FCC0805B102K102FT
FCC0805B102K102FT
    FOJAN(富捷)
    贴片电容(MLCC) 0805 1nF ±10% 1KV X7R
FCC0805B102K102FT 数据手册
1 目 录 CONTENTS 电容器 与介质分类 01 产品 结构 02 产品规格型号 命名规则 . 产品容量 范围 04-16 产品 尺寸 03 17 技术要求 和测试条件 18-27 产品 包装 28-32 MLCC 使用注意事项 33-38 电容器及介质分类 Types of Capacitor and Dielectric Material 多层片式陶瓷电容器产品目录 Types of Capacitor and Dielectric Material COG:此类介质材料的电容器为Ⅰ类电容器, 包括常规、中高压COG 产品。此类产品电性能 稳定,几乎不随 温度、电压和时间的变化而变化。适用于低损耗,稳定性要求高的电路中, 如滤波器、谐振器和计时电路中。 -------------------------------------------------------------------------------------------COG: The capacitor of this kind dielectric material is considered as ClassⅠcapacitor, including general capacitor and high frequency COG capacitor。The electrical properties of COG capacitor are the most stable one and have little change with temperature, voltage and time. They are suited for applications where low-losses and high-stability are required, such as filters, oscillators, and timing circuits. -------------------------------------------------------------------------------------------X7R、X5R、X6S、X7T:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比 Ⅰ类电容器高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔 直、耦合、旁路、鉴频等电路中。 -------------------------------------------------------------------------------------------X7R、X5R、X6S、X7T:material is a kind of material has high dielectric constant. The capacitor made of this kind material is considered as Class Ⅱ capacitor whose capacitance is higher than that of class Ⅰ. These capacitors are classified as having a semi-stable temperature characteristic and used over a wide temperature range, such in these kinds of circuits, DC-blocking, decoupling, bypassing, frequency discriminating etc. -------------------------------------------------------------------------------------------Y5V:此类介质材料的电容器为Ⅱ类电容器,是所有电容器中介电常数最大的电容器,但其容 量稳定性较差,对温度、电压等条件较敏感,适用于要求大容量,温度变化不大的电路中。 -------------------------------------------------------------------------------------------Y5V:The capacitor made of this kind of material is the highest dielectric constant of all ceramic capacitors. They are used over a moderate temperature range in application where high capacitance is required because of its unstable temperature coefficient, but where moderate losses and capacitance changes can be tolerated. Its capacitance and dissipation factors are sensible to measuring conditions, such as temperature and voltage, etc 1 产品结构 Product Frame 多层片式陶瓷电容器产品目录 产品结构 Product Frame 图示说明 1 ------------------------------------------ 陶瓷介质 2 -------------------------------------------- 内电极 3 -------------------------------------------- 外电极 4 ---------------------------------------------- 镍层 5 ---------------------------------------------- 锡层 2 产品规格型号命名规则 General Product Parts Numbering System 多层片式陶瓷电容器产品目录 产品规格型号命名规则 General Product Parts Numbering System 例 [example] F 公司名 CC 产品别 0805 尺寸 F 温度特性 105 电容值 M 公差 500 额定电压 D 厚度 T 包装 S 特殊码 FCC0805F105M500DT FOJAN 陶瓷电容器代号 Code of Ceramic Capacitor 规 格 Chip Size Type=L×W 0402=1.00×0.50mm 1206=3.20×1.60mm 0201=0.60×0.30mm 0805=2.00×1.25mm 0603=1.60×0.80mm 1210=3.20×2.50mm 温度特性 Dielectrics COG=N, X7R=B , 电容值 X5R=X, Y5V=F, X7T=T, X6S=S Capacitance 105=10×105 =1000,000pF 5 表示 105 Two significant digits followed by no. of zero 容量容差 Capacitance Tolerance A= ±0.05pF B= ±0.1pF C= ±0.25pF J= ±5.0% K= ±10% M= ±20% D= ±0.5pF Z=-20/+80% F= ±1.0% G= ±2.0% 额定电压 Rated Voltage 6R3=6.3VDC 201=200VDC 100=10VDC 160=16VDC 250=25VDC 500=50VDC 101=100VDC 251=250VDC 501=500VDC 102=1000VDC 202=2000VDC 厚 度 Thickness A:0.5±0.10mm B:0.60±0.10mm F:1.25±0.20mm H:1.6 ±0.20mm C:0.80±0.10mm G:2.0 ±0.20mm D:0.85±0.10mm M:2.5 ±0.30mm E:1.00±0.10mm Z:0.3 ±0.03mm 包 装 Packing B:袋散装 B: bulk packaging in a bag T:编带 T:tape carrier packa 特殊码 Specific S:防断裂 ■ 产品的介质特性组别 材质 工作温度范围 C0G (N) -55℃~+125℃ 0±30ppm/℃ X7R (B) -55℃~+125℃ ±15% X5R (X) -55℃~+85℃ ±15% X7T (T) -55℃~+125℃ +22/-33% Y5V (F) -30℃~+85℃ +22/-82% X6S (S) -55℃~+105℃ 3 温度系数或温度特性 ±22% 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 产品容量范围 Product Capacitance Range ■ 0201[0603]尺寸 尺寸 0201[0603] 系列 X5R (X) 型号 CP VDC 25 103 Z 223 Z 16 10 X6S (S) 6.3 25 16 10 X7T (T) 6.3 Z Z 16 10 6.3 Z Z Z Z Z Z 473 Z 683 Z Z Z Z Z Z 104 Z Z Z Z Z Z 224 4 Z Z Z 说明 容量容差: X5R/X6S/X7T;K(±10%);M(±20%) 厚度:Z:0.30±0.03mm 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: X5R/X6S/X7T: K(±10%);M(±20%) Thickness: Z:0.30±0.03mm ; Above capacitance for reference only, actual cap. Range depends on the standard products. 4 Z 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 ■ 0402[1005]尺寸 尺寸 系列 型号 0402[1005] COG (N) X7R (B) X6S (S) X5R (X) X7T (T) Y5V (F) 5 0 2 5 1 6 1 0 6 · 3 5 0 2 5 1 6 1 0 6 · 3 5 0 2 5 1 6 1 0 6 · 3 5 0 2 5 1 6 1 0 6 · 3 A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A 181 A A A A A A A A A A A A A A A A A A A A A A 201 A A A A A A A A A A A A A A A A A A A A A A 221 A A A A A A A A A A A A A A A A A A A A A A 271 A A A A A A A A A A A A A A A A A A A A A A 331 A A A A A A A A A A A A A A A A A A A A A A 391 A A A A A A A A A A A A A A A A A A A A A A 471 A A A A A A A A A A A A A A A A A A A A A A 561 A A A A A A A A A A A A A A A A A A A A A A 681 A A A A A A A A A A A A A A A A A A A A A A 821 A A A A A A A A A A A A A A A A A A A A A A 102 A A A A A A A A A A A A A A A A A A A A A A 152 A A A A A A A A A A A A A A A A A A A A 182 A A A A A A A A A A A A A A A A A A A A 222 A A A A A A A A A A A A A A A A A A A A 272 A A A A A A A A A A A A A A A A A A A 332 A A A A A A A A A A A A A A A A A A A 472 A A A A A A A A A A A A A A A A A A A CP VDC 5 0 2 5 0R5 A A 1R0 A A 2R0 A A 3R0 A A 4R0 A A 5R0 A A 6R0 A A 7R0 8R0 9R0 A A A A A A 100 A A 120 A A 150 A A 180 A A 200 A A 220 A A 270 A A 300 A A 330 A A 390 A A 470 A A 560 A A 680 A A 820 A A 101 A 121 A 151 5 5 0 2 5 1 6 1 0 6 · 3 A A A A A A A A A A A A A A A A A A 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 562 A A A A A A A A A A A A A A A A A A A A A A A A A 103 A A A A A A A A A A A A A A A A A A A A A A A A A 153 A A A A A A A A A A A A A A A A A A A A A A A A A 183 A A A A A A A A A A A A A A A A A A A A A 223 A A A A A A A A A A A A A A A A A A A A A 273 A A A A A A A A A A A A A A A A A A A A A 333 A A A A A A A A A A A A A A A A A A A A A 393 A A A A A A A A A A A A A A A A A A A A A 473 A A A A A A A A A A A A A A A A A A A A A 563 A A A A A A A A A A A A A A A A A A A A 683 A A A A A A A A A A A A A A A A A A A A 104 A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A 184 A A A A A A A A A A A 224 A A A A A A A A A 154 A A 274 A A A A A A 334 A A A A A A 474 A A A A A A 684 A A A A A 105 A A A A A 说明 容量容差: COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%), X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%) ; Y5V: M(±20%);Z(-20,+80%) 厚度:A:0.50±0. 10mm; 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: COG(0.5pF~4.9pF): COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%) Y5V: M(±20%);Z(-20,+80%) Thickness: A:0.50±0.10mm ; Above capacitance for reference only, actual cap. Range depends on the standard products. 6 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 ■ 0603[1608]尺寸 尺寸 0603[1608] 系列 COG (N) 型号 CP VDC 0R5 1R0 2R0 3R0 4R0 5R0 6R0 7R0 8R0 9R0 100 120 150 180 200 220 270 300 330 390 470 560 680 820 101 121 151 181 201 221 271 331 391 471 561 681 821 102 152 182 222 272 332 X7R (B) X6S (S) X5R (X) X7T (T) Y5V (F) 2 2 1 5 2 2 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 5 0 0 0 5 5 0 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 · 0 5 6 0 3 3 3 3 0 0 0 0 0 0 C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C 472 C C C C C C C C C C C C C C C C C C C C C C C C C C C 562 C C C C C C C C C C C C C C C C C C C C C C C C C C C 682 C C C C C C C C C C C C C C C C C C C C C C C C C C C 103 C C C C C C C C C C C C C C C C C C C C C C C C C 153 C C C C C C C C C C C C C C C C C C C C C C C C C 183 C C C C C C C C C C C C C C C C C C C C C C C C C 223 C C C C C C C C C C C C C C C C C C C C C C C C C 273 C C C C C C C C C C C C C C C C C C C C C C C C 7 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 333 C C C C C C C C C C C C C C C C C C C C C C C C 393 C C C C C C C C C C C C C C C C C C C C C C C C 473 C C C C C C C C C C C C C C C C C C C C C C C C 563 C C C C C C C C C C C C C C C C C C C C C C C C 683 C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C 154 C C C C C C C C C C C C C C C C C C C C C C C C 184 C C C C C C C C C C C C C C C C C C C C C C C C 224 C C C C C C C C C C C C C C C C C C C C C C C C 274 C C C C C C C C C C C C C C C C C C C C C C C C 334 C C C C C C C C C C C C C C C C C C C C C C C C 474 C C C C C C C C C C C C C C C C C C C C C C C C 104 C 684 C C C C C C C C C C C C C C C C C C C 105 C C C C C C C C C C C C C C C C C C C 225 C C C C C C C C C C C C C C 475 C C C C C C C C C 106 C C C C 说明 容量容差: COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%); Y5V: M(±20%);Z(-20,+80%) 厚度:C:0.80±0.1mm (0.80±0.2mm ) ; 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: COG(0.5pF~4.9pF): B/C; COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%); Y5V: M(±20%);Z(-20,+80%) Thickness: C:0.80±0.1mm(0.80±0.2mm ) ; Above capacitance for reference only, actual cap. Range depends on the standard products. 8 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 ■ 0805[2012]尺寸 尺寸 0805[2012] 系列 COG (N) 型号 X7R (B) CP VDC 2 5 0 0R5 1R0 2R0 3R0 4R0 5R0 6R0 7R0 8R0 9R0 100 120 150 180 200 220 270 300 330 390 470 560 680 820 101 121 151 181 201 221 271 B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B 331 B B B B B 391 B B B B B 471 B B B B B 561 B B B B B 681 B B B B B 821 B B B B B 102 B B B B B X5R (X) X6S(S) X7T (T) Y5V (F) 1 5 2 1 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6 0 0 5 6 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 · 0 5 6 0 · 0 0 0 3 3 3 3 3 B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B D D D / F D / F D / F D / F D / F D / F D / F B B B B B D D D / F D / F D / F D / F D / F D / F D / F D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D 9 D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D B / D B / D B / D B / D B / D B / D B / D D D D D D 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 152 182 222 272 332 472 562 682 103 B D B B B B / F D B B B B / F D B B B B / F D B B B / F D D D / F D D D / F D D D / F D D / F D / F 153 F 183 F 223 F 273 F 333 F 393 F 473 F 563 683 104 D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D / F D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 154 D D D D D D D D D D D D D D D D D D D D D D D D D 184 D D / F D / F D / F D / F 224 274 334 474 D D D D D D D D D D / F D D D D D / F D D D D D / F D D D / / D D / F F F D D D D D D D D D D / F D D D D D / F D D D D D / F D D D / / D D / F F F 10 D D D D D D D D D D / F D D D D D / F D D D D D / F D D D / / D D / F F F D D D D D D D D D D / F D D D D D / F D D D D D / F D D D / / D D / F F F D D D D D D D D D D D D D D D D D D / / D D F F 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 D D D D / / / D D D / F F F F D D D F / / D D F / F F F F F F F F 684 105 225 475 F 106 D D D D / D D D / / D D D / F F F F D D D D / D D F / / D D D / F F F F F F F F F F F F D / D D F D / D D F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 226 476 F D D / D D D / F F D D / D D F / F F F F F F F F F 说明 容量容差: COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%),K(±10%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%);Y5V: M(±20%);Z(-20,+80%) 厚度: B:0.60±0.1mm 、D:0.85±0.1mm、F:1.25±0.2mm; 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: COG(0.5pF~4.9pF): B/C; COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%);Y5V: M(±20%);Z(-20,+80%) Thickness: B:0.60±0.1mm、D:0.85±0.1mm、F:1.25±0.2mm; Above capacitance for reference only, actual cap. Range depends on the standard products. 11 F F F F F 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 ■ 1206[3216]尺寸 尺寸 1206[3216] 系列 COG (N) 型 X7R (B) X6S (S) X5R (X) X7T (T) Y5V (F) 号 CP VDC 0R5 1R0 2R0 3R0 4R0 5R0 6R0 7R0 8R0 9R0 100 120 150 180 200 220 270 300 330 390 470 560 2 0 0 0 D D D D D D D D D D D D D D D D / E / F D / E / F D / E / F D / E / F D / E / F D / E / F D / E 1 6 5 2 1 5 2 1 2 1 6 5 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6 0 3 0 5 0 0 5 6 0 0 3 0 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 · 0 5 6 0 · 0 0 0 0 0 0 0 0 0 0 0 3 3 3 3 3 0 0 0 D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 12 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 680 820 101 121 151 181 201 221 271 331 391 471 561 681 821 102 152 182 222 272 332 472 562 682 103 153 183 223 273 333 393 473 563 / F D / E / F D / E / F D / E / F D / E / F D D D D D D D D D D D D D D D D D / D D D D D D D F F F F F E D / D D D D D D D F F F F F E D / E D / E D / E D / E D / E D / E D / E D / E D D D D D D D F F F F F D D D D D D D F F F F F D D D D D D D F F F F F D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D F D D D D D D D D D D D D F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 13 D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 683 104 154 184 224 274 334 474 F D D F D D D D D D D D D D D D F F F F / / H H F F / / H H F / H F 684 105 205 225 475 D D D D D D D F D D D D D D D F F F F F F / H F F F F F / H D D D D D D D F D D D D D D D F F F F F F / H F F F F F / H D D D D D D D F D D D D D D D F F F F F F / H F F F F F / H D D D D D D D F E E E E E E E E E E E E F H / H 106 226 D D D D D D D F F H / H H / H D D D D D D D F F H / H H / H H / H 476 D D D D D D D F F H / H H / H H / H H / H F H / H D D D D D D D F F H / H H / H D D D D D D D F F H / H H / H H / H D D D D D D D F F H / H H / H H / H H / H F H / H D D D D D D D F F H / H H / H D D D D D D D F F H / H H / H H / H D D D D D D D F F H / H H / H H / H H / H D D D D D D D F F F F F F / H F F F F F / H F H / H D D D D D D D F F H / H H / H D D D D D D D F F H / H H / H H / H D D D D D D D F F H / H H / H H / H H / H 容量容差: COG(0.5pF~4.9pF): B/C;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%),K(±10%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%); Y5V: M(±20%);Z(-20,+80%) D:0.85±0.1mm 、E:1.00±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、1.60±0.3*mm; 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: COG(0.5pF~4.9pF): C ;COG(5.0pF~9.9pF): D;COG(≥10pF): F(±1%), G(±2%), J(±5%) X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%); Y5V: M(±20%);Z(-20,+80%) Thickness: D:0.85±0. 1mm、E:1.00±0. 1mm、F:1.25±0.2mm、H:1.60±0.2mm、1.60±0.3*mm; Above capacitance for reference only, actual cap. Range depends on the standard products. 14 D D D D D D D F D D D D D D D F D D D D D D D F F F F F F F F F E E E E 说明 厚度: D D D D D D D F F F F F F F F F F F F F F / / H H 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 ■ 1210[3225]尺寸 尺 寸 1210[3225] 系 列 COG (N) 型 X7R (B) X6S (S) X5R (X) X7T (T) Y5V (F) 号 CP VDC 100 120 150 180 200 220 270 300 330 390 470 560 680 820 101 121 151 181 201 221 271 331 391 471 561 681 821 102 152 182 222 272 332 472 2 0 0 0 D D D D D D D D D D D D D D D F F F F F 1 5 2 1 5 2 1 6 5 2 1 5 2 1 1 6 5 2 1 1 6 5 2 1 1 6 2 1 1 6 4 5 2 1 1 6 0 0 5 0 0 0 0 3 0 5 0 0 5 6 0 · 0 5 6 0 · 0 5 6 0 · 5 6 0 · 0 5 6 0 · 0 0 0 0 0 0 0 0 0 0 3 3 3 3 3 0 0 0 D D D D D D D D D D F F F F D D D D D D D D D D D D D D D D D F D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 562 F F F F F 682 F F F F F 103 F F F F F 153 F F F F F 223 H H F F 333 H H F F 473 G G F F 563 F F 683 F F 104 F F 154 H H 15 产品容量范围 Product Capacitance Range 多层片式陶瓷电容器产品目录 224 G H 334 G 394 G 474 G G G G G G G G G G G G G G G G G G G G G G G G G G 684 H H H H H H H H H H H H H H H H H H H H H H H H H H 105 H H H H H H H H H H H H H H H H H H H H H H H H H H 225 H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H / H H H / H H H / H H H / H H H / H H H G G G G G M G M M M G M M M G M M M G M M M G M M 475 106 226 M M M M M M M M M M M M M M M 476 M M M M M M M M M M 107 M M M M M 说明 容量容差: COG(≥10pF): F(±1%), G(±2%), J(±5%),K(±10%); X7R/X5R/X6S/X7T:J(±5.0%);K(±10%);M(± 20%); Y5V: M(±20%);Z(-20,+80%) 厚度: D:0.85±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、G:2.00±0.20mm 、M:2.50±0.30mm; 以上容量仅供参考,具体容量取决于使用要求。 Tolerance: COG(≥10pF): F(±1%), G(±2%), J(±5%); X7R/X5R/X6S/X7T: J(±5.0%);K(±10%);M(±20%); Y5V: M(±20%);Z(-20,+80%) Thickness: D:0.85±0.1mm 、F:1.25±0.2mm 、H:1.60±0.2mm 、G:2.00±0.20mm 、M:2.50±0.30mm; Above capacitance for reference only, actual cap. Range depends on the standard products. 16 产品尺寸 Dimensions 多层片式陶瓷电容器产品目录 产品尺寸 Dimensions 规格: 0201 、0402 、0603 、0805 、1206 、1210。 Chip Size:0201,0402,0603,0805, 1206 and 1210 规格 L W Type (mm) (mm) e (mm) g min T (mm) (mm) 0201 0.60±0.03 0.30±0.03 0. 1~0.2 0.2 0.30±0. 03 0402 1.00±0. 10 0.50±0. 10 0. 15~0.3 0.4 0.50±0. 10 —— —— —— —— 0603 1.60±0. 10 0.80±0. 10 0.2~0.6 0.5 0.80±0. 10 —— —— —— —— 0603*1 1.60±0.20*1 0.80±0.20*1 0.2~0.6 0.5 0.80±0.20*1 —— —— —— —— 0.2~0.7 0.7 0.60±0. 10 0.85±0. 10 1.25±0.20 —— —— 0805*1 2.00±0.20*1 1.25±0.20*1 0.2~0.7 0.7 0.60±0. 10 0.85±0. 10 1.25±0.20 —— —— 2.00±0. 10 0805 1.25±0. 10 1206 3.20±0.20 0.3~0.8 1.6 0.85±0. 10 1.00±0. 10 1.25±0.20 1.60±0.20 —— 1206*1 3.20±0.30*1 1.60±0.30*1 0.3~0.8 1.6 0.85±0. 10 1.00±0. 10 1.25±0.20 1.60±0.30*1 —— 1210 3.20±0.30 0.3~0.8 1.6 0.85±0. 10 1.25±0.20 1.60±0.20 2.00±0.20 2.50±0.30 1210*1 3.20±0.40*1 2.5±0.30*1 0.3~0.8 1.6 0.85±0. 10 1.25±0.20 1.60±0.20 2.00±0.20 2.50±0.30 *1 1.60±0.20 2.5±0.20 标识该规格型号标识为 1uF 及以上规格产品尺寸。 17 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 技术要求和测试条件 Specification and Test Condition ■ 外观 Appearance 类型 Dielectrics COG/X7R/X5R/Y 5V /X7T/X6S 技术要求 Specification 测试条件 Testing Condition 1/10L<L≤1/8L, 1/10W<W≤1/8W, 1/10T<t≤1/8T(I、W 、T 任意一项不符 合,均判定不合格) (I、W 、T None is acceptable ,All judged unqualified) 目视检查 Visual inspection. ■ 尺寸 Dimensions 类型 Dielectrics COG/X7R/X5R/Y 5V/ X7T/X6S 技术要求 Specification 测试条件 Testing Condition 在要求的范围内 用千分尺 Using calipers on micrometer Within the specified dimensions ■ 容量 Capacitance 类型 Dielectrics COG 技术要求 Specification 在要求的容值容差范围内 1.0±0.2Vrms, 1MHz±10% Within the specified tolerance (C>1000pF,1.0±0.2Vrms, 1KHz±10% ,) A:±0.05pF; B:±0.1pF; C:±0.25pF; D:±0.5pF; J: ±5% X7R/X5R/X7T /X6S 在要求的容值容差范围内 tolerance Within the specified J: ±5%;K: ±10%; M: ±20% 在要求的容值容差范围内 Y5V 测试条件 Testing Condition 1.0±0.2Vrms, 1KHz±10% (Cp>10uF,0.5±0. 1Vrms, 120±24Hz) 1.0±0.2Vrms, 1KHz±10% (Cp>10uF,0.5±0. 1Vrms, Within the specified tolerance 120±24Hz) M: ±20%; Z: -20%, +80% 备注: 测试温度:25℃±3℃,测试湿度:<70%RH. 针对二类介质规格需去老化处理,条件:电容器在 150℃热处理 1 小时, 放置 48h 后进行测量。 18 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 损耗 Dissipation Factor 类型 Dielectrics 测试条件 Testing Condition 技术要求 Specification 1.0±0.2Vrms, 1MHz±10% ,25 ℃ Cp1000pF, 1.0±0.2Vrms, 1K Hz±10%) Cp≥30pF, Q≥1000 0201 ≤25v ≤25v 0402 >25v ≤25v 0603 >25v X7R/X5R/X7T /X6S ≤25v 0805 >25v ≤25v 1206 >25v 1210 ≤25v UR DF UR≥50v C≤0.22 ㎌ ≤10.0% C≤0.47 ㎌ ≤7.0% C>0.47 ㎌ ≤10.0% C≤0.1 ㎌ ≤7.0% C>0.1 ㎌ ≤10.0% C≤0.47 ㎌ ≤7.0% C>0.47 ㎌ ≤10.0% C≤0.1 ㎌ ≤5.0% 0.1 ㎌<C≤0.22 ㎌ ≤7.0% C>0.22 ㎌ ≤10.0% C≤1 ㎌ ≤7.0% C>1 ㎌ ≤10.0% C≤0.47 ㎌ ≤7.0% C>0.47 ㎌ ≤10.0% C<2.2 ㎌ ≤7.0% 2.2 ㎌≤C<47 ㎌ ≤10.0% C>1 ㎌ ≤7.0% 1 ㎌≤C<47 ㎌ ≤10.0% C<2.2 ㎌ ≤7.0% 2.2 ㎌≤C<47 ㎌ ≤10.0% 1.0±0.2Vrms, 1KHz±10% ( Cp > 10uF,0.5±0.1Vrms, 120±24Hz) 备注 DF≤7.0% 683>0402≥473,474>0603≥104 DF≤7.0% UR=25v Y5V DF≤9.0% 105>0805≥334,475>1206≥684 1.0±0.2Vrms, 1KHz±10%, 106>1210≥105 (Cp > 10uF,0.5 ± 0.1Vrms, 0402≥683, 0603≥474 0805≥105 120±24Hz) 1206≥475, 1210≥106 25 ℃ , 预 处 理 后 48hrs 。 at DF≤9.0% UR=16v DF≤12.5% UR=10v DF≤12.5% UR=6.3v DF≤15.0% 0402≥224, 0603≥225, 0805≥335 25 ℃ ,48hrs after annealing 1206≥106,1210≥226, 1812≥476 备注: 测试温度: 25℃±3℃,测试湿度: <70%RH. 针对二类介质规格需去老化处理,条件: 电容器在 150℃热处 理 1 小时,放置 48h 后进行测量。 19 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 绝缘电阻 Insulation Resistance 类型 Dielectrics 技术要求 Specification UR≤50V ,大于 10 GΩ 或 100Ω·F /CR(大于其中较小的数 COG/X7R/ X5R/Y5V/X7T/X6S 值) UR≤50V ,More than 10 GΩ or 100Ω·F /CR, whichever is smaller. 测试条件 Testing Condition UR≤50V 温度:25℃ Charge Time:60±5sec Temperture:25℃ UR≤400V COG/X7R/X7T/X6S U 测=UR; 充电时间:60±5 秒 U 测=UR UR>50V,大于4GΩ 或 100Ω·F/CR (大于其中较小的数值) UR>400V U 测=400V; UR>50V,More than 4 GΩ or 100Ω·F/CR , whichever is 充电时间:60±5 秒 smaller. 温度:25℃ Charge Time:60±5sec Temperture:25℃ 备注: 测试温度: 25℃±3℃,测试湿度: < 70%RH. ■ 耐电压 Dielectric Strength 类型Dielectrics 额定电压范围 耐电压性能测试方法Measuring Method Rated voltage range COG X7R/X5R/Y5V/X7T/ X6S UR≤50V 施加额定电压的 300%,5 秒,最大电流不超过50mA Force 300%Rated voltage for 5second. Max..current should not exceed 50 mA. UR≤50V 施加额定电压的250%,5 秒,最大电流不超过50mA Force 250%Rated voltage for 5second. Max..current should not exceed 50 mA. 100V≤UR<500V 施加额定电压的200%,5 秒,最大电流不 超过50mA Force 200%Rated voltage for 5second. Max..current should not exceed 50 mA. 500V≤UR<1000V COG/X7R/X7T 施加额定电压的 150%,5 秒,最大电流不 超过50mA Force 150% Rated voltage for 5second. Max..current should not exceed 50 mA. 1000V≤UR<2000V 施加额定电压的 150%,5 秒,最大电流不 超过50mA Force 150%Rated voltage for 5second. Max..current should not exceed 50 mA. UR≥2000V 施加额定电压的 120%,5 秒,最大电流不 超过30mA Force 120%Rated voltage for 5second. Max..current should not exceed 30 mA. 20 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 静电容量温度特性 Temperature Coefficient of Capacitance 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 按系列温度顺序测试电容容量 容量变化在±30ppm/℃以内 COG 容量漂移在±0.2%或±0.05p F 以内 Temperature coefficient within ±30ppm/℃; Cp drift within ±0.2% or±0.05pF Measure capacitance under follow table list temperature: 在 140~ 150℃预处理 1 小时,放置24h 后进行测量。 步骤 COG, STEP X7R,X7T 25 ±2 25 ±2 25 ±2 25 ±2 -55±3 -55±3 -55±3 -30±3 1 2 X7R/X5R X7T X6S 3 容量变化在±15%以内 Capacitance change within ±15% 容量变化在+22%, -33%以内 Capacitance change within +22%, -33% 容量变化在±22%以内 Capacitance change within ±22% 4 5 X6S Y5V Y5V 25 ±2 25 ±2 25 ±2 25 ±2 125±3 105±3 85±3 85±3 25 ±2 25 ±2 25 ±2 25 ±2 1) COG 容量漂移的计算方法为: 用步骤 3 测量的电容容值量除以在第 1 、3 和 5 步骤测量得到的误差的最大值和最小值的差。 温度系数的计算以第 3 步骤测量电容容量为参考。 The capacitance drift is calculated by dividing the differences between the maximum and minimum measured values in the step 1,3 and 5. The temperature coefficient is determined using the Capacitance measured in step 3 as a reference. 2) X7R、X5R 、X7T 、X6S 容量变化在+22%, -82%以内 Capacitance change within +22%, -82% X5R 和 Y5V 与 25℃时的电容容量相比较,电容容量在温度范围内的变化在要求 的范围之内。 X7R 、X5R 、X7T 、X6S and Y5V The ranges of capacitance change compared within the above 25℃ value over the temperature ranges shall be within the specified ranges. ■ 附着力 Adhesion 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 施加6N 的压力,并保持 10±1 秒 The pressurizing force shall be 6N (=600g*f) and the duration of application shall be 10±1sec. COG/X7R/X5R/ Y5V/X7T/X6S 端电极无松动,也无其它不良现象 No removal of the terminations or other defect shall occur. 21 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 可焊性 Solder ability of Termination 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 锡炉温度: 245±5℃ X7R/X5R/X7T 端电极挂锡面积不小于 95%,针孔或粗糙面积小于 5% /X6S 95% min. coverage of both terminal electrodes and less than 5% have pin holes or rough spots. 浸入时间: 2±1 秒 两侧端电极完全浸入焊锡炉 Solder temperature: 245±5℃ Dipping time: 2±1 seconds. Completely soak both terminal electrodes in solder ■ 耐焊性 Resistance to leaching 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 预热: 120℃~ 150℃/60 秒 端电极挂锡面积不小于 95%,针孔或粗糙面积小于 5%,外 X7R/X5R/X7T /X6S 观无开裂 95% min. coverage of both terminal electrodes and less than 5% have pin holes or rough spots. No remarkable visual damage. 锡炉温度: 270±5℃ 浸入时间: 10±1 秒 两侧端电极完全浸入焊锡炉 Solder temperature: 270±5℃ preheated: 120℃~ 150℃/60sec Dipping time: 10±1 seconds. Completely soak both terminal electrodes in solder ■ 端电极结合强度 Bending 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 无可见损伤;容量变化小于等于±5%或± COG 0.5pF(取较大值) No remarkable visual damage Cp change within ±5.0% or ±0.5pF, whichever is larger. X7R/X5R/X7T /X6S 无可见损伤; 将片状电容器安装在测试夹具上,按图所示 方向以 1.0mm/s 的速率施加压力,弯曲 1mm。 Solder the capacitor on testing substrate and put it on testing stand. The middle part of substrate shall successively be pressurized by pressuring rod at a rated of about 1.0mm/sec. Until the deflection become means of the 1.0mm.) 容量变化小于等于±10% No remarkable visual damage Cp change ≤ ±10% 50 pressurizing speeding:1.0mm/sec. pressurize 无可见损伤; Y5V ≤1 capacitance meter 容量变化小于等于 ±30% No remarkable visual damage Cp change ≤ ±30% 22 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 耐焊接热 Resistance to Soldering Heat 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 无明显可见损伤 容量变化在±2.5%或±0.25pF(取较大值)以内 DF 满足产品初始值的要求 COG IR 满足产品初始值的要求 No remarkable visual damage Cp change within ±2.5% or ±0.25pF, whichever is larger. 焊接温度: 270±5℃ DF meets initial standard value. 预热: 120~ 150℃ 60 秒 IR meets initial standard value. 浸 入 在 室 温 时 间 下 放 置 : 10±1 24±2 (COG) 48±4(X7R 、 X5R、Y5V 、X7T 、X6S) 无明显可见损伤 时以后测量 试验后在标准条件下恢复 容量变化在±7.5%以内 *高介电常数电容器的初始值测量 /X6S 小 温下 放置 48±4 小时 IR 满足产品初始值的要求 测量初始值 Soldering temperature: 270±5℃ Preheating: 120~ 150℃ 60sec. Dipping time: 10±1 seconds. Measurement to be made after being kept at room temperature for 24±2 (COG) or 48±4(X7R ,X5R, Y5V 、X7T 、X6S) hours. Recovery for the following period under the standard condition after test. *Initial measurement for high dielectric constant type Perform a heat treatment at 140~ 150 ℃ for 1hr and let sit for 48±4hrs at room temperature. Perform the initial measurement. No remarkable visual damage Cp change within ±7.5% DF meets initial standard value. IR meets initial standard value. 无明显可见损伤 容量变化在±20%以内 DF 满足产品初始值的要求 Y5V 或 在 140~ 150℃进行 1 小时的热处理后在室 DF 满足产品初始值的要求 X7R/X5R/X7T 秒 IR 满足产品初始值的要求 No remarkable visual damage Cp change within ±20% DF meets initial standard value. IR meets initial standard value 23 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 温度快速循环 Temperature Cycle 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 无明显可见损伤 容量变化在±2.5%或 ±0.25pF (取较大值) 以 内 No remarkable visual damage COG Cp change within ±2.5% or ±0.25pF, whichever is larger. 按下列步骤进行 5 次循环: To perform 5 cycles of the stated environment 步骤温度 Step Temperature 下限类别温度 +0/-3℃ 25℃ 上限类别温度 +3/-0℃ 25℃ 无明显可见损伤 X7R/X5R/X7T /X6S 在室温下放置 48±4 (X7R, X5R, Y5V、X7T、 X6S) 小时以后测量 容量变化在±7.5%以内 *高介电常数电容器的初始值测量在 140~ No remarkable visual damage 150℃进行 1 小时的热处理后在室温下放置 Cp change within ±7.5% 48±4 小时测量初始值 Measurement to be made after being kept at room temperature for 24±2hrs (COG) or 48±4hrs (X7R, X5R, Y5V、X7T、X6S) at room temperature, then measure. *Initial measurement for high dielectric constant type Perform a heat treatment at 140~ 150 ℃ for 1hr and let sit for 48±4hrs at room temperature. Perform the initial measurement. 无明显可见损伤 Y5V 容量变化在±20%以内 No remarkable visual damage Cp change within ±20% 24 技术要求和测试条件 Specification and Test Condition 多层片式陶瓷电容器产品目录 ■ 温度快速循环 Temperature Cycle 类型 Dielectrics 技术要求 Specification 测试条件 Testing Condition 外观无明显可见损伤 容量变化在±5%或 ±0.5pF(取较大值) 以内 Cp
