WS3222D
WS3222D
Http//:www.willsemi.com
Over-Voltage-Protection Load Switch with
Adjustable OVLO threshold
Descriptions
The WS3222 is an Over-Voltage-Protection (OVP)
load switch with adjustable OVLO threshold voltage.
The device will switch off internal MOSFET to
disconnect IN to OUT to protect load when any of input
DFN2×2-8L (Bottom View)
voltage over the threshold.
When the OVLO input set below the external OVLO
select voltage, the WS3222 automatically chooses the
internal fixed OVLO threshold voltage. The over
voltage protection threshold voltage can be adjusted
with external resistor divider and the OVLO threshold
voltage range is 4V~15V. The Over temperature
protection (OTP) function monitors chip temperature to
Pin configuration (Top view)
protect the device.
The WS3222 is available in DFN2×2-8L Package.
Standard products are Pb-free and Halogen-free.
Features
Maximum input voltage
: 29V
Switch ON resistance
: 45mΩ Typ.
Ultra fast OVP response time
: 450ns Typ.
Adjust OVLO threshold voltage : 4V~15V
Marking
D= Package code
b = Voltage code
Y = Year code
W = Week code
Applications
Mobile Handsets and Tablets
Portable Media Players
STB, OTT
Car DVR, Car Media System
Peripherals
Will Semiconductor Ltd.
Order information
Device
WS3222D-8/TR
1
Package
Shipping
DFN2×2-8L
3000/Reel&Tape
Jul, 2019 - Rev.1.3
WS3222D
Function Block Diagram
Typical Applications
Note1: R1 and R2 are only required for External OVP, otherwise connect OVLO to GND
Note2: Recommend
10K≤R2≤50K;add unidirection TVS close to VIN
Pin Descriptions
Pin No.
Symbol
1, 2, 3
OUT
Output
4
GND
Ground
5
OVLO
OVLO Threshold set pin. Connect a resistor-divider to set different OVLO
threshold, VOVLO=1.2x(1+R1/R2) as shown typical application diagram.
6, 7, 8
IN
9
EXPOSED
PAD
Descriptions
Input and Device Power Supply.
Connected to GND.
2
Jul, 2019 - Rev.1.3
WS3222D
Absolute Maximum Ratings
Parameter
Symbol
Value
Unit
VIN
-0.3 ~ 29
V
Output voltage (OUT pin)
VOUT
-0.3 ~ 22
V
Input voltage (OVLO pin)
VOVLO
-0.3~17
V
IOUT
3
A
0.5
W
Input voltage (IN pin)
MAX Continuous Output current
Power dissipation * *
1 3
PD
2 3
Thermal resistance
*1
Thermal resistance *
RθJA
2
0.3
W
250
oC/W
416
o
C/W
Junction temperature
TJ
150
o
Lead temperature(10s)
TL
260
o
Tstg
-55 ~ 150
o
HBM
±4000
V
MM
±200
V
Storage temperature
ESD Ratings
C
C
C
Note:Thesearestressratingsonly.Stressesexceedingtherangespecifiedunder“AbsoluteMaximumRatings”
maycausesubstantialdamagetothedevice.Functionaloperationofthisdeviceatotherconditionsbeyondthose
listedinthespecificationisnotimpliedandprolongedexposuretoextremeconditionsmayaffectdevicereliability.
*1: Surface mounted on FR-4 Board using 1 square inch pad size, dual side, 1oz copper
*2:Surface mounted on FR-4 board using minimum pad size,1oz copper
*3: Power dissipation is calculated by PD = (VIN-VOUT) x IOUT
Recommend Operating Conditions (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Value
Unit
Input voltage
VIN
2.5 ~ 28
V
Ambient operating temperature
TA
-40 ~ 85
oC
3
Jul, 2019 - Rev.1.3
WS3222D
Electronics Characteristics(VIN=5V, CIN=1uF, COUT=4.7uF, Ta=25oC, unless otherwise noted)
Parameter
Symbol
Conditions
Input voltage range
VIN
Quiescent current
IQ
NO Load
ON resistance
RON
VIN=5V, IOUT=1A
OVP response time
TOVP
VIN rising, CIN=CL=0pF
OVLO reference voltage
Min.
Typ.
2.5
VOVLO_TH
110
*1
1.17
VOVLO_HYS*2
Max.
Units
28
V
200
uA
45
mΩ
450
ns
1.2
1.23
35
VIN rising
V
mV
Adjust OVP voltage range
VOVLO_RANGE
4
15
V
External OVLO select
Threshold
VOVLO_SELECT
0.2
0.3
V
UVLO threshold voltage
VUVLO
VIN rising
2.25
2.45
V
UVLO hysteresis voltage
VUVLO_HYS
VIN falling
0.25
V
Turn ON time
TON
VIN>UVLO to
VOUT=VIN*90%
CL=0
16
ms
Output discharge
resistance
RDCHG
VIN=5V
220
Ω
OTP threshold
temperature
TOTP
VIN=5V
150
o
OTP hysteresis
temperature
THYS
VIN=5V
C
oC
*1: Guaranteed by design
*2: If connect a resistor-divider to set different OVLO threshold, then VOVLO_HYS = 35 x (1+R1/R2) mV
4
Jul, 2019 - Rev.1.3
WS3222D
Typical Characteristics (TA=25°C, unless otherwise noted)
ON Resistance vs. Load Current
ON Resistance vs. Temperature
OVLO Threshold vs. Temperature
OVLO Reference Threshold vs. Temperature
Output Voltage vs. Output Current
5
Jul, 2019 - Rev.1.3
WS3222D
UVLO vs. Temperature
Power-ON
Quiescent Current vs. Temperature
Power-OFF VIN=5V,IOUT=3A,Cout=1uf
Power-ON VIN=14.6V, IOUT=2A,Cout=1uf
Power-OFF VIN=14.6V,IOUT=2A,Cout=1uf
6
Jul, 2019 - Rev.1.3
WS3222D
OVP and OVP Recovery(OVP=6.8V, Iout=0A)
OVP and OVP Recovery(OVP=6.8V, Iout=2.5A)
OVP and OVP Recovery(OVP=16V, Iout=0A)
7
OVP and OVP Recovery(OVP=16V, Iout=2A)
Jul, 2019 - Rev.1.3
WS3222D
PACKAGE OUTLINE DIMENSIONS
DFN2x2-8L
Symbol
A
Dimensions in Millimeters
Min.
Typ.
Max.
0.52
0.55
0.58
A3
0.13 Ref.
L
0.2
0.25
0.30
D
1.90
2.00
2.10
E
1.90
2.00
2.10
D1
0.90
1.00
1.10
E1
1.60
1.70
1.80
e
b
0.50 Typ.
0.25
0.30
8
0.35
Jul, 2019 - Rev.1.3
WS3222D
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
Tape Dimensions
W
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
RD
Reel Dimension
7inch
13inch
W
Overall width of the carrier tape
8mm
12mm
P1
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1
Pin1 Quadrant
Q1
Q2
Q3
9
Q4
Jul, 2019 - Rev.1.3
很抱歉,暂时无法提供与“WS3222D-8/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.13580
- 10+1.57950
- 100+1.35410
- 1000+1.12840
- 国内价格
- 5+1.71343
- 50+1.35260
- 150+1.19795
