东莞市广督实业有限公司
DONGGUAN KIINGTEK LNDUSTRIAL CO.,LTD.
Page
1/9
MODEL
TS66H
SPECIFICATION
1、 概述
GENERAL
1.1 适用范围
APPLICATION
此规格书适用于机械式轻触开关的相关要求
This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT)
1.2 工作温度范围
Operating Temperature Range
-20℃~80℃(在标准大气压、标准湿度条件下)
-20℃~80℃(Normal humidity, normal air pressure)
1.3 贮藏温度范围
Storage Temperature Range
1.4
测试条件
Test Conditions
在没有其它特定的条件下,应该在以下的条件下进行测试和测量:
Unless otherwise specified, tests and measurement shall be made in
the following standard conditions:
常温…………………………………5℃~35℃
Normal temperature………………5℃~35℃
标准湿度……………………………相对湿度25%~85%
Normal humidity…………………relative humidity 25%~85%
标准大气压…………………………86KPa~106Kpa
Normal air pressure…………………86Kpa~106Kpa
在制造过程中,测试和测量应该在以下的条件下进行:
If any doubt arise from the judgment, tests shall be conducted
at the following conditions:
温度…………………………………20℃±2℃
Temperature………………………20℃±2℃
相对湿度……………………………65%±5%
Relative humidity………………65%±5%
环境气压…………………………86KPa~106Kpa
Air pressure…………………………86KPa~106Kpa
东莞市广督实业有限公司
Page
2/9
MODEL
TS66H
SPECIFICATION
2、 详细说明
Detailed specification
2.1 外观:应无影响、降低产品性能的缺陷;
Appearance: There should be no defects that affect the serviceability of product.
2.2 结构尺寸和安装尺寸:应符合装配图要求
Style and dimension: shall conform to the assemble drawings.
2.3
操作形式:有触觉反应的操作
Type of actuating: Tactile feedback.
2.4
开关结构:单回路单输出(具体的触点结构在装配图中已绘出);
Contact arrangement: 1 pole, 1 throw
(Details of contact arrangement are given in the assembly drawings.)
2.5
开关工作额定值:DC 12V,50mA(有效值)
DC 12V,50mA (最大额定值)
DC 1V,10μA (最小额定值)
Ratings: 12V DC, 50mA (effective value)
12V DC, 50mA (maximum)
1V DC,10μA (minimum)
3、 电气性能:
ELECTRICAL SPECIFICATION
NO.
3.1
3.2
项目
ITEM
试验条件
TEST CONDITIONS
要求
REQUIREMENTS
接触电阻
Contact
Resistance
在以 5V 10mA的直流电源或不低于1KHz的交流电源的
电路中,以一个等于2倍按力的静负荷施加于手柄中心
Applying a static load of 2 times operating
force to the center of the stem, measurements
shall be made by 5V DC 10mA or more than 1KHZ
AC small-current contact resistance meter.
≤100mΩ
绝缘电阻
Insulation
Resistance
在端子之间施加DC 100V /1min的条件下,测量端子之间
底座、盖板的电阻值
Measurement shall be made following application
of 100V DC potential, across terminals, and
across terminals and cover, for one minute.
≥100MΩ
在端子之间施加250V AC(50HZ或60HZ)/1min
250V AC (50HZ or 60HZ) shall be applied across
terminals, for one minute.
3.3
介质耐压
Dielectric
voltage proof
无击穿、无飞弧
There should be no
breakdown and flashover
东莞市广督实业有限公司
Page
3/9
MODEL
TS66H
SPECIFICATION
在正常使用中(以每秒3-4次周期)轻轻地在手柄中心加
力,在通与断瞬间测试抖动
Lightly striking the
center of the stem at a rate encountered in
normal use (3 to 4 operations per sec),
Bounce shall be tested when “ON” and “OFF”.
Switch
抖动
Bounce
3.4
DC3-5V
Oscillograph
示波器
5kΩ
t
≤10mS
t
t
为触点抖动时间
4、 机械性能:
MECHANICAL SPECIFICATION
NO.
4.1
4.2
4.3
项目
ITEM
试验条件
TEST CONDITIONS
开关的动作方向为垂直放置开关向推柄中心逐渐地增加
负荷直到推柄停止时所测量的最大负荷。
Placing the switch such that the direction of
switch operation is vertical and then gradually
按力
increasing the load applied to the center of
Operating Force
the stem, the maximum load required for the
switch to come to a stop shall be measured.
最大行程
Full Travel
回弹力
Return Force
开关垂直于操作方向放置,以一个等于2倍按力的静负
荷施加在开关驱动件顶端中心,测量顶端移动的距离。
switch operation is vertical and then applying
static load of 2times operating force to the
center of the stem; the travel distance for the
开关垂直于操作方向放置,在开关驱动件顶端中心下降
至全行程后,测量顶端向自由位置转换的力度。
The sample switch is installed such that the
direction of switch operation is vertical and
upon depressing the stem in its center to the
whole travel distance, the force of the stem to
return to its free position shall be measured.
要求
REQUIREMENTS
按力:250±40gf
Operating
Force:250±40gf
0.25±0.1m
回弹力
Return Force:(80~
115)gf min
东莞市广督实业有限公司
Page
4/9
MODEL
TS66H
SPECIFICATION
4.4
4.5
4.6
5、
开关垂直于操作方向放置,从操作方向向驱动件施加
无机械和电气损坏
10N的静负荷持续1min。
There shall be no sign
停止强度
of damage mechanically
Stop Strength
switch operation is vertical, and then a static
and electrically.
load of 10N shall be applied in the direction
of stem operation for a period of 1 min.
手柄拔出强度
Stem
Strength
开关垂直于操作方向放置,反方向实施最大操作力,并
测量手柄的行程范围。
switch operation is vertical, and then the
maximum force to withstand a pull applied
opposite to the direction of stem operation
shall be measured.
在以下设定条件下进行测量:
Measurements shall be made following the test
set forth below:
(1) 焊接温度:245±5℃
Solder temperature : 245±5℃
可焊性
(2) 浸入时间:2s±0.5s
Solderability
Immersion time: 2s±0.5s
对于其它步骤参考《GB 5095.6—86》试验12a
The other steps please refer to《GB 5095.6-86》
TEST 12a
20N.min.
除边缘外涂层应均匀覆盖
90%以上
Except for the edge,
the coating should
cover a minimum 90%
极限电气性能:
ENVIRONMENTAL SPECIFICATION
NO.
5.1
5.2
项目
ITEM
试验条件
TEST CONDITIONS
要求
REQUIREMENTS
样品应按照以下实验条件进行测试,实验后样品应放在
常温及标准湿度的环境中1小时后做性能测试:
Following the test set forth below the sample
低温测试
shall be left in normal temperature and
Resistance to humidity conditions for 1 h before measurements
low temperature are made:
(1) 温度:-30±2℃
Temperature : -30±2℃
(2) 时间:96h
接触电阻:≤500mΩ
Time: 96h
Contact resistance: ≤
500mΩ
项目3,4
Item 3,4
高温测试
Heat resistance
are made:
(1) 温度:80±2℃
temperature:80±2℃
(2) 时间:96h
time: 96h
东莞市广督实业有限公司
Page
5/9
MODEL
TS66H
SPECIFICATION
5.3
根据下面的测试要求进行5次循环的温度周期性测试,
实验后样品应放在常温及标准湿度的环境中1小时后做
性能测试。测试期间样品应保持干燥.
After 5 cycles of following conditions, the
sample shall be allowed to stand under normal
temperature and humidity conditions for 1 h.
and measurements shall be made. During the test
温度周期性测试
water drops shall be removed.
Change of
+65±2℃
temperature
-10±2℃
2(hour)
1(hour)
2(hour)
1(hour)
1 cycle
5.4
5.5
5.6
湿温测试
Moisture
resistance
接触电阻:≤500mΩ
500mΩ
项目3,4
are made:
Item 3,4
(1) 温度:60±2℃
temperature: 60±2℃
(2) 相对湿度:90%~95%
relative humidity:90% to 95%
(3) 时间:96h
time: 96h
硫化试验
Sulfuration
resistance
are made:
(1) H2S气体浓度:3ppm±1ppm
H2S gas concentration: 3ppm±1ppm
(2) 时间:72h
Time: 72h
(3) 温度:40±2℃(90~95%RH)
temperature: 40±2℃(90~95%RH)
盐雾试验
Salt Mist
在以下设定条件下进行测量:
The switch shall be checked after following
test:
(1)温度:35℃±2℃
temperature: 35℃±2℃
(2)盐溶液浓度:5±1%(质量百分比)
salt solution : 5±1%(solids by
mass)
(3)时间:4h±1h
Time: 4h±1 hour
实验后的盐沉积物后水冲掉
After test, salt deposit shall be removed by
running water.
金属件上没有腐蚀斑点
No remarkable corrosion
shall be recognized in
metal part.
东莞市广督实业有限公司
Page
6/9
MODEL
TS66H
SPECIFICATION
6、
极限机械性能:
ENDURANCE SPECIFICATION
项目
ITEM
NO.
6.1
6.2
6.4
7、
试验条件
TEST CONDITIONS
根据下面的测试要求进行测试:
Measurement shall be made following the test
set forth below:
(1) DC 12V,50mA带负载
DC 12V, 50 mA resistive load
工作寿命
(2)
按动速率:2次/秒
Operation life
Rate of operation: 2 times/s
(3) 按力:300g
Operating Force:300g
(4) 平均无故障寿命/Average fault-free
life:30000次
耐振动
Vibration
Resistance
抗冲击
Impact Shock
Resistance
set forth below: 按下列条件进行抗振动试验
(1)Range of oscillation:10 to 55Hz 频率范围
(2)Amplitude,pk-to-pk:1.5 mm 振幅: 峰-峰1.5mm
(3)Cycle of sweep: 10-55-10Hz in one minute,
approx.扫描周期: 10-55-10Hz约一分钟内
(4)Mode of sweep: Logarithmically sweep or
uniform sweep. 扫描方式:对数扫描式恒定扫描
(5)Direction of oscillation: 振动方向
Three mutually perpendicular directions,
including the direction of stem travel. 3个相互
垂直方向,包括推柄行程方向
(6)2 hours each ,for a total of 6hours.每方向2
小时.共6小时
set forth below: 按下列条件进行冲击试验
(1)Acceleration:80g 加速度
(2)Cycles of test :3 cycles each in
6directions, for a total of 18cycles 试验次数:
每个方向3次,6个方向共18次
要求
REQUIREMENTS
接触电阻≤500mΩContact
resistance≤500mΩ
触点弹力≤10ms
Contact bounce≤10ms
按力:初值的±30%
Operating Force:
initial value±30%
项目 3
项目 4.1、4.2
Item 3
Item 4.1、4.2
项目 3
项目 4.1、4.2
Item 3
Item4.1、4.2
焊接条件:
SOLDERING CONDITIONS:
NO.
7.1
项目
ITEM
试验条件
TEST CONDITIONS
请按以下条件进行焊接:
(1) 焊锡温度:≤350℃
(2) 连续焊接时间:≤3 s vhvmmn
手工焊接
(3) 电铬铁的功率:≤20W
Hand soldering Please practice according to below conditions:
(1) Soldering temperature: 350℃ Max.
(2) Continuous soldering time: 3 s Max.
(3) Capacity of soldering iron:≤20 W
要求
REQUIREMENTS
东莞市广督实业有限公司
Page
7/9
MODEL
TS66H
SPECIFICATION
在使用的情况下自动焊接
In case the automatic flow soldering is to be used
(1)预热
-------------- 150℃ ~ 175℃, 40 ~ 80 sec
Preheat -------------- 150℃ ~ 175℃, 40 ~ 80 sec
(2)峰值温度----- 260℃ (max)
Peak temperature ----- 260℃ (max)
(3)焊接区温度------ 260℃, 1 ~ 4 sec, 2 times (max)
Soldering area temperature ------ 260℃, 1 ~ 4 sec, 2 times (max)
T:℃
7.2
自动焊接
Automatic
soldering
280
260℃ max
240℃
210
140
170℃
140℃
70
Time:S
5-6minute
8、
8.1
8.2
8.3
8.4
8.5
Other precautions其他注意事项
印刷基板的安装孔尺寸参见产品图。
Follow recommended P.W.B. piercing plan in outside drawing page.
注意不要施加超负荷的压力或晃动开关。
Please be cautions not to give excessive static load or shock to swiches.
进行焊接过程中,不可以用溶剂或类似品清洗开关
Following the soldering process,do not try to clean the switch with a solvent or the like.
防止助焊剂从开关的顶端渗入
Safeguard the switch assembly against flux penetration from its topside.
保管时尤其应注意避开高湿高温和有腐蚀性气体的环境。如需要长时间保存,请不要打开包装箱。
Preservation under high temperature and high high humidity or corrosive gas should be
avoided Especially . When you need to preserve for a long period ,do not open the carton.
8.5
9.5
10.5
12.0
8.0
9.0
10.0
11.0
50mA DC12V
≤100m Ω
250±40gf
0.25±0.1m
≥100M Ω
≥250VAC/1min
≥30000次
接触电阻
Contact resistance
按力
Operating force
行程
travel
绝缘电阻
Insulated resistance
介电强度
Dielectric strength
寿命
Endurance
mm
单位
UNIT
重量
WEIGHT
2017.05.17
2017.05.17
2017.05.17
设计 DESIGN
审核 CHECKED
批准 APPROVED
签名
APPROVED
1:1
更改文件号
REVISION
比例
SCALE
处数
FREQUENCY
日期
DATE
标记
SING
FIRST VIEW
第一视角
>0.5 ~2
>2 ~5
表面处理/颜色
FINSH/COLOR
镀银
数量
QTY
黑色
1
±0.30 东莞市广督实业有限公司
±0.5° DONGGUAN KIINGTEK LNDUSTRIAL CO.,LTD.
TS66H
型号/MODEL:
轻触开关
TACTILE SWITCH
名称/NAME:
材质
MATERIAL
黄铜
Page
8/9
MODEL
TS66H
角度
ANGLE
±0.10
±0.25
一般公差
GENERAL TOLERANCE
名称
DESCRIPTION
>5~10
项目
ITEM
卡件
A
复银
1
1
PPA
磷铜
弹片
本体
B
C
黑色
镀锡锑
1
1
铁盖板
盖板
按钮
D
E
PCB.WELDING DRAWING
The Main Thchnology Performance
额定电流、电压
Rate voltage.current
PCB.焊接图
PPA
电路图
CIRCUIT DIAGRAM
主要技术参数、性能
6.5
7.5
7.0
5.5
5.0
6.0
H
4.5
H
4.3
东莞市广督实业有限公司
SPECIFICATION
外形、结构图
箱式包装
1K PCS
格: ~~~~~~~
量: 1000pcs
: TACTILE SWITCH
每盒 袋装
每盒 袋装
每袋 装
干燥剂
每袋 装
R O S H
本产品按标准检验合格准予出厂
生产批号:~~~~~~~~~
规
数
产品名称:轻触开关
合格证
每箱20盒装
每箱20盒装
轻触开关
东莞市广督实业有限公司
Page
9/9
MODEL
TS66H
SPECIFICATION
载带包装图
很抱歉,暂时无法提供与“TS6685H-250GF”相匹配的价格&库存,您可以联系我们找货
