Technical Data 11108
Effective November 2021
Supersedes June 2020
MFBW1V2012
Multilayer chip ferrite bead
Applications
• Industrial connectivity (IoT)
• Wireless communications
• Bluetooth
• WiFi
• Antenna
• Machine-to-machine (M2M)
• Mobile phones
Product features
• Wearable devices
0805 (2012 metric) package
• Wireless LAN
High impedance values
• Computing/gaming consoles
Multilayer monolithic construction yields high
reliability
• Broadband components
Impedance range from 0 Ω to 2000 Ω
• RF transceiver modules
Environmental compliance
and general specifications
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MFBW1V2012
Product specifications
Part number3
Impedance
tolerance
Impedance
(Ω)
DCR (Ω) maximum
@ +25 °C
Test frequency1
(MHz)
Test voltage1
(mV)
Rated current2
(mA)
maximum
MFBW1V2012-000-R
0~15 Ω
100
50
3000
MFBW1V2012-050-R
0~15 Ω
5
0.03
100
50
3000
MFBW1V2012-070-R
0~11 Ω
7
0.03
100
50
3000
MFBW1V2012-090-R
5~13 Ω
9
0.03
100
50
3000
MFBW1V2012-110-R
7~15 Ω
11
0.03
100
50
3000
MFBW1V2012-150-R
9~21 Ω
15
0.03
100
50
3000
MFBW1V2012-190-R
12~25 Ω
19
0.03
100
50
3000
MFBW1V2012-300-R
±25%
30
0.05
100
50
3000
MFBW1V2012-310-R
±25%
31
0.05
100
50
3000
MFBW1V2012-360-R
±25%
36
0.06
100
50
3000
MFBW1V2012-600-R
±25%
60
0.06
100
50
3000
MFBW1V2012-700-R
±25%
70
0.08
100
50
2500
MFBW1V2012-800-R
±25%
80
0.08
100
50
2500
MFBW1V2012-101-R
±25%
100
0.10
100
50
2500
MFBW1V2012-121-R
±25%
120
0.10
100
50
2000
MFBW1V2012-151-R
±25%
150
0.10
100
50
2000
MFBW1V2012-181-R
±25%
180
0.15
100
50
2000
MFBW1V2012-201-R
±25%
200
0.15
100
50
2000
MFBW1V2012-221-R
±25%
220
0.15
100
50
2000
MFBW1V2012-301-R
±25%
300
0.20
100
50
2000
MFBW1V2012-501-R
±25%
500
0.25
100
50
1500
MFBW1V2012-601-R
±25%
600
0.25
100
50
1500
MFBW1V2012-801-R
±25%
800
0.30
100
50
800
MFBW1V2012-102-R
±25%
1000
0.30
100
50
800
MFBW1V2012-122-R
±25%
1200
0.45
100
50
500
MFBW1V2012-152-R
±25%
1500
0.50
100
50
300
MFBW1V2012-202-R
±25%
2000
0.50
100
50
300
1. Impedance test frequency and voltage.
2. Rated current: Current rating for an approximate self-temperature rise of 40 °C or less.
2
www.eaton.com/electronics
3. Part number definition: MFBW1V2012-xxx-R
MFBW1V2012 = Product code and size
xxx = Impedance value in Ω, last character equals number of zeros
-R suffix = RoHS compliant
MFBW1V2012
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
a (2plcs)
Part number
L
W
T
a
F
G
H
MFBW1V2012-xxx-R
2.0 ±0.20
1.2 ±0.20
0.9 ±0.20
0.5 ±0.3
1.60 ref
0.20 ref
1.20 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.2
4.00
P2±0.1
2.00
D0±0.1
1.55
A0
1.5±0.2
B0
2.3±0.2
T
0.95±0.1
T1 Max
na
3
MFBW1V2012
Qualification testing
No.
Test item
Sample size (pcs)
Test condition
Acceptable value/range
1
External visual
72
Specification
No physical damage
2
Physical dimension
72
Specification
Specification
3
Initial electrical test
72
Specification
User specification
4
Solderability
6
+245 °C ±5 °C, dipping 5 ±1s
>95% solder coverage
5
Resistance to soldering heat
6
+260 ±5 °C for 10 ±1 s
1. ΔZ/Z
很抱歉,暂时无法提供与“MFBW1V2012-152-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.884081+0.11460
- 10+0.3610910+0.04681
- 100+0.29505100+0.03825
- 1000+0.242681000+0.03146
- 国内价格 香港价格
- 4000+0.230834000+0.02992
- 8000+0.217648000+0.02821
- 12000+0.2102812000+0.02726
- 20000+0.2013520000+0.02610
- 28000+0.1956928000+0.02537
- 40000+0.1898640000+0.02461
