CT2305M
P-CHANNEL ENHANCEMENT
MODE POWER MOSFET
»Features
■ Simple Drive Requirement
■ Small Package Outline
BVDSS
-12V
■ Surface Mount Device
■ RoHS Compliant & Halogen-Free
RDS(ON)typ
40mΩ
ID
-4.1A
»Description
CT2305M is from Coretong innovated design and silicon process technology to
achieve the lowest possible on- resistance and fast switching performance. It
provides the designer with an extreme efficient device for use in a wide range of
»Schematic & PIN Configuration
SOT-23
»Absolute Maximum Ratings@Tj=25oC(unless otherwise specified)
Symbol
VDS
VGS
ID-Continuous
IDM
Parameter
Drain-Source Voltage
Gate-Source Voltage
Drain Current, VGS @ 10V
Pulsed Drain Current2
PD@TA=25℃ Total Power Dissipation3
TSTG
Storage Temperature Range
TJ
Operating Junction Temperature Range
»Thermal Data
Symbol
Rthj-a
Parameter
Maximum Thermal Resistance, Junction-ambient3
www.coretong.com
Rating
-12
±8
-4.1
Units
V
V
A
-16
A
0.4
W
-55 to 150
150
Value
313
Unit
℃/W
1/5
CT2305M
MODE POWER MOSFET
»Electrical Characteristics@Tj=25 oC(unless otherwise specified)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Test Conditions
Min.
Typ.
Max.
Units
VGS=0V, ID=250uA
-12
V
VGS=4.5V, ID=-3.5A
40
50
mΩ
Static Drain-Source On-Resistance VGS=-2.5V, ID=-3.0A
55
65
mΩ
VGS=-1.8V, ID=-2.0A
90
120
mΩ
-0.5
-1
V
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250uA
gfs
Forward Transconductance
VDS=5V, ID=-4.1A
6
S
IDSS
Drain-Source Leakage Current
VDS=-8V, VGS=0V
-1
uA
IGSS
Gate-Source Leakage
VGS=±8V, VDS=0V
±100
nA
Qg
Qgs
Total Gate Charge
ID=-4.1A
VDS=-4V
VGS=-2.5V
4.5
nC
1.2
nC
1.6
nC
13
ns
35
53
ns
32
48
ns
10
ns
740
pF
290
pF
190
pF
Test Conditions
Min.
Typ.
Max.
Units
IS=3A, VGS =0V
-0.75
-1.3
V
Qgd
Gate-Source Charge
Gate-Drain ("Miller") Charge
td(on)
Turn-on Delay Time
tr
td(off)
Rise Time
tf
Ciss
Fall Time
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Turn-off Delay Time
Input Capacitance
»Source-Drain Diode
Symbol Parameter
VSD
VDS=-4V
ID=3.3A
RG=1Ω
VGS=-4.5V,RL=1.2Ω
Forward On Voltage²
VGS=0V
VDS=-10V
f=1.0MHz
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 2oz copper pad of FR4 board, t
很抱歉,暂时无法提供与“CT2305M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.17360
- 20+0.15732
- 100+0.14105
- 500+0.12477
- 1000+0.11718
- 2000+0.11176
