COS4426/4427/4428
1.5A Dual High-Speed Power MOSFET Drivers
Features
General Description
High Peak Output Current: 1.5A
The COS4426/7/8 are matched dual power
Wide Supply Voltage Operating Range:
MOSFET
4.5V to 25V
enables high speed operation capable of
High Capacitive Load Drive Capability
delivering peak currents of 1.5A into 1000pF
1000pF in 11ns (typical)
capacitive loads. Improved speed and drive
Short Delay Times: 35ns (typical)
capability are enhanced by matched rise and
Matched Rise/Fall Times
fall
Low Output Impedance
maintain
Low Supply Current
pulse-widths to reduce timing errors and clock
Over-temperature Protection
skew problems. Dynamic switching losses are
Under-voltage Lockout
minimized with non-overlapped drive techni-
Non-overlapped Drive Tech
ques. These devices are highly latch-up
ESD Protected: 2.0kV
resistant within their power and voltage ratings.
Input withstands negative inputs up to 5V
They are not subject to damage when up to 5V
Available in Green SOP8, DIP8 and DFN8
of noise spiking (of either polarity) occurs on
Packages
the ground pin. All terminals are fully protected
delay
drivers.
times.
the
Unique
These
integrity
circuit
matched
of
design
delays
input-to-output
against Electrostatic Discharge (ESD) up to 2.0
Applications
kV.
Wireless Power Transmitter
Switch Mode Power Supplies
Pin Configuration
Pulse Transformer Drivers
Line Drivers
CCD Driver
Class D Switching Amplifiers
Rev1.2
Copyright@2022 Cosine Nanoelectronics Inc. All rights reserved
The information provided here is believed to be accurate and reliable. Cosine Nanoelectronics assumes
no reliability for inaccuracies and omissions. Specifications described and contained here are subjected
to change without notice on the purpose of improving the design and performance. All of this information
described herein should not be implied or granted for any third party.
www.cosine-ic.com
COS4426:
COS4427:
COS4428:
Outputs out of phase with inputs
Outputs in phase with inputs
OutputA: out of phase with input A
OutputB in phase with input B
1
COS4426/4427/4428
1. Pin Configuration and Functions
COS4426:
COS4427:
COS4428:
Output A: out of phase with input A;
Output B: in phase with input B
Figure 1. Pin Diagram
Figure 2. Functional Block Diagram
www.cosine-ic.com
2
COS4426/4427/4428
Pin Description
Pin
1
2
3
4
5
6
7
8
Name
NC
IN A
GND
In B
OUT B
VDD
OUT A
NC
PAD
Description
No connection
Input A
Ground
Input B
Output of Channel B
Power Supply
Output of Channel A
No connection
Exposed Metal Pad of
DFN Package
Function Table
COS4426
INA
INB
L
L
H
L
H
H
H
COS4427
COS4428
OUTA
OUTB
OUTB
H
L
L
H
L
H
L
L
H
H
H
L
L
H
H
L
L
L
H
L
L
H
H
L
H
1.1 Inputs A and B
MOSFET driver inputs A and B are high-impedance, TTL/CMOS compatible inputs. These inputs
also have 300 mV of hysteresis between the high and low thresholds that prevents output glitching
even when the rise and fall time of the input signal is very slow.
1.2 Ground (GND)
Ground is the device return pin. The Ground pin(s) should have a low-impedance connection to the
bias supply source return. High peak current flows out the Ground pin(s) when the capacitive load is
being discharged.
1.3 Output A and B
MOSFET driver outputs A and B are low-impedance, CMOS push-pull style outputs. The pull-down
and pullup devices are of equal strength, making the rise and fall times equivalent.
www.cosine-ic.com
3
COS4426/4427/4428
1.4 Supply Input (VDD)
The VDD input is the bias supply for the MOSFET driver and is rated for 4.5V to 25V with respect to
the Ground pin. The VDD input should be bypassed with local ceramic capacitors. The value of
these capacitors should be chosen based on the capacitive load that is being driven. A value of 1.0
μF is suggested.
1.5 Exposed Metal Pad
The exposed metal pad of the DFN-8 package is not internally connected to any potential. Therefore,
this pad can be connected to a ground plane or other copper plane on a Printed Circuit Board (PCB),
to aid in heat removal from the package.
2. Product Specification
2.1 Absolute Maximum Ratings (1)
Parameter
DC supply voltage Vs
Operating junction temperature
Storage temperature
Maximum input voltage
Combined peak output current
Min
Max
Unit
-40
-55
GND-5
26
125
150
VDD+0.3
4
V
°C
°C
V
A
(1) Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable
above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition,
extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute
maximum ratings are stress ratings only.
2.2 Thermal Data
Parameter
Rating
Unit
Package Thermal Resistance
155 (SOP8)
90 (DIP8)
57 (FDN8,3x3)
°C/W
Rating
Unit
2.3 Recommended Operating Conditions
Parameter
DC Supply Voltage
Operating ambient temperature
www.cosine-ic.com
4.5V ~ 25V
-40 to +85
V
°C
4
COS4426/4427/4428
2.4 Electrical Characteristics
(Typical values are tested at TA=25 oC, VDD=18V)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
INPUT
Input Signal High Threshold
VIH
Input Signal Low Threshold
VIL
Input Signal Hysteresis
Input Current
1.8
0.7
VHYS
IIN
V
0.3
0VVINVDD
V
V
±1
µA
OUTPUT
Pull-Up Resistance
ROH
Source Current = 10mA
2.0
Ω
Pull-Down Resistance
ROL
Sink Current = -10mA
2.0
Ω
Peak Output Current
IPK
Source Current, f=1kHz,
CL=1000pF
Sink Current, f=1kHz,
CL=1000pF
Continuous Output Current
IDC
Source / Sink Current
1.5
A
-1.5
±200
mA
POWER SUPPLY
Power Supply Current
ICC
Operating Voltage Range
VDD
VINA=VINB=3V
0.8
VINA=VINB=0V
0.4
4.5
Under-Voltage Lockout ON
Threshold
Hysteresis
3.6
mA
25
V
4
V
0.5
V
11
ns
11
ns
Non-inverting Input
34
ns
Inverting Input
44
ns
Non-inverting Input
34
ns
Inverting Input
44
ns
SWITCHING CHARACTERISTICS
Rise Time
tR
Fall Time
tF
Turn-On Delay Time
tD1
Turn-Off Delay Time
tD2
www.cosine-ic.com
CL =1000pF,
See Figure 3.1
CL =1000pF,
See Figure 3.1
5
COS4426/4427/4428
OVER-TEMPERATURE PROTECTION
Thermal Shutdown Threshold
150
°C
Hysteresis
25
°C
3.0 Application Information
Figure 3.1 Switching Time Test Circuit
4.0 Package and Ordering Information
Model
COS4426
COS4427
COS4428
www.cosine-ic.com
Order Number
Package
Package Option
Marking
Information
COS4426SR
SOP-8
Tape and Reel, 4000
COS4426SR
COS4426DR
DIP-8
Tube 50
COS4426DR
COS4427SR
SOP-8
Tape and Reel, 4000
COS4427SR
COS4427DR
DIP-8
Tube 50
COS4427DR
COS4428SR
SOP-8
Tape and Reel, 4000
COS4428SR
COS4428DR
DIP-8
Tube 50
COS4428DR
6
COS4426/4427/4428
5.0 Package Information
5.1 SOP8 (Package Outline Dimensions)
5.2 DIP8 (Package Outline Dimensions)
www.cosine-ic.com
7
很抱歉,暂时无法提供与“COS4428SR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.31000
- 10+1.26000
- 100+1.11000
- 500+1.08000
