W78ERD2A40DL
W78ERD2A40DL
    NUVOTON(新唐)
    DIP40
    IC MCU 8BIT 64KB FLASH 40DIP
W78ERD2A40DL 数据手册
W78ERD2/W78ERD2A Data Sheet 8-BIT MICROCONTROLLER Table of Contents1. GENERAL DESCRIPTION.......................................................................................................... 3 2. FEATURES ................................................................................................................................. 3 3. PIN CONFIGURATIONS ............................................................................................................. 4 4. PIN DESCRIPTION ..................................................................................................................... 5 5. FUNCTIONAL DESCRIPTION .................................................................................................... 6 5.1 RAM ................................................................................................................................ 6 5.2 Timers/Counters ............................................................................................................. 6 5.3 Clock ............................................................................................................................... 7 5.4 Power Management ........................................................................................................ 7 5.5 Reduce EMI Emission..................................................................................................... 7 5.6 Reset ............................................................................................................................... 7 6. SPECIAL FUNCTION REGISTER .............................................................................................. 8 7. PORT 4 AND BASE ADDRESS REGISTERS .......................................................................... 30 8. INTERRUPTS ........................................................................................................................... 32 9. 10. 11. 12. 8.1 External Interrupts 2 and 3 ............................................................................................ 32 8.2 Interrupt Priority............................................................................................................. 32 PROGRAMMABLE TIMERS/COUNTERS ................................................................................ 33 9.1 Timer 0 and Timer 1 ..................................................................................................... 33 9.2 Timer/Counter 2 ............................................................................................................ 35 ENHANCED FULL DUPLEX SERIAL PORT ............................................................................ 38 10.1 MODE 0 ........................................................................................................................ 38 10.2 MODE 1 ........................................................................................................................ 39 10.3 MODE 2 ........................................................................................................................ 40 10.4 MODE 3 ........................................................................................................................ 41 10.5 Framing Error Detection................................................................................................ 42 10.6 Multi-Processor Communications ................................................................................. 42 PROGRAMMABLE COUNTER ARRAY (PCA)......................................................................... 44 11.1 PCA Capture Mode ....................................................................................................... 47 11.2 16-bit Software Timer Comparator Mode ..................................................................... 47 11.3 High Speed Output Mode.............................................................................................. 48 11.4 Pulse Width Modulator Mode ........................................................................................ 49 11.5 Watchdog Timer ........................................................................................................... 49 HARDWARE WATCHDOG TIMER (ONE-TIME ENABLED WITH RESET-OUT) ................... 50 -1- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 13. DUAL DPTR .............................................................................................................................. 50 14. TIMED-ACCESS PROTECTION .............................................................................................. 51 15. IN-SYSTEM PROGRAMMING (ISP) MODE ............................................................................. 53 16. H/W REBOOT MODE (BOOT FROM LDROM) ........................................................................ 57 17. OPTION BITS REGISTER ........................................................................................................ 58 18. ELECTRICAL CHARACTERISTICS ......................................................................................... 60 18.1 Absolute Maximum Ratings .......................................................................................... 60 18.2 D.C. Characteristics ...................................................................................................... 60 18.3 A.C. Characteristics ...................................................................................................... 62 19. TIMING WAVEFORMS ............................................................................................................. 64 20. TYPICAL APPLICATION CIRCUITS......................................................................................... 66 20.1 External Program Memory and Crystal ......................................................................... 66 20.2 Expanded External Data Memory and Oscillator .......................................................... 67 21. PACKAGE DIMENSIONS ......................................................................................................... 68 22. APPLICATION NOTE................................................................................................................ 70 23. 22.1 In-System Programming (ISP) Software Examples ...................................................... 70 22.2 How to Use Programmable Counter Array ................................................................... 74 REVISION HISTORY ................................................................................................................ 75 -2- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 1. GENERAL DESCRIPTION The W78ERD2 is an 8-bit microcontroller which is pin- and instruction-set-compatible with the standard 80C52. The W78ERD2 contains a 64-KB Flash EPROM whose contents may be updated in-system by a loader program stored in an auxiliary, 4-KB Flash EPROM. Once the contents are confirmed, it can be protected for security. The W78ERD2 also contains 256 bytes of on-chip RAM; 1 KB of auxiliary RAM; four 8-bit, bidirectional and bit-addressable I/O ports; an additional 4-bit port P4; three 16-bit timer/counters; and a serial port. These peripherals are all supported by nine interrupt sources with 4 levels of priority. The W78ERD2 has two power-reduction modes: idle mode and power-down mode, both of which are software-selectable. Idle mode turns off the processor clock but allows peripherals to continue operating, while power-down mode stops the crystal oscillator for minimum power consumption. Power-down mode can be activated at any time and in any state without affecting the processor. 2. FEATURES • • • • • • • • • • • • • • • • • • • • • • 8-bit CMOS microcontroller Pin-compatible with standard 80C52 Instruction-set compatible with 80C52 Four 8-bit I/O ports; Port 0 has internal pull-up resisters enabled by software. One extra 4-bit I/O port with interrupt and chip-select functions Three 16-bit timers Programmable clock out Programmable Counter Array (PCA) with PWM, Capture, Compare and Watchdog functions 9 interrupt sources with 4 levels of priority Full-duplex serial port with framing-error detection and automatic address recognition 64-KB, in-system-programmable, Flash EPROM (AP Flash EPRAOM) 4-KB auxiliary Flash EPROM for loader program (LD Flash EPROM) 256-byte on-chip RAM 1-KB auxiliary RAM, software-selectable Software Reset 12 clocks per machine cycle operation (default). Speed up to 40 MHz. 6 clocks per machine cycle operation set by the writer. Speed up to 20 MHz. 2 DPTR registers Low EMI (inhibit ALE) Built-in power management with idle mode and power down mode Code protection Packages: — Lead Free (RoHS) DIP 40: W78ERD2A40DL — Lead Free (RoHS) PLCC 44: W78ERD2A40PL — Lead Free (RoHS) PQFP 44: W78ERD2A40FL -3- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 3. PIN CONFIGURATIONS 40-Pin DIP T2, P1.0 T2EX, P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 RST RXD, P3.0 TXD, P3.1 INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 WR, P3.6 RD, P3.7 XTAL2 XTAL1 VSS 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 P1.5 P1.6 P1.7 RST RXD, P3.0 INT2, P4.3 TXD, P3.1 INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 T 2 , P 1 . 0 / I N T 3 , P 4 V . D 2 D A D 0 , P 0 . 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 P 3 . 7 , / R D X T A L 2 EA ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P2.4, A12 P2.3, A11 P2.2, A10 P2.1, A9 P2.0, A8 X V P T S 4 A S . L 0 1 P 2 . 0 , A 8 P 2 . 1 , A 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 A D 3 , P 0 . 3 6 5 4 3 2 1 44 43 42 41 40 7 39 38 8 37 9 36 10 35 11 34 12 33 13 32 14 31 15 30 16 29 17 18 19 20 21 22 23 24 25 26 27 28 P 3 . 6 , / W R P0.0, AD0 P0.1, AD1 P0.2, AD2 P0.3, AD3 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 44-Pin QFP 44-Pin PLCC T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 VDD P0.4, P0.5, P0.6, P0.7, P1.5 P1.6 P1.7 RST RXD, P3.0 INT2, P4.3 TXD, P3.1 AD4 AD5 AD6 AD7 EA P4.1 ALE INT0, P3.2 PSEN P2.7, A15 P2.6, A14 P2.5, A13 INT1, P3.3 T0, P3.4 T1, P3.5 P 2 . 4 , A 1 2 / I N T 3 , P 4 V . D 2 D A D 0 , P 0 . 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 A D 3 , P 0 . 3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 3 30 4 29 5 28 6 27 7 26 8 9 25 10 24 23 11 12 13 14 15 16 17 18 19 20 21 22 1 2 P 3 . 6 , / W R -4- T 2 , P 1 . 0 P 3 . 7 , / R D X T A L 2 X V P P P T S 4 2 2 A S . . . L 0 0 1 1 , , A A 8 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 P0.4, P0.5, P0.6, P0.7, AD4 AD5 AD6 AD7 EA P4.1 ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P 2 . 4 , A 1 2 Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 4. PIN DESCRIPTION SYMBOL TYPE* DESCRIPTIONS EA I EXTERNAL ACCESS ENABLE: This pin forces the processor to execute instructions in external ROM. The ROM address and data are not presented on the bus if the EA pin is high. PSEN O H PROGRAM STORE ENABLE: PSEN indicates external ROM data is on the Port 0 address/data bus. If internal ROM is accessed, no PSEN strobe signal is present on this pin. ALE O H ADDRESS LATCH ENABLE: ALE is used to enable the address latch that separates the address from the data on Port 0. ALE runs at 1/6th of the oscillator frequency. RST I L RESET: If this pin is set high for two machine cycles while the oscillator is running, the W78ERD2 is reset. XTAL1 I CRYSTAL 1: Crystal oscillator input or external clock input. XTAL2 O CRYSTAL 2: Crystal oscillator output. VSS I GROUND: ground potential. VDD I POWER SUPPLY: Supply voltage for operation. P0.0 − P0.7 I/O D P1.0 − P1.7 I/O H PORT 1: 8-bit, bi-directional I/O port, the same as that of the standard 80C52. P2.0 − P2.7 I/O H P3.0 − P3.7 I/O H PORT 3: 8-bit, bi-directional I/O port, the same as that of the standard 80C52. P4.0 − P4.3 I/O H PORT 4: 4-bit, bi-directional I/O port with chip-select functions. PORT 0: 8-bit, bi-directional I/O port, the same as that of the standard 80C52. Port 0 has internal pull-up resisters enabled by software. PORT 2: 8-bit, bi-directional I/O port with internal pull-ups. This port also provides the upper address bits when accessing external memory. * Note: TYPE I: input, O: output, I/O: bi-directional, H: pull-high, L: pull-low, D: open drain -5- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 5. FUNCTIONAL DESCRIPTION The W78ERD2 architecture consists of a core processor that supports 111 different op-codes and references 64 KB of program space and 64 KB of data space. It is surrounded by various registers; four general-purpose I/O ports; one special-purpose, programmable, 4-bit I/O port; 256 bytes of RAM; 1 KB of auxiliary RAM (AUX-RAM); three timer/counters; a serial port; and an internal 74373 latch and 74244 buffer which can be switched to port 2. This section introduces the RAM, Timers/Counters, Clock, Power Management, Reduce EMI Emission, and Reset. 5.1 RAM The W78ERD2 has two banks of RAM: 256 bytes of RAM and 1 KB of AUX-RAM. AUX-RAM is enabled by clearing bit 1 in the AUXR register, and it is enabled after reset. Different addresses in RAM are addressed in different ways. • RAM 00H − 7FH can be addressed directly or indirectly, as in the 8051. The address pointers are R0 and R1 of the selected bank. • RAM 80H − FFH can only be addressed indirectly, as in the 8051. The address pointers are R0 and R1 of the selected bank. • AUX-RAM 00H −3FFH is addressed indirectly in the same way external data memory is accessed with the MOVX instruction. The address pointers are R0 and R1 of the selected bank and the DPTR register. • Addresses higher than 3FFH are stored in external memory and are accessed indirectly with the MOVX instruction, as in the 8051. When AUX-RAM is enabled, the instruction "MOVX @Ri" always accesses AUX-RAM. When the W78ERD2 is executing instructions from internal program memory, accessing AUX-RAM does not affect ports P0, P2, WR or RD . For example, ANL AUXR,#11111101B MOV DPTR,#1234H MOV A,#56H MOVX @DPTR,A 5.2 MOV XRAMAH,#02H MOV R0,#34H MOV A,@R0 ; Enable AUX-RAM ; Write 56h to address 1234H in external memory ; Only 2 LSB effective ; Read AUX-RAM data at address 0234H Timers/Counters The W78ERD2 has three timers/counters called Timer 0, Timer 1, and Timer 2. Each timer/counter consists of two 8-bit data registers: TL0 and TH0 for Timer 0, TL1 and TH1 for Timer 1, and TL2 and TH2 for Timer 2. The operations of Timer 0 and Timer 1 are similar to those in the W78C52, and these timers are controlled by the TCON and TMOD registers. -6- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Timer 2 is controlled by the T2CON register. Like Timers 0 and 1, Timer 2 can operate as either an external event counter or an internal timer, depending on the setting of bit C/T2 in T2CON. Timer 2 has three operating modes: capture, auto-reload, and baud rate generator. In capture or auto-reload mode, RCAP2H and RCAP2L are the reload / capture registers and the clock speed is the same as that of Timers 0 and 1. 5.3 Clock The W78ERD2 is designed for either a crystal oscillator or an external clock. The W78ERD2 incorporates a built-in crystal oscillator. To make the oscillator work, a crystal must be connected across pins XTAL1 and XTAL2, and a load capacitor may be connected from each pin to ground. In addition, if the crystal frequency is higher than 24 MHz, a resistor should be connected between XTAL1 and XTAL2 to provide a DC bias. An external clock is connected to pin XTAL1, while pin XTAL2 should be left disconnected. The XTAL1 input is a CMOS-type input, as required by the crystal oscillator. As a result, the logic-1 voltage should be higher than 3.5 V. 5.4 Power Management The W78ERD2 provides two modes, idle mode and power-down mode, to reduce power consumption. Both modes are entered by software. The W78ERD2 enters Idle mode when the IDL bit in the PCON register is set. In Idle mode, the internal clock for the processor stops while the internal clock for the peripherals and interrupt logic continues to run. The W78ERD2 leaves Idle mode when an interrupt or a reset occurs. The W78ERD2 enters Power-Down mode when the PD bit in the PCON register is set. In Power-Down mode, all of the clocks are stopped, including the oscillator. The W78ERD2 leaves Power-Down mode when there is a hardware reset or by external interrupts INT0 or INT1 , if enabled. 5.5 Reduce EMI Emission If the crystal frequency is less than 25 MHz, set bit 7 in the option register to 0 to reduce EMI emissions. Please see Option Bits for more information. 5.6 Reset The external RESET signal is sampled at S5P2. To take effect, it must be held high for at least two machine cycles while the oscillator is running, as the W78ERD2 has a special glitch-removal circuit that ignores glitches on the reset line. During reset, the ports are initialized to FFH, the stack pointer to 07H, and all of the other SFR to 00H, with two exceptions—SBUF does not change, and bit 4 in PCON is not cleared. -7- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 6. SPECIAL FUNCTION REGISTER The following table identifies the Special Function Registers (SFRs) in the W78ERD2, as well as each of their addresses and reset values. F8 F0 E8 CH CCAP0H CCAP1H CCAP2H CCAP3H CCAP4H 00000000 00000000 00000000 00000000 00000000 00000000 +B CHPENR 00000000 00000000 +P4 CL CCAP0L CCAP1L CCAP2L CCAP3L CCAP4L xxxx1111 00000000 00000000 00000000 00000000 00000000 00000000 FF F7 EF +ACC E0 E7 00000000 D8 CCON CMOD CCAPM0 CCAPM1 CCAPM2 CCAPM3 CCAPM4 CKCON x0000000 00xxx000 x0000000 x0000000 x0000000 x0000000 x0000000 xx000xx1 +PSW D0 D7 00000000 C8 C0 B8 B0 A8 A0 98 90 88 80 DF +T2CON T2MOD RCAP2L RCAP2H TL2 TH2 00000000 xxxxxx00 00000000 00000000 00000000 00000000 XICON XICONH P4CONB 00000000 SFRAH SFRFD SFRCN 0xxx0xxx P4CONA 00000000 SFRAL 00000000 00000000 00000000 00000000 00000000 CF +IP SADEN CHPCON x0000000 00000000 000xx000 +P3 P43AL P43AH IPH 11111111 00000000 00000000 x0000000 +IE SADDR P42AL P42AH P4CSIN 00000000 00000000 00000000 00000000 00000000 +P2 XRAMAH 11111111 00000000 +SCON SBUF P2EAL P2EAH 00000000 xxxxxxxx 00000000 00000000 +P1 P41AL P41AH 00000000 00000000 B7 A7 00000000 11111111 BF AF WDTRST AUXR1 xxxxx0x0 C7 9F 97 +TCON TMOD TL0 TL1 TH0 TH1 AUXR 00000000 00000000 00000000 00000000 00000000 00000000 00000000 +P0 SP DPL DPH P40AL P40AH PORT PCON 11111111 00000111 00000000 00000000 00000000 00000000 00000000 00110000 8F 87 Notes: 1. SFRs marked with a plus sign (+) are both byte- and bit-addressable. 2. The text of SFR with bold type characters are extension function registers. The rest of this section explains each SFR, starting with the lowest address. -8- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Port 0 Bit: 7 6 5 4 3 2 1 0 P0.7 P0.6 P0.5 P0.4 P0.3 P0.2 P0.1 P0.0 Mnemonic: P0 Address: 80h Port 0 is an open-drain, bi-directional I/O port after chip is reset. Besides, it has internal pull-up resisters enabled by setting P0UP of POPT (86H) to high. This port also provides a multiplexed, loworder address/data bus when the W78IRD2 accesses external memory. Stack Pointer Bit: 7 6 5 4 3 2 1 0 SP.7 SP.6 SP.5 SP.4 SP.3 SP.2 SP.1 SP.0 Mnemonic: SP Address: 81h The Stack Pointer stores the RAM address (scratchpad RAM, not AUX-RAM) where the stack begins. It always points to the top of the stack. Data Pointer Low Bit: 7 6 5 4 3 2 1 0 DPL.7 DPL.6 DPL.5 DPL.4 DPL.3 DPL.2 DPL.1 DPL.0 Mnemonic: DPL Address: 82h This is the low byte of the standard-8052 16-bit data pointer. Data Pointer High Bit: 7 6 5 4 3 2 1 0 DPH.7 DPH.6 DPH.5 DPH.4 DPH.3 DPH.2 DPH.1 DPH.0 2 1 0 Mnemonic: DPH Address: 83h This is the high byte of the standard-8052 16-bit data pointer. Port 4.0 Low-Address Comparator Bit: 7 6 5 4 3 P40AL.7 P40AL.6 P40AL.5 P40AL.4 P40AL.3 P40AL.2 P40AL.1 P40AL.0 Mnemonic: P40AL Address: 84h Port 4.0 High-Address Comparator Bit: 7 6 5 4 3 2 1 0 P40AH.7 P40AH.6 P40AH.5 P40AH.4 P40AH.3 P40AH.2 P40AH.1 P40AH.0 Mnemonic: P40AH Address: 85h -9- Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Port Option Register Bit: 7 6 5 4 3 2 1 0 - - - - - - - P0UP Mnemonic: POPT BIT NAME 1–7 - 0 P0UP Address: 86h FUNCTION Reserve 0: Port 0 pins are open-drain. 1: Port 0 pins are internally pulled-up. Port 0 is structurally the same as Port 2. Power Control Bit: 7 6 5 4 3 2 1 0 SMOD SMOD0 - POR GF1 GF0 PD IDL Mnemonic: PCON BIT NAME 7 SMOD Address: 87h FUNCTION 1: Double the serial-port baud rate in serial port modes 1, 2, and 3. 0: Framing Error Detection Disable. SCON.7 acts as per the standard 8052 function. 6 SMOD0 5 - 4 POF This bit is set to 1 when a power-on reset has occurred. It can be cleared by software. 3 GF1 General-purpose flag. 2 GF0 General-purpose flag. 1 PD Set this bit to 1 to go into POWER DOWN mode. 0 IDL Set this bit to 1 to go into IDLE mode. 1: Framing Error Detection Enable. SCON.7 indicates a Frame Error and acts as the FE (FE_1) flag. Reserved Timer Control Bit: 7 6 5 4 3 2 1 0 TF1 TR1 TF0 TR0 IE1 IT1 IE0 IT0 Mnemonic: TCON Address: 88h - 10 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A BIT NAME FUNCTION 7 TF1 Timer 1 overflow flag: This bit is set when Timer 1 overflows. It is cleared automatically when the program does a timer 1 interrupt service routine. It can also be set or cleared by software. 6 TR1 5 TF0 4 TR0 3 IE1 1: Turn on Timer 1. 0: Turn off Timer 1. Timer 0 overflow flag: This bit is set when Timer 0 overflows. It is cleared automatically when the program does a timer 0 interrupt service routine. It can also be set or cleared by software. 1: Turn on Timer 0. 0: Turn off Timer 0. Interrupt 1 Edge Detect: This bit is set by the hardware when a falling-edge / lowlevel is detected on INT1 . If INT1 is edge-triggered, this bit is cleared by the hardware when the interrupt service routine begins. Otherwise, it follows the pin. Interrupt 1 type control 2 IT1 1: Interrupt 1 is triggered by a falling-edge on INT1 . 0: Interrupt 1 is triggered by a low-level on INT1 . 1 IE0 Interrupt 0 Edge Detect: This bit is set by the hardware when a falling-edge / lowlevel is detected on INT0 . If INT0 is edge-triggered, this bit is cleared by the hardware when the interrupt service routine begins. Otherwise, it follows the pin. Interrupt 0 type control 0 IT0 1: Interrupt 0 is triggered by a falling-edge on INT0 . 0: Interrupt 0 is triggered by a low-level on INT0 . Timer Mode Control Bit: 7 6 5 4 3 2 1 0 GATE C/ T M1 M0 GATE C/ T M1 M0 Mnemonic: TMOD Address: 89h BIT NAME FUNCTION 7 GATE Gating control: When this bit is set, Timer/Counter 1 is enabled only while the INT1 pin is high and the TR1 control bit is set. When cleared, the INT1 pin has no effect, and Timer 1 is enabled whenever TR1 is set. 6 C/ T Timer or Counter Select: When cleared, Timer 1 is incremented by the internal clock. When set, Timer 1 counts falling edges on the T1 pin. 5 M1 Timer 1 Mode Select bits: See below. 4 M0 Timer 1 Mode Select bits: See below. - 11 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Continued BIT NAME FUNCTION 3 GATE 2 C/ T Timer or Counter Select: When cleared, Timer 0 is incremented by the internal clock. When set, Timer 0 counts falling edges on the T0 pin. 1 M1 Timer 0 Mode Select bits: See below. 0 M0 Timer 0 Mode Select bits: See below. Gating control: When this bit is set, Timer/Counter 0 is enabled only while the INT0 pin is high and the TR0 control bit is set. When cleared, the INT0 pin has no effect, and Timer 0 is enabled whenever TR0 is set. M1, M0: Mode Select bits: M1 0 0 1 1 M0 0 1 0 1 Mode Mode 0: 8048 timer, TLx serves as 5-bit pre-scale. Mode 1: 16-bit timer/counter, no pre-scale. Mode 2: 8-bit timer/counter with auto-reload from THx Mode 3: (Timer 0) TL0 is an 8-bit timer/counter controlled by the standard Timer-0 control bits. TH0 is an 8-bit timer only controlled by Timer-1 control bits. (Timer 1) Timer/Counter 1 is stopped. Timer 0 LSB Bit: 7 6 5 4 3 2 1 0 TL0.7 TL0.6 TL0.5 TL0.4 TL0.3 TL0.2 TL0.1 TL0.0 Mnemonic: TL0 Address: 8Ah TL0.7-0: Timer 0 Low byte Timer 1 LSB Bit: 7 6 5 4 3 2 1 0 TL1.7 TL1.6 TL1.5 TL1.4 TL1.3 TL1.2 TL1.1 TL1.0 Mnemonic: TL1 Address: 8Bh TL1.7-0: Timer 1 Low byte Timer 0 MSB Bit: 7 6 5 4 3 2 1 0 TH0.7 TH0.6 TH0.5 TH0.4 TH0.3 TH0.2 TH0.1 TH0.0 Mnemonic: TH0 Address: 8Ch TH0.7-0: Timer 0 High byte - 12 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Timer 1 MSB Bit: 7 6 5 4 3 2 1 0 TH1.7 TH1.6 TH1.5 TH1.4 TH1.3 TH1.2 TH1.1 TH1.0 1 0 Mnemonic: TH1 Address: 8Dh TH1.7-0: Timer 1 High byte Auxiliary Register Bit: 7 6 5 4 3 2 - - - - - - Mnemonic: AUXR BIT NAME 7~2 - 1 EXTRAM 0 ALEOFF EXTRAM ALEOFF Address: 8Eh FUNCTION Reserve 0 = Enable AUX-RAM 1 = Disable AUX-RAM 0: ALE expression is enabled. 1: ALE expression is disabled. Port 1 Bit: 7 6 5 4 3 2 1 0 P1.7 P1.6 P1.5 P1.4 P1.3 P1.2 P1.1 P1.0 Mnemonic: P1 Address: 90h P1.7-0: General-purpose input/output port. Port-read instructions read the port pins, while read-modifywrite instructions read the port latch. Port 4.1 Low Address Comparator Bit: 7 6 5 4 3 2 1 0 P41AL.7 P41AL.6 P41AL.5 P41AL.4 P41AL.3 P41AL.2 P41AL.1 P41AL.0 Mnemonic: P41AL Address: 94h Port 4.1 High Address Comparator Bit: 7 6 5 4 3 2 1 0 P41AH.7 P41AH.6 P41AH.5 P41AH.4 P41AH.3 P41AH.2 P41AH.1 P41AH.0 Mnemonic: P41AH Address: 95h - 13 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Serial Port Control Bit: 7 6 5 4 3 2 1 0 SM0/FE SM1 SM2 REN TB8 RB8 TI RI Mnemonic: SCON BIT 7 Address: 98h NAME FUNCTION Serial port, Mode 0 (SM0) bit or Framing-Error (FE) Flag: The SMOD0 bit in PCON SFR determines whether this bit acts as SM0 or as FE. SM0 is described with SMI1 SM0/FE below. When used as FE, this bit indicates whether the stop bit is invalid (FE=1) or valid (FE=0). This bit must be manually cleared by software. Serial port, Mode 1 (SM1) bit: Mode: SM0 SM1 6 SM1 Description Length Baud rate 0 0 0 Synchronous 8 6(6T mode)/12(12T mode) Tclk 1 0 1 Asynchronous 10 Variable 2 1 0 Asynchronous 11 32/16(6T mode) or 64/32(12T mode) Tclk 3 1 1 Asynchronous 11 Variable Multi-processor communication. 5 SM2 (Modes 2 and 3) Set this bit to enable the multi-processor communication feature. With this feature, RI is not activated if the ninth data bit received (RB8) is 0. (Mode 1) Set this bit to 1 to keep RI de-activated if a valid stop bit is not received. (Mode 0) SM2 controls the serial port clock. If clear, the serial port runs at 1/12 the oscillator. This is compatible with the standard 8052. Receive enable: 4 REN 1 = Serial reception is enabled 0 = Serial reception is disabled 3 TB8 (Modes 2 and 3) This is the ninth bit to be transmitted. This bit is set and cleared by software as desired. (Modes 2 and 3) This is the ninth data bit that was received. 2 RB8 (Mode 1) If SM2 is 0, RB8 is the stop bit that was received. (Mode 0) No function. 1 TI Transmit interrupt flag: This flag is set by the hardware at the end of the eighth bit in mode 0 or at the beginning of the stop bit in modes 1 – 3 during serial transmission. This bit must be cleared by software. 0 RI Receive interrupt flag: This flag is set by the hardware at the end of the eighth bit in mode 0 or halfway through the stop bit in modes 1 – 3 during serial reception. However, SM2 restricts this bit. This bit can be cleared only by software. - 14 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Serial Data Buffer Bit: 7 6 5 4 3 2 1 0 SBUF.7 SBUF.6 SBUF.5 SBUF.4 SBUF.3 SBUF.2 SBUF.1 SBUF.0 Mnemonic: SBUF Address: 99h BIT NAME FUNCTION 7~0 Serial port data is read from or written to this location. It actually consists of two separate, internal 8-bit registers, the receive register and the transmit buffer. Any read SBUF access reads data from the receive register, while write access writes to the transmit buffer. Port 2 Bit: 7 6 5 4 3 2 1 0 P2.7 P2.6 P2.5 P2.4 P2.3 P2.2 P2.1 P2.0 3 2 1 0 Mnemonic: P2 Address: A0h Ram High Byte Address Bit: 7 0 6 0 Mnemonic: XRAMAH 5 0 4 0 0 0 XRAMAH.1 XRAMAH.0 Address: A1h The AUX-RAM high byte address Auxiliary 1 Register Bit: 7 6 5 4 3 2 1 0 - - - - GF2 0 - DPS Mnemonic: AUXR1 Address: A2h BIT NAME FUNCTION 7~4 - 3 GF2 2 0 The bit cannot be written and is always read as 0. 1 - Reserved 0 DPS Reserved General purpose, user–defined flag. 0 = switch to DPTR0 1 = switch to DPTR1 - 15 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Watchdog Timer Reset Register Bit: 7 6 5 4 3 2 1 0 WDTRST.7 WDTRST.6 WDTRST.5 WDTRST.4 WDTRST.3 WDTRST.2 WDTRST.1 WDTRST.0 Mnemonic: WDTRST Address: A6h Interrupt Enable Bit: 7 6 5 4 3 2 1 0 EA EC ET2 ES ET1 EX1 ET0 EX0 Mnemonic: IE Address: A8h BIT NAME FUNCTION 7 EA Global interrupt enable. Enable/disable all interrupts except for PFI. 6 EC Enable PCA interrupt. 5 ET2 Enable Timer 2 interrupt. 4 ES Enable Serial port interrupt. 3 ET1 Enable Timer 1 interrupt. 2 EX1 Enable external interrupt INT1 . 1 ET0 Enable Timer 0 interrupt. 0 EX0 Enable external interrupt INT0 . SLAVE ADDRESS Bit: 7 6 5 Mnemonic: SADDR 4 3 2 1 0 Address: A9h BIT NAME FUNCTION 7~0 SADDR The SADDR should be programmed to the given or broadcast address for serial port to which the slave processor is designated. Port 4.2 Low Address Comparator Bit: 7 6 5 4 3 2 1 0 P42AL.7 P42AL.6 P42AL.5 P42AL.4 P42AL.3 P42AL.2 P42AL.1 P42AL.0 Mnemonic: P42AL Address: Ach - 16 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Port 4.2 High Address Comparator Bit: 7 6 5 4 3 2 1 0 P42AH.7 P42AH.6 P42AH.5 P42AH.4 P42AH.3 P42AH.2 P42AH.1 P42AH.0 Mnemonic: P42AH Address: ADh Port 4 CS Inverse Bit: 7 6 5 4 3 2 1 0 P43INV P42INV P41INV P40INV 0 0 0 0 Mnemonic: P4CSIN BIT Address: AEh NAME FUNCTION The active polarity of P4.x which functions chip-select signal. 7~4 P4xINV 1: Active high 0: Active low 3~0 - Reserved and must be set zero. Port 3 Bit: 7 6 5 4 3 2 1 0 P3.7 P32.6 P3.5 P32.4 P3.3 P3.2 P3.1 P3.0 3 2 1 0 Mnemonic: P3 Address: B0h Port 4.3 Low Address Comparator Bit: 7 6 5 4 P43AL.7 P43AL.6 P43AL.5 P43AL.4 P43AL.3 P43AL.2 P43AL.1 P43AL.0 Mnemonic: P43AL Address: B4h Port 4.3 High Address Comparator Bit: 7 6 5 4 3 2 1 0 P43AH.7 P43AH.6 P43AH.5 P43AH.4 P43AH.3 P43AH.2 P43AH.1 P43AH.0 Mnemonic: P43AH Address: B5h Interrupt Priority High Bit: 7 6 5 4 3 2 1 0 - PPCH PT2H PSH PT1H PX1H PT0H PX0H Mnemonic: IPH BIT NAME 7 6 PPCH Address: B8h FUNCTION This bit is not implemented and is always read high. 1: Set the priority of the PCA interrupt to the highest level. - 17 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 5 4 3 PT2H PSH PT1H 1: Set the priority of the Timer 2 interrupt to the highest level. 1: Set the priority of the Serial Port interrupt to the highest level. 1: Set the priority of the Timer 1 interrupt to the highest level. 2 PX1H 1 PT0H 1: Set the priority of external interrupt INT1 to the highest level. 1: Set the priority of the Timer 0 interrupt to the highest level. 0 PX0H 1: Set the priority of external interrupt INT0 to the highest level. Interrupt Priority Bit: 7 6 5 4 3 2 1 0 - PPC PT2 PS PT1 PX1 PT0 PX0 Mnemonic: IP Address: B8h BIT NAME FUNCTION 7 - 6 PPC 1: Set the priority of the PCA interrupt one level higher. 5 PT2 1: Set the priority of the Timer 2 interrupt one level higher. 4 PS 1: Set the priority of the Serial Port interrupt one level higher. 3 PT1 1: Set the priority of the Timer 1 interrupt one level higher. 2 PX1 1: Set the priority of external interrupt INT1 one level higher. 1 PT0 1: Set the priority of the Timer 0 interrupt one level higher. 0 PX0 1: Set the priority of external interrupt INT0 one level higher. This bit is not implemented and is always read high. Slave Address Mask Enable Bit: 7 6 5 Mnemonic: SADEN BIT 7~0 4 3 2 1 0 Address: B9h NAME FUNCTION This register enables the Automatic Address Recognition feature of the serial port. When a bit in SADEN is set to 1, the same bit in SADDR is compared to the SADEN incoming serial data. When a bit in SADEN is set to 0, the same bit in SADDR is a "don't care" value in the comparison. The serial port interrupt occurs only if all the SADDR bits where SADEN is set to 1 match the incoming serial data. On-Chip Programming Control Bit: 7 6 5 4 3 2 SWRST/ REBOOT - - - - 0 Mnemonic: CHPCON 1 0 FBOOTSL FPROGEN Address: BFh - 18 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A BIT 7 6–2 1 0 NAME FUNCTION When FBOOTSL and FPROGEN are set to 1, set this bit to 1 to force the W: SWRESET microcontroller to reset to the initial condition, just like power-on reset. This action re-boots the microcontroller and starts normal operation. R: REBOOT Read this bit to determine whether or not a hardware reboot is in progress. Reserved Program Location Selection. This bit should be set before entering ISP mode. 0: The Loader Program is in the 64-KB AP Flash EPROM. The 4-KB LD FBOOTSL Flash EPROM is the destination for re-programming. 1: The Loader Program is in the 4-KB memory bank. The 64-KB AP Flash EPROM is the destination for re-programming. FLASH EPROM Programming Enable. 1: Enable in-system programming mode. In this mode, erase, program and FPROGEN read operations are achieved during device enters idle state. 0: Disable in-system programming mode. The on-chip flash memory is read-only. CHPCON has an unrestricted read access, however, the write access is protected by timed-access protection. See the section of timed-access protection for more information. External Interrupt Control Bit: 7 6 5 4 3 2 1 0 PX3 EX3 IE3 IT3 PX2 EX2 IE2 IT2 Mnemonic: XICON Address: C0h BIT NAME FUNCTION 7 PX3 1: Set the priority of external interrupt INT3 one level higher. 6 EX3 1: Enable external interrupt INT3 . 5 IE3 Interrupt INT3 flag. This bit is set and cleared automatically by the hardware when the interrupt is detected and processed. 4 IT3 1: INT3 is falling-edge triggered 0: INT3 is low-level triggered 3 PX2 1: Set the priority of external interrupt INT2 one level higher. 2 EX2 1: Enable external interrupt INT2 . 1 IE2 Interrupt INT2 flag. This bit is set and cleared automatically by the hardware when the interrupt is detected and processed. 0 IT2 1: INT2 is falling-edge triggered 0: INT2 is low-level triggered - 19 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A External Interrupt High Control Bit: 7 6 5 4 3 2 1 0 PXH3 - - - PXH2 - - - Mnemonic: XICONH BIT NAME 7 PXH3 6-4 - 3 PXH2 2-0 - Address: C1h FUNCTION 1: Set the priority of external interrupt INT3 to the highest level. Reserved 1: Set the priority of external interrupt INT2 to the highest level. Reserved Port 4 Control Register A Bit: 7 6 5 4 3 2 1 0 P41FUN1 P41FUN0 P41CMP1 P41CMP0 P40FUN1 P40FUN0 P40CMP1 P40CMP0 Mnemonic: P4CONA BIT 7, 6 5, 4 3, 2 1, 0 Address: C2h NAME FUNCTION P41FUN1 P41FUN0 P41CMP1 P41CMP0 P40FUN1 P40FUN0 P40CMP1 P40CMP0 P4.1 function control bits, similar to P43FUN1 and P43FUN0 below. P4.1 address-comparator length control bits, similar to P43CMP1 and P43CMP0 below. P4.0 function control bits, similar to P43FUN1 and P43FUN0 below. P4.0 address-comparator length control bits, similar to P43CMP1 and P43CMP0 below. Port 4 Control Register B Bit: 7 6 5 4 3 2 1 0 P43FUN1 P43FUN0 P43CMP1 P43CMP0 P42FUN1 P42FUN0 P42CMP1 P42CMP0 Mnemonic: P4CONB Address: C3h - 20 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A BIT 7, 6 5, 4 3, 2 1, 0 NAME FUNCTION 00: Mode 0. P4.3 is a general purpose I/O port, like Port 1. 01: Mode 1. P4.3 is a read-strobe signal for chip-select purposes. address range depends on SFR P43AH, P43AL, P43CMP1 P43CMP0. 10: Mode 2. P4.3 is a write-strobe signal for chip-select purposes. address range depends on SFR P43AH, P43AL, P43CMP1 P43CMP0. 11: Mode 3. P4.3 is a read/write-strobe signal for chip-select purposes. address range depends on SFR P43AH, P43AL, P43CMP1, P43CMP0. Chip-select signal address comparison: 00: Compare the full 16-bit address with P43AH and P43AL. 01: Compare the 15 MSB of the 16-bit address with P43AH and P43AL. 10: Compare the 14 MSB of the 16-bit address with P43AH and P43AL. 11: Compare the 8 MSB of the 16-bit address with P43AH. P43FUN1 P43FUN0 P43CMP1 P43CMP0 P42FUN1 P42FUN0 P42CMP1 P42CMP0 The and The and The and P4.2 function control bits, similar to P43FUN1 and P43FUN0 above. P4.2 address-comparator length control bits, similar to P43CMP1 and P43CMP0 above. F/W Flash Low Address Bit: 7 6 Mnemonic: SFRAL 5 4 3 2 1 0 3 2 1 0 3 2 1 0 Address: C4h F/W flash low byte address F/W Flash High Address Bit: 7 6 Mnemonic: SFRAH 5 4 Address: C5h F/W flash high byte address F/W Flash Data Bit: 7 6 Mnemonic: SFRFD 5 4 Address: C6h F/W flash data - 21 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A F/W Flash Control Bit: 7 6 5 4 3 2 1 0 0 WFWIN OEN CEN CTRL3 CTRL2 CTRL1 CTRL0 Mnemonic: SFRCN BIT NAME 7 - Address: C7h FUNCTION Reserved On-chip Flash EPROM bank select for in-system programming. This bit should be defined by the loader program in ISP mode. 6 WFWIN 0: 64-KB Flash EPROM is the destination for re-programming. 1: 4-KB Flash EPROM is the destination for re-programming. 5 OEN Flash EPROM output enable. 4 CEN Flash EPROM chip enable. 3-0 CTRL[3:0] Flash control signals Timer 2 Control Bit: 7 6 5 4 3 2 1 0 TF2 EXF2 RCLK TCLK EXEN2 TR2 C/T2 CP/RL2 Mnemonic: T2CON BIT 7 6 Address: C8h NAME FUNCTION TF2 Timer 2 overflow flag: If RCLK and TCLK are 0, this bit is set when Timer 2 overflows or when the count is equal to the value in the capture register in downcount mode. This bit can also be set by software, and it can only be cleared by software. EXF2 Timer 2 External Flag: When Timer 2 is in either capture or auto-reload mode and DCEN is 0, a negative transition on the T2EX pin (P1.1) and EXEN2=1 sets this flag. This flag can also be set by software. Once set, this flag generates a Timer-2 interrupt, if enabled, and it must be cleared by software. Receive Clock Flag: Set this bit to force Timer 2 into baud-rate generator mode when receiving data on the serial port in modes 1 or 3. 5 RCLK 1 = Timer 2 overflow is the time base. 0 = Timer 1 overflow is the time base. Transmit clock Flag: Set this bit to force Timer 2 into baud-rate generator mode when transmitting data on the serial port in modes 1 or 3. 4 TCLK 1 = Timer 2 overflow is the time base. 0 = Timer 1 overflow is the time base. - 22 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Continued BIT 3 NAME FUNCTION Timer 2 External Enable: If Timer 2 is not in baud-rate generator mode (see RCLK EXEN2 and TCLK above), set this bit to allow a negative transition on the T2EX pin to capture/reload Timer 2 counter. Timer 2 Run Control: 2 TR2 1 = Enable Timer 2. 0 = Disable Timer 2, which preserves the current value in TH2 and TL2. Counter/Timer select: 1 C/T2 0 = Timer 2 operates as a timer at a speed controlled by T2M (CKCON.5) 1 = Timer 2 counts negative edges on the T2EX pin. Capture/Reload Select: If EXEN2 is set to 1, this bit determines whether the capture or auto-reload function is activated. 0 CP/RL2 0 = auto-reload when timer 2 overflows or a falling edge is detected on T2EX 1 = capture each falling edge is detected on T2EX If either RCLK or TCLK is set, this bit has no function, as Timer 2 runs in autoreload mode. Timer 2 Mode Bit: 7 6 5 4 3 2 1 0 - - - - - - T2OE DCEN Mnemonic: T2MOD Address: C9h BIT NAME FUNCTION 7~2 - 1 T2OE Timer 2 Output Enable. This bit enables/disables the Timer 2 clock-out function. 0 DCEN Down Count Enable: Setting DCEN to 1 allows T2EX pin to control the direction that Timer 2 counts in 16-bit auto-reload mode. Reserved Timer 2 Capture Low Bit: 7 6 5 4 3 2 1 0 RCAP2L.7 RCAP2L.6 RCAP2L.5 RCAP2L.4 RCAP2L.3 RCAP2L.2 RCAP2L.1 RCAP2L.0 Mnemonic: RCAP2L Address: CAh RCAP2L Timer 2 Capture LSB: In capture mode, RCAP2L is used to capture the TL2 value. In autoreload mode, RCAP2L is used as the LSB of the 16-bit reload value. - 23 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Timer 2 Capture High Bit: 7 6 5 4 3 2 1 0 RCAP2H.7 RCAP2H.6 RCAP2H.5 RCAP2H.4 RCAP2H.3 RCAP2H.2 RCAP2H.1 RCAP2H.0 Mnemonic: RCAP2H Address: CBh RCAP2H Timer 2 Capture HSB: In capture mode, RCAP2H is used to capture the TH2 value. In autoreload mode, RCAP2H is used as the MSB of the 16-bit reload value. Timer 2 Register Low Bit: 7 6 5 4 3 2 1 0 TL2.7 TL2.6 TLH2.5 TL2.4 TL2.3 TL2.2 TL2.1 TL2.0 Mnemonic: TL2 Address: CCh TL2 Timer 2 LSB Timer 2 Register High Bit: 7 6 5 4 3 2 1 0 TH2.7 TH2.6 TH2.5 TH2.4 TH2.3 TH2.2 TH2.1 TH2.0 Mnemonic: TH2 Address: CDh TL2 Timer 2 MSB Program Status Word Bit: 7 6 5 4 3 2 1 0 CY AC F0 RS1 RS0 OV F1 P Mnemonic: PSW Address: D0h BIT NAME FUNCTION 7 CY Carry flag: Set when an arithmetic operation results in a carry being generated from the ALU. It is also used as the accumulator for bit operations. 6 AC Auxiliary carry: Set when the previous operation resulted in a carry from the high order nibble. 5 F0 General–purpose, user-defined flag 0. 4 RS1 Register bank select bits: See below. 3 RS0 Register bank select bits: See below. 2 OV Overflow flag: Set when a carry was generated from the seventh bit but not from the eighth bit as a result of the previous operation, or vice-versa. 1 F1 General–purpose, user-defined flag 1. 0 P Parity flag: Set and cleared by the hardware to indicate an odd or even number, respectively, of 1's in the accumulator. - 24 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A RS.1-0: Register bank select bits: RS1 RS0 REGISTER BANK ADDRESS 0 0 0 00-07h 0 1 1 08-0Fh 1 0 2 10-17h 1 1 3 18-1Fh PCA Counter Control Register Bit: 7 6 5 4 3 2 1 0 CF CR - CCF4 CCF3 CCF2 CCF1 CCF0 Mnemonic: CCON Address: D8h PCA Counter Mode Register Bit: 7 6 5 4 3 2 1 0 CIDL WDTE - - - CPS1 CPS0 ECF 3 2 1 0 MAT0 TOG0 PWM0 ECCF0 3 2 1 0 MAT1 TOG1 PWM1 ECCF1 3 2 1 0 MAT2 TOG2 PWM2 ECCF2 3 2 1 0 MAT3 TOG3 PWM3 ECCF3 Mnemonic: CMOD Address: D9h PCA Module 0 Register Bit: 7 - 6 5 4 ECOM0 CAPP0 CAPN0 Mnemonic: CCAPM0 Address: DAh PCA Module 1 Register Bit: 7 - 6 5 4 ECOM1 CAPP1 CAPN1 Mnemonic: CCAPM1 Address: DBh PCA Module 2 Register Bit: 7 - 6 5 4 ECOM2 CAPP2 CAPN2 Mnemonic: CCAPM2 Address: DCh PCA Module 3 Register Bit: 7 - 6 5 4 ECOM3 CAPP3 CAPN3 Mnemonic: CCAPM3 Address: DDh - 25 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A PCA Module 4 Register Bit: 7 - 6 5 4 ECOM4 CAPP4 CAPN4 Mnemonic: CCAPM4 3 2 1 0 MAT4 TOG4 PWM4 ECCF4 Address: DEh Clock Control Register Bit: 7 6 5 4 3 2 1 0 - - T2M T1M T0M - - MD Mnemonic: CKCON BIT NAME 7 - Reserved 6 - Reserved Address: DFh FUNCTION Timer 2 clock select: 5 T2M 0 = Divide-by-6 clock 1 = Divide-by-12 clock This bit has no effect if option bit 3 is set to 1 to select 12 clocks / machine cycle. Timer 1 clock select: 4 T1M 0 = Divide-by-6 clock 1 = Divide-by-12 clock This bit has no effect if option bit 3 is set to 1 to select 12 clocks / machine cycle. Timer 0 clock select: 3 T0M 0 = Divide-by-6 clock 1 = Divide-by-12 clock This bit has no effect if option bit 3 is set to 1 to select 12 clocks / machine cycle. 2 - Reserved 1 - Reserved 0 MD Stretch MOVX select bits: This bit is used to select the stretch value for the MOVX instruction, which enables the microcontroller to access slower memory devices or peripherals transparently and without the need for external circuits. The RD or WR strobe and all internal timings are stretched by the selected interval. The default value is 1 cycle. For faster access, set the value to 0. CKCON has an unrestricted read access, however, the write access is protected by timed-access protection. See the section of timed-access protection for more information. - 26 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Accumulator Bit: 7 6 5 4 3 2 1 0 ACC.7 ACC.6 ACC.5 ACC.4 ACC.3 ACC.2 ACC.1 ACC.0 Mnemonic: ACC Address: E0h ACC.7-0: The A (or ACC) register is the standard 8052 accumulator. Port 4 Bit: 7 6 5 4 - - - - Mnemonic: ACC 3 2 P4.3/INT2 P4.2/INT3 1 0 P4.1 P4.0 Address: E8h P4.3-0: Port 4 is a bi-directional I/O port with internal pull-ups. BIT NAME FUNCTION 7–4 - 3 P4.3 Port 4 Data bit which outputs to pin P4.3 in mode 0, or external interrupt INT2 . 2 P4.2 Port 4 Data bit which outputs to pin P4.2 in mode 0, or external interrupt INT3 . 1 P4.1 Port 4 Data bit which outputs to pin P4.1 in mode 0. 0 P4.0 Port 4 Data bit which outputs to pin P4.0 in mode 0. Reserved PCA Counter Low Register Bit: 7 6 5 4 3 2 1 0 CL.7 CL.6 CL.6 CL.4 CL.3 CL.2 CL.1 CL.0 3 2 1 0 Mnemonic: CL Address: E9h PCA Module 0 Compare/Capture Low Register Bit: 7 6 5 4 CCAP0L.7 CCAP0L.6 CCAP0L.5 CCAP0L.4 CCAP0L.3 CCAP0L.2 CCAP0L.1 CCAP0L.0 Mnemonic: CCAP0L Address: EAh PCA Module 1 Compare/Capture Low Register Bit: 7 6 5 4 3 2 1 0 CCAP1L.7 CCAP1L.6 CCAP1L.5 CCAP1L.4 CCAP1L.3 CCAP1L.2 CCAP1L.1 CCAP1L.0 Mnemonic: CCAP1L Address: EBh - 27 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A PCA Module 2 Compare/Capture Low Register Bit: 7 6 5 4 3 2 1 0 CCAP2L.7 CCAP2L.6 CCAP2L.5 CCAP2L.4 CCAP2L.3 CCAP2L.2 CCAP2L.1 CCAP2L.0 Mnemonic: CCAP2L Address: ECh PCA Module 3 Compare/Capture Low Register Bit: 7 6 5 4 3 2 1 0 CCAP3L.7 CCAP3L.6 CCAP3L.5 CCAP3L.4 CCAP3L.3 CCAP3L.2 CCAP3L.1 CCAP3L.0 Mnemonic: CCAP3L Address: EDh PCA Module 4 Compare/Capture Low Register Bit: 7 6 5 4 3 2 1 0 CCAP4L.7 CCAP4L.6 CCAP4L.5 CCAP4L.4 CCAP4L.3 CCAP4L.2 CCAP4L.1 CCAP4L.0 Mnemonic: CCAP4L Address: EEh B Register Bit: 7 6 5 4 3 2 1 0 B.7 B.6 B.5 B.4 B.3 B.2 B.1 B.0 Mnemonic: B Address: F0h B.7-0: The B register is the standard 8052 register that serves as a second accumulator. Chip Enable Register Bit: 7 6 Mnemonic: CHPENR 5 4 3 2 1 0 Address: F6h PCA Counter High Register Bit: 7 6 5 4 3 2 1 0 CH.7 CH.6 CH.6 CH.4 CH.3 CH.2 CH.1 CH.0 Mnemonic: CH Address: F9h PCA Module 0 Compare/Capture High Register Bit: 7 6 5 4 3 2 1 0 CCAP0H.7 CCAP0H.6 CCAP0H.5 CCAP0H.4 CCAP0H.3 CCAP0H.2 CCAP0H.1 CCAP0H.0 Mnemonic: CCAP0H Address: FAh - 28 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A PCA Module 1 Compare/Capture High Register Bit: 7 6 5 4 3 2 1 0 CCAP1H.7 CCAP1H.6 CCAP1H.5 CCAP1H.4 CCAP1H.3 CCAP1H.2 CCAP1H.1 CCAP1H.0 Mnemonic: CCAP1H Address: FBh PCA Module 2 Compare/Capture High Register Bit: 7 6 5 4 3 2 1 0 CCAP2H.7 CCAP2H.6 CCAP2H.5 CCAP2H.4 CCAP2H.3 CCAP2H.2 CCAP2H.1 CCAP2H.0 Mnemonic: CCAP2H Address: FCh PCA Module 3 Compare/Capture High Register Bit: 7 6 5 4 3 2 1 0 CCAP3H.7 CCAP3H.6 CCAP3H.5 CCAP3H.4 CCAP3H.3 CCAP3H.2 CCAP3H.1 CCAP3H.0 Mnemonic: CCAP3H Address: FDh PCA Module 4 Compare/Capture High Register Bit: 7 6 5 4 3 2 1 0 CCAP4H.7 CCAP4H.6 CCAP4H.5 CCAP4H.4 CCAP4H.3 CCAP4H.2 CCAP4H.1 CCAP4H.0 Mnemonic: CCAP4H Address: FEh - 29 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 7. PORT 4 AND BASE ADDRESS REGISTERS Port 4, address E8H, is a 4-bit, multi-purpose, programmable I/O port. Each bit can be configured individually, and registers P4CONA and P4CONB contain the control bits that select the mode of each pin. Each pin has four operating modes. Mode 0: Bi-directional I/O port, like port 1. P4.2 and P4.3 serve as external interrupts INT3 and INT2 , if enabled. Mode 1: Read-strobe signals synchronized with the RD signal at specified addresses. These signals can be used as chip-select signals for external peripherals. Mode 2: Write-strobe signals synchronized with the WR signal at specified addresses. These signals can be used as chip-select signals for external peripherals. Mode 3: Read/write-strobe signals synchronized with the RD or WR signal at specified addresses. These signals can be used as chip-select signals for external peripherals. In modes 1 – 3, the address range for chip-select signals depends on the contents of registers P4xAH and P4xAL, which contain the high-order byte and low-order byte, respectively, of the 16-bit address comparator for P4.x. This is illustrated in the following schematic. P4xCSINV P4 REGISTER P4.x DATA I/O RD_CS MUX 4->1 WR_CS READ WRITE RD/WR_CS PIN P4.x ADDRESS BUS P4xFUN0 P4xFUN1 EQUAL REGISTER P4xAL P4xAH Bit Length Selectable comparator P4.x INPUT DATA BUS REGISTER P4xCMP0 P4xCMP1 Figure 7-1 For example, the following program sets up P4.0 as a write-strobe signal for I/O port addresses 1234H − 1237H with positive polarity, while P4.1 − P4.3 are used as general I/O ports. - 30 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A MOV P40AH, #12H MOV P40AL, #34H ; Base I/O address 1234H for P4.0 MOV P4CONA, #00001010B ; P4.0 is a write-strobe signal; address lines A0 and A1 are masked. MOV P4CONB, #00H ; P4.1 − P4.3 are general I/O ports MOV P2ECON, #10H ; Set P40SINV to 1 to invert the P4.0 write-strobe to positive polarity. Then, any instruction MOVX @DPTR, A (where DPTR is in 1234H − 1237H) generates a positivepolarity, write-strobe signal on pin P4.0, while the instruction MOV P4, #XX puts bits 3 – 1 of data #XX on pins P4.3 − P4.1. - 31 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 8. INTERRUPTS This section provides more information about external interrupts INT2 and INT3 and provides an overview of interrupt priority levels and polling sequences. 8.1 External Interrupts 2 and 3 The W78ERD2 offers two additional external interrupts, INT2 and INT3 , similar to external interrupts INT0 and INT1 in the standard 80C52. These interrupts are configured by the XICON (External Interrupt Control) register, which is not a standard register in the 80C52. Its address is 0C0H. XICON is bit-addressable; for example, "SETB 0C2H" sets the EX2 bit of XICON. 8.2 Interrupt Priority Each interrupt has one of four priority levels in the W78ERD2, as shown below. Four-level interrupt priority PRIORITY BITS INTERRUPT PRIORITY LEVEL IPH.X IP.X 0 0 Level 0 (lowest priority) 0 1 Level 1 1 0 Level 2 1 1 Level 3 (highest priority) Interrupts with the same priority level are polled in the sequence indicated below. Nine-source interrupt information POLLING SEQUENCE WITHIN PRIORITY LEVEL ENABLE REQUIRED SETTINGS INTERRUPT TYPE EDGE/LEVEL VECTOR ADDRESS 0 (highest) IE.0 TCON.0 03H Timer/Counter 0 1 IE.1 - 0BH External Interrupt 1 2 IE.2 TCON.2 13H Timer/Counter 1 3 IE.3 - 1BH Programmable Counter Array 4 IE.6 - 33H Serial Port 5 IE.4 - 23H Timer/Counter 2 6 IE.5 - 2BH External Interrupt 2 7 XICON.2 XICON.0 3BH External Interrupt 3 8 (lowest) XICON.6 XICON.3 43H INTERRUPT SOURCE External Interrupt 0 - 32 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 9. PROGRAMMABLE TIMERS/COUNTERS The W78ERD2 has three 16-bit programmable timer/counters. Time-Base Selection The W78ERD2 offers two speeds for the timer. The timers can count at 1/12 of the clock, the same speed they have in the standard 8051 family. Alternatively, the timers can count at 1/6 of the clock, called turbo mode. The speed is controlled by bits T0M, T1M and T2M bits in CKCON. The default value is zero, which selects 1/12 of the clock. These 3 bits, T0M, T1M and T2M, have no effect if option bit 3 is set to 1 to select 12 clocks / machine cycle. 9.1 Timer 0 and Timer 1 Timers 0 and 1 each have a 16-bit timer/counter which consists of two eight-bit registers: Timer 0 consists of TH0 (8 MSB) and TL0 (8 LSB), and Timer 1 consists of TH1 and TL1. These timers/counters can be configured to operate either as timers, machine–cycle counters or counters based on external inputs. The "Timer" or "Counter" function itself is selected by the corresponding " C/ T " bit in the TMOD register: bit 2 for Timer 0 and bit 6 for Timer 1. In addition, each timer/counter can operate in one of four possible modes, which are selected by bits M0 and M1 in TMOD. The rest of this section explains the time-base for the timers and then introduces each mode. Mode 0 In mode 0, the timer/counter is a 13-bit counter whose eight MSB are in THx and five LSB are the five lower bits in TLx. The upper three bits in TLx are ignored. Because THx and TLx are read separately, the timer/counter acts like an eight-bit counter with a five-bit, divide-by-32 pre-scale. Counting is enabled only when TRx is set and either GATE = 0 or INTx = 1. What the timer/counter counts depends on C/ T . When C/ T is set to 0, the timer/counter counts the negative edges of the clock according to the time-base selected by bits TxM in CKCON. When C/ T is set to 1, it counts falling edges on T0 (P3.4, for Timer 0) or T1 (P3.5, for Timer 1). When the 13-bit counter reaches 1FFFh, the next count rolls over the timer/counter to 0000h, and the timer overflow flag TFx (in TCON) is set. If enabled, an interrupt occurs. - 33 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A T0M = CKCON.3 (T1M = CKCON.4) 1 C/T = TMOD.2 (C/T = TMOD.6) 0 0 1/6 osc 1/12 Timer 1 functions are shown in brackets M1,M0 = TMOD.1,TMOD.0 (M1,M0 = TMOD.5,TMOD.4) 00 4 0 1 T0 = P3.4 (T1 = P3.5) 0 7 TL0 (TL1) 7 TH0 (TH1) 01 TR0 = TCON.4 (TR1 = TCON.6) GATE = TMOD.3 (GATE = TMOD.7) TFx Interrupt TF0 (TF1) INT0 = P3.2 (INT1 = P3.3) Figure 9-1 Timer/Counter Mode 0 & Mode 1 Mode 1 Mode 1 is similar to mode 0, except that the timer/counter is 16-bit counter, not a 13-bit counter. All the bits in THx and TLx are used. Roll-over occurs when the timer moves from FFFFh to 0000h. Mode 2 Mode 2 is similar to mode 0, except that TLx acts like an eight-bit counter and THx holds the autoreload value for TLx. When the TLx register overflows from FFh to 00h, the timer overflow flag TFx bit (in TCON) is set, TLx is reloaded with the contents of THx, and the counting process continues. The reload operation does not affect the THx register. T0M = CKCON.3 (T1M = CKCON.4) 1/6 osc 1/12 T0 = P3.4 (T1 = P3.5) 1 0 Timer 1 functions are shown in brackets C/T = TMOD.2 (C/T = TMOD.6) 0 TL0 (TL1) 7 0 1 TFx Interrupt TF0 (TF1) TR0 = TCON.4 (TR1 = TCON.6) GATE = TMOD.3 (GATE = TMOD.7) 0 7 TH0 (TH1) INT0 = P3.2 (INT1 = P3.3) Figure 9-2 Timer/Counter Mode 2 - 34 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Mode 3 Mode 3 is used when an extra eight-bit timer is needed, and it has different effects on Timer 0 and Timer 1. Timer 0 separates TL0 and TH0 into two separate eight-bit count registers. TL0 uses the Timer 0 control bits C/ T , GATE, TR0, INT0 and TF0 and can count clock cycles (clock / 12 or clock / 6) or falling edges on pin T0. Meanwhile, TH0 takes over TR1 and TF1 from Timer 1 and can count clock cycles (clock / 12 or clock / 6). Mode 3 simply freezes Timer 1, which provides a way to turn it on and off. When Timer 0 is in mode 3, Timer 1 can still be used in modes 0, 1 and 2, but its flexibility is limited. Timer 1 can still be used as a timer / counter (or a baud-rate generator for the serial port) and retains the use of GATE and INT1 pin, but it no longer has control over the overflow flag TF1 and enable bit TR1. 1/6 osc 1/12 T0M = CKCON.3 1 C/T = TMOD.2 0 TL0 0 7 0 1 TF0 Interrupt T0 = P3.4 TR0 = TCON.4 GATE = TMOD.3 INT0 = P3.2 TH0 0 TR1 = TCON.6 7 TF1 Interrupt Figure 9-3 Timer/Counter 0 Mode 3 9.2 Timer/Counter 2 Timer 2 is a 16-bit up/down counter equipped with a capture/reload capability. It is configured by the T2MOD register and controlled by the T2CON register. As with Timers 0 and 1, Timer 2 can count clock cycles (fosc / 12 or fosc / 6) or the external T2 pin, as selected by C/ T2 , and there are four operating modes, each discussed below. Capture Mode Capture mode is enabled by setting the CP/RL2 bit in the T2CON register. In capture mode, Timer 2 serves as a 16-bit up-counter. When the counter rolls over from FFFFh to 0000h, the TF2 bit is set, and, if enabled, an interrupt is generated. If the EXEN2 bit is set, then a negative transition on the T2EX pin captures the value in TL2 and TH2 registers in the RCAP2L and RCAP2H registers. This action also causes the EXF2 bit in T2CON to be set, which may also generate an interrupt. - 35 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A RCLK+TCLK=0, CP/RL2 =T2CON.0=1 1/6 osc 1/12 T2M = CKCON.5 1 0 C/T2 = T2CON.1 T2CON.7 0 1 TF2 TH2 TL2 T2 = P1.0 TR2 = T2CON.2 Timer 2 Interrupt T2EX = P1.1 RCAP2L RCAP2H EXF2 EXEN2 = T2CON.3 T2CON.6 Figure 9-4 16-Bit Capture Mode Auto-reload Mode, Counting up This mode is enabled by clearing the CP/RL2 bit in T2CON and the DCEN bit in T2MOD. In this mode, Timer 2 is a 16-bit up-counter. When the counter rolls over from FFFFh to 0000h, the contents of RCAP2L and RCAP2H are automatically reloaded into TL2 and TH2, and the timer overflow bit TF2 is set. If the EXEN2 bit is set, then a negative transition of T2EX pin also causes a reload, which also sets the EXF2 bit in T2CON. RCLK+TCLK=0, CP/RL2 =T2CON.0=0, DCEN=0 1/6 osc 1/12 T2M = CKCON.5 1 0 C/T2 = T2CON.1 0 T2CON.7 TL2 1 TF2 TH2 T2 = P1.0 TR2 = T2CON.2 Timer 2 Interrupt T2EX = P1.1 RCAP2L RCAP2 H EXF2 EXEN2 = T2CON.3 T2CON.6 Figure 9-5 16-Bit Auto-reload Mode, Counting Up Auto-reload Mode, Counting Up/Down This mode is enabled when the CP/RL2 bit in T2CON is clear and the DCEN bit in T2MOD is set. In this mode, Timer 2 is an up/down-counter whose direction is controlled by the T2EX pin (1 = up, 0 = down). When Timer 2 overflows while counting up, the counter is reloaded by RCAP2L and RCAP2H. When Timer 2 is counting down, the counter is reloaded with FFFFh when Timer 2 is equal to RCAP2L and RCAP2H. In either case, the timer overflow bit TF2 is set, and the EXF2 bit is toggled, though EXF2 can not generate an interrupt in this mode. - 36 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A RCLK+TCLK=0, CP/RL2 =T2CON.0=0, DCEN=1 Down Counting Reload Value 0FFh 1/6 osc 1/12 0FFh T2M = CKCON.5 1 C/T = T2CON.1 0 0 T2CON.7 TL2 1 Timer 2 Interrupt TF2 TH2 T2 = P1.0 TR2 = T2CON.2 RCAP2L RCAP2H Up Counting Reload Value T2EX = P1.1 EXF2 T2CON.6 Figure 9-6 16-Bit Auto-reload Up/Down Counter Baud Rate Generator Mode Baud-rate generator mode is enabled by setting either the RCLK or TCLK bits in T2CON register. In baud-rate generator mode, Timer 2 is a 16-bit up-counter that automatically reloads when it overflows, but this overflow does not set the timer overflow bit TF2. If EXEN2 is set, then a negative transition on the T2EX pin sets EXF2 bit in T2CON and, if enabled, generates an interrupt request. RCLK+TCLK=1 osc 0 C/T = T2CON.1 TL2 1 Timer 2 overflow TH2 T2 = P1.0 TR2 = T2CON.2 T2EX = P1.1 RCAP2L RCAP2H EXF2 EXEN2 = T2CON.3 Timer 2 Interrupt T2CON.6 Figure 9-7 Baud Rate Generator Mode - 37 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 10. ENHANCED FULL DUPLEX SERIAL PORT The W78ERD2 serial port is a full-duplex port, and the W78ERD2 provides additional features such as frame-error detection and automatic address recognition. The serial port runs in one of four operating modes. Serial Ports Modes SM1 SM0 MODE TYPE BAUD CLOCK FRAME SIZE START BIT STOP BIT 9TH BIT FUNCTION 0 0 0 Synch. 12 TCLKS 8 bits No No None 0 1 1 Asynch. Timer 1 or 2 10 bits 1 1 None 1 0 2 Asynch. 32 or 64 TCLKS 11 bits 1 1 0, 1 1 1 3 Asynch. Timer 1 or 2 11 bits 1 1 0, 1 In synchronous mode (mode 0), the W78ERD2 generates the clock and operates in a half-duplex mode. In asynchronous modes (modes 1 – 3), full-duplex operation is available so that the serial port can simultaneously transmit and receive data. In any mode, register SBUF functions as both the transmit register and the receive buffer. Any write to SBUF writes to the transmit register, while any read from SBUF reads from the receive buffer. The rest of this section discusses each operating mode and then discusses frame-error detection and automatic address recognition. 10.1 MODE 0 Mode 0 is a half-duplex, synchronous mode. RxD transmits and receives serial data, and TxD transmits the shift clock. The TxD clock is provided by the W78ERD2. Eight bits are transmitted or received per frame, LSB first. The baud rate is fixed at 1/12 of the oscillator frequency. The functional block diagram is shown below. osc Internal Data Bus Write to SBUF PARIN SOUT LOAD CLOCK 12 TX SHIFT TX START TX CLOCK RXD P3.0 Alternate Output Function Transmit Shift Register TI Serial Port Interrupt SERIAL RI CONTROLLE RX CLOCK RI REN RXD P3.0 Alternate Iutput function RX START SHIFT CLOCK TXD P3.1 Alternate Output function LOAD SBUF RX SHIFT CLOCK PAROUT SBUF SIN Read SBUF SBUF Internal Data Bus Receive Shift Register Figure 10-1 Serial Port Mode 0 - 38 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A As mentioned before, data enters and leaves the serial port on RxD. TxD line provides the shift clock, which shifts data into and out of the W78ERD2 and the device at the other end of the line. Any instruction that writes to SBUF starts the transmission. The shift clock is activated, and the data is shifted out on the RxD pin until all eight bits are transmitted. If SM2 is set to 1, the data appears on RxD one clock period before the falling edge on TxD, and the TxD clock then remains low for two clock periods before going high again. If SM2 is set to 0, the data appears on RxD three clock periods before the falling edge on TxD, and the TxD clock then remains low for six clock periods before going high again. This ensures that the receiving device can clock RxD data on the rising edge of TxD or when the TxD clock is low. Finally, the TI flag is set high in C1 once the last bit has been transmitted. The serial port receives data when REN is 1 and RI is zero. The TxD clock is activated, and the serial port latches data on the rising edge of the shift clock. As a result, the external device should present data on the falling edge of TxD. This process continues until all eight bits have been received. Then, after the last rising edge on TxD, the RI flag is set high in C1, which stops reception until RI is cleared by the software. 10.2 MODE 1 Mode 1 is a full–duplex, asynchronous mode. Serial communication frames are made up of ten bits transmitted on TXD and received on RXD. The ten bits consist of a start bit (0), eight data bits (LSB first), and a stop bit (1). When the W78ERD2 receives data, the stop bit goes into RB8 in SCON. The baud rate is either 1/16 or 1/32 of the Timer 1 overflow, which can be set to a variety of reload values. (The 1/16 or 1/32 factor is determined by the SMOD bit in PCON SFR.) The functional diagram is shown below. Timer 2 Overflow Timer 1 Overflow Transmit Shift Register STOP Write to SBUF 2 SMOD = 0 TCLK PARIN START LOAD 1 0 0 SOUT TXD CLOCK TX START 1 16 RCLK Internal Data Bus TX SHIFT TX CLOCK TI SERIAL CONTROLLER 1 Serial Port Interrupt RI 16 RX CLOCK SAMPLE 1-TO-0 DETECTOR RX START LOAD Read SBUF SBUF RX SHIFT CLOCK PAROUT RXD BIT DETECTOR SIN D8 SBUF RB8 Internal Data Bus Receive Shift Register Figure 10-2 Serial Port Mode 1 - 39 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Transmission begins when data is written to SBUF but is synchronized with the roll-over of Timer 1 (divided by 16 or 32, as configured) and not the write signal. The W78ERD2 waits until the next rollover of Timer 1 (divided by 16 or 32) before the data is put on TxD. The next bit is placed on TxD after the next rollover. After all eight bits of data are transmitted, the stop bit is transmitted. Finally, the TI flag is set, at the tenth rollover after the write signal. Reception is enabled only if REN is high. The W78ERD2 samples the RxD line at a rate of 16 times the selected baud rate, looking for a falling edge. When a falling edge is detected on the RxD pin, Timer 1 (divided by 16 or 32) is immediately reset to align the bit boundaries better, and the serial port starts receiving data. The 16 states of the counter effectively divide the time into 16 slices, and bit detection is done on a best-of-three basis using the eighth, ninth and tenth states. If the start bit is invalid (1), reception is aborted, and the serial port resumes looking for a falling edge on RxD. If the start bit is valid, the eight data bits are shifted in. Then, if (1) RI = 0 and (2) SM2 = 0 or the stop bit = 1, the stop bit is put into RB8, the data is put in SBUF, and RI is set. Otherwise, the received frame may be lost. In the middle of the stop bit, the W78ERD2 resumes looking for falling edges on RxD. 10.3 MODE 2 Mode 2 is a full-duplex, asynchronous mode. Serial communication frames are made up of eleven bits transmitted on TXD and received on RXD. The eleven bits consist of a start bit (0), eight data bits (LSB first), a programmable ninth bit (TB8) and a stop bit (1). The ninth bit is read into and transmitted from RB8. The baud rate is either 1/32 or 1/64 of the oscillator frequency, and the 1/32 or 1/64 factor is determined by the SMOD bit in PCON SFR. The functional diagram is shown below. TB8 1/2 fosc Write to SBUF 2 SMOD = 0 D8 Internal Data Bus STOP PARIN START SOUT TXD LOAD 1 CLOCK TX SHIFT TX START 16 16 TX CLOCK Transmit Shift Register TI SERIAL CONTROLLER Serial Port Interrupt RI RX CLOCK SAMPLE 1-TO-0 DETECTOR RX START LOAD SBUF RX SHIFT Read SBUF CLOCK PAROUT RXD BIT DETECTOR SIN D8 SBUF RB8 Internal Data Bus Receive Shift Register Figure 10-3 Serial Port Mode 2 - 40 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Transmission begins when data is written to SBUF but is synchronized with the roll-over of the counter (divided by 32 or 64, as configured) and not the write signal. The W78ERD2 waits until the next rollover of the counter (divided by 32 or 64) before the data is put on TxD. The next bit is placed on TxD after the next rollover. After all nine bits of data are transmitted, the stop bit is transmitted. Finally, the TI flag is set, at the eleventh rollover after the write signal. Reception is enabled only if REN is high. The W78ERD2 samples the RxD line at a rate of 16 times the selected baud rate, looking for a falling edge. When a falling edge is detected on the RxD pin, the counter (divided by 32 or 64) is immediately reset to align the bit boundaries better, and the serial port starts receiving data. The 16 states of the counter effectively divide the time into 16 slices, and bit detection is done on a best-of-three basis using the eighth, ninth and tenth states. If the start bit is invalid (1), reception is aborted, and the serial port resumes looking for a falling edge on RxD. If the start bit is valid, the rest of the bits are shifted in. Then, if (1) RI = 0 and (2) Either SM2 = 0 or the received 9th bit = 1, the ninth bit is put into RB8, the data is put in SBUF, and RI is set. Otherwise, the received frame may be lost. In the middle of the stop bit, the W78ERD2 resumes looking for falling edges on RxD. 10.4 MODE 3 Mode 3 is similar to mode 2 in all respects, except that the baud rate is programmable the same way it is programmable in mode 1. The functional diagram is shown below. Timer 2 Overflow Timer 1 Overflow STOP TB8 Write to SBUF 2 SMOD = 0 TCLK PARIN START LOAD 1 0 0 SOUT TXD CLOCK TX START 1 16 RCLK D8 Internal Data Bus TX SHIFT TX CLOCK TI SERIAL CONTROLLER 1 Transmit Shift Register Serial Port Interrupt RI 16 SAMPLE 1-TO-0 DETECTOR RX CLOCK LOAD SBUF RX START Read SBUF RX SHIFT CLOCK PAROUT RXD BIT DETECTOR SIN D8 SBUF RB8 Internal Data Bus Receive Shift Register Figure 10-4 Serial Port Mode 3 - 41 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 10.5 Framing Error Detection A frame error occurs when a valid stop bit is not detected. This could indicate incorrect serial data communication. Typically, the frame error is due to noise or contention on the serial communication line. The W78ERD2 has the ability to detect framing errors and set a flag which can be checked by software. The frame error FE bit is located in SCON.7. This bit is normally used as SM0 in the standard 8051 family. However, in the W78ERD2 it serves a dual function and is called SM0/FE. There are actually two separate flags, one for SM0 and the other for FE. The flag that is actually accessed as SCON.7 is determined by SMOD0 (PCON.6) bit. When SMOD0 is set to 1, then the FE flag is accessed. When SMOD0 is set to 0, then the SM0 flag is accessed. The FE bit is set to 1 by the hardware but must be cleared by software. Once FE is set, any frames received afterwards, even those without any errors, do not clear the FE flag. The flag has to be cleared by software. Note that SMOD0 must be set to 1 while reading or writing to FE. 10.6 Multi-Processor Communications Multi-processor communication makes use of the 9th data bit in modes 2 and 3. In the W78ERD2, the RI flag is set only if the received byte corresponds to the Given or Broadcast address. This hardware feature eliminates the software overhead required in checking every received address and greatly simplifies the software programmer task. In multi-processor communication mode, the address bytes are distinguished from the data bytes by the 9th bit, which is set high for address bytes. When the master processor wants to transmit a block of data to one of the slaves, it first sends out the address of the target slave (or slaves). All the slave processors should have their SM2 bit set high when waiting for an address byte. This ensures that they are interrupted only by the reception of an address byte. The automatic address recognition feature ensures that only the addressed slave is actually interrupted because the address comparison is done by the hardware, not the software. The addressed slave clears the SM2 bit, thereby clearing the way to receive data bytes. With SM2 = 0, the slave is interrupted on the reception of every single complete frame of data. The unaddressed slaves are not affected, as they are still waiting for their address. The Master processor can selectively communicate with groups of slaves by using the Given Address. All the slaves can be addressed together using the Broadcast Address. The addresses for each slave are defined in the SADDR and SADEN registers. The slave address is an eight-bit value specified in the SADDR SFR. The SADEN SFR is actually a mask for the byte value in SADDR. If a bit position in SADEN is 0, then the corresponding bit position in SADDR is don't care. Only those bit positions in SADDR whose corresponding bits in SADEN are 1 are used to obtain the Given Address. This gives the user flexibility to address multiple slaves without changing the slave address in SADDR. The following example shows how the user can define the Given Address to address different slaves. - 42 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Slave 1: SADDR 1010 0100 SADEN 1111 1010 Given 1010 0x0x Slave 2: SADDR 1010 0111 SADEN 1111 1001 Given 1010 0xx1 The Given address for slaves 1 and 2 differ in the LSB. For slave 1, it is a don't-care, while for slave 2 it is 1. Thus to communicate only with slave 1, the master must send an address with LSB = 0 (1010 0000). Similarly the bit 1 position is 0 for slave 1 and don't care for slave 2. Hence to communicate only with slave 2 the master has to transmit an address with bit 1 = 1 (1010 0011). If the master wishes to communicate with both slaves simultaneously, then the address must have bit 0 = 1 and bit 1 = 0. The bit 3 position is don't-care for both the slaves. This allows two different addresses to select both slaves (1010 0001 and 1010 0101). The master can communicate with all the slaves simultaneously with the Broadcast Address. This address is formed from the logical OR of the SADDR and SADEN SFRs. The zeros in the result are defined as don't cares. In most cases, the Broadcast Address is FFh. In the previous example, the Broadcast Address is (1111111X) for slave 1 and (11111111) for slave 2. The SADDR and SADEN SFRs are located at addresses A9h and B9h, respectively. On reset, these registers are initialized to 00h. This results in Given Address and Broadcast Address being set as XXXX XXXX(i.e. all bits don't care). This effectively removes the multi-processor communications feature, since any selectivity is disabled. - 43 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 11. PROGRAMMABLE COUNTER ARRAY (PCA) The PCA is a special 16-bit timer that has five 16-bit capture/compare modules associated with it. Each module can be programmed to operate in one of four modes: rising and/or falling edge capture, software timer, high-speed output, or pulse width modulator. Each module has a pin associated with it in port 1. Module 0 is connected to p1.3 (CEX0), module 1 to p1.4 (CEX1), and so on. PCA Timer/Counter CH Module0 P1.3/CEX0 Module1 P1.4/CEX1 Module2 P1.5/CEX2 Module3 P1.6/CEX3 Module4 P1.7/CEX4 CL 16-bit Up-Counter time base for PCA modules Module Functions: 16-bit Capture 16-bit Timer/Compare 16-bit High Speed Output 8-bit PWM Watchdog Timer (Module 4 Only) Figure 11-1 Programmable Counter Array (PCA) Each module has a special function register CCAPMn, where n is the same number as the module (CCAPM0 for module0, CCAPM1 for module1, etc.). CCAPMn contains the bits that control the mode of each module. CCAPMn: PCA module compare/capture register CCAPM0(DAH) , CCAPM1(DBH) , CCAPM2(DCH) , CCAPM3(DDH), CCAPM4(DEH) BIT NAME FUNCTION 7 - 6 ECOMn Enable Comparator. ECOMn = 1 enables the comparator function 5 CAPPn Capture Positive. CAPPn = 1 enables positive-edge capture. 4 CAPNn Capture Negative. CAPNn = 1 enables negative-edge capture. 3 MATn Match. When MATn = 1 a match of the PCA counter with this module’s compare/capture register causes the CCFn bit in CCON to be set and, if ECCFn is set, generating an interrupt. 2 TOGn Toggle. When TOGn = 1 a match of the PCA counter with this module’s compare/capture register causes the CEXn bit to toggle. 1 PWMn Pulse Width Modulation Mode. PWMn = 1 enables the CEXn bit to be used for pulse-width modulated output. 0 ECCFn Enable CCF interrupt. Enables the compare/capture flag CCFn in the CCON register to generate an interrupt. Reserved - 44 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A ECOMn MODULE FUNCTION CAPPn CAPNn MATn TOGn PWMn ECCFn No operation 0 0 0 0 0 0 0 16-bit capture by a positive edge trigger on CEXn X 1 0 0 0 0 X 16-bit capture by a negative trigger on CEXn X 0 1 0 0 0 X 16-bit capture by a transition on CEXn X 1 1 0 0 0 X 16-bit Software Timer 1 0 0 1 0 0 X 16-bit High Speed Output 1 0 0 1 1 0 X 8-bit PWM 1 0 0 0 0 1 0 Watchdog Timer (only in module4) 1 0 0 1 X 0 X PCA Module Modes (CCAPMn Register) PWM enables pulse width modulation. The TOG bit causes the output CEXn to toggle when there is a match between the PCA counter and the module’s compare/capture register. The match bit MAT causes the CCF bit in the CCON register to be set when there is a match between the PCA counter and the module’s compare/capture register, and the ECCF bit enables the CCF flag to generate an interrupt. The bits CAPP and CAPN determine whether positive and negative edges, respectively, are captured. The bit ECOM enables the comparator function. The PCA Timer is the common time-base for all five modules and can be programmed to select the appropriate timer source. The default value is 12 clocks (12T) per machine cycle, and 6T can also be selected by a bit in the options registers. The actual timer is then determined by the CPS1 and CPS2 bits in the CMOD SFR, as follows: CPS1 CPS0 0 0 1 1 0 1 0 1 PCA TIMER COUNT SOURCE FOR 12T Oscillator frequency / 12 Oscillator frequency / 4 Timer 0 overflow External input at ECI pin PCA TIMER COUNT SOURCE FOR 6T Oscillator frequency / 6 Oscillator frequency / 2 Timer 0 overflow External input at ECI pin - 45 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A CMOD(D9H): PCA counter mode register BIT NAME FUNCTION 7 CILD 6 WDTE 5 - Reserved 4 - Reserved 3 - Reserved 2 CPS1 PCA Count Pulse Select bit 1 1 CPS0 PCA Count Pulse Select bit 0 0 ECF Counter idle control: CILD = 0 programs the PCA Counter to continue functioning in idle mode; CILD = 1 programs it to stop in idle mode. Watchdog Timer Enable: WDTE = 0 disables the Watchdog Timer function in PCA module 4. WDTE = 1 enables it. PCA Enable Counter Overflow interrupt: ECF = 1 enables CF bit in CCON to generate an interrupt. ECF = 0 disables the interrupt. There are three additional bits in the CMOD SFR. CILD allows the PCA to stop during idle mode, WDTE enables and disables the watchdog function executed in module 4, and ECF causes an interrupt when the PCA timer overflows (and the PCA overflow flag CF is set). The CCON SFR contains the run-control bit for the PCA and the flags for the PCA timer overflow (CF) and each module match / capture (CCFn). CCON(D8H): PCA counter control register BIT NAME FUNCTION 7 CF PCA Counter Overflow flag. Set by hardware when the counter rolls over. CF generates an interrupt if bit ECF in CMOD is set. CF may be set by either hardware or software but can only be cleared by software. 6 CR PCA Counter Run control bit. Set by software to turn on the PCA counter. Must be cleared by software to turn the PCA counter off. 5 - 4 CCF4 PCA Module4 interrupt flag. Set by hardware when a match or capture occurs. Must be cleared by software. 3 CCF3 PCA Module3 interrupt flag. Set by hardware when a match or capture occurs. Must be cleared by software. 2 CCF2 PCA Module2 interrupt flag. Set by hardware when a match or capture occurs. Must be cleared by software. 1 CCF1 PCA Module1 interrupt flag. Set by hardware when a match or capture occurs. Must be cleared by software. 0 CCF0 PCA Module0 interrupt flag. Set by hardware when a match or capture occurs. Must be cleared by software. Reserved The CR bit (CCON.6) must be set by the software, and the PCA is turned off by clearing this bit. The CF bit (CCON.7) is set when the PCA Counter overflows, and an interrupt is generated if the ECF bit in the CMOD register is set. The CF bit can only be cleared by software. CCON.0~CCON.4 are the flags - 46 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A for the modules and are set by hardware when either a match or a capture occurs. These flags can only be cleared by software. The next five sections provide more information about each of the five modes (four modes for all registers and the watchdog timer in module 4). 11.1 PCA Capture Mode To use one of the PCA modules in capture mode, either one or both of the CCAPM bits CAPN and CAPP for that module must be set. CF CR - CCF4 CCF3 CCF2 CCF1 CCF0 CCON(D8H) PCA INTERRUPT PCA Timer/Counter To CCFn CEXn CH CL CCAPnH CCAPnL Capture - ECOMn 0 CAPPn CAPNn MATn TOGn PWMn 0 0 0 ECCFn CCAPMn, n=0~4 (DAH~DEH) Figure 11-2 PCA Capture Mode In capture mode, the external CEXn input is sampled for a transition. When a valid transition occurs, the PCA hardware loads the value of the PCA counter registers CH and CL into the module’s capture registers (CCAPnH and CCAPnL). If the CCFn (CCON) and ECCFn (CCAPMn) bits are set, then an interrupt is generated. 11.2 16-bit Software Timer Comparator Mode The PCA modules can be used as software timers by setting both the ECOM and MAT bits in the CCAPMn register. - 47 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A CF CR CCAPnH Write To CCAPnL - CCF4 CCF3 CCF1 CCF0 CCAPnL CCON(D8H) PCA INTERRUPT Write To CCAPnH To CCFn 16-bit Comparator 0 CCF2 Match 1 Enable CH CL PCA Timer/Counter - ECOMn CAPPn CAPNn 0 0 MATn TOGn PWMn 0 0 ECCFn CCAPMn, n=0~4 (DAH~DEH) Figure 11-3 PCA 16-bit Timer Comparator Mode In this mode, the PCA timer is compared to the module’s capture registers. When a match occurs, an interrupt is generated if the CCFn (CCON) and ECCFn (CCAPMn) bits are set. 11.3 High Speed Output Mode To activate this mode, the TOG, MAT, and ECOM (CCAPMn) bits must be set. CF CR CCAPnH Write To CCAPnL - CCF3 CCF1 CCF2 CCF0 CCAPnL CCON(D8H) PCA INTERRUPT Write To CCAPnH To CCFn 16-bit Comparator 0 CCF4 Match 1 CEXn Enable CH CL PCA Timer/Counter - ECOMn CAPPn CAPNn 0 0 MATn TOGn PWMn 1 0 ECCFn CCAPMn, n=0~4 (DAH~DEH) Figure 11-4 PCA High Speed Output Mode In this mode, the CEXn output toggles each time a match occurs between the PCA counter and the module’s capture registers. - 48 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 11.4 Pulse Width Modulator Mode The PWM and ECOM (CCAPM) bits must be set to enable the PWM mode. CCAPnH CCAPnL 0 CL < CCAPnL 8-BIT COMPARATOR Enable CEXn CL >= CCAPnL 1 Overflow CL PCA Timer/Counter - ECOMn CAPPn CAPNn MATn TOGn 0 0 0 0 PWMn CCAPMn, n=0~4 (DAH~DEH) ECCFn 0 Figure 11-5 PAC PWM Mode All of the modules have the same frequency because they share the same PCA timer. The duty cycle of each module, however, is independently controlled by the module’s capture register CCAPLn. When the value of the PCA CL SFR is less than the value in CCAPLn, the output is low; when it is equal to or greater than the value in CCAPLn, the output is high. When CL overflows from FF to 00, CCAPLn is reloaded with the value in CCAPHn. 11.5 Watchdog Timer The Watchdog Timer is a free-running timer that serves as a system monitor. It is implemented in module 4, which can still be used for other modes if the Watchdog Timer is not needed. CIDL WDTE CCAP4H Write To CCAP4L - - CPS1 CPS0 ECF CMOD(D9H) CCAP4L Module4 Write To CCAP4H Match 16-bit Comparator 0 - RESET 1 Enable CH CL PCA Timer/Counter - ECOM4 CAPP4 CAPN4 MAT4 TOG4 PWM4 ECCF4 0 0 1 x 0 x CCAPM4(DEH) Figure 11-6 PCA Watchdog Timer Mode The program first loads a 16-bit value into the compare registers. Then, like the other compare modes, this 16-bit value is compared to the PCA timer value. If a match occurs, an internal reset is generated, but it does not make the RST pin go high. - 49 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 12. HARDWARE WATCHDOG TIMER (ONE-TIME ENABLED WITH RESET-OUT) The WDT is intended as a way to recover when the CPU may be subject to software problem. The WDT consists of a 14-bit counter and the WDT reset (WDTRST) register located at 0A6H. The WDT is disabled at reset. To enable the WDT, user must write 01EH and 0E1H in sequence to WDTRST. Once the WDT is enabled, it increments every machine cycle, while the oscillator is running, and there is no way to disable the WDT except through reset (either hardware reset or WDT overflow reset). The program must reset the counter by writing 01EH and 0E1H to WDTRST before the WDT counter reaches 3FFFH (i.e., overflows). If it does overflow, it drives a HIGH pulse on the RST-pin. This pulse width is 98 source clocks in 12-clock mode or 49 source clocks in 6-clock mode. No external pull-down resistor or pull-up capacitor is required on the reset pin. The WDT counter cannot be read or written. To make the best use of the WDT, the WDT should be reset in sections of code that are periodically executed in time to prevent a WDT reset. 13. DUAL DPTR The dual DPTR structure is the way the chip specifies the address of an external data memory location. There are two 16-bit DPTR registers that address external memory. The DPS bit (AUXR1, bit 0) switches between them, and it can be toggled quickly by an INC AUXR1 instruction. (AUXR1, bit 2 cannot be written and is always read as a zero, so the INC AUXR1 instruction does not affect the GF2 bit that is higher in the AUXR1 register.) It is important to keep track of the value of the DPS bit. For example, procedures and functions should save the DPS bit before switching between DPTR0 and DPTR1 and restore the original value afterwards to prevent other code from using the wrong memory. - 50 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 14. TIMED-ACCESS PROTECTION The W78ERD2 has features like Timer clock selecting by setting CKCON, software reset and ISP function that are crucial to the proper operation of the system. Consequently, The SFR CHPCON and CKCON, which control the functions, have restricted write access to protect CPU from errant operation. The W78ERD2 provides has a timed-access protection scheme that controls write access to critical bits. In this scheme, protected bits have a timed write-enable window. A write is successful only if this window is active; otherwise, the write is discarded. The write-enable window is opened in two steps. First, the software writes 87h to the register CHPENR. This starts a counter, which expires in three machine cycles. Then, if the software writes 59h to CHPENR before the counter expires, the writeenable window is opened for three machine cycles. After three machine cycles, the window automatically closes, and the procedure must be repeated again to access protected bits. The suggested code for opening the write-enable window is CHPENR REG 0F6h ; Define new register CHPENR, located at 0F6h MOV CHPENR, #87h MOV CHPENR, #59h Five examples, some correct and some incorrect, of using timed-access protection are shown below. - 51 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Example 1: Valid access MOV CHPENR, #87h ;3 M/C, Note: M/C = Machine Cycles MOV CHPENR, #59h ;3 M/C MOV CKCON, #00h ;3 M/C Example 2: Valid access MOV CHPENR, #87h ;3 M/C MOV CHPENR, #59h ;3 M/C NOP ;1 M/C SETB EWT ;2 M/C Example 3: Valid access MOV CHPENR, #87h ;3 M/C MOV CHPENR, #59h ;3 M/C ORL CKCON, #01h ;3M/C Example 4: Invalid access MOV CHPENR, #87h ;3 M/C MOV CHPENR, #59h ;3 M/C NOP ;1 M/C NOP ;1 M/C CLR MD ;2 M/C Example 5: Invalid Access MOV CHPENR, #87h ;3 M/C NOP ;1 M/C MOV CHPENR, #59h ;3 M/C SETB MD ;2 M/C In the first three examples, the protected bits are written before the window closes. In Example 4, however, the write occurs after the window has closed, so there is no change in the protected bit. In Example 5, the second write to CHPENR occurs four machine cycles after the first write, so the timed access window in not opened at all, and the write to the protected bit fails. - 52 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 15. IN-SYSTEM PROGRAMMING (ISP) MODE The W78ERD2 is equipped with 64 KB of main flash EPROM (AP Flash EPROM) for the application program and 4 KB of auxiliary flash EPROM (LD Flash EPROM) for the loader program. In normal operation, the microcontroller executes the code in the AP Flash EPROM. If the code in the AP Flash EPROM needs to be modified, however, the W78ERD2 allows the program to activate the In-System Programming (ISP) mode to modify it. The contents in the AP Flash EPROM can be modified by setting the CHPCON register. The CHPCON is read-only by default. The program must write two specific values, 87H and then 59H, sequentially to the CHPENR register to enable the CHPCON write attribute. Writing CHPENR register with any other values disables the write attribute. Setting the bit CHPCON.0 makes the W78ERD2 enter ISP mode when it wakes up from the next idle mode. It takes time to set this up in idle mode, however, so the program may use a timer interrupt to wake up the W78ERD2 and enter ISP mode after an appropriate amount of time in idle mode. To change the contents in the AP Flash EPROM, the existing contents must set the CHPCON register and then enter idle mode. When the W78ERD2 wakes up, it switches from AP Flash EPROM to LD Flash EPROM, clears the program counter, pushing 0000H to the first 2 bytes of stack memory and executes the interrupt service routine in the LD Flash EPROM. Therefore, the first execution of RETI instruction will make the program jump to 00H in the LD Flash EPROM. When the AP Flash EPROM has been updated, the W78ERD2 offers a software reset to switch back to the AP Flash EPROM. Setting CHPCON bits 0, 1 and 7 to logic-1 creates a software reset to reset the CPU. A flowchart for the LD Flash EPROM program is shown at the end of this section. SFRAH, SFRAL: The objective address of the on-chip flash EPROM in ISP mode. SFRFAH contains the high-order byte, and SFRFAL contains the low-order byte. SFRFD: The program data in ISP mode. SFRCN: The control byte for ISP mode. SFRCN (C7) BIT NAME 7 - FUNCTION Reserve. On-chip flash EPROM bank select for in-system programming. 6 WFWIN 0: 64-KB flash EPROM bank is the destination for re-programming. 1: 4-KB flash EPROM bank is the destination for re-programming. 5 OEN Flash EPROM output enable. 4 CEN Flash EPROM chip enable. 3, 2, 1, 0 CTRL[3:0] Flash EPROM control signals; see below. - 53 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A MODE WFWIN CTRL OEN CEN SFRAH, SFRAL SFRFD Erase 64KB AP Flash EPROM 0 0010 1 0 X X Program 64KB AP Flash EPROM 0 0001 1 0 Address in Data in Read 64KB AP Flash EPROM 0 0000 0 0 Address in Data out Erase 4KB LD Flash EPROM 1 0010 1 0 X X Program 4KB LD Flash EPROM 1 0001 1 0 Address in Data in Read 4KB LD Flash EPROM 1 0000 0 0 Address in Data out - 54 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A The Algorithm of In-System Programming Part 1:APROM procedure of entering In-System Programming Mode START Enter In-System Programming Mode ? (conditions depend on user's application) No Yes Setting control registers MOV CHPENR,#87H MOV CHPENR,#59H MOV CHPCON,#03H Execute the normal application program Setting Timer (about 1.5 us) and enable timer interrupt END Start Timer and enter idle Mode. (CPU will be wakened from idle mode by timer interrupt, then enter In-System Programming mode) CPU will be wakened by interrupt and re-boot from 4KB LDROM to execute the loader program. Go Figure 15-1 The algorithm of ISP for AP ROM - 55 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A Part 2: 4KB LDROM Go Procedure of Updating the 64KB APROM Timer Interrupt Service Routine: Stop Timer & disable interrupt PGM Yes Yes Is F04KBOOT Mode? (CHPCON.7=1) End of Programming ? No No Reset the CHPCON Register: MOV CHPENR,#87H MOV CHPENR,#59H MOV CHPCON,#03H Setting Timer and enable Timer interrupt for wake-up . (50us for program operation) Yes Is currently in the F04KBOOT Mode ? No Software reset CPU and re-boot from the 64KB APROM. MOV CHPENR,#87H MOV CHPENR,#59H MOV CHPCON,#83H Get the parameters of new code Setting Timer and enable Timer interrupt for wake-up . (15 ms for erasing operation) Setting erase operation mode: MOV SFRCN,#22H (Erase 64KB APROM) Start Timer and enter IDLE Mode. (Erasing...) (Address and data bytes) through I/O ports, UART or other interfaces. Setting control registers for programming: Hardware Reset to re-boot from new 64 KB APROM. (S/W reset is invalid in H/W reboot Mode) MOV SFRAH,#ADDRESS_H MOV SFRAL,#ADDRESS_L MOV SFRFD,#DATA MOV SFRCN,#21H End of erase operation. CPU will be wakened by Timer interrupt. END Executing new code from address 00H in the 64KB APROM. PGM Figure 15-2 The algorithm of ISP for LD ROM - 56 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 16. H/W REBOOT MODE (BOOT FROM LDROM) By default, the W78ERD2 boots up from the AP Flash EPROM after a power-on reset. Sometimes, this is not desirable. H/W REBOOT mode forces the W78ERD2 to use the LD Flash EPROM instead and execute in-system programming procedures. Enter H/W REBOOT mode using these settings. H/W REBOOT MODE P4.3 P2.7 P2.6 OPTION BIT MODE X L L Bit4 = L H/W REBOOT L X X Bit5 = L H/W REBOOT This might be implemented by connecting pins P2.6 and P2.7 to switches or jumpers. For example, in a CD-ROM system, P2.6 and P2.7 might be connected to the PLAY and EJECT buttons on the panel. If the user wants to enter H/W REBOOT mode, the user can press these two buttons at the same time and then turn on the power to force the W78ERD2 to enter H/W REBOOT mode. After the power-on, releasing both buttons finishes the in-system programming procedure. This mode can be accidentally activated, so be careful with the values of pins P2, P3, ALE, EA and PSEN at reset. The Reset Timing For Entering H/W REBOOT Mode 1 P2.7 Hi-Z P2.6 Hi-Z RST 10us 20ms H/W REBOOT Mode 2 P4.3 Hi-Z RST 10us 20ms Figure 16-1 - 57 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 17. OPTION BITS REGISTER In the on-chip Flash EPROM writer programming mode mode, the flash EPROM can be programmed and verified repeatedly. Until the code is ready, it can be protected by properly setting option bits. Option bits control the initial configuration of W78ERD2, including code protection, system clock mode selection (6T/12T), H/W reboot mode selection and oscillator control. D7 D6 D5 D4 D3 D2 D1 D0 B7 B6 B5 B4 B3 B2 B1 B0 4KB Flash EPROM Program Memory LD Flash EPROM Option Bits B0: Lock bit, Logic 0 is active 0000H 0FFFH B1: MOVC Inhibit, Logic 0 is active B2: Encryption bit, Logic 0 is active 64KB Flash EPROM Program Memory AP Flash EPROM B3: logic 1 is 12 clock per machine cycle Reserved logic 0 is 6 clock per machine cycle B4: Enable P2.7 and P2.6 as H/W Reboot Function logic 1: P2.7 and P2.6 are as I/O Function logic 0: P2.7 and P2.6 are as H/W Reboot Function Option Bits Register B5: Enable P4.3 as H/W Reboot Function FFFFH logic 1: P4.3 is as I/O Function logic 0: P4.3 is as H/W Reboot Function Default 1 is for all Security Bits. The Reserved bit must be kept in logic 1. B6: Reserved (0) B7: Logic 1: The Crystal Frequency is above 25MHz Logic 0: The Crystal Frequency is under 25MHz Option Bits Register Lock bit This bit is used to protect the code in the W78ERD2. It may be set after the programmer finishes programming and verifies the sequence. Once this bit is set to logic-0, both the Flash EPROM data and Option Bits Register cannot be accessed again. - 58 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A MOVC Inhibit This bit is used to restrict the accessible region of the MOVC instruction. It can prevent a MOVC instruction in external program memory from reading the internal program code. When this bit is set to logic-0, a MOVC instruction in external program memory space can only access code in external memory, not in internal memory. A MOVC instruction in internal program memory can always access both internal and external memory. If this bit is logic-1, there are no restrictions on MOVC. Encryption This bit is used to enable and disable the encryption logic for code protection. Once encryption is enabled, the data presented on port 0 is encoded via encryption logic. This bit can be reset only by erasing the whole chip. Oscillator Control The gain of the on-chip oscillator amplifier can be reduced by bit B7 in the option bits register. If bit 7 is set to zero, the gain is cut in half. According the circuit in Figure 20-1, the values of R, C1 and C2 may need some adjustment when running at lower gain. Furthermore, reducing the gain by one-half may improperly affect an external crystal running at frequencies above 25 MHz. - 59 - Publication Release Date: March 2, 2009 Revision A12 W78ERD2/W78ERD2A 18. ELECTRICAL CHARACTERISTICS 18.1 Absolute Maximum Ratings PARAMETER SYMBOL MIN. MAX. UNIT VDD − VSS -0.3 +6.0 V Input Voltage VIN VSS -0.3 VDD +0.3 V Operating Temperature TA 0 70 °C Storage Temperature TST -55 +150 °C DC Power Supply Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 18.2 D.C. Characteristics (VDD − VSS = 5V ±10%, TA = 25°C, Fosc = 20 MHz, unless otherwise specified.) PARAMETER SYM. SPECIFICATION MIN. MAX. UNIT TEST CONDITIONS Operating Voltage VDD 4.5 5.5 V Operating Current IDD - 20 mA IIDLE - 10 mA Idle mode VDD = 5.5V IPWDN - 10 µA Power-down mode VDD = 5.5V Input Current P1, P2, P3, P4 IIN1 -50 +10 µA VDD = 5.5V VIN = 0V or VDD Input Current RST IIN2 0 +300 µA VDD = 5.5V 0< VIN
W78ERD2A40DL 价格&库存
很抱歉,暂时无法提供与“W78ERD2A40DL”相匹配的价格&库存,您可以联系我们找货
