FPV453215E330PKT
FPV453215E330PKT
    FH(风华)
    压敏电阻 45V 1812
FPV453215E330PKT 数据手册
(MLV) MULTILAYER CHIP VARISTOR MLV 0.1J 0 10-9 10-6 30V, 0.1J 174 Downloaded From Oneyac.com 10-3 Current(A) 30V, 0.1J 10+0 48V, 0.1J 10+3 48V, >0.1J MLV INTRODUCTION FO FPV SERIES MULTILAYER VB VS. TEMPERATURE Voltag as Percent of Average Breakdown Vdtage Temperature Dependence of Voltage 100 90 80 70 60 50 40 30 20 10 10-9 10-7 10-8 10 -5 10 -6 10 -4 10 -3 10 -2 Current(A) -40 25 85 125 ENERGY AND CAPACITANCE VS. TEMPERATURE PERCENT OF RATED CALUE TYPICAL CAPACITANCE VS TEMPERATURE +25 100 +20 60 40 20 +15 +10 +5 Av -5 -10 -15 -55 50 60 70 80 -25 90 100 110 120 130 140 150 AMBIENT TEMPERATURE( ag e 25 -20 0 er 0 Reference Capacitance Relative to 25 80 -40 -20 0 20 40 60 Temperature ( ) 80 100 120 140 ) RELIABILITY TEST DATA Heat resistance (High-Temperature load) Test Sample:FPV100505G3R3 Low Temperature Resistance Test Sample:FPV160808G5R5 10 10 voltage(V) 10 voltage(V) 10 2 1 High Temperature life test: 10 -1 10 -2 10 -3 Vdc max applied at 85 0 hour 1000 hours 1 Low Temperature Resistance 10 -5 10 -4 10 -3 10 -2 10 -1 1 10 10 2 10 -1 test at -40 10 -2 10 -6 10 10 2 0 hour 500 hours -3 -6 10 10 3 -5 10 5 4 3 2 1 0 -1 -2 -3 -4 -5 voltage(V) 10 1 10 -2 10 -3 Temal Shock Test 10+85 at 30 minute -40 0 cycle 100 cycles -6 10 10 -5 10 -4 10 -3 10 -2 10 -1 10 -2 10 -1 1 10 10 2 10 3 FPV20109G5R6, FPV321611G5R6 Test Sample:FPV100505G5R6,FOV160808G5R6 2 -1 -3 Resistamce to Solder Heat Thermal Shock (Temperature cycle) Test Sample:FPV100505G5R6 10 10 Current(mA) Current(mA) 10 -4 1 10 10 2 10 3 Resustance to solder heat Test 260 10 ,10sec 1005 Current(mA) 1608 2012 Chip Size 175 Downloaded From Oneyac.com 3216 MULTILAYER CHIP VARISTOR ARRAY CVA 3216 - 4 (L Product Code 3R3 G W P M T T) (mm) Configuration Product Series 2 S Working DC Voltage Termination Tolerance Dimensions 3216 CVA Multilayer Chip Varistor Array 2010 3.2 2.0 1.6 1.0 0.9 0.5 4 2 Array 4Array High speed type 3R3 3.3V P 180 18V S Plated Non-plated G General type K 10% L 15% M 20% Packaging Style T B Tape & Reel Bulk SHAPE AND DIMENSIONS & EQUIVALENT CIRCUIT unit mm(inch) Part No. L W T E1 E2 D 2010 2.0 0.15 1.0 0.15 0.5 0.1 0.20+0.15/-0.1 2.0 0.15 2.0 0.15 (0804) (0.079 0.008) (0.039 0.006) (0.035 0.008) (0.010+0.006/-0.004) (0.079 0.006) (0.079 0.006) 3216 3.2 0.2 1.6 0.2 0.9 0.1 0.35 0.2 0.3 0.2 0.8 0.1 (1206) (0.126 0.008) (0.063 0.008) (0.035 0.008) (0.014 0.008) (0.012 0.008) (0.031 0.004) 176 Downloaded From Oneyac.com MLV INTRODUCTION FO FPV SERIES MULTILAYER Multilayer Chip Varistor Array Electrical Characteristics Per Element Reduced component placement costs. PCB Downsize PCB. Use in multiple lines for transient voltage suppression. Working voltage PART Number Varistor voltage @1mA DC Maximum Clamping Voltage 8/20 s 1A Energy Absorb 10/1000 s Peak Current 8/20 s Typical Capacitance @1MHz DC AC Volts Volts VB VB Volts Joules Amps pF 5.6 4 8 20% 19 0.1 30 225 CVA2010-2G9R0 L 9 6.4 12 15% 30 0.1 30 150 CVA2010-2G140 L 14 10 18 15% 35 0.1 30 125 CVA2010-2G180 L 18 12.7 24 15% 44 0.1 30 125 60 0.05 20 FH(风华高科) Downloaded From Oneyac.com
FPV453215E330PKT 价格&库存
很抱歉,暂时无法提供与“FPV453215E330PKT”相匹配的价格&库存,您可以联系我们找货
FPV453215E330PKT
    • 20+0.98599
    • 200+0.92799
    • 600+0.86999
    • 3000+0.81199
