KBP2005-KBP210
Silicon Bridge Rectifiers
VOLTAGE RANGE: 50 --- 1000 V
CURRENT:
2.0 A
KBP
1.8 TYP.
1.8 TYP.
1.5 TYP.
Rating to 1000V PRV
4.8± 0.2
Features
Surge overload rating to 50 Amperes peak
14.5± 0.5
3.2 45°
11.2± 0.5
Ideal for printed circuit board
AC
15.2 MIN
1.0 TYP.
plastic technique results in inexpensive product
Lead solderable per MIL-STD-202 method 208
Plastic material has UL flammability classification
12.7 MIN
Reliable low cost construction utilizing molded
φ 0.8± 0.1
3.7± 0.25
3.7± 0.25
94V-O
Weight: 0.050 ounces,1.42 grams
Dimensions in millimeters
Glass passivated chip junctions
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25
ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
KBP
2005
KBP
201
KBP
202
KBP
204
KBP
206
KBP
208
KBP
210
UNITS
Maximum recurrent peak reverse voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
V DC
50
100
200
400
600
800
1000
V
Maximum average forw ard
IF(AV)
2.0
A
IFSM
50.0
A
I²t Rating for fusing @Tj=25℃
I²t
10.4
A²S
Maximum instantaneous forw ard voltage
@ 2.0 A
VF
1.1
V
10.0
μA
1.0
mA
Output current
@TA=25
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
Maximum reverse current
at rated DC blocking voltage
@TA=25
IR
@TA =100
Typical Thermal Resistance (Note)
RθJA
RθJC
RθJL
8
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
Operating junction temperature range
Storage temperature range
Revision:20170701-P1
25
5
ht t p : //
www.lgesem i .c o m
o
C/W
mail:lge@lgesemi.com
KBP2005-KBP210
Ratings AND Charactieristic Curves
FIG.2 -- FORWARD DERATING CURVE
VVNVVOUTPUT RECTIFIED CURRENT
AVERAGE FORWARD OUTPUT CURRENT,
AMPERSE
PEAK FORWARD SURGE CURRENT,
AMPERSE
FIG.1 -- PEAK FORWARD SURGE CURRENT
50
40
8.3ms Single Half Sine Wave
30
10
100
2.5
2
1.5
1
0.5
NUMBER OF CYCLES AT 60HZ
0.1
TJ=125
Pulse Width
=300uS
0.4
0.6
0.8
1.0
1.2
ht t p : //
100
125
150
10
1.0
TJ=100
0.1
TJ=25
.01
60
80
100
120
140
1.4
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
75
FIG.4 -- TYPICAL REVERSE CHARACTERISTIC
INSTANTANEOUS REVERSE CURRENT,
MICRO AMPERSE
1.0
AMPERSE
INSTANTANEOUS FORWARD CURRENT,
10
0.2
50
AMBIENT TEMPERATURE,
FIG.3 -- TYPICAL FORWARD CHARACTERISTIC
PERCENT OF RATED PEAK REVERSE VOLTAGE
www.lgesem i .c o m
很抱歉,暂时无法提供与“KBP210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.70168
- 50+0.56225
- 150+0.49259
- 500+0.44032
- 2500+0.39852
- 5000+0.37757
