ASDM4100S-R
ASDM4100S-R
    ASDSEMI(安森德)
    SOP-8
    MOSFETs N-沟道,P-沟道 100V 4A,3A 104mΩ@4.5V,125mΩ@4.5V 1.6W SOP8_150MIL
ASDM4100S-R 数据手册
ASDM4100S 100V N&P-Channel MOSFET Product Summary Features ● N-Channel VDS RDS(on),Typ VGS=10V RDS(on),Typ VGS=4.5V ● High power and current handing capability ● Lead free product is acquired ● Surface mount package ID Application mΩ mΩ 4 A ● P-Channel ● '&'&SULPDU\EULGJH V VDS -100 RDS(on),Typ VGS=-10V 122 mΩ RDS(on),Typ VGS=-4.5V 125 mΩ -3 ID A ● '&'&6\QFKURQRXVUHFWLILFDWLRQ ● +RWVZDS ● )DQGULYH SOP-8 V 100 98 104 top view D1 D1 D2 D2 S1 G1 S2 G2 N-channel P-channel Absolute Maximum Ratings (TA=25℃unless otherwise noted) Parameter Drain-Source Voltage Symbol VDS N-Channel P-Channel Unit 100 -100 V ±20 ±20 V Gate-Source Voltage VGS Continuous Drain Current ID 4 -3 A Pulsed Drain Current (Note 1) IDM 16 -12 A Maximum Power Dissipation PD 2.5 1.6 W TJ,TSTG -55 To 150 Operating Junction and Storage Temperature Range -55 To 150 ℃ Thermal Characteristic Thermal Resistance,Junction-to-Ambient (Note2) NOV 2021 Version1.0 1/10 RθJA N-Ch 89 P-Ch 90 www.ascendsemi.com ℃/W 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET N-CH Electrical Characteristics (TA=25℃unless otherwise noted) Parameter Symbol Condition Min Drain-Source Breakdown Voltage BVDSS VGS=0V ID=250μA 100 Zero Gate Voltage Drain Current IDSS VDS=80V,VGS=0V - Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V - Gate Threshold Voltage VGS(th) VDS=VGS,ID=250μA 1 Drain-Source On-State Resistance RDS(ON) VGS=10V, ID=3A - VGS=4.5V, ID=2A VDS=10V, ID=2.5A Typ Max Unit - V - 1 μA - ±100 nA 2.5 V 98 120 mΩ - 104 125 mΩ - 20 - S 723 - PF - 28 - PF - 17 - PF - 3.9 - nS Off Characteristics On Characteristics (Note 3) Forward Transconductance gFS Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss VDS=15V,VGS=0V , F=1.0MHz - Switching Characteristics (Note 4) Turn-on Delay Time td(on) Turn-on Rise Time tr VDD=50V, RL=3Ω - 7.7 - nS td(off) VGS=10V,RGEN=3Ω - 33.8 - nS - 9.1 - nS - 6.2 - nC - 1.25 - nC - 1.7 - nC - - 1.3 V - - 4 A Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=50V,ID=3.5 A, VGS=10V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS NOV 2021 Version1.0 2/10 VGS=0V,IS=1A www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET P-CH Electrical Characteristics (TA=25℃unless otherwise noted)  Parameter Symbol Condition Min Typ Max Unit - V Off Characteristics Drain-Source Breakdown Voltage BVDSS VGS=0V ID=-250μA -100 Zero Gate Voltage Drain Current IDSS VDS=-100V , VGS=0V - - -1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V - - ±100 nA Gate Threshold Voltage VGS(th) VDS=VGS,ID=-250μA -1 -2.5 V Drain-Source On-State Resistance RDS(ON) VGS=-10V, ID=-2.5A - 122 146 mΩ VGS=-4.5V, ID=-2.0A - 125 150 mΩ VGS=-5V, ID=-2.5A 12 - - S - 1774 - PF - 338 - PF - 203 - PF - 8 - nS On Characteristics (Note 3) Forward Transconductance gFS Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss VDS=-25V,VGS=0V, F=1.0MHz Switching Characteristics (Note 4) Turn-on Delay Time td(on) Turn-on Rise Time tr VDD=-25V,RL=3.6Ω - 4 - nS td(off) VGS=-10V,RGEN=3Ω - 27 - nS Turn-Off Delay Time Turn-Off Fall Time tf - 12.5 - nS Total Gate Charge Qg - 13 - nC Gate-Source Charge Qgs - 3.2 - nC Gate-Drain Charge Qgd - 4 - nC - - VDS=-50V,ID=-2.5A,VGS=-10V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD VGS=0V,IS=-1A -1.3 V Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production NOV 2021 Version1.0 3/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET Typical Characteristics:N-channel NOV 2021 Version1.0 4/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET Typical Characteristics:N-channel NOV 2021 Version1.0 5/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET Typical Characteristics:P-channel NOV 2021 Version1.0 6/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET Typical Characteristics:P-channel NOV 2021 Version1.0 7/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET Ordering and Marking Information Ordering Device No. ASDM4100S-R Package Packing Quantity 4100 SOP-8 Tape&Reel 4000/ Reel MARKING PACKAGE SOP-8 NOV 2021 Version1.0 Marking 4100 8/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET SOP-8 PACKAGE IN FORMATION NOV 2021 Version1.0 9/10 www.ascendsemi.com 0755-86970486 ASDM4100S 100V N&P-Channel MOSFET IMPORTANT NOTICE ShenZhen Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). ShenZhen Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. ShenZhen Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does ShenZhen Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume . all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on ShenZhen Ascend Semiconductor Incorporated website, harmless against all damages. ShenZhen Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use ShenZhen Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold ShenZhen Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2021 Version1.0 10/10 www.ascendsemi.com 0755-86970486
ASDM4100S-R 价格&库存
很抱歉,暂时无法提供与“ASDM4100S-R”相匹配的价格&库存,您可以联系我们找货
