TSS-SOD123 Series
Thyristor Surge protector
TSS-SOD123
ROHS
Features
◆ Bi-directional crowbar transient voltage protection
◆ High surge capability
◆ High off-state impedance
◆ Low leakage current
◆ Low on-state voltage
◆ Short-circuit failure mode
Main Application
BORN’s thyristor surge protector devices are designed to help protect sensitive telecommunication
equipment from the hazards caused by lighning ,power contact,and power induction. These devices
enable equipment to comply with various regulatory requirements including GR 1089,ITU
K.20,K.21and K.45,IEC 60950,UL 60950,and TIA-968-A(formerly known as FCC Part 68).
Typical application including:
● Central office switching equipment. Analog and digital linecards(xDSL,T1/E1,ISDN……)
● Customer Premises Equipment(CPE)such as phones, fax machines,modems,POS terminals,
PBX systems and caller ID adjunct boxes.
Primary protection modules including Main Distribution Frames(MDF),building
entrance equipment and station protection modules.
Access
network
equipment
such
as
remote
terminals,line
repeaters,multiplexers,cross-connects,WAN
equipment,Network
Interface
Devices(NID).
Data lines and security systems.
CATV line amplifiers and power inserters.
Sprinkler systems.
Electrcal Parameters (Tamb=25℃)
Part
Number
BEP0080MA
1/4
VDRM
IDRM
VBO
IBO
VT
IT
CO
`IH
Min.
Max.
Max.
Max.
Max.
Max.
Max.
Min.
V
uA
V
mA
V
A
pF
mA
6
5
25
800
4
2.2
50
50
TSS-SOD123 Series
TSS-SOD123
ROHS
Eletrical Characteristics
VDRM
Stand-off voltage,is measured at IDRM
IH
Holding current.
VBO
Breakover voltage,is measured at 100V/μs.
IBO
Breadover current.
CO
Off-state capacitance ismeasured in VDC=2V@1MHZ.
IT
ON-state current
VT
On-state voltage.
IDRM Leakage current,is measured at VDRM.
Part Numbering System
BEP
0080
M
A
(A)
(B)
(C)
(D)
(A) BORN’s Semiconductor Surge Arrester
(B) Series:0080
(C) Pake:SOD123
(D) Rating Sure Voltage:A:2KV(10/700μs)
2/4
TSS-SOD123 Series
TSS-SOD123
ROHS
Electrical Characteristics Curves
Figure1 V-I Characteristics
Figure2 tr x td Pulse Wave-form
Figure 3 Normalized VS Change versus
Junction Temperature
Figure 4 Normalized DC Holding Current
Thermal Considerations
Package
3/4
SOD123
Symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature
-40 to +150
TS
Storage Temperature Range
-40 to +150
RθJA
Junction to Ambient on printed circuit
90
℃/W
TSS-SOD123 Series
TSS-SOD123
ROHS
Solder Reflow Recommendations
●Recommended reflow methods: IR, vapor
phase oven, hot air oven, wave solder.
●The device can be exposed to a maximum
temperature of 265°C for 10 seconds.
●Devices can be cleaned using standard
industry methods and solvents.
Notes: If reflow temperatures exceed the
recommended
profile,
devices may
not meet the performance requirements.
Product Dimensions
Cathode Band
T op View
1.8 ± 0.1
1.0± 0.2
2.8± 0.1
5
0.05 - 0.30
0.98 ± 0.1
5
Z
0.60± 0.25
DetailZ
enlarged
0.00 - 0.10
3.7± 0.2
17247
Mounting Pad Layout
C
A
B
H
D
F
4/4
17248
1.6
1.2
A
0.049
0.065
1.250
1.650
B
0.157
0.177
3.990
4.500
C
0.100
0.110
2.540
2.790
D
0.078
0.090
1.980
2.290
E 1.2
F
0.030
0.060
0.780
1.520
0.008
0.203
G
0.194
0.208
4.930
5.280
H
0.006
0.012
0.152
0.305
很抱歉,暂时无法提供与“BEP0080MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36537
- 100+0.29279
- 300+0.25650
- 3000+0.22929
- 6000+0.20747
- 9000+0.19656
- 国内价格
- 1+0.35640
- 200+0.22990
- 1500+0.20020
- 3000+0.17600
- 国内价格
- 10+0.33492
- 100+0.26839
- 600+0.23512
- 1200+0.23159
