F31MDP-08V-K
F31MDP-08V-K
    JST
    Housings
    胶壳及附件 P=3.81mm
F31MDP-08V-K 数据手册
JFA CONNECTOR J300 SERIES 3.81, 5.08, 5.4 mm pitch/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ––––––––––––––––––– • Current rating: (AC, DC) Connectors for signal circuit or power supply circuit, applicable to the factory automation, heavy electric machinery, and other industrial equipment in general. In spite of the various kinds of housings available, their contacts are designed to be common. The applicable tooling can be standardized. • Double-spring construction • Housing lances • Clear click feeling 1 • Voltage rating: J310/J340/J380 series (3.81 mm pitch) 250 V AC, DC J320/J350 series (5.08 mm pitch) 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 5 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: J310/J340/J380 series (3.81 mm pitch) 1,500 VAC/minute J320/J350 series (5.08 mm pitch) 2,200 VAC/minute • Applicable wire: AWG #28 to #14 • Applicable PC board thickness: 1.6 to 2.4 mm * Refer to the page of each product for the specifications of the J330 series and common type (J350D, J360T). * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance. Standards –––––––––––––––––––––– 0 Recognized E60389 2 R50133261 JFA CONNECTOR/J300 SERIES List of J300 series products 3.81 mm pitch / Voltage rating 250 V AC, DC Type Wire-to-wire Wire-to-board Top entry type Side entry type Free hanging type Panel mounting type Screw type Housing lock type J310S Single-row type No. of circuits 3, 4, 5, 6, 8,10 3, 4, 5, 8,10 3, 4, 5, 8,10 B A J310D Double-row type 3, 4, 5, 6, 8,10 B B B A A A [Line pitch 5.08 mm] B B A B A A A B No. of circuits 6, 8,10,12,16, 20 6, 8,10,12,16, 20 6, 8,10,12,16, 20 6,12, 20 B A J310M Double-row module type 6, 8,10,12,16, 20 B A [Line pitch 7.62 mm] B A J-3 10 A B No. of circuits 6 6 J-3 40 J340F Four-row type [Line pitch 5.08 mm] D C B A No. of circuits 12, 20 5.4 mm pitch / Voltage rating 600 V AC, DC 17 0 X A J-3 Panel mounting type J-38 1 1 2 3 4 5 6 18 19 20 21 22 23 13 7 B 2 3 Y 12 [Line pitch 5.08 mm] (Thin type) Wire-to-wire Type 11 J380 Double-row type 4 5 6 7 23 22 11 21 12 13 20 19 18 Screw type 17 17 18 J-38 13 19 20 0 21 Housing lock type 22 12 23 11 7 6 5 4 3 2 1 A B J330 No. of circuits 40 20, 40 [Line pitch 7.7 mm] No. of circuits 30, 40 2 JFA CONNECTOR/J300 SERIES List of J300 series products 5.08 mm pitch / Voltage rating 600 V AC, DC Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type Panel mounting type Screw type 20 J-3 20 J-3 J-3 J320S Single-row type Housing lock type 20 J-3 20 2, 3, 4, 5, 6 2, 3, 4, 5, 6 1, 2, 3, 4 1, 2, 3, 4 12 12 4 1 No. of circuits 2 3 4 1 5 6 1 2 7 8 J-3 9 2 3 50 A 3 4 B 3 J- 10 J350D Double-row type 4 A 5 5 B 3 J- 1 2 3 4 5 [Line pitch 5.08 mm] 1 2 3 10 4 5 9 J-3 8 50 7 6 5 3 A 2 B 12, 20 B J-3 20 20 [Line pitch 7.62 mm] A J320M Double-row module type 4,12, 20 20 No. of circuits J-3 1 J-3 4 B B A J-3 B 20 A A A B 6,10,12 6, 8,10,12 J320T Triple-row module type 6,12 6,12, 20 J-3 No. of circuits 20 [Line pitch 7.62 mm] No. of circuits 9 Double-row common type (J350D) Triple-row common type (J360T) Common type (Line pitch 5.08 mm) No. of circuits 3 12 (Line pitch 6.5 mm) 9,18, 24 JFA CONNECTOR/J300 SERIES Receptacle contact 17.9 (18.4/2L) 3,700 1,000 3,700 1,000 3,200 1,000 3,200 1,000 Material and Finish 17.9 (18.4/2L) (5.3 5.8/2L) Q’ty reel box (Loose piece) Applicable wire Model No. Insulation O.D. (mm) Strip contact Loose piece Size mm2 AWG# SF3F-002 (*) -P2.0 BF3F-002 (*) -P2.0 S 0.08∼0.20 28∼24 0.8∼1.4 M 0.20∼0.50 24∼20 1.2∼2.6 SF3F-01 (*) -P2.0 BF3F-01 (*) -P2.0 L 0.50∼1.25 20∼16 1.8∼2.8 SF3F-41 (*) -P2.0 LF3F-41 (*) -P2.0 2L 1.25∼2.0 16∼14 2.4∼3.4 SF3F-71 (*) -P2.0 BF3F-71 (*) -P2.0 (9.3) Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) (2.5 3.0/2L) RoHS2 compliance Note: Finish (*):GF...Nickel-undercoated, 0.38 μm selective gold-plated GI....Nickel-undercoated, 0.76 μm selective gold-plated T......Tin-plated (reflow treatment) Tab contact Applicable wire Model No. Insulation O.D. (mm) Strip contact Loose piece Size AWG# mm2 SF3M-002 (*) -M2.0N BF3M-002 (*) -M2.0N S 0.08∼0.20 28∼24 0.8∼1.4 1.2∼2.6 SF3M-01 (*) -M2.0N BF3M-01 (*) -M2.0N M 0.20∼0.50 24∼20 1.8∼2.8 0.50∼1.25 20∼16 SF3M-41 (*) -M2.0N LF3M-41 (*) -M2.0N L 2.4∼3.4 16∼14 SF3M-71 (*) -M2.0N BF3M-71 (*) -M2.0N 2L 1.25∼2.0 24.7 (25.2/2L) Q’ty reel box (Loose piece) 3,500 1,000 3,500 1,000 3,300 1,000 3,200 1,000 24.7 (25.2/2L) Material and Finish (5.3 5.8/2L) (2.5 3.0/2L) Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) (11.4) RoHS2 compliance Note: 1. Finish (*):GF...Nickel-undercoated, 0.38 μm selective gold-plated GI....Nickel-undercoated, 0.76 μm selective gold-plated T......Tin-plated (reflow treatment) Crimping machine, Applicator Strip contact Model No. Loose piece Applicator Crimping machine Crimp applicator Dies Crimp applicator with dies BF3F-002 (*) -P2.0 BF3M-002 (*) -M2.0N YRF-882 YRK-8821 BF3F-01 (*) -P2.0 BF3M-01 (*) -M2.0N YRF-881 YRF-880 SF3F-002 (*) -P2.0 SF3M-002 (*) -M2.0N MK/SF3F/M-002-20 APLMK SF3F/M002-20 SF3F-01 (*) -P2.0 SF3M-01 (*) -M2.0N MK/SF3F/M-01-20 APLMK SF3F/M01-20 YRK-8811 LF3F-41 (*) -P2.0 LF3M-41 (*) -M2.0N MK/SF3F/M-41-20 APLMK SF3F/M41-20 YRK-8801 BF3F-71 (*) -P2.0 BF3M-71 (*) -M2.0N MK/SF3F/M-71-20 APLMK SF3F/M71-20 YRK-1071 SF3F-41 (*) -P2.0 SF3M-41 (*) -M2.0N AP-K2N MKS-L SF3F-71 (*) -P2.0 SF3M-71 (*) -M2.0N Hand tools Hand tools YRF-1070 YRF-1071 Note: Finish (*): GF...Nickel-undercoated, 0.38 μm selective gold-plated GI....Nickel-undercoated, 0.76 μm selective gold-plated T......Tin-plated Note: Finish (*): GF...Nickel-undercoated, 0.38 μm selective gold-plated GI....Nickel-undercoated, 0.76 μm selective gold-plated T......Tin-plated • Special extraction tool for J300 series: For receptacle only ...EJ-JFAJ3R, For tab only ...EJ-JFAJ3T • Extraction tool for J300 series: EJ-JFAJ3 • Refer to the page of "Crimping tools " for details of YRK series hand crimping tools that uses a strip contact. Recognition mark • Plating of the contact Each contact has a marking on its side so that the type or thickness of the plating is recognized. 2 ... gold-plated 0.38 μm thickness 3 ... gold-plated 0.76 μm thickness 5 ... tin-plated Receptacle contact T Tab contact JST 2 JS 2 Indication of the plating Indication of the plating • Common marking on the contact and its application tools In order to avoid incorrect combination of the hand crimp tools or extraction tools and the contacts, the series name (for example J-3) and wire range mark (S, M, L, 2L) are shown on both the tools and the contacts. J-3 S.....AWG #28 ∼ #24 M....AWG #24 ∼ #20 L.....AWG #20 ∼ #16 2L...AWG #16 ∼ #14 Receptacle contact Tab contact J-3 L Wire range mark J3 L Wire range mark Series name Series name 4 JFA CONNECTOR/J300 SERIES Keying plug 3.6 2.5 RoHS2 compliance 2.9 4.5 25 Tab contact (Cutting jig) RoHS2 compliance Note: Not UL/TÜV approved. 5 J300 SERIES/J310S Assembly layout (8.6) (28.9) (28.4) (10.1) Wire-to-board (40.6) (8.6) Wire-to-wire Receptacle housing Circuits Keying Model No. A 3.81 3 X 7.15 6.55 Y 4 X Y 5 X Y B 6 X Y 16.4 Series name X JST J-3 1 2 3 Circuit No. 8 22.8 Keying No. X Y 10 X Y 4 5 F31FSS-03V-KX F31FSS-03V-KY F31FSS-04V-KX F31FSS-04V-KY F31FSS-05V-KX F31FSS-05V-KY F31FSS-06V-KX F31FSS-06V-KY F31FSS-08V-KX F31FSS-08V-KY F31FSS-10V-KX F31FSS-10V-KY Dimensions (mm) A B C Q’ty /bag 7.62 16.70 26.62 200 7.62 16.70 26.62 200 11.43 20.51 30.43 200 11.43 20.51 30.43 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 19.05 28.13 38.05 200 19.05 28.13 38.05 200 26.67 35.75 45.67 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 34.29 43.37 53.29 100 Material and Finish C Glass-filled PBT, UL94V-0, black RoHS2 compliance 6 J300 SERIES/J310S Tab housing (Free hanging type) Circuits Keying Model No. A C F31MSF-03V-KX F31MSF-03V-KY F31MSF-04V-KX F31MSF-04V-KY F31MSF-05V-KX F31MSF-05V-KY F31MSF-08V-KX F31MSF-08V-KY F31MSF-10V-KX F31MSF-10V-KY X 8.78 9.35 12.7 9.35 X X 3 Y X 4 Y X 3.81 5 Keying No. A Y X 8 5.0 B Y X 33.6 4.0 10 Y Dimensions (mm) B C Q’ty /bag 7.62 21.62 25.57 200 7.62 21.62 25.57 200 11.43 25.43 29.38 200 11.43 25.43 29.38 200 15.24 29.24 33.19 200 15.24 29.24 33.19 200 26.67 40.67 44.62 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 34.29 48.29 52.24 100 Material and Finish Series name Glass-filled PBT, UL94V-0, black Circuit No. J-310 RoHS2 compliance 3 2 1 Tab housing (Panel mounting type) Circuits Keying E D X 8.78 9.35 5 . φ3 2- 12.7 9.35 X X 3 Y X 4 Y X 3.81 A 5 Keying No. Y 5.0 X 8 B Y X 33.6 4.0 10 Series name φ3.6 ±0.1 A F31MSP-03V-KX F31MSP-03V-KY F31MSP-04V-KX F31MSP-04V-KY F31MSP-05V-KX F31MSP-05V-KY F31MSP-08V-KX F31MSP-08V-KY F31MSP-10V-KX F31MSP-10V-KY Dimensions (mm) B C D E Q’ty /bag 7.62 21.62 22.60 31.00 40.00 200 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 200 11.43 25.43 26.40 34.50 43.50 200 15.24 29.24 30.20 38.00 47.00 200 15.24 29.24 30.20 38.00 47.00 200 26.67 40.67 41.60 50.00 59.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 34.29 48.29 49.20 58.00 67.00 100 Material and Finish 5.15 ±0.3 Glass-filled PBT, UL94V-0, black J-310 Circuit No. D ±0.05 C ±0.3 10.3 ±0.3 3 2 1 Connector outline 4-R0.5(MAX) Panel layout 7 Y Model No. RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. J300 SERIES/J310S Header (Top entry type) Circuits Keying Model No. C X X 9.35 X 3 X (1.27) Keying No. 3.81 A Y Series name 4 Y X 5 Y X 6 21.6 Circuit No. J-310 Y X 8 5 4 3 2 1 Y X Y 3.8 10 (3.175) B03B-F31SK-GGXR B03B-F31SK-GGYR B04B-F31SK-GGXR B04B-F31SK-GGYR B05B-F31SK-GGXR B05B-F31SK-GGYR B06B-F31SK-GGXR B06B-F31SK-GGYR B08B-F31SK-GGXR B08B-F31SK-GGYR B10B-F31SK-GGXR B10B-F31SK-GGYR Dimensions (mm) A B C Q’ty/box 7.62 13.97 21.62 220 7.62 13.97 21.62 220 11.43 17.78 25.43 180 11.43 17.78 25.43 180 15.24 21.59 29.24 160 15.24 21.59 29.24 160 19.05 25.40 33.05 140 19.05 25.40 33.05 140 26.67 33.02 40.67 120 26.67 33.02 40.67 120 34.29 40.64 48.29 100 34.29 40.64 48.29 100 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 1.27 ±0.05 φ1.1 ±0.1 Copper foil land 2-φ3.0 (MIN) Through-hole 2-φ2.0 ±0.1 3.81±0.05 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits Keying (3.81) 3.8 3.34 A 3.81 X 7.62 0.82 3 Y X X Keying No. 9.35 10.85 X 4 Y X 5 Y X Series name 6 Y X Circuit No. J-310 22.1 8 Y X 10 Y Model No. S03B-F31SK-GGXR S03B-F31SK-GGYR S04B-F31SK-GGXR S04B-F31SK-GGYR S05B-F31SK-GGXR S05B-F31SK-GGYR S06B-F31SK-GGXR S06B-F31SK-GGYR S08B-F31SK-GGXR S08B-F31SK-GGYR S10B-F31SK-GGXR S10B-F31SK-GGYR Dimensions (mm) Q’ty/box A B C 7.62 15.24 21.62 165 7.62 15.24 21.62 165 11.43 19.05 25.43 135 11.43 19.05 25.43 135 15.24 22.86 29.24 120 15.24 22.86 29.24 120 19.05 26.67 33.05 105 19.05 26.67 33.05 105 26.67 34.29 40.67 90 26.67 34.29 40.67 90 34.29 41.91 48.29 75 34.29 41.91 48.29 75 5 4 3 2 1 Material and Finish C Connector outline 0.82 7.62±0.05 Copper foil land 2-φ4.0 (MIN) Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Through-hole 2-φ3.0 ±0.1 3.81±0.05 φ1.1 ±0.1 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 8 J300 SERIES/J310D Assembly layout (13.7) B A (32.8) B B A (28.4) A B (15.2) Wire-to-board A (40.6) Wire-to-wire B (13.7) B A A Receptacle housing A Line No. 12.23 11.63 5.08 3.81 B A B Circuits Keying 6 — 8 — 10 — 12 — 16 — 20 — Model No. F31FDS-06V-K F31FDS-08V-K F31FDS-10V-K F31FDS-12V-K F31FDS-16V-K F31FDS-20V-K Dimensions (mm) A B C Q’ty/bag 7.62 16.70 26.62 200 11.43 20.51 30.43 100 15.24 24.32 34.24 100 19.05 28.13 38.05 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 16.4 22.8 Material and Finish Series name J-3 RoHS2 compliance JST 1 2 3 Circuit No. Glass-filled PBT, UL94V-0, black 4 5 C Tab housing (Free hanging type) C 3.81 5.0 14.43 A A B 17.78 5.08 Line No. Circuits Keying 6 — 8 — 10 — 12 — 16 — 20 — B Model No. F31MDF-06V-K F31MDF-08V-K F31MDF-10V-K F31MDF-12V-K F31MDF-16V-K F31MDF-20V-K A Dimensions (mm) B C 7.62 21.62 25.57 200 11.43 25.43 29.38 100 15.24 29.24 33.19 100 19.05 33.05 37.00 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 Material and Finish 4.0 33.6 Glass-filled PBT, UL94V-0, black Series name J-310 3 2 1 9 Circuit No. RoHS2 compliance Q’ty/bag J300 SERIES/J310D Tab housing (Panel mounting type) Circuits Keying E Line No. 17.78 A B .5 φ3 2- 14.43 5.08 D 3.81 6 — 8 — 10 — 12 — 16 — 20 — Dimensions (mm) Model No. F31MDP-06V-K F31MDP-08V-K F31MDP-10V-K F31MDP-12V-K F31MDP-16V-K F31MDP-20V-K C D E Q’ty /bag 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 100 15.24 29.24 30.20 38.00 47.00 100 19.05 33.05 34.00 42.00 51.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 Glass-filled PBT, UL94V-0, black B 4.0 5.0 B Material and Finish A 33.6 A RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Series name Circuit No. J-310 7.65 ±0.3 3 2 1 15.3 ±0.3 D ±0.05 C ±0.3 φ3 .6 4- Connector outline R0 .5 ± 0.1 (M AX ) Panel layout Tab housing (Panel mounting Housing lock type) Circuits Keying 14.43 17.5 14.43 3.81 B 7 A 10.3 5.08 E 12.7 10.5 E Q’ty /bag 7.62 21.62 22.15 26.65 26.33 100 19.05 33.05 33.55 38.05 37.76 100 34.29 48.29 48.80 53.30 53.00 80 3 2 1 2.25 ±0.1 C ±0.1 14.7 ±0.1 4 4-R 0.3max. 10.8 ±0.1 5 1.95 ±0.1 33.6 D ±0.1 J-310 6 — D RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Not UL/TÜV approved. Circuit No. 7 20 F31MDPL-06V-K F31MDPL-12V-K F31MDPL-20V-K C Glass-filled PBT, UL94V-0, black Series name 8 — B Material and Finish B 9 — A Line No. A 10 6 12 Dimensions (mm) Model No. 4-R 0.8max. Panel layout (Panel thickness:1.6∼2.5 mm) 10 J300 SERIES/J310D Header (Top entry type) Circuits Keying (1.27) A 5.08 B 14.43 5.08 C Model No. Line No. 3.81 A 6 — 8 — 10 — 12 — 16 — 20 — B06B-F31DK-GGR B08B-F31DK-GGR B10B-F31DK-GGR B12B-F31DK-GGR B16B-F31DK-GGR B20B-F31DK-GGR Dimensions (mm) A C B Q’ty/box 7.62 13.97 21.62 132 11.43 17.78 25.43 108 15.24 21.59 29.24 96 19.05 25.40 33.05 84 26.67 33.02 40.67 72 34.29 40.64 48.29 60 Series name Material and Finish 21.6 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Circuit No. J-310 5 4 3 2 1 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. 3.8 3.81 (3.175) φ1.1 ±0.1 1.27 ±0.05 5.08 ±0.05 Copper foil land 2-φ3.0 (MIN) Through-hole 2-φ2.0 ±0.1 3.81±0.05 Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Circuits Keying 5.08 14.43 15.93 3.8 (3.81) Series name J-310 5 4 3 2 1 C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) 0.82 3.81 ±0.05 Through-hole 2-φ3.0 ±0.1 3.81±0.05 3.81±0.05 B ±0.05 φ1.1 ±0.1 PC board layout (viewed from component side) 11 6 — 8 — 10 — 12 — 16 — 20 — Line No. Model No. S06B-F31DK-GGR S08B-F31DK-GGR S10B-F31DK-GGR S12B-F31DK-GGR S16B-F31DK-GGR S20B-F31DK-GGR Dimensions (mm) C A B Q’ty/box 7.62 15.24 21.62 88 11.43 19.05 25.43 72 15.24 22.86 29.24 64 19.05 26.67 33.05 56 26.67 34.29 40.67 48 34.29 41.91 48.29 40 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 25.91 Circuit No. 7.62 3.81 0.82 B A 3.81 A 3.34 Header (Side entry type) RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES/J310M Assembly layout When mating with J310M receptacle When mating with J310S receptacle modular (16.2) A B (16.2) (28.4) (28.4) Top entry type B B A A Wire-to-board (32.8) (32.8) A B A B A (17.7) B (17.7) Side entry type 12 J300 SERIES/J310M Receptacle housing Circuits 7.62 Keying Model No. Q’ty/bag XX F31FMS-06V-KXX F31FMS-06V-KYY F31FMS-06V-KXY 100 Line No. 3.81 6 14.77 14.17 A B 7.62 YY XY 100 100 Material and Finish Glass-filled PBT, UL94V-0, black (16.7) 16.4 22.8 RoHS2 compliance Keying No. Series name XX J-3 JST 1 2 3 Circuit No. (21.42) (26.62) Header (Top entry type) 7.62 A B 16.97 X 7.62 X X X Keying Model No. Q’ty/box XX B06B-F31MK-GGXXR B06B-F31MK-GGYYR B06B-F31MK-GGXYR 132 YY 6 XY Line No. 3.81 7.62 1.27 ±0.05 φ1.1 ±0.1 21.6 J-310 Copper foil land 2-φ3.0 (MIN) 3.8 3 2 1 3.81 (3.175) 132 Material and Finish Series name Circuit No. 132 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Through-hole 2-φ2.0 ±0.1 7.62 ±0.05 Keying No. Circuits (1.27) 21.62 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 3.81 ±0.05 3.175 ±0.05 13.97 ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits (3.81) 3.8 3.81 7.62 18.47 16.97 X 7.62 X X Model No. Q’ty/box XX S06B-F31MK-GGXXR S06B-F31MK-GGYYR S06B-F31MK-GGXYR 88 YY XY B X A 3.34 6 Keying No. Keying 3.81 0.82 88 88 Material and Finish Line No. Series name Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 3 2 1 Copper foil land 2-φ4.0 (MIN) 7.62 ±0.05 J-310 25.91 Connector outline Circuit No. Through-hole 2-φ3.0 ±0.1 3.81 ±0.05 21.62 3.81 ±0.05 φ1.1 ±0.1 3.81 ±0.05 15.24 ±0.05 PC board layout (viewed from component side) 13 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES/J310M Keying J310M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) XX-Keying Line B X Y Indication of keying Y Line B Y Line B Line A Indication of keying Y X X Indication of keying X Y Line A Y X X Line A Key rib Key rib Key rib YY-Keying XY-Keying List of combinations With the combination of the J310M headers and the J310M/J310S (3 circuits) receptacle housings, the following modular combinations are possible. Header Receptacle housing Top entry type F31FSS-03V-KX X X-Keying X Single-row 3 circuits (J310S) Single-row 3 circuits (J310S) X X Y X-Keying S03B-F31SK-GGXR Y-Keying B03B-F31SK-GGYR S03B-F31SK-GGYR Double-row XX-Keying 6 circuits B06B-F31MK-GGXXR (J310M) Double-row XX-Keying 6 circuits S06B-F31MK-GGXXR (J310M) Y X Y F31FMS-06V-KYY B B03B-F31SK-GGXR Single-row 3 circuits (J310S) Y-Keying YY-Keying Y YY-Keying X Double-row XX-Keying 6 circuits F31FMS-06V-KXX (J310M) Y F31FSS-03V-KY Y Y-Keying X-Keying Side entry type B06B-F31MK-GGYYR J-3 10 YY-Keying B S06B-F31MK-GGYYR A A A X XY-Keying X B XY-Keying XY-Keying B06B-F31MK-GGXYR S06B-F31MK-GGXYR Y Y F31FMS-06V-KXY 14 J300 SERIES/J320S Assembly layout • Normal type (8.6) (10.1) (28.9) (28.4) Wire-to-board • Reverse type (9.1) (28.9) • Single circuit • 2 to 4 circuits (40.6) 15 (8.6) (10.2) Wire-to-wire (40.6) J300 SERIES/J320S Receptacle housing • Single circuit Circuits Keying Model No. (C) 1 X 1 JST Circuit No. Keying No. 22.8 2 3 4 B 8.9 5 6 X Y X Y X Y X Y X Y X Y F32FSS-01V-KX F32FSS-01V-KY F32FSS-02V-KX F32FSS-02V-KY F32FSS-03V-KX F32FSS-03V-KY F32FSS-04V-KX F32FSS-04V-KY F32FSS-05V-KX F32FSS-05V-KY F32FSS-06V-KX F32FSS-06V-KY Dimensions (mm) A B C — — Q’ty/bag 9.40 12.00 200 9.40 12.00 200 5.08 14.16 24.08 200 5.08 14.16 24.08 200 10.16 19.24 29.16 200 10.16 19.24 29.16 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 20.32 29.40 39.32 200 20.32 29.40 39.32 200 25.40 34.48 44.40 100 25.40 34.48 44.40 100 Material and Finish • 2 to 6 circuits A Glass-filled PBT, UL94V-0, black 7.15 6.55 5.08 RoHS2 compliance 16.4 Keying No. Series name X J-3 1 Circuit No. 22.8 B JST 2 3 4 5 C Tab housing (Free hanging type) Circuits Keying • Single circuit Model No. Keying No. 7 11.6 1 2 3 5 C B 4 4 J-320 Y X Y X Y X Y (33.6) Series name X F32MSF-01V-KX F32MSF-01V-KY F32MSF-02V-KX F32MSF-02V-KY F32MSF-03V-KX F32MSF-03V-KY F32MSF-04V-KX F32MSF-04V-KY Dimensions (mm) A B C Q’ty/bag — 13.60 15.60 150 — 13.60 15.60 150 5.08 19.08 23.03 200 5.08 19.08 23.03 200 10.16 24.16 28.11 200 10.16 24.16 28.11 200 15.24 29.24 33.19 200 15.24 29.24 33.19 200 Material and Finish Circuit No. Glass-filled PBT, UL94V-0, black RoHS2 compliance 6.4 11.6 • 2 to 4 circuits 8.78 9.35 9.35 12.7 X X C 5.08 Keying No. A Series name J-320 3 2 33.6 4 5 B Circuit No. 1 16 J300 SERIES/J320S Tab housing (Panel mounting type) Circuits Keying Single circuit E D X 1 Y X 7 11.6 15.6 11.6 2 Y X 3 Keying No. Y X 4 Y 5 B Model No. F32MSP-01V-KX F32MSP-01V-KY F32MSP-02V-KX F32MSP-02V-KY F32MSP-03V-KX F32MSP-03V-KY F32MSP-04V-KX F32MSP-04V-KY D ±0.05 C ±0.05 2-φ3.6 12.6 ±0.05 6.3 ±0.05 Circuit No. 1 6.4 E Q’ty /bag — 11.60 12.60 21.00 28.60 150 — 11.60 12.60 21.00 28.60 150 5.08 19.08 20.00 28.00 36.83 200 5.08 19.08 20.00 28.00 36.83 200 10.16 24.16 25.00 33.00 41.91 200 10.16 24.16 25.00 33.00 41.91 200 15.24 29.24 30.00 38.00 46.99 200 15.24 29.24 30.00 38.00 46.99 200 R0 .5 Glass-filled PBT, UL94V-0, black ±0.1 4- Connector outline (M AX ) 11.6 Dimensions (mm) B C D Material and Finish 4 (33.6) J-320 Series name A RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Panel layout 2 to 4 circuits E 8.78 3.5 2-φ 9.35 12.7 X X D 5.08 Keying No. A 5 B 33.6 4 10.22 ±0.3 5.11 ±0.3 D ±0.05 C ±0.3 Series name J-320 Circuit No. 3 2 .6 φ3 1 ) 0.1 ± AX (M 5 0. R 4- Connector outline Panel layout Tab housing (Panel mounting type Housing lock type) Circuits Keying Model No. Q’ty/bag 4 X F32MSPL-04V-KX 90 (37.04) 33.95 Keying No. 8.78 12.4 6 9.35 X X Material and Finish RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Not TÜV approved. 5.08 10.5 34.25 ±0.1 33.6 Series name 9.65 ±0.1 12.7 15.24 Circuit No. J-320 4 3 2 22.24 29.24 17 Glass-filled PBT, UL94V-0, black ) AX 1 4- .4 R0 (M Panel layout (Panel thickness:1.6∼2.5 mm) J300 SERIES/J320S Header (Top entry type) Circuits Keying (1.27) X 9.35 X C Keying No. 2 3 5.08 4 Series name 21.6 5 Circuit No. J-320 5 4 3 2 6 X Y X Y X Y X Y X Y Model No. B02B-F32SK-GGXR B02B-F32SK-GGYR B03B-F32SK-GGXR B03B-F32SK-GGYR B04B-F32SK-GGXR B04B-F32SK-GGYR B05B-F32SK-GGXR B05B-F32SK-GGYR B06B-F32SK-GGXR B06B-F32SK-GGYR A Dimensions (mm) B C Q’ty/box 5.08 11.43 19.08 240 5.08 11.43 19.08 240 10.16 16.51 24.16 200 10.16 16.51 24.16 200 15.24 21.59 29.24 160 15.24 21.59 29.24 160 20.32 26.67 34.32 140 20.32 26.67 34.32 140 25.40 31.75 39.40 120 25.40 31.75 39.40 120 1 Material and Finish 3.8 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 5.08 φ1.1 ±0.1 Copper foil land 2-φ3.0(MIN) Through-hole 2-φ2.0 ±0.1 3.175 1.27 ±0.05 (3.175) A RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 5.08 ±0.05 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits Keying 9.35 3.8 7.62 0.82 2 3 10.85 X 3.34 X Keying No. 4 5 Series name 6 22.1 Circuit No. J-320 3 2 X Y X Y X Y X Y X Y S02B-F32SK-GGXR S02B-F32SK-GGYR S03B-F32SK-GGXR S03B-F32SK-GGYR S04B-F32SK-GGXR S04B-F32SK-GGYR S05B-F32SK-GGXR S05B-F32SK-GGYR S06B-F32SK-GGXR S06B-F32SK-GGYR A Dimensions (mm) C B Q’ty/box 5.08 12.70 19.08 180 5.08 12.70 19.08 180 10.16 17.78 24.16 150 10.16 17.78 24.16 150 15.24 22.86 29.24 120 15.24 22.86 29.24 120 20.32 27.94 34.32 105 20.32 27.94 34.32 105 25.40 33.02 39.40 90 25.40 33.02 39.40 90 Material and Finish 1 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated C Connector outline Copper foil land 2-φ4.0 (MIN) 7.62 ±0.05 4 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Through-hole 2-φ3.0 ±0.1 0.82 5 Model No. (3.81) A 5.08 5.08 ±0.05 φ1.1 ±0.1 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 18 J300 SERIES/J320S Header (Side entry type Reverse type) (3.81) Circuits Keying X 9.35 X 3.8 7.62 (0.82) 10.85 3.34 A 5.08 22.1 Type J-320 2 3 4 Connector outline 5 C 7.62±0.05 Copper foil land 2-φ4 (MIN) 0.82 Through-hole 2-φ3 ±0.1 5.08±0.05 3.81±0.05 B ±0.05 PC board layout (viewed from component side) 19 X SR05B-F32SK-GGXR SR06B-F32SK-GGXR Dimensions (mm) C B Q’ty /box 20.32 27.94 34.32 105 25.40 33.02 39.40 90 Material and Finish Series name R 1 X 6 A Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Keying No. Circuit No. 5 Model No. φ1.1±0.1 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. 3. Not TÜV approved. J300 SERIES/J320M Assembly layout When mating with J320S receptacle modular When mating with J320M receptacle (16.2) A B (16.2) (28.4) (28.2) Top entry type A B (34) (33.8) Wire-to-wire B B A A (40.4) (17.7) (17.7) A A Free hanging type / Panel mounting type B B A (16.2) B Side entry type A B (16.2) B Wire-to-board A (40.6) 20 J300 SERIES/J320M Receptacle housing Circuits Keying A Line No. 5.08 YY 14.77 14.17 A B 7.62 XY XX YY 10 XY B XX YY 12 Keying No. XY 16.4 22.8 Series name XX J-3 1 2 F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY F32FMS-10V-KXX F32FMS-10V-KYY F32FMS-10V-KXY F32FMS-12V-KXX F32FMS-12V-KYY F32FMS-12V-KXY F32FMS-20V-KXX XX 6 3 4 XX 20 Dimensions (mm) A B C Model No. Q’ty /bag 10.16 19.24 29.16 100 10.16 19.24 29.16 100 10.16 19.24 29.16 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 45.72 54.80 64.72 84(box) Material and Finish JST 5 Circuit No. Glass-filled PBT, UL94V-0, black C RoHS2 compliance Tab housing (Free hanging type) C Circuits Keying Line No. F32MDF-06V-KXX F32MDF-06V-KYY F32MDF-06V-KXY F32MDF-12V-KXX F32MDF-12V-KYY F32MDF-12V-KXY YY 16.4 16.97 20.32 7.62 X X B X A X XX 6 XY XX 12 YY 5.08 XY Keying No. A Dimensions (mm) A B C Model No. Q’ty /bag 10.16 24.16 28.11 100 10.16 24.16 28.11 100 10.16 24.16 28.11 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 Material and Finish B 4.0 5.0 Glass-filled PBT, UL94V-0, black 33.6 RoHS2 compliance Series name Circuit No. J-320 3 2 1 Tab housing (Panel mounting type) E D Line No. Circuits Keying 16.4 16.97 20.32 7.62 X X X 5.08 A 3.5 2-φ B X XX 6 YY XY XX 12 Keying No. YY XY A 20 B XX Model No. A F32MDP-06V-KXX F32MDP-06V-KYY F32MDP-06V-KXY F32MDP-12V-KXX F32MDP-12V-KYY F32MDP-12V-KXY F32MDP-20V-KXX Dimensions (mm) B C D E Q’ty /bag 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 45.72 59.72 61.00 70.00 78.23 42(box) 4.0 5.0 Material and inish 33.6 Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Series name Circuit No. J-320 3 2 1 D ±0.05 8.95 ±0.3 17.9 ±0.3 C ±0.3 φ3 .6 ±0 .1 4-R Connector outline 21 0.5 Panel layout (M AX ) J300 SERIES/J320M Header (Top entry type) Line No. (1.27) Circuits Keying XX 6 A 7.62 16.97 YY XY B X 7.62 X X X C XX Keying No. 10 YY XY Series name XX 12 J-320 4 3 2 5.08 B06B-F32MK-GGXXR B06B-F32MK-GGYYR B06B-F32MK-GGXYR B10B-F32MK-GGXXR B10B-F32MK-GGYYR B10B-F32MK-GGXYR B12B-F32MK-GGXXR B12B-F32MK-GGYYR B12B-F32MK-GGXYR Dimensions (mm) A B C Q’ty /box 10.16 16.51 24.16 120 10.16 16.51 24.16 120 10.16 16.51 24.16 120 20.32 26.67 34.32 84 20.32 26.67 34.32 84 20.32 26.67 34.32 84 25.40 31.75 39.40 72 25.40 31.75 39.40 72 25.40 31.75 39.40 72 Material and Finish 1 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 3.8 5 XY 21.6 Circuit No. YY Model No. (3.175) A RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. Copper foil land 2-φ3.0(MIN) 7.62 ±0.05 1.27 ±0.05 φ1.1±0.1 Through-hole 2-φ2.0 ±0.1 5.08 ±0.05 Connector outline 3.175 ±0.05 B ±0.05 PC board layout (viewed from component side) Header (Side entry type) Circuits Keying (3.81) A 7.62 5.08 0.82 3.8 5.08 XX 6 YY 18.47 16.97 X 7.62 X X X 8 XY XX B Keying No. A 3.34 XY 10 Line No. YY XY Series name XX 12 YY XY 27.18 Circuit No. J−320 Model No. S06B-F32MK-GGXXR S06B-F32MK-GGYYR S06B-F32MK-GGXYR S08B-F32MK-GGXYR S10B-F32MK-GGXXR S10B-F32MK-GGYYR S10B-F32MK-GGXYR S12B-F32MK-GGXXR S12B-F32MK-GGYYR S12B-F32MK-GGXYR Dimensions (mm) A B C Q’ty /box 10.16 17.78 24.16 80 10.16 17.78 24.16 80 10.16 17.78 24.16 80 15.24 22.86 29.24 64 20.32 27.94 34.32 56 20.32 27.94 34.32 56 20.32 27.94 34.32 56 25.40 33.02 39.40 48 25.40 33.02 39.40 48 25.40 33.02 39.40 48 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 5 4 3 2 1 C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 μm gold-plated product and tin-plated product. 5.08 ±0.05 Through-hole 2-φ3.0 ±0.1 φ1.1 ±0.1 5.08 ±0.05 3.81 ±0.05 B ±0.05 PC board layout (viewed from component side) 22 J300 SERIES/J320M Keying J320M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) XX-Keying X X Line A Y Line B Y Line B Indication of keying Y Indication of keying Y X X Indication of keying Line B Key rib Y Line A Y X Line A Key rib X Key rib YY-Keying XY-Keying List of combinations With the combination of the J320M headers and the J320M/J320S receptacle housings, the following modular combinations are possible. Tab housing Receptacle housing X Single-row 3, 4 circuits (J320S) 20 F32FSS- V-KX X X-Keying J-3 Single-row 3, 4, 5, 6 circuits (J320S) Free hanging type Y-Keying X-Keying Header Single-row X-Keying 3, 4, 5, 6 circuits Free hanging type (J320S) F32MSF- V-KX Panel mounting type J-3 20 F32MSP- V-KX Top entry type B B-F32SK-GGXR Side entry type S B-F32SK-GGXR Y-Keying Y-Keying Top entry type 20 Free hanging type F32MSF- V-KY Panel mounting type Panel mounting type F32MSP- V-KY Y Y J-3 X X XX-Keying X X F32FMS- V-KXX F32MDF- V-KXX Panel mounting type F32MDP- V-KXX 20 J-3 YY-Keying YY-Keying Side entry type Top entry type B B-F32SK-GGYR Side entry type S B-F32SK-GGYR Double-row XX-Keying 6, 8,10,12 circuits Top entry type (J320M) B B-F32MK-GGXXR Side entry type S B-F32MK-GGXXR J-3 20 A YY-Keying Y Y Y F32FMS- V-KYY B A Top entry type J-3 Y B Free hanging type Free hanging type F32MDF- V-KYY Panel mounting type F32MDP- V-KYY 20 Double-row 6,10,12,20 circuits (J320M) Double-row XX-Keying 6,12,20 circuits Free hanging type (J320M) J-3 20 F32FSS- V-KY Top entry type B B-F32MK-GGYYR Side entry type S B-F32MK-GGYYR 20 J-3 XY-Keying X X XY-Keying Note: Number of circuits is indicated in ■■. 23 Y Y F32FMS- V-KXY Free hanging type Panel mounting type F32MDF- V-KXY Panel mounting type F32MDP- V-KXY XY-Keying Side entry type Top entry type B B-F32MK-GGXYR Side entry type S B-F32MK-GGXYR J300 SERIES/J320T Assembly layout When mating with J320S receptacle When mating with J320M receptacle (39.1) C Side entry type B A (25.3) Wire-to-board C B B A (25.3) (39.3) A 24 J300 SERIES/J320T Receptacle housing Circuits Single-row type • 3 circuits Keying Model No. Q’ty/bag X F32FSS-03V-KX F32FSS-03V-KY 200 3 Y 10.16 5.08 200 7.15 6.55 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance 16.4 Keying No. Series name X J-3 22.8 19.24 JST 1 2 3 Circuit No. 29.16 Circuits Double-row type • 6 circuits 6 10.16 5.08 Keying Model No. Q’ty/bag XX F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY 100 YY XY Line No. 100 100 14.77 14.17 A B 7.62 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance 16.4 22.8 19.24 Keying No. Series name XX J-3 1 Circuit No. JST 3 2 29.16 Header (Side entry type) 3.81±0.5 (0.82) 5.08 ±0.05 Circuits Keying Model No. Q’ty/box XXX S09B-F32TK-GGXAR S09B-F32TK-GGXBR S09B-F32TK-GGXCR S09B-F32TK-GGXDR 42 17.78 ±0.5 Circuit No. 5.08 ±0.5 9 φ1.1±0.1 3 2 1 7.62 ±0.05 32.26 J-320 5.08 24.16 B X X X X 25 3.34 7.62 5.08 (3.81) 26.09 X 3.8 X 24.59 Keying No. C 7.62 42 RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. Connector outline 7.62 (0.82) 42 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Series name A 42 Material and Finish Through-hole 2-φ3 ±0.1 Line No. XYX YYX Copper foil land 2-φ4 (MIN) PC board layout (viewed from component side) XXY J300 SERIES/J320T Keying J320T series have mis-insertion preventive keying. Available in 4 types - XXX-Keying, XXY-Keying, XYX-Keying and YYX-Keying. (Headers viewed from the mating side are shown below.) Line A Line A Line A Line A Line B Indication Line B of keying Indication Line B of keying Indication Line B of keying Line C Line C Line C Line C Key rib XXX-Keying Key rib XXY-Keying Indication of keying Key rib Key rib XYX-Keying YYX-Keying List of combinations With the combination of the J320T headers and the J320S/J320M receptacle housings, the following modular combinations are possible. Receptacle housing Single-row 3 circuits (J320S) X-Keying F32FSS-03V-KX Header Triple-row 9 circuits (J320T) XXX-Keying S09B-F32TK-GGXAR Y-Keying XXY-Keying F32FSS-03V-KY S09B-F32TK-GGXBR XX-Keying 20 J-3 Double-row 6 circuits (J320M) F32FMS-06V-KXX XYX-Keying S09B-F32TK -GGXCR YY-Keying F32FMS-06V-KYY B A YYX-Keying XY-Keying S09B-F32TK-GGXDR F32FMS-06V-KXY 26 J300 SERIES/J330 Assembly layout Specifications ––––––––––––––––––– • Current rating: (AC, DC) 21 11 (A) 21 Wire-to-board 11 Dimensions (mm) 1 1 (47.7) * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * RoHS2 compliance. • Voltage rating: 600 V AC, DC • Temperature range: -55˚C to +105˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 5 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 2,200 VAC/minute • Applicable wire: AWG #28 to #14 Receptacle housing (Reverse type Panel mounting type) Circuits Keying 85.2 76 Keying No. (B) 7.7 A 5.4 X 40 C (D) W (18.2) 1 1 2 3 4 5 6 7 8 9 10 X 4.4 Series name 8 7 Circuit No. 6 5 4 3 2 1 1 11 21 E (F) 54.4 (59.4) φ4 ± Dimensions (mm) C D E F Q’ty /box G 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 310 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) 40.6 11 J-330 9 B Material and Finish 21 (66.4) 10 Y Z (48.6) Keying No. Y Z φ3 .5 A F33FRTPA-30V-KX F33FRTPA-30V-SY F33FRTPA-30V-EZ F33FRFPA-40V-KX F33FRFPA-40V-SY F33FRFPA-40V-EZ F33FRFPA-40V-MW X 30 Circuit No. Model No. RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Not UL/TÜV approved. G A ±0.1 Connector outline ±0.3 R1MAX − 0.2 0 67.2 ±0.3 76 ±0.1 Panel layout Tab housing (Reverse type) (69.6) Circuit No. Circuits (64.6) 30 1 2 3 4 5 6 7 8 10 28 38.6 9 JST Circuit No. F33MRTS-30V-KX F33MRTS-30V-SY F33MRTS-30V-EZ F33MRFS-40V-KX F33MRFS-40V-SY F33MRFS-40V-EZ F33MRFS-40V-MW Y X 40 9 X Z X 10 Model No. J -3 Keying No. Keying Series name 8 7 6 5 4 3 2 1 1 11 A 56 21 Y Z W Dimensions (mm) A B Q’ty /box 24.9 15.4 64 24.9 15.4 64 24.9 15.4 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 7.7 (B) Material and Finish 5.4 (48.6) 27 Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) RoHS2 compliance Note: Not UL/TÜV approved. J300 SERIES/J340F Assembly layout D C C B B A (33.7) D Side entry type J-3 Wire-to-board JST (40.4) A Receptacle housing • 12 circuits Circuits Keying Model No. Q’ty/bag 12 — 100 20 — F34FFC-12V-K F34FFC-20V-K Material and Finish Line No. 12.22 100 C J-3 B 5.08 3.81 D RoHS2 compliance 30.1 (32.71) 15.24 JST Glass-filled PBT, UL94V-0, black A 16.4 7.62 22.8 Series name • 20 circuits Line No. C J-3 B 5.08 3.81 D A 16.4 22.8 15.24 30.1 (32.71) 15.24 JST 19.84 Series name Circuit No. Series name 1 φ1.1 ±0.1 2 3.81 Copper foil land φ4 (MIN) 7.62 ±0.05 Circuits Keying Model No. 12 — 20 — SC12B-F34FK-GGR SC20B-F34FK-GGR ±0.05 33.53 (0.82) A±0.5 3 7.62 15.02 63 15.24 22.64 42 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated J-340 Through-hole φ3 ±0.1 Connector outline PC board layout (viewed from component side) Dimensions (mm) Q’ty/box A B B RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. A 3.81 C 3.34 B 30.09 5.08 D 31.59 Line No. A (0.82) 3.81 7.62 3.8 3.81±0.05 Header (Side entry type) 28 J300 SERIES/J350D Assembly layout (21.4) (34.2) A B J-3 J-3 A B A (22.9) B B A (28.6) Wire-to-board (40.6) A J-3 A B B (21.4) Wire-to-wire *When mating with receptacle housing (2-circuit) 29 J300 SERIES/J350D Receptacle housing • 4 circuits • 6 circuits 22.8 5.08 Line No. 16.4 10.16 (19.98) 17.38 B 5.08 Series name Series name 22.8 • 20 circuits • 10 circuits 24.9 16.4 5.08 22.8 45.72 (19.98) B A J-3 Line No. Series name 17.38 5.08 (19.98) B 22.8 A J-3 16.4 17.38 50.3 5.08 5.08 J-3 Line No. 16.4 22.8 20.32 5.08 (19.98) B Series name A Line No. 16.4 17.38 5.08 (20.7) 17.38 14.74 J-3 4.88 A B J-3 5.08 9.96 A • 2 circuits Line No. Series name Circuits Keying Model No. Q’ty/bag 2 — — 6 — 10 — 20 — F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K F35FDC-20V-K 200 4 200 200 100 100 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance 30 J300 SERIES/J350D Tab housing (Free hanging type) Circuit No. 32.48 Circuits Keying Model No. Q’ty/box 12 — F35MDF-12V-K 50 Material and Finish 6 5 4 3 2 1 J-350 Glass-filled PBT, UL94V-0, black 4 33.6 Series name 5 RoHS2 compliance Note: Not TÜV approved. 32.48 25.4 Circuit No. 3 4 5 6 B A 18.17 2 13.78 1 Line No. 21.52 18.17 5.08 5.08 36.43 Tab housing (Panel mounting type) 2-φ3.6 ±0.1 43 Circuit No. ±0.05 ±0.3 Series name 9.6 33.4 ±0.3 5 4 3 2 1 19.2 4 33.6 J-350 5 32.48 4-R0.5 (MAX) Panel layout 25.4 5.08 3 4 43 52 31 5 6 B A Line No. 18.17 2 13.78 1 2-φ3.5 21.52 18.17 5.08 Circuit No. Keying Model No. Q’ty/box 12 — F35MDP-12V-K 41 Material and Finish ±0.3 6 Connector outline Circuits Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Not TÜV approved. J300 SERIES/J350D Header (Top entry type) Q ty/box φ ± 6 5 4 3 2 1 21.6 7 8 7 8 9 10 RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. J-350 (4.78) A ±0.05 9 5.08 ±0.05 10 5.08 ±0.05 3.81 ±0.05 φ φ1.1 ±0.1 (3.54) B A 3.8 B 18.17 5.08 3.81 5.08 2 3 4 5 6 A 5.08 1 3.8 Header (Side entry type) Circuit No. Circuits Series name 10 9 8 7 27.18 Keying Model No. 4 — 12 — 20 — SC04B-F35DK-GGR SC12B-F35DK-GGR SC20B-F35DK-GGR Dimensions (mm) A B Q’ty/box 5.08 12.16 152 25.40 32.48 56 45.72 52.80 32 6 5 4 3 2 1 J-350 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated B A A 4 5 6 7 8 B 7.62 5.08 1 3.8 (0.82) 10 3.34 A 9 12, 20 circuits (3.54) A ±0.05 (3.54) Copper foil land 2-φ4 (MIN) 7.62 ±0.05 Through-hole 2-φ3 ±0.1 2.54 ±0.05 Copper foil land φ4 (MIN) (0.82) φ1.1 ±0.1 Through-hole φ3 ±0.1 Connector outline Connector outline PC board layout (viewed from component side) 12, 20 circuits RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. 4 circuits 5.08 ±0.05 (0.82) 5.08 ±0.05 A±0.05 2 3.34 3 3.8 2 18.17 19.67 1 5.08 5.08 5.08 18.17 19.67 Line No. PC board layout (viewed from component side) 4 circuits 32 J300 SERIES/KEYING BLOCK Keying block 10.4 3.7 22.4 RoHS2 compliance Note: Not UL/TÜV approved. 8.6 4.7 21.3 Features Mis-mating prevention keying block can be freely mounted to keying block space. • 16 types of keying can be provided by mounting 4 types of keying block to 2 keying block spaces. • Since a color varies on each type of keying, the kind of keying is easy to recognize. How to use keying block (When using J380D) Side entry type Header Keying block (for header housing) Space for keying block Space for keying block Keying block (for receptacle housing) Receptacle housing Keying block 33 J300 SERIES/J380D (for keying block) Assembly layout (14) B A (34.6) Wire-to-board (28.6) B (14.4) B A A B A Receptacle housing Circuits Keying C B 11.3 A 5.08 20 — 40 — F38FDS-20V-KE F38FDS-40V-KE Dimensions (mm) A C B Q’ty /bag 68.3 58.9 45.72 100 106.4 97.0 83.82 60 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance This product displays (LF)(AU) on a label. Note: Not UL/TÜV approved. 16.4 Series name J-3 22.8 B JST 1 Circuit No. 13.45 Line No. 3.81 Model No. 2 3 4 5 6 7 11 12 13 17 18 19 20 21 22 23 (A) 34 J300 SERIES/J380D (for keying block) Header (Top entry type) 92 Circuits Keying Model No. Q’ty/box 40 — B40B-F38DK-GGER — 83.82 3.8 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 23 22 21 20 19 18 17 7 6 5 4 3 2 1 13 12 11 21.6 3.8 Series name 3.81 J-380 Circuit No. 99.6 Line No. 83.82 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. Not UL/TÜV approved. (2.54) 5.08 92 ±0.05 (3.8) ±0.05 4.09 83.82 ±0.05 22.86 (4.55) 5.08 ±0.05 5.08 A B 13.6 3.81 ±0.05 ±0.05 15.24 15.24 ±0.05 ±0.05 ±0.1 φ1.1 22.86 ±0.05 2-φ2 2.54 ±0.05 3.81 ±0.1 Connector outline PC board layout (viewed from component side) Header (Side entry type) Circuits Keying Circuit No. 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 27.54 — S20B-F38DK-GGER S40B-F38DK-GGER Q’ty /box 61.5 55.8 45.72 3.81 — 99.6 93.9 83.82 22.86 — J-380 Material and Finish RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. Not UL/TÜV approved. 14 5.08 3.81 B (0.82) 3.81 3.4 9.9 3.34 A C B 3.81 (2.85) B ±0.05 C ±0.05 (0.82) ±0.05 D ±0.05 15.24 5.04 ±0.05 ±0.05 15.24 D ±0.05 φ1.1±0.1 ±0.05 3.81 2-φ3 ±0.1 9.9 ±0.05 3.81 — 40 Dimensions (mm) B D C C Line No. ±0.05 20 A Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated A Connector outline PC board layout (viewed from component side) 35 Model No. Series name J300 SERIES COMMON TYPE/J350D Double-row Common type (J350D) Unit: A Current rating ( AC, DC) Circuit figure Wire size (AWG) #16 #18 #20 Contact for common connection Tab side Contact for common connection Tab side 1 J-3 50 2 3 4 5 6 12 - 13.0 11.5 9.5 7.5 12 - 13.0 11.5 9.5 7.5 4 11.25 11.25 11.25 10.0 8.0 12 8.25 8.25 8.25 7.75 6.0 20 8.0 8.0 8.0 7.25 6.0 12 - 8.25 8.25 7.75 6.0 Contact for common connection Tab side Contact for common connection Tab side 1 J-3 50 2 3 4 5 6 Contact for common connection Receptacle side Remark Total input current on single-row #14 Total input current on all circuits Circuit Note 1 Contact for common connection Receptacle side Header 6 5 J-3 - 50 4 3 2 1 Tab contact Tab contact 0 6 5 4 3 2 1 Tab housing Contact for common connection Receptacle side 35 Normal Receptacle hosuing Appearance J- Receptacle hosuing assembly with common connection Tab side J-3 Receptacle side JS JS • Rationalization of wiring is realized by the common connection inside the connector T2 T2 - Note: Use only receptacle housing assembly with common cnnection. Specifications ––––––––––––––––––– Assembly layout A J-3 A B B (37) *When mating with receptacle housing (2-circuit) (21.4) Direct mounting type • Current rating: Refer to the above table. • Voltage rating: 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 2,200 VAC/minute • Applicable wire: AWG #28 to #14 * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * Compliant with RoHS2. 36 J300 SERIES COMMON TYPE/J350D Receptacle housing • 4 circuits • 6 circuits B J-3 (19.98) 5.08 (19.98) A J-3 B 17.38 5.08 (20.7) 17.38 A B J-3 5.08 4.88 17.38 14.74 9.96 A • 2 circuits Line No. 16.4 Line No. 16.4 5.08 Series name 22.8 Series name 22.8 • 10 circuits 5.08 22.8 Line No. Series name Keying Model No. Q’ty/bag 2 — — 6 — 10 — F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K 200 4 200 200 100 Material and Finish Glass-filled PBT, UL94V-0, black 16.4 Line No. 22.8 20.32 16.4 10.16 Circuits (19.98) 17.38 A J-3 B 5.08 24.9 5.08 RoHS2 compliance Series name Receptacle housing assembly with common connection 4.9 Circuits Keying Model No. Q’ty/box — — F35FDC-00(2-A1D)V-EC 700 Material and Finish (20.7) 17.4 A B J- 3 5.08 Contact for common connection: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, blue RoHS2 compliance Note: 1. Contact JST about 0.76 μm gold-plated product and tin-plated product. 2. Not UL/TÜV approved. Line No. 22.8 Series name Cross-section of receptacle housing assembly with common connection Illustration when using Circuit figure when using Contact for common connection Tab side 1 J-3 2 3 50 4 5 6 B A Inserted the contact for common connection to the inside of receptacle housing 37 *When using receptacle housing assembly with common connection Contact for common connection Receptacle side J300 SERIES COMMON TYPE/J350D Tab housing Assembly Keying Model No. Q’ty/box 12 — P12B-F35DK-GFAR 196 30 4 Circuits J-350 Series name Material and Finish 1 Circuit No. 2 3 4 5 6 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 33.08 57 44.6 Circuit No. Line No. 2 3 4 5 6 18.17 21.6 1 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76 μm gold-plated product and tin-plated product. 5. Refer to the top page of J350D (Common type) for circuit figure. B 5.08 A 5.08 25.4 ±0.05 (6.2) 44.6 ±0.1 (10.8) 2 -φ4.6 Connector outline Panel layout Tab housing (Free hanging type) Circuit No. 32.48 Circuits Keying Model No. Q’ty/box 12 — F35MDF-12V-K 50 6 5 4 3 2 1 J-350 Material and finish 33.6 Series name 4 Glass-filled PBT, UL94V-0, black 5 RoHS2 compliance Note: Not TÜV approved. 32.48 25.4 Circuit No. 3 4 5 6 B A 18.17 2 13.78 1 Line No. 21.52 18.17 5.08 5.08 36.43 Tab housing (Panel mounting type) 2-φ3.6 ±0.1 43 ±0.05 ±0.3 Series name Circuit No. 9.6 33.4 ±0.3 ±0.3 6 5 4 3 2 1 19.2 5 32.48 4-R0.5 (MAX) Panel layout 25.4 5.08 3 4 43 Q’ty/box 12 — F35MDP-12V-K 41 Material and Finish Glass-filled PBT, UL94V-0, black 5 6 B A 18.17 2 13.78 1 Model No. 2-φ3.5 21.52 18.17 5.08 Circuit No. Keying RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Not TÜV approved. 4 33.6 J-350 Connector outline Circuits Line No. 52 38 J300 SERIES COMMON TYPE/J350D Header (Top entry type) Q ty/box φ ± 5 4 3 2 1 21.6 6 7 8 9 10 RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. J-350 (4.78) 5.08 ±0.05 7 8 A ±0.05 9 5.08 ±0.05 10 φ1.1 3.81 ±0.05 φ ±0.1 (3.54) B A 3.8 B 18.17 5.08 3.81 5.08 2 3 4 5 6 A 5.08 1 3.8 Header (Side entry type) Circuit No. Circuits Series name 10 9 8 7 27.18 Keying Model No. 4 — 12 — 20 — SC04B-F35DK-GGR SC12B-F35DK-GGR SC20B-F35DK-GGR Dimensions (mm) A B Q’ty/box 5.08 12.16 152 25.40 32.48 56 45.72 52.80 32 6 5 4 3 2 1 J-350 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated B A A 4 5 6 7 8 B 7.62 5.08 1 3.8 (0.82) 10 3.34 A 9 12, 20 circuits (3.54) A ±0.05 (3.54) 7.62 ±0.05 Through-hole 2-φ3 ±0.1 2.54 ±0.05 Copper foil land φ4 (MIN) (0.82) φ1.1 ±0.1 Copper foil land 2-φ4 (MIN) Through-hole φ3 ±0.1 Connector outline Connector outline PC board layout (viewed from component side) 12, 20 circuits 39 4 circuits 5.08 ±0.05 (0.82) 5.08 ±0.05 A±0.05 2 3.34 3 3.8 2 18.17 19.67 1 5.08 5.08 5.08 18.17 19.67 Line No. PC board layout (viewed from component side) 4 circuits RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 μm gold-plated product and tin-plated product. J300 SERIES COMMON TYPE/J360T Triple-row Common type (J360T) • Rationalization of wiring is realized by the common connection inside the connector Specifications ––––––––––––––––––– • Current rating: (AC, DC) Unit: A Wire size (AWG) #14 #16 #18 #20 Receptacle housing (Total input current on single-row) 12.0 10.5 8.5 6.5 Receptacle housing assembly with common connection (Total input current on all circuits) 15.0 13.5 11.5 9.5 • Voltage rating: 600 V AC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. (When using receptacle housing) • Withstanding voltage: 2,200 VAC/minute (When using receptacle housing) • Applicable wire: AWG #28 to #14 * In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * Contact JST for details. * Compliant with RoHS2. 40 J300 SERIES COMMON TYPE/J360T Assembly layout Panel mounting type Direct mounting type C (28.6) A A A B J-3 C B B B J-3 C C (28.6) (36.8) A (36.8) *When mating with receptacle housing (3-circuit) Receptacle housing 16.4 22.8 25.3 (28) RoHS2 compliance Note: 9, 18, and 24-circuit products are not approved by UL/TÜV standards. A J-3 6.5 B C A Line No. Series name Receptacle housing assembly with common connection 41.2 5.08 35.56 1 2 3 4 5 6 7 41 16.4 22.8 25.3 (28) A J -3 6.5 B 6.5 C RoHS2 compliance Note: 1. Contact JST about 0.76 μm gold-plated product. 2. Not UL/TÜV approved. Line No. Series name J300 SERIES COMMON TYPE/J360T Common tab housing Assembly Circuits Keying • Panel mounting type Circuit No. B ±0.05 E ±0.3 2-φ3.6 ±0.1 9 — 18 — Model No. A P09B-F36TK-GFR P18B-F36TK-GFR Dimensions (mm) B C D E Q’ty /box 35.0 26.1 17.8 10.16 18.8 364 50.2 41.3 33.1 25.40 34.1 224 Series name 2 13.55 ±0.3 3 1 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 5 4 30 J-360 27.1±0.3 Material and Finish Connector outline 4-R0.5 (MAX) C Panel layout A B Circuit No. Line No. 2 2-φ3.5 3 6.5 B 26.09 C 29.44 1 26.09 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76 μm gold-plated product and tin-plated product. 5. Refer to the top page of J360T (Common type) for circuit figure. A 5.08 D Circuits Keying 2-φ3.6 ±0.1 30 J-360 3 2 1 C A B 1 2 3 9 — 18 — 24 — P09B-F36TK-GFAR P18B-F36TK-GFAR P24B-F36TK-GFAR A Dimensions (mm) B C D Q’ty /box 35.0 26.1 17.8 10.16 364 50.2 41.3 33.1 25.40 224 60.4 51.5 43.2 35.56 168 Material and Finish 4 14.72 ±0.3 B ±0.05 Model No. 2-φ3.5 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76 μm gold-plated product and tin-plated product. 5. The directions such as series names of 24-circuit product are different from 9 and 18-circuit products. 6. 24-circuit product is not approved by UL standard. 7. Refer to the top page of J360T (Common type) for circuit figure. 6.5 26.09 B 29.44 C A 5.08 D 42 JFA CONNECTOR/J300 SERIES Model number identification Receptacle contact Tab contact Form: S...Strip form, B...Loose piece L...Loose piece with curled barrels Form: S...Strip form, B...Loose piece, L...Loose piece with curled barrels Series name Series name Kind of terminal: M...Tab contact Kind of terminal: F...Receptacle contact Applicable wire: 002...AWG #28 41...AWG #20 #24, 01...AWG #24 #16, 71...AWG #16 #20, #14 Surface finish: GF...Nickel-undercoated, 0.38 m selective gold-plated GI...Nickel-undercoated, 0.76 m selective gold-plated T...Tin-plated (reflow treatment) Applicable wire: 002...AWG #28 41...AWG #20 Material: M...Copper alloy Terminal size Terminal size Sub model No. Series name Type of connector: F...Receptacle housing, FR...Receptacle housing Reverse type Rows: S...Single-row, D....Double-row with 5.08 mm line pitch M...Double-row with 7.62 mm line pitch T...Triple-row, F....Quadruple-row Mounting arrangement: S...Side locking, C...Center locking, PA...Panel mounting type No. of circuits: 1 6, 8 10, 12, 16, 18, 20, 24, 30, 40 Flammability: V...UL94V-0 Color indication: K...Black, S...White, E...Blue, M...Green Keying: X...X-Keying, Y...Y-Keying, Z...Z-Keying, W...W-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, Blank...Without Keying No. E...Space (2 spaces) for Keying block Header PC board mounting direction: B...Top entry type S...Side entry type BC...Top & center locking SR...Side reverse SC...Side & center locking No. of circuits: 2 6, 8 10, 12, 16, 20, 40 Product name: Header Series name Rows: S...Single-row D...Double-row with 5.08 mm line pitch M...Double-row with 7.62 mm line pitch T...Triple-row F...Quadruple-row Color indication: K...Black, S...White, E...Blue Surface finish: GG...Nickel-undercoated, 0.38 m selective gold-plated GK...Nickel-undercoated, 0.76 m selective gold-plated T...Tin-plated (reflow treatment) Keying: X...X-Keying, Y...Y-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, E...Space (2 spaces) for Keying block, XA...XXX-Keying, XB...XXY-Keying, XC...XYX-Keying, XD...YYX-Keying, Blank...Without Keying No. Packaging form: R...Tray, M...Magazine stick 43 #20 #14 Surface finish: GF...Nickel-undercoated, 0.38 m selective gold-plated GI...Nickel-undercoated, 0.76 m selective gold-plated T...Tin-plated (reflow treatment) Material: P...Copper alloy Receptacle housing #24, 01...AWG #24 #16, 71...AWG #16 Tab housing JFA CONNECTOR/J300 SERIES Model number identification Receptacle housing assembly Common tab housing assembly Series name Type of connector: F...Receptacle housing Rows: D...Double-row, T...Triple-row Mounting arrangement: C...Center locking PC board mounting direction: Panel mounting type The number of receptacle contact that can be mounted to the housing.: 00, 21 No. of circuits Assembly: 9, 12, 18, 24 Indication of Common: 2-A1D...Common circuit is set to No. 1 circuit at each row of A and B. 24-C8T...Common circuit is set to No. 8 circuit at each row of A, B and C. Flammability: V...UL94V-0 Color indication: K...Black, E...Blue, M...Green Surface finish of assembled short circuit terminal : C...Nickel-undercoated, 0.38 : D...Nickel-undercoated, 0.76 m selective gold-plated m selective gold-plated Series name: F35D...J350D, F36T...J360T Color indication: K...Black, M...Green Surface finish: GF...Nickel-undercoated, 0.38 G I ...Nickel-undercoated, 0.76 m selective gold-plated m selective gold-plated Mounting arrangement: A...Direct mounting type, AN...Direct mounting without housing cover type Blank...Panel mounting type Packaging form: R...Tray Keying block Series name: Panel mounting type Product name: Keying block Type of connector: F...For receptacle housing M...For header housing Flammability: V...UL94V-0 Color/Keying indeicaation: R-X...Red/X-Keying, Y-Y...Yellow/Y-Keying, E-Z...Blue/Z-Keying, S-W...Natural (White)/W-Keying 44 JFA CONNECTOR J300 SERIES PROTECTOR 0 B A J-31 J-31 10 9 0 8 7 6 5 4 3 2 1 When applying a current to the connector, the protector prevents foreign substances being inserted into mating part from the wiring side. However it has no function of holding the wire securely. B A Note: Protector is not approved by UL/TÜV standards. J300 Series J310D series for 20 circuits (50.3) 16.08 Model No. Color Q’ty/box 1 F31PFD-20VK F31PFD-20SC Black 112 Transparent 112 1 Material and Finish Black: Glass-filled PBT Transparent: Polycarbonate RoHS2 compliance Note: Two protectors of the same color are used. (42.9) 26.2 1 No. F31FDS-20V-K (11.63) (43.37) (53.29) J310D series / Embedding-type prottector for 8, 10 circuits (53.29) 1 (12.23) No. Model No. Color Q’ty/box 1 F31PFS-10KU Black 1,000 Material and Finish 1 0.8 Glass-filled, PBT (22.8) RoHS2 compliance Note: This protector is cut and used for each number of the circuits. (43.37) (11.63) No. J340F series for 20 circuits 23.04 1 (32.3) 1 2 2 Model No. Color Q ty/box F34PFF-20VKA F34PFF-20SCA F34PFF-20VKB F34PFF-20SCB Black 80 Transparent 80 Black 80 Transparent 80 21.2 Material and Finish (37.9) Black: Glass-filled PBT Transparent: Polycarbonate RoHS2 compliance Note: Both 1 and 2 protectors in the same color are used. F34FFC-20V-K (19.84) 1 25.77
F31MDP-08V-K 价格&库存
很抱歉,暂时无法提供与“F31MDP-08V-K”相匹配的价格&库存,您可以联系我们找货
F31MDP-08V-K
  • 100+15.16645100+1.96124
F31MDP-08V-K
    • 1+14.04000
    • 10+11.92320
    • 30+10.59480
    库存:63
    F31MDP-08V-K
      • 1+25.411351+3.28604
      • 10+17.5817210+2.27356
      • 50+13.9290650+1.80122
      • 100+13.19503100+1.70630
      • 500+12.65325500+1.63624
      • 1000+12.286231000+1.58878
      • 2000+12.207592000+1.57861
      库存:6
      F31MDP-08V-K
        • 100+11.83600
        库存:3102
