ESD5B5VL
ESD5B5VL
1-Line, Bi-directional, Transient Voltage Suppressors
www.omnivision-group.com
Descriptions
The ESD5B5VL is a bi-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components that may be subjected to ESD
(Electrostatic Discharge) and Lightning. It is particularly
SOD-523
well-suited for cellular phones, portable device, digital
cameras,
power
supplies
and
many
other
portable
applications because of its small package and low weight.
The ESD5B5VL may be used to provide ESD protection up to
±8kV (contact discharge) according to IEC61000-4-2, and
Pin1
Pin2
withstand peak pulse current up to 3 A (8/20μs) according to
IEC61000-4-5.
Circuit diagram
The ESD5B5VL is available in SOD-523 package. Standard
products are Pb-free and Halogen-free.
* B
Pin1
Features
Stand-off voltage: ±5V Max
Transient protection for each line according to
B = Device code
IEC61000-4-2 (ESD): ±8kV (contact discharge)
* = Date code ( A~Z)
IEC61000-4-5 (surge): 3A (8/20μs)
Capacitance: CJ = 5.0pF typ.
Solid-state silicon technology
Pin2
Marking (Top View)
Order information
Applications
Cell phone handsets and accessories
Personal Digital Assistants (PDAs)
Notebooks, Desktops, and Servers
Portable Instrumentation
Digital Cameras
MP3/MP4/PMP Players
Will Semiconductor Ltd.
1
Device
Package
Shipping
ESD5B5VL-2/TR
SOD-523
3000/Tape&Reel
Revision 1.5, 2022/08/23
ESD5B5VL
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
33
W
Peak pulse current (tp = 8/20μs)
IPP
3
A
ESD according to IEC61000-4-2 air discharge
VESD
ESD according to IEC61000-4-2 contact discharge
±15
kV
±8
TJ
125
oC
Operating temperature
TOP
-40~85
oC
Lead temperature
TL
260
oC
TSTG
-55~150
oC
Junction temperature
Storage temperature
Electrical characteristics (TA=25 oC, unless otherwise noted)
VRWM Reverse stand-off voltage
IR
Reverse leakage current
VCL
Clamping voltage
IPP
Peak pulse current
IPP
IHOLD
VCL
VTRIG VHOLD
VBR VRWM
IBR
ITRIG
IR
IR
ITRIG
IBR
VRWM VBR
VHOLD VTRIG
VCL
V
IHOLD
VTRIG Reverse trigger voltage
ITRIG
Reverse trigger current
VBR
Reverse breakdown voltage
IBR
Reverse breakdown current
VHOLD Reverse holding voltage
IPP
IHOLD Reverse holding current
2
ESD5B5VL
Parameter
Symbol
VRWM
IR
Condition
Min.
Typ.
VRWM = 5V
Unit
±5
V
1
μA
8.2
V
VBR
IT=1mA
Clamping voltage 1)
VCL
IPP = 16A, tp = 100ns
13
V
Clamping voltage 2)
VCL
VESD = 8kV
13
V
Clamping voltage 3)
VC
Dynamic resistance 1)
RDYN
Junction capacitance
CJ
6.2
Max.
Ipp=1A tp=8/20μs
8.5
V
Ipp=3A tp=8/20μs
11
V
Ω
0.4
VR = 0V, f = 1MHz
5.0
10
pF
VR =5V, f = 1MHz
3.5
5
pF
Notes:
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 70ns to 90ns. RDYN is calculated from 4A to
2)
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
100
90
Time to half-value: T2= 20s
50
T2
10
90
Front time: T1= 1.25 T = 8s
Current (%)
Peak pulse current (%)
16A.
10
T
T1
8/20μs waveform per IEC61000-4-5
60ns
30ns
Time (s)
tr = 0.7~1ns
t
Time (ns)
Contact discharge current waveform per IEC61000-4-2
3
ESD5B5VL
Typical characteristics (TA=25oC, unless otherwise noted)
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
11.0
Pulse waveform: tp=8/20μs
10.5
10.0
pin1 to pin2
9.5
9.0
pin2 to pin1
8.5
8.0
7.5
0.5
1.0
1.5
2.0
2.5
3.0
3.5
6.00
5.75
5.50
5.25
5.00
4.75
4.50
4.25
4.00
3.75
3.50
3.25
3.00
-5
Ipp - Peak pulse current (A)
f = 1MHz
VAC = 50mV
-4
-3
-2
-1
2
3
4
5
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
10V/div
10V/div
20ns/div
20ns/div
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
24
Z0 = 50
TLP current (A)
16
8
tr = 2ns
tp = 100ns
-16
-24
-15
-10
-5
10
15
TLP voltage (V)
TLP Measurement
4
ESD5B5VL
Package outline dimensions
SOD-523
A1
E
b
D
E2
E1
A
TOP VIEW
SIDE VIEW
0.4
c
2
1.5
1
0.5
SIDE VIEW
Symbol
θ
RECOMMENDED LAND PATTERN(Unit:mm)
Dimensions in Millimeters
Min.
Typ.
Max.
A
0.51
0.77
A1
0.50
0.60
0.70
b
0.25
0.40
c
0.08
0.15
D
0.75
0.80
0.85
E
1.10
1.20
1.30
E1
1.50
1.60
1.70
E2
0.20 Ref.
θ
7︒C Ref.
5
ESD5B5VL
Tape and reel information
Reel Dimensions
RD
Reel Dimensions
Tape Dimensions
W
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
6
Q4
