A16-300
A16-300
    JDTFUSE(集电通)
    FUSE_9X3MM_TM
    PTC自恢复保险丝 Vmax=16V Imax=40A Pd=2.3W Ih=3A It=5.1A
A16-300 数据手册
PRODUCT DATASHEET A16 Series PTC Devices A16 Series PTC Devices Description JDTFUSE A16 Series Radial Leaded PTCs are designed to provide resettable overcurrent protection serving a wide range of electronics applications. With maximum 16 voltage and maximum 40-ampere short circuit rating,they offer an ideal solution for USB protection. Features ● 100A short circuit rating ● 16V Operating voltages ● Fast time-to-trip ● Meets all USB protection requirements ● RoHS compliant, Lead-Free and Halogen-Free* Agency Approvals Agency Applications File Number E472196 Regulation ● Computers & peripherals ● Any USB applications ● Motor protection ● General Electronics Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/6 Revised 22/03/19 A16 Series PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Pd @25°C (A) @25°C (A) Typ. (W) Maximum Time To Trip Current (A) Time (Sec) Resistance R i min R i max R1max (Ω) (Ω) (Ω) A16-030 16 40 0.30 0.60 0.30 1.50 1.00 0.300 0.900 1.300 A16-050 16 40 0.50 1.00 0.40 2.50 1.10 0.200 0.500 0.760 A16-065 16 40 0.65 1.30 0.60 3.25 5.00 0.120 0.480 0.650 A16-075 16 40 0.75 1.50 0.30 3.75 4.80 0.100 0.320 0.400 A16-090 16 40 0.90 1.80 0.60 4.50 1.20 0.090 0.180 0.250 A16-110 16 40 1.10 2.20 0.70 5.50 2.30 0.060 0.150 0.240 A16-120 16 40 1.20 2.40 0.60 6.00 5.50 0.050 0.180 0.240 A16-135 16 40 1.35 2.70 0.80 6.75 4.50 0.040 0.130 0.190 A16-160 16 40 1.60 3.20 0.90 8.00 9.00 0.030 0.110 0.200 A16-185 16 40 1.85 3.70 1.00 9.25 10.0 0.030 0.100 0.160 A16-250 16 40 2.50 5.00 1.30 7.50 15·.0 0.020 0.070 0.120 A16-300 16 40 3.00 5.10 2.30 15.0 2.00 0.020 0.070 0.110 A16-400 16 40 4.00 6.80 2.40 20.0 3.50 0.020 0.040 0.080 A16-500 16 40 5.00 8.50 2.60 25.0 3.60 0.014 0.025 0.033 A16-600 16 40 6.00 10.20 2.80 30.0 5.80 0.001 0.021 0.031 A16-700 16 40 7.00 11.90 3.00 35.0 8.00 0.008 0.015 0.022 A16-800 16 40 8.00 13.60 3.00 40.0 9.00 0.006 0.013 0.021 A16-900 16 40 9.00 15.30 3.30 45.0 12.0 0.004 0.012 0.018 A16-1000 16 40 10.00 17.00 3.60 50.0 12.5 0.004 0.011 0.015 A16-1100 16 40 11.00 18.70 3.70 55.0 13.5 0.003 0.009 0.013 A16-1200 16 40 12.00 20.40 4.20 60.0 16.0 0.003 0.008 0.012 A16-1400 16 40 14.00 23.80 4.60 70.0 20.0 0.003 0.007 0.011 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Pd Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Test Resistance change Passive aging     +85°C, 1000 hrs. ±5% typical Humidity aging     +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock     +85°C to -40°C, 20 times ±33% typical Resistance to solvent     MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change Vibration     Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/6 Revised 22/03/19 A16 Series PTC Devices Thermal Derating Curve Derating Curves for A16 Series 1.8 Percentage of Rated Current 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Temperature (°C ) Average Time-Current Curve A=A16-030 B=A16-050 C=A16-065 D=A16-075 E=A16-090 F=A16-110 G=A16-120 H=A16-135 I=A16-160 J=A16-185 K=A16-250 L=A16-300 M=A16-400 N=A16-500 O=A16-600 P=A16-700 Q=A16-800 R=A16-900 S=A16-1000 T=A16-1100 U=A16-1200 V=A16-1400 JDT FUSE Industrial Corp. www.jdtfuse.com A B C D E FGH I J K L MNO PQR STUV Page 3/6 Revised 22/03/19 A16 Series PTC Devices Soldering Parameters Temperature (°C ) TP 260 Pre-Heating 1 Minute Min. Soldering 5Sea.MAX Gradual Cooling 100 Time 25 WAVE SOLDERING INFORMATIONS Pre-Heating Zone Max.ramping rate should not exceed 4℃/Sec. Soldeing Zone Max.solder temperature should not exceed 260℃ Cooling Zone Cooling by natural convection in air. ◎Specifications are subject to change without notice JDT FUSE Industrial Corp. www.jdtfuse.com Page 4/6 Revised 22/03/19 A16 Series PTC Devices Physical Dimensions(mm.) FIG A B C D E Max. Max. Max. Max. Max. A16-030 5.50 13.0 5.10 7.60 3.1 1 A16-050 5.50 12.0 5.10 7.60 3.0 1 A16-065 6.90 12.0 5.10 7.60 3.0 1 A16-075 7.40 13.0 5.10 7.60 3.0 1 A16-090 7.40 13.0 5.10 7.60 3.0 2 A16-110 7.40 14.4 5.10 7.60 3.0 1 A16-120 7.40 14.4 5.10 7.60 3.0 2 A16-135 8.90 15.9 5.10 7.60 3.0 2 A16-160 8.90 16.7 5.10 7.60 3.0 2 A16-185 10.7 17.7 5.10 7.60 3.0 2 A16-250 9.00 14.0 5.10 7.60 3.0 2 A16-300 9.00 12.0 5.10 7.60 3.0 3 A16-400 10.0 13.0 5.10 7.60 3.0 3 A16-500 10.7 17.5 5.10 7.60 3.0 3 A16-600 13.5 17.5 5.10 7.60 3.0 3 A16-700 13.5 23.0 5.10 7.60 3.0 3 A16-800 13.5 23.0 5.10 7.60 3.0 3 A16-900 15.0 24.0 5.10 7.60 3.0 3 A16-1000 18.0 26.0 5.10 7.60 3.0 3 A16-1100 18.0 26.0 5.10 7.60 3.0 3 A16-1200 22.5 28.0 5.10 7.60 3.5 3 A16-1400 24.5 30.0 10.2 7.60 3.5 3 Model PHYSICAL SPECIFICATIONS : Materials : Leads A16-030 ~ 250: Tin plated copper-clad steel,24AWG(0.51mm/0.020“ Dia.) A16-300 ~ 1100: Tin plated copper, 20AWG(0.81mm/0.032”Dia) A16-1200 ~ 1400: Tin plated copper, 18 AWG(1.0mm/0.04” Dia.) Lead Solderability : MIL-STD-202, Method 208E Device Labeling : Device is marked wiht Logo,amperage rating,voltage rating & date code. JDT FUSE Industrial Corp. www.jdtfuse.com Page 5/6 Revised 22/03/19 A16 Series PTC Devices Packaging Quantity Model Reel QTY A16-030 ~ A16-600 3000 500 A16-700 ~ A16-900 1500 500 A16-1000 ~ A16-1400 - 500 Bag QTY Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference Model Tyco / PolySwitch® Bourns / POLY-FUSE® Polytronics / EVERFUSE® A16-030 - - - A16-050 - - - A16-065 - - - A16-075 - MF-RHT070 - A16-090 RUEF090 MF-RHT090 RLD16P090BF A16-110 RUEF110 - RLD16P110BF A16-120 RUEF120 - A16-135 RUEF135 - RLD16P135BF A16-160 RUEF160 - RLD16P160BF A16-185 RUEF185 - RLD16P185BF A16-250 RUSBF250/RUEF250 - RLD16P250BF A16-300 RUEF300 MF-RG300 RLD16P300BF A16-400 RUEF400 MF-RHT450 RLD16P400BF A16-500 RUEF500 MF-RG500 RLD16P500BF A16-600 RUEF600 MF-RHT650 RLD16P600BF A16-700 RUEF700 MF-RHT750 RLD16P700BF A16-800 RUEF800 - RLD16P800BF A16-900 RUEF900 - RLD16P900BF A16-1000 RUEF1000 - RLD16P1000BF A16-1100 RUEF1100 MF-R1100 RLD16P1100BF A16-1200 RUEF1200 - RLD16P1200BF A16-1400 RUEF1400 MF-RHT1300 RLD16P1400BF “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 6/6 Revised 22/03/19
A16-300 价格&库存
很抱歉,暂时无法提供与“A16-300”相匹配的价格&库存,您可以联系我们找货
A16-300
  • 10+0.72290
  • 100+0.43120
  • 500+0.30190
  • 1000+0.21560
  • 2000+0.20480
  • 10000+0.18980
库存:10272
A16-300
  • 1+0.24215
  • 100+0.22765
  • 300+0.21315
  • 500+0.19865
  • 2000+0.19140
  • 5000+0.18705
库存:1190
A16-300
  • 10+0.41608
  • 100+0.33397
  • 300+0.29292
  • 1000+0.23798
  • 5000+0.21337
  • 10000+0.20101
库存:4610
