ASDM40N80KQ
40V N-Channel MOSFET
Features
Product Summary
Low On-Resistance
• Fast Switching Speed
• 100% avalanche tested
• Lead Free and Green Devices
Available (RoHS Compliant)
VDSS
40
V
RDS(ON)-Typ@VGS=10V
4.0
mΩ
ID
80
A
Application
DC/DC Converters
• On board power for server
• Synchronous rectification
N-channel
Absolute Maximum Ratings
Parameter
Symbol
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
40
VGSS
Gate-Source Voltage
±20
Maximum Junction Temperature
150
°C
-55 to 150
°C
TC=25°C
80
A
TC=25°C
320
A
TC=25°C
80
TC=100°C
51
TA=25°C
25
TA=70°C
19
TC=25°C
65
TC=100°C
26
TA=25°C
4.2
TA=70°C
2.7
TJ
TSTG
IS
Storage Temperature Range
Diode Continuous Forward Current
V
Mounted on Large Heat Sink
IDP
①
300μs Pulse Drain Current Tested
Continuous Drain Current@TC(VGS=10V)
②
ID
Continuous Drain Current@TA(VGS=10V)
③
Maximum Power Dissipation@TC
PD
Maximum Power Dissipation@TA
Parameter
Symbol
RJC
RJA
③
③
A
W
Rating
Unit
Thermal Resistance-Junction to Case
2.4
°C/W
Thermal Resistance-Junction to Ambient
62
°C/W
121
mJ
Drain-Source Avalanche Ratings
EAS
④
Avalanche Energy, Single Pulsed
NOV 2018 Version2.0
1/8
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
Electrical Characteristics (TC=25°C Unless Otherwise Noted)
Symbol
Parameter
Test Condition
LIMIT
Min.
Typ.
Max.
Unit
Static Characteristics
BVDSS
IDSS
Drain-Source Breakdown Voltage VGS=0V, IDS=250µA
Zero Gate Voltage Drain Current
VGS(th)
IGSS
⑤
RDS(ON)
V
VDS=40V, VGS=0V
1
TJ=125°C
Gate Threshold Voltage
VDS=VGS, IDS=250µA
Gate Leakage Current
VGS=±20V, VDS=0V
Drain-Source On-state Resistance
40
30
1
µA
2.5
V
±100
nA
VGS=4.5V, IDS=35A
5.5
6.0
mΩ
VGS=10V, IDS=50A
4.0
4.5
mΩ
1.2
V
Diode Characteristics
⑤
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=50A, VGS=0V
ISD=50A, dlSD/dt=100A/µs
18
ns
29
nC
Ω
⑥
Dynamic Characteristics
RG
Gate Resistance
VGS=0V,VDS=0V,F=1MHz
1.3
Ciss
Input Capacitance
3027
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VGS=0V,
VDS=20V,
Frequency=1.0MHz
td(ON)
Turn-on Delay Time
tr
Turn-on Rise Time
td(OFF)
tf
Turn-off Delay Time
1513
pF
155
13
VDD=20V,IDS=50A,
VGEN=10V,RG=4.7Ω
Turn-off Fall Time
21
29
ns
9
⑥
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
NOV 2018 Version2.0
2/8
VDS=32V, VGS=10V,
IDS=50A
29
5
nC
9
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
Typical Characteristics
Power Dissipation
70
80
ID - Drain Current (A)
60
PD - Power (W)
Drain Current
90
50
40
30
70
60
50
40
30
VGS=10V
50
75
100
125
25
150
50
TJ - Junction Temperature (°C)
10
RDS(ON) - On - Resistance (mΩ)
RDS(ON) limited
100
10µs
100µs
1ms
10ms
DC
1
TC=25°C
0.1
0.01
0.1
1
10
100
100
125
150
Safe Operation Area
1000
75
Drain Current
10
Ids=50A
8
6
4
2
1
2
3
7
8
10
VGS - Gate-Source Voltage (V)
VDS - Drain-Source Voltage (V)
ZthJC - Thermal Response (°C/W)
Thermal Transient Impedance
10
Duty=0.5, 0.2, 0.1, 0.05, 0.02, 0.01, Single Pulse
1
0.1
Single Pulse
0.01
RθJC=1.92°C/W
0.001
1E-05
0.0001
0.001
0.01
0.1
1
10
Square Wave Pulse Duration (sec)
NOV 2018 Version2.0
3/8
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
Output Characteristics
VGS=10V,8V,7V
80
5V
60
3V
40
2V
2
3
4
Drain-Source On Resistance
10
5
RDS(ON) - On Resistance (mΩ)
100
8
VGS=4.5V
6
4
VGS=10V
2
2.0
1.5
1.0
TJ=25°C
Rds(on)=3.5mΩ
-25
50
75
100
125
TJ=150°C
0.1
0.2
150
0.4
C - Capacitance (pF)
3200
Ciss
Coss
800
Crss
1
1
1.2
1.4
10
VDS=24V
IDS=50A
9
8
7
6
5
4
3
2
1
NOV 2018 Version2.0
0.8
Gate Charge
Frequency=1.0MHz
VSD - Source-Drain Voltage (V)
Capacitance
4000
1600
TJ=25°C
1
2400
100
10
0.0
-50
80
Source-Drain Diode Forward
100
VGS=10V
IDS=50A
0.5
60
IS - Source Current (A)
Normalized On Resistance
2.5
40
4/8
100
QG - Gate Charge (nC)
www.ascendsemi.com
0755-86970486
30
ASDM40N80KQ
Avalanche Test Circuit and Waveforms
Switching Time Test Circuit and Waveforms
NOV 2018 Version2.0
5/8
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
Ordering and Marking Information
Ordering Device No.
Marking
ASDM40N80KQ-R
40N80
TO-252
Packing
Tape&Reel
Quantity
2500/Reel
MARKING
PACKAGE
TO-252
NOV 2018 Version2.0
Package
40N80
6/8
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
TO-252 Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
2.200
2.400
0.087
0.094
A1
0.000
0.127
0.000
0.005
b
0.660
0.860
0.026
0.034
c
0.460
0.580
0.018
0.023
D
6.500
6.700
0.256
0.264
D1
5.100
5.460
0.201
0.215
D2
0.483 TYP.
0.190 TYP.
E
6.000
6.200
0.236
0.244
e
2.186
2.386
0.086
0.094
L
9.800
10.400
0.386
0.409
L1
L2
2.900 TYP.
1.400
L3
0.114 TYP.
1.700
0.055
1.600 TYP.
0.067
0.063 TYP.
L4
0.600
1.000
0.024
0.039
Φ
1.100
1.300
0.043
0.051
θ
0°
8°
0°
8°
h
0.000
0.300
0.000
0.012
V
NOV 2018 Version2.0
5.350 TYP.
7/8
0.211 TYP.
www.ascendsemi.com
0755-86970486
ASDM40N80KQ
IMPORTANT NOTICE
ShenZhen Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS
DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION).
ShenZhen Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements,
corrections or other changes without further notice to this document and any product described herein. ShenZhen Ascend Semiconductor
Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither
does ShenZhen Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any
Customer or user of this document or products described herein in such applications shall assume .
all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on ShenZhen
Ascend Semiconductor Incorporated website, harmless against all damages.
ShenZhen Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased
through unauthorized sales channel. Should Customers purchase or use ShenZhen Ascend Semiconductor Incorporated products for any
unintended or unauthorized application, Customers shall indemnify and hold ShenZhen Ascend Semiconductor Incorporated and its
representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal
injury or death associated with such unintended or unauthorized application.
www.ascendsemi.com
NOV 2018 Version2.0
8/8
www.ascendsemi.com
0755-86970486
很抱歉,暂时无法提供与“ASDM40N80KQ-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.10150
- 50+0.85385
- 150+0.74769
- 500+0.61528
