MBRF10200TCT
MBRF10200TCT
    MDD(辰达半导体)
    ITO220AB
    肖特基二极管 200V 10A 880mA@5A ITO-220AB
MBRF10200TCT 数据手册
MBRF10200TCT Reverse Voltage 20 Volts Forward Current 10 Ampere 6CHOTTKY BARRIER RECTIFIERS ITO-220AB FEATURES *XDUG5LQJIRU6WUHVV3URWHFWLRQ /RZ)RUZDUG9ROWDJH /RZ3RZHU/RVV+LJK(IILFLHQF\ +LJK6XUJH&DSDFLW\ /RZ6WRUHG&KDUJH0DMRULW\&DUULHU&RQGXFWLRQ 3E)UHH3DFNDJHVDUH$YDLODEOH • • • • • • • &DVH(SR[\0ROGHG • )LQLVK$OO([WHUQDO6XUIDFHV&RUURVLRQ5HVLVWDQWDQG7HUPLQDO • /HDGVDUH5HDGLO\6ROGHUDEOH • /HDG7HPSHUDWXUHIRU6ROGHULQJ3XUSRVHV ƒ&0D[IRU6HFRQGV 4 2 Common 1 Cathoed 3 Anode Anode MECHANICAL DATA Maximum Ratings And Electrical Characteristics Parameter Peak Repetitive Reverse Voltage Average Rectified Output Current (Total) Average Rectified Output Current (per Leg) Maximum Forward Voltage (IF = 5A, TC = 25°C) Non-Repetitive Peak Forward Surge Current 8.3ms Single Half SineWave Superimposed on Reate Load Operating Junction Temperature Maximum Instantaneous Reverse Current (Rated dc Voltage, TC = 125°C) (Rated dc Voltage, TC = 25°C) Symbol MBRF10200TCT Unit VRRM 200 V 10 IO 5 A VF 0.88 V I FSM 150 A TJ - 55 to +175 °C 6.0 IR 0.02 mA Note:The typical data above is for reference only. DN:T23215A0 http://www.microdiode.com Rev:2023A0 Page :1 MBRF10200TCT Reverse Voltage 20 Volts Forward Current 10 Ampere I R- Insiantaneous Reverse Curront(mA) I F - Insiantaneous Forward Curront(A) Ratings And Characteristic Curves 25 10 5 3 1 0 0 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 5 0.1 0.05 0.02 0 6 4 2 0 0 25 175 100 IFSM, PEAK FORWARD SURGE CURRENT (A) I O, AVERAGE RECTIFIED CURRENT (A) 8 120 80 160 200 Figure 2. Typical Reverse Current Per Diode Figure 1. Typical Forward Voltage Per Diode 10 40 300 250 200 150 100 50 0 1 10 100 o TC ,CASE TEMPERATURE( C ) Fig.3 Forward Current Derating Curve NUMBER OF CY CLES AT 6 0HZ Fig.4 Max Non- Repetitive Surge Current The curve above is for reference only. http://www.microdiode.com Rev:2023A0 Page :2 MBRF10200TCT Reverse Voltage 20 Volts Forward Current 10 Ampere Outlitne ITO-220AB Package Outline Dimensions http://www.microdiode.com Rev:2023A0 Page :3
MBRF10200TCT 价格&库存
很抱歉,暂时无法提供与“MBRF10200TCT”相匹配的价格&库存,您可以联系我们找货
MBRF10200TCT
  • 1+0.73444
  • 10+0.70434
库存:50
