read. 2 RESV Reserved Reserved, this bit must be written to ‘0’ by software. 3 RESV Reserved Reserved, this bit must be written to ‘0’ by software. 4 INT1_INT2_REQ_S WAP Swap INT1 and INT2 pin functionality. 0: INT1 requests are routed to the INTN1 pin, INT2 requests are routed to the INTN2 pin (default). 1: INT1 requests are routed to the INTN2 pin, INT2 requests are routed to the INTN1 pin. 5 SPI_3WIRE_EN Enable SPI 3-wire mode. 0: SPI 3-wire more is disabled (default). 1: SPI 3-wire mode is enabled When this bit is enabled, the DOUT_A6 pin becomes a bi-directional data pin. SPI MISO and MOSI is applied to the DOUT_A6 pin. Note that it is possible to simply tie the DIN_SDA and DOUT_A6 pins together to enable 3-wire mode without using this bit. 6 INDIV_INTR_CLR Enable individual interrupt mode. 0: Individual interrupt clear mode is disabled. All interrupts are cleared by writing to register 0x14, contents of write cycle do not matter. (default). 1: Individual interrupt clear mode is enabled. Individual interrupts are cleared by writing to register 0x14 as a bitmask. Each bit of register 0x14 controls a corresponding interrupt service/clear bit. 7 Reserved Reserved This bit must be ‘0’ for proper device operation. Table 46. Communication Control bit assignments MEMSIC MC3419 APS-048-0071 v1.1 Page 66 of 78 Formal release date: 2020/07/13 12.25 (0X33) GPIO CONTROL REGISTER This register is used to select the INTN1 pin and INTN2 pin polarity and drive mode when the pins are used as interrupt request outputs. Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W 0x33 GPIO_ CTRL GPIO Control Register INTN2_ IPP INTN2_IAH RESV RESV INTN1_ IPP INTN1_IAH RESV RESV 0x00 W Bit Name Function Description 1:0 Reserved Reserved Reserved 0: The INTN1 pin is active low. 1: The INTN1 pin is active high. 2 3 5:4 GPIO1_INTN1_IAH GPIO1_INTN1_IPP Reserved Set polarity of INTN1 output. Select open drain or push/pull mode for INTN1. Reserved This bit sets the polarity level of the INTN1 pin. This bit is used in interrupt mode to set the level of the interrupt request. 0: The INTN1 pin operates in open-drain mode as an output. 1: The INTN1 pin operates in push-pull mode as an output. This bit sets the drive mode of the INTN1 pin as an interrupt request output. Open drain mode requires an external pullup resistor. Reserved 0: The INTN2 pin is active low. 1: The INTN2 pin is active high. 6 7 GPIO2_INTN2_IAH GPIO2_INTN2_IPP Set polarity of INTN2 output. Select open drain or push/pull mode for INTN2. This bit sets the polarity level of the INTN2 pin. This bit is used in interrupt mode to set the level of the interrupt request, or in GPIO mode to set the level of the GPIO output drive. 0: The INTN2 pin operates in open-drain mode as an output. 1: The INTN2 pin operates in push-pull mode as an output. This bit sets the drive mode of the INTN2 pin as an interrupt request output. Open drain mode requires an external pullup resistor. Table 47. GPIO Control Register MEMSIC MC3419 APS-048-0071 v1.1 Page 67 of 78 Formal release date: 2020/07/13 12.26 (0X40 – 0X41) TILT/FLIP THRESHOLD REGISTERS The tilt/flip threshold registers are used for both the flat/tilt/flip and tilt-35 algorithms. For the flat/tilt/flip algorithm, these registers hold the programmed 15-bit threshold value to detect the flat/tilt/flip position of the device. If the sample value is greater than the programmed value of these registers, a tilt condition is detected. If the sample value is less than the programmed value of these registers, a flat/flip condition is detected. A flat/flip condition is dependent on the Z-axis value and the Z-axis orientation bit (register 0x09, bit 5). For the tilt-35 algorithm, these registers hold the programmed 15-bit threshold value that defines the amount of tilt to detect. When the programmed tilt is detected, the tilt-35 interrupt is set in the interrupt status registers (register 0x14, bit 4). Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TF_ Tilt/Flip TF_ 0x40 THRESH_ TF_THR[7] TF_THR[6] TF_THR[5] TF_THR[4] TF_THR[3] TF_THR[2] TF_THR[1] Threshold LSB THR[0] LSB TF_ Tilt/Flip TF_ TF_ TF_ TF_ TF_ TF_ 0x41 THRESH_ Resv TF_THR[9] Threshold MSB THR[14] THR[13] THR[12] THR[11] THR[10] THR[8] MSB POR R/W Value 0x00 W 0x00 W Table 48. Tilt/Flip Threshold Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 68 of 78 Formal release date: 2020/07/13 12.27 (0X42) TILT/FLIP DEBOUNCE REGISTER The tilt/flip debounce register holds the programmed 8-bit duration of a tilt/flip. When a tilt/flip condition is detected and the duration of the condition is greater than the programmed value of this register, the tilt/flip interrupt is set in the interrupt status registers (register 0x14, bits 0 and 1). Addr Name Description 0x42 TF_DB Tilt/Flip Debounce Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TF_DB[7] TF_DB[6] TF_DB[5] TF_DB[4] TF_DB[3] TF_DB[2] TF_DB[1] TF_DB[0] POR R/W Value 0x00 W Table 49. Tilt/Flip Debounce Register MEMSIC MC3419 APS-048-0071 v1.1 Page 69 of 78 Formal release date: 2020/07/13 12.28 (0X43 – 0X44) ANYMOTION THRESHOLD REGISTERS The Anymotion threshold registers hold the programmed 15-bit threshold value to detect a change in the position of the device. If the change in position between the current sample value and previous sample value on any axis is greater than the programmed value of this register, an AnyMotion condition is detected. When the change in position exceeds the programmed AnyMotion threshold, the AnyMotion interrupt is set in the interrupt status registers (register 0x14, bit 2). Addr Name Description AM_ AnyMotion 0x43 THRESH_ Threshold LSB LSB AM_ AnyMotion 0x44 THRESH_ Threshold MSB MSB POR R/W Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 ANYM_ THR[7] ANYM_ THR[6] ANYM_ THR[5] ANYM_ THR[4] ANYM_ THR[3] ANYM_ THR[2] ANYM_ THR[1] ANYM_ THR[0] 0x00 W Resv ANYM_ THR[14] ANYM_ THR[13] ANYM_ THR[12] ANYM_ THR[11] ANYM_ THR[10] ANYM_ THR[9] ANYM_ THR[8] 0x00 W Table 50. AnyMotion Threshold Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 70 of 78 Formal release date: 2020/07/13 12.29 (0X45) ANYMOTION DEBOUNCE REGISTER The AnyMotion debounce register holds the programmed 8-bit duration of any motion. After an AnyMotion condition is detected, if another AnyMotion condition is not detected for the programmed duration, the AnyMotion interrupt is cleared in the interrupt status registers (register 0x14, bits 0 and 1). Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0x45 AM_DB AnyMotion Debounce ANYM_ DB[7] ANYM_ DB[6] ANYM_ DB[5] ANYM_ DB[4] ANYM_ DB[3] ANYM_ DB[2] ANYM_ DB[1] ANYM_ DB[0] POR R/W Value 0x00 W Table 51. AnyMotion Debounce Register MEMSIC MC3419 APS-048-0071 v1.1 Page 71 of 78 Formal release date: 2020/07/13 12.30 (0X46 – 0X47) SHAKE THRESHOLD REGISTERS The shake threshold registers hold the programmed 15-bit threshold value to detect a shake. If the change in position between the current sample value and previous sample value on any axis is greater than the programmed value of this register, a shake condition is detected. Addr Name Description SHK_ Shake Threshold 0x46 THRESH_ LSB LSB SHK_ Shake Threshold 0x47 THRESH_ MSB MSB POR R/W Value Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SH _ THR[7] SH _ THR[6] SH _ THR[5] SH _ THR[4] SH _ THR[3] SH _ THR[2] SH _ THR[1] SH _ THR[0] 0x00 W SH_ THR[15] SH _ THR[14] SH _ THR[13] SH _ THR[12] SH _ THR[11] SH _ THR[10] SH _ THR[9] SH _ THR[8] 0x00 W Table 52. Shake Threshold Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 72 of 78 Formal release date: 2020/07/13 12.31 (0X48 – 0X49) SHAKE DURATION, PEAK-TO-PEAK REGISTERS The shake duration and peak-to-peak registers hold the programmed 12-bit threshold value of a peak and the peak-to-peak width of a shake and the programmed 3-bit threshold value of the shake counter. The data in these registers and the shake threshold registers is used to determine if the shake interrupt should be set. If a shake condition is detected, the shake counter is incremented and the shake’s peak is detected and measured. If the peak’s width is greater than the peak threshold set in this register, the shake counter continues to increment (measuring the duration of the peak event). When a shake condition is no longer detected, the peak-to-peak event is measured and the shake counter continues to increment (measuring the duration of the peak-to-peak event). When the peak-to-peak threshold is surpassed, the shake counter continues to increment, measuring the duration of the peak event. The shake counter continues to increment each time a peak or peak-to-peak threshold is surpassed. When the shake counter threshold is surpassed, the shake interrupt is set in the interrupt status registers (register 0x14, bit 3). Addr Name Description Bit 7 Bit 6 Bit 5 Bit 4 PK_P2P_ DUR_ Peak-to-Peak PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ 0x48 THRESH_ Duration LSB DUR[7] DUR[6] DUR[5] DUR[4] LSB PK_P2P_ Shake Duration DUR_ SHK_CNT_ SHK_CNT_ SHK_CNT_ 0x49 and Peak-to-Peak Resv THRESH_ DUR[2] DUR[1] DUR[0] Duration MSB MSB Bit 3 Bit 2 Bit 1 Bit 0 POR R/W Value PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ DUR[3] DUR[2] DUR[1] DUR[0] 0x00 W PK_P2P_ PK_P2P_ PK_P2P_ PK_P2P_ DUR[11] DUR[10] DUR[9] DUR[8] 0x00 W Table 53. Shake Duration and Peak-to-Peak Registers MEMSIC MC3419 APS-048-0071 v1.1 Page 73 of 78 Formal release date: 2020/07/13 12.32 (0X4A) TIMER CONTROL REGISTER The timer control register sets the period or duration of two features driven by the 10 Hz low speed clock. Addr Name Description 0x4A TIMER_ CTRL Timer Control Bit 7 Bit 6 Bit 5 Bit 4 TEMP_ TEMP_ TEMP_ TEMP_ PER_INT_ PERIOD[2] PERIOD[1] PERIOD[0] EN Bit 3 Bit 2 Bit 1 Bit 0 POR R/W Value Resv TILT_ 35[2] TILT_35[1] TILT_ 35[0] 0x00 W Name Description Duration of a valid tilt-35 angle detection. 000: 1.6 s (default) 001: 1.8 s 010: 2.0 s 011: 2.2 s TILT_35[2:0] 100: 2.4 s 101: 2.6 s 110: 2.8 s 111: 3.0 s Timeout or re-arm time for the temporary latch on the TEST_INT pin. 000: 200 ms (default) 001: 400 ms 010: 800 ms TEMP_PERIOD[2:0] 011: 1600 ms 100: 3200 ms 101: 6400 ms 110: Reserved 111: Reserved Temporary latch. TEMP_PER_INT_EN 0: The temporary latch feature is disabled (default). 1: The temporary latch feature is enabled. Table 54. Timer Control Register MEMSIC MC3419 APS-048-0071 v1.1 Page 74 of 78 Formal release date: 2020/07/13 12.33 (0X4B) READ COUNT REGISTER The read count register (0x4B) sets length of FIFO burst read transactions. Addr Name Description 0x4B RD_CNT Read Count Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 RD_CNT[7] RD_CNT[6] RD_CNT[5] RD_CNT[4] RD_CNT[3] RD_CNT[2] RD_CNT[1] RD_CNT[0] POR R/W Value 0x06 RW Bit Name Function Description 7:0 RD_CNT[7:0] Sample count to be 0x06: POR value (default) used during I2C/SPI If register 0x30 bit 7 (FIFO_BURST) is enabled, this read cycles. register is the number of samples to be read in single burst read transaction. A sample is one 6-byte sample from the FIFO and optionally one or two status bytes from registers 0x13 and 0x14 (a sample can be 6, 7, or 8-bytes long). Note this parameter is a sample count, not a byte count. If FIFO burst mode is disabled, this parameter is not used. Table 55. Read Count Register MEMSIC MC3419 APS-048-0071 v1.1 Page 75 of 78 Formal release date: 2020/07/13 13 INDEX OF TABLES Table 1. Order Information.........................................................................................................................................5 Table 2. Package Information .....................................................................................................................................5 Table 3. Pin Description ..............................................................................................................................................9 Table 4. Absolute Maximum Ratings ....................................................................................................................... 16 Table 5. Sensor Characteristics................................................................................................................................ 17 Table 6. Electrical Characteristics ............................................................................................................................ 18 Table 7. Electrical and Timing Characteristics - Interface ....................................................................................... 19 Table 8. I2C Timing Characteristics.......................................................................................................................... 20 Table 9. SPI Interface Timing Parameters ............................................................................................................... 21 Table 10. Summary of Resolution, Range, and Scaling ........................................................................................... 22 Table 11. Operational States ................................................................................................................................... 23 Table 12. Forcing Operational States ...................................................................................................................... 24 Table 13. Interrupt Overview .................................................................................................................................. 25 Table 14. Interrupt servicing details (Motion + Sample) ......................................................................................... 29 Table 15. Interrupt servicing details (FIFO) ............................................................................................................. 29 Table 16. GPIO Control Register .............................................................................................................................. 30 Table 17. Interrupt drive and polarity control......................................................................................................... 30 Table 18. Swapping Interrupt Requests, register 0x31 bit 4 ................................................................................... 31 Table 19. Combining interrupt requests, register 0x2D bit 3 .................................................................................. 31 Table 20. Sample Rate Settings ............................................................................................................................... 32 Table 21. Hardware Decimation Ratios ................................................................................................................... 33 Table 22. I2C Address Selection .............................................................................................................................. 34 Table 23. Register Summary .................................................................................................................................... 41 Table 24. Device Status Register ............................................................................................................................. 42 Table 25. Interrupt Enable Register......................................................................................................................... 43 Table 26. Mode Register States ............................................................................................................................... 44 Table 27. Sample Rate Register ............................................................................................................................... 45 Table 28. Sample Rate Values ................................................................................................................................. 45 Table 29. Motion Control Register .......................................................................................................................... 46 Table 12-30: FIFO read pointer, register 0x0B ........................................................................................................ 48 Table 12-31: FIFO write pointer, register 0xC ......................................................................................................... 49 Table 32. Accelerometer LSB and MSB Registers .................................................................................................... 50 MEMSIC MC3419 APS-048-0071 v1.1 Page 76 of 78 Formal release date: 2020/07/13 Table 33. Status Register ......................................................................................................................................... 51 Table 34. Interrupt Status Register ......................................................................................................................... 52 Table 35. Range and Scale Control Register ............................................................................................................ 53 Table 36. X-Axis Digital Offset Registers .................................................................................................................. 54 Table 37. Y-Axis Digital Offset Registers .................................................................................................................. 55 Table 38. Z-Axis Digital Offset Registers .................................................................................................................. 56 Table 39. X-Axis Digital Gain Registers .................................................................................................................... 57 Table 40. Y-Axis Digital Offset Registers .................................................................................................................. 58 Table 41. Z-Axis Digital Offset Registers .................................................................................................................. 59 Table 42. FIFO Control bit assignments ................................................................................................................... 61 Table 43. FIFO Threshold level bit assignments ...................................................................................................... 62 Table 44. Interrupt status bit assignments .............................................................................................................. 63 Table 45. FIFO Control 2 bit assignments ................................................................................................................ 65 Table 46. Communication Control bit assignments ................................................................................................ 66 Table 47. GPIO Control Register .............................................................................................................................. 67 Table 48. Tilt/Flip Threshold Registers .................................................................................................................... 68 Table 49. Tilt/Flip Debounce Register ..................................................................................................................... 69 Table 50. AnyMotion Threshold Registers .............................................................................................................. 70 Table 51. AnyMotion Debounce Register................................................................................................................ 71 Table 52. Shake Threshold Registers ....................................................................................................................... 72 Table 53. Shake Duration and Peak-to-Peak Registers ........................................................................................... 73 Table 54. Timer Control Register ............................................................................................................................. 74 Table 55. Read Count Register ................................................................................................................................ 75 MEMSIC MC3419 APS-048-0071 v1.1 Page 77 of 78 Formal release date: 2020/07/13 14 REVISION HISTORY Date 2019-05 2019-06 2020-0713 Revision APS-048-0071v1.0 APS-048-0071v1.01 APS-048-0071v1.1 MEMSIC MC3419 APS-048-0071 v1.1 Description Initial release Fixed a few formatting issues Change to MEMSIC format based on the License Agreement with mCube Page 78 of 78 Formal release date: 2020/07/13
MC3419 价格&库存
很抱歉,暂时无法提供与“MC3419”相匹配的价格&库存,您可以联系我们找货
