CT7002M
CT7002M
    CORETONG(芯通)
    SOT23-3
    MOSFETs VDS=60V ID=500mA PD=700mW SOT23-3
CT7002M 数据手册
CT7002M N-CHANNEL ENHANCEMENT MODE POWER MOSFET »Features ■Small Package Outline ■Simple Drive Requirement BVDSS 60V ■ Surface Mount Device ■ RoHS Compliant & Halogen-Free RDS(ON) ID 1.5Ω 0.5A »Description CT7002M is from Coretong innovated design and silicon process technology to achieve the lowest possible on- resistance and fast switching performance. It provides the designer with an extreme efficient device for use in a wide range of »Schematic & PIN Configuration SOT-23 »Absolute Maximum Ratings@Tj=25oC(unless otherwise specified) Symbol VDS VGS ID-Continuous IDM PD@TA=25℃ TSTG TJ Parameter Drain-Source Voltage Gate-Source Voltage Drain Current, VGS @ 10V Pulsed Drain Current1 Total Power Dissipation3 Storage Temperature Range Operating Junction Temperature Range »Thermal Data Symbol Rthj-a Revision 2020 Parameter Maximum Thermal Resistance, Junction-ambient3 www.coretong.com Rating 60 ±20 115 800 0.7 -55 to 150 150 Units V V mA mA W Value 150 Unit ℃/W ℃ ℃ 1/5 CT7002M N-CHANNEL ENHANCEMENT MODE POWER MOSFET »Electrical Characteristics@Tj=25 oC(unless otherwise specified) Symbol Parameter BVDSS Drain-Source Breakdown Voltage RDS(ON) Static Drain-Source On-Resistance2 Test Conditions Min. Typ. Max. Units 60 70 - V VGS=10V, ID=300mA - 1.5 3 Ω VGS=4.5V, ID=200mA - 2 4 Ω VGS=0V, ID=10uA VGS(th) Gate Threshold Voltage VDS =VGS, ID=250uA 1.35 1.6 1.85 V gfs Forward Transconductance VGS=10V, ID=200mA 80 - - mS IDSS Drain-Source Leakage Current VDS =48V, VGS=0V - - 1 uA IGSS Gate-Source Leakage VGS=±20V, VDS =0V - - ±10 uA td(on) Turn-on Delay Time - 10 ns Turn-off Delay Time VDS=25V,ID=500mA RG=25Ω,VGS =10V - td(off) - - 15 ns Ciss Input Capacitance - - 40 pF Coss Output Capacitance - - 30 pF Crss Reverse Transfer Capacitance VGS=0V VDS =25V f=1.0MHz - - 10 pF ESD Electro-Static Discharge HBM - - 2000 V Min. Typ. Max. Units - - 1.2 V »Source-Drain Diode Symbol Parameter VSD Forward On Voltage² Test Conditions IS=115mA, VGS =0V Notes: 1.Pulse width limited by Max. junction temperature. 2.Pulse test Revision 2020 www.coretong.com 2/5 CT7002M N-CHANNEL ENHANCEMENT MODE POWER MOSFET »Typical Performance Characteristics Revision 2020 www.coretong.com 3/5 CT7002M N-CHANNEL ENHANCEMENT MODE POWER MOSFET »Marking Information Package A1 Y WW S SOT-23 PN code Yesr Weeks Assembly Description 0-9,A-Z , F=2020, G=2021……… Ex. 10/27=44weeks, 11/3=45weeks Ass. Code »Package Outline : SOT-23 Revision 2020 www.coretong.com 4/5 CT7002M N-CHANNEL ENHANCEMENT MODE POWER MOSFET »SOT-23 FOOTPRINT:(mm) »Ordering information Order code CT7002M Revision 2020 Package SOT-23 www.coretong.com Base qty 3k Delivery mode Tape and reel 5/5
CT7002M 价格&库存
很抱歉,暂时无法提供与“CT7002M”相匹配的价格&库存,您可以联系我们找货
CT7002M
  • 5+0.03564
  • 20+0.03499
  • 100+0.03368
库存:2800
