1N5824
1N5824
    SUNMATE(森美特)
    DO-27(DO-201AA)
    肖特基二极管 IO=5A DO-201AD
1N5824 数据手册
1N5823 - 1N5825 SCHOTTKY BARRIER RECTIFIER DIODE VOLTAGE RANGE: 20 - 40V CURRENT: 5.0 A Features ! Schottky Barrier Chip ! Guard Ring Die Construction for Transient Protection ! High Current Capability A B ! Low Power Loss, High Efficiency ! High Surge Current Capability ! For Use in Low Voltage, High Frequency Inverters, Free Wheeling, and Polarity Protection                Applications  Mechanical Data ! ! ! ! ! ! A C D DO-201AD Case: DO-201AD, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 1.2 grams (approx.) Mounting Position: Any Marking: Type Number Dim Min Max A 25.40 — B 8.50 9.53 C 0.96 1.06 D 4.80 5.21 All Dimensions in mm Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current (Note 1) @TL = 100°C Symbol 1N5823 1N5824 1N5825 Unit VRRM VRWM VR 20 30 40 V VR(RMS) 14 21 28 V IO 5.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 150 A Forward Voltage @IF = 5.0A VFM 0.55 V @TA = 25°C @TA = 100°C IRM 0.5 50 mA Cj 500 pF RJA 10 °C/W Tj, TSTG -65 to +150 °C Peak Reverse Current At Rated DC Blocking Voltage Typical Junction Capacitance (Note 2) Typical Thermal Resistance (Note 1) Operating and Storage Temperature Range Note: 1. Valid provided that leads are kept at ambient temperature at a distance of 9.5mm from the case. 2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. 1 of 2 www.sunmate.tw IF, INSTANTANEOUS FORWARD CURRENT (A) IFSM, PEAK FORWARD SURGE CURRENT (A) 150 Single Half-Sine-Wave (JEDEC Method) 120 90 60 30 0 40 10 1.0 Tj - 25°C IF Pulse Width = 300µs 0.1 0 1 10 0.4 0.6 0.8 1.0 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics NUMBER OF CYCLES AT 60Hz Fig. 3 Max Non-Repetitive Peak Fwd Surge Current 3000 Tj = 25°C 100 Tj = 125°C 10 Cj, CAPACITANCE (pF) IR, INSTANTANEOUS REVERSE CURRENT (mA) 0.2 100 1.0 Tj = 75°C 0.1 1000 Tj = 25°C 0.01 100 0.001 0.1 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig. 5 Typical Reverse Characteristics 2 of 2 1.0 100 10 VR, REVERSE VOLTAGE (V) Fig. 4 Typical Junction Capacitance www.sunmate.tw
1N5824 价格&库存
很抱歉,暂时无法提供与“1N5824”相匹配的价格&库存,您可以联系我们找货
