SRVPB-A05-H
SRVPB-A05-H
    JST
    Housings
    胶壳及附件 5Pin 1Row 灰色
SRVPB-A05-H 数据手册
SRVCONNECTOR Wire-to-wire/Sealed Connectors Features ●2 circuits to 5 circuits, Wire-to-Wire Connection ●Connector Position Assurance (CPA) Mechanism ●Sealed Inline Connector ●1.2 Clean Body Terminals ●Designed for Small Packaging 1.2 Sealed Connector Specifications ¡Current rating: 7 A AC, DC max. ¡Voltage rating: 14 V AC, DC ¡Temperature range: -40°C to +125°C    (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/ 8.0 mΩ max. After environmental tests/ 8.0 mΩ max. ¡Insulation resistance: 100 MΩ min. ¡Withstanding voltage: 1,000 VAC/minute ¡Applicable wire: FLR2X-B 0.35 mm2 to 0.75 mm2 ∗ Compliant with ELV/RoHS . ∗ Contact JST for details. 1 SRV CONNECTOR Female terminal Applicable wire range Model No. Conductor (mm2) Insulation O.D. (mm) Gage Size 1670144-1 or equivalent 0.5 to 0.75 1.4 to 1.9 18-20AWG 1534594-1 or equivalent 0.35 1.2 to 1.4 22AWG Material and Finish Copper alloy, tin-plated (refer to TE Connectivity for details) Note: Contact JST for details. 16.5 Female connector ¡2 circuits (Key D) ¡3 circuits (Key C) (0.97) 1 ¡5 circuits (Key A) (0.97) (4.47) 1 5 (2.72) ¡5 circuits (Key D) 1 5 ¡4 circuits (Key B) (0.78) 5 27.7 1 6.9 (1.8) Color of Housing and Back Cover 1 5 Circuits Model No. Key Q’ty/box 2 SRVPB-D02-K D 6,000 Black 3 SRVPB-C03-N C 6,000 Brown 4 SRVPB-B04-S B 6,000 Natural 5 SRVPB-A05-H A 6,000 Light gray 5 SRVPB-D05-K D 6,000 Black Material and Finish Housing: Glass-filled PBT TPA: Glass-filled PBT, Red Matte seal: Silicone, Green Back cover: Glass-filled PBT 2 5 SRV CONNECTOR Male terminal Applicable wire range Model No. Conductor (mm2) Insulation O.D. (mm) Gage Size 1718350-1 or equivalent 0.5 to 0.75 1.4 to 1.9 18-20AWG 1718348-1 or equivalent 0.35 1.2 to 1.4 22AWG Material and Finish Copper alloy, tin-plated (refer to TE Connectivity for details)   Note: Contact JST for details. Male connector (47.5) 29.54 ¡2 circuits (Key D) ¡3 circuits (Key C) (0.97) (0.78) ¡4 circuits (Key B) (2.72) 1 Color of Housing and Back Cover 2 SRVWSB-02A-DK D 900 Black 3 SRVWSB-03A-CN C 900 Brown 4 SRVWSB-04A-BS B 900 Natural 5 SRVWSB-05A-AH A 900 Light gray 5 SRVWSB-05A-DK D 900 Black 5 Q’ty/box 1 Key 5 Model No. ¡5 circuits (Key A) (4.47) 1 Circuits 5 (16.5) (2.3) ¡5 circuits (Key D) (0.97) Material and Finish 3 1 Note: Tolerances are non-cumulative: ±0.05 mm for all centers. 5 (55.9) 1 Assembly Layout 5 Housing: Glass-filled PBT TPA: Glass-filled PBT, Red Ring seal: Silicone, Green Back cover: Glass-filled PBT CPA: Glass-filled PBT, Red Mat seal: Silicone, Green Retainer clip: Glass-filled PBT, Natural
SRVPB-A05-H 价格&库存
很抱歉,暂时无法提供与“SRVPB-A05-H”相匹配的价格&库存,您可以联系我们找货
SRVPB-A05-H
    • 1000+4.79860
    库存:7000
    SRVPB-A05-H
      库存:295
