AGM425M
● General Description
The AGM425M combines advanced trench
MOSFET technology with a low resistance
package to provide extremely low RDS(ON) .
Product Summary
BVDSS
RDSON
ID
40V
25mΩ
6.6A
-40V
65mΩ
-5.5A
This device is ideal for load switch and battery
protection applications.
● Features
■ Advance high cell density Trench technology
SOP8 Pin Configuration
■ Low RDS(ON) to minimize conductive loss
■Low Gate Charge for fast switching
■Low Thermal resistance
D1
D1
● Application
■MB/VGA Vcore
S1
■SMPS 2nd Synchronous Rectifier
■POL application
■BLDC Motor driver
D2
D1
D2
D2
G1
G1
S2
G2
G2
S1
S2
Package Marking and Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
AGM425M
AGM425M
SOP8
--mm
--mm
3000
Table 1. Absolute Maximum Ratings (TA=25℃)
Rating
Symbol
Parameter
N-Ch
P-Ch
Units
VDS
Drain-Source Voltage (VGS=0V)
40
-40
V
VGS
Gate-Source Voltage (VDS=0V)
±20
±20
V
Drain Current-Continuous(Tc=25℃) (Note 1)
6.6
-5.5
A
Drain Current-Continuous(Tc=100℃)
4.3
-3.7
A
Drain Current-Continuous@ Current-Pulsed (Note 2)
17
-15
A
Total Power Dissipation(Tc=25℃)
1.3
2.0
W
Total Power Dissipation(Tc=100℃)
0.7
0.7
W
EAS
Avalanche energy (Note 3)
22
18
mJ
TJ,TSTG
Operating Junction and Storage Temperature Range
ID
IDM (pluse)
PD
-55 To 150
-55 To 150
Typ
Max
Unit
Table 2. Thermal Characteristic
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
62.5
℃/W
RθJC
Thermal Resistance Junction-Case1
℃/W
www.agm-mos.com
1
VER2.5
AGM425M
Table 3. N- Channel Electrical Characteristics (TA=25℃unless otherwisenoted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
40
V
IDSS
Zero Gate Voltage Drain Current
VDS=40V,VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.1
1.5
2.5
V
gFS
Forward Transconductance
VDS=5V,ID=6A
S
RDS(on)
Drain-Source On-State Resistance
VGS=10V, ID=5A
25
37
mΩ
VGS=4.5V, ID=3A
41
60
mΩ
495
pF
VDS=20V,VGS=0V,
F=1MHZ
42
pF
33
pF
VGS=0V,
VDS=0V,f=1.0MHz
Ω
15
nS
49.5
nS
19.2
nS
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
11
nS
Qg
Total Gate Charge
10
nC
Qgs
Gate-Source Charge
1.4
nC
Qgd
Gate-Drain Charge
1.9
nC
6.6
A
VGS=10V,VDS=20V,
ID=3.5A,RGEN=3Ω
VGS=10V, VDS=20V,
ID=3.5A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VSD
Forward on Voltage
VGS=0V,IS=1A
1.2
V
trr
Reverse Recovery Time
IF=1A , dI/dt=100A/µs ,
ns
Qrr
Reverse Recovery Charge
TJ=25℃
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃
www.agm-mos.com
2
VER2.5
AGM425M
Table 3. P-Channel Electrical Characteristics (TA=25℃unless otherwisenoted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
VGS=0V ID=-250μA
-40
V
IDSS
VDS=-40V,VGS=0V
-1
μA
IGSS
VGS=±20V,VDS=0V
±100
nA
VGS(th)
VDS=VGS,ID=-250μA
-1.2
-1.9
-2.5
V
gFS
VDS=-15V,ID=-3.1A
10
S
RDS(on)
VGS=-10V, ID=-5A
65
80
mΩ
VGS=-4.5V, ID=-4A
92
120
mΩ
600
pF
VDS=-20V,VGS=0V,
F=1MHZ
90
pF
70
pF
VGS=0V,
VDS=0V,f=1.0MHz
Ω
9
nS
8
nS
28
nS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Rg
Gate resistance
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
10
nS
Qg
Total Gate Charge
14
nC
Qgs
Gate-Source Charge
2.9
nC
Qgd
Gate-Drain Charge
3.8
nC
-5.5
A
VGS=-10V,VDS=-20V,
RL=2Ω,RGEN=3Ω
VGS=-10V,
VDS=-20V, ID=-5A
ISD
VSD
Forward on Voltage
VGS=0V,IS=-5A
-1.2
V
trr
IF=-5A , dI/dt=100A/µs ,
ns
Qrr
TJ=25℃
nc
Notes2.RepetitiveRating: Pulsewidthlimitedby maximumjunction temperatureNotes
www.agm-mos.com
3
VER2.5
AGM425M
Typical Characteristics
15
10
VGS = 10V
VDS= 3V
VGS = 6V
VGS = 4.5V
8
Drain current ID (A)
12
VGS = 3V
9
6
VGS = 2.5V
3
4
2
2
3
4
Drain−source voltage VDS (V)
Figure 1. Output Characteristics
1
2
3
4
Gate−source voltage VGS (V)
Figure 2. Transfer Characteristics
5
250
ID= 5A
On-Resistance RDS (on) (mΩ)
Source current IS (A)
4
3
2
1
150
100
50
0.4
0.6
0.8
1.0
Source−drain voltage VSD (V)
Figure 3. Forward Characteristics of Reverse
12
15
2.5
2.0
60
Normalized RDS (on)
9
Figure 4. RDS(ON) vs. VGS
80
VGS = 4.5V
40
VGS = 10V
1.5
1.0
0.5
0.0
2
3
4
5
Figure 5. RDS(ON) vs. ID
www.agm-mos.com
-50
-25
50
75
Temperature Tj(°C)
100
125
150
Figure 6. Normalized RDS(on) vs. Temperature
4
VER2.5
AGM425M
10000
Capacitance(pF)
1000
Ciss
100
Coss
Crss
10
F=1.0MHz
1
Drain-source voltage VDS(V)
40
Figure 7. Capacitance Characteristics
www.agm-mos.com
Figure 8. Gate Charge Characteristics
5
VER2.5
AGM425M
Typical Electrical and Thermal Characteristics
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 1:Switching Test Circuit
PD Power(W)
ID- Drain Current (A)
Figure 2:Switching Waveforms
TJ-Junction Temperature(℃)
Figure 3 Power Dissipation
Rdson On-Resistance(mΩ)
Figure 4 Drain Current
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
www.agm-mos.com
Figure 6 Drain-Source On-Resistance
6
VER2.5
Normalized On-Resistance
AGM425M
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Vsd Source-Drain Voltage (V)
Figure 11 Gate Charge
www.agm-mos.com
Figure 12 Source- Drain Diode Forward
7
VER2.5
AGM425M
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
www.agm-mos.com
8
VER2.5
AGM425M
●Dimensions(SOP8)
SYMBOL
min
TYP
max
SYMBOL
min
max
A
4.80
5.00
C
1.30
1.50
A1
0.37
0.47
C1
0.55
0.75
A2
1.27
C2
0.55
0.65
A3
0.41
C3
0.05
0.20
0.19
B
5.80
6.20
C4
B1
3.80
4.00
D
B2
www.agm-mos.com
5.00
D1
9
0.20
0.23
1.05
0.40
0.62
VER2.5
AGM425M
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequencesDo not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the second version issued on May 10, 2022. This document
replaces andReplace all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
10
VER2.5
很抱歉,暂时无法提供与“AGM425M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.36450
- 10+0.35100
- 100+0.31860
- 500+0.30240
