MDD2305
-20V P-Channel Enhancement Mode MOSFET
SOT-23
3
V(BR)DSS
RDS(on)Typ
37mΩ@-4.5V
-20V
40mΩ@-3.3V
1. Gate
ID Max
2. Source
-4.2A
3. Drain
2
1
Features
APPLICATION
Trench FET Power MOSFET
z
z
Marking
Load Switch for Portable Devices
DC/DC Converter
Equivalent Circuit
D
D
G
G
XXX
S5
XXX:Date Code
S
S
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
±10
V
Continuous Drain Current
ID
-4.2
A
Pulsed Drain Current (Note 1)
IDM
-16.8
A
Power Dissipation(Note 2)
PD
1.25
W
RθJA
100
℃/W
TJ,Tstg
-50 ~150
Thermal Resistance from Junction to Ambient(Note 2)
Junction Temperature and Storage Temperature
Notes: Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional
operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the
Recommended Operating Conditions may affect device reliability.
1/5
V 1.0
MDD2305
Ta = 25℃ unless otherwise specified
Symbol
Parameter
Condition
Min
Typ
Max
Unit
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA
-20
V
IDSS
Drain-Source Leakage Current
VDS=-20V, VGS=0V
-1
uA
IGSS
Gate-Source Leakage Current
VGS=±10V, VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS, ID=-250μA
-0.4
-0.6
-1
V
Drain-Source On-State Resistance(Note 3)
VGS=-4.5V, ID=-3A
RDS(ON)
37
48
mΩ
VGS=-2.5V, ID=-2A
45
60
mΩ
Min
Typ
Max
Unit
760
pF
94
pF
76
pF
Dynamic Electrical Characteristics
Symbol
Parameter
Condition
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
VDS=-10V
7.8
nC
Qgs
Gate Source Charge
VGS=-4.5V
0.9
nC
Qgd
Gate Drain Charge
1.8
nC
Min
Typ
Max
Unit
VDS=-10V
5.5
ns
VGS =-4.5V
3.9
ns
VDS=-10V
VGS=0V
f=1MHz
ID=-3A
Switching Characteristics
Symbol
Parameter
Condition
td(on)
Turn on Delay Time
tr
Turn on Rise Time
td(off)
Turn Off Delay Time
RG=3.3Ω
11.3
ns
tf
Turn Off Fall Time
RL=1.2Ω
36
ns
Min
Typ
Max
Unit
ID=-2A
Source Drain Diode Characteristics
Symbol
Parameter
Condition
ISD
Source drain current(Body Diode)
TA=25℃
-2
A
VSD
Drain-Source Diode Forward Voltage
IS=-4A, VGS=0V
-0.87
-1.2
V
Notes: 1.Pulse width limited by maximum allowable junction temperature
2.The value of PD&RθJA is measured with the device mounted on 1 in2 FR-4 board with 2oz.Copper, double sided, in a
still air environment with Ta=25℃.
3.Pulse test ; Pulse width≤300us, duty cycle≤2%
2/5
V 1.0
MDD2305
-ID, Drain-Source Current (A)
-VGS(TH), Gate -Source Voltage (V)
Typical Characteristics
-VDS, Drain -Source Voltage (V)
Tj - Junction Temperature (°C)
Fig1. Typical Output Characteristics
Rdson, On -Resistance (mΩ))
Fig2. Normalized Threshold Voltage Vs. Temperature
Fig3. Typical Transfer Characteristics
Fig4. On-Resistance vs. Drain Current and Gate Voltage
-ID - Drain Current (A)
-ID , Drain Current (A)
-ISD, Reverse Drain Current (A)
-VGS, Gate -Source Voltage (V)
-VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
Fig6. Maximum Safe Operating Area
3/5
V 1.0
MDD2305
C, Capacitance (pF)
-VGS, Gate-Source Voltage (V)
-VDS, Drain-Source Voltage (V)
Qg, Total Gate Charge (nC)
Fig8. Typical Gate Charge Vs. Gate-Source Voltage
Thermal Resistance
ZqJA Normalized Transient
Fig7. Typical Capacitance Vs. Drain-Source Voltage
Pulse Width (s)
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Switching Time Test Circuit and waveforms
4/5
V 1.0
MDD2305
Outlitne Drawing
SOT-23 Package Outline Dimensions
A
A1
b
c
D
E
E1
e
L
L1
θ
L
L1
E
E1
Symbol
e
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
5/5
V 1.0
很抱歉,暂时无法提供与“MDD2305”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.16585
- 100+0.15515
- 500+0.14445
- 2000+0.12840
- 5000+0.12305
- 10000+0.11984
- 国内价格
- 5+0.30706
- 50+0.24588
- 150+0.21529
- 500+0.19234
- 3000+0.15641
- 6000+0.14719
