C1259VS10411M0101RA
C1259VS10411M0101RA
    KONNRA(康瑞电子)
    Accessories_8.25X4.2MM_SM
    线对板连接器 间距1.25mm 4Pin(1x4) 磷青铜 立贴
C1259VS10411M0101RA 数据手册
SPECIFICATIONS 1. Current rating: 1A AC, DC 2. Voltage rating:50V AC,DC 3. Temperature range: -40°C ~ +105°C 4. Insulation resistance: 100MΩ/ min. 5. Withstanding voltage: 500V AC/ minute. 6. Contact resistance: 30mΩ/ max. Material:PA66 or PBT UL94 V-0 Suitable KR1259 Series Terminal Mates With KR1259 Series Wafer Ordering Code: H125901** **01A 01:PA66 UL94 V-0 White 02:PA66 UL94 V-0 Black ,HF 20:PA66 UL94 V-0 Red 24:PBT White 102=02P 103=03P Circuits 2 Add specification MARK ZSZ Uniformly arrange the drawings Arvin 2021.09.06 Change the part number and frame format TLX 2020.03.28 REVISION DESCRIPTION SIGNATURE Shen 2021.09.06 2022.03.28 DATE GH1.25 Housing A 1.25 Dimensions B C 3.85 1.90 3 2.50 5.10 2.90 4 3.75 4.15 5 6 5.00 6.25 6.35 7.50 8.75 6.15 7 7.50 10.00 6.15 8 11.25 6.15 9 8.75 10.00 12.50 6.15 10 11.25 13.75 8.10 11 12.50 15.00 8.10 12 16.25 8.10 13 13.75 15.00 17.50 8.10 14 16.25 18.75 8.10 15 17.50 20.00 8.10 16 18.75 21.25 8.10 东莞市康瑞电子有限公司 DongGuan Konnra Electronics C o.,Ltd. PART NO.:H125901****01A UNIT:mm SCALE:1/1 SHEET:1/1 PROJECTION 4.15 REV.:A5 DRAWING NO.:1259H01-1-S 1 2 3 4 5 6 7 8 9 RoHS COMPLIANT A SPECIFICATIONS 1. Current rating: 1A AC, DC 2. Voltage rating:50V AC,DC 3. Temperature range: -40°C ~ +105°C 4. Insulation resistance: 100MΩ/ min. 5. Withstanding voltage: 500V AC/ minute. 6. Contact resistance: 30mΩ/ max. B A Material: Phosphor Bronze Applicable wires: Conductor size: AWG#26~#30 Insulation O.D. : 1.0mm Max. Finish: Tin plated or Gold plated contact area Suitable KR1259 Series Housing Mates With KR1259 Series Wafer Q'TY/Reel: 20,000PCS A C B B C Ordering Code: T12590P *** 01A Gold-plated area B A S00:Material T01:Sn B08:Half Au,Ni G08:Au40u" D D E E F MARK TITLE: TOLERANCE ±0.20 GH1.25 Terminal Uniformly arrange the drawings Shen 2021.09.06 X.X X.XX ±0.15 Change the part number and TLX 2020.05.08 X.XXX ±0.08 frame format REVISION DESCRIPTION SIGNATURE DATE Angle ±2° UNIT:mm SCALE:1/1 1 2 3 4 5 Shen 2021.09.06 DRAWN: 东莞市康瑞电子有限公司 CHECKED DongGuan Konnra Electronics C o.,Ltd. F APPROVED PART NO.:T12590P***01A SHEET:1/1 PROJECTION REV.:A4 DRAWING NO.:1259T01-A-S 6 7 8 9 1 2 3 4 5 6 7 RoHS COMPLIANT 8 9 SPECIFICATIONS 1. Current rating: 1A AC, DC 2. Voltage rating:50V AC,DC 3. Temperature range: -40°C ~ +105°C 4. Insulation resistance: 100MΩ/ min. 5. Withstanding voltage: 500V AC/ minute. 6. Contact resistance: 30mΩ/ max. Material: Insulator: PA6T UL94V-0 Contact: Phosphor bronze Solder tabs: Brass Finish: Tin plated or selective gold plated over nickel Mate With KR1259 series housing A B A B Ordering code: 8-16P Has card slot 2-7P Has no card slot There are two tapping holes above 7P C1259RS *** 09 M01 ** RA 102: 2P 114: 14P 09: PA6T Natural 11: PA9T Natural C 01: Has card slot 03: Has no card slot M01: Matte TIN B01:Half Gold & Matte Tin D C D CONNECTOR EDGE E E Add specification F ZSZ 2022.8.9 Uniformly arrange the drawings Shen 2021.9.3 ADD 14P Specification Arvin 2021.2.2 MARK REVISION DESCRIPTION 1 2 SIGNATURE 3 DATE TITLE: TOLERANCE X.X ±0.30 GH 1.25 SMT 90° X.XX ±0.20 Wafer X.XXX ±0.10 Angle ±2° UNIT:mm SCALE:1/1 4 5 Shen 2021.09.03 DRAWN: 东莞市康瑞电子有限公司 CHECKED DongGuan Konnra Electronics C o.,Ltd. F APPROVED PART NO.:C1259RS***09*****RA SHEET:1/1 PROJECTION REV.:A6 DRAWING NO.:1259WHS01-A-S 6 7 8 9 1 2 3 4 5 6 7 RoHS COMPLIANT 8 9 SPECIFICATIONS 1. Current rating: 1A AC, DC 2. Voltage rating:50V AC,DC 3. Temperature range: -40°C ~ +105°C 4. Insulation resistance: 100MΩ/ min. 5. Withstanding voltage: 500V AC/ minute. 6. Contact resistance: 30mΩ/ max. Material: Insulator: PA6T UL94V-0 Contact: Phosphor bronze Solder tabs: Brass Finish: Tin plated or selective gold plated over nickel Mate With KR1259 series housing A B A B Ordering code: C1259VS *** 09 M01 ** RA 8-16P Has card slot 2-7P Has no card slot 102: 2P 114: 14P 09: PA6T Natural 11: PA9T Natural There are two tapping holes above 7P C 01: Has no card slot 03: Has card slot M01: Matte TIN B01:Half Gold & Matte Tin D C D CONNECTOR EDGE E E F Add specification ZSZ 2022.8.9 Change Cap Arvin 2022.3.18 Uniformly arrange the drawings Shen 2021.9.3 MARK REVISION DESCRIPTION 1 2 SIGNATURE 3 DATE TITLE: TOLERANCE X.X ±0.30 GH 1.25 SMT 180° X.XX ±0.20 Wafer X.XXX ±0.10 Angle ±2° UNIT:mm SCALE:1/1 4 5 Shen 2021.09.03 DRAWN: 东莞市康瑞电子有限公司 CHECKED DongGuan Konnra Electronics C o.,Ltd. F APPROVED PART NO.:C1259VS***09*****RA SHEET:1/1 PROJECTION REV.:A7 DRAWING NO.:1259WVS01-A-S 6 7 8 9
C1259VS10411M0101RA 价格&库存
很抱歉,暂时无法提供与“C1259VS10411M0101RA”相匹配的价格&库存,您可以联系我们找货
