1N5338B - 1N5388B
AXIAL LEADED SILICON ZENER DIODES
VOLTAGE RANGE: 5.1 - 200V
POWER: 5.0Wa t t s
Features
! Complete Voltage Range 5.1 to 200 Volts
! High peak reverse power dissipation
! High reliability
B
A
! Low leakage current
A
Mechanical Data
C
D
Case: DO-201AD, Molded Plastic
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: Cathode Band
Weight: 1.2 grams (approx.)
Mounting Position: Any
Marking: Type Number
DO-201AD
Dim
Min
Max
A
25.40
¾
B
7.20
9.50
C
1.20
1.30
D
4.80
5.30
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
Rating
@ TA = 25°C unless otherwise specified
Symbol
Value
Unit
DC Power Dissipation at T L = 75°C
PD
5.0
W
Maximum Forward Voltage at IF = 1 A
VF
1.2
RθJA
45
K/W
Junction Temperature Range
TJ
- 65 to + 200
°C
Storage Temperature Range
Ts
- 65 to + 200
°C
Maximum Thermal Resistance Junction to Ambient Air
Note : (1) T L = Lead temperature at 3/8 " (9.5mm) from body
Fig. 2 TYPICAL THERMAL RESISTANCE
Fig. 1 POWER TEMPERATURE DERATING CURVE
50
JUNCTION-TO-LEAD THERMAL
RESISTANCE (C°/W)
PD, MAXIMUM DISSIPATION
(WATTS)
5
4
3
L = 3/8" (9.5mm)
2
1
50
75
100
125
150
TL, LEAD TEMPERATURE (°C)
175
200
40
30
0.4
0.6
0.8
1.0
LEAD LENGTH TO HEATSINK(INCH)
1 of 2
www.sunmate.tw
Nominal Zener
Maximum Zener
Voltage
TYPE
1N5338 B
1N5339B
1N5340B
1N5341B
1N5342B
1N5343B
1N5344B
1N5345B
1N5346B
1N5345B
1N5348B
1N5349 B
1N5350B
1N5351B
1N5352B
1N5353B
1N5354B
1N5355B
1N5356B
1N5357 B
1N5358B
1N5359 B
1N5360B
1N5361B
1N5362B
1N5363B
1N5364B
1N5365B
1N5366B
1N5367 B
1N5368B
1N5369 B
1N5370B
1N537 1B
1N5372B
1N537 3B
1N5374B
1N537 5B
1N5376B
1N537 7 B
1N5378B
1N537 9 B
1N5380B
1N538 1B
1N5382B
1N538 3B
1N5384B
1N538 5B
1N5386B
1N538 7 B
1N538 8 B
Impedance
Maximum Reverse
Maximum DC
Leakage Current
Zener Current
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
(V)
(mA)
(Ω)
(Ω)
(mA)
(μA)
(V)
(mA)
5.1
5.6
6.0
6.2
6.8
7.5
8.2
8.7
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
28
30
33
36
39
43
47
51
56
60
62
68
75
82
87
91
100
110
120
130
140
150
160
170
180
190
200
240
220
200
200
175
175
150
150
150
125
125
100
100
100
75
75
70
65
65
65
50
50
50
50
50
40
40
30
30
30
25
25
15
15
12
12
10
10
8.0
8.0
8.0
8.0
5.0
5.0
5.0
1.5
1.0
1.0
1.0
1.0
1.5
1.5
2.0
2.0
2.0
2.5
2.5
2.5
2.5
2.5
2.5
2.5
2.5
3.0
3.0
3.5
3.5
4.0
5.0
6.0
8.0
10
11
14
27
35
40
42
44
45
65
75
75
90
125
170
190
230
330
350
380
430
450
480
400
400
300
200
200
200
200
200
150
125
125
125
100
75
75
75
75
75
75
75
75
100
110
120
130
140
150
160
170
190
210
230
280
350
400
500
620
720
760
760
800
1000
1150
1250
1500
1500
1650
1750
1750
1850
1850
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
10
10
10
10
7.5
5.0
5.0
2.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
1.0
2.0
3.0
3.0
5.2
5.7
6.2
6.6
6.9
7.6
8.4
9.1
9.9
10.6
11.5
12.2
12.9
13.7
14.4
15.2
16.7
18.2
19.0
20.6
21.2
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
45.5
47.1
51.7
56.0
62.2
66.0
69.2
76.0
83.6
91.2
98.8
106
114
122
129
137
144
152
930
856
790
765
700
630
580
545
520
475
430
395
365
340
315
295
280
265
250
237
216
198
190
176
170
158
144
132
122
110
100
93.0
86.0
79.0
76.0
70.0
63.0
58.0
54.5
52.5
47.5
43.0
39.5
36.6
34.0
31.6
29.4
28.0
26.4
25.0
23.6
2 of 2
IR @ V R
IZM
www.sunmate.tw
很抱歉,暂时无法提供与“1N5349B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91448
- 50+0.75443
- 150+0.67439
- 1000+0.60442
- 2000+0.55641
- 5000+0.53239
