AGM311MAP
● General Description
Product Summary
The AGM311MAP combines advanced trench
MOSFET technology with a low resistance package
to provide extremely low RDS(ON) .
This device is ideal for load switch and battery
protection applications.
● Features
■ Advance
BVDSS
30V
high cell density Trench technology
■ Low
■ Low
RDS(ON) to minimize conductive loss
Gate Charge for fast switching
■ Low
Thermal resistance
■ POL
10.5mΩ
25A
D2 D2
D1 D1
2nd Synchronous Rectifier
application
■ BLDC
ID
PDFN3.3*3.3 Pin Configuration
● Application
■ MB/VGA Vcore
■ SMPS
RDSON
S1
G1 S2
G2
Motor driver
Package Marking and Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
AGM311MAP
AGM311MAP
DFN3.3*3.3
5000
Table 1.
Absolute Maximum Ratings (Tc=25℃)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
30
V
VGS
Gate-Source Voltage (VDS=0V)
±20
V
Drain Current-Continuous(Tc=25℃) (Note 1)
25
A
Drain Current-Continuous(Tc=100℃)
A
Drain Current-Continuous@ Current-Pulsed (Note 2)
40
A
Maximum Power Dissipation(Tc=25℃)
12.5
w
Maximum Power Dissipation(Tc=100℃)
5.0
w
Avalanche energy (Note 3)
75
mJ
-55 To 150
Max
Unit
ID
IDM (pluse)
PD
EAS
TJ,TSTG
Table 2.
Operating Junction and Storage Temperature Range
Thermal Characteristic
Symbol
Typ
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
60
℃/W
RθJC
Thermal Resistance Junction-Case1
10
℃/W
www.agm-mos.com
1
VER2.5
AGM311MAP
Table 3.
Electrical Characteristics (TA=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
30
V
IDSS
Zero Gate Voltage Drain Current
VDS=30V,VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.2
1.6
2.5
V
gFS
Forward Transconductance
VDS=10V,ID=5A
10
S
RDS(on)
Drain-Source On-State Resistance
VGS=10V, ID=15A
10.5
15
mΩ
VGS=4.5V, ID=15A
15
22
mΩ
850
pF
130
pF
98
pF
1.9
Ω
4.7
nS
11
nS
17
nS
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VDS=15V,VGS=0V,
F=1MHZ
VGS=0V,
VDS=0V,f=1.0MHz
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
5.6
nS
Qg
Total Gate Charge
10
nC
Qgs
Gate-Source Charge
4.0
nC
Qgd
Gate-Drain Charge
6.1
nC
25
A
VGS=10V,VDS=15V,
RL=0.75Ω,RGEN=3.3Ω
VGS=10V, VDS=15V,
ID=10A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VSD
Forward on Voltage
VGS=0V,Is=20A
1.2
V
trr
Reverse Recovery Time
IF=20A , dI/dt=100A/µs ,
ns
Qrr
Reverse Recovery Charge
TJ=25℃
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃
www.agm-mos.com
2
VER2.5
AGM311MAP
Fig.1 Power Dissipation Derating Curve
Fig.2 Typical output Characteristics
50
1
Drain Current (A)
Power Dissipation Pd/Pd MAX.%
1.2
0.8
0.6
0.4
VGS=10V
VGS=4.5V
25
0.2
100
150
Temperature (。C)
0.5
1
1.5
Drain-Source voltage (V)
200
Fig.3 Threshold Voltage V.S Junction Temperature
2
Fig.4 Resistance V.S Drain Current
2.5
ON Resistance
Vgs(th )
2
1.5
1
10
0.5
50
Fig.5 On-Resistance VS Gate Source Voltage
30
Fig.6 On-Resistance V.S Junction Temperature
1.5
Normalized ON-Resistance
14
12
RDson(mΩ)
10
Drain Current(A)
10
8
6
4
2
0.5
3
www.agm-mos.com
5
7
VGS( V )
9
-50
3
100
Temperature
150
VER2.5
AGM311MAP
Fig.7 Switching Time Measurement Circuit
Fig.8 Gate Charge Waveform
Fig.9 Switching Time Measurement Circuit
Fig.10 Gate Charge Waveform
Fig.11 Avalanche Measurement Circuit
www.agm-mos.com
Fig.12 Avalanche Waveform
4
VER2.5
AGM311MAP
PDFN3333 Package OutlineData
DIMENSIONS ( unit : mm )
Symbol
Min
Typ
Max
Symbol
Min
Typ
Max
A
0.70
0.75
0.80
b
0.25
0.30
0.35
C
0.10
0.15
0.25
D
3.25
3.35
3.45
D1
3.00
3.10
3.20
D2
1.78
1.88
1.98
D3
0.13
E
3.20
3.30
3.40
E1
3.00
3.15
3.20
E2
2.39
2.49
2.59
H
0.30
0.39
0.50
0.65BSC
e
L
0.30
0.40
0.50
L1
0.13
θ
10°
12°
M
0.15
*Not specified
www.agm-mos.com
5
VER2.5
AGM311MAP
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequencesDo not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the second version issued on May 10, 2022. This document
replaces and Replace all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
6
VER2.5
很抱歉,暂时无法提供与“AGM311MAP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64703
- 50+0.63591
- 150+0.62835
- 500+0.62090
