AGM402Q
AGM402Q
    AGMSEMI(芯控源)
    DFN-8(5x6)
    N沟道 40V 120A 125W(Tc) 1.5mΩ
AGM402Q 数据手册
AG GM402Q ● General Description Product Summary The AGM402Q combines advanced trench MOSFET technology with a low resistance package to provide extremely low RDS(ON) . BVDSS RDSON ID 40V 1.5mΩ 120A This device is ideal for load switch and battery protection applications. PDFN5*6 Pin Configuration ● Features ■ Advance high cell density Trench technology RDS(ON) to minimize conductive loss ■ Low Gate Charge for fast switching ■ Low ■ Low Thermal resistance ● Application ■ MB/VGA Vcore ■ SMPS ■ POL 2nd Synchronous Rectifier application Motor driver ■ BLDC Package Marking and Ordering Information Device Marking Device Device Package AGM402Q AGM402Q PDFN5*6 Table 1. Reel Size Tape width Quantity ---- 3000 ---- Absolute Maximum Ratings (TA=25℃) Symbol Parameter Value Unit VDS Drain-Source Voltage (VGS=0V) 40 V VGS Gate-Source Voltage (VDS=0V) ±20 V Drain Current-Continuous(Tc=25℃) (Note 1) 120 A Drain Current-Continuous(Tc=100℃) 90 A Drain Current-Continuous@ Current-Pulsed (Note 2) 400 A Maximum Power Dissipation(Tc=25℃) 125 w Maximum Power Dissipation(Tc=100℃) 50 w Avalanche energy (Note 3) 420 mJ -55 To 150 ℃ Typ Max Unit ID IDM (pluse) PD EAS TJ,TSTG Table 2. Operating Junction and Storage Temperature Range Thermal Characteristic Symbol Parameter RθJA Thermal Resistance Junction-ambient (Steady State)1 --- 50 ℃/W RθJC Thermal Resistance Junction-Case1 --- 1.0 ℃/W www.agm-mos.com 1 VER2.5 AG GM402Q Table 3. Electrical Characteristics (TA=25℃unless otherwise noted) Symbol Parameter Conditions Min Typ Max Unit On/Off States BVDSS Drain-Source Breakdown Voltage VGS=0V ID=250μA 40 -- -- V IDSS Zero Gate Voltage Drain Current VDS=40V,VGS=0V -- -- 1 μA IGSS Gate-Body Leakage Current VGS=±20V,VDS=0V -- -- ±100 nA VGS(th) Gate Threshold Voltage VDS=VGS,ID=250μA 1.2 1.6 2.5 V gFS Forward Transconductance VDS=5V,ID=20A -- 52 -- S RDS(on) Drain-Source On-State Resistance VGS=10V, ID=20A -- 1.5 2.0 mΩ VGS=4.5V, ID=15A -- 2.0 2.6 mΩ -- 3850 -- pF -- 1890 -- pF -- 86 -- pF -- -- -- Ω -- 18.3 -- nS -- 9.0 -- nS -- 58.4 -- nS Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg Gate resistance VDS=15V,VGS=0V, F=1MHZ VGS=0V, VDS=0V,f=1.0MHz Switching Times td(on) Turn-on Delay Time tr Turn-on Rise Time td(off) Turn-Off Delay Time tf Turn-Off Fall Time -- -- -- nS Qg Total Gate Charge -- 45 -- nC Qgs Gate-Source Charge -- 12 -- nC Qgd Gate-Drain Charge -- 18 -- nC -- -- 120 A VGS=10V,VDS=15V, RL=0.75Ω,RGEN=3.3Ω VGS=10V, VDS=25V, ID=12A Source-Drain Diode Characteristics ISD Source-Drain Current(Body Diode) VSD Forward on Voltage VGS=0V,IS=20A -- -- 1.2 V trr Reverse Recovery Time IF=20A , dI/dt=100A/µs , -- -- -- ns Qrr Reverse Recovery Charge TJ=25℃ -- -- -- nc Notes 1.The maximum current rating is package limited. Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature Notes 3.EAS condition: TJ=25℃ www.agm-mos.com 2 VER2.5 AG GM402Q Typical Characteristics Fig.1 Typical Output Characteristics Fig.2 On-Resistance vs G-S Voltage Fig.3 Source Drain Forward Characteristics Fig.4 Gate-Charge Characteristics Fig.5 Normalized VGS(th) vs TJ www.agm-mos.com Fig.6 Normalized RDSON vs TJ 3 VER2.5 AG GM402Q Fig.8 Safe Operating Area Fig.7 Capacitance Normalized Thermal Response (RθJC) 1 DUTY=0.5 0.2 0.1 0.1 0.05 0.02 0.01 0.01 P DM SINGLE T ON T D = TON/T TJpeak = TC+P DMXRθJC 0.001 0.00001 0.0001 0.001 0.01 0.1 1 10 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance EAS= VDS 90% BVDSS 1 L x IAS2 x 2 BVDSS BVDSS-VDD VDD IAS 10% VGS Td(on) Tr Ton Td(off) Tf Toff VGS Fig.11 Unclamped Inductive Switching Waveform Fig.10 Switching Time Waveform www.agm-mos.com 4 VER2.5 AG GM402Q SYMBOL A MILLIMETER MIN 0.900 0.254 REF. A2 0~0.05 MAX 1.100 D 4.824 4.900 4.976 D1 3.910 4.010 4.110 D2 4.924 5.000 5.076 E 5.924 6.000 6.076 E1 3.375 3.475 3.575 E2 5.674 5.750 5.826 b 0.350 0.400 0.450 1.270 TYP. L 0.534 L1 0.424 0.610 0.686 0.500 0.576 1.800 REF. L2 k 1.190 1.290 1.390 H 0.549 0.625 0.701 0 8˚ 10˚ 1²˚ Ø d 5 1.000 A1 e www.agm-mos.com Typ. 1.100 1.200 1.300 0.100 VER2.5 AG GM402Q Disclaimer: The information provided in this document is believed to be accurate and reliable. however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume any responsibility for the following consequences.Do not consider the use of such information or use beyond its scope. The information mentioned in this document may be changed at any time without notice. The products and information provided in this document do not infringe patents. Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility for any infringement of any other rights of third parties.The result of using such products and information. This document is the second version issued on May 10, 2022. This document replaces and Replace all previously provided information. It is a registered trademark of Shenzhen Core Control Electronics Technology Co., Ltd. Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights reserved. www.agm-mos.com 6 VER2.5
AGM402Q 价格&库存
很抱歉,暂时无法提供与“AGM402Q”相匹配的价格&库存,您可以联系我们找货
AGM402Q
  • 1+2.02500
  • 10+1.95000
  • 100+1.77000
  • 500+1.68000
