AZ1143-04F.R7G
AZ1143-04F.R7G
    AMAZING(晶焱)
    DFN2510P10E
    ESD保护 VRWM=3.3V VBR(Min)=4.5V VC=9V IPP=6A DFN2510P10E
AZ1143-04F.R7G 数据手册
AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Features Consumer Electronics  Set Top Box  DVDRW Players  Graphics Cards  ESD Protect for Transition Minimized Differential Signaling (TMDS) channels  Protects four I/O lines  Provide ESD protection for each line to  IEC 61000-4-2 (ESD) ±18kV (air), ±16kV (contact) IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 6A (8/20µ µs) For operating voltage of 3.3V and below  Ultra low capacitance : 0.45pF typical  Fast turn-on and Low clamping voltage  Array of ESD rated diodes with internal equivalent TVS (Transient Voltage Suppression) diode  Simplified layout for HDMI connectors  Solid-state silicon-avalanche and active circuit triggering technology  Green part  Applications High Definition Multi-Media Interface (HDMI) 1.3 & 1.4 and 2.0 version  DisplayPort interface  SATA and eSATA interface  USB3.0  V-By-One  LVDS interfaces  IEEE 1394 up to 3.2 Gb/s  Ethernet port: 10/100/1000 Mb/s  Desktop and Notebooks PCs  Description AZ1143-04F is a design which includes ESD rated diode arrays to protect high speed data interfaces. The AZ1143-04F has been specifically designed to protect sensitive components which are connected to data and transmission lines from over-voltage caused by Electrostatic Discharging (ESD), Electrical Fast Transients (EFT), Lightning, and Cable Discharge Event (CDE). AZ1143-04F is a unique design which includes ESD rated, ultra low capacitance steering diodes and a unique design of clamping cell which is an equivalent TVS diode in a single package. During transient conditions, the steering diodes direct the transient to either the internal ESD line or to ground line. The internal unique design of clamping cell prevents over-voltage on the internal ESD line and on the I/O line, which is protecting any downstream components. AZ1143-04F may be used to meet the ESD immunity requirements of IEC 61000-4-2, Level 4 (±15kV air, ±8kV contact discharge). Circuit Diagram 1 2 4 Pin Configuration 5 3,8 Line-1 1 10 NC Line-2 2 9 GND 3 Line-3 4 7 NC Line-4 5 6 NC 8 NC GND DFN2510P10E (Top View) Revision 2014/10/02 ©2014-2015 Amazing Micro. 1 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL RATING UNITS Peak Pulse Current (tp= 8/20µs) IPP 6 A Operating Voltage (I/O pin-GND) VDC (GND – 0.5) to 3.6 V ESD per IEC 61000-4-2 (Air) 18 VESD ESD per IEC 61000-4-2 (Contact) Lead Soldering Temperature TSOL kV 16 260 (10 sec.) o C Operating Temperature TOP -55 to +85 o Storage Temperature TSTO -55 to +150 o C C ELECTRICAL CHARACTERISTICS PARAMETER Reverse Stand-Off Voltage Channel Leakage Current Reverse Breakdown Voltage Forward Voltage ESD Clamping Voltage ESD Dynamic Turn-on Resistance Channel Input Capacitance Channel to Channel Input Capacitance Revision 2014/10/02 SYMBOL VRWM ICH-Leak VBV VF Vclamp Rdynamic CIN CCROSS CONDITIONS MIN TYP Pin-1,-2,-4,-5 to pin-3,-8, T=25 oC VPin-1,-2,-4,-5 = 3.3V, VPin-3,-8 = 0V, T=25 oC IBV = 1mA, T=25 oC, pin-1,-2,-4,-5 to pin-3,-8 IF = 15mA, T=25 oC, pin-3,-8 to pin-1,-2,-4,-5 IEC 61000-4-2 +6kV, T=25 oC, Contact mode, any I/O pin to Ground IEC 61000-4-2, 0~+6kV, T=25 oC, Contact mode, any I/O pin to Ground Vpin-3,-8 = 0V, VIN = 1.65V, f = 1MHz, T=25 oC, any I/O pin to Ground Vpin-3,-8 = 0V, VIN = 1.65V, f = 1MHz, T=25 oC, between I/O pins ©2014-2015 Amazing Micro. 2 MAX UNITS 3.3 V 1.0 µA 4.5 V 0.9 1.1 V 9 V 0.24 Ω 0.45 0.65 pF 0.05 0.1 pF www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Typical Characteristics Typical Variation of CIN vs. VIN 0.8 Input Capacitance (pF) Input Capacitance (pF) f = 1MHz, T=25 oC, 0.09 f = 1MHz, T=25 oC, 0.7 Typical Variation of CIO-to-IO vs. VIN 0.10 0.6 0.5 0.4 0.3 0.2 0.1 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0.0 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0 3.3 0.00 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0 3.3 Input Voltage (V) Input Voltage (V) Insertion Loss S21 (IO-to-GND) Analog Cross Talk 20 0 10 Analog Cross Talk (dB) Insertion Loss (dB) -3 -6 -9 -12 -15 -18 -21 -24 8.1GHz : -3dB -27 -20 -30 -40 -50 -60 -70 -30 -80 1e+8 1e+9 1e+10 1e+8 Frequency (Hz) Transmission Line Pulsing (TLP) Current (A) 0 -10 1e+9 1e+10 Frequency (Hz) Transmission Line Pulsing (TLP) Measurement 18 16 14 V_pulse 12 Pulse from a transmission line TLP_I 10 100ns + TLP_V 8 DUT - 6 4 I/O to GND 2 0 0 1 2 3 4 5 6 7 8 9 10 11 Transmission Line Pulsing (TLP) Voltage (V) Revision 2014/10/02 ©2014-2015 Amazing Micro. 3 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Applications Information The AZ1143-04F is designed to protect four data lines from transient over-voltage (such as ESD stress pulse). The device connection of AZ1143-04F is shown in the Fig. 1. In Fig. 1, the four protected data lines are connected to the ESD protection pins (pin1, pin2, pin4, and pin5) of AZ1143-04F. The ground pins (pin3 and pin8) of AZ1143-04F are the negative reference pins. I/O 1 line data line I/O 1 I/O 2 I/O 2 Line-1 Line-2 GND Line-3 Line-4 To I/O-port Connector data 1 10 NC 2 9 NC 3 4 AZ1143-04F To I/O-port Connector These pins should be directly connected to the GND rail of PCB (Printed Circuit Board). To get minimum parasitic inductance, the path length should keep as short as possible. AZ1143-04F can provide ESD protection for 4 I/O signal lines simultaneously. If the number of I/O signal lines is less than 4, the unused I/O pins can be simply left as NC pins. 5 8 GND 7 NC 6 NC I/O 3 I/O 3 I/O 4 data line data line To Protected IC To Protected IC I/O 4 Fig. 1 Data lines connection of AZ1143-04F. B. Application AZ1143-04F is designed for protecting high speed I/O ports from over-voltage caused by Electrostatic Discharging (ESD). Thus, a lot of kinds of high speed I/O ports can be the applications of AZ1143-04F, especially, the HDMI port. HDMI Protection for High and Low speed signals The HDMI Compliance Test Specification (CTS) requires sink (receiver) ports maintain a differential impedance of 100 Ohms +/- 15%. ESD protection devices have an inherent junction capacitance. Even a small amount of added capacitance on a HDMI port will cause the impedance of the differential pair to drop. Thus, some form of compensation to the layout will be required to bring the differential pairs back within the required 100 Ohm +/- 15% range. The higher the added capacitance, the more extreme the modifications will need to be. If the added capacitance is too high, compensation may not even be possible. The AZ1143-04F presents 0.45pF capacitance to each differential signal while being rated to handle >8kV ESD contact discharges (>15kV air discharge) as outlined in IEC 61000-4-2. Therefore, it is possible to make Revision 2014/10/02 4 ©2014-2015 Amazing Micro. www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port none adjustment to the board layout parameters to compensate for the added capacitance of the AZ1143-04F. Figure 2 shows how to implement the AZ1143-04F in a HDMI application. The AZ1143-04F is designed for allowing the traces to run straight through the device to simplify the PCB layout. As shown in Figure 2, the best way to design the PCB trace is using the flow through layout. The solid line represents the PCB trace. Note that the PCB traces are used to connect the pin pairs for each line (pin 1 to pin 10, pin 2 to pin 9, pin 4 to pin 7, pin 5 to pin 6). For example, line 1 enters at pin 1 and exits at Pin 10 and the PCB trace connects pin 1 and 10 together. Lines 2, 3, and 4 have the same way of connection. The ground pins (pin3 and pin8) of AZ1143-04F are the negative reference pins. These pins should be directly connected to the GND plane of PCB. To get minimum parasitic inductance, the path length should keep as short as possible. In Figure 2, the none-TMDS signals, DDC_CLK, DDC_DAT, CE_REMOTE, and HOTPLUG_DET, can be protected with another low cost part, e.g., AZC199-04S. TMDS_D2+ NC 9 NC 8 GND 7 NC 5 6 NC Line-1 1 10 NC TMDS_GND Line-2 2 9 NC TMDS_D0- GND 3 8 GND TMDS_CK+ Line-3 4 7 NC TMDS_GND Line-4 5 6 NC Line-1 1 TMDS_GND Line-2 2 TMDS_D2- GND 3 TMDS_D1+ Line-3 4 TMDS_GND Line-4 TMDS_D0+ AZ1143-04F 10 TMDS_D2+ TMDS_D2- TMDS_D1+ TMDS_D1- AZ1143-04F TMDS_D1TMDS_D0+ TMDS_D0- TMDS_CK+ TMDS_CK- TMDS_CKCE_REMOTE CE_REMOTE Via hole to GND N/C DDC_DAT GND GND 2 DDC_CLK 1 AZC199-04S DDC_CLK 3 4 5 +5V 6 Via hole to +5V +5V OUT C=100nF (optional) HOTPLUG_DET DDC_DAT Via hole to GND HOTPLUG_DET HDMI Connector Fig. 2 HDMI Protection for High and Low speed signals. Revision 2014/10/02 ©2014-2015 Amazing Micro. 5 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Fig. 3 shows the HDMI 2.0 (6 Gb/s) eye diagrams with and without AZ1143-04F. Due to ultra low capacitance of AZ1143-04F, no degradation is observed. Without AZ1143-04F With AZ1143-04F Fig. 3 HDMI 2.0 (6 Gb/s) Eye Diagrams with and without AZ1143-04F. Revision 2014/10/02 ©2014-2015 Amazing Micro. 6 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port PACKAGE OUTLINE (DFN2510P10E) TOP VIEW (unit in mm) BOTTOM VIEW (unit in mm) SIDE VIEW (unit in mm) Symbol A A1 A3 D E D1 E1 b e L1 L2 b2 L Revision 2014/10/02 Millimeters min max 0.40 0.55 0.00 0.05 0.152REF. 2.45 2.55 0.95 1.05 0.35 0.45 0.35 0.45 0.15 0.25 0.5 BSC 0.075 REF 0.05 REF 0.20 0.30 0.35 0.45 ©2014-2015 Amazing Micro. 7 Inches min max 0.016 0.022 0.000 0.002 0.006 BSC 0.096 0.100 0.037 0.041 0.014 0.018 0.014 0.018 0.006 0.010 0.019 BSC 0.0029 REF 0.0019 REF 0.0079 0.012 0.014 0.018 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port LAND LAYOUT D D1 Dimensions B F A E C C1 Notes: This LAND LAYOUT is for Index Millimeter Inches A 0.875 0.034 B 0.20 0.008 C 0.50 0.02 C1 1.00 0.039 D 0.25 0.01 D1 0.4 0.016 E 0.675 0.027 F 1.55 0.061 reference purposes only. Please consult your manufacturing partners to ensure your company’s PCB design guidelines are met. MARKING CODE Part Number 143XY AZ1143-04F (Green part) 143 = Device Code X = Date Code Y= Control Code Marking Code 143XY Note. Green means Pb-free, RoHS, and Halogen free compliant. Ordering Information PN# Material Type Reel size MOQ/internal box MOQ/carton AZ1143-04F.R7G Green T/R 7 inch 4 reel= 12,000/box 6 box =72,000/carton Revision 2014/10/02 ©2014-2015 Amazing Micro. 8 www.amazingIC.com AZ1143-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Revision History Revision Modification Description Revision 2014/06/16 Preliminary Release. Revision 2014/10/02 Formal Release. Revision 2014/10/02 ©2014-2015 Amazing Micro. 9 www.amazingIC.com
AZ1143-04F.R7G 价格&库存
很抱歉,暂时无法提供与“AZ1143-04F.R7G”相匹配的价格&库存,您可以联系我们找货
AZ1143-04F.R7G
  • 10+0.59618
  • 100+0.47847
  • 600+0.47369
  • 1200+0.46422
  • 3000+0.45029
库存:3101
AZ1143-04F.R7G
    • 1+0.54890
    • 200+0.35420
    • 1500+0.30800
    • 3000+0.27170
    库存:85864
