AG
GM1405C1
C
● General Description
Product Summary
The AGM1405C1 combines advanced trench
MOSFET technology with a low resistance package
to provide extremely low RDS(ON) .
This device is ideal for load switch and battery
BVDSS
RDSON
ID
40V
3mΩ
130A
protection applications.
● Features
■ Advance
TO-220 Pin Configuration
high cell density Trench technology
■ Low
■ Low
RDS(ON) to minimize conductive loss
Gate Charge for fast switching
■ Low
Thermal resistance
● Application
■ MB/VGA Vcore
■ SMPS
■ POL
2nd Synchronous Rectifier
application
■ BLDC
Motor driver
Package Marking and Ordering Information
Device Marking
Device
Device Package
AGM1405C1
AGM1405C1
TO-220
Table 1.
Reel Size
Tape width
Quantity
1000
Absolute Maximum Ratings (TA=25℃)
Symbol
Parameter
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
40
V
VGS
Gate-Source Voltage (VDS=0V)
±20
V
Drain Current-Continuous(Tc=25℃) (Note 1)
130
A
Drain Current-Continuous(Tc=100℃)
82
A
Drain Current-Continuous@ Current-Pulsed (Note 2)
420
A
Maximum Power Dissipation(Tc=25℃)
105
w
Maximum Power Dissipation(Tc=100℃)
41
w
Avalanche energy (Note 3)
360
mJ
ID
IDM (pluse)
PD
EAS
TJ,TSTG
Table 2.
Operating Junction and Storage Temperature Range
-55 To 150
Thermal Characteristic
Symbol
Typ
Parameter
Max
Unit
RθJA
Thermal Resistance Junction-ambient (Steady State)1
45
℃/W
RθJC
Thermal Resistance Junction-Case1
1.2
℃/W
www.agm-mos.com
1
VER2.55
AG
GM1405C1
C
Table 3.
Electrical Characteristics (TA=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
40
V
IDSS
Zero Gate Voltage Drain Current
VDS=40V,VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.1
1.5
2.1
V
gFS
Forward Transconductance
VDS=5V,ID=20A
16
S
RDS(on)
Drain-Source On-State Resistance
VGS=10V, ID=20A
3.0
4.2
mΩ
VGS=4.5V, ID=15A
3.5
4.9
mΩ
2600
pF
370
pF
170
pF
1.7
Ω
6.9
nS
1.7
nS
30
nS
15
nS
nC
9
nC
11
nC
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VDS=15V,VGS=0V,
F=1MHZ
VGS=0V,
VDS= 0V,f=1.0MHz
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VGS=10V,VDS=15V,
RGEN=3.3Ω
RL=0.75Ω
VGS=10V, VDS=20V,
ID=12A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VG=VD=0V,Force Current
130
A
VSD
Forward on Voltage
VGS=0V,IS=20A
1.2
V
trr
Reverse Recovery Time
IF=40A , dI/dt=100A/µs ,
ns
Qrr
Reverse Recovery Charge
TJ=25℃
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃,VDD=15V,VG=10V, RG=25Ω
www.agm-mos.com
2
VER2.55
AG
GM1405C1
C
Fig.1 Power Dissipation
Fig.2 Typical output Characteristics
VGS=10V
VGS=4.5V
Fig.3 Threshold Voltage V.S Junction Temperature
Fig.5 On-Resistance VS Gate Source Voltage
www.agm-mos.com
Fig.4 Resistance V.S Drain Current
Fig.6 On-Resistance V.S Junction Temperature
3
VER2.55
AG
GM1405C1
C
Fig.7 Switching Time Measurement Circuit
Fig.8 Gate Charge Waveform
Fig.9 Switching Time Measurement Circuit
Fig.10 Gate Charge Waveform
Fig.11 Avalanche Measurement Circuit
www.agm-mos.com
Fig.12 Avalanche Waveform
4
VER2.55
AG
GM1405C1
C
Figure1:Gate Charge Test Circuit & Waveform
Figure 2: Resistive Switching Test Circuit & Waveforms
Figure 3:Unclamped Inductive Switching Test Circuit & Waveforms
www.agm-mos.com
5
VER2.55
AG
GM1405C1
C
TO220 PACKAGE INFORMATION
Symbol
Dimensions In Millimeters
Dimensions In Inches
MAX
MIN
MAX
MIN
A
10.300
9.700
0.406
0.382
A1
8.840
8.440
0.348
0.332
A2
1.250
1.050
0.049
0.041
A3
5.300
5.100
0.209
0.201
B
16.200
15.400
0.638
0.606
C
4.680
4.280
0.184
0.169
C1
1.500
1.100
0.059
0.043
D
1.000
0.600
0.039
0.024
E
3.800
3.400
0.150
0.134
G
9.300
8.700
0.366
0.343
H
0.600
0.400
0.024
0.016
K
2.700
2.100
0.106
0.083
L
13.600
12.800
0.535
0.504
M
1.500
1.100
0.059
0.043
N
2.590
2.490
0.102
0.098
T
DIA
www.agm-mos.com
W0.35
Φ1.5 TYP.
W0.014
deep0.2 TYP.
6
Φ0.059 TYP.
deep0.008 TYP.
VER2.55
AG
GM1405C1
C
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequences.Do not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the second version issued on May 10, 2022. This document
replaces and Replace all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
7
VER2.55
很抱歉,暂时无法提供与“AGM1405C1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.48500
- 10+1.43000
- 100+1.29800
- 500+1.23200
- 国内价格
- 1+4.21200
- 10+3.51000
- 50+2.58120
- 100+2.20320
- 500+2.04120
- 1000+1.93320
