NSi824x
High Reliability Reinforced
Quad-Channel Digital Isolators
Datasheet (EN) 1.5
The NSi824x devices are high reliability quad-channel
digital isolators. The NSi824x device is safety certified by
UL1577 support several insulations withstand voltages
(3kVrms, 3.75kVrms, 5kVrms, 8kVrms), while providing
high electromagnetic immunity and low emissions at
low power consumption. The data rate of the NSi824x is
up to 150Mbps, and the common-mode transient
immunity (CMTI) is up to 250kV/us. The NSi824x device
provides digital channel direction configuration and the
default output level configuration when the input power
is lost. Wide supply voltage of the NSi824x device
supports to connect with most digital interface directly,
easy to do the level shift. High system level EMC
performance enhance reliability and stability of use.
Safety Regulatory Approvals
UL recognition: up to 5000Vrms for 1 minute per UL1577
CQC certification per GB4943.1-2011
CSA component notice 5A
DIN VDE V 0884-11:2017-01
Industrial automation system
Isolated SPI, RS232, RS485
General-purpose multichannel isolation
Motor control
Up to 5000Vrms Insulation voltage
Data rate: DC to 150Mbps
Power supply voltage: 2.5V to 5.5V
High CMTI: 250kV/us
Chip level ESD: HBM: ±8kV
Robust Electromagnetic Compatibility (EMC)
System-Level ESD, EFT, and Surge Immunity
Low Emissions
Default output high level or low-level option
Low power consumption: 1.5mA/ch (1 Mbps)
Low propagation delay:
很抱歉,暂时无法提供与“NSI8242S1-DSSR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.13480
- 10+9.05040
- 30+7.90560
- 100+6.62040
- 500+6.03720
- 1000+5.77800
- 国内价格
- 1+10.91340
- 10+8.87000
- 30+7.74790
- 100+6.48810
- 500+5.91660
- 1000+5.66250
