ASDM30N80P-T
ASDM30N80P-T
    ASDSEMI(安森德)
    TO-220-3
    MOSFETs N-沟道 30V 80A 5mΩ@10V 75W TO220
ASDM30N80P-T 数据手册
ASDM30N80P 30V N-Channel MOSFET Features  Advanced Trench Technology  Provide Excellent RDS(ON) and Low Gate Charge Product Summary V DS 30 V R DS(on),TYP@ VGS=10 V 5.0 mΩ 80 A Application  Load Switch  PWM Application ID Absolute Maximum Ratings (TC=25℃ unless otherwise specified) Symbol Parameter Max. Units VDSS Drain-Source Voltage 30 V VGSS Gate-Source Voltage ±20 V TC = 25℃ 80 A TC = 100℃ 50 A 320 A 88 mJ 75 W ID IDM Continuous Drain Current Pulsed Drain Current note1 note2 EAS Single Pulsed Avalanche Energy PD Power Dissipation RθJC Thermal Resistance, Junction to Case RθJA Thermal Resistance, Junction to Ambient TJ, TSTG TC = 25℃ Operating and Storage Temperature Range NOV 2018 Version1.0 1/7 1.68 62 -55 to +175 www.ascendsemi.com ℃/W ℃ 0755-86970486 ASDM30N80P 30V N-Channel MOSFET Electrical Characteristics (TC=25℃ unless otherwise specified) Symbol Parameter Test Condition Min. Typ. Max. Units 30 - - V VDS =30V, VGS = 0V, TJ=25℃ - - 1 VDS =24V, VGS = 0V, TJ=125℃ - - 10 VDS =0V,VGS = ±20V - - ±100 nA Gate Threshold Voltage VDS= VGS, ID=250μA 1.0 1.6 2.5 V Off Characteristic V(BR)DSS IDSS IGSS Drain-Source Breakdown Voltage Zero Gate Voltage Drain Current Gate to Body Leakage Current VGS=0V,ID=250μA uA On Characteristics VGS(th) RDS(on) gFS Static Drain-Source on-Resistance VGS =10V, ID =20A - 5.0 6 note3 VGS =4.5V, ID =10A - 6.8 12 Forward Transconductance VDS =5V, ID =10A - 20 - S - 1914 - pF - 270 - pF - 218 - pF - 11.1 - nC - 1.85 - nC - 6.8 - nC - 7.5 - ns - 14.5 - ns - 35.2 - ns - 9.6 - ns mΩ Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain(“Miller”) Charge VDS =25V, VGS =0V, f = 1.0MHz VDS =15V, ID =20A, VGS =4.5V Switching Characteristics td(on) Turn-on Delay Time tr Turn-on Rise Time td(off) Turn-off Delay Time tf Turn-off Fall Time VDS=15V, ID=15A, RG=3.3Ω, VGS =10V Drain-Source Diode Characteristics and Maximum Ratings IS Maximum Continuous Drain to Source Diode Forward Current - - 80 A ISM Maximum Pulsed Drain to Source Diode Forward Current - - 320 A VSD Drain to Source Diode Forward Voltage - - 1.2 V trr Body Diode Reverse Recovery Time - 32 - ns - 12 - nC Qrr Body Diode Reverse Recovery VGS = 0V, IS=30A IS=30A,dI/dt=100A/μs Charge Notes:1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature 2. EAS condition: TJ=25℃,VDD=25V,VGS=10V, L=0.1mH, IAS=42A, RG=25Ω 3. Pulse Test: Pulse Width≤300μs, Duty Cycle≤2% NOV 2018 Version1.0 2/7 www.ascendsemi.com 0755-86970486 ASDM30N80P 30V N-Channel MOSFET Typical Performance Characteristics Figure1:Gate Charge Test Circuit & Waveform Figure 2: Resistive Switching Test Circuit & Waveforms Figure 3:Unclamped Inductive Switching Test Circuit & Waveforms NOV 2018 Version1.0 3/7 www.ascendsemi.com 0755-86970486 ASDM30N80P 30V N-Channel MOSFET Figure 4:Peak Diode Recovery dv/dt Test Circuit & Waveforms (For N-channel) NOV 2018 Version1.0 4/7 www.ascendsemi.com 0755-86970486 ASDM30N80P 30V N-Channel MOSFET Ordering and Marking Information Ordering Device No. Marking ASDM30N80P-T 30N80 Package TO-220 Packing Quantity Tube 50/Tube MARKING PACKAGE Lot Number TO-220 30N80 Date Code NOV 2018 Version1.0 5/7 www.ascendsemi.com 0755-86970486 ASDM30N80P 30V N-Channel MOSFET TO-220 NOV 2018 Version1.0 6/7 www.ascendsemi.com 0755-86970486 ASDM30N80P 30V N-Channel MOSFET IMPORTANT NOTICE ShenZhen Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). ShenZhen Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. ShenZhen Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does ShenZhen Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume . all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on ShenZhen Ascend Semiconductor Incorporated website, harmless against all damages. ShenZhen Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use ShenZhen Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold ShenZhen Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2018 Version1.0 7/7 www.ascendsemi.com 0755-86970486
ASDM30N80P-T 价格&库存
很抱歉,暂时无法提供与“ASDM30N80P-T”相匹配的价格&库存,您可以联系我们找货
