LM7824T
LM7824T
    HGSEMI(华冠)
    TO-220-3
    线性稳压器/LDO 24V 1.2A 35V
LM7824T 数据手册
LM78XX POSITIVE VOLTAGE REGULATORS ■ ■ ■ ■ ■ OUTPUT CURRENT TO 1.5A OUTPUT VOLTAGES OF 5; 6; 8; 9; 10; 12; 15; 18; 24V THERMAL OVERLOAD PROTECTION SHORT CIRCUIT PROTECTION OUTPUT TRANSITION SOA PROTECTION DESCRIPTION The LM78XX series of three-terminal positive regulators is available in TO-220, TO263, packages and several fixed output voltages, making it useful in a wide range of applications. These regulators can provide local on-card regulation, eliminating the distribution problems associated with single point regulation. Each type employs internal current limiting, thermal shut-down and safe area protection, making it essentially indestructible. If adequate heat sinking is provided, they can deliver over 1A output current. Although designed primarily as fixed voltage regulators, these devices can be used with external components to obtain adjustable voltage and currents. TO-220 Top View DDPAK/TO-263 Top View Figure 1: Schematic Diagram http:www.hgsemi.com.cn 1 2018 MAY LM78XX Table 1: Absolute Maximum Ratings Symbol VI Parameter DC Input Voltage Value for VO= 5 to 18V 35 for VO= 20, 24V 40 Unit V Output Current Internally Limited Ptot Power Dissipation Internally Limited Tstg Storage Temperature Range -65 to 150 °C Top Operating Junction Temperature for L7800 Range for L7800C -55 to 150 0 to 150 °C IO Absolute Maximum Ratings are those values beyond which damage to the device may occur. Functional operation under these condition is not implied. Table 2: Thermal Data TO-220 TO-263 Unit Rthj-case Thermal Resistance Junction-case Max 5 5 °C/W Thermal Resistance Junction-ambient Rthj-amb Max 50 60 °C/W Symbol Parameter Figure 2: Schematic Diagram http:www.hgsemi.com.cn 2 2018 MAY LM78XX Figure 4: Application Circuits TEST CIRCUITS Figure 5: DC Parameter Figure 6: Load Regulation http:www.hgsemi.com.cn 3 2018 MAY LM78XX Figure 7: Ripple Rejection Table 4: Electrical Characteristics Of LM7805 (refer to the test circuits, TJ = -55 to 150°C, VI = 10V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 4.8 5 5.2 V 4.65 5 5.35 V TJ = 25°C 3 50 mV 1 VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 8 to 20 V ∆VO(*) Line Regulation VI = 7 to 25 V VI = 8 to 12 V TJ = 25°C ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 100 IO = 250 to 750 mA TJ = 25°C 25 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W 25 mV 6 mA IO = 5 mA to 1 A 0.5 mA VI = 8 to 25 V 0.8 IO = 5 mA 0.6 Output Noise Voltage B =10Hz to 100KHz Supply Voltage Rejection VI = 8 to 18 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C TJ = 25°C f = 120Hz mV/°C µV/VO 40 68 TJ = 25°C dB 2 2.5 17 TJ = 25°C 1.3 V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 4 2018 MAY LM78XX Table 5: Electrical Characteristics Of LM7806 (refer to the test circuits, TJ = -55 to 150°C, VI = 11V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 5.75 6 6.25 V 5.65 6 6.35 V 60 mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 9 to 21 V ∆VO(*) Line Regulation VI = 8 to 25 V TJ = 25°C VI = 9 to 13 V TJ = 25°C 30 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 100 IO = 250 to 750 mA TJ = 25°C 30 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W mV 6 mA IO = 5 mA to 1 A 0.5 mA VI = 9 to 25 V 0.8 IO = 5 mA 0.7 Output Noise Voltage B =10Hz to 100KHz Supply Voltage Rejection VI = 9 to 19 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C TJ = 25°C f = 120Hz mV/°C 40 65 TJ = 25°C dB 2 2.5 19 TJ = 25°C 1.3 µV/VO V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 6: Electrical Characteristics Of LM7808 (refer to the test circuits, TJ = -55 to 150°C, VI = 14V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 11.5 to 23 V ∆VO(*) Line Regulation VI = 10.5 to 25 V VI = 11 to 17 V ∆VO(*) Id ∆Id Load Regulation Min. Typ. 7.7 8 8.3 V 8 8.4 V TJ = 25°C 80 mV TJ = 25°C 40 IO = 5 mA to 1.5 A TJ = 25°C 100 IO = 250 to 750 mA TJ = 25°C 40 TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A PO ≤ 15W VI = 11.5 to 25 V eN SVR Unit 7.6 Quiescent Current ∆VO/∆T Output Voltage Drift Max. B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 11.5 to 21.5 V f = 120Hz Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mA mA 1 Output Noise Voltage Vd 6 0.5 0.8 IO = 5 mA RO mV mV/°C 40 62 TJ = 25°C dB 2 2.5 16 TJ = 25°C 1.3 µV/VO V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 5 2018 MAY LM78XX Table 7: Electrical Characteristics Of LM7812 (refer to the test circuits, TJ = -55 to 150°C, VI = 19V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 15.5 to 27 V ∆VO(*) Line Regulation VI = 14.5 to 30 V VI = 16 to 22 V ∆VO(*) Id ∆Id Load Regulation Min. Typ. 11.5 12 12.5 V 12 12.6 V TJ = 25°C 120 mV TJ = 25°C 60 IO = 5 mA to 1.5 A TJ = 25°C 100 IO = 250 to 750 mA TJ = 25°C 60 TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A PO ≤ 15W VI = 15 to 30 V eN SVR Unit 11.4 Quiescent Current ∆VO/∆T Output Voltage Drift Max. B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 15 to 25 V f = 120Hz Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mA mA 1.5 Output Noise Voltage Vd 6 0.5 0.8 IO = 5 mA RO mV mV/°C µV/VO 40 61 TJ = 25°C dB 2 2.5 18 TJ = 25°C 1.3 V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 8: Electrical Characteristics Of LM7815 (refer to the test circuits, TJ = -55 to 150°C, VI = 23V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 18.5 to 30 V ∆VO(*) Line Regulation VI = 17.5 to 30 V VI = 20 to 26 V ∆VO(*) Id ∆Id Load Regulation Min. Typ. 14.4 15 15.6 V 15 15.75 V TJ = 25°C 150 mV TJ = 25°C 75 IO = 5 mA to 1.5 A TJ = 25°C 150 IO = 250 to 750 mA TJ = 25°C 75 TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A PO ≤ 15W VI = 18.5 to 30 V eN SVR Unit 14.25 Quiescent Current ∆VO/∆T Output Voltage Drift Max. B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 18.5 to 28.5 V f = 120Hz Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mA mA 1.8 Output Noise Voltage Vd 6 0.5 0.8 IO = 5 mA RO mV mV/°C 40 60 TJ = 25°C dB 2 2.5 19 TJ = 25°C 1.3 µV/VO V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 6 2018 MAY LM78XX Table 9: Electrical Characteristics Of LM7818 (refer to the test circuits, TJ = -55 to 150°C, VI = 26V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 22 to 33 V ∆VO(*) Line Regulation VI = 21 to 33 V VI = 24 to 30 V ∆VO(*) Id ∆Id Load Regulation SVR Typ. Max. Unit 17.3 18 18.7 V 17.1 18 18.9 V TJ = 25°C 180 mV TJ = 25°C 90 IO = 5 mA to 1.5 A TJ = 25°C 180 IO = 250 to 750 mA TJ = 25°C 90 PO ≤ 15W mV Quiescent Current TJ = 25°C 6 mA Quiescent Current Change IO = 5 mA to 1 A 0.5 mA VI = 22 to 33 V 0.8 ∆VO/∆T Output Voltage Drift eN Min. IO = 5 mA 2.3 Output Noise Voltage B =10Hz to 100KHz TJ = 25°C f = 120Hz Supply Voltage Rejection VI = 22 to 32 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mV/°C 40 59 µV/VO dB TJ = 25°C 2 2.5 TJ = 25°C 0.75 1.2 A 2.2 3.3 A 22 1.3 V mΩ (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 11: Electrical Characteristics Of LM7824 (refer to the test circuits, TJ = -55 to 150°C, VI = 33V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 23 24 25 V 22.8 24 25.2 V TJ = 25°C 240 mV VI = 30 to 36 V TJ = 25°C 120 IO = 5 mA to 1.5 A TJ = 25°C 240 TJ = 25°C 120 VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 28 to 38 V ∆VO(*) Line Regulation VI = 27 to 38 V ∆VO(*) Load Regulation IO = 250 to 750 mA Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W mV 6 mA IO = 5 mA to 1 A 0.5 mA VI = 28 to 38 V 0.8 IO = 5 mA 3 Output Noise Voltage B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 28 to 38 V f = 120Hz Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mV/°C 40 56 TJ = 25°C dB 2 2.5 28 TJ = 25°C 1.3 µV/VO V mΩ 0.75 1.2 A 2.2 3.3 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 7 2018 MAY LM78XX Table 12: Electrical Characteristics Of LM7805C (refer to the test circuits, TJ = 0 to 125°C, VI = 10V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 4.8 5 5.2 V 4.75 5 5.25 V TJ = 25°C 3 100 mV VI = 8 to 12 V TJ = 25°C 1 IO = 5 mA to 1.5 A TJ = 25°C 100 IO = 250 to 750 mA TJ = 25°C 50 VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 7 to 20 V ∆VO(*) Line Regulation VI = 7 to 25 V ∆VO(*) Load Regulation Id ∆Id Quiescent Current TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A PO ≤ 15W VI = 7 to 25 V ∆VO/∆T Output Voltage Drift eN SVR Output Noise Voltage B =10Hz to 100KHz Supply Voltage Rejection VI = 8 to 18 V Vd Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C mV 8 mA 0.5 mA 0.8 IO = 5 mA RO 50 TJ = 25°C f = 120Hz -1.1 mV/°C 40 µV/VO 62 TJ = 25°C TJ = 25°C dB 2 V 17 mΩ 0.75 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 14: Electrical Characteristics Of LM7806C (refer to the test circuits, TJ = 0 to 125°C, VI = 11V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 5.75 6 6.25 V 5.7 6 6.3 V 120 mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 8 to 21 V ∆VO(*) Line Regulation VI = 8 to 25 V TJ = 25°C VI = 9 to 13 V TJ = 25°C 60 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 120 IO = 250 to 750 mA TJ = 25°C 60 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W mV 8 mA IO = 5 mA to 1 A 0.5 mA VI = 8 to 25 V 1.3 IO = 5 mA Output Noise Voltage B =10Hz to 100KHz Supply Voltage Rejection VI = 9 to 19 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C TJ = 25°C f = 120Hz TJ = 25°C TJ = 25°C -0.8 mV/°C 45 µV/VO 59 dB 2 V 19 mΩ 0.55 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 8 2018 MAY LM78XX Table 15: Electrical Characteristics Of LM7808C (refer to the test circuits, TJ = 0 to 125°C, VI = 14V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 7.7 8 8.3 V 7.6 8 8.4 V 160 mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 10.5 to 25 V ∆VO(*) Line Regulation VI = 10.5 to 25 V VI = 11 to 17 V TJ = 25°C 80 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 160 IO = 250 to 750 mA TJ = 25°C 80 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W TJ = 25°C mV 8 mA IO = 5 mA to 1 A 0.5 mA VI = 10.5 to 25 V 1 IO = 5 mA Output Noise Voltage B =10Hz to 100KHz TJ = 25°C f = 120Hz Supply Voltage Rejection VI = 11.5 to 21.5 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C -0.8 mV/°C 52 µV/VO 56 dB TJ = 25°C 2 V 16 mΩ TJ = 25°C 0.45 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 17: Electrical Characteristics Of LM7809C (refer to the test circuits, TJ = 0 to 125°C, VI = 15V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 8.64 9 9.36 V 8.55 9 9.45 V 180 mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 11.5 to 26 V ∆VO(*) Line Regulation VI = 11.5 to 26 V TJ = 25°C VI = 12 to 18 V TJ = 25°C 90 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 180 IO = 250 to 750 mA TJ = 25°C 90 Id ∆Id Quiescent Current TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A PO ≤ 15W VI = 11.5 to 26 V ∆VO/∆T Output Voltage Drift eN SVR Output Noise Voltage B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 12 to 23 V f = 120Hz Vd Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C 8 mA 0.5 mA 1 IO = 5 mA RO mV TJ = 25°C TJ = 25°C -1 mV/°C 70 µV/VO 55 dB 2 V 17 mΩ 0.40 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 9 2018 MAY LM78XX Table 18: Electrical Characteristics Of LM7810C (refer to the test circuits, TJ = 0 to 125°C, VI = 16V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 9.6 10 10.4 V 9.5 10 10.5 V mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 12.5 to 26 V ∆VO(*) Line Regulation VI = 12.5 to 26 V TJ = 25°C 200 VI = 13.5 to 19 V TJ = 25°C 100 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 200 IO = 250 to 750 mA TJ = 25°C 100 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W mV 8 mA IO = 5 mA to 1 A 0.5 mA VI = 12.5 to 26 V 1 IO = 5 mA Output Noise Voltage B =10Hz to 100KHz TJ = 25°C f = 120Hz Supply Voltage Rejection VI = 13 to 23 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C -1 mV/°C 70 µV/VO 55 TJ = 25°C TJ = 25°C dB 2 V 17 mΩ 0.40 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 19: Electrical Characteristics Of LM7812C (refer to the test circuits, TJ = 0 to 125°C, VI = 19V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 11.5 12 12.5 V 11.4 12 12.6 V mV VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 14.5 to 27 V ∆VO(*) Line Regulation VI = 14.5 to 30 V TJ = 25°C 240 VI = 16 to 22 V TJ = 25°C 120 ∆VO(*) Load Regulation IO = 5 mA to 1.5 A TJ = 25°C 240 IO = 250 to 750 mA TJ = 25°C 120 Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change ∆VO/∆T Output Voltage Drift eN SVR PO ≤ 15W mV 8 mA IO = 5 mA to 1 A 0.5 mA VI = 14.5 to 30 V 1 IO = 5 mA Output Noise Voltage B =10Hz to 100KHz TJ = 25°C f = 120Hz Supply Voltage Rejection VI = 15 to 25 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C -1 mV/°C 75 µV/VO 55 dB TJ = 25°C 2 V 18 mΩ TJ = 25°C 0.35 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 10 2018 MAY LM78XX Table 20: Electrical Characteristics Of LM7815C (refer to the test circuits, TJ = 0 to 125°C, VI = 23V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 17.5 to 30 V ∆VO(*) Line Regulation VI = 17.5 to 30 V VI = 20 to 26 V IO = 5 mA to 1.5 A TJ = 25°C 300 IO = 250 to 750 mA TJ = 25°C 150 ∆VO(*) Id ∆Id Load Regulation SVR 14.5 15 15.6 V 14.25 15 15.75 V TJ = 25°C 300 mV TJ = 25°C 150 PO ≤ 15W mV Quiescent Current TJ = 25°C 8 mA Quiescent Current Change IO = 5 mA to 1 A 0.5 mA VI = 17.5 to 30 V 1 ∆VO/∆T Output Voltage Drift eN Unit IO = 5 mA Output Noise Voltage B =10Hz to 100KHz TJ = 25°C f = 120Hz Supply Voltage Rejection VI = 18.5 to 28.5 V Vd Dropout Voltage IO = 1 A RO Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C -1 mV/°C 90 µV/VO 54 dB TJ = 25°C 2 V 19 mΩ TJ = 25°C 0.23 A 2.2 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Table 21: Electrical Characteristics Of LM7818C (refer to the test circuits, TJ = 0 to 125°C, VI = 26V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 17.3 18 18.7 V 17.1 18 18.9 V TJ = 25°C 360 mV VI = 24 to 30 V TJ = 25°C 180 IO = 5 mA to 1.5 A TJ = 25°C 360 TJ = 25°C 180 VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 21 to 33 V ∆VO(*) Line Regulation VI = 21 to 33 V ∆VO(*) Load Regulation IO = 250 to 750 mA Quiescent Current TJ = 25°C Quiescent Current Change IO = 5 mA to 1 A Id ∆Id PO ≤ 15W VI = 21 to 33 V ∆VO/∆T Output Voltage Drift eN SVR Output Noise Voltage B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 22 to 32 V f = 120Hz Vd Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C 8 mA 0.5 mA 1 IO = 5 mA RO mV TJ = 25°C TJ = 25°C -1 mV/°C 110 µV/VO 53 dB 2 V 22 mΩ 0.20 A 2.1 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. http:www.hgsemi.com.cn 11 2018 MAY LM78XX Table 23: Electrical Characteristics Of LM7824C (refer to the test circuits, TJ = 0 to 125°C, VI = 33V, IO = 500 mA, CI = 0.33 µF, CO = 0.1 µF unless otherwise specified). Symbol Parameter Test Conditions Min. Typ. Max. Unit 23 24 25 V 22.8 24 25.2 V TJ = 25°C 480 mV VI = 30 to 36 V TJ = 25°C 240 IO = 5 mA to 1.5 A TJ = 25°C 480 TJ = 25°C 240 VO Output Voltage TJ = 25°C VO Output Voltage IO = 5 mA to 1 A VI = 27 to 38 V ∆VO(*) Line Regulation VI = 27 to 38 V ∆VO(*) Load Regulation IO = 250 to 750 mA Quiescent Current TJ = 25°C Id ∆Id Quiescent Current Change PO ≤ 15W IO = 5 mA to 1 A VI = 27 to 38 V ∆VO/∆T Output Voltage Drift eN SVR IO = 5 mA B =10Hz to 100KHz TJ = 25°C Supply Voltage Rejection VI = 28 to 38 V f = 120Hz Vd Dropout Voltage IO = 1 A Output Resistance f = 1 KHz Isc Short Circuit Current VI = 35 V Iscp Short Circuit Peak Current TJ = 25°C 8 mA 0.5 mA 1 Output Noise Voltage RO mV TJ = 25°C TJ = 25°C -1.5 mV/°C 170 µV/VO 50 dB 2 V 28 mΩ 0.15 A 2.1 A (*) Load and line regulation are specified at constant junction temperature. Changes in VO due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. Figure 8: Dropout Voltage vs Junction Temperature http:www.hgsemi.com.cn Figure 9: Peak Output Current vs Input/output Differential Voltage 12 2018 MAY LM78XX Figure 13: Quiescent Current vs Junction Temperature Figure 10: Supply Voltage Rejection vs Frequency Figure 11: Output Voltage vs Junction Temperature Figure 14: Load Transient Response Figure 12: Output Impedance vs Frequency Figure 15: Line Transient Response http:www.hgsemi.com.cn 13 2018 MAY LM78XX Figure 16: Quiescent Current vs Input Voltage Figure 17: Fixed Output Regulator NOTE: 1. To specify an output voltage, substitute voltage value for "XX". 2. Although no output capacitor is need for stability, it does improve transient response. 3. Required if regulator is locate an appreciable distance from power supply filter. Figure 18: Current Regulator Vxx IO =  + Id R1 http:www.hgsemi.com.cn 14 2018 MAY LM78XX Figure 19: Circuit for Increasing Output Voltage IR1 ≥ 5 Id R2 VO = VXX (1+  ) + Id R2 R1 Figure 20: Adjustable Output Regulator (7 to 30V) Figure 21: 0.5 to 10V Regulator R4 VO = V xx  R1 http:www.hgsemi.com.cn 15 2018 MAY LM78XX Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http:www.hgsemi.com.cn 16 2018 MAY
LM7824T 价格&库存
很抱歉,暂时无法提供与“LM7824T”相匹配的价格&库存,您可以联系我们找货
LM7824T
  • 1+1.25400
  • 50+0.96690
  • 1000+0.89100
库存:1308
LM7824T
    • 5+2.01890
    • 50+1.61357
    • 150+1.41639
    库存:205
