AGM206D
● General Description
Product Summary
The AGM206D combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON) .
This device is ideal for load switch and battery
protection applications.
● Features
■ Advance
high cell density Trench technology
■ Low
■ Low
RDS(ON) to minimize conductive loss
Gate Charge for fast switching
■ Low
Thermal resistance
BVDSS
RDSON
ID
20V
3.5mΩ
85A
TO-252 Pin Configuration
● Application
■ MB/VGA Vcore
■ SMPS
■ POL
2nd Synchronous Rectifier
application
■ BLDC
Motor driver
Package Marking and Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
AGM206D
AGM206D
TO-252
2500
Table 1.
Absolute Maximum Ratings (TA=25℃)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
V
VGS
Gate-Source Voltage (VDS=0V)
±12
V
Drain Current-Continuous(Tc=25℃) (Note 1)
85
A
Drain Current-Continuous(Tc=100℃)
59
A
Drain Current-Continuous@ Current-Pulsed (Note 2)
300
A
Maximum Power Dissipation(Tc=25℃)
72
w
Maximum Power Dissipation(Tc=100℃)
29
w
340
mJ
-55 To 150
Typ
Max
Unit
ID
IDM (pluse)
PD
EAS
TJ,TSTG
Table 2.
Avalanche energy (Note 3)
Operating Junction and Storage Temperature Range
Thermal Characteristic
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
℃/W
RθJC
Thermal Resistance Junction-Case1
1.72
℃/W
www.agm-mos.com
1
VER2.5
AGM206D
Table 3.
Electrical Characteristics (TA=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
V
IDSS
Zero Gate Voltage Drain Current
VDS=20V,VGS=0V
1.0
μA
IGSS
Gate-Body Leakage Current
VGS=±12V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
0.5
0.7
1.1
V
gFS
Forward Transconductance
VDS=5V,ID=15A
40
S
RDS(on)
Drain-Source On-State Resistance
VGS=4.5V, ID=20A
3.5
4.8
mΩ
VGS=2.5V, ID=15A
6.0
7.0
mΩ
2800
pF
353
pF
265
pF
1.1
17
nS
49
nS
74
nS
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VDS=15V,VGS=0V,
F=1MHZ
VGS=0V,
VDS=0V,f=1.0MHz
Ω
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
26
nS
Qg
Total Gate Charge
32
nC
Qgs
Gate-Source Charge
3.0
nC
Qgd
Gate-Drain Charge
11
nC
85
A
VGS=4.5V,VDS=15V
RL=0.75Ω,RGEN=3Ω
VGS=4.5V,
VDS=10V, ID=12A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VSD
Forward on Voltage
VGS=0V,IS=20A
1.2
V
trr
Reverse Recovery Time
IF=20A , dI/dt=100A/µs ,
23
ns
Qrr
Reverse Recovery Charge
TJ=25℃
10
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃
www.agm-mos.com
2
VER2.5
AGM206D
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS (Curves)
Figure 2. Transfer Characteristics
Id (A)
Id (A)
Figure 1. Output Characteristics
VDS Drain-to-Source Voltage(V)
VGS Gate-to-Source Voltage(V)
Figure 4. Drain Current
Id (A)
Normalized BVDSS
Figure 3. Max BVDSS vs Junction Temperature
TJ-Junction Temperature(℃)
Figure 6. RDS(ON) vs Junction Temperature
Normalized Vth
Normalized Rdson
Figure 5. VGS(th) vs Junction Temperature
www.agm-mos.com
3
VER2.5
AGM206D
Figure 8. Capacitance
Vgs (V)
C Capacitance(pF)
Figure 7. Gate Charge Waveforms
Qg(nC)
Figure 10. Maximum Safe Operating Area
Is (A)
Id (A)
Figure 9. Body-Diode Characteristics
Vsd (V)
Figure 11. Normalized Maximum Transient Thermal Impedance
www.agm-mos.com
4
VER2.5
AGM206D
Test Circuit
1) EAS Test Circuits
2) Gate Charge Test Circuit:
3) Switch Time Test Circuit:
www.agm-mos.com
5
VER2.5
AGM206D
● Dimensions
www.agm-mos.com
SYMBOL
min
max
SYMBOL
min
max
A
2.10
2.50
B
0.85
1.25
b
0.50
0.80
b1
0.50
0.90
b2
0.45
0.70
C
0.45
0.70
D
6.30
6.75
D1
5.10
5.50
E
5.30
6.30
e1
2.25
2.35
L1
9.20
10.60
e2
4.45
4.75
L2
0.90
1.75
L3
0.60
1.10
K
0.00
0.23
6
VER2.5
AGM206D
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequencesDo not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the second version issued on June 10, 2022. This document
replaces andReplace all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
7
VER2.5
很抱歉,暂时无法提供与“AGM206D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89212
- 50+0.74436
- 150+0.67049
- 500+0.61509
- 2500+0.54307
- 5000+0.52080
