CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PCMB063T-000
REVISION
: A2
PAGE
: 1 OF 5
Power Choke Coil PCMB063T type
Features
High performance (Isat) realized by metal dust core.
Low profile Thickness max. 3.0mm
Low loss realized with low DCR
Capable of corresponding high frequency (3MHz)
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
L
A'
A
B
W
B'
Code
L
W
T
A
A’
B
B’
H
Dimensions (mm)
6.95 ± 0.35
6.6 ± 0.2
2.8 ± 0.2
1.6 ± 0.3
2.0 ± 0.1
3.0 ± 0.3
3.6 ± 0.2
0 ~ +0.15
T
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown above after confirming and safety.
B
A
C
A
3.5
B
3.7
C
8.4
Unit : mm
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PCMB063T-000
REVISION
: A2
PAGE
: 2 OF 5
Specifications
Part Number
PCMB063T-R10MS
PCMB063T-R15MS
PCMB063T-R20MS
PCMB063T-R22MS
PCMB063T-R33MS
PCMB063T-R36MS
PCMB063T-R47MS
PCMB063T-R56MS
PCMB063T-R68MS
PCMB063T-R82MS
PCMB063T-1R0MS
PCMB063T-1R2MS
PCMB063T-1R5MS
PCMB063T-2R2MS
PCMB063T-2R5MS
PCMB063T-3R3MS
PCMB063T-4R7MS
PCMB063T-5R6MS
PCMB063T-6R8MS
PCMB063T-8R2MS
PCMB063T-100MS
L0
Inductance
( µH )
@ (0A)
0.10
0.15
0.20
0.22
0.33
0.36
0.47
0.56
0.68
0.82
1.0
1.2
1.5
2.2
2.5
3.3
4.7
5.6
6.8
8.2
10.0
Rdc ( mΩ)
Typical
1.5
1.9
2.4
2.5
3.0
2.6
3.5
4.7
4.5
7.0
8.5
10.0
10.6
18.0
20.0
25.0
32.5
39.0
54.0
54.0
62.0
Maximum
1.7
2.5
3.0
2.8
3.5
3.9
4.1
5.0
5.0
7.5
9.0
12.0
12.1
20.0
22.0
28.0
35.0
42.0
60.0
60.0
68.0
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Typical
Typical
32.5
30.0
24.0
23.0
21.0
20.0
18.0
16.5
16.0
14.0
12.0
10.0
10.0
8.0
7.0
6.5
5.5
5.5
4.5
4.5
4.0
60.0
45.0
41.0
40.0
25.0
26.0
20.0
25.5
17.0
16.0
15.0
20.0
14.0
10.0
14.0
10.0
6.5
6.0
8.0
6.0
5.5
*: If you require another part number please contact with us.
**:Inductance Tolerance ± 20%
: All test data is referenced to 25℃ ambient.
Note 2.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 3.: Isat : DC current (A) that will cause Lo to drop approximately 30%
Note 4.: Operating Temperature Range -55℃ to + 125℃
Note 5.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case operating
Note 1.
conditions. Circuit design , component placement, PWB trace size and thickness, airflow and
other cooling provision all affect the part temperature. Part temperature should be verified in the
end application.
Note 6.
: The rated current as listed is either the saturation current or the heating current depending on
which value is lower.
CYNTEC CO., LTD.
乾坤科技股份有限公司
PAGE
: 3 OF 5
80
0.10
0.08
60
0.06
40
0.04
INDUCTANCE(µH)
0.02
TEMP RISE ( )
15
DC BIAS(Amps )
50
80
60
INDUCTANCE(µH)
0.09
TEMP RISE (
0.06
40
0.00
10
15
30
DC BIAS(Amps)
35
40
45
PCMB063T-R22MS
0.30
100
100
0.20
60
0.15
40
0.10
INDUCTANCE(µH)
0.05
0.00
10
15
30
DC BIAS(Amps )
35
40
0.40
80
0.32
60
INDUCTANCE(µH)
40
0.12
0.00
4
6
8
TE MP RISE ( )
100
0.24
TEMP RISE (
10
15
30
35
40
45
80
60
INDUCTANCE(µH)
0.16
TEMP RISE (
40
0.00
6
0.80
9
12
15
18
DC BIAS(Amps)
21
24
27
30
100
PCMB063T-R56MS
100
0.30
60
INDUCTANCE(µH)
TEMP RISE (
0.20
40
0.10
6
9
12
15
18
DC BIAS(Amps)
21
24
27
INDUCTANCE(µH)
80
TEMP RISE( )
INDUCTANCE(µH)
0.70
0.40
DC BIAS(Amps)
PCMB063T-R47MS
100
PCMB063T-R36MS
0.24
10 12 14 16 18 20 22 24 26 28 30
0.50
DC BIAS(Amps)
0.30
0.18
40
INDUCTANCE(µH)
0.10
45
PCMB063T-R33MS
0.36
0.15
INDUCTANCE(µH)
5
60
0.00
0.05
TEMP RISE ( )
80
TEMP RISE( )
80
INDUCT ANCE(µH)
0.25
0.25
0.12
55 60 65
PCMB063T-R20MS
0.30
0.15
TEMP RISE( )
5
100
80
0.60
0.50
60
0.40
40
0.30
INDUCTANCE(µH)
0.20
TEMP RISE (
10
15
DC BIAS(Amps)
25
30
TEMP RISE( )
PCMB063T-R15MS
0.18
TEMP RISE( )
INDUCTANCE (µH)
: A2
TEMP RISE( )
100
0.12
I NDUCTANCE(µH)
REVISION
TEMP RISE(
PCMB063T-R10MS
INDUCTANCE(µH)
0.14
INDUCTANCE(µH)
: PCMB063T-000
Current Characteristic
TEMP RISE( )
DOCUMENT
80
0.75
60
INDUCTANCE(µH)
40
0.15
9
12
15
DC BIAS(Amps)
18
21
10
12
14
16
18
24
14
16
18
80
60
40
0.40
INDUCT ANCE(µH)
TEMP RISE (
5
10
DC BIAS(Amps)
PCMB063T-2R2MS
2.80
100
100
80
1.20
INDUCT ANCE(µH)
60
TEMP RISE ( )
40
0.90
0.60
INDUCTANCE(µH)
2.40
1.50
2
4
3.60
6
8 10 12 14
DC BIAS(Amps)
16
18
60
1.80
40
INDUCTANCE(µH)
0.60
TEMP RISE (
4
6
8
10
12
DC BIAS(Amps)
14
16
TEMP RISE (
0.80
18
40
4
3.60
6
8
DC BIAS(Amps)
10
12
14
100
PCMB063T-3R3MS
3.00
1.20
INDUCTANCE(µH)
1.20
0.00
100
3.00
60
1.60
22
PCMB063T-2R5MS
80
2.00
0.40
PCM B063T-1R5MS
100
PCMB063T-1R2MS
0.60
0.00
0.00
INDUCTANCE(µH)
8
0.80
INDUCTANCE(µH)
INDUCTANCE( µH)
40
6
TEMP RISE( )
8
10
12
DC BIAS(Amps)
4
1.00
0.00
6
1.20
0.20
4
40
0.15
0.20
TEMP RISE (
0.00
TEMP RISE( )
INDUCTANCE(µH)
60
TEMP RISE (
60
0.30
100
0.80
0.40
80
INDUCTANCE(µH)
100
DC BIAS(Amps)
1.00
0.60
: 4 OF 5
PCMB063T-R82MS
0.45
24
PCMB063T-1R0MS
1.20
PAGE
INDUCTANCE(µH)
INDUCTANCE(µH)
6
TEMP RISE( )
3
: A2
0.60
REVISION
TEMP RISE( )
TEMP RISE (
: PCMB063T-000
80
2.40
60
1.80
40
1.20
INDUCTANCE(µH)
0.60
TEMP RISE (
2
3
4
5
6
7
8
DC BIAS(Amps)
9
10
11
12
13
TEMP RISE( )
0.30
INDUCTANCE(µH)
0.45
0.90
TEMP RISE( )
INDUCTANCE(µH)
0.60
100
TEMP RISE( )
PCMB063T-R68MS
0.75
DOCUMENT
TEMP RISE( )
CYNTEC CO., LTD.
乾坤科技股份有限公司
4.00
3.20
INDUCTANCE( µH)
2.40
T EMP RISE ( )
60
40
1.60
INDUCTANCE(µH)
TEMP RISE( )
INDUCTANCE( µH)
80
0.80
: 5 OF 5
100
80
5.0
60
4.0
INDUCTANCE(µH)
3.0
TEMP RISE (
2.0
40
1
2
3
4
5
6
7
0.0
8
PCMB063T-6R8MS
8.00
1
2
3
4
5
DC BIAS(Amps)
60
4.00
40
3.00
INDUCTANCE(µH)
2.00
TEMP RISE (
1.00
3
4
5
6
DC BIAS(Amps)
7
8
9
100
10.0
8.0
60
7.0
40
6.0
5.0
INDUCTANCE(µH)
4.0
TEMP RISE (
3
4
DC BIAS(Amps)
5
6
7
TEMP RISE( )
80
9.0
1
80
8.00
7.00
60
6.00
INDUCTANCE(µH)
5.00
TEMP RISE (
40
4.00
PCMB063T-100MS
11.0
100
2.00
8
3.00
0.00
INDUCTANCE(µH)
TEMP RISE( )
5.00
7
9.00
80
6.00
6
PCMB063T-8R2MS
10.00
7.00
DC BIAS(Amps)
INDUCTANCE(µH)
PAGE
1.0
0.00
INDUCTANCE(µH)
: A2
6.0
4.80
REVISION
PCMB063T-5R6MS
7.0
100
: PCMB063T-000
1
2
3
4
DC BIAS(Amps)
5
6
7
TEMP RISE( )
PCMB063T-4R7MS
5.60
DOCUMENT
TEMP RISE( )
CYNTEC CO., LTD.
乾坤科技股份有限公司
很抱歉,暂时无法提供与“PCMB063T-1R0MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68902
- 50+1.37150
- 150+1.23531
