BRCO7530T
BRCO7530T
    BLUEROCKET(蓝箭电子)
    SOT89-3
    线性稳压器/LDO VIN=24V VOUT=3V 100mA SOT-89
BRCO7530T 数据手册
BRCO7530T Rev.B May.-2019 描述 / DATA SHEET Descriptions SOT-89 塑封封装低压差线性稳压器。 Low dropout linear regulator in a SOT-89 Plastic Package . 特征 / Features 低功耗,低压差,温度漂移系数小,输入电压可达 24V,静态电流 1.5μA,输出电压精度:±2%。 无卤产品。 Low power consumption,Low voltage drop,Small temperature drift coefficient, Input voltage up to 24V,The static current 1.5μA,The output voltage accuracy:±2%. Halogen-free Product. 用途 / Applications 用于各类电源设备,通信设备,音频和视频设备。 For use in power equipment,Communication equipment,Audio and video equipment. 内部等效电路 引脚排列 / Equivalent Circuit / Pinning 1 2 3 PIN1:GND 印章代码 PIN 2:VIN PIN 3:VOUT / Marking 见印章说明 / See Marking Instructions. http://www.fsbrec.com 1/7 BRCO7530T Rev.B May.-2019 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Working Voltage VIN -0.3~26 V Thermal Resistance RθJA 200 ℃/W Power Consumption PW 500 mW Storage Temperature TSTG -50~+125 ℃ Working Temperature TA -40~+85 ℃ 注:如果器件运行条件超过上述各项条件最大额定值,可能对器件造成永久性损坏。上述参数仅是运行 条件的极大值,我们不建议器件在该规范范围外运行。如果器件长时间工作在绝对最大极限条件下,其 稳定性可能会受到影响。 Notes: If the device operating conditions over the maximum rating of the above-mentioned conditions, may cause permanent damage to the device. The above parameters is only part of the operating conditions the maximum, we do not recommend the device running outside the scope of this specification. If the device to work long hours under the condition of absolute maximum limit, its stability may be affected. 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter 符号 Symbol 测试条件 Test Conditions The Output Voltage VOUT VIN=5.0V,IOUT=10mA The Output Current IOUT VIN=5.0V VIN=5.0V 1mA≤IOUT≤100mA Load Regulation △VOUT Low Dropout VDIF IOUT=10mA, △VOUT=2% Static Power ISS VIN=5.0V Line Regulation The Input Voltage Temperature Coefficient △VOUT/VOUT* △VIN 最小值 典型值 最大值 Min Typ Max 2.94 3.00 100 25 1.5 5.0≤VIN≤24V IOUT=10mA VIN △VOUT/ △TA*VOUT VIN=5.0V,IOUT=10mA -40℃≤TA≤85℃ 3.06 100 单位 Unit V mA 60 mV 100 mV 3.0 μA 0.2 %/V 24 V ppm/℃ 注:当 VIN=5.0V,固定负载条件下使输出电压下降 2%,此时输入电压和输出电压的差值为低压差值 VDIF。 Note: VDIF is defined as the input voltage minus the output voltage that produces a 2% change in the output voltage from the value at VIN=5.0V with a fixed load. http://www.fsbrec.com 2/7 BRCO7530T Rev.B May.-2019 电参数曲线图 DATA SHEET / Electrical Characteristic Curve 输入电压与输出电压/ The input voltage and output voltage 注:固定负载电流 IOUT=10mA。 输出电压与负载电流/ The output voltage and load current 注:固定输入电压 VIN=5.0V。 http://www.fsbrec.com 3/7 BRCO7530T Rev.B May.-2019 典型应用电路 DATA SHEET / Typical Application Circuit 1. 应用时尽量将电容接到 VIN 和 VOUT 脚位附近。 2.电路内部使用了相位补偿电路和利用输出电容的 ESR 来补偿。所以输出到地一定要接大于 2.2uF 的电容器,推荐使用钽电容。 3.注意输入输出电压和负载电流的使用条件,避免 IC 内部的功耗超出封装允许的最大功耗值。 http://www.fsbrec.com 4/7 BRCO7530T Rev.B May.-2019 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 5/7 BRCO7530T Rev.B May.-2019 / Marking Instructions 7530 ** 印章说明 DATA SHEET 说明: 7530: 为型号代码 **: 为生产批号代码,随生产批号变化。 Note: 7530: Product Type. **: Lot No. Code, code change with Lot No. http://www.fsbrec.com 6/7 BRCO7530T Rev.B May.-2019 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / 温度:260±5℃ 包装规格 卷盘包装 Package Type 封装形式 SOT-89 使用说明 Resistance to Soldering Heat Test Conditions 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec / Packaging SPEC. / REEL Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box Units/Inner Box Inner Boxes/Outer Box Units/Outer Box 卷盘/盒 只/盒 盒/箱 只/箱 1,000 7 7,000 6 42,000 Reel Inner Box 盒 Outer Box 箱 7〞×12 180×120×180 390×385×205 / Notices http://www.fsbrec.com 7/7
BRCO7530T 价格&库存
很抱歉,暂时无法提供与“BRCO7530T”相匹配的价格&库存,您可以联系我们找货
BRCO7530T
  • 10+0.50145
  • 100+0.40295
  • 300+0.35370
库存:46
BRCO7530T
  • 10+0.44108
库存:30
