SS510
Reverse Voltage - 100 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AC/SMA
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters,
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.039 (1.00)
0.177(4.50)
0.157(3.99)
free wheeling, and polarity protection applications
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
0.059(1.50)
0.035(0.90)
Mechanical Data
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Case: JEDEC DO-214AC/SMA molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Dimensions in inches and (millimeters)
Weight : 0.0021 ounce, 0.060grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Symbols
SS510
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
V
Maximum RMS voltage
V RMS
70
V
Maximum DC Blocking Voltage
V DC
100
V
Maximum Average Forward Rectified Current
I F(AV)
5.0
A
Peak Forward Surge Current,8.3ms Single Half
Sine-wave Superimposed on Rated Load (JEDEC
method)
I FSM
100
A
Max Instantaneous Forward Voltage at 5 A
VF
0.85
V
IR
0.3
3
mA
Typical Junction Capacitance(1)
Cj
127
pF
Operating Junction Temperature Range
Tj
-55 ~ +175
°C
T stg
-55 ~ +175
°C
Parameter
Maximum DC Reverse Current at
Rated DC Reverse Voltage
Storage Temperature Range
Ta = 25°C
Ta =100°C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A3
Page :1
SS510
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
5.0
4.0
3.0
2.0
1.0
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current (μ
uA)
Average Forward Current (A)
6.0
10
4
10
3
10
2
TJ=100 °C
10 1
TJ=25°C
10
Lead Temperature (°C)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
10
TJ=25°
=25°C
500
JunctionCapacitance (pF)
Instaneous Forward Current (A)
1000
1.0
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
200
100
0.1
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surge Current (A)
125
100
75
50
25
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2024A3
Page :2
SS510
Packing information
unit:mm
P0
Item
P1
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
80,000
16.0
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.90
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“SS510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34409
- 100+0.28156
- 300+0.24938
- 1000+0.22281
- 5000+0.19354
- 10000+0.18728
- 国内价格
- 100+0.18023
- 500+0.17029
- 国内价格
- 10+0.30541
- 100+0.24809
- 1000+0.19424
- 2000+0.19133
- 5000+0.16731
- 国内价格
- 1+0.27060
- 500+0.18150
- 2500+0.15840
- 5000+0.14300
