DOSIN-801-0081
DOSIN-801-0081
    DOSINCONN(德索)
    插件
    射频和同轴连接器 弯插 75Ω 500V
DOSIN-801-0081 数据手册
A B D C E F G Product NO. REV A B 1 2 Tolerance 6 Hex Nut Washer Center Contact Brass TE Brass Nickel Nickel Glod Insulator Body DESCRIPTION Teflon Brass MATERIAL None Nickel FINISH A B APPROVEN John kine 2022/08/09 John kine N I D Specifications Impedance:75 Ohms Frequency Range:DC~3G VSWR:1.3MAX Working Voltage:500V rms @ sea level Insulation Resistance:5000 MOhms min Temperature Range:-55℃ TO +155℃ Relative Temperature:≤95%(40°C±2°C) Drawings products are in line with ROHS standards 5 4 3 2 1 NO DATE 2012/11/02 S O 3 5 DOSIN-801-0081(左右) DWN DESCRIPTION First issue JIM Size 29.5mm changed to 29.2mm, Gavin 14 changed to 13.5 1 1 1 1 1 QTY C 0.5 - 8mm ± 0.20mm 8 - 30mm ± 0.25mm 30 -120mm ± 0.30mm Dosin Industrial(H.K)Co.Ltd Dosin Hardware Electronics Co.,Ltd Name: View UNIT SCALE D dosin2005@dosin-china.com Web:http://www.china-guan.com TEL:(0086)769-81153906 FAX:(0086)769-81875836 R/A BNC JACK FOR PCB CONNECTOR SIZE MM Product NO. A DateTime 1:1 2022/08/09 E REV DOSIN-801-0081(左右) CAD FILE D/company drawings/BD F B SHEET: G 1 OF 1
DOSIN-801-0081 价格&库存
很抱歉,暂时无法提供与“DOSIN-801-0081”相匹配的价格&库存,您可以联系我们找货
DOSIN-801-0081
  • 1+10.36260
  • 10+8.81334
  • 50+7.54110
  • 100+6.54588
  • 500+6.10470
  • 1000+5.90976
库存:22
DOSIN-801-0081
  • 1+6.12654
  • 10+5.86017
库存:9
