JW5026
40V/1A, 1.1MHz Synchronous
Step-Down Converter
Parameters Subject to Change Without Notice
DESCRIPTION
FEATURES
The JW5026 is a current mode monolithic buck
switching regulator. Operating with an input range
of 4.7V~40V, the JW5026 delivers 1A of
continuous output current with two integrated
N-Channel MOSFETs. The internal synchronous
power switches provide high efficiency without
the use of an external Schottky diode. At light
loads, the regulator operates in continual
conduction mode to maintain low output ripple.
Current mode control provides tight load transient
response and cycle-by-cycle current limit.
The JW5026 guarantees robustness with
short-circuit protection, thermal protection,
current run-away protection, and input under
voltage lockout.
The JW5026 is available in 6-pin SOT23-6
package, which provides a compact solution with
minimal external components.
4.7V to 40V operating input range
1A output current
Up to 93% efficiency
FCC at light load
Internal Soft-Start
1.1MHz switching frequency
Input under voltage lockout
Available in SOT23-6 package
Current run-away protection
Short circuit protection
Thermal protection
APPLICATIONS
Distributed Power Systems
Automotive Systems
High Voltage Power Conversion
Industrial Power Systems
Battery Powered Systems
TYPICAL APPLICATION
Efficiency
100
90
80
70
60
50
40
30
Efficiency
Vin=8V
Vin=12V
Vin=24V
400
600
800
1000
Io(mA)
JW5026 Rev.0.8
JoulWatt Proprietary Information. Patent Protected.
Unauthorized Photocopy and Duplication Prohibited.
1
JW5026
JoulWatt
ORDER INFORMATION
TOP
LEAD FREE FINISH
TAPE AND REEL
PACKAGE
Note
MARKING
JW5026SOTB#PBF
JW5026SOTB#TRPBF
SOT23-6
JWBH
PIN CONFIGURATION
TOP VIEW
BST
1
6
SW
GND
2
5
V IN
FB
3
4
EN
S O T 2 3 -6
ABSOLUTE MAXIMUM RATING1)
VIN, EN, SW Pin ................................................................................................................. -0.3V to 44V
BST Pin ................................................................................................................... SW-0.3V to SW+5V
All other Pins ......................................................................................................................... -0.3V to 6V
Junction Temperature2) 3) ..................................................................................................................150ºC
Lead Temperature
......................................................................................................................260ºC
Storage Temperature .................................................................................................. -65ºC to +150ºC
RECOMMENDED OPERATING CONDITIONS
Input Voltage VIN ................................................................................................................4.7V to 40V
Output Voltage Vout.............................................................................................................0.8V to VIN-3V
Operating Junction Temperature ......................................................................................-40ºC to 125ºC
THERMAL PERFORMANCE4)
θJA
θJc
SOT23-6 ............................................................................................................................ 220...130ºC/W
Note
1)
2)
3)
4)
Exceeding these ratings may damage the device.
The JW5026 guarantees robust performance from -40°C to 150°C junction temperature. The junction temperature
range specification is assured by design, characterization and correlation with statistical process controls.
The JW5026 includes thermal protection that is intended to protect the device in overload conditions. Thermal
protection is active when junction temperature exceeds the maximum operating junction temperature. Continuous
operation over the specified absolute maximum operating junction temperature may damage the device.
Measured on JESD51-7, 4-layer PCB.
JW5026 Rev.0.8
2
JW5026
JoulWatt
ELECTRICAL CHARACTERISTICS
VIN = 12V, TA = 25ºC, unless otherwise stated.
Item
Symbol
VIN Undervoltage Lockout
VIN_MIN
Threshold
Condition
Min.
VIN rising
VIN_MIN_HYST
Hysteresis
Typ.
Max.
Units
4.3
V
250
mV
Shutdown Supply Current
ISD
VEN=0V
0.1
1
µA
Supply Current
IQ
VEN=5V, VFB=1.2V
40
60
µA
800
824
mV
Feedback Voltage
Top Switch Resistance
VFB
5)
4.7V
很抱歉,暂时无法提供与“JW5026”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.70158
- 30+1.64291
- 100+1.52556
- 500+1.40821
- 1000+1.34953
