HSU70P06
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSU70P06 is the high cell density trenched
P-ch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications.
The HSU70P06 meet the RoHS and Green
Product requirement, 100% EAS guaranteed
with full function reliability approved.
VDS
-60
V
RDS(ON),typ
7.5
mΩ
ID
-70
A
TO252 Pin Configuration
Super Low Gate Charge
100% EAS Guaranteed
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
±20
V
-70
A
ID@TC=25℃
ID@TC=100℃
Continuous Drain Current, -VGS @
-10V1
-10V1
-44
A
IDM
Pulsed Drain Current2
-280
A
EAS
Single Pulse Avalanche Energy3
320
mJ
IAS
Avalanche Current
80
A
135
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
62
℃/W
0.95
℃/W
1
HSU70P06
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
Reference to 25℃ , ID=-1mA
-0.036
V/℃
VGS=-10V , ID=-20A
7.5
9.2
VGS=-4.5V , ID=-10A
9.3
12
-1.0
-1.6
-2.5
V
4.28
mV/℃
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
10
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-3A
18
S
Qg
Total Gate Charge (-4.5V)
140
Qgs
Gate-Source Charge
17
Qgd
Gate-Drain Charge
29
Td(on)
VDS=-48V , VGS=-10V , ID=-5A
70
Rise Time
VDD=-48V , VGS=-10V , RG=6,
206
Turn-Off Delay Time
ID=-1A
400
Fall Time
198
Ciss
Input Capacitance
8635
Coss
Output Capacitance
494
Crss
Reverse Transfer Capacitance
291
Min.
Typ.
Max.
Unit
-70
A
-140
A
-1
V
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=-25V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source
Current1,5
Pulsed Source
Current2,5
Diode Forward
Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-50V,VGS=-10V,L=0.1mH,Rg=25,IAS=-80A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSU70P06
Typical Characteristics
Fig.1 Continuous Drain Current vs. TC
Fig.2 Normalized RDSON vs. TJ
Voltage
Fig.3 Normalized Vth vs. TJ
Fig.4 Gate Charge Waveform
diode
Fig.5 Typical Output Characteristics
www.hs-semi.cn
Fig.6 Turn-on Resistances vs.ID
Ver 2.0
3
HSU70P06
Fig.7 Normalized Transient Impedance
Fig.8 Maximum Safe Operation Area
Fig.9 Capacitance Characteristics
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Waveform
Ver 2.0
4
HSU70P06
Ordering Information
Part Number
HSU70P06
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU70P06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.96260
- 10+6.64650
- 30+5.94070
- 100+5.14550
- 500+3.73680
- 1000+3.57790
- 国内价格
- 1+8.07840
- 10+6.77160
- 30+6.05880
- 100+5.24880
- 500+3.81240
- 1000+3.65040
- 国内价格
- 1+4.93000
- 30+4.76000
- 100+4.42000
- 500+4.08000
- 1000+3.91000
- 国内价格
- 1+5.71130
- 10+5.21900
- 30+4.93780
- 100+4.17520
- 300+4.01760
- 1000+3.93890
