5.0SMDJ Series
Transient Voltage Suppressor
HF LF RoHS
5.0SMDJxxxXX
»Features
Excellent clamping capability
Low leakage current
Low capacitance
High surge capability
Glass passivated chip
Epoxy resin package
Built-in strain relief
Will not fatigue
RoHS Compliant
Fast response time:
typically less than 1.0ps from 0 Volts to VBR min
»Mechanical
SMC (DO-214AB)
»Applications
Characteristics
Package: SMC plastic package.
Lead Finish: Matte Tin
Case Material: Epoxy Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Telecom
Computer
Industrial electronic
Consumer electronic
»Electrical Parameters
Parameter
Definition
+I
CJ
Junction Capacitance - typical capacitance measured
with 0V or VR bias
IPP
Peak Pulse Current - maximum rated peak impulse
current
VC
Clamping Voltage - Peak voltage measured across the
suppressor at a specified Ippm (peak impulse current)
VBR
Breakdown Voltage - Maximum voltage that flows
though the TVS at a specified test current (IT)
IR
Leakage Current - maximum peak off-state current
measured at VR
VR
Peak Off-state Voltage - maximum voltage that can be
applied while maintaining off state
VF
Uni
Bi
Ipp
IT
IR
VR
VBR
VC
+V
»Summary of Packing Options
Package
SMC
Revision: 2018
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13" reel
3000
EIA-481-1
Tape/Reel,7" reel
500
EIA-481-1
www.born-tw.com
1/7
5.0SMDJ Series
»Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Units
Remarks
PPPM
5000
W
(Note1)(Note2)
Steady State Power Dissipation
PD
6.5
W
(Note3)
Peak Forward Surge Current
IFSM
300
A
(Note4)
Maximum Instantaneous Forward Voltage at 100A
VFM
5
V
(Note5)
Typical Thermal Resistance Junction to Lead
RθJL
15
℃/W
Typical Thermal Resistance Junction to Ambient
RθJA
75
℃/W
TJ
-55 to 150
TSTG
-55 to 150
Peak Pulse Power Dissipation
Operating Temperature Range
Storage Temperature Range
Notes1: Non-repetitive current pulse , 10/1000us Waveform.
Notes2: Mounted on copper pad area of 8×8mm to each terminal.
Notes3: Infinite HeatSink at TA=50°C
Notes4: Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perminute maximum.
Notes5: For UnidirectionalOnly.
»Electrical Characteristics (TA=25°C unless otherwise noted)
Part
Number
(Uni)
Part
Number
(Bi)
Marking
Code
Uni
Bi
Reverse
Stand off
Voltage VR
(V)
Breakdown
Voltage
VBR @ IT
(V)
Test
Current
IT
(mA)
Maximum
Clamping
Voltage
VC@ IPP
(V)
Maximum
Peak Pulse
Current
IPP
(A)
Maximun
Reverse
Leakage
IR @ VR
(μA)
Min
Max
5
6.4
7
10
9.2
543
800
5.0SMDJ5.0CA
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12
13.3
14.7
10
19.9
252
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13
14.4
15.9
10
21.5
233
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14
15.6
17.2
10
23.2
216
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15
16.7
18.5
1
24.4
205
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16
17.8
19.7
1
26
193
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17
18.9
20.9
1
27.6
181
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18
1
29.2
172
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
24.5
1
32.4
155
5
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22
24.4
26.9
1
35.5
141
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24
26.7
29.5
1
38.9
129
5
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26
28.9
31.9
1
42.1
119
5
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28
31.1
34.4
1
45.4
110
5
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30
33.3
36.8
1
48.4
103
5
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33
36.7
40.6
1
53.3
93.9
5
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36
40
44.2
1
58.1
86.1
5
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40
44.4
49.1
1
64.5
77.6
5
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43
47.8
52.8
1
69.4
72.1
5
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45
50
55.3
1
72.7
68.8
5
5.0SMDJ48A
5.0SMDJ48CA
5PFX
5BFX
48
53.3
58.9
1
77.4
64.7
5
Revision: 2018
5.0SMDJ5.0CA
www.born-tw.com
2/7
5.0SMDJ Series
Breakdown
Voltage
VBR @ IT
(V)
Test
Current
IT
(mA)
Maximum
Clamping
Voltage
VC@ IPP
(V)
Maximum
Peak Pulse
Current
IPP
(A)
Maximun
Reverse
Leakage
IR @ VR
(μA)
62.7
1
82.4
60.7
5
60
66.3
1
87.1
57.5
5
58
64.4
71.2
1
93.6
53.5
5
5BGK
60
66.7
73.7
1
96.8
51.7
5
5PGM
5BGM
64
71.1
78.6
1
103
48.6
5
5.0SMDJ70CA
5PGP
5BGP
70
77.8
86
1
113
44.3
5
5.0SMDJ75A
5.0SMDJ75CA
5PGR
5BGR
75
83.3
92.1
1
121
41.4
5
5.0SMDJ78A
5.0SMDJ78CA
5PGT
5BGT
78
86.7
95.8
1
126
39.7
5
5.0SMDJ85A
5.0SMDJ85CA
5PGV
5BGV
85
94.4
104
1
137
36.5
5
5.0SMDJ90A
5.0SMDJ90CA
5PGX
5BGX
90
100
111
1
146
34.3
5
5.0SMDJ100A
5.0SMDJ100CA
5PGZ
5BGZ
100
111
123
1
162
30.9
5
5.0SMDJ110A
5.0SMDJ110CA
5PHE
5BHE
110
122
135
1
177
28.3
5
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
120
133
147
1
193
26
5
5.0SMDJ130A
5.0SMDJ130CA
5PHK
5BHK
130
144
159
1
209
24
5
5.0SMDJ150A
5.0SMDJ150CA
5PHM
5BHM
150
167
185
1
243
20.6
5
5.0SMDJ160A
5.0SMDJ160CA
5PHP
5BHP
160
178
197
1
259
19.3
5
5.0SMDJ170A
5.0SMDJ170CA
5PHR
5BHR
170
189
209
1
275
18.2
5
Marking
Code
Reverse
Stand off
Voltage VR
(V)
Part
Number
(Uni)
Part
Number
(Bi)
Uni
Bi
Min
Max
5.0SMDJ51A
5.0SMDJ51CA
5PFZ
5BFZ
51
56.7
5.0SMDJ54A
5.0SMDJ54CA
5PGE
5BGE
54
5.0SMDJ58A
5.0SMDJ58CA
5PGG
5BGG
5.0SMDJ60A
5.0SMDJ60CA
5PGK
5.0SMDJ64A
5.0SMDJ64CA
5.0SMDJ70A
Revision: 2018
www.born-tw.com
3/7
5.0SMDJ Series
»Rating And Characteristic Curves (TA=25°C unless otherwise noted)
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
0.1
0.001
0.01
0.1
80
60
40
td - Pulse Width (ms)
150
Fig.2 - Pulse Derating Curve
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
10000
100
1000
CJ (pF)
IPP - Peak Pulse Current, % IRSM
100
TA - Ambient Temperature (℃)
Fig.1 - Peak Pulse Power Rating
50
100
Uni V=0V
10
Bi V=0V
Uni V=VR
Bi V=VR
tr
1
td
14
Fig.3 - Pulse Waveform
Fig.4 - Typical Junction Capacitance
300
IFSM - Peak Forward Surge Current (A)
7
6
5
4
3
2
1
100
150
250
200
150
100
50
10
100
Number of Cycles at 60 Hz
Fig.5 - Steady State Power Dissipation Derating Curve
Revision: 2018
140
VBR - Reverse Breakdown Voltage (V)
t - Time (us)
PD - Steady State Power Dissipation (W)
50
Fig.6 - Maximum Non-Repetitive Peak Forward Surge Current
Uni-Directional Only
www.born-tw.com
4/7
5.0SMDJ Series
»Package Dimensions
B
D
C
A
F
H
L
G
Z
X
Y
SMC
Dimension
Inches
MIN
NOM
Millimeters
MAX
MIN
NOM
MAX
A
0.22
0.245
5.59
6.22
B
0.305
0.32
7.75
8.13
C
0.114
0.126
2.9
3.2
D
0.26
0.28
6.6
7.11
F
0.006
0.012
0.15
0.305
G
H
L
X
Y
Z
0.087
0.03
0.008
0.11
0.06
2.2
0.76
0.203
2.8
1.52
0.15
0.119
0.151
3.82
3.03
3.84
»Marking Information
5.0SMDJxxCA
Revision: 2018
5.0SMDJxxA
or
www.born-tw.com
xx
xx
YYWW
YYWW
xx = Type Code
YYWW = Date Code
xx = Type Code
YYWW = Date Code
5/7
5.0SMDJ Series
»Soldering Parameters
tp
Temperature (T)
TP
Ramp-up
TL
tL
Critical Zone
TL to TP
Ts(max)
Ramp-down
Ts(min)
ts
Preheat
25℃
t 25℃ to Peak
Time (t)
Reflow Condition
Pre Heat
Lead-free assembly
- Temperature Min (Ts(min))
150°C
- Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
Average ramp up rate (Liquidus Temp (TL) to peak)
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Reflow
- Temperature (TL) (Liquidus)
- Time (tL)
217°C
60 – 150 secs
260+0/-5 °C
Peak Temperature (TP)
Time within 5°C of actual peak Temperature (tp)
Revision: 2018
60 – 180 secs
20 – 40 secs
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (t)
Do not exceed
8 minutes Max.
260°C
www.born-tw.com
6/7
5.0SMDJ Series
»Tape and Reel Specification
Cathode
Carrier tape
P0
W
0.059(1.5) DIA
P
Cover tape
D1 or D2
Dimensions are in inches(millimeters)
0.80 (20.2)
Arbor Hole Dia.
Direction of Feed
W1
Dimension
P
P0
W
W1
D1
D2
Revision: 2018
Inches
MIN
NOM
0.315
0.157
0.63
0.646
7
13
Millimeters
MAX
www.born-tw.com
MIN
NOM
8
4
16
16.4
177.8
330.2
MAX
7/7
很抱歉,暂时无法提供与“5.0SMDJ33A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.11040
- 10+2.52720
- 30+2.26800
- 100+1.95480
- 500+1.74960
- 1000+1.66320
