PSBD1DF20V2H THRW PSBD1DF200V2H
Switching Diode
Description
Surface Mount Schottky Barrier Rectifier Rectifiers
Reverse Voltage 20 to 200 V
2
1
Forward Current 2.0 A
SOD123-FL
Maximum Ratings and Electrical characteristics per line@25℃( unless otherwise specified)
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %
Parameter
Symbols
20V2H
40V2H
60V2H
80V2H
100V2H
120V2H
150V2H
200V2H
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
60
80
100
120
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
VDC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
2.0
A
Peak Forward Surge Current 8.3 ms Single
Half
Sine Wave Superimposed on Rated Load
IFSM
50
40
A
(JEDEC Method)
Maximum Instantaneous Forward Voltage at
2A
Maximum DC Reverse Current Ta = 25 ℃
at Rated DC Blocking Voltage Ta =100 ℃
VF
IR
0.55
0.70
0.85
0.5
0.3
5
3
220
2
80
0.95
V
mA
Typical Junction Capacitance 1
Cj
Typical Thermal Resistance 2
RθJA
85
℃/W
Operating and Storage Temperature Range
Tj,Tstg
-55~+150
pF
1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
2)Thermal resistance from junction to ambient at 0.375" (9.5 mm) lead length, P.C.B. mounted
Rev.06.3
1
www.prisemi.com
Switching Diode
40V2H
200V2H
Fig.1 Forward Current Derating Curve
Fig.2 Typical Reverse Characteristics
40V2H
80V2H
120V2H
40V2H
200V2H
200V2H
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
60V2H
200V2H
Fig.5
Maximum Non-Repetitive
Peak
Fig.6 Typical Transient Thermal Impedance
Forward Surage Current
Rev.06.3
2
www.prisemi.com
Switching Diode
Product dimension (SOD-123FL)
Unit:mm
1.2
2.0
1.2
1.4
Suggested PCB Layout
Rev.06.3
3
Unit:mm
www.prisemi.com
Switching Diode
Rev.06.3
4
www.prisemi.com
Switching Diode
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi
assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.3
5
www.prisemi.com
很抱歉,暂时无法提供与“PSBD1DF40V2H”相匹配的价格&库存,您可以联系我们找货
